06-MPLS Command Reference
HomeSupportSwitchesS12500X-AF SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R3606)-6W10006-MPLS Command Reference
04-MPLS TE commands
04-MPLS TE commands 533.45 KB
MPLS TE commands· 1
backup-path exclude-srlg· 1
delete-delay· 1
destination· 2
disable (explicit path view) 3
display explicit-path· 3
display isis mpls te advertisement 4
display isis mpls te configured-sub-tlvs· 8
display isis mpls te network· 8
display isis mpls te tunnel 10
display mpls statistics tunnel-interface· 11
display mpls te binding-sid· 11
display mpls te binding-sid ref-list 12
display mpls te ds-te· 13
display mpls te link-management bandwidth-allocation· 14
display mpls te link-management srlg· 16
display mpls te pce discovery· 16
display mpls te pce lspdb· 19
display mpls te pce parameter 22
display mpls te pce peer 24
display mpls te pce stateful neighbor 26
display mpls te pce statistics· 27
display mpls te segment-routing tunnel path· 29
display mpls te srlg· 30
display mpls te tedb· 31
display mpls te tunnel-interface· 36
display ospf mpls te advertisement 40
display ospf mpls te network· 43
display ospf mpls te pce· 44
display ospf mpls te tunnel 46
display tunnel-bundle· 47
ds-te bc-model 48
ds-te mode· 49
ds-te te-class· 50
exclude-srlg· 52
explicit-path· 52
fast-reroute timer 53
interface tunnel-bundle· 54
link-management periodic-flooding timer 54
member interface· 55
mpls te· 56
mpls te affinity-attribute· 57
mpls te backup· 58
mpls te backup bandwidth· 59
mpls te backup-path· 60
mpls te bandwidth· 61
mpls te bandwidth change thresholds· 62
mpls te binding-sid· 63
mpls te delegation· 64
mpls te enable (interface view) 65
mpls te enable (IS-IS view) 65
mpls te enable (OSPF area view) 66
mpls te fast-reroute· 67
mpls te fast-reroute bypass-tunnel 68
mpls te igp advertise· 69
mpls te igp metric· 70
mpls te igp shortcut 70
mpls te link-attribute· 71
mpls te load-share· 72
mpls te loop-detection· 73
mpls te max-link-bandwidth· 74
mpls te max-reservable-bandwidth· 75
mpls te max-reservable-bandwidth mam·· 76
mpls te max-reservable-bandwidth rdm·· 78
mpls te metric· 79
mpls te passive-delegate report-only· 80
mpls te path· 80
mpls te path verification· 81
mpls te path-metric-type· 82
mpls te priority· 83
mpls te record-route· 84
mpls te reoptimization (tunnel interface view) 85
mpls te reoptimization (user view) 86
mpls te resv-style· 86
mpls te retry· 87
mpls te route-pinning· 88
mpls te service-class· 88
mpls te signaled-name· 89
mpls te signaling· 90
mpls te srlg· 91
mpls te static-cr-lsp· 92
mpls te statistics· 92
mpls te timer retry· 93
mpls te tunnel-attribute prefer 94
nexthop· 94
nextsid· 96
path verification enable· 97
path-metric-type· 97
pce address· 98
pce capability segment-routing· 99
pce deadtimer 100
pce keepalive· 100
pce multi-delegate enable· 101
pce peer delegation-priority· 102
pce peer keychain· 102
pce redelegation-timeout 103
pce request-timeout 104
pce retain initiated-lsp· 105
pce retain lsp-state· 105
pce state-timeout 106
pce static· 107
pce tolerance· 107
pcep type· 108
reset mpls statistics tunnel-interface· 109
reset mpls te pce statistics· 109
snmp-agent trap enable te· 110
switch-delay· 110
te-subtlv· 111
tunnel route-static· 112
tunnel-attribute prefer 113
MPLS TE commands
Use backup-path exclude-srlg to configure CSPF to include the SRLG constraint in the computation of a backup path.
Use undo backup-path exclude-srlg to restore the default.
backup-path exclude-srlg [ preferred ]
CSPF does not include the SRLG constraint in the computation of a backup path.
MPLS TE view
preferred: Prefers to use the SRLG constraint in the backup path computation, and if the computation fails, the SRLG constraint will not be used in the subsequent backup path computation. If you do not specify this keyword, the SRLG constraint must be included in the backup path computation.
If the SRLG constraint is included in path computation, CSPF excludes all links with interfaces which belong to the same SRLG as the protected interface.
In hot-standby SRLSP backup scenarios, executing this command on the tunnel ingress ensures that the links on the primary and backup paths are not in the same SRLG. This improves the reliability of the MPLS TE tunnel.
# Configure CSPF to include the SRLG constraint in the computation of a backup path.
[Sysname] mpls te
[Sysname-te] backup-path exclude-srlg
delete-delay
Use delete-delay to set the time that MPLS TE must wait before deleting the old CRLSP.
Use undo delete-delay to restore the default.
delete-delay time-value
undo delete-delay
MPLS TE must wait 10000 milliseconds before deleting the old CRLSP.
MPLS TE view
time-value: Specifies the time that MPLS TE must wait before deleting the old CRLSP, in the range of 0 to 65535000 milliseconds.
When TE attributes (bandwidth and priority, for example) of an MPLS TE tunnel change, MPLS TE establishes a new CRLSP compliant with the new attributes. MPLS TE uses the make-before-break mechanism to make sure the new CRLSP is established to take over traffic forwarding before deleting the old CRLSP. The mechanism starts a delay timer after traffic is switched to the new CRLSP and does not delete the old CRLSP until the timer expires. If the new CRLSP fails during the delay time, the old CRLSP will not be deleted, so that the traffic can be switched back to the old CRLSP.
MPLS TE uses a PathErr message to report the failure of the new CRLSP from downstream to upstream. The message might not be able to reach the upstream nodes before the old CRLSP is deleted because the downstream nodes are too busy to deliver it. To prevent this problem, use this command to tune the delay time to ensure enough time for the failure to be reported before the old CRLSP is deleted.
# Configure MPLS TE to wait 100000 milliseconds before deleting the old CRLSP during path selection.
[Sysname] mpls te
[Sysname-te] delete-delay 100000
destination
Use destination to configure the destination address for a tunnel bundle interface.
Use undo destination to restore the default.
destination ip-address
undo destination
No destination address is specified for a tunnel bundle interface.
Tunnel bundle interface view
ip-address: Specifies the destination IPv4 address.
When the remote PE have the same address as the tunnel bundle destination, the tunnel bundle can be used as the public tunnel for MPLS L3VPN, MPLS L2VPN, and VPLS.
As a best practice, configure the same destination address for a tunnel bundle interface and its member interfaces. If a tunnel bundle interface and its member interfaces have different destination addresses, traffic cannot be forwarded unless the member interfaces can reach the tunnel bundle interface's destination address.
# Configure the destination address for tunnel bundle interface Tunnel-Bundle 2 as 2.2.2.2.
[Sysname] interface tunnel-bundle 2
[Sysname-Tunnel-Bundle2] destination 2.2.2.2
Use disable to disable an explicit path.
Use undo disable to restore the default.
disable
undo disable
The explicit path is enabled.
Explicit path view
You can use the disable command to prevent an explicit path from being used by a tunnel during explicit path configuration.
# Disable explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] disable
Use display explicit-path to display explicit path information.
display explicit-path [ path-name ]
path-name: Displays information about the explicit path specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all explicit paths.
# Display information about all explicit paths.
<Sysname> display explicit-path
Path Name: path1      Hop Count: 3     Path Status: Enabled
Index     IP Address             Hop Type    Hop Attribute
1         1.1.1.1                Strict      Include
101       2.2.2.2                Loose       Include
201       3.3.3.3                  -         Exclude
Path Name
Name of the explicit path.
Hop Count
Number of nodes specified in the explicit path.
Path Status
Explicit path status:
·     Enabled—The explicit path is available.
·     Disabled—The explicit path is not available.
Index
Index of a node on the explicit path.
IP Address
IP address of a node on the explicit path.
Hop Type
Node type:
·     Strict—The node must be connected directly to its previous hop.
·     Loose—The node can be connected indirectly to its previous hop.
Hop Attribute
Node attribute:
·     Include—The node must be included in the explicit path.
·     Exclude—The node must not be included in the explicit path.
·     Exclude-SRLG—The links in the same SRLG as the specified IP address must not be included in the explicit path.
Use display isis mpls te advertisement to display link and node information in an IS-IS TEDB.
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ]
level-1: Displays link and node information for Level-1 routers.
level-2: Displays link and node information for Level-2 routers.
originate-system system-id: Displays link and node information advertised by the system specified by its system ID, in the format of XXXX.XXXX.XXXX.
local: Displays link and node information advertised by the local device.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays link and node information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays link and node information for both Level-1 and Level-2 routers.
If you do not specify the originate-system system-id option or the local keyword, this command displays link and node information advertised by all systems.
# Display brief link and node information in the IS-IS TEDB for Level-1 routers.
<Sysname> display isis mpls te advertisement level-1
                           TE information for IS-IS(1)
Level-1 TE node and link information
Node total count   : 2
Node index         : 0
  System ID        : 0000.0000.0004
  MPLS LSR ID      : 4.4.4.4
  Node flags       : -/-/R/-
  Link total count : 1
  Link information :
    Neighbor           Frag ID   Link Type   Local Address    Remote Address
    0000.0000.0004.04   0x00      Broadcast   1.1.1.3
Node index         : 1
  System ID        : 0000.0000.0001
  MPLS LSR ID      : 1.1.1.1
  Link information :
    0000.0000.0004.04   0x00      Broadcast   1.1.1.1          --
# Display detailed link and node information in the IS-IS TEDB for Level-1 routers.
<Sysname> display isis mpls te advertisement level-1 local verbose
Node index         : 0
  Link information :
  Link index   : 0
    Neighbor   : 0000.0000.0004.04       Frag ID     : 0x00
    Link type  : Broadcast               Admin group : 0x00000000
    IGP metric : 10                      TE metric   : 10
    Link flags : -/-/-
    Physical bandwidth: 12500000 bytes/sec
    Reservable bandwidth: 0 bytes/sec
    Unreserved bandwidth for each TE class:
      TE class  0: 0 bytes/sec           TE class  1: 0 bytes/sec
      TE class  2: 0 bytes/sec           TE class  3: 0 bytes/sec
      TE class  4: 0 bytes/sec           TE class  5: 0 bytes/sec
      TE class  6: 0 bytes/sec           TE class  7: 0 bytes/sec
      TE class  8: 0 bytes/sec           TE class  9: 0 bytes/sec
      TE class 10: 0 bytes/sec           TE class 11: 0 bytes/sec
      TE class 12: 0 bytes/sec           TE class 13: 0 bytes/sec
      TE class 14: 0 bytes/sec           TE class 15: 0 bytes/sec
    Bandwidth constraint model: Prestandard DS-TE RDM
    Bandwidth constraints:
      BC[00]: 0 bytes/sec                BC[01]: 0 bytes/sec
    Local address: 1.1.1.3
Node index         : 1
  Node flags       : -/-/-/-
  Link information :
  Link index  : 0
    IGP metric: 10                       TE metric   : 10
    Link flags: -/-/-
    Local address: 1.1.1.1
TE information for IS-IS process 1.
Node total count
Total number of nodes that advertised TE information.
Node flags
Node information flags:
·     A—Already synchronized node information with CSPF.
·     S—Ready to synchronize node information with CSPF again after the previous synchronization failed.
·     R—The node is reachable.
·     O—The node is overloaded.
Link total count
Total number of links advertised by the node.
Link information
Link information advertised by the node.
Neighbor
System ID of the neighbor.
Frag ID
LSP fragment number.
Link type
Link type: Broadcast or P2P.
Admin group
Administrator group attribute of the link.
Link flags
Link information flags:
·     A—Already synchronized link information with CSPF.
·     U—Ready to update link information with CSPF again after the previous update failed.
·     D—Ready to delete link information from CSPF again after the previous deletion failed.
·     Prestandard DS-TE RDM.
·     IETF DS-TE RDM.
·     IETF DS-TE MAM.
Local address
Local IP address of the link.
Remote address
Remote IP address of the link.
Use display isis mpls te configured-sub-tlvs to display sub-TLV information for IS-IS TE.
display isis mpls te configured-sub-tlvs [ process-id ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays sub-TLV information for all IS-IS processes.
# Display sub-TLV information for IS-IS TE.
<Sysname> display isis mpls te configured-sub-tlvs
TE sub-TLV information for IS-IS(1)
  Type value of the unreserved sub-pool bandwidth sub-TLV : 251
  Type value of the bandwidth constraint sub-TLV          : 252
TE Sub-TLV Information for IS-IS(1)
DS-TE sub-TLV information for IS-IS process 1.
Use display isis mpls te network to display network information in an IS-IS TEDB.
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ] * [ process-id ]
level-1: Displays network information for Level-1 routers.
level-2: Displays network information for Level-2 routers.
local: Displays network information advertised by the local device.
lsp-id lsp-id: Displays network information for an LSP. The lsp-id argument is the LSP ID in the format of SYSID.Pseudonode ID-fragment num. SYSID represents the system ID of the node or pseudonode that generates the LSP. Pseudonode ID represents ID of the pseudonode. fragment num represents the fragment number of the LSP.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays network information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays network information for both Level-1 and Level-2 routers.
If you do not specify the local keyword or the lsp-id lsp-id option, this command displays all TE network information.
# Display network information in IS-IS TEDBs.
<Sysname> display isis mpls te network
Level-1 network information
LAN ID             : 0000.0000.0004.04
Frag ID            : 0x00
Flags              : -/-/-
Attached routers   : 0000.0000.0001
                     0000.0000.0004
Level-2 Network Information
Frag ID            : 0x00
Flags              : -/-/-
                     0000.0000.0004
LAN ID
Broadcast network ID, in the format of System-ID.Pseudonode-ID.
Frag ID
Flags
State flag for network information:
·     A—Already synchronizes network information with CSPF.
·     U—Ready to update network information with CSPF again after the previous update failed.
·     D—Ready to delete network information from CSPF again after the previous deletion failed.
Use display isis mpls te tunnel to display MPLS TE tunnel interface information for IS-IS.
display isis mpls te tunnel [ level-1 | level-2 ] [ process-id ]
level-1: Displays tunnel interface information for Level-1 routers.
level-2: Displays tunnel interface information for Level-2 routers.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays tunnel information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays IS-IS tunnel interface information for both IS-IS Level-1 and IS-IS Level-2 routers.
# Display MPLS TE tunnel interface information for IS-IS.
<Sysname> display isis mpls te tunnel
                    MPLS-TE tunnel information for IS-IS(1)
                           Level-1 Tunnel Statistics
   Tunnel Name      Auto Route       Destination      Metric
   Tun0             Advertise        2.2.2.2          Relative 0
                           Level-2 Tunnel Statistics
Table 5 Command output
MPLS TE tunnel interface information for IS-IS process 1.
Auto Route
Automatic route advertisement method on the tunnel interface:
·     Advertise—Forwarding adjacency.
·     Shortcut—IGP shortcut.
Destination
Tunnel destination address.
Metric
Metric type and value configured on the tunnel interface:
·     Relative.
·     Absolute.
Use display mpls statistics tunnel-interface to display MPLS TE tunnel traffic statistics.
display mpls statistics tunnel-interface number
number: Specifies a tunnel interface by its number. The value range for this argument is 0 to 70000.
If the type of a tunnel changes, the system restarts traffic statistics collection for the tunnel.
The system performs MPLS TE tunnel traffic statistics based on LSPs. If the LSP of a tunnel is removed, the tunnel traffic statistics is cleared.
# Display MPLS TE tunnel traffic statistics for tunnel interface 0.
<Sysname> display mpls statistics tunnel-interface 0
Tunnel name: Tunnel 0
Output total:
20000 packets, 40000 bytes, 850 drops
Table 6 Command output
drops
Number of packets dropped.
Use display mpls te binding-sid to display MPLS TE tunnel and BSID associations.
display mpls te binding-sid [ label label-value ]
label label-value: Specifies a BSID label in the range of 16 to 1048575. If you do not specify a BSID, this command displays all MPLS TE tunnel and BSID associations.
# Display all MPLS TE tunnel and BSID associations.
<Sysname> display mpls te binding-sid
Label value      Signaling type            Tunnel name
10000            Segment-Routing           Tunnel10
10001            Segment-Routing           Tunnel11
# Display the MPLS TE tunnel associated with BSID 1000.
<Sysname> display mpls te binding-sid label 1000
1000             Segment-Routing           Tunnel1
Table 7 Command output
Label value
BSID associated with the MPLS TE tunnel.
Signaling type
Signaling protocol used to established the tunnel. The value of this field is Segment-Routing.
Tunnel name
Name of the tunnel.
Use display mpls te binding-sid ref-list to display information about the explicit paths that use BSIDs.
display mpls te binding-sid ref-list [ label label-value ]
label label-value: Specifies a BSID label in the range of 0, 3, 16 to 1048575. If you do not specify a BSID, this command displays information about all explicit paths that use a BSID.
# Display information about all explicit paths that use a BSID.
<Sysname> display mpls te binding-sid ref-list
Binding SID: 100             Reference count: 1
Explicit path list:
path123
Binding SID: 200             Reference Count: 3
Explicit path list:
200
201
aaa
# Display information about explicit paths that use BSID 300.
<Sysname> display mpls te binding-sid ref-list label 300
Binding SID: 300             Reference Count: 2
Explicit path list:
path300
path400
Table 8 Command output
Binding SID
BSID of the MPLS TE tunnel.
Reference count
Number of times that the SID was used.
Explicit path list
List of the explicit paths that use the SID.
nextsid
Use display mpls te ds-te to display DS-TE information, including the DS-TE mode, bandwidth constraint (BC) model, and TE classes.
# Display DS-TE information.
<Sysname> display mpls te ds-te
MPLS LSR ID         : 0.0.0.0
MPLS DS-TE mode     : Prestandard
MPLS DS-TE BC model  : RDM
TE Class       Class Type     Priority
0              0              0
1              0              1
2              0              2
3              0              3
4              0              4
5              0              5
6              0              6
7              0              7
8              1              0
9              1              1
10             1              2
11             1              3
12             1              4
13             1              5
14             1              6
15             1              7
Table 9 Command output
MPLS LSR ID
MPLS LSR ID of the device.
MPLS DS-TE mode
DS-TE mode: Prestandard or IETF.
MPLS DS-TE BC model
DS-TE BC model:
·     RDM—Russian Dolls Model.
·     MAM—Maximum Allocation Model.
·     Extended-MAM—Extended Maximum Allocation Model.
TE Class
Serial number of a TE class.
Use display mpls te link-management bandwidth-allocation to display bandwidth information on MPLS TE-enabled interfaces.
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ]
interface interface-type interface-number: Displays bandwidth information on the interface specified by its type and number. If you do not specify this option, the command displays bandwidth information on all MPLS TE-enabled interfaces except VA interfaces.
# Display bandwidth information on all MPLS TE-enabled interfaces.
<Sysname> display mpls te link-management bandwidth-allocation
Interface: HundredGigE1/0/1
  Max Link Bandwidth                          : 3200000 kbps
  Max Reservable Bandwidth of Prestandard RDM : 2000000 kbps
  Max Reservable Bandwidth of IETF RDM        : 200000 kbps
  Max Reservable Bandwidth of IETF MAM        : 300000 kbps
  Allocated Bandwidth-Item Count :1
  Allocated Bandwidth            :1000 kbps
  Physical Link Status           : Up
  BC  Prestandard RDM(kbps)  IETF RDM(kbps)       IETF MAM(kbps)
  0   2000000                200000               2000
  1   1000000                150000               2000
  2   0                      100000               2000
  3   0                      50000                2000
  TE Class    Class Type    Priority   BW Reserved(kbps)  BW Available(kbps)
  0           0             0          0                  2000000
  1           0             1          0                  2000000
  2           0             2          0                  2000000
  3           0             3          0                  2000000
  4           0             4          0                  2000000
  5           0             5          0                  2000000
  6           0             6          0                  2000000
  7           0             7          1000               1999000
  8           1             0          0                  1000000
  9           1             1          0                  1000000
  10          1             2          0                  1000000
  11          1             3          0                  1000000
  12          1             4          0                  1000000
  13          1             5          0                  1000000
  14          1             6          0                  1000000
  15          1             7          0                  1000000
Table 10 Command output
Interface enabled with MPLS TE.
Max Link Bandwidth
Maximum link bandwidth for MPLS TE traffic.
Number of CRLSPs that have successfully obtained bandwidth.
Use display mpls te link-management srlg to display the SRLG information of interfaces.
display mpls te link-management srlg [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SRLGs of all interfaces.
# Display SRLGs of all interfaces.
<Sysname> display mpls te link-management srlg
Interface HundredGigE1/0/1:
  SRLGs: 1, 2
Interface HundredGigE1/0/2:
  SRLGs: 2, 3
Table 11 Command output
Interface configured with SRLGs.
SRLGs
List of the SRLG numbers of the interface.
Use display mpls te pce discovery to display information about discovered PCEs.
display mpls te pce discovery [ ip-address ] [ verbose ]
ip-address: Specifies a PCE by its IP address. If you do not specify this argument, the command displays information about all discovered PCEs.
# Display brief information about PCE 100.100.100.150.
<Sysname> display mpls te pce discovery 100.100.100.150
Total number of PCEs: 1
Peer address          Discovery methods
100.100.100.150       Static, OSPF
# Display brief information about all discovered PCEs.
Total number of PCEs: 3
100.100.100.10        OSPF
100.100.100.160       Static
Table 12 Command output
Peer address
IP address of the PCE.
Discovery methods
PCE discovery methods:
·     Static—The PCE is specified by command.
·     OSPF—The PCE is discovered automatically by OSPF.
# Display detailed information about PCE 2.2.2.9.
<Sysname> display mpls te pce discovery 2.2.2.9 verbose
PCE address: 2.2.2.9
  Discovery methods: OSPF
  Path scopes:
    Path scope                                                  Preference
    Compute intra-area paths                                    7
    Act as PCE for inter-area TE LSP computation                6
    Act as a default PCE for inter-area TE LSP computation      6
  Capabilities:
    Bidirectional path computation
    Support for request prioritization
    Support for multiple requests per message
  Domains:
    OSPF 1 area 0.0.0.0
    OSPF 1 area 0.0.0.1
# Display detailed information about all discovered PCEs.
<Sysname> display mpls te pce discovery verbose
  Path scopes:
  Capabilities:
  Domains:
    OSPF 1 area 0.0.0.0
    OSPF 1 area 0.0.0.1
PCE address: 4.4.4.9
  Path scopes:
  Capabilities:
  Domains:
    OSPF 1 area 0.0.0.2
  Neighbor domains:
    OSPF 1 area 0.0.0.0
Table 13 Command output
Discovery methods
Path scope
Scope of PCE path computation:
·     Compute intra-area paths.
·     Act as PCE for inter-area TE LSP computation.
·     Act as a default PCE for inter-area TE LSP computation.
·     Act as PCE for inter-AS TE LSP.
·     Act as a default PCE for inter-AS TE LSP.
·     Act as PCE for inter-layer TE LSP.
Preference
Preference of the PCE path scope, in the range of 0 to 7. A higher value represents a higher priority.
Capabilities
PCE capability:
·     Path computation with GMPLS link constraints.
·     Bidirectional path computation.
·     Diverse path computation.
·     Load-balanced path computation.
·     Synchronized path computation.
·     Support for multiple objective functions.
·     Support for additive path constraints.
·     Support for request prioritization.
·     Support for multiple requests per message.
Use display mpls te pce lspdb to display CRLSP and SRLSP information in the PCE LSP state database (LSPDB).
display mpls te pce lspdb [ plsp-id plsp-id ] [ verbose ]
plsp-id plsp-id: Specifies a CRLSP or SRLSP by a PLSP ID. The PLSP ID uniquely identifies a tunnel, and its value equals the tunnel ID plus 1. The value range for a PLSP ID is 1 to 1048574. If you do not specify this option, the command displays information about all CRLSPs in the PCE LSPDB.
# Display brief information about all CRLSPs and SRLSPs in the PCE LSPDB.
<Sysname> display mpls te pce lspdb
Destination      Source        Tunnel ID LSP ID PLSP ID  Delegated address  State
1.1.1.9          2.2.2.9       0         100    1        192.168.115.3      up
3.3.3.9          2.2.2.9       100       100    101      -                  down
Figure 1 Command output
Destination
Source
Tunnel source address.
PLSP ID
Delegated address
IP address of the delegated PCE.
If the CRLSP or SRLSP is not delegated or the delegation fails, this field displays a hyphen (-).
If the multi-delegation feature is enabled, this field displays Multi-delegate.
CRLSP/SRLSP state:
·     up—The CRLSP/SRLSP has been established.
·     down—The CRLSP/SRLSP has not been established or the establishment fails.
# Display detailed information about all CRLSPs and SRLSPs in the PCE LSPDB.
<Sysname> display mpls te pce lspdb verbose
PLSP ID: 2                                       Symbolic name: Sysname_t1
SRP ID: 0                                        PCE initiated-lsp: No
PCE-setup-type: RSVP
Delegatable: Yes                                 Delegated address: -
Operational state: Up                            Speaker address: -
Binding SID: 1024
LSP identifiers:
  Destination: 4.4.4.8                           Source: 2.2.2.8
  Tunnel ID: 1                                   LSP ID: 36293
  Sender address: 2.2.2.8
LSP path:
  EROs: 3
  20.20.20.4                Loose
  20.20.20.8                Strict
  30.30.30.2                Exclude
  SR-EROs: 2
  Label: 100            Strict         SID type: SID without NAI
  Label: 101            Loose          SID type: IPv4 node ID
  LSP attributes:
    Exclude any: 0                               Include any: 0
    Include all: 0
    Setup priority: 7                            Hold priority: 7
    Bandwidth: 0 kbps
    Metric Type: TE                               Metric Value: 0
  RROs: 5
  20.20.20.8/32             Flag: 0x00 (No FRR)
  20.20.20.4/32             Flag: 0x40 (No FRR/In-Int)
  3                         Flag: 0x01 (Global label)
  4.4.4.8/32                Flag: 0x20 (No FRR/Node-ID)
Figure 2 Command output
PLSP ID
Symbolic name
CRLSP/SRLSP name. The value is Sysname_ttunnel-ID, where Sysname represents the device name. You can configure the device name by executing the sysname command in system view.
SRP ID
Stateful PCE request parameters.
PCE initiated-lsp
Whether the CRLSP/SRLSP is created by PCE: Yes or No.
PCE-setup-type
Protocol used to establish the CRLSP/SRLSP: RSVP or Segment Routing.
Delegatable
Whether the CRLSP/SRLSP is delegatable:
·     Yes—The CRLSP/SRLSP is delegatable to a PCE.
·     No—The CRLSP/SRLSP is not delegatable to a PCE.
·     Multi-delegate—The CRLSP/SRLSP is delegatable to all PCEs.
Delegated address
If the CRLSP/SRLSP is not delegated or the delegation fails, this field displays a hyphen (-).
This field is displayed only when multi-delegation is disabled.
Last update address
IP address of the PCE that sent the last update request.
If no PCEs send update requests, this field displays a hyphen (-).
This field is displayed only when multi-delegation is enabled.
Operational state
LSP state:
·     Up—The LSP has been established.
·     Down—The LSP has not been established or the establishment fails.
Speaker address
Binding SID
If no BSID is specified, this field displays a hyphen (-).
Destination
Source
Sender address
Sender address identifies the tunnel source end.
EROs
Number of Explicit Route Objects (EROs) and the ERO information.
ERO information includes the addresses of the nodes on the explicit path, and whether the current node is a loose or strict next hop.
SR-EROs
Number of Segment Routing Explicit Route Objects (SR-EROs) and the SR-ERO information.
SR-ERO information includes the MPLS label value (SID), whether the current node is a loose or strict next hop, and the type of the Node or Adjacency Identifier (NAI) associated with the SID contained in the object.
Label
MPLS label value, used as the SID in SR.
SID Type
Type of the NAI associated with the SID that is contained in the SR-ERO:
·     SID without NAI—The NAI is absent.
·     IPv4 Node ID—The NAI is an IPv4 node ID (IPv4 address).
·     IPv6 Node ID—The NAI is an IPv6 node ID (IPv4 addresses).
·     IPv4 Adjacency—The NAI is an IPv4 adjacency (a pair of IPv4 addresses).
·     IPv6 Adjacency—The NAI is an IPv6 adjacency (a pair of IPv6 addresses).
·     Unnumbered Adjacency with IPv4 NodeIDs—The NAI is an unnumbered adjacency with IPv4 node IDs (a pair of node ID/interface ID tuples).
Metric Type
Metric type: TE or IGP.
RROs
Number of Record Route Objects (RROs).
If the number is not 0, the subsequent output displays the IP addresses or labels recorded in the RROs.
Flag
Flag value and its meaning in an RRO:
·     No FRR—FRR is not configured.
·     FRR Avail—FRR is available.
·     In use—FRR has occurred.
·     BW—Bandwidth protection.
·     Node-Prot—Node protection.
·     Node-ID—The IP address in the RRO is the LSR ID of the node.
·     In-Int—The IP address in the RRO is that of the incoming interface.
·     Global label—Per-platform label space.
Use display mpls te pce parameter to display local PCEP session settings.
# Display local PCEP session settings.
<Sysname> display mpls te pce parameter
Public parameters:
  Keepalive interval   : 30 sec            Recommended Deadtimer: 120 sec
  Request timeout      : 50 sec
  Tolerance:
    Min keepalive interval      : 10 sec
    Max unknown messages        : 5/min
  Capability for Nonstop routing: Yes
  Nonstop routing state         : Ready
PCC parameters:
  PCEP type                     : Active stateful
  Capability for Initiate       : Yes
  Capability for Segment-Routing: Yes
  Retain lsp-state              : Enable
  Retain initiated-lsp          : Enable
  Redelegation timeout          : 30 sec
  State timeout                 : 60 sec
PCE parameters:
  PCEP type                     : Stateless
  PCE address                   : 1.1.1.8
  Capability for Segment-Routing: No
Table 14 Command output
Public parameters
Public parameters, which take effect when the device operates as a PCC or PCE.
Keepalive interval
Locally configured keepalive interval, in seconds.
Locally configured recommended PCEP session hold time, in seconds.
Request timeout
Path computation request timeout, in seconds.
Tolerance
Tolerance of the local device to the messages received from the PCE peer.
Locally acceptable minimum keepalive interval (in seconds) sent by the peer.
Locally acceptable maximum number of unknown messages sent by the peer in a second.
Whether the local device supports PCEP nonstop routing (NSR):
·     Yes.
·     No.
PCEP NSR state:
·     Ready—PCEP NSR has backed PCEP session information from the active process to the standby process. An active/standby switchover occurred in this state does not affect the existing PCEP session. Data forwarding will be not interrupted.
·     Not Ready—PCEP NSR is backing PCEP session information from the active process to the standby process. An active/standby switchover occurred in this state might result in re-establishment of the PCEP session, so data forwarding cannot be guaranteed.
·     Not configured—PCEP NSR is not enabled.
PCC parameters
PCC parameters, which take effect only when the device operates as a PCC.
PCEP type
Type of the local PCEP session:
·     Stateless.
·     Passive stateful.
·     Active stateful.
The PCEP session type finally used is negotiated by the two peers.
Whether the local device supports establishing tunnels and LSPs through PCE Initiated-LSP packets:
·     Yes.
·     No.
Whether the local device supports PCE Segment Routing:
·     Yes—The local device supports establishing SR-TE tunnels by using the following methods:
¡     PCE sends Update packets (delegation update).
¡     PCE sends Initial packets (actively establish)
¡     Sends SR-TE path computation requests to the PCE.
·     No—The local device does not support PCE Segment Routing.
Retain lsp-state
Whether to retain the PCE-updated LSP states after the active stateful PCEP session is broken:
·     Enable—Retains the PCE-updated LSP states.
·     Disable—Does not retain the PCE-updated LSP states but restores the LSP states prior to the update.
Whether to retain the PCE-initiated LSPs after the active stateful PCEP session is broken:
·     Enable—Retains the PCE-initiated LSPs.
·     Disable—Does not retain the PCE-initiated LSPs.
Redelegation wait time (in seconds) after the PCEP session is broken.
State timeout
PCC state aging time (in seconds) after the PCEP session is broken.
PCE parameters
PCE parameters, which take effect only when the device operates as a PCE.
PCE address
PCE address advertised by the device when it operates as a PCE.
Use display mpls te pce peer to display PCC and PCE peer information.
display mpls te pce peer [ ip-address ] [ verbose ]
ip-address: Specifies a peer by its IP address. If you do not specify this argument, the command displays information about all peers.
This command displays information about peers that are establishing or have established PCEP sessions to the local device.
# Display brief information about all peers.
<Sysname> display mpls te pce peer
Total number of peers: 1
Peer address      Peer type   State     Mastership      Role
100.100.100.100   PCE         UP        Normal          Active
Table 15 Command output
Peer type
Peer type, PCC or PCE.
PCEP session state:
·     Idle—Initial state.
·     TCPPending—Waiting for the TCP connection to be set up.
·     OpenWait—Waiting for an Open message from the peer.
·     KeepWait—Waiting for a Keepalive message from the peer.
·     UP—The PCEP session is established.
Mastership
Peer role:
·     Normal—Normal PCC or PCE.
·     Primary—Primary PCE to which the CRLSP is delegated.
·     Backup—Backup PCE to which the CRLSP is delegated.
Role
Role of the local device in the PCEP session:
·     Active—Initiator of the PCEP session.
·     Passive—Responder of the PCEP session.
# Display detailed information about all peers.
<Sysname> display mpls te pce peer verbose
Peer address: 100.100.100.20
  TCP Connection                : 100.100.100.20:5696 -> 100.100.100.10:4189
  Peer type                     : PCC
  Session type                  : Active stateful
  Session state                 : UP
  Mastership                    : Normal
  Role                          : active
  Session up time               : 0000 days 01 hours 03 minutes
  Session ID                    : Local 1, Peer 1
  Keepalive interval            : Local 0 sec, Peer 0 sec
  Recommended DeadTimer         : Local 0 sec, Peer 0 sec
  Tolerance:
    Max unknown messages        : 10
  Delegation timeout            : 30 sec
Table 16 Command output
Peer type
Peer type: PCC or PCE.
Session type
PCEP session type:
·     Stateless.
·     Passive stateful.
·     Active stateful.
Session state
PCEP session state:
Mastership
Peer role:
Role
Minimum acceptable keepalive interval in seconds.
Maximum number of unknown messages allowed in one minute.
Request timeout
Request timeout time in seconds.
Delegation timeout
Delegation timeout time in seconds.
Whether the device supports establishing the tunnel and LSP by using the PCE-Initiated-LSP packets.
Whether the PCEP session has the SR capability.
Use display mpls te pce stateful neighbor to display information about stateful PCE peers on a PCC.
display mpls te pce stateful neighbor [ ip-address ]
ip-address: Specifies the IP address of a stateful PCE peer. If you do not specify this argument, the command displays information about all stateful PCE peers.
# Display information about the stateful PCE peer at 2.2.2.8.
<Sysname> display mpls te pce stateful neighbor 2.2.2.8
Neighbor address: 2.2.2.8
Delegation priority: 1000
Synchronization    : Finished
Redelegation timer : Active
Table 17 Command output
Neighbor address
IP address of the stateful PCE peer.
Session type
PCEP session type:
·     Passive stateful.
·     Active stateful.
Delegation priority
Delegation priority. A bigger value represents a higher priority.
Synchronization
Synchronization state with the peer:
·     Not started.
·     Synchronizing.
·     Finished.
Redelegation timer
Running state of the redelegation timer:
·     Started.
·     Not started.
Use display mpls te pce statistics to display PCC and PCE statistics.
display mpls te pce statistics [ ip-address ]
ip-address: Specifies a PCC or PCE by its IP address. If you do not specify this argument, the command displays statistics about all PCEs and PCCs.
# Display statistics about all PCCs and PCEs.
<Sysname> display mpls te pce statistics
  Keepalive messages sent/received           : 70/75
  Open messages sent/received                : 1/1
  PCReq messages sent/received               : 0/0
  PCRep messages sent/received               : 0/0
  PCRpt messages sent/received               : 0/0
  PCUpd messages sent/received               : 0/0
  PCErr messages sent/received               : 0/0
  PCNtf messages sent/received               : 0/0
  Session setup failures                     : 0
  Unknown messages received                  : 0
  Unknown requests received                  : 0
  Unknown responses received                 : 0
  Requests sent                              : 0
    Response is pending                      : 0
    Response with ERO received               : 0
    Response with NO-PATH received           : 0
    Canceled by peer sending a PCNtf         : 0
    Canceled by peer sending a PCErr         : 0
    Canceled by local speaker sending a PCNtf: 0
    Implicitly canceled (session down)       : 0
    Timeout                                  : 0
  Requests received                          : 0
    Response with ERO sent                   : 0
    Response with NO-PATH sent               : 0
    Canceled by local speaker sending a PCErr: 0
Table 18 Command output
Number of unknown requests (the request ID carried in the RP object is 0) received.
Number of unknown responses (the request ID in the response does not match the one in the request) received.
Requests sent
Total number of sent requests.
Response is pending
Number of requests that are waiting for responses.
Number of requests that have received responses with ERO.
Number of requests that have received responses with NO-PATH.
Cancelled by peer sending a PCNtf
Number of requests canceled byPCNtf messages sent by the peer.
Number of requests canceled byPCErr messages sent by the peer.
Number of requests canceled by PCNtf messages sent by the local device.
Implicitly canceled(session down)
Number of requests that became invalid because the PCEP session was down.
Timeout
Number of requests that became invalid because of request timeout.
Requests received
Total number of received requests.
Response is pending
Number of requests whose responses are not sent yet.
Number of responses sent with ERO.
Number of responses sent with NO-PATH.
Number of PCNtf messages for request cancellation sent by the local device.
Number of PCErr messages for request cancellation sent by the local device.
Number of PCNtf messages for request cancellation sent by the peer.
Use display mpls te segment-routing tunnel path to display the path information of SR-signaled MPLS TE tunnels (MPLS SR-TE tunnels for short).
display mpls te segment-routing tunnel path [ tunnel number ]
Parameter
tunnel number: Specifies a tunnel interface. The number argument represents the interface number of an existing tunnel interface on the device. If you do not specify a tunnel interface, this command displays path information for all MPLS SR-TE tunnels.
# Display path information for all MPLS SR-TE tunnels.
<Sysname> display mpls te segment-routing tunnel path
Tunnel name      : Tunnel1
  Main path info : 1.1.1.1/1/61103
   Forwarding information:
    HGE1/0/1                 20.0.0.2
    HGE1/0/2                 40.0.0.2
  Hop information:
    Hop 0    Prefix SID 16030       NAI 3.3.3.3
    Hop 1    Adjacency SID 1151     NAI 21.0.0.1, 21.0.0.2
    Hop 2    SID 1140               NAI -
  Backup path info : 1.1.1.1/1/61104
    NID : 268435458
  Hop information:
    Hop 1    Adjacency SID 18040    NAI 4.4.4.4, 21.0.0.2
  Modify path info : 1.1.1.1/1/61105
    HGE1/0/3                 10.0.0.2
    HGE1/0/4                 30.0.0.2 (Backup)
  Hop information:
Table 19 Command output
Tunnel Name
Name of the tunnel interface.
Main Path Info
Primary path information. The value is Ingress LSR ID/Tunnel ID/LSP ID.
Backup Path Info
Backup path information.
Modify Path Info
Information about the path established by using the make-before-break mechanism.
Forwarding information. Possible values include:
·     Primary and backup outgoing interfaces and next hops. A backup outgoing interface and next hop item is suffxed with (Backup). If multiple outgoing interface and next hop items exist, traffic is forwarded in load sharing mode.
·     NID.
Hop information
Information about the hops of the path.
Hop
Hop index.
Prefix SID
Prefix SID value.
Adjacency SID
Adjacency SID value.
SID
SID of an unknown type.
NAI
Node or Adjacency Identifier.
For a prefix SID, the NAI is the node identifier, which is the IP address of the node.
For an adjacency SID, the NAI is the adjacency identifier, which displays the local and remote IP addresses of the link.
If the NAI is not available or is unknown, this field displays a hyphen (-).
Use display mpls te srlg to display information about SRLGs.
display mpls te srlg [ srlg-number ]
srlg-number: Specifies an SRLG by its number, in the range of 0 to 4294967295. If you do not specify an SRLG, this command displays information about all SRLGs.
# Display information about all SRLGs.
<Sysname> display mpls te srlg
Total SRLGs configured: 2
 SRLG 1: HGE1/0/1, HGE1/0/2
 SRLG 2: HGE1/0/3
Table 20 Command output
Number of SRLGs configured.
SRLG number
Interfaces in an SRLG.
Use display mpls te tedb to display MPLS TE database (TEDB) information.
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary }
isis: Displays TEDB information for IS-IS.
level-1: Displays TEDB information for Level-1 routers.
level-2: Displays TEDB information for Level-2 routers.
ospf area area-id: Displays TEDB information for an OSPF area. The value range for the OSPF area ID is 0 to 4294967295.
link ip-address: Displays TEDB information for a link. The ip-address argument represents the IP address of the local interface on the link.
network: Displays TEDB information for all broadcast and NBMA networks.
node: Displays TEDB information for the local or specified node. If you do not specify the local keyword or the mpls-lsr-id argument, this command displays TEDB information for all nodes.
local: Displays TEDB information for the local node.
mpls-lsr-id: Displays TEDB information for the node specified by its MPLS LSR ID.
summary: Displays summary TEDB information.
# Display TEDB information for all broadcast and NBMA networks.
<Sysname> display mpls te tedb network
DR MPLS LSR-ID  DR-address      IGP   Process-ID Area/Level  Neighbors
8.1.1.2         3.0.0.2         OSPF  100        0           1.1.1.1
                                                             2.1.1.1
                                                             8.1.1.2
2.1.1.1         3.0.0.3         OSPF  100        0           2.1.1.1
                                                             3.1.1.1
                                                             2.1.1.2
3.1.1.2         3.0.0.4          OSPF  100       0           3.1.1.1
                                                             4.1.1.1
                                                             3.1.1.2
4.1.1.2        3.0.0.5          OSPF  100         0          4.1.1.1
                                                             5.1.1.1
                                                             4.1.1.2
5.1.1.2        3.0.0.6          OSPF  100         0          5.1.1.1
                                                             6.1.1.1
                                                             5.1.1.2
6.1.1.2        3.0.0.9          OSPF  100         0          6.1.1.1
                                                             7.1.1.1
                                                             6.1.1.2
7.1.1.1        12.0.0.7         OSPF  100         0          3.1.1.1
                                                             7.1.1.1
                                                             7.1.1.2
Table 21 Command output
DR MPLS LSR-ID
MPLS LSR ID of a designated router (DR), in dotted decimal notation.
DR-address
Interface address of the DR.
IGP
Internal gateway protocol: OSPF or IS-IS.
Process-ID
IGP process ID.
Area/Level
OSPF area or IS-IS level of the router.
Neighbors
Router IDs of the routers that have formed full adjacencies with the DR, and router ID of the DR itself.
# Display summary TEDB information.
<Sysname> display mpls te tedb summary
MPLS LSR-ID     IGP     Process-ID    Area/Level    Links-Count
1.1.1.1         OSPF    100           1001          20
                                      1002          30
                                      1003          40
                                      1004          50
                                      1007          70
                                      1010          80
2.1.1.1         ISIS    100           Level-1       20
                                      Level-1       30
3.1.1.1         OSPF    100           0             4
Table 22 Command output
MPLS LSR-ID
MPLS LSR ID of a router, in dotted decimal notation.
IGP
Process-ID
IGP process ID.
Area/Level
Links-Count
Number of links in an OSPF area or IS-IS level.
# Display TEDB information for an OSPF area.
<Sysname> display mpls te tedb ospf area 1
Node information for OSPF area 1:
MPLS LSR-ID    IGP     Process-ID     Area            Links-Count
2.2.2.2        OSPF    100            1               1
3.3.3.3        OSPF    100            1               1
Network information for OSPF area 1:
DR MPLS LSR-ID  DR-address    IGP  Process-ID Area    Neighbors
3.3.3.3         20.1.1.2      OSPF 100        1       2.2.2.2
                                                      3.3.3.3
Table 23 Command output
MPLS LSR-ID
IGP
Process-ID
IGP process ID.
Area
OSPF area of the router.
Links-Count
Number of links in the OSPF area or IS-IS level.
DR MPLS LSR-ID
MPLS LSR ID of a DR.
DR-address
Neighbors
# Display TEDB information for the local node in prestandard mode.
<Sysname> display mpls te tedb node local
MPLS LSR-ID: 1.1.1.1
  IGP Type: OSPF          Process ID: 100         Area: 1
  Link[1]:
    Local IP Address: 2.0.1.33
          Neighbor IP Address: 2.0.1.2
    Neighbor MPLS LSR-ID: 1.1.1.2
    Link Type: P2P  Link Status: Inactive
    IGP Metric: 100             TE Metric: 100         Link Attribute: 0xff
    Maximum Link Bandwidth: 100 kbps
    Maximum Reservable Bandwidth: 20 kbps
    Bandwidth Constraint Model: Prestandard DS-TE RDM
    Bandwidth Constraints:
         BC[0]:  100        kbps
         BC[1]:  20         kbps
    Unreserved Bandwidth for each TE class:
         TE class  0:    10         kbps
         TE class  1:    10         kbps
         TE class  2:    10         kbps
         TE class  3:    10         kbps
         TE class  4:    10         kbps
         TE class  5:    10         kbps
         TE class  6:    10         kbps
         TE class  7:    10         kbps
         TE class  8:    10         kbps
         TE class  9:    10         kbps
         TE class 10:    10         kbps
         TE class 11:    10         kbps
         TE class 12:    10         kbps
         TE class 13:    10         kbps
         TE class 14:    10         kbps
         TE class 15:    10         kbps
  IGP Type: ISIS   Process ID: 100   Level: Level-1
  Link[1]:
    Link Type: P2P  Link Status: Active
    IGP Metric: 10              TE Metric: 10          Link Attribute: 0x11
    Maximum Bandwidth: 100 (kbps)
    Maximum Reservable Bandwidth: 100 (kbps)
         BC[0]:  100        kbps
         BC[1]:  20         kbps
    Unreserved Bandwidth for each TE Class:
         TE class  0:    10         kbps
         TE class  1:    10         kbps
         TE class  2:    10         kbps
         TE class  3:    10         kbps
         TE class  4:    10         kbps
         TE class  5:    10         kbps
         TE class  6:    10         kbps
         TE class  7:    10         kbps
         TE class  8:    10         kbps
         TE class  9:    10         kbps
Table 24 Command output
MPLS LSR-ID
IGP Type
Process ID
IGP process ID.
Area
Level
IS-IS level of the router: Level-1 or Level-2.
Link[n]
Information about a link. n is the number of the link.
Local IP Address
Local interface address.
Neighbor IP Address
Remote interface address for a P2P link.
For an NBMA or a broadcast link, this field displays a hyphen (-).
MPLS LSR ID of the routing neighbor (DR).
Link Type
Link type:
·     P2P.
·     NBMA.
·     Broadcast.
Link Status
Link status: Active or Inactive.
·     IETF DS-TE RDM.
·     IETF DS-TE MAM.
# Display TEDB information for the link connected to the interface with interface address 20.1.1.1 in IETF DS-TE RDM model.
<Sysname> display mpls te tedb link 20.1.1.1
MPLS LSR-ID: 2.2.2.2
    Local IP Address: 20.1.1.1
Neighbor MPLS LSR-ID: 20.1.1.2
Link Type: Broadcast  Link Status: Active
    IGP Metric: 10          TE Metric: 0             Link Attribute: 0x0
    Maximum Bandwidth: 0 kbps
    Maximum Reservable Bandwidth: 0 kbps
    Bandwidth Constraint Model: IETF DS-TE RDM
         BC[0] :  0          kbps
         BC[1] :  0          kbps
         BC[2] :  0          kbps
         BC[3] :  0          kbps
         TE class  0:    0          kbps
         TE class  1:    0          kbps
         TE class  2:    0          kbps
         TE class  3:    0          kbps
         TE class  4:    0          kbps
         TE class  5:    0          kbps
         TE class  6:    0          kbps
         TE class  7:    0          kbps
Table 25 Command output
MPLS LSR-ID
IGP Type
Process ID
IGP process ID.
Area
Level
Local IP Address
Neighbor IP Address
For an NBMA or a broadcast link, this field is not displayed.
Link Type
Link type:
·     P2P.
·     NBMA.
·     Broadcast.
Link Status
·     IETF DS-TE RDM.
·     IETF DS-TE MAM.
Use display mpls te tunnel-interface to display information about MPLS TE tunnel interfaces.
display mpls te tunnel-interface [ tunnel number ]
tunnel number: Displays information about the tunnel interface specified by its number. The interface must have been created. If you do not specify this option, the command displays information about all MPLS TE tunnel interfaces.
# Display information about all MPLS TE tunnel interfaces.
<Sysname> display mpls te tunnel-interface
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up. Backup CRLSP up)
Tunnel Attributes      :
  LSP ID               : 49770           Tunnel ID            : 1
  Admin State          : Normal
  Ingress LSR ID       : 2.2.2.8         Egress LSR ID        : 4.4.4.8
  Signaling            : RSVP-TE         Static CRLSP Name    : -
  Static SRLSP Name    : -/-
  Resv Style           : SE
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Reverse-LSP BSID     : -
  Class Type           : CT1             Tunnel Bandwidth     : 100 kbps
  Class Type           : CT2             Tunnel Bandwidth     : 100 kbps
  Reserved Bandwidth   : 0 kbps
  Setup Priority       : 7               Holding Priority     : 7
  Affinity Attr/Mask   : 0/0
  Explicit Path        : ero1
  Backup Explicit Path : ero2
  Metric Type          : TE
  Record Route         : Enabled         Record Label         : Enabled
  FRR Flag             : Disabled        Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : No              Auto Created         : No
  Route Pinning        : Disabled
  Retry Limit          : 3               Retry Interval       : 2 sec
  Reoptimization       : Disabled        Reoptimization Freq  : -
  Backup Type          : Hot Standby     Backup LSP ID        : 49771
  Backup Restore Time  : 10 sec
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -               Service Class        : -
  Traffic Policy       : Disable         Reserved for binding : No
  Path SetupType       : -/-
  Binding SID          : -               Binding SID State    : -
  Last Down Reason     : Admin Down
  Down Time            : 2017-12-05 11:23:35:535
Table 26 Command output
Tunnel Name
Tunnel State
Running state of the tunnel: Down or Up.
Description information includes:
·     Main CRLSP down.
·     Main CRLSP up.
·     Main CRLSP being set up.
·     Shared-resource CRLSP down.
·     Shared-resource CRLSP up.
·     Shared-resource CRLSP being set up.
·     Shared-resource CRLSP being activated.
·     Shared-resource CRLSP switching to Main CRLSP.
·     Backup CRLSP down.
·     Backup CRLSP up.
·     Backup CRLSP being set up.
·     Main CRLSP BFD-detected down.
·     Backup CRLSP BFD-detected down.
Admin State
Administrative state of the tunnel interface:
·     Normal—The interface is not shut down by the shutdown command.
·     Shutdown—The tunnel interface is shut down by the shutdown command.
Signaling
Signaling protocol used to set up the tunnel: RSVP-TE or Static.
Static CRLSP Name
Static CRLSP used by the tunnel.
Static SRLSP Name
Static SRLSP used by the tunnel. The value is primary static SRLSP name/backup static SRLSP name.
If no primary or backup static SRLSP is specified for the tunnel, the primary or backup static SRLSP name is displayed as a hyphen (-).
Resv Style
Resource reservation style for the CRLSPs.
This field displays FF or SE for an MPLS TE tunnel that uses dynamic CRLSPs, and displays a hyphen (-) for an MPLS TE tunnel that uses static CRLSPs.
Tunnel Mode
Tunnel mode of the tunnel:
If the tunnel is a unidirectional tunnel, this field displays a hyphen (-).
Reverse-LSP Name
Name of the associated reverse LSP.
Reverse-LSP LSR ID
LSR ID of the reverse LSP.
This field has a value for the LSR of an associated reverse LSP and the passive end of the co-routed bidirectional tunnel. For other LSPs, this field displays a hyphen (-).
Tunnel ID of the reverse LSP.
This field has a value for an associated reverse LSP and the passive end of the co-routed bidirectional tunnel. For other LSPs, this field displays a hyphen (-).
Reverse-LSP BSID
BSID of the reverse LSP.
This field has a value for an associated reverse LSP. For other LSPs, this field displays a hyphen (-).
Class Type
CT of the tunnel. The value can be CT0, CT1, CT2, CT3, CT4, CT5, CT6, or CT7.
Tunnel Bandwidth
Bandwidth required by the tunnel, in kbps.
Reserved Bandwidth
Bandwidth reserved for the tunnel, in kbps.
Setup Priority
Tunnel setup priority.
Holding Priority
Tunnel holding priority.
Affinity Attr/Mask
Tunnel affinity attribute and mask.
Explicit Path Name
Name of the explicit path used by the tunnel.
If the path used by the tunnel is not an explicit path, this field displays a hyphen (-).
Name of the explicit path used by the backup tunnel.
If the path used by the backup tunnel is not an explicit path, this field displays a hyphen (-).
Metric Type
Link metric type used for tunnel path selection, TE or IGP.
Whether FRR needs bandwidth protection: Enabled or Disabled.
Whether all-CT protection and unlimited bandwidth protection is enabled for the bypass tunnel (by using the mpls te backup bandwidth command):
·     Enabled.
·     Disabled.
Class type of the traffic on the primary tunnel that the bypass tunnel can protect. The value is All Class Type, which means that the bypass tunnel can protect all class types.
If the mpls te backup bandwidth command is not executed, this field display a hyphen (-).
Backup Bandwidth
Bandwidth that the bypass tunnel can protect, in kbps.
If the protection bandwidth is unlimited, this field displays Unlimited.
Bypass Tunnel
Whether it is a bypass tunnel: Yes or No.
Auto Created
Whether the bypass tunnel is automatically created:
·     Yes.This value is not supported in the current software version.
·     No.
Retry Limit
Maximum number of tunnel setup retries.
Retry Interval
Tunnel setup retry interval, in seconds.
Reoptimization Freq
Tunnel reoptimization frequency, in seconds.
Backup Type
CRLSP backup mode:
·     None—CRLSP backup is disabled.
·     Hot Standby—Hot-standby backup mode.
·     Ordinary—Ordinary backup mode.
Backup LSP ID
LSP ID of the backup tunnel.
Backup Restore Time
Recovery delay time, in seconds. This field is valid only when the value of the Backup Type field is Hot Standby.
Auto Bandwidth
State of the automatic bandwidth adjustment feature.
Auto Bandwidth Freq
Automatic bandwidth adjustment interval, in seconds.
Min Bandwidth
Minimum bandwidth (in kbps) that can be applied to the tunnel by automatic bandwidth adjustment.
Max Bandwidth
Maximum bandwidth (in kbps) that can be applied to the tunnel by automatic bandwidth adjustment.
Collected Bandwidth
Current output rate, in kbps.
Service Class
Service class value of the tunnel. If no service class value is set for the tunnel, this field displays a hyphen (-).
Traffic Policy
Status of the outbound traffic policing feature: Enable or Disable. If the outbound traffic policing feature is not supported, this field displays a hyphen (-).
Whether the tunnel is reserved for tunnel policy destination binding:
·     Yes—This tunnel can only be used by a tunnel policy that has a binding destination.
·     No—This tunnel can be used by any types of tunnel policies.
Path SetupType
Path setup type used by the primary and backup tunnels:
·     CSPF—Uses the CSPF-computed SRLSPs to establish the tunnels.
·     PCE—Uses the PCE-computed SRLSPs to establish the tunnels.
·     EXPLICITPATH—Uses the explicit-path SRLSPs to establish the tunnels.
This field has values when the tunnels are established by using the Segment Routing protocol. In other cases, this field displays hyphens (-).
Binding SID
BSID of the tunnel that uses an SRLSP.
Binding SID State
BSID state of the tunnel:
·     Available—The label has been allocated to the tunnel successfully and is available.
·     Idle—The label is not allocated to the tunnel.
·     Dup—The label has been occupied by others.
Last Down Reason
Reason for the last down event:
·     Admin Down—The tunnel interface was shut down administratively by using the shutdown command.
·     Configuration Change—The configuration changed.
·     Signal Error—An RSVP signaling error occurred.
Down Time
Last time when the tunnel went down.
Use display ospf mpls te advertisement to display link and node information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
area area-id: Specifies an area by its ID, an IP address or a decimal integer. The integer is in the range of 0 to 4294967295. If you specify an integer, the system will translate the integer into the IP address format. If you do not specify this option, the command displays information about all areas.
originate-router advertising-router-id: Displays information originated from a router specified by its router ID.
self-originate: Displays information generated by the local router.
# Display link and node information for all processes in all areas.
<Sysname> display ospf mpls te advertisement
                 Traffic Engineering Database
                          Area: 0.0.0.1
    Adv Router ID              : 1.1.1.1
    Flags                      : A/S/R
    Router Address Count       : 1
      Router Address Index     : 0
      Instance ID              : 0.0.0.0
    Link Count                 : 1
      Link Index               : 0
      Link Type                : Broadcast
      Instance ID              : 0.0.0.1
      Link Flags               : -/U/-
      Link ID                  : 197.168.1.1
      TE Metric                : 1000
      IGP Metric               : 1000
      Maximum Bandwidth        : 12500000 bytes/sec
      Maximum Reservable BW    : 0 bytes/sec
      Administrative Group     : 0x0
        TE class  0 = 0 bytes/sec
        TE class  1 = 0 bytes/sec
        TE class  2 = 0 bytes/sec
        TE class  3 = 0 bytes/sec
        TE class  4 = 0 bytes/sec
        TE class  5 = 0 bytes/sec
        TE class  6 = 0 bytes/sec
        TE class  7 = 0 bytes/sec
        TE class  8 = 0 bytes/sec
        TE class  9 = 0 bytes/sec
        TE class 10 = 0 bytes/sec
        TE class 11 = 0 bytes/sec
        TE class 12 = 0 bytes/sec
        TE class 13 = 0 bytes/sec
        TE class 14 = 0 bytes/sec
        TE class 15 = 0 bytes/sec
        BC [ 0] = 0 bytes/sec
        BC [ 1] = 0 bytes/sec
      SRLGs:
        10             20             30
      Local Interface Address  : 197.168.1.1
      Remote Interface Address : 197.168.1.11
Table 27 Command output
Adv Router ID
ID of the router that advertised TE information.
MPLS LSR ID
MPLS LSR ID of the router that advertised TE information.
Flags
TE information flags:
·     A—Already synchronized information with CSPF.
·     S—Ready to synchronize information with CSPF.
·     R—The router that advertised information is reachable.
Number of Router TLV messages in TEDB.
Index of the current Router TLV message.
Instance ID
LSA instance ID.
Link Count
Number of Link TLV messages in TEDB.
Link Index
Index of the current Link TLV message.
Link Type
Link types:
·     Point to Point.
·     Point to Multi Point.
·     Broadcast.
·     NBMA.
Link Flags
·     U—Ready to update information with CSPF again after the previous update failed.
·     D—Ready to delete information from CSPF again after the previous deletion failed.
Link ID
Link state ID.
IGP Metric
OSPF protocol metric.
Link attributes.
Bandwidth constraint model: Prestandard DS-TE RDM, IETF DS-TE RDM, or IETF DS-TE MAM.
This field takes effect only on DS-TEs.
BC
Bandwidth constraint value.
The Prestandard mode supports two BCs, and the IETF mode supports four BCs.
SRLGs
SRLG membership (list of SRLG numbers) of the interface.
Use display ospf mpls te network to display network information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ]
area area-id: Specifies an area by its ID, an IP address or a decimal integer, in the range of 0 to 4294967295. If you specify an integer, the system will translate the integer into the IP address format. If you do not specify this option, the command displays information about all areas.
# Display network information for all processes in all areas.
<Sysname> display ospf mpls te network
         OSPF Process 1 with Router ID 12.1.1.1
                 Traffic Engineering Network
                          Area: 0.0.0.0
      Designated Router         :  197.168.1.1
      Flags                     :  -/U/-
       Attached router    2.2.2.2
       Attached router    1.1.1.1
Table 28 Command output
Adv Router ID
ID of the router that advertised the TE network information.
Designated Router
IP address of the designated router.
Flag
Network information flags:
Attached router
ID of the attached router.
display ospf mpls te pce
Use display ospf mpls te pce to display information about PCEs discovered by OSPF.
display ospf [ process-id ] [ area area-id ] mpls te pce [ originate-router advertising-router-id | self-originate ]
# Display PCE information for all processes in all areas.
<Sysname> display ospf mpls te pce
          OSPF Process 1 with Router ID 2.1.1.1
                 Path Computation Element
                          Area: 0.0.0.1
    Adv Router ID                : 2.1.1.1
    PCE Address                  : 5.6.7.8
    Flags                        : A/-/R/E
    PCE Path Scopes:
        Path Scope                     Preference
        L (PCE for intra-area)         7
        R (PCE for inter-area)         6
    PCE Capabilities:
    PCE Domain List:
        Area 0.0.0.1
        Area 0.0.0.3
    PCE Neighbor Domain List:
        Area 0.0.0.2
Table 29 Command output
Adv Router ID
ID of the router that advertised the information.
Flags
PCE information flag:
·     A—Already synchronized information with PCEP.
·     U—Ready to update information with PCEP again after the previous update failed.
·     D—Ready to delete information from PCEP again after the previous deletion failed.
·     E—PCE information is valid.
Path Scope
PCE path scope:
·     L (PCE for intra-area).
·     R (PCE for inter-area).
·     Rd (Default PCE for inter-area).
·     S (PCE for inter-AS).
·     Sd (Default PCE for inter-AS).
·     Y (PCE for inter-layer).
Preference
PCE Capabilities
PCE capability:
PCE Domain List
List of local domains that support TE on the PCE.
List of neighbor domains that support TE on the PCE.
Area
Area that supports TE.
AS
AS that supports TE.
display ospf mpls te tunnel
Use display ospf mpls te tunnel to display MPLS TE tunnel interface information for OSPF.
display ospf [ process-id ] [ area area-id ] mpls te tunnel
# Display MPLS TE tunnel interface information for all OSPF processes in all areas.
<Sysname> display ospf mpls te tunnel
                   Traffic Engineering Tunnel
                          Area: 0.0.0.1
Interface: Tunnel1 (12.1.1.2)
    State: Inactive
    Neighbor ID: 0.0.0.0         Cost: 0
    Destination: 125.1.1.1
    Auto Route: IGP Shortcut
    Metric: Relative  10
Table 30 Command output
Name and IP address of a tunnel interface.
Tunnel interface states:
·     Inactive—The tunnel interface is not used to forward packets, because the tunnel route is not the optimal route.
·     Active—The tunnel interface is used to forward packets, because the tunnel route is the optimal route.
Neighbor ID
Router ID for the tunnel destination.
Cost
Route cost of the tunnel interface.
Destination
LSR ID for the tunnel destination.
Auto Route
Automatic route advertisement method: IGP Shortcut or IGP Advertise.
Metric
Absolute or relative metric of the MPLS TE tunnel.
display tunnel-bundle
Use display tunnel-bundle to display information about tunnel bundle interfaces and their member interfaces.
display tunnel-bundle [ number ]
number: Specifies a tunnel bundle interface and its member interfaces by the tunnel bundle interface number. The value range for this argument is 0 to 511. If you do not specify this argument, the command displays information about all tunnel bundle interfaces and their member interfaces.
# Display information about all tunnel bundle interfaces and their member interfaces.
<Sysname> display tunnel-bundle
Total number of tunnel bundles: 1, 1 up, 0 down
Tunnel bundle name: Tunnel-Bundle 1
Bundle state           : Up
Bundle attributes      :
  Working mode         : Load Balancing
  Tunnel type          : CR-LSP
  Tunnel destination   : 2.2.2.2
Bundle members:
  Member         State        Load-share
  Tunnel2        Up           2
  Tunnel3        Down         3
  Tunnel6        Down         3
Table 31 Command output
Working mode
Tunnel bundle interface operating modes:
·     Load Balancing.
·     1+1—1+1 protection switching mode.
·     1:1—1:1 protection switching mode.
For more information about 1+1 and 1:1 protection switching modes, see MPLS Configuration Guide.
Tunnel type
This field supports only CRLSP.
Tunnel destination
Destination address for the tunnel bundle interface.
Load-share
Weight of the interface for load sharing. This field is displayed when the tunnel bundle interface operates in Load Balancing mode.
Role
Role of a member interface. This field is displayed when the tunnel bundle interface operates in 1+1 or 1:1 mode.
·     Working—The tunnel for the member interface is the working tunnel.
·     Protection—The tunnel for the member interface is the protection tunnel.
ds-te bc-model
Use ds-te bc-model to specify the bandwidth constraint (BC) model used in IETF DS-TE.
Use undo ds-te bc-model to restore the default.
ds-te bc-model { extended-mam | mam }
undo ds-te bc-model
The BC model of IETF DS-TE is Russian Dolls Model (RDM).
MPLS TE view
extended-mam: Specifies the BC model as Extended Maximum Allocation Model (Extended-MAM).
mam: Specifies the BC model as Maximum Allocation Model (MAM).
RDM is suitable for networks where traffic is unstable and traffic bursts might occur. RDM does not define the bandwidth for one class type (CT) but limits the shared bandwidth for multiple CTs. In cooperation with priority preemption, the RDM model can also implement the isolation between CTs, ensuring each CT its share of bandwidth.
MAM is suitable for networks where traffic of each CT is stable. MAM constrains the bandwidth for only one CT on an interface. This ensures isolation between CTs no matter whether preemption is used or not. Compared with RDM, MAM is easy to understand and configure.
Similar to MAM, Extended MAM constrains the bandwidth for only one CT on an interface, and CTs do not share bandwidth. Extended MAM can reserve bandwidth for multiple CTs on one LSP. Extended MAM supports eight CTs (CT 0 through CT 7) and 16 TE classes (TE class 0 through TE class 15). The default mappings of the first eight TE classes are the same as MAM TE classes. The last eight TE classes define the mappings between CT 0 and priorities 0 to 7, and they are not configurable.
This command applies only to IETF DS-TE. The prestandard DS-TE only uses RDM.
After you change the BC model in IETF DS-TE mode, all nonzero-bandwidth CRLSPs on the device are deleted and then re-established.
# Specify the BC model of IETF DS-TE as MAM.
[Sysname] mpls te
[Sysname-te] ds-te bc-model mam
ds-te mode
ds-te mode
Use ds-te mode to configure the DS-TE mode.
Use undo ds-te mode to restore the default.
ds-te mode ietf
undo ds-te mode
The DS-TE mode is prestandard.
MPLS TE view
ietf: Specifies the DS-TE mode as IETF.
The prestandard and IETF modes of DS-TE have the following differences:
·     The prestandard mode supports 2 CTs (CT 0 and CT 1), 8 priorities, and a maximum of 16 TE classes. The IETF mode supports 8 CTs (CT 0 through CT 7), eight priorities, and a maximum of 16 TE classes.
·     The prestandard mode does not allow you to configure TE classes. The IETF mode allows for TE class configuration.
·     The prestandard mode supports only RDM. The IETF mode supports RDM, MAM, and Extended-MAM.
·     A device operating in prestandard mode cannot communicate with devices from some vendors. A device operating in IETF mode can communicate with devices from other vendors.
Be aware of these differences and choose a proper DS-TE mode as needed.
After the DS-TE mode is changed, all CRLSPs on the device are deleted and then re-established.
# Configure the DS-TE mode as IETF.
[Sysname] mpls te
[Sysname-te] ds-te mode ietf
ds-te bc-model
ds-te te-class
Use ds-te te-class to configure a TE class used in IETF DS-TE mode.
Use undo ds-te te-class to restore the default.
ds-te te-class te-class-index class-type class-type-number priority priority
undo ds-te te-class te-class-index
Table 32 Default TE classes in IETF MAM model
TE class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
Table 33 Default TE classes in IETF Extended MAM model
TE class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
8
0
0
9
0
1
10
0
2
11
0
3
12
0
4
13
0
5
14
0
6
15
0
7
MPLS TE view
te-class-index: Specifies a TE class index in the range of 0 to 7.
class-type class-type-number: Specifies a CT by its number in the range of 0 to 3. The system supports four CTs, CT 0 through CT 3.
priority priority: Specifies a priority number in the range of 0 to 7.
The setup or/and holding priority of the LSP transporting a traffic trunk from a CT must be the priority specified for the CT in the TE class.
When you configure a TE class, make sure to specify a CT-priority pair different from that in any existing TE class.
When you restore the default settings for a TE class, make sure the default CT-priority pair is different from the CT-priority pair of an existing TE class.
After a TE class is modified, the device performs the following operations:
1.     Notifies the IGP to re-advertise the bandwidth information for all TE interfaces.
2.     Removes and then re-establishes the CRLSPs of the TE class on all TE interfaces.
TE class 8 through TE class 15 are implicit TE classes, which cannot be configured or displayed by commands.
# Specify CT 2 and priority 3 for TE class 7 in IETF DS-TE mode.
[Sysname] mpls te
[Sysname-te] ds-te te-class 7 class-type 2 priority 3
ds-te mode
exclude-srlg
Use exclude-srlg to exclude the links that are in the same SRLG as the specified IP address from an explicit path.
Use undo exclude-srlg to cancel the SRLG-exclusion configuration for an explicit path.
exclude-srlg [ index index-number ] ip-address
undo exclude-srlg [ index index-number ]
Explicit path computation does not consider SRLG information.
Explicit path view
index index-number: Specifies a node in the explicit path by the node index, in the range of 1 to 65535. If you do not specify a node index, this command calculates the node index automatically, which is the current maximum index plus 100.
ip-address: Specifies the IP address of an interface, in dotted decimal notation.
In the same explicit path, the node indexes configured by the exclude-srlg, nexthop, and nextsid commands cannot be the same.
# Exclude all links that are in the same SRLG as the interface with IP address 10.0.0.1.
[Sysname] explicit-path 1
[Sysname-explicit-path 1] exclude-srlg index 1 10.0.0.1
explicit-path
Use explicit-path to create an explicit path and enter its view, or enter the view of an existing explicit path.
Use undo explicit-path to remove an explicit path.
explicit-path path-name
undo explicit-path path-name
No explicit paths exist.
path-name: Specifies a name for the explicit path, a case-sensitive string of 1 to 31 characters.
In explicit path view, you can use the nexthop command to explicitly specify a node or link that a tunnel must or must not traverse.
# Create explicit path path1 and enter its view.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1]
display explicit-path
mpls te backup-path
mpls te path
nexthop
fast-reroute timer
Use fast-reroute timer to set the interval for selecting an optimal bypass tunnel.
Use undo fast-reroute timer to restore the default.
fast-reroute timer interval
The optimal bypass tunnel selection interval is 300 seconds.
MPLS TE view
interval: Specifies the interval for selecting an optimal bypass tunnel, in the range of 0 to 604800 seconds. If you set the interval to 0 seconds, RSVP does not periodically select an optimal bypass tunnel.
If you have specified multiple bypass tunnels for a primary CRLSP, MPLS TE selects an optimal bypass tunnel to protect the primary CRLSP. Sometimes, a bypass tunnel might become better than the current optimal bypass tunnel because, for example, the reservable bandwidth changes. MPLS TE must poll the bypass tunnels periodically to update the optimal bypass tunnel.
After traffic is switched from the primary CRLSP to a bypass tunnel, MPLS TE no longer periodically selects optimal bypass tunnels for the primary CRLSP.
If the optimal bypass tunnel selection interval is set to less than 60 seconds, the interval of 60 seconds applies. As a best practice, use the default selection interval.
# Set the optimal bypass tunnel selection interval to 120 seconds.
[Sysname] mpls te
[Sysname-te] fast-reroute timer 120
interface tunnel-bundle
Use interface tunnel-bundle to create a tunnel bundle interface and enter its view, or enter the view of an existing tunnel bundle interface.
Use undo interface tunnel-bundle to delete a tunnel bundle interface.
interface tunnel-bundle number
undo interface tunnel-bundle number
No tunnel bundle interfaces exist.
number: Specifies the tunnel bundle interface number. The value range for this argument is 0 to 511.
You can specify multiple member interfaces (MPLS TE tunnel interfaces) for a tunnel bundle interface. The member interfaces form a tunnel bundle. When the outgoing interface is the tunnel bundle interface, the device forwards traffic through the MPLS TE tunnels to implement load sharing.
# Create tunnel bundle interface Tunnel-Bundle 2 and enter its view.
[Sysname] interface tunnel-bundle 2
[Sysname-Tunnel-Bundle2]
destination
member interface
link-management periodic-flooding timer
Use link-management periodic-flooding timer to set the interval at which IGP floods TE information.
Use undo link-management periodic-flooding timer to restore the default.
link-management periodic-flooding timer interval
The IGP floods TE information every 180 seconds.
MPLS TE view
interval: Specifies the interval at which IGP floods TE information. The value range is 0 and 30 to 3600 seconds. If you set the interval to 0, the periodical flooding feature is disabled.
When the reservable bandwidth of a link changes, IGP floods the link TE information to notify network devices of the change. You can use the mpls te bandwidth change thresholds command to configure IGP to flood only significant bandwidth changes of a link to prevent excessive IGP flooding. The bandwidth changes that cannot trigger immediate flooding are flooded at the interval configured by the link-management periodic-flooding timer command.
After you execute this command, the configured interval takes effect immediately.
# Configure IGP to flood TE information every 100 seconds.
[Sysname] mpls te
[Sysname-te] link-management periodic-flooding timer 100
member interface
Use member interface to specify a member interface for a tunnel bundle interface.
Use undo member interface to delete a member interface from a tunnel bundle interface.
member interface tunnel tunnel-number [ load-share value ]
undo member interface tunnel tunnel-number
No member interface is specified for a tunnel bundle interface.
Tunnel bundle interface view
tunnel tunnel-number: Specifies a member interface by its interface number. The value range for this argument is 0 to 70000.
load-share value: Configures a weight for a member interface, in the range of 1 to 65535. The default value is 1.
You can specify multiple member interfaces for a tunnel bundle interface.
Traffic is shared on the member interfaces in proportion of their weights. If the member interfaces have the same weight, they will share the same load.
For example, a tunnel bundle interface has three member interfaces. The weights for the member interfaces are 1, 1, and 2, respectively. The proportions of traffic forwarded by the member interfaces are 1/4, 1/4, and 1/2, respectively. If you configure the weights as 2, 2, and 4 for the member interfaces, the traffic forwarding proportions of the member interfaces are still 1/4, 1/4, and 1/2.
Adding or deleting a member interface enabled with MPLS TE tunnel traffic statistics clears traffic statistics on the tunnel bundle interface and all its member interfaces. MPLS TE tunnel traffic statistics for a tunnel interface is enabled by using the mpls te statistics command.
# Specify Tunnel 1 and Tunnel 2 as the member interfaces for Tunnel-Bundle 2, and configure the weights of the member interfaces as 1 and 3, respectively.
[Sysname-Tunnel-Bundle2] member interface tunnel 1
[Sysname-Tunnel-Bundle2] member interface tunnel 2 load-share 3
mpls te statistics
mpls te
Use mpls te to enable MPLS TE for the local node and enter MPLS TE view.
Use undo mpls te to disable MPLS TE for the local node.
mpls te
undo mpls te
MPLS TE is disabled.
Disabling MPLS TE also deletes all CRLSPs on the device and MPLS TE configurations on all interfaces.
# Enable MPLS TE for the local node and enter MPLS TE view.
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls te
[Sysname-te]
mpls te enable
mpls te affinity-attribute
Use mpls te affinity-attribute to set an affinity for a tunnel.
Use undo mpls te affinity-attribute to restore the default.
mpls te affinity-attribute attribute-value [ mask mask-value ]
The affinity is 0x00000000, and the mask is 0x00000000. That is, a tunnel can use any link.
Tunnel interface view
attribute-value: Specifies the affinity value, a hexadecimal number in the range of 0 to ffffffff. An affinity is a 32-bit binary number. Each bit of the affinity represents an attribute, which takes a value of 0 or 1.
mask mask-value: Specifies the mask of the affinity bits, a hexadecimal number in the range of 0 to ffffffff. A mask is a 32-bit binary number. Each bit of the mask determines whether to check the corresponding bit of the link attribute. If the mask bit is 1, the corresponding link attribute bit must be checked with the affinity bit. The link can be used by the tunnel only when the link attribute bit meets certain requirements. If the mask bit is 0, the corresponding link attribute bit is not checked.
Affinity determines which links a tunnel can use. The affinity attribute and its mask, and the link attribute are all 32-bit long. A link is available for a tunnel if the link attribute meets the following requirements:
·     The link attribute bits corresponding to the affinity attribute's 1 bits whose mask bits are 1 must have a minimum of one bit set to 1.
·     The link attribute bits corresponding to the affinity attribute's 0 bits whose mask bits are 1 must have no bit set to 1.
The link attribute bits corresponding to the 0 bits in the affinity mask are not checked.
For example, if the affinity is 0xfffffff0 and the mask is 0x0000ffff, a link is available for the tunnel when its attribute bits meet the following requirements:
·     The highest 16 bits each can be 0 or 1 (no requirements).
·     The 17th through 28th bits must have a minimum of one bit whose value is 1.
·     The lowest four bits must be 0.
# Set the tunnel affinity to 0x101 and mask to 0x303. Then, a link is available for the tunnel only when the link attribute bits (from left to right) meet the following requirements:
·     The 23rd bit is 0.
·     The 31st bit is 0.
·     A minimum of one bit from the 24th to 32nd bits must be 1.
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te affinity-attribute 101 mask 303
mpls te link-attribute
mpls te backup
Use mpls te backup to enable tunnel backup and specify the backup mode for a tunnel.
Use undo mpls te backup to disable tunnel backup.
mpls te backup { hot-standby [ wtr delay-time ] | ordinary }
undo mpls te backup
Tunnel backup is disabled.
hot-standby: Enables hot-standby backup for the tunnel. In this mode, a backup CRLSP is established immediately after the primary CRLSP is established. When the primary CRLSP fails, MPLS TE immediately switches traffic to the backup CRLSP.
wtr delay-time: Sets the recovery delay time for hot-standby backup, in seconds. The value range for the delay-time argument is 0 to 2592000. The default value is 10. To avoid packet loss during tunnel switchover, do not set a recovery delay time that is smaller than the default value.
ordinary: Enables ordinary backup for the tunnel. In this mode, a backup CRLSP is established after the primary CRLSP fails.
A tunnel interface must wait for the recovery delay time to elapse before it switches traffic from the backup CRLSP back to the recovered primary CRLSP.
After you execute this command for a tunnel, the record route flag is automatically set for the tunnel, regardless of whether the mpls te record-route command is executed.
In the same tunnel interface view, the mpls te backup command is mutually exclusive with the mpls te reoptimization command.
# Enable hot-standby backup for Tunnel 0.
[Sysname-Tunnel0] mpls te backup hot-standby
mpls te backup-path
Use mpls te backup bandwidth to configure the bypass tunnel to protect all CTs without limiting the protected bandwidth.
Use undo mpls te backup bandwidth to restore the default.
mpls te backup bandwidth [ ct0 | ct1 | ct2 | ct3 ]un-limited
The bandwidth and the CT that the bypass tunnel can protect are not specified.
After this command is executed, the bypass tunnel can protect all CTs without limiting the protected bandwidth. If the sum of traffic of the protected tunnels exceeds the actual bandwidth of the bypass tunnel, traffic of protected tunnels might be lost.
After you execute this command for a tunnel, the record route flag is automatically set for the tunnel, regardless of whether the mpls te record-route command is configured.
If both the mpls te backup bandwidth and mpls te fast-reroute commands are configured, only the mpls te backup bandwidth command takes effect.
Configure Tunnel 1 to provide protection for CRLSPs of all CTs without constraining the protected bandwidth.
[Sysname-Tunnel0] mpls te backup bandwidth un-limited
[Sysname-Tunnel0] quit
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te backup bandwidth ct1 1000
mpls te backup-path
Use mpls te backup-path to specify a path for the backup CRLSP and set the preference of the path.
Use undo mpls te backup-path to delete the specified path for the backup CRLSP.
mpls te backup-path preference value { dynamic [ pce [ ip-address ]&<0-8> ] | explicit-path path-name } [ no-cspf ]
undo mpls te backup-path preference value
MPLS TE uses the dynamically calculated path to establish the backup CRLSP.
preference value: Specifies a preference value for a path, in the range of 1 to 10. A smaller value represents a higher preference.
dynamic: Uses the path dynamically calculated by CSPF to establish the backup CRLSP.
pce: Uses the path calculated by PCEs to establish the CRLSP. If you do not specify this keyword, the local LSR uses the path dynamically calculated by CSPF.
[ ip-address ]&<0-8>: Specifies a space-separated list of a maximum of eight PCE addresses. If you do not specify a PCE address, the system automatically selects a PCE from the discovered PCEs. If you specify more than one PCE address, a BRPC calculation will be performed on the specified PCEs in configuration order.
explicit-path path-name: Uses the specified explicit path to establish the backup CRLSP. The path-name argument specifies the name of an explicit path, a case-sensitive string of 1 to 31 characters.
no-cspf: Calculates the path by searching the routing table instead of using the CSPF algorithm.
You can specify a maximum of 10 backup paths for a tunnel interface. The backup paths must have different preferences.
When establishing a backup CRLSP, MPLS TE performs CSPF calculations using the specified paths in the descending order of preference until the backup CRLSP is established successfully. If the CSPF calculations for all paths are failed, the backup CRLSP cannot be established.
This command takes effect only when backup has been enabled for the tunnel by using the mpls te backup command.
If you specify PCE addresses in this command or in the mpls te path command, the local device establishes PCEP sessions to the specified PCEs. If you do not specify a PCE address, the local device establishes PCEP sessions to all discovered PCEs.
# Configure Tunnel 0 to use explicit path path1 and the path calculated by PCEs to establish a backup CRLSP. Set a higher preference for the path calculated by PCEs.
[Sysname-Tunnel0] mpls te backup-path preference 2 explicit-path path1
[Sysname-Tunnel0] mpls te backup-path preference 1 dynamic pce 1.1.1.9 2.2.2.9
mpls te backup
mpls te path
mpls te bandwidth
Use mpls te bandwidth to assign bandwidth to the MPLS TE tunnel and specify a class type (CT) for the tunnel.
Use undo mpls te bandwidth to restore the default.
mpls te bandwidth { bandwidth | { ct0 ct0-bandwidth | ct1 ct1-bandwidth | ct2 ct2-bandwidth | ct3 ct3-bandwidth | ct4 ct4-bandwidth | ct5 ct5-bandwidth | ct6 ct6-bandwidth | ct7 ct7-bandwidth } * }
No bandwidth (0 bps) is assigned to an MPLS TE tunnel and the tunnel is available for CT 0.
bandwidth: Specifies the bandwidth required by the MPLS TE tunnel, in kbps. The value range for this argument is 1 to 4294967295
ct0 ct0-bandwidth: Specifies CT 0 for the tunnel, in kbps. The ct0-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 0. The value range for this argument is 1 to 4294967295.
ct1 ct1-bandwidth: Specifies CT 1 for the tunnel. The ct1-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 1. The value range for this argument is 1 to 4294967295 kbps.
ct2 ct2-bandwidth: Specifies CT 2 for the tunnel. The ct2-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 2. The value range for this argument is 1 to 4294967295 kbps.
ct3 ct3-bandwidth: Specifies CT 3 for the tunnel. The ct3-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 3. The value range for this argument is 1 to 4294967295 kbps.
ct4 ct4-bandwidth: Specifies CT 4 for the tunnel. The ct4-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 4. The value range for this argument is 1 to 4294967295 kbps.
ct5 ct5-bandwidth: Specifies CT 5 for the tunnel. The ct5-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 5. The value range for this argument is 1 to 4294967295 kbps.
ct6 ct6-bandwidth: Specifies CT 6 for the tunnel. The ct6-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 6. The value range for this argument is 1 to 4294967295 kbps.
ct7 ct7-bandwidth: Specifies CT 7 for the tunnel. The ct7-bandwidth argument specifies the bandwidth for the tunnel traffic of CT 7. The value range for this argument is 1 to 4294967295 kbps.
If you do not specify a CT for a tunnel, the tunnel is available for CT 0.
If you specify multiple CTs for a tunnel, the tunnel is available only for the specified CTs. For example, if you execute the mpls te bandwidth ct0 100 ct3 200 ct6 400 command, the following applies:
·     The bandwidth required by the tunnel traffic of CT 0, CT 3, and CT 6 is 100, 200, and 400 kbps, respectively.
·     A link can be selected for the tunnel only if the link's interface has BC0, BC3, and BC6 greater than or equal to 100, 200, and 400 kbps, respectively.
If you specify multiple CTs for a tunnel, the tunnel will use the extended-MAM model to select links for the traffic.
If the bandwidth required by the MPLS TE tunnel is more than 1024 kbps, set the bandwidth to a multiple of 1024 kbps.
This command applies only to the MPLS TE tunnels established by RSVP-TE. The bandwidth and CT of an MPLS TE tunnel established by using a static CRLSP are determined by the static-cr-lsp ingress command.
# Assign 1000 kbps bandwidth to MPLS TE Tunnel 0 and specify the CT of the tunnel as CT 0.
[Sysname-Tunnel0] mpls te bandwidth ct0 1000
mpls te max-link-bandwidth
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
Use mpls te bandwidth change thresholds to set the bandwidth up/down threshold for the IGP to flood TE information.
Use undo mpls te bandwidth change thresholds to restore the default.
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
The IGP floods the TE information when the bandwidth increases or decreases by 10% of the link reservable bandwidth.
Interface view
down: Specifies the bandwidth decrease percentage threshold that triggers the IGP to flood TE information. When the percentage of the link reservable-bandwidth decrease to the maximum link reservable bandwidth reaches or exceeds the threshold, the IGP floods the TE information and updates the TEDB.
up: Specifies the bandwidth increase percentage threshold that triggers the IGP to flood TE information. When the percentage of the link reservable-bandwidth increase to the maximum link reservable bandwidth reaches or exceeds the threshold, the IGP floods the TE information and updates the TEDB.
percent: Specifies the IGP flooding threshold in the range of 0% to 100%.
When the reservable bandwidth of a link changes, the IGP floods the link TE information to notify network devices of the change. To avoid frequent TE information flooding from affecting network performance, you can use this command to configure the IGP to flood only significant bandwidth changes of a link.
# On HundredGigE 1/0/1, configure the IGP to flood TE information when the link available bandwidth decreases by 100%.
[Sysname-HundredGigE1/0/1] mpls te bandwidth change thresholds down 100
mpls te binding-sid
Use mpls te binding-sid to specify a BSID for an MPLS TE tunnel.
Use undo mpls te binding-sid to delete the BSID of an MPLS TE tunnel.
mpls te binding-sid label label-value
No BSID is specified for an MPLS TE tunnel.
label label-value: Specifies a BSID label in the range of 16 to 1048575. The value range for the label-value argument is 16 to 250000.
A binding SID (BSID) identifies an MPLS TE tunnel. You can configure a path to use an MPLS TE tunnel by specifying the BSID of the MPLS TE tunnel for the path.
You can specify only one BSID on a tunnel interface. You must specify different BSIDs on different tunnel interfaces.
If a BSID label is already used, for example, by a static CRLSP, you can specify the BSID for an MPLS TE tunnel, but the configuration does not take effect. In this case, the BSID state of the tunnel is Dup. To view the BSID state of a tunnel, see the Binding SID State field in the output from the display mpls te tunnel-interface command.
# Specify BSID 1000 for MPLS TE tunnel 1.
[Sysname] interface Tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te binding-sid label 1000
display mpls te binding-sid
nextsid
mpls te delegation
Use mpls te delegation to enable CRLSP/SRLSP delegation on a PCC.
Use undo mpls te delegation to disable CRLSP/SRLSP delegation on a PCC.
mpls te delegation
CRLSP/SRLSP delegation is disabled.
After CRLSP/SRLSP delegation is enabled on a PCC, the PCC performs the following operations:
1.     Delegates CRLSPs/SRLSPs to a PCE in the descending order of delegation priority.
2.     Accepts CRLSP/SRLSP update requests from the delegated PCE.
3.     Updates CRLSPs/SRLSPs according to the configurations specified by the delegated PCE.
# Enable CRLSP/SRLSP delegation on a PCC.
[Sysname-Tunnel0] mpls te delegation
pce peer delegation-priority
mpls te enable (interface view)
Use mpls te enable to enable MPLS TE on an interface.
Use undo mpls te enable to disable MPLS TE on an interface.
mpls te enable
undo mpls te enable
MPLS TE is disabled on an interface.
Interface view
After you enable MPLS TE on an interface by using the mpls te enable command, the interface can act as part of an MPLS TE tunnel.
After you execute the undo mpls te enable command on an interface, MPLS TE is disabled on the interface and all CRLSPs on the interface are deleted.
# Enable MPLS TE on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mpls te enable
display mpls te link-management bandwidth-allocation
mpls te
mpls te enable (IS-IS view)
Use mpls te enable to enable MPLS TE for an IS-IS process.
Use undo mpls te enable to disable MPLS TE for an IS-IS process.
mpls te enable [ level-1 | level-2 ]
undo mpls te enable [ level-1 | level-2 ]
MPLS TE is disabled for an IS-IS process.
IS-IS view
level-1: Enables MPLS TE for IS-IS at Level-1.
level-2: Enables MPLS TE for IS-IS at Level-2.
If you do not specify an IS-IS level, this command enables MPLS TE for IS-IS at both Level-1 and Level-2.
IS-IS TE uses a sub-TLV of the extended IS reachability TLV (type 22) to carry TE attributes. Because the extended IS reachability TLV carries wide metrics, specify a wide metric-compatible metric style for the IS-IS process before enabling IS-IS TE. Available metric styles for IS-IS TE include wide, compatible, or wide-compatible. For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
If you execute this command multiple times, the most recent configuration takes effect. For example, if you execute the mpls te enable command and then the mpls te enable level-1 command, MPLS TE is enabled for Level-1 and disabled for Level-2.
After you enable MPLS TE for both Level-1 and Level-2, executing the undo mpls te enable level-1 command disables MPLS TE for Level-1. MPLS TE is still enabled for Level-2. Similarly, the undo mpls te enable level-2 command only disables MPLS TE for Level-2.
IS-IS messages cannot be fragmented at the IP layer. For IS-IS TE to operate correctly, make sure the following requirements are met:
·     The Link State PDU size is large enough so that the Link State PDUs can carry TE information. To set the maximum size of Level-1 and Level-2 Link State PDUs, use the lsp-length originate command.
·     The MTU of an IS-IS enabled interface is greater than or equal to the size of IS-IS Link State PDUs with TE information. To set the interface MTU, use the mtu command.
# Enable MPLS TE for IS-IS process 1 at Level-2.
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] mpls te enable level-2
cost-style (Layer 3—IP Routing Command Reference)
mpls te enable (OSPF area view)
Use mpls te enable to enable MPLS TE for an OSPF area.
Use undo mpls te enable to disable MPLS TE for an OSPF area.
mpls te enable
undo mpls te enable
MPLS TE is disabled for an OSPF area.
OSPF area view
OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see Layer 3—IP Routing Configuration Guide.
# Enable MPLS TE for OSPF process 1 in OSPF area 1.
[Sysname] ospf 1
[Sysname-ospf-1] area 1
[Sysname-ospf-1-area-0.0.0.1] mpls te enable
opaque-capability enable (Layer 3—IP Routing Command Reference)
Use mpls te fast-reroute to enable fast reroute (FRR).
Use undo mpls te fast-reroute to disable FRR.
FRR is disabled.
FRR provides a quick link or node protection on a CRLSP. FRR traffic switching can happen in as fast as 50 milliseconds, minimizing data loss.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, the following events occur:
·     FRR reroutes the traffic to a bypass tunnel.
·     The ingress node attempts to set up a new CRLSP.
After the new CRLSP is set up successfully, traffic is forwarded on the new CRLSP.
After FRR is enabled for a tunnel, the label recording feature is automatically enabled for the tunnel, regardless of whether the mpls te record-route label command is executed.
# Enable FRR for Tunnel 0.
[Sysname-Tunnel0] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
Use mpls te fast-reroute bypass-tunnel to specify a bypass tunnel for an interface.
Use undo mpls te fast-reroute bypass-tunnel to delete a bypass tunnel from an interface.
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
No bypass tunnel is specified for an interface.
Interface view
tunnel tunnel-number: Specifies a bypass tunnel by the tunnel interface number. The value range for the tunnel-number argument is 0 to 70000.The specified bypass tunnel must be established by RSVP, and the protected interface must not be the outgoing interface of a bypass tunnel.
The protected interface (where the command is executed) is the outgoing interface of a primary CRLSP. When the outgoing interface is down or a neighbor failure is detected through the BFD or hello mechanism, traffic of the primary CRLSP is switched to the bypass tunnel.
When you use this command, follow these restrictions and guidelines:
·     You can specify a maximum of three bypass tunnels for an interface.
·     A bypass tunnel can protect a maximum of three interfaces.
# Configure tunnel interface Tunnel 0 as the bypass tunnel for HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mpls te fast-reroute bypass-tunnel tunnel 0
fast-reroute timer
mpls te igp advertise
Use mpls te igp advertise to enable forwarding adjacency for an MPLS TE tunnel or tunnel bundle, so IGP advertises the tunnel as a link in the IGP network.
Use undo mpls te igp advertise to disable forwarding adjacency.
Tunnel interface view:
mpls te igp advertise [ hold-time value ]
Tunnel bundle interface view:
Forwarding adjacency is disabled for an MPLS TE tunnel or tunnel bundle, and IGP does not advertise the tunnel as a link in the IGP network.
hold-time value: Specifies the period of time that IGP waits to advertise an MPLS TE tunnel up/down state change. The value range is 0 to 4294967295 milliseconds. The default value is 0, which means when the MPLS TE tunnel state changes, IGP immediately advertises the state change.
MPLS TE tunnels that consist of SRLSPs do not support this command.
To make forwarding adjacency take effect, you must establish two MPLS TE tunnels or tunnel bundles in opposite directions between two nodes, and enable forwarding adjacency on both nodes.
On an interface, if you configure both the mpls te igp advertise command and the mpls te igp shortcut command, the most recent configuration takes effect.
After a tunnel interface becomes a tunnel bundle member interface, the hold-time configuration for the tunnel interface still takes effect. As a best practice, remove the hold-time configuration by using the undo mpls te igp advertise command in tunnel interface view to avoid impact on the tunnel bundle interface.
# Enable forwarding adjacency for MPLS TE Tunnel 0, and set the wait time before advertising a tunnel state change to 10000 milliseconds.
[Sysname-Tunnel0] mpls te igp advertise hold-time 10000
mpls te igp metric
mpls te igp metric
Use mpls te igp metric to assign a metric to an MPLS TE tunnel or tunnel bundle.
Use undo mpls te igp metric to restore the default.
mpls te igp metric { absolute value | relative value }
The metric of an MPLS TE tunnel or tunnel bundle equals its IGP metric.
absolute value: Specifies an absolute metric, an integer in the range of 1 to 65535.
relative value: Specifies a relative metric, an integer in the range of –10 to +10. A relative metric is the assigned metric value plus the IGP metric.
When IGP shortcut is enabled for an MPLS TE tunnel or tunnel bundle, the tunnel is included in the IGP route calculation as a link. You can use this command to configure the metric of this link used for IGP route calculation.
# Assign MPLS TE tunnel interface Tunnel 0 a relative metric of –1 for route calculation in IGP shortcut mechanism.
[Sysname-Tunnel0] mpls te igp metric relative -1
Use mpls te igp shortcut to enable IGP shortcut for an MPLS TE tunnel or tunnel bundle. The tunnel ingress node includes the tunnel in the IGP route calculation as a link.
Use undo mpls te igp shortcut to disable IGP shortcut.
mpls te igp shortcut [ isis | ospf ]
IGP shortcut is disabled for an MPLS TE tunnel or tunnel bundle. The ingress node does not include the tunnel in the IGP route calculation as a link.
isis: Specifies IS-IS as the IGP.
ospf: Specifies OSPF as the IGP.
If you do not specify the IGP in this command, both OSPF and IS-IS will include the MPLS TE tunnel or tunnel bundle in route calculation.
# Enable IGP shortcut for MPLS TE Tunnel 0, so the tunnel ingress node considers the tunnel as a link in the OSPF and IS-IS route calculation.
[Sysname-Tunnel0] mpls te igp shortcut
mpls te igp metric
Use mpls te link-attribute to set the link attribute.
Use undo mpls te link-attribute to restore the default.
mpls te link-attribute attribute-value
The link attribute value is 0x00000000.
Interface view
attribute-value: Specifies the link attribute value, a hexadecimal number in the range of 0 to ffffffff. A link attribute value is a 32-bit binary number. Each bit represents an attribute with a value of 0 or 1.
The TE information for a link advertised by the IGP includes the link attribute configured by this command. After receiving the link TE information, the ingress node of an MPLS TE tunnel determines whether the link can be used for MPLS TE tunnel establishment according to the following settings:
·     The configured tunnel affinity attribute.
·     The affinity mask.
·     The link attribute.
A link is available for a tunnel if the following requirements are met:
For example, if the affinity is 0xfffffff0 and the mask is 0x0000ffff, a link is available for the tunnel when its link attribute bits meet the following requirements:
# On HundredGigE 1/0/1, set the link attribute to 0x00000101.
[Sysname-HundredGigE1/0/1] mpls te link-attribute 101
mpls te load-share
Use mpls te load-share to assign bandwidth to an MPLS TE tunnel for unequal load sharing.
Use undo mpls te load-share to restore the default.
mpls te load-share value
No bandwidth is assigned to an MPLS TE tunnel interface for unequal load sharing. The proportion of traffic forwarded over the MPLS TE tunnel is based on the bandwidth assigned by the mpls te bandwidth command.
value: Specifies the bandwidth to be assigned to the MPLS TE tunnel for unequal load sharing, in the range of 1 to 4294967295 kbps.
Use this command to assign bandwidth to multiple equal-cost MPLS TE tunnels that have the same destination. Traffic to that destination is shared over the tunnels in proportion of their bandwidths.
For example, Tunnel 1, Tunnel 2, and Tunnel 3 are three equal-cost MPLS TE tunnels destined for the same address. The bandwidths of Tunnel 1, Tunnel 2, and Tunnel 3 are 10000 kbps, 10000 kbps, and 20000 kbps, respectively. The proportions of traffic forwarded over the tunnels are 1/4, 1/4, and 1/2, respectively. If you change the bandwidths of the tunnels to 1 kbps, 1 kbps, and 2 kbps, the traffic forwarding proportions of the tunnels are still 1/4, 1/4, and 1/2.
When adjacency forwarding is enabled, bandwidth assigned by the mpls te load-share command participates in IGP link cost calculation. As a result, the IGP link costs of the MPLS TE tunnels for unequal load sharing might be different. In this case, tune the IGP costs of the tunnels with the ospf cost or isis cost command to ensure that their IGP link costs are equal.
# Assign bandwidth 10000 kbps to Tunnel 0 for unequal load sharing.
[Sysname-Tunnel0] mpls te load-share 10000
isis cost (Layer 3—IP Routing Command Reference)
ospf cost (Layer 3—IP Routing Command Reference)
mpls te loop-detection
Use mpls te loop-detection to enable loop detection during establishment of an MPLS TE tunnel.
Use undo mpls te loop-detection to disable loop detection for the MPLS TE tunnel.
Loop detection is disabled for an MPLS TE tunnel.
When loop detection is enabled on the ingress node of an MPLS TE tunnel, the route recording feature is automatically enabled for the tunnel, regardless of whether the mpls te record-route command is configured. When establishing the MPLS TE tunnel, each node of the tunnel detects whether a loop has occurred according to the recorded route information.
# Enable loop detection for establishing MPLS TE Tunnel 0.
[Sysname-Tunnel0] mpls te loop-detection
Use mpls te max-link-bandwidth to set the maximum bandwidth for MPLS TE traffic on an interface.
Use undo mpls te max-link-bandwidth to restore the default.
mpls te max-link-bandwidth { bandwidth-value | percent percent-bandwidth }
The maximum link bandwidth for MPLS TE traffic is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum link bandwidth in the range of 1 to 4294967295 kbps.
percent percent-bandwidth: Specifies the percentage of the maximum link bandwidth out of the total interface bandwidth. The value range for the percent-bandwidth argument is 1 to 200.
The device carries the maximum link bandwidth in advertised IGP routes. The tunnel ingress node can obtain the information and use the information in CSPF calculation to select a path that meets the tunnel bandwidth requirements.
# On HundredGigE 1/0/1, set the maximum link bandwidth for MPLS TE traffic to 1158 kbps.
[Sysname-HundredGigE1/0/1] mpls te max-link-bandwidth 1158
mpls te bandwidth
Use mpls te max-reservable-bandwidth to set the maximum reservable bandwidth of the link (BC 0) and BC 1 in prestandard DS-TE RDM model.
Use undo mpls te max-reservable-bandwidth to restore the default.
mpls te max-reservable-bandwidth { bandwidth-value [ bc1 bc1-bandwidth ] | percent percent-bandwidth [ bc1 bc1-percent-bandwidth ] }
The maximum reservable bandwidth is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link (the value of BC 0), in the range of 1 to 4294967295 kbps.
bc1 bc1-bandwidth: Specifies the value of BC 1, in the range of 1 to 4294967295 kbps. The default value is 0.
percent percent-bandwidth: Specifies the percentage of BC 0 out of the maximum link bandwidth. The value range for the percent-bandwidth argument is 1 to 200.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum link bandwidth. The value range for the bc1-percent-bandwidth argument is 1 to 200.The default value is 0.
The device carries the bandwidth values configured by this command in IGP route advertisements. The tunnel ingress node can obtain the information and use the information in CSPF calculation to select a path that meets the tunnel bandwidth requirements.
The maximum reservable bandwidth of a link cannot be greater than the maximum bandwidth of the link configured with the mpls te max-link-bandwidth command. The value of BC 1 cannot be greater than the maximum reservable bandwidth of the link.
The bandwidth values configured by this command are only for MPLS TE traffic.
# Set the link maximum reservable bandwidth to 1158 kbps and BC 1 to 200 kbps for MPLS TE traffic in prestandard DS-TE RDM model.
[Sysname-HundredGigE1/0/1] mpls te max-reservable-bandwidth 1158 bc1 200
mpls te bandwidth
Use mpls te max-reservable-bandwidth mam to set the maximum reservable bandwidth of the link and the BCs in MAM model of the IETF DS-TE.
Use undo mpls te max-reservable-bandwidth mam to restore the default.
mpls te max-reservable-bandwidth mam { bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth | bc4 bc4-bandwidth | bc5   bc5-bandwidth | bc6  bc6-bandwidth | bc7 bc7-bandwidth } * | percent percent-bandwidth { bc0 bc0-percent-bandwidth | bc1 bc1-percent-bandwidth | bc2 bc2-percent-bandwidth | bc3 bc3-percent-bandwidth | bc4 bc4-percent-bandwidth | bc5 bc5-percent-bandwidth | bc6 bc6-percent-bandwidth | bc7 bc7-percent-bandwidth } * }
The maximum reservable bandwidth of a link is 0 kbps and each BC is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link, in the range of 1 to 4294967295 kbps.
bc0 bc0-bandwidth: Specifies the value of BC 0, in the range of 1 to 4294967295 kbps. By default, BC 0 is 0 kbps.
bc1 bc1-bandwidth: Specifies the value of BC 1, in the range of 1 to 4294967295 kbps. By default, BC 1 is 0 kbps.
bc2 bc2-bandwidth: Specifies the value of BC 2, in the range of 1 to 4294967295 kbps. By default, BC 2 is 0 kbps.
bc3 bc3-bandwidth: Specifies the value of BC 3, in the range of 1 to 4294967295 kbps. By default, BC 3 is 0 kbps.
bc4 bc4-bandwidth: Specifies the value of BC 4, in the range of 1 to 4294967295 kbps. By default, BC 4 is 0 kbps.
bc5 bc5-bandwidth: Specifies the value of BC 5, in the range of 1 to 4294967295 kbps. By default, BC 5 is 0 kbps.
bc6 bc6-bandwidth: Specifies the value of BC 6, in the range of 1 to 4294967295 kbps. By default, BC 6 is 0 kbps.
bc7 bc7-bandwidth: Specifies the value of BC 7, in the range of 1 to 4294967295 kbps. By default, BC 7 is 0 kbps.
percent-bandwidth: Specifies the percentage of the maximum reservable link bandwidth out of the maximum link bandwidth. The value range for this argument is 1 to 200.The default value is 0.
bc0 bc0-percent-bandwidth: Specifies the percentage of BC 0 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc2 bc2-percent-bandwidth: Specifies the percentage of BC 2 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc3 bc3-percent-bandwidth: Specifies the percentage of BC 3 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc4 bc4-percent-bandwidth: Specifies the percentage of BC 4 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc5 bc5-percent-bandwidth: Specifies the percentage of BC 5 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc6 bc6-percent-bandwidth: Specifies the percentage of BC 6 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
bc7 bc7-percent-bandwidth: Specifies the percentage of BC 7 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200.The default value is 0.
The maximum reservable bandwidth of a link cannot be greater than the maximum bandwidth of the link configured with the mpls te max-link-bandwidth command. Each BC cannot be greater than the maximum reservable bandwidth of the link.
The maximum reservable bandwidth and BCs configured by this command are only for MPLS TE traffic.
# Set the link maximum reservable bandwidth to 1158 kbps and BC 0 through BC 3 to 500 kbps, 300 kbps, 400 kbps, and 100 kbps for MPLS TE traffic in IETF DS-TE MAM model.
[Sysname-HundredGigE1/0/1] mpls te max-reservable-bandwidth mam 1158 bc0 500 bc1 300 bc2 400 bc3 100
mpls te bandwidth
Use mpls te max-reservable-bandwidth rdm to set the BCs in IETF DS-TE RDM model.
Use undo mpls te max-reservable-bandwidth rdm to restore the default.
mpls te max-reservable-bandwidth rdm { bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ] | percent percent-bandwidth [ bc1 bc1-percent-bandwidth ] [ bc2 bc2-percent-bandwidth ] [ bc3 bc3-percent-bandwidth ] }
Each BC is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link, or, the value of BC 0, in the range of 1 to 4294967295 kbps.
percent-bandwidth: Specifies the percentage of the maximum reservable link bandwidth (the value of BC 0) out of the maximum link bandwidth. The value range for the percentage is 1 to 200.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200. The default value is 0.
bc2 bc2-percent-bandwidth: Specifies the percentage of BC 2 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200. The default value is 0.
bc3 bc3-percent-bandwidth: Specifies the percentage of BC 3 out of the maximum reservable link bandwidth. The value range for the percentage is 1 to 200. The default value is 0.
BC 0 must be smaller than or equal to the maximum bandwidth of the link configured with the mpls te max-link-bandwidth command. BC 0 must be greater than or equal to BC 1. BC 1 must be greater than or equal to BC 2. BC 2 must be greater than or equal to BC 3.
The BCs configured by this command are only for MPLS TE traffic.
# Set BC 0 in IETF RDM model to 500 kbps, BC 1 to 400 kbps, BC 2 to 300 kbps, and BC 3 to 100 kbps.
[Sysname-HundredGigE1/0/1] mpls te max-reservable-bandwidth rdm 500 bc1 400 bc2 300 bc3 100
mpls te bandwidth
mpls te metric
Use mpls te metric to assign a TE metric to the link.
Use undo mpls te metric to restore the default.
mpls te metric value
undo mpls te metric
A link uses its IGP metric as its TE metric.
Interface view
value: Specifies a TE metric for the link, in the range of 1 to 4294967295.
The device carries two types of metrics (IGP metric and TE metric) of a link in the advertised IGP routes. You can use this command to configure the TE metric. When the tunnel ingress receives the link metrics, it uses the IGP or TE metric for path selection according to the configuration of the mpls te path-metric-type or path-metric-type command.
# Assign a TE metric of 20 to the link on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mpls te metric 20
mpls te path metric-type
path metric-type
mpls te passive-delegate report-only
Use mpls te passive-delegate report-only to configure a PCC to report CRLSP information of a tunnel to the PCE without delegating the CRLSP to the PCE.
Use undo mpls te passive-delegate report-only to restore the default.
A PCC does not report CRLSP information to the PCE.
This command is applicable to MPLS TE tunnels that use PCE-computed paths to establish CRLSPs. If an ingress needs to delegate only part of its CRLSPs to the PCE, the PCE does not have complete CRLSP information to calculate global bandwidth information. In this case, you can use this command to configure the ingress to report information about the undelegated CRLSPs to the PCE without delegating the CRLSPs to the PCE.
If you execute both the mpls te passive-delegate report-only command and the mpls te delegation command for a tunnel interface, the mpls te passive-delegate report-only command takes effect.
# Configure the device to report CRLSP information of Tunnel 1 to the PCE without delegating the CRLSP to the PCE.
[Sysname-Tunnel1] mpls te passive-delegate report-only
mpls te delegation
mpls te path
Use mpls te path to specify a path for the tunnel and set the preference of the path.
Use undo mpls te path to delete the specified path for the tunnel.
mpls te path preference value { dynamic [ pce [ ip-address ]&<0-8> ] | explicit-path path-name } [ no-cspf ]
undo mpls te path preference value
MPLS TE uses the dynamically calculated path to establish a CRLSP.
dynamic: Uses the path dynamically calculated by CSPF to establish the CRLSP.
[ ip-address ]&<0-8>: Specifies a space-separated list of a maximum of eight PCE addresses. If you do not specify a PCE address, the system automatically selects a PCE from discovered PCEs. If you specify more than one PCE address, a BRPC calculation will be performed on the specified PCEs in configuration order.
explicit-path path-name: Uses the specified explicit path to establish the CRLSP. The path-name argument specifies the name of an explicit path, a case-sensitive string of 1 to 31 characters.
You can specify a maximum of 10 paths for a tunnel interface. The paths must have different preferences.
When establishing a CRLSP, MPLS TE performs CSPF calculations according to the specified paths in a descending order of preference until the CRLSP is established successfully. If the CSPF calculations for all paths are failed, the CRLSP cannot be established.
If you specify PCE addresses in this command or in the mpls te backup-path command, the local device establishes PCEP sessions to the specified PCEs. If you do not specify a PCE address, the local device establishes PCEP sessions to all discovered PCEs.
# Configure Tunnel 0 to use explicit path path1 and the path calculated by PCEs for CRLSP establishment. Set a higher preference for the path calculated by PCEs.
[Sysname-Tunnel0] mpls te path preference 2 explicit-path path1
[Sysname-Tunnel0] mpls te path preference 1 dynamic pce 1.1.1.9 2.2.2.9
mpls te backup-path
mpls te path verification
Use mpls te path verification to configure path verification for an MPLS TE tunnel.
Use undo mpls te path verification to restore the default.
mpls te path verification { enable | disable }
The path verification configuration for an MPLS TE tunnel is the same as the global path verification configuration.
enable: Enables path verification for the MPLS TE tunnel.
disable: Disables path verification for the MPLS TE tunnel.
After path verification is enabled for an MPLS TE tunnel, the system examines the label and route mapping for the corresponding SRLSP. If the configured label has been occupied or the corresponding route does not exist, the system sets the SRLSP's state to down to avoid traffic forwarding failure.
# Enable path verification on MPLS TE tunnel interface Tunnel 1.
[Sysname-Tunnel1] mpls te path verification enable
Use mpls te path-metric-type to specify the link metric type for path selection of a tunnel.
Use undo mpls te path-metric-type to restore the default.
mpls te path-metric-type { igp | te }
No link metric type is specified for path selection of a tunnel.
igp: Uses the IGP metric.
te: Uses the TE metric.
Each MPLS TE link has two metrics: IGP metric and TE metric. By using the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay). Use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel1 for voice traffic and Tunnel2 for video traffic. Configure Tunnel1 to use IGP metrics for path selection, and configure Tunnel2 to use TE metrics for path selection. As a result, the video traffic travels through the path that has larger bandwidth and the voice service travels through the path that has lower delay.
If you specify a metric type for a tunnel by using this command, the tunnel uses the specified metric type for path selection. If you do not specify a metric type, the tunnel uses the metric type specified by the path-metric-type command in MPLS TE view for path selection.
# Configure Tunnel 0 to use the IGP metric for path selection.
[Sysname-Tunnel0] mpls te path-metric-type igp
mpls te metric
path-metric-type
mpls te priority
Use mpls te priority to set a setup priority and a holding priority for an MPLS TE tunnel.
Use undo mpls te priority to restore the default.
mpls te priority setup-priority [ hold-priority ]
The setup priority and the holding priority of an MPLS TE tunnel are both 7.
setup-priority: Specifies the setup priority in the range of 0 to 7. A smaller number represents a higher priority.
hold-priority: Specifies the holding priority in the range of 0 to 7. A smaller number represents a higher priority. If you do not specify this argument, the holding priority is the same as the setup priority.
The setup priority and holding priority of an MPLS TE tunnel determines the importance of the tunnel. A tunnel that has a higher setup priority than the holding priority of another tunnel can preempt the resources of the second.
The setup priority and holding priority can be applied to the following scenarios:
·     Multiple MPLS TE tunnels use the same path but the path does not have enough bandwidth for all the tunnels. You can configure different setup and holding priorities for different tunnels to make sure important tunnels can be established first.
·     Before an important tunnel is established, multiple less-important MPLS TE tunnels have existed on the network, occupying the bandwidth resources and the optimal path. You can assign a higher setup priority to the import tunnel, so the tunnel can preempt the resources of the existing tunnels and use the optimal path.
The setup priority of a tunnel must not be higher than its holding priority. Configure the setup priority value to be equal to or greater than the holding priority value.
# Set both the setup priority and holding priority of Tunnel 0 to 1.
[Sysname-Tunnel0] mpls te priority 1 1
Use mpls te record-route to enable route recording and label recording for a tunnel.
Use undo mpls te record-route to disable route recording and label recording for a tunnel.
mpls te record-route [ label ]
Route recording or label recording is disabled for a tunnel.
label: Enables both route recording and label recording. If you do not specify this keyword, the command enables only route recording.
Route recording records the nodes that an MPLS TE tunnel traverses. Label recording records the label assigned by each node. The recorded information helps you know about the path used by the MPLS TE tunnel and the label distribution information. When the tunnel fails, the recorded information helps you locate the fault.
# Enable route recording for MPLS TE tunnel 0.
[Sysname-Tunnel0] mpls te record-route
mpls te reoptimization (tunnel interface view)
Use mpls te reoptimization to enable tunnel reoptimization.
Use undo mpls te reoptimization to disable tunnel reoptimization.
mpls te reoptimization [ frequency seconds ]
Tunnel reoptimization is disabled.
frequency seconds: Specifies the tunnel reoptimization frequency in the range of 1 to 604800 seconds. The default is 3600 seconds. If you set the tunnel reoptimization frequency to a value smaller than 60, MPLS TE performs tunnel reoptimization at intervals of 60 seconds.
MPLS TE uses the tunnel reoptimization feature to implement dynamic CRLSP optimization. For example, if a link on the optimal path does not have enough reservable bandwidth during tunnel setup, MPLS TE sets up the tunnel on another path. When the link has enough bandwidth, tunnel optimization can automatically switch the tunnel to the optimal path.
You can configure the ingress to perform tunnel reoptimization periodically. Or, you can use the mpls te reoptimization command in user view to trigger the ingress to perform a tunnel reoptimization at any time.
On the same tunnel interface, the mpls te reoptimization command is mutually exclusive with the following commands:
·     mpls te route-pinning.
·     mpls te backup ordinary.
# Enable reoptimization for tunnel 0, and set the reoptimization frequency to 43200 seconds (12 hours).
[Sysname-Tunnel0] mpls te reoptimization frequency 43200
mpls te reoptimization (user view)
Use mpls te reoptimization to reoptimize all reoptimization-enabled MPLS TE tunnels.
After this command is executed in tunnel interface view, you can execute it in user view to trigger the ingress node to immediately reselect an optimal path for a tunnel.
# Reoptimize all reoptimization-enabled MPLS TE tunnels.
<Sysname> mpls te reoptimization
mpls te resv-style
Use mpls te resv-style to configure the resource reservation style for the MPLS TE tunnel.
Use undo mpls te resv-style to restore the default.
mpls te resv-style { ff | se }
The resource reservation style is SE.
ff: Specifies the resource reservation style as fixed filter (FF). In FF style, resources are reserved for individual senders and cannot be shared among senders on the same session.
se: Specifies the resource reservation style as shared explicit (SE). In SE style, resources are reserved for senders on the same session and shared among them.
This command applies only to MPLS TE tunnels established by RSVP-TE.
A tunnel always uses the SE style when the tunnel is enabled with tunnel reoptimization, fast reroute, and tunnel backup.
# Use the FF reservation style to establish MPLS TE tunnel 0.
[Sysname-Tunnel0] mpls te resv-style ff
mpls te signaling
mpls te retry
Use mpls te retry to set the maximum number of tunnel setup attempts.
Use undo mpls te retry to restore the default.
mpls te retry retries
undo mpls te retry
The maximum number of tunnel setup attempts is 3.
retries: Specifies the number of tunnel setup attempts, in the range of 1 to 4294967295.
After failing to establish an MPLS TE tunnel, the tunnel ingress node waits for the tunnel setup retry interval (configured by the mpls te timer retry command). Then it tries to set up the tunnel until the tunnel is established successfully. If the tunnel cannot be established when the number of attempts reaches the maximum, the ingress waits for a longer period and then repeats the previous process.
# Set the maximum number of tunnel setup attempts to 20.
[Sysname-Tunnel0] mpls te retry 20
mpls te timer retry
Use mpls te route-pinning to enable route pinning.
Use undo mpls te route-pinning to restore the default.
Route pinning is disabled.
When route pinning is enabled, an established CRLSP does not re-select an optimal path even if the optimal route has changed.
Use this feature to avoid CRLSPs from changing frequently on an unstable network. This feature ensures that the established CRLSPs are not re-established as long as they are available.
In the same tunnel interface view, the mpls te route-pinning command cannot be used together with the mpls te reoptimization command.
# Enable route pinning for Tunnel 0.
[Sysname-Tunnel0] mpls te route-pinning
mpls te service-class
Use mpls te service-class to set a service class value for an MPLS TE tunnel.
Use undo mpls te service-class to delete the service class value of an MPLS TE tunnel.
mpls te service-class service-class-value
No service class value is set for an MPLS TE tunnel.
service-class-value: Specifies a service class value for an MPLS TE tunnel. The value range for the service class value is 0 to 7. The smaller the service class value, the lower the tunnel priority. An MPLS TE tunnel that is not assigned a service class value has the lowest priority.
Class Based Tunnel Selection (CBTS) compares the service class value of the traffic with the service class values of MPLS TE tunnels. CBTS uses the following rules to select a tunnel to forward the traffic:
·     If the traffic matches an MPLS TE tunnel, CBTS uses this tunnel.
·     If the traffic matches multiple MPLS TE tunnels, CBTS selects a tunnel based on the flow forwarding mode set on the tunnel interface:
¡     If there is only one flow and flow-based forwarding is set, CBTS randomly selects a matching tunnel for packets of the flow.
¡     If there are multiple flows or if there is one flow but packet-based forwarding is set, CBTS uses all matching tunnels to load share the packets.
·     If the traffic does not match any MPLS TE tunnels, CBTS randomly selects a tunnel from all tunnels with the smallest service class value.
To set a service class value for traffic, use the remark service-class command in traffic behavior view. For information about the remark service-class command, see QoS commands in ACL and QoS Command Reference.
# Set the service class value of Tunnel 0 to 5.
[Sysname-Tunnel0] mpls te service-class 5
remark service-class (ACL and QoS Command Reference)
mpls te signaled-name
Use mpls te signaled-name to configure the tunnel name for an MPLS TE tunnel.
Use undo mpls te signaled-name to restore the default.
mpls te signaled-name name
The tunnel name of an MPLS TE tunnel is tunneltunnel-id.
name: Name of the MPLS TE tunnel, a case-sensitive string of 1 to 37 characters.
This command does not take effect on MPLS TE tunnels established by using PCE-Initiated-LSP packets.
Execute this command for an MPLS TE tunnel before you establish the tunnel. Executing this command for an existing MPLS TE tunnel will cause the tunnel to be re-established.
After you execute this command on a PCC to modify the name of an MPLS TE tunnel, you must also modify the tunnel name on the PCE if the PCE cannot learn MPLS TE tunnel names dynamically. Otherwise, the PCE cannot update the MPLS TE tunnel or send error messages for the tunnel.
You must configure different names for different MPLS TE tunnels, and do not configure a tunnel name in tunneltunnel-id format.
# Configure the tunnel name for MPLS TE tunnel 1 as red.
[Sysname-Tunnel1] mpls te signaled-name red
mpls te signaling
Use mpls te signaling to configure the signaling protocol for an MPLS TE tunnel interface.
Use undo mpls te signaling to restore the default.
mpls te signaling { rsvp-te | static | segment-routing }
MPLS TE uses RSVP-TE to establish tunnels.
rsvp-te: Uses the RSVP-TE signaling protocol to establish a tunnel.
static: Uses a static CRLSP to establish a tunnel.
segment-routing: Uses the Segment Routing (SR) protocol and stateful PCE to estalbish a tunnel.
To use RSVP-TE to establish an MPLS TE tunnel, you must enable MPLS TE and RSVP on each node and interface that the MPLS TE tunnel traverses.
To establish an MPLS TE tunnel over a static CRLSP, you must configure the tunnel to use the static CRLSP by using the mpls te static-cr-lsp command.
To use SR to establish an MPLS TE tunnel, you must enable the SR capability on the active stateful PCE (by using the pce capability segment-routing command). The PCC delegates the MPLS TE tunnel to the SR-capable PCE, and establishes the LSP by using the update messages sent by the PCE.
# Use RSVP-TE to establish MPLS TE tunnel 0.
[Sysname-Tunnel0] mpls te signaling rsvp-te
mpls te srlg
Use mpls te srlg to configure the Shared Risk Link Group (SRLG) membership of an interface.
Use undo mpls te srlg to remove an interface from an SRLG.
mpls te srlg srlg-number
undo mpls te srlg srlg-number
An interface does belong to an SRLG.
Interface view
srlg-number: Specifies the number of an SRLG, in the range of 0 to 4294967295.
An SRLG is a set of links that share a resource. If one link in the group fails, all other links also fail. For example, if the primary and backup SRLSPs are establish on links that belong to the same SRLG, the backup path cannot protect the primary path.
SRLG is a TE constraint. IGP will advertise SRLGs of interfaces in TE link TLVs. When a tunnel ingress receives SRLG information, it will include the SRLG constraint in path computation for the tunnel. In this way, the backup tunnel or path will avoid using the links in the SRLGs of the protected interface, improving the TE tunnel reliability.
An interface can belong to multiple SRLGs.
# Add interface HundredGigE 1/0/1 to SRLG 45.
[Sysname] hundredgige 1/0/1
[Sysname-HundredGigE1/0/1] mpls te srlg 45
Use mpls te static-cr-lsp to specify a static CRLSP for a tunnel.
Use undo mpls te static-cr-lsp to remove the configuration.
mpls te static-cr-lsp lsp-name
A tunnel does not use any static CRLSP.
lsp-name: Specifies a static CRLSP by its name, a case-sensitive string of 1 to 15 characters.
This command takes effect only when the mpls te signaling static command has been configured in tunnel interface view.
Execute this command on the ingress node. The static CRLSP specified must have been created by using the static-cr-lsp ingress command.
# Configure tunnel 0 to use static CRLSP static-te-3.
[Sysname-Tunnel0] mpls te static-cr-lsp static-te-3
mpls te signaling
static-cr-lsp egress
static-cr-lsp transit
mpls te statistics
Use mpls te statistics to enable MPLS TE tunnel traffic statistics.
Use undo mpls te statistics to disable MPLS TE tunnel traffic statistics.
mpls te statistics
MPLS TE tunnel traffic statistics is disabled.
# Enable tunnel traffic statistics for tunnel interface 0.
[Sysname-Tunnel0] mpls te statistics
display mpls statistics tunnel-interface
mpls te timer retry
Use mpls te timer retry to set the tunnel setup retry interval.
Use undo mpls te timer retry to restore the default.
mpls te timer retry seconds
The retry interval is 2 seconds.
seconds: Specifies the interval at which MPLS TE tries to re-establish the tunnel, in the range of 1 to 604800 seconds.
After failing to establish an MPLS TE tunnel, the tunnel ingress node waits for the tunnel setup retry interval. Then, it tries to set up the tunnel until the tunnel is established successfully. If the tunnel cannot be established when the number of attempts reaches the maximum (configured by the mpls te retry command), the ingress waits for a longer period. Then, it repeats the previous process.
# Set the setup retry interval to 20 seconds for tunnel 0.
[Sysname-Tunnel0] mpls te timer retry 20
mpls te retry
mpls te tunnel-attribute prefer
Use mpls te tunnel-attribute prefer to configure the attribute usage preference for MPLS TE tunnel setup.
Use undo mpls te tunnel-attribute prefer to restore the default.
mpls te tunnel-attribute prefer { local | pce }
The attribute usage preference configured in MPLS TE view applies.
pce: Uses the attributes carried in Update or Initial messages received from a PCE to establish the MPLS TE tunnel. For attributes not carried in the PCE messages, the device uses the default values of the attributes.
local: Uses the locally configured attributes to establish the MPLS TE tunnel. For attributes that are not configured locally, the device uses the default values of the attributes.
This command applies to the following attributes: bandwidth, affinity, setup and holding priorities, explicit path, link metric type, TE metric of a link, and BSID. For other attributes, the device always uses the locally configured attribute values.
The attribute usage preference can be configured in both tunnel interface view and MPLS TE view. The configuration in MPLS TE view applies to all MPLS TE tunnels. The configuration in tunnel interface view applies only to the current MPLS TE tunnel. For an MPLS TE tunnel, the configuration in tunnel interface view has a higher priority than the configuration in MPLS TE view.
# Configure interface Tunnel 1 to use the locally configured attributes to establish the MPLS TE tunnel.
[Sysname-Tunnel1] mpls te tunnel-attribute prefer local
nexthop
Use nexthop to add or modify a node in an explicit path, and configure the attributes of the node.
Use undo nexthop to delete a node in an explicit path.
nexthop [ index index-number ] ip-address [ exclude | include [ [ loose | strict ] | [ incoming | outgoing ] ] * ]
undo nexthop index index-number
An explicit path does not include any nodes.
Explicit path view
index index-number: Specifies an index for the node in the explicit path, in the range of 1 to 65535. If you do not specify an index, MPLS TE automatically calculates an index for the node, the value of which is the current maximum index value plus 100.
ip-address: Specifies a node by its IP address in dotted decimal notation.
exclude: Excludes the specified node from the explicit path.
include: Includes the specified node on the explicit path.
loose: Specifies the node as a loose node, which means the specified node and its previous hop can be indirectly connected.
strict: Specifies the node as a strict node, which means the node and its previous hop must be directly connected.
incoming: Uses the interface with the specified IP address as the packet incoming interface of the node.
outgoing: Uses the interface with the specified IP address as the packet outgoing interface of the node.
The IP address specified in this command can be one of the following:
·     Link IP address—IP address of an interface on the device, identifying a link.
·     Device LSR ID—Identifies the device.
The address of a strict node must be a link IP address. The address of a loose node can be a link IP address or the device LSR ID.
CSPF excludes the links or devices specified by exclude from path calculation, and uses the links specified by include in ascending order of indexes to establish a CRLSP.
When you execute the nexthop command, follow these guidelines:
·     If you specify an existing index, the command modifies the IP address or attribute of the node identified by that index.
·     If you specify neither include nor exclude, the include keyword is used by default.
·     If you specify neither loose nor strict, the strict keyword is used by default.
·     If you specify neither incoming nor outgoing, the incoming keyword is used by default.
·     The incoming and outgoing keywords are supported only for explicit paths of MPLS TE tunnels signaled by using Segment Routing.
# Exclude IP address 10.0.0.125 from MPLS TE explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] nexthop 10.0.0.125 exclude
display explicit-path
nextsid
nextsid
Use nextsid to add or modify a label node in an explicit path, and configure the attributes of the label node.
Use undo nextsid to delete a label node in an explicit path.
nextsid [ index index-number ] label label-value type { adjacency | binding-sid | prefix }
undo nextsid index index-number
An explicit path does not include any label nodes.
Explicit path view
label label-value: Specifies the label value for the node, in the range of 0, 3, and 16 to 1048575.
type: Specifies the type of the node.
adjacency: Specifies the node as an adjacency SID node.
binding-sid: Specifies the node as a node that uses a BSID.
prefix: Specifies the node as a prefix SID node.
In the same explicit path view, do not set the same index value for a node added by the nextsid command and a node added by the nexthop command. If you do so, the command executed later will fail.
If you specify an existing node index, the nextsid command modifies the attributes of the node.
# In explicit path path1, add an adjacency SID node whose label value is 100.
[Sysname-explicit-path-path1] nextsid index 1 label 100 type adjacency
nexthop
Use path verification enable to enable global path verification.
Use undo path verification enable to disable global path verification.
Global path verification is enabled.
MPLS TE view
After global path verification is enabled, the system examines the label and route mappings for all SRLSPs. If the label configured for an SRLSP has been occupied or the corresponding route does not exist, the system sets the SRLSP's state to down to avoid traffic forwarding failure.
The mpls te path verification command in tunnel interface view has a higher priority than the global path verification configuration.
# Enable global path verification.
[Sysname] mpls te
[Sysname-te] path verification enable
path-metric-type
Use path-metric-type to specify the link metric type to be used for path selection when a metric type is not explicitly specified for a tunnel.
Use undo path-metric-type to restore the default.
A tunnel uses TE metrics of links for path selection when no metric type is specified for the tunnel.
MPLS TE view
Each MPLS TE link has two metrics: IGP metric and TE metric. By correctly planning the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay). Use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel1 for voice traffic and Tunnel2 for video traffic. Configure Tunnel1 to use IGP metrics for path selection, and configure Tunnel2 to use TE metrics for path selection. As a result, the video traffic travels through the path that has larger bandwidth and the voice traffic travels through the path that has lower delay.
If you specify a metric type for a tunnel by using the mpls te path-metric-type command, the tunnel uses the specified metric type for path selection. If you do not specify a metric type, the tunnel uses the metric type specified by the path-metric-type command for path selection.
# Configure MPLS TE tunnels that are not explicitly specified with a metric type to use the IGP metric for path selection.
[Sysname] mpls te
[Sysname-te] path-metric-type igp
mpls te metric
pce address
Use pce address to configure an IP address for a PCE.
Use undo pce address to restore the default.
pce address ip-address
undo pce address
No PCE IP address is configured.
MPLS TE view
ip-address: Specifies the PCE IP address.
For the device to act as a PCE, use this command to specify a PCE IP address for the device.
As a best practice, configure the loopback interface address as the PCE address. For a PCE to be discovered, enable OSPF TE on the loopback interface to advertise the PCE address or manually specify the PCE on PCCs.
If no PCE address is configured, the local device can only act as a PCC and use the MPLS LSR ID to communicate with the PCE. A PCC sends a PCEP connection request to a PCE, but it does not accept a request from a PCE.
# Specify the local device as a PCE and configure the IP address for the PCE as 10.10.10.10.
[Sysname] mpls te
[Sysname-te] pce address 10.10.10.10
Use pce capability segment-routing to enable the SR capability for a PCEP device.
Use undo pce capability segment-routing to disable the SR capability for a PCEP device.
A PCEP device does not have the SR capability.
MPLS TE view
To establish an SR-capable stateful PCEP session, you need to enable the SR capability on both peers of the PCEP session. An SR-capable active stateful PCEP session supports delegation and update of SR-based LSPs, but it does not support path computation for SR-based LSPs.
# Enable the SR capability for the PCEP device.
[Sysname] mpls te
[Sysname-te] pce capability segment-routing
pce deadtimer
Use pce deadtimer to set the PCEP session deadtimer.
Use undo pce deadtimer to restore the default.
pce deadtimer value
undo pce deadtimer
The PCEP session deadtimer is 120 seconds.
MPLS TE view
value: Specifies the PCEP session deadtimer in the range of 0 to 255 seconds. Value 0 indicates that the PCEP session will never time out.
The local device sends the deadtimer setting to its peer. If the local device does not receive a PCEP message from its peer before the deadtimer expires, it tears down the PCEP session. Then, the local device tries to establish a new PCEP session to its peer.
The deadtimer must be greater than the keepalive interval.
# Set the PCEP session deadtimer to 180 seconds.
[Sysname] mpls te
[Sysname-te] pce deadtimer 180
display mpls te pce peer
pce keepalive
pce keepalive
Use pce keepalive to set the keepalive interval for PCEP sessions.
Use undo pce keepalive to restore the default.
pce keepalive interval
undo pce keepalive
The keepalive interval is 30 seconds.
MPLS TE view
interval: Specifies the keepalive interval in the range of 0 to 255 seconds. Value 0 indicates that no keepalive messages will be sent once the PCEP session is established.
If the keepalive interval for the local device is less than the min-keepalive setting on the peer device, the local device uses the peer's min-keepalive setting as the keepalive interval.
If the keepalive interval is set to 0 on the local device, configure the min-keepalive value as 0 on the peer device to avoid session establishment failure.
For more information about the min-keepalive setting, see the pce tolerance command.
# Set the keepalive interval to 60 seconds.
[Sysname] mpls te
[Sysname-te] pce keepalive 60
pce deadtimer
pce tolerance
pce multi-delegate enable
Use pce multi-delegate enable to enable the multi-delegation feature on a PCC to delegate LSPs to all PCEs.
Use undo pce multi-delegate enable to disable the multi-delegation feature.
The multi-delegation feature is disabled.
MPLS TE view
If multi-delegation is enabled on a PCC, the PCC can delegate delegation-enabled dynamic CRLSPs and SRLSPs to all the PCEs specified for the PCC. The PCC updates the CRLSPs and SRLSPs according to the update requests received from any of the PCEs.
# Enable the PCC to delete LSPs to all its PCEs.
[Sysname] mpls te
[Sysname-te] pce multi-delegate enable
mpls te delegation
Use pce peer delegation-priority to set the delegation priority of a PCE on a PCC.
Use undo pce peer delegation-priority to remove the delegation priority configuration of a PCE on a PCC.
pce peer ip-address delegation-priority priority
undo pce peer ip-address delegation-priority
The delegation priority of a PCE is 65535.
MPLS TE view
ip-address: Specifies the IP address of a PCE.
priority: Specifies the delegation priority in the range of 1 to 65535. A smaller value represents a higher priority.
If multiple PCEs are specified for a PCC, the PCC delegates CRLSPs to the PCE that has the highest delegation priority. If the delegation fails, the PCC chooses the PCE with the second highest priority.
# Set the delegation priority of PCE 10.10.10.10 to 1.
[Sysname] mpls te
[Sysname-te] pce peer 10.10.10.10 delegation-priority 1
mpls te delegation
pce peer keychain
Use pce peer keychain to configure PCEP session authentication for a peer PCC or PCE.
Use undo pce peer keychain to remove the PCEP session authentication configuration for a peer PCC or PCE.
pce peer ip-address keychain keychain-name
undo pce peer ip-address keychain
PCEP session authentication is not configured.
MPLS TE view
ip-address: Specifies the IP address of a PCC or PCE.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
For two devices to establish a PCEP session, you must configure keychain authentication and specify the same authentication algorithm and key string on both devices.
# Configure the device to use keychain test for authentication with peer PCE or PCC 10.10.10.10.
[Sysname] mpls te
[Sysname-te] pce peer 10.10.10.10 keychain test
display keychain (Security Command Reference)
pce redelegation-timeout
Use pce redelegation-timeout to set the redelegation timeout interval on a PCC.
Use undo pce redelegation-timeout to restore the default.
pce redelegation-timeout value
The redelegation timeout interval is 30 seconds.
MPLS TE view
value: Specifies the redelegation timeout interval in the range of 0 to 600 seconds.
If a PCEP session between a PCC and a PCE terminates, the PCC waits for the redelegation timeout interval before it redelegates the CRLSP. If the PCEP session is re-established within the redelegation timeout interval, the PCC redelegates the CRLSP to the PCE. If the PCEP session fails to be re-established within the interval, the PCC redelegates the CRLSP to another PCE that has a lower delegation priority.
The redelegation timeout interval must not be greater than the CRLSP state timeout interval (configured by the pce state-timeout command).
# Set the redelegation timeout interval to 20 seconds.
[Sysname] mpls te
[Sysname-te] pce redelegation-timeout 20
mpls te delegation
pce state-timeout
pce request-timeout
Use pce request-timeout to set the path calculation request timeout time.
Use undo pce request-timeout to restore the default.
pce request-timeout value
The request timeout time is 10 seconds.
MPLS TE view
value: Specifies the request timeout time in the range of 5 to 100 seconds.
In EPC calculation, if a PCC does not receive a calculation reply within the configured timeout time, it resends calculation requests to the PCE until it receives a reply.
In BRPC calculation, if a PCC does not receive a calculation reply from the PCE within the configured timeout time, the PCC does not resend a request. If a PCE does not receive a calculation reply from its downstream PCE within the timeout time, it sends the local calculation result to its upstream device as a reply. The PCE does not wait for a reply from its downstream PCE.
# Set the request timeout time to 20 seconds.
[Sysname] mpls te
[Sysname-te] pce request-timeout 20
pce retain initiated-lsp
Use pce retain initiated-lsp to configure the PCC to retain PCE-initiated LSPs.
Use undo pce retain initiated-lsp to restore the default.
A PCC deletes PCE-initiated LSPs when the state timeout interval expires.
MPLS TE view
After an active-stateful PCE establishes a connection with a PCC, the PCE can send an initiate message to the PCC to create an LSP. After the PCE is disconnected from the PCC, the PCC deletes the PCE-initiated LSPs when the state timeout interval (set by using the pce state-timeout command) expires. If the pce retain initiated-lsp command is executed, the PCC will retain these PCE-initiated LSPs.
# Configure the PCC to retain PCE-initiated LSPs.
[Sysname] mpls te
[Sysname-te] pce retain initiated-lsp
pce state-timeout
pce retain lsp-state
Use pce retain lsp-state to configure the PCC to retain PCE-updated LSP states.
Use undo pce retain lsp-state to restore the default.
A PCC restores the original LSP states (the states before PCE updates) when the state timeout interval expires.
MPLS TE view
After an active-stateful PCE establishes a connection with a PCC, the PCE can update the states of the delegated LSPs on the PCC. After the PCE is disconnected from the PCC, the PCC sets the PCE-updated LSPs to their original states when the state timeout interval (set by using the pce state-timeout command) expires. If the pce retain lsp-state command is executed, the PCC will retain the updated states for the LSPs.
The pce retain lsp-state command does not take effect on PCE-initiated LSPs.
# Configure the PCC to retain PCE-updated LSP states.
[Sysname] mpls te
[Sysname-te] pce retain lsp-state
mpls te delegation
pce state-timeout
pce state-timeout
Use pce state-timeout to set the state timeout interval on a PCC.
Use undo pce state-timeout to restore the default.
pce state-timeout value
The state timeout interval is 60 seconds.
MPLS TE view
value: Specifies the state timeout interval in the range of 0 to 600 seconds.
If a PCEP session between a PCC and a PCE terminates, the PCC waits for the state timeout interval before it clears the CRLSP state set by the PCE. If the PCC redelegates the CRLSP to another PCE before the state timeout interval elapses, the CRLSP state does not change.
The state timeout interval must be greater than or equal to the redelegation timeout interval (configured by the pce redelegation-timeout command).
# Set the state timeout interval to 100 seconds.
[Sysname] mpls te
[Sysname-te] pce state-timeout 100
pce static
Use pce static to specify a PCE as a peer on a PCC or PCE.
Use undo pce static to delete the specified PCE peer.
pce static ip-address
undo pce static ip-address
No PCE peers exist.
MPLS TE view
ip-address: Specifies the IP address of a PCE peer.
# Specify the PCE 10.10.10.10 as a peer.
[Sysname] mpls te
[Sysname-te] pce static 10.10.10.10
display mpls te pce discovery
pce tolerance
Use pce tolerance to set the minimum acceptable keepalive interval and the maximum number of allowed unknown messages received from the peer.
Use undo pce tolerance to restore the default.
pce tolerance { min-keepalive value | max-unknown-messages value }
undo pce tolerance { min-keepalive | max-unknown-messages }
The minimum acceptable keepalive interval is 10 seconds, and the maximum number of allowed unknown messages in a minute is 5.
MPLS TE view
min-keepalive value: Specifies the minimum acceptable keepalive interval in the range of 0 to 255 seconds. Value 0 indicates that any keepalive interval is acceptable.
max-unknown-messages value: Limits the maximum number of allowed unknown messages in a minute, in the range of 0 to 16384. Value 0 indicates that no limit is enforced.
If the keepalive interval set on the peer device is less than the min-keepalive setting on the local device, the peer device uses the min-keepalive setting as the keepalive interval.
If the number of unknown messages received from the peer in a minute exceeds the max-unknown-messages setting on the local device, the local device tears down the PCEP session.
# Set the minimum acceptable keepalive interval to 20 seconds and the maximum number of allowed unknown messages to 10.
[Sysname] mpls te
[Sysname-te] pce tolerance min-keepalive 20
[Sysname-te] pce tolerance max-unknown-messages 10
pce keepalive
pcep type
Use pcep type to specify the PCEP device (PCC or PCE) type.
Use undo pcep type to restore the default.
pcep type { active-stateful | passive-stateful }
undo pcep type
The PCEP device type is stateless.
MPLS TE view
active-stateful: Specifies the active stateful type.
passive-stateful: Specifies the passive stateful type.
For a PCC and a PCE to establish a stateful PCEP session, you must execute this command to specify the same device type for the two devices. After the stateful PCEP session is established, the PCE can know all CRLSPs maintained by the PCC.
·     If both the PCC and PCE are configured as active stateful devices, the PCE can accept CRLSP delegation requests sent by the PCC and optimize the CRLSPs.
·     If they are configured as passive stateful devices, the PCE does not accept CRLSP delegation requests sent by the PCC or optimize the CRLSPs.
If the device cannot act as both a PCE and a stateful PCC, do not execute both the pcep type command and the pce address command on the device.
# Specify the PCEP device type as active-stateful.
[Sysname] mpls te
[Sysname-te] pcep type active-stateful
reset mpls statistics tunnel-interface
Use reset mpls statistics tunnel-interface to clear MPLS TE tunnel traffic statistics.
reset mpls statistics tunnel-interface number
number: Specifies a tunnel interface by its number. The value range for this argument is 0 to 70000.
# Clear MPLS TE traffic statistics for tunnel interface 0.
<Sysname> reset mpls statistics tunnel-interface 0
reset mpls te pce statistics
Use reset mpls te pce statistics to clear PCC and PCE statistics.
reset mpls te pce statistics [ ip-address ]
ip-address: Specifies a PCC or PCE by its IP address. If you do not specify this argument, the command clears statistics about all PCEs and PCCs.
# Clear statistics about PCE 10.10.10.10.
<Sysname> reset mpls te pce statistics 10.10.10.10
display mpls te pce statistics
snmp-agent trap enable te
Use snmp-agent trap enable te to enable SNMP notifications for MPLS TE.
Use undo snmp-agent trap enable te to disable SNMP notifications for MPLS TE.
SNMP notifications for MPLS TE are disabled.
This command enables generating SNMP notifications for MPLS TE upon MPLS TE tunnel status changes, as defined in RFC 3812. For MPLS TE event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS TE.
[Sysname] snmp-agent trap enable te
switch-delay
Use switch-delay to set the time that MPLS TE must wait before switching the traffic to the new path.
Use undo switch-delay to restore the default.
switch-delay time-value
undo switch-delay
MPLS TE must wait 10000 milliseconds before switching the traffic to the new path.
MPLS TE view
time-value: Specifies the time that MPLS TE must wait before switching the traffic to the new path, in the range of 0 to 65535000 milliseconds.
When TE attributes (bandwidth and priority, for example) of an MPLS TE tunnel change, MPLS TE establishes a new CRLSP/SRLSP compliant with the new attributes. MPLS TE uses the make-before-break mechanism to make sure the new CRLSP/SRLSP is established to take over traffic forwarding before deleting the old CRLSP/SRLSP. The mechanism starts a switching delay timer after the new CRLSP/SRLSP is established and does not switch the traffic to the new CRLSP/SRLSP until the timer expires.
When the upstream is idle but the downstream is busy, the new CRLSP/SRLSP might not be able to come up on every LSR within the switching delay time. If the upstream switches traffic to the new CRLSP/SRLSP but the CRLSP/SRLSP is not up at the downstream, traffic forwarding is interrupted. To prevent this problem, use this command to tune the switching delay time. A proper switching delay time ensures that the new CRLSP/SRLSP has enough time to come up on the entire path before traffic is switched to it.
The configured switching delay time also applied to tunnel backup and FRR. When the primary path recovers, MPLS TE waits the configured delay time before switching the traffic back to the primary path.
# Configure MPLS TE to wait 100000 milliseconds before switching the traffic to the new path.
[Sysname] mpls te
[Sysname-te] switch-delay 100000
te-subtlv
Use te-subtlv to specify the types of the sub-TLVs for carrying DS-TE parameters.
Use undo te-subtlv to restore the default.
te-subtlv { bw-constraint value | unreserved-subpool-bw value } *
undo te-subtlv { bw-constraint | unreserved-subpool-bw } *
The bw-constraint parameter is carried in sub-TLV 252, and the unreserved-subpool-bw parameter is carried in sub-TLV 251.
IS-IS view
bw-constraint value: Specifies the type value of the sub-TLV that carries the bandwidth constraints, in the range of 23 to 254.
unreserved-subpool-bw value: Specifies the type value of the sub-TLV that carries the unreserved subpool bandwidth, in the range of 23 to 254.
In prestandard mode, no standard sub-TLV type values are defined to carry DS-TE parameters. Different vendors might use different type values. To communicate with devices from other vendors, use this command to specify the sub-TLV type values.
This command takes effect when the DS-TE mode is prestandard. It does not take effect when the DE-TE mode is IETF.
# For IS-IS process 1, specify the sub-TLV type value 200 for bw-constraint, and 202 for unreserved-subpool-bw.
[Sysname] isis 1
[Sysname-isis-1] te-subtlv bw-constraint 200 unreserved-subpool-bw 202
display isis mpls te configured-sub-tlvs
tunnel route-static
Use tunnel route-static to configure automatic static route advertisement.
Use undo tunnel route-static to restore the default.
tunnel route-static [ preference preference-value ]
Automatic static route advertisement is not configured.
Tunnel interface view
preference preference-value: Specifies a preference for the static route to be advertised, in the range of 1 to 255. The default value is 60.
IGP shortcut or forwarding adjacency is usually configured to direct traffic to an MPLS TE tunnel. On a network that contains multiple IGP areas, however, configuring IGP shortcut and forwarding adjacency causes route convergence failure. As a result, traffic cannot be forwarded over the MPLS TE tunnel. To direct traffic to an MPLS TE tunnel in this scenario, you can execute the tunnel route-static command on the ingress node of the MPLS TE tunnel. This command creates a static route whose destination address and output interface are the tunnel destination address and the tunnel interface, respectively.
# Configure automatic static route advertisement on Tunnel 1 and set the preference to 3.
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] tunnel route-static preference 3
mpls te igp advertise
mpls te igp shortcut
Use tunnel-attribute prefer to configure the global attribute usage preference for MPLS TE tunnel setup.
Use undo tunnel-attribute prefer to restore the default.
The device uses the attributes received from a PCE to establish MPLS TE tunnels.
MPLS TE view
pce: Uses the attributes carried in the Update or Initial messages received from a PCE to establish MPLS TE tunnels. For attributes not carried in the PCE messages, the device uses the default values of the attributes.
local: Uses the locally configured attributes to establish MPLS TE tunnels. For attributes that are not locally configured, the device uses the default values of the attributes.
This command applies to the following attributes: bandwidth, affinity, setup and holding priorities, explicit path, link metric  type, TE metric of a link, and BSID. For other attributes, the device always uses the locally configured values.
# Configure the device to use locally configured attributes to establish MPLS TE tunnels.
[Sysname] mpls te
[Sysname-te] tunnel-attribute prefer local
