14-Cloud Connection Command Reference
HomeSupportWirelessWBC Series Multiservice Access ControllersReference GuidesCommand ReferencesH3C WBC Series Multservice Access Controllers Command References(E5448)-6W10014-Cloud Connection Command Reference
01-Cloud connection commands
01-Cloud connection commands 75.30 KB
cloud-management backup-server domain
Use cloud-management backup-server domain to specify a backup cloud server by its domain name.
Use undo cloud-management backup-server domain to remove one or all backup cloud servers.
cloud-management backup-server domain domain-name
undo cloud-management backup-server domain [ domain-name ]
No backup cloud server is specified.
domain-name: Specifies a backup cloud server by its domain name, a case-sensitive string of 1 to 253 characters. If you do not specify this parameter in the undo cloud-management backup-server domain command, all backup cloud servers will be deleted.
Before configuring this command, make sure a DNS server is configured to translate domain names.
You can specify one primary server by using the cloud-management server domain command and a maximum of eight backup servers by repeating the cloud-management backup-server domain command.
When establishing a cloud connection, the device connects to one of the primary and backup servers according to the sequence in which they are specified. The first specified server has the highest priority. When the connected server fails, the device switches to another server and does not switch back to the original server even if the original server recovers.
To view the connected server, execute the display cloud-management state command.
# Specify the server with domain name 123.com as a backup cloud server.
[Sysname] cloud-management backup-server domain 123.com
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the cloud server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 10 to 600 seconds.
If the device does not receive a response from the cloud server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management ping
Use cloud-management ping to set the interval at which the local device sends ping packets to the cloud server.
Use undo cloud-management ping to restore the default.
cloud-management ping interval
The local device sends ping packets to the cloud server at intervals of 60 seconds.
interval: Specifies the interval at which the local device sends ping packets to the cloud server, in the range of 10 to 600 seconds.
After the connection to the cloud server is established, the local device sends ping packets to the server periodically to prevent NAT entry aging. Reduce the interval value if the network condition is poor or the NAT entry aging time is short.
The cloud server does not respond to ping packets.
# Configure the local device to send ping packets to the cloud server at intervals of 120 seconds.
[Sysname] cloud-management ping 120
Use cloud-management server domain to configure the domain name of the cloud server.
Use undo cloud-management server domain to restore the default.
cloud-management server domain domain-name
The domain name of the cloud server is not configured.
domain-name: Specifies the domain name of the cloud server, a case-sensitive string of 1 to 253 characters.
Before you configure the domain name of the cloud server, make sure a DNS server is configured to translate the domain name.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the cloud server as lvzhouv3.h3c.com.
[Sysname] cloud-management server domain lvzhouv3.h3c.com
cloud-management server password
Use cloud-management server password to set the password for establishing cloud connections to the cloud server.
Use cloud-management server password to restore the default.
cloud-management server password { cipher | simple } string
undo cloud-management server password
No password is set for establishing cloud connections to the cloud server.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext form is a case-sensitive string of 1 to 63 characters. The encrypted form is a case-sensitive string of 1 to 117 characters.
After you change the password, the device terminates the cloud connections that have been established (if any) and uses the new password to establish cloud connections.
A device can use either of the following methods to obtain the password for establishing cloud connections to the cloud server:
·     Execute this command on the device to specify the password for establishing cloud connections to the cloud server.
·     Configure VLAN interface 1 of the device as a DHCP client and the cloud server as the DHCP server. The device obtains the IP address of the DHCP server and parses the option 252 field in the DHCP packets to obtain the password for connection to the cloud server. For more information about the option 252 field, see DHCP configuration in Network Connectivity Configuration Guide.
The password obtained through DHCP has a higher priority than the password configured manually.
If a device obtains the password for connection to the cloud server through DHCP after establishing a cloud connection to the cloud server with the manually configured password, the device performs the following tasks:
·     If the automatically obtained and manually configured passwords are identical, the device retains the cloud connection.
·     If the automatically obtained and manually configured passwords are different, the device tears down the cloud connection and then establishes a cloud connection to the cloud server with the automatically obtained password.
# Set the password for establishing cloud connections to the cloud server to 12345678 in plaintext format.
[Sysname] cloud-management server password simple 12345678
cloud-management server port
Use cloud-management server port to specify the TCP port number used to establish cloud connections.
Use undo cloud-management server port to restore the default.
cloud-management server port port-number
TCP port number 19443 is used to establish cloud connections.
port-number: Specifies a TCP port number in the range of 1 to 65535.
After you change the TCP port number, the device terminates the existing cloud connection and uses the new TCP port number to re-establish a cloud connection to the cloud server.
# Set the TCP port number used to establish cloud connections to 80.
[Sysname] cloud-management server port 80
cloud-management unbinding-code
Use cloud-management unbinding-code to send the verification code for device unbinding to the cloud server.
cloud-management unbinding-code code
code: Specifies the verification code obtained from the cloud server. The verification code is a case-sensitive string of 16 characters.
A device can be registered on the cloud server by only one user.
To register a device that has been registered by another user, you need to take the following steps:
1.     Obtain a verification code for device unbinding from the cloud server.
2.     Execute this command on the device to send the verification code to the cloud server.
3.     Register the device on the cloud server.
# Send the verification code for device unbinding to the cloud server.
[Sysname] cloud-management unbinding-code A6B9C3C2D5A8Z1S7
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state                      : Established
Device state                                : Request_success
Cloud server address                        : 139.217.27.153
Cloud server domain name                    : oasis.h3c.com
Cloud connection mode                       : Https
Cloud server port                           : 19443
Connected at                                : Wed Jan 27 14:18:40 2018
Duration                                    : 00d 00h 02m 01s
Process state                               : Message received
Failure reason                              : N/A
Last down reason                            : socket connection error (Details:N/A)
Last down at                                : Wed Jan 27 13:18:40 2018
Last report failure reason                  : N/A
Last report failure at                      : N/A
Dropped packets after reaching buffer limit : 0
Total dropped packets                       : 1
Last report incomplete reason               : N/A
Last report incomplete at                   : N/A
Buffer full count                           : 0
Cloud connection state: Unconnected, Request, and Established.
Device state
Local device state:
·     Idle—In idle state.
·     Connecting—Connecting to the cloud server.
·     Request_CAS_url—Sent a central authentication service (CAS) URL request.
·     Request_CAS_url_success—Requesting CAS URL succeeded.
·     Request_CAS_TGT—Sent a ticket granting ticket (TGT) request.
·     Request_CAS_TGT_success—Requesting TGT succeeded.
·     Request_CAS_ST—Sent a service ticket (ST) request.
·     Request_CAS_ST_success—Requesting ST succeeded.
·     Request_cloud_auth—Sent an authentication request.
·     Request_cloud_auth_success—Authentication succeeded.
·     Register—Sent a registration request.
·     Register_success—Registration succeeded.
·     Request—Sent a handshake request.
·     Request_success—Handshake succeeded.
IP address of the cloud server.
Domain name of the cloud server.
Cloud server port
Connected at
Time when the cloud connection was established.
Duration
Duration since the establishment of the cloud connection.
Process state
Cloud connection processing state:
·     DNS not parsed.
·     DNS parsed.
·     Message not sent.
·     Message sent.
·     Message not received.
·     Message received.
Failure reason
Cloud connection failure reason:
·     DNS parse failed.
·     Socket connection failed.
·     SSL creation failed.
·     Sending CAS url request failed.
·     Sending CAS TGT failed.
·     Sending CAS ST failed.
·     Sending cloud auth failed.
·     Sending register failed.
·     Processing CAS url response failed.
·     Processing CAS TGT response failed.
·     Processing CAS ST response failed.
·     Processing cloud auth response failed.
·     Processing register response failed.
·     Sending handshake request failed.
·     Processing handshake failed.
·     Sending websocket request failed.
·     Processing websocket packet failed.
Last down reason
Reason for the most recent cloud connection interruption:
·     Device or process rebooted.
·     Socket connection error.
·     Configuration changed.
·     Received websocket close packet from cloud.
·     Keepalive expired.
·     Packet processing failed.
·     Main connection went down.
·     Cloud reset connection.
·     Memory reached threshold.
Last down at
Time when the cloud connection went down most recently.
Reason for the most recent cloud connection packet sending failure:
·     Tunnel is being deleted.
·     Tunnel socket is invalid.
·     Failed to convert string to json.
·     Failed to convert json to string.
·     Failed to create message node.
·     Tunnel is not ready.
·     Failed to create packet buffer.
·     SSL sending failure.
If the reason is SSL sending failure, one of the following detailed reason will be displayed:
·     ssl error none.
·     ssl error ssl.
·     ssl error read.
·     ssl error write.
·     ssl error x509 lookup.
·     ssl error syscall.
·     ssl error zero return.
·     ssl error connect.
·     ssl error accept.
Time when the most recent cloud connection packet sending failure occurred.
Number of packets that are dropped because the CMTNL buffer limit is reached.
Total number of dropped packets.
Reason for the most recent unfinished packet sending:
·     Interrupted system call.
·     Socket buffer is full.
Time when the most recent unfinished packet sending occurred.
Buffer full count
Number of times that the buffer becomes full.
