- 03-Layer 2-LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface configuration commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-DRNI commands
- 06-Port isolation commands
- 07-VLAN commands
- 08-MVRP commands
- 09-Loopback, null, and inloopback interface commands
- 10-QinQ commands
- 11-VLAN mapping commands
- 12-Loop detection commands
- 13-Spanning tree commands
- 14-LLDP commands
- 15-L2PT commands
- 16-Service loopback group commands
- 17-Cut-through Layer 2 forwarding commands
| 04-Ethernet link aggregation commands | 258.90 KB |
display link-aggregation load-sharing mode
display link-aggregation load-sharing path
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
lacp default-selected-port disable
link-aggregation auto-aggregation enable
link-aggregation global load-sharing algorithm
link-aggregation global load-sharing mode
link-aggregation global load-sharing offset
link-aggregation global load-sharing seed
link-aggregation global load-sharing tunnel
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing ignore
link-aggregation load-sharing mode local-first
link-aggregation management-port
link-aggregation management-subnet
link-aggregation management-vlan
link-aggregation port-priority
link-aggregation selected-port maximum
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Last 300 seconds input: 6900 packets/sec 885160 bytes/sec 0%
Last 300 seconds output: 3150 packets/sec 404430 bytes/sec 0%
Input (total): 5364747 packets, 686688416 bytes
2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal): 5364747 packets, 686688416 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
- ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
- lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
0 packets input, 0 bytes, 0 drops
0 packets output, 0 bytes, 0 drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
Interface Link Speed Duplex Type PVID Description
BAGG1 DOWN auto A A 1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
Bridge-Aggregation1 |
Layer 2 aggregate interface name. |
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
IPv6 packet frame type |
IPv6 packet framing format. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps. |
Port priority |
Port priority of the interface. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
Port link-type |
Port link type: · Access. · Trunk. · Hybrid. |
Tagged VLANs |
VLAN whose packets are sent out of this interface with a tag. |
Untagged VLANs |
VLAN whose packets are sent out of this interface without a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input/output rate |
Average input or output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received or sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received or sent on the interface. |
Line protocol state |
Data link layer state of the interface: · UP. · DOWN. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Brief information on interfaces in bridge mode |
Brief information about Layer 2 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the LACP system priority (0x8000 in this sample output) and the LACP system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when aggregate interfaces of the corresponding type exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
0 (default)
Link-aggregation load-sharing offset:
0 (default)
Link-aggregation load-sharing seed:
0x0 (default)
Tunneled traffic load-sharing mode:
Inner (default)
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
2
3
0x3ff
Inner
destination-mac address, source-mac address
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 10. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 10
Bridge-Aggregation10 load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 2 aggregation group 10. This example displays a user-configured setting.
Link-aggregation load-sharing algorithm |
Link aggregation load sharing algorithm. By default, this field displays the default setting. If you have configured the load sharing algorithm, this field displays the configured algorithm. |
Link-aggregation load-sharing offset |
Hash offset to adjust the load sharing hash results on link aggregations. By default, this field displays the default setting. If you have configured a hash offset, this field displays the configured offset value. |
Link-aggregation load-sharing seed |
Link aggregation load sharing hash seed. By default, this field displays the default setting. If you have configured the load sharing hash seed, this field displays the configured seed. |
Tunneled traffic load-sharing mode |
Load sharing mode for tunneled traffic on aggregate links. By default, this field displays the default setting. If you have configured a load sharing mode for tunneled traffic, this field displays the configured mode. |
Link-aggregation load-sharing mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic. If you have configured the global link-aggregation load sharing mode, this field displays the configured mode. |
Bridge-Aggregation10 load-sharing mode |
Link-aggregation load sharing mode of Layer 2 aggregation group 10. By default, this field displays the global link-aggregation load sharing modes. If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode. |
Route-Aggregation10 load-sharing mode |
Link-aggregation load sharing mode of Layer 3 aggregation group 10. By default, this field displays the global link-aggregation load sharing modes. If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode. |
Layer 2 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 2 traffic. By default, Layer 2 traffic is load shared based on the source MAC and destination MAC addresses, and EtherType value. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. By default, Layer 3 traffic is load shared based on the source IP and destination IP addresses, protocol number, and source and destination ports. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
Use display link-aggregation load-sharing path to display the outgoing physical interface selected for a traffic flow.
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ethernet-type type-number | ip-protocol protocol-id | source-mac mac-address | source-port port-id | vlan vlan-id } *
interface-number: Specifies an existing aggregate interface by its number.
ingress-port interface-type interface-number: Specifies an ingress port by its type and number. The ingress port must be a physical port.
route: Displays forwarding information about Layer 3 traffic. If you do not specify this keyword, the command displays forwarding information about Layer 2 traffic.
Traffic pattern parameters:
· destination-ip ip-address: Specifies a destination IPv4 address.
· destination-ipv6 ipv6-address: Specifies a destination IPv6 address.
· source-ip ip-address: Specifies a source IPv4 address.
· source-ipv6 ipv6-address: Specifies a source IPv6 address.
· destination-mac mac-address: Specifies a destination MAC address in H-H-H format.
· destination-port port-id: Specifies a destination port number in the range of 1 to 65535.
· ethernet-type type-number: Specifies an Ethernet type code in the range of 1 to 65535.
· ip-protocol protocol-id: Specifies an IP protocol by its ID in the range of 0 to 255.
· source-mac mac-address: Specifies a source MAC address in H-H-H format.
· source-port port-id: Specifies a source port number in the range of 1 to 65535.
· vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
IMPORTANT: For correctness of the command output, make sure the values of the specified parameters match the fields of the target traffic flow. |
To obtain correct outgoing physical interface information, you must specify the same traffic pattern parameters as in the load sharing mode displayed by using the display link-aggregation load-sharing mode command.
If a parameter required for selecting the egress port is not specified, the default value of the parameter is used. If the parameter does not have any default values, the parameter is set to 0.
# Display the outgoing physical interface for the specified traffic flow to be sent out of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface bridge-aggregation 1 ingress-port twenty-fivegige 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 vlan 20 ethernet-type 0800 source-ip 10.100.0.2 destination-ip 10.100.0.1 ip-protocol 253
Load sharing mode: packet type-based sharing
Unspecified parameters are set to 0.
Load-sharing parameters:
Ethernet type: 0x0800
Ingress port: Twenty-FiveGigE1/0/1
Destination MAC: 0000-fc00-0001
Source MAC: 0000-fc00-0002
Destination IP: 10.100.0.1
Source IP: 10.100.0.2
IP protocol: 253
VLAN: 20
Egress port: Twenty-FiveGigE1/0/3
Load sharing mode: |
Load sharing mode set for the aggregation group: · destination-mac—Traffic is load shared based on destination MAC addresses. · source-mac—Traffic is load shared based on source MAC addresses. · destination-ip—Traffic is load shared based on destination IP addresses. · source-ip—Traffic is load shared based on source IP addresses. · destination-port—Traffic is load shared based on destination ports. · source-port—Traffic is load shared based on source ports. · mpls-label1—Traffic is load shared based on Layer 1 MPLS labels. · mpls-label2—Traffic is load shared based on Layer 2 MPLS labels. · ingress-port—Traffic is load shared based on ingress ports. · packet type-based sharing—Traffic is load shared automatically based on packet types. If no load sharing mode is set, this field also displays packet type-based sharing. |
Load sharing parameters |
Parameters that the system used in outgoing physical interface selection. |
Egress port |
Outgoing physical interface for the specified traffic flow. If no outgoing physical interface is found, this field displays N/A. |
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about Twenty-FiveGigE 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port twenty-fivegige 1/0/1
G -- Defaulted, H -- Expired
Twenty-FiveGigE1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about Twenty-FiveGigE 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port twenty-fivegige 1/0/2
Twenty-FiveGigE1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
# Display detailed information about all link aggregation member ports that are enabled with automatic assignment.
<Sysname> display link-aggregation member-port auto
Twenty-FiveGigE1/0/3:
Preference Aggregation Interface: Bridge-Aggregation11
Aggregate Interface: Bridge-Aggregation11
Local:
Port Number: 3
Oper-Key: 1
Flag: {ACDEF}
Remote:
System ID: 0x8000, a057-75a2-0100
Port Number: 3
Oper-Key: 1
Flag: {ACDEF}
Received LACP Packets: 3 packet(s)
Sent LACP Packets: 6 packet(s)
Table 5 Command output
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0. · A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive. · B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no. · D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no. · E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no. · F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no. · G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no. · H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Preferred Aggregate Interface |
Aggregate interface to which you prefer to assign the member port during automatic assignment. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the LACP system priority and the LACP system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
RAGG10 S None 1 0 0 NonS
BAGG20 D 0x8000,00e0-fcff-ff01 2 0 0 Shar
Table 6 Command output
Aggregate Interface Type |
Aggregate interface type: · BAGG—Layer 2. · RAGG—Layer 3. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load-sharing. · NonS—Non-load-sharing. |
Actor System ID |
Local system ID, which contains the local LACP system priority and the local LACP system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer LACP system priority and the peer LACP system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Individual Ports |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
This command does not display the interfaces that are enabled with automatic assignment if they have not joined an aggregation group.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
Port Status Priority Index Oper-Key Flag
WGE1/0/1 S 32768 61 2 {ACDEF}
WGE1/0/2 S 32768 62 2 {ACDEF}
WGE1/0/3 S 32768 63 2 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
WGE1/0/1(R) 32768 111 2 0x8000, 000f-e267-57ad {ACDEF}
WGE1/0/2 32768 112 2 0x8000, 000f-e267-57ad {ACDEF}
WGE1/0/3 32768 113 2 0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
Port Status Priority Oper-Key
WGE1/0/1(R) S 32768 1
WGE1/0/2 S 32768 1
WGE1/0/3 S 32768 1
Table 7 Command output
Loadsharing Type |
Port Status |
Port state: · Selected. · Unselected. · Individual. |
Port |
Port type: · Auto port—The port is enabled with automatic assignment. · Management port—The port is a management port. · Reference port—The port is a reference port. |
Flags |
Name of the aggregate interface. |
Creation Mode |
Creation mode of the dynamic aggregate interface: · Auto. · Manual. |
Aggregation Mode |
Management VLANs |
Management VLANs. If no management VLANs are specified, this field displays None. |
System ID |
Local system ID, containing the local LACP system priority and the local LACP system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Index—Port index. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Index and Flag fields are not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port. · Priority—Priority of the peer port. · Index—Index of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An interface allows jumbo frames with a maximum length of 9416 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value range for this argument is 1536 to 9416.
# Allow jumbo frames on Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] lacp period short
lacp select speed
Use lacp select speed to configure a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection.
Use undo lacp select speed to restore the default.
lacp select speed
Port ID is the prioritized criterion for reference port selection in a dynamic aggregation group.
CAUTION: Changing reference port selection criteria might cause transient traffic interruption. When you use this command, make sure you understand its impact on your network. |
This command enables a dynamic aggregation group to select a high-speed member port as the reference port.
You must execute this command at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
This command takes effect only on dynamic aggregate interfaces. On a static aggregate interface, you can execute this command, but the setting cannot take effect.
# Specify port speed as the prioritized criterion for reference port selection on Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
All S-MLAG devices must use the same LACP system MAC address.
The LACP system MAC address configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system MAC address to send LACPDUs. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the LACP system priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The LACP system priority is 32768.
priority: Specifies the LACP system priority in the range of 0 to 65535. The smaller the value, the higher the LACP system priority.
All S-MLAG devices must use the same LACP system priority.
# Set the LACP system priority to 64.
[Sysname] lacp system-priority 64
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
For DRNI to operate correctly, do not use this command on a DR system.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
link-aggregation bfd ipv4
Use link-aggregation bfd ipv4 to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ip-address destination ip-address
BFD is disabled for an aggregation group.
source ip-address: Specifies the unicast source IP address of BFD sessions. The source IP address cannot be 0.0.0.0.
destination ip-address: Specifies the unicast destination IP address of BFD sessions. The destination IP address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
# Enable BFD for Layer 2 aggregation group 1, and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation global load-sharing algorithm to configure a link aggregation load sharing algorithm.
Use undo link-aggregation global load-sharing algorithm to restore the default.
link-aggregation global load-sharing algorithm algorithm-number
No link aggregation load sharing algorithm is configured.
algorithm algorithm-number: Specifies an algorithm by its number. The value range for the algorithm-number argument is 1 to 13.
Each load sharing algorithm represents a CRC calculation method.
When you try each algorithm or algorithm and seed combination, use the display counters command to verify the load sharing result.
# Specify algorithm 1 as the link aggregation load sharing algorithm.
[Sysname] link-aggregation global load-sharing algorithm 1
display counters
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | mpls-label1 | mpls-label2 | source-ip | source-mac | source-port } *
Packets are load shared depending on their packet type, as follows:
· Layer 2 frames are load shared based on the source and destination MAC addresses, and EtherType value.
· Layer 3 packets are load shared based on the following information:
¡ Source and destination IP addresses.
¡ Source and destination port numbers.
¡ IP protocol number.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
ingress-port: Distributes traffic based on ingress ports.
mpls-label1: Distributes MPLS traffic based on Layer 1 labels.
mpls-label2: Distributes MPLS traffic based on Layer 2 labels.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
The following are the global load sharing modes supported on the device:
· Default mode (load sharing mode automatically determined based on the packet type).
· Source IP.
· Destination.
· Source MAC.
· Destination MAC.
· Layer 1 MPLS label.
· Layer 2 MPLS label.
· Source IP and destination IP.
· Source IP and source port.
· Destination IP and destination port.
· Layer 1 MPLS label and Layer 2 MPLS label.
· Source IP, source port, destination IP, and destination port.
· Any combination of ingress port, source MAC, and destination MAC.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
Use link-aggregation global load-sharing offset to set a hash offset to adjust the load balancing hash results on link aggregations.
Use undo link-aggregation global load-sharing offset to restore the default.
link-aggregation global load-sharing offset offset-value
No hash offset is configured for load sharing on link aggregations.
offset-value: Specifies a hash offset. The value range for this argument is 1 to 63.
IMPORTANT: Misuse of this command causes unbalanced traffic distribution. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
If undesirable traffic imbalance occurs on link aggregations, you can use this command to adjust the load sharing results on link aggregations.
# Set the hash offset to 2 for the load balancing hash results on link aggregations.
<Sysname> system
[Sysname] link-aggregation global load-sharing offset 2
Use link-aggregation global load-sharing seed to configure a link aggregation load sharing hash seed.
Use undo link-aggregation global load-sharing seed to restore the default.
link-aggregation global load-sharing seed seed-number
No hush seed is configured.
seed seed-number: Specifies a seed. The value range for the seed-number argument is 1 to FFFFFFFF.
This command is intended to help you optimize load sharing performance when the default load sharing mode is used. It does not take effect on per-flow load sharing.
The load sharing hash seed is used in hashing.
You can use a load sharing algorithm and a hash seed individually or in combination to obtain the optimal load sharing performance.
# Specify 1023 (3FF in hexadecimal format) as the link aggregation load sharing hash seed.
[Sysname] link-aggregation global load-sharing seed 3FF
display counters
Use link-aggregation global load-sharing tunnel to set the load sharing mode for tunneled traffic on link aggregations.
Use undo link-aggregation global load-sharing tunnel to restore the default.
link-aggregation global load-sharing tunnel { inner | outer }
Tunneled traffic is distributed based on the inner IP header on aggregate links.
inner: Distributes tunneled traffic based on the inner IP header.
outer: Distributes tunneled traffic based on the outer IP header.
This command sets the criterion used by aggregation groups to distribute tunneled traffic for load sharing.
# Set the load sharing mode to inner IP header for tunneled traffic on link aggregations.
<Sysname> system
[Sysname] link-aggregation global load-sharing tunnel inner
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to remove the specified ignored VLANs for a Layer 2 aggregate interface.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command takes effect only when the link type of the Layer 2 aggregate interface is hybrid or trunk.
By default, you cannot add a port to a Layer 2 link aggregation group if it has a different VLAN permit state or tagging mode than the aggregate interface.
To have a port participate in a Layer 2 aggregation despite its difference with the aggregate interface in the settings of a VLAN, configure that VLAN as an ignored VLAN.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
· The port is shut down by using the shutdown command.
· The slot that hosts the port reboots, and the aggregation group spans multiple slots.
NOTE: The device does not redirect traffic to member ports that become Selected during the traffic redirection process. |
This feature ensures zero packet loss for known unicast traffic, but it does not protect other types of traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
As a best practice, enable link-aggregation traffic redirection on a per-interface basis. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing ignore to specify ignored packet fields for default link-aggregation load sharing.
Use undo link-aggregation load-sharing ignore to restore the default.
link-aggregation load-sharing ignore { destination-ip | destination-mac | destination-port | ethernet-type | ingress-port | ip-protocol | mpls-label1 | mpls-label2 | mpls-label3 | source-ip | source-mac | source-port | vlan-id } *
No ignored packet fields are specified for default link-aggregation load sharing.
destination-ip: Specifies the destination IP address.
destination-mac: Specifies the destination MAC address.
destination-port: Specifies the destination port.
ethernet-type: Specifies the EtherType value.
ingress-port: Specifies the ingress port.
ip-protocol: Specifies IP protocol type.
mpls-label1: Specifies Layer 1 MPLS label.
mpls-label2: Specifies Layer 2 MPLS label.
mpls-label3: Specifies Layer 3 MPLS label.
source-ip: Specifies the source IP address.
source-mac: Specifies the source MAC address.
source-port: Specifies the source port.
vlan-id: Specifies the VLAN ID.
In default load sharing mode, an aggregation group might fail to load share traffic in a balanced manner. To resolve the problem, you can configure the device to ignore specific packet fields for link-aggregation load sharing. The specified packet field values are ignored in load sharing calculation.
# Configure the device to ignore the EtherType value for default link-aggregation load sharing.
[Sysname] link-aggregation load-sharing ignore ethernet-type
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-mac | source-ip | source-mac } * | flexible | per-packet | resilient }
The group-specific load sharing mode is the same as the global load sharing mode.
flexible: Automatically chooses a load sharing mode depending on the packet type. For example, the load sharing mode differs for Layer 2, IPv4, IPv6, and MPLS packets.
per-packet: Distributes traffic on a per-packet basis.
resilient: Redistributes as less traffic as possible when a link state change occurs to minimize its impact on services. In this mode, an aggregation group distributes traffic based on the default load sharing mode when no link change occurs. When a link fails, the system rehashes the traffic on the failed link across the remaining Selected links. Because the existing traffic on the Selected links is not rehashed as in other modes, impact on the ongoing services is minimized. When the failed link recovers, the system rehashes part of the traffic on the existing Selected links to the recovered link. Because not all traffic is rehashed, the traffic distribution pattern might differ from what it was before the link failure. This keyword is available in Release 6555P02 and later.
The following are the load sharing modes supported in aggregate interface view:
· Load sharing mode automatically determined based on the packet type.
· Source IP.
· Source MAC and destination MAC.
· Resilient load sharing.
When you configure resilient load sharing, follow these restrictions and guidelines:
· In resilient load sharing mode, an aggregation group distributes traffic based on the default load sharing mode if no link change occurs.
· Before you enable resilient load sharing on an aggregate interface, make sure its aggregation group does not contain Selected member ports. If Selected member ports exist, shut down the aggregate interface.
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation.
Local-first load sharing is enabled for link aggregation.
Use local-first load sharing in a multidevice link aggregation scenario to distribute traffic preferentially across member ports on the ingress card or device. Local-first load sharing takes effect only on known unicast traffic.
If you disable local-first load sharing, packets on an aggregate interface are load shared among all its Selected ports on IRF member devices.
# Disable local-first load sharing for link aggregation.
[Sysname] undo link-aggregation load-sharing mode local-first
Use link-aggregation management-port to configure a management port for an aggregation group.
Use undo link-aggregation management-port to restore the default.
A port does not act as a management port.
You can execute this command on multiple member ports of an aggregation group. The system chooses the member port with the smallest port number as the management port of the aggregation group.
# Configure Twenty-FiveGigE 1/0/1 as the management port of its aggregation group.
[Sysname-Twenty-FiveGigE1/0/1] link-aggregation management-port
Use link-aggregation management-subnet to specify a link aggregation management subnet.
Use undo link-aggregation management-subnet to remove a link aggregation management subnet.
link-aggregation management-subnet ip-address { mask | mask-length }
undo link-aggregation management-subnet ip-address { mask | mask-length }
No link aggregation management subnets are specified.
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies the subnet mask in dotted decimal notation.
mask-length: Specifies the mask length. The value range is 0 to 32.
Typically, an aggregate interface distributes traffic across its Selected member ports. The uplink and downlink traffic of a host might be distributed to different member ports. To make sure the bidirectional traffic of a subnet traverses the same member port, you can exclude that subnet from load sharing by specifying it as a link aggregation management subnet.
When a link aggregate interface receives an ARP packet from the management subnet, the device looks up the sender IP address in the ARP table for a matching entry.
· If no matching entry exists, the device creates an ARP entry on the aggregation member port from which the packet came in. This mechanism ensures that the returned downlink traffic will be forwarded out of the member port that received the uplink traffic.
· If an ARP entry already exists on a different port than the link aggregate interface or its member ports, the device does not update that ARP entry. Instead, the device broadcasts an ARP request out of all ports to relearn the ARP entry.
When a link aggregate interface sends an ARP packet to the management subnet, the device sends the packet out of all Selected member ports of the link aggregate interface.
You can configure a maximum of 20 management subnets.
To ensure correct packet forwarding, delete all ARP entries of a subnet before you specify it as a management subnet or after you remove it from the management subnet list.
If you are using link aggregation management subnets, do not use the following features:
· DRNI. For more information, see Layer 2—LAN Switching Configuration Guide.
· ARP snooping. For more information, see Layer 3—IP Services Configuration Guide.
# Specify 22.1.1.1/8 as a link aggregation management subnet.
[Sysname] link-aggregation management-subnet 22.1.1.1 255.0.0.0
link-aggregation management-vlan
Use link-aggregation management-vlan to specify link aggregation management VLANs.
Use undo link-aggregation management-vlan to remove link aggregation management VLANs.
link-aggregation management-vlan vlan-id-list
undo link-aggregation management-vlan vlan-id-list
No link aggregation management VLANs are specified.
vlan-id-list: Specifies a space-separated list of up to 10 link aggregation management VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
If you execute this command multiple times, the system allows all specified management VLANs whose total number cannot exceed 64.
You cannot specify VLAN 1 as a link aggregation management VLAN.
# Specify VLAN 2 and VLAN 3 as link aggregation management VLANs.
[Sysname] link-aggregation management-vlan 2 3
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
When you change the aggregation mode, make sure you understand the impact of the change on services.
Aggregation mode change might cause Selected member ports to become Unselected.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
link-aggregation port-priority
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface Twenty-FiveGigE 1/0/2.
[Sysname] interface twenty-fivegige 1/0/2
[Sysname-Twenty-FiveGigE1/0/2] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number
The maximum number of Selected ports allowed in an aggregation group is 32.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 32.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
link-aggregation selected-port minimum { min-number | percentage number }
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 32.
percentage number: Sets the minimum percentage of Selected ports in an aggregation group. The value range for the number argument is 1 to 100.
IMPORTANT: After you set the minimum percentage of Selected ports for an aggregation group, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this setting when you configure it on a live network. |
You can set either the minimum number or the minimum percentage of Selected ports for an aggregation group. If you configure both settings on an aggregate interface, the higher Selected port number limit takes effect.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
You must set the same minimum number or minimum percentage of Selected ports at the two ends of an aggregate link.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
· If you do not specify the msec keyword, the value range is 0 to 300 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress link-down events, link-up events, or both. If an event of the specified type persists when the suppression interval expires, the system reports the event.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for an event type, the most recent configuration takes effect on that event type.
When you configure suppression interval settings on an aggregate interface, make sure its peer interface is also an aggregate interface in the same aggregation mode. In addition, the suppression interval settings must be the same between the peer aggregate interfaces.
As a best practice, use the default setting in an S-MLAG environment.
Use this command on an aggregate interface to reduce the impact of interface flapping on upper-layer services, for example, on a DRNI IPP. For more information about IPPs, see Layer 2—LAN Switching Configuration Guide.
# Set the link-down event suppression interval to 8 seconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down 8
# Set the link-down event suppression interval to 8 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down 8
mac-address
Use mac-address to assign a MAC address to an aggregate interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
All Layer 3 aggregate interfaces and subinterfaces on the device use the same default MAC address.
The default MAC address of Layer 3 aggregate interfaces and subinterfaces varies by device. You can use the display interface command to view the MAC address of a Layer 3 aggregate interface or subinterface.
# Assign MAC address 0001-0001-0002 to interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mac-address 1-1-2
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for this argument is 128 to 9008.
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port bridge enable
Use port bridge enable to enable port bridging on a Layer 2 aggregate interface.
Use undo port bridge enable to disable port bridging on a Layer 2 aggregate interface.
port bridge enable
Port bridging is disabled on a Layer 2 aggregate interface.
By default, the device drops a packet if its outgoing interface is the incoming interface where the packet arrived. Port bridging enables a Layer 2 aggregate interface to reflect a packet back when it is both the incoming and outgoing interfaces of that packet.
# Enable port bridging on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port bridge enable
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 1024.
force: Enables the current interface to synchronize attribute configurations from the aggregate interface. If you do not specify this keyword, the current interface does not synchronize attribute configurations from the aggregate interface when it joins the aggregation group. This keyword is supported only on Layer 2 Ethernet interfaces.
auto: Enables automatic assignment.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only. A Layer 3 Ethernet interface can be assigned to a Layer 3 aggregation group only.
An interface can belong to only one aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
The force keyword takes effect only when you assign the interface to an aggregation group. It cannot be saved in the running configuration or a configuration file.
Automatic assignment is available only on Layer 2 and Layer 3 Ethernet interfaces.
When you enable automatic assignment, you can specify a preferred aggregation group, which must be in dynamic mode.
The device assigns the interface to the preferred aggregation group as long as the LACPDUs received on the interface match the peer information of the reference port in the group.
If you do not specify a preferred group or if the preferred group match fails, the device attempts to select a matching group from the existing dynamic aggregation groups. If no match is found, the device creates a dynamic aggregation group based on the LACPDUs and assigns the interface to that aggregation group.
As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
# Assign Layer 2 Ethernet interface Twenty-FiveGigE 1/0/1 to Layer 2 aggregation group 1.
[Sysname-Twenty-FiveGigE1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface Twenty-FiveGigE 1/0/2 to Layer 3 aggregation group 2.
[Sysname-Twenty-FiveGigE1/0/2] port link-aggregation group 2
port s-mlag group
Use port s-mlag group to assign an aggregate interface to an S-MLAG group.
Use undo port s-mlag group to restore the default.
port s-mlag group group-id
An aggregate interface is not in any S-MLAG group.
group-id: Specifies an S-MLAG group number in the range of 1 to 1024.
You can assign only Layer 2 aggregate interfaces in dynamic mode to an S-MLAG group.
Each S-MLAG group can contain only one aggregate interface on each device.
The aggregate interfaces in an S-MLAG group cannot be used as DR interfaces or IPPs in DRNI. For more information about DR interfaces and IPPs, see DRNI configuration in Layer 2—LAN Switching Configuration Guide.
# Assign Bridge-Aggregation 1 to S-MLAG group 1.
[Sysname-Bridge-Aggregation1] port s-mlag group 1
reset counters interface
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics for all interfaces in the system.
If you specify only an aggregate interface type, the command clears statistics for all aggregate interfaces of the specified type.
The bridge-aggregation or route-aggregation keyword is available only when aggregate interfaces of the corresponding type exist on the device.
# Clear the statistics about interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
CAUTION: The shutdown command will disconnect all links established on an interface. Make sure you are fully aware of the impacts of this command when you use it on a live network. |
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
