02-Layer 2-LAN Switching Command Reference
HomeSupportSwitchesS12500X-AF SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R3606)-6W10002-Layer 2-LAN Switching Command Reference
04-Ethernet link aggregation commands
04-Ethernet link aggregation commands 254.00 KB
Ethernet link aggregation commands· 1
bandwidth· 1
default 1
description· 2
display interface· 3
display lacp system-id· 7
display link-aggregation capability· 8
display link-aggregation load-sharing mode· 8
display link-aggregation load-sharing path· 11
display link-aggregation member-port 13
display link-aggregation summary· 16
display link-aggregation verbose· 17
interface bridge-aggregation· 21
interface route-aggregation· 21
jumboframe enable· 22
lacp default-selected-port disable· 23
lacp edge-port 24
lacp mode· 24
lacp period short 25
lacp system-mac· 26
lacp system-number 26
lacp system-priority· 27
link-aggregation bfd· 28
link-aggregation bfd-compatible enable· 29
link-aggregation capability· 30
link-aggregation global load-sharing algorithm·· 31
link-aggregation global load-sharing mode· 32
link-aggregation global load-sharing offset 33
link-aggregation global load-sharing seed· 33
link-aggregation global load-sharing tunnel 34
link-aggregation ignore speed· 35
link-aggregation ignore vlan· 36
link-aggregation lacp traffic-redirect-notification enable· 37
link-aggregation load-sharing mode· 38
link-aggregation mode· 38
link-aggregation port-priority· 39
link-aggregation selected-port maximum·· 40
link-aggregation selected-port minimum·· 41
link-aggregation selected-port minimum percentage· 42
link-delay· 43
mac-address· 44
mtu· 45
port link-aggregation group· 46
port s-mlag group· 46
reset counters interface· 47
reset lacp statistics· 48
shutdown· 48
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
# Restore the default settings for Layer 3 aggregate interface 1.
[Sysname-Route-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
# Configure the description as connect to the lab for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
 Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
 Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
 Input (total):  5364747 packets, 686688416 bytes
          2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
 Input (normal):  5364747 packets, 686688416 bytes
          - ignored, - parity errors
 Output (total): 1042508 packets, 133441832 bytes
          1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
 Output (normal): 1042508 packets, 133441832 bytes
          1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
          - lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Port priority: 0
 0 packets input, 0 bytes, - drops
 0 packets output, 0 bytes, - drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                UP   auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
Description of the interface.
Bandwidth
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps.
Port priority
Port priority of the interface.
The interface speed and duplex mode are unknown.
Port link-type
Port link type:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLAN whose packets are sent out of this interface with a tag.
Untagged VLANs
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Last 300 seconds input/output rate
Average input or output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
Statistics about packets received on the interface. A hyphen (-) indicates that the statistical item is not supported.
Statistics about packets sent on the interface. A hyphen (-) indicates that the statistical item is not supported.
Line protocol state
Data link layer state of the interface:
·     UP.
·     DOWN.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output).
Use display link-aggregation capability to display the link aggregation capability for the device.
# Display the link aggregation capability for the device.
<Sysname> display link-aggregation capability
Default link aggregation capability:
  Maximum groups: 1024
  Maximum Selected ports per group: 16
Current link aggregation capability:
Link aggregation capability at the next reboot:
Supported link aggregation capability list:
  1024*16        512*32         256*64         128*128        64*256
Link aggregation capabilities supported by the device. Each item in the list is in the format of maximum number of aggregation groups*maximum number of Selected ports per aggregation group.
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when the corresponding aggregate interfaces exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
Link-aggregation load-sharing offset:
Link-aggregation load-sharing seed:
Tunneled traffic load-sharing mode:
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
10
11
0x0
Inner
destination-mac address  source-mac address
# Display the default link-aggregation load sharing modes of Layer 2 aggregation group 1.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 1
Bridge-Aggregation1 load-sharing mode:
# Display the set link-aggregation load sharing mode of Layer 2 aggregation group 1.
# Display the default link-aggregation load sharing modes of Layer 3 aggregation group 1.
<Sysname> display link-aggregation load-sharing mode interface route-aggregation 1
Route-Aggregation1 load-sharing mode:
# Display the link-aggregation load sharing mode of Layer 3 aggregation group 1. This example displays a user-configured setting.
destination-ip address  source-ip address
Link aggregation load sharing algorithm.
By default, this field displays Default. If you have configured the load sharing algorithm, this field displays the configured algorithm.
Hash offset to adjust the load sharing hash results on link aggregations.
By default, this field displays Default. If you have configured a hash offset, this field displays the configured offset value.
Link aggregation load sharing hash seed.
By default, this field displays Default. If you have configured the load sharing hash seed, this field displays the configured seed.
Load sharing mode for tunneled traffic on aggregate links.
By default, this field displays Default. If you have configured a load sharing mode for tunneled traffic, this field displays the configured mode.
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2 and Layer 3 traffic.
If you have configured the global link-aggregation load sharing mode, this field displays the configured mode.
Link-aggregation load sharing mode of Layer 2 aggregation group 1.
By default, this field displays the global link-aggregation load sharing modes.
If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode.
Link-aggregation load sharing mode of Layer 3 aggregation group 1.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, the system distributes Layer 2 traffic based on the destination and source IP addresses, destination and source MAC addresses, destination and source ports, ingress port, and IP protocol type.
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, the system distributes Layer 3 traffic based on the destination and source IP addresses, destination and source MAC addresses, destination and source ports, ingress port, and IP protocol type.
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination IP addresses.
Use display link-aggregation load-sharing path to display forwarding information about the specified traffic flow.
display link-aggregation load-sharing path interface { bridge-aggregation | route-aggregation } interface-number ingress-port interface-type interface-number [ route ] { { destination-ip ip-address | destination-ipv6 ipv6-address } | { source-ip ip-address | source-ipv6 ipv6-address } | destination-mac mac-address | destination-port port-id | ip-protocol protocol-id | source-mac mac-address | source-port port-id | vlan vlan-id }*
interface-number: Specifies an existing aggregate interface by its number.
ingress-port interface-type interface-number: Specifies an ingress port by its type and number. The ingress port must be a physical port.
route: Displays forwarding information about Layer 3 traffic. If you do not specify this keyword, the command displays forwarding information about Layer 2 traffic.
destination-ip ip-address: Specifies a destination IPv4 address.
destination-ipv6 ipv6-address: Specifies a destination IPv6 address.
source-ip ip-address: Specifies a source IPv4 address.
source-ipv6 ipv6-address: Specifies a source IPv6 address.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format.
destination-port port-id: Specifies a destination port number in the range of 1 to 65535.
ip-protocol protocol-id: Specifies an IP protocol by its ID in the range of 0 to 255.
source-mac mac-address: Specifies a source MAC address in H-H-H format.
source-port port-id: Specifies a source port number in the range of 1 to 65535.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
A parameter specified in the command might not be used for selecting the egress port. The Load sharing parameters field displays the parameters that are used in egress port selection. For example, you can specify both the destination-mac mac-address and destination-ip ip-address options. If only the destination MAC address is used for selecting the egress port, the Load sharing parameters field does not display the destination-ip parameter.
If a parameter required for selecting the egress port is not specified, the default value of the parameter is used. If the parameter does not have any default values, the parameter is set to 0.
This command takes effect only on per-flow load sharing and automatic load sharing. As a best practice, do not use this command for per-packet load sharing.
# Display forwarding information about the specified traffic flow to be sent out of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface bridge-aggregation 1 ingress-port hundredgige 1/0/1 destination-mac 0000-fc00-0001 source-mac 0000-fc00-0002 source-ip 10.100.0.2 destination-ip 10.100.0.1
Load sharing mode: destination-mac, source-mac, source-ip, destination-ip
Unspecified parameters are set to 0.
Load-sharing parameters:
  Ingress port: HundredGigE1/0/1
  Destination MAC: 0000-fc00-0001
  Source MAC: 0000-fc00-0002
  Destination IP: 10.100.0.1
  Source IP: 10.100.0.2
Egress port: HundredGigE1/0/3
# Display forwarding information about the specified traffic flow to be sent out of Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display link-aggregation load-sharing path interface route-aggregation 1 ingress-port hundredgige 1/0/1 source-ip 10.100.0.2 destination-ip 10.100.0.1
Load sharing mode: destination-ip
Table 5 Command output
Load sharing mode:
Load sharing mode set for the aggregation group:
·     destination-mac—Traffic is load shared based on destination MAC addresses.
·     source-mac—Traffic is load shared based on source MAC addresses.
·     destination-ip—Traffic is load shared based on destination IP addresses.
·     source-ip—Traffic is load shared based on source IP addresses.
·     destination-port—Traffic is load shared based on destination ports.
·     source-port—Traffic is load shared based on source ports.
·     ip-protocol—Traffic is load shared based on IP protocol types.
·     ingress-port—Traffic is load shared based on ingress ports.
·     packet type-based sharing—The system automatically selects a load sharing mode depending on the packet type. If no load sharing mode is set, this field also displays packet type-based sharing.
Parameters that are used in egress port selection.
Egress port
Egress port of the specified traffic flow. If no egress port is found, this field displays N/A.
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed link aggregation information about HundredGigE 1/0/1, which is a member port of a static Layer 2 aggregation group.
<Sysname> display link-aggregation member-port hundredgige 1/0/1
       G -- Defaulted, H -- Expired
HundredGigE1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed link aggregation information about HundredGigE 1/0/1, which is a member port of a static Layer 3 aggregation group.
HundredGigE1/0/1:
Port Number: 1
Oper-Key: 1
# Display detailed link aggregation information about HundredGigE 1/0/2, which is a member port of a dynamic Layer 2 aggregation group.
<Sysname> display link-aggregation member-port hundredgige 1/0/2
HundredGigE1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
# Display detailed link aggregation information about HundredGigE 1/0/2, which is a member port of a dynamic Layer 3 aggregation group.
HundredGigE1/0/2:
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Table 6 Command output
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the system LACP priority and the system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG10     S     None                    1         0           0           NonS
BAGG20     D     0x8000,00e0-fcff-ff01   2         0           0           Shar
Table 7 Command output
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local system LACP priority and the local system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ all-configuration ]
all-configuration: Specifies all member ports of the specified aggregate interfaces. If you do not specify this keyword, the command displays only the aggregation member ports on the present cards.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto
Role: P -- Primary, S -- Secondary
Aggregation Mode: Dynamic
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  HGE1/0/1            S        32768    1        1                      {ACDEF}
  HGE1/0/2            S        32768    2        1                      {ACDEF}
  HGE1/0/3            S        32768    3        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  HGE1/0/1            32768    1        1        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/2            32768    2        1        0x8000, 000f-e267-57ad {ACDEF}
  HGE1/0/3            32768    3        1        0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Port: A -- Auto
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  Port             Status  Priority Oper-Key  Role
  HGE1/0/1         U       32768    1         None
  HGE1/0/2         U       32768    1         None
  HGE1/0/3         U       32768    1         None
# Display detailed information about Layer 3 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 1
Port: A -- Auto
Local:
Remote:
# Display detailed information about Layer 3 aggregation group 1, which is a static aggregation group.
Port: A -- Auto
  HGE1/0/1         S       32768    1         None
  HGE1/0/2         S       32768    1         None
  HGE1/0/3         S       32768    1         None
Table 8 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type. Letter A indicates that the port was assigned to the aggregation group by the automatic link aggregation feature or the automatic member port assignment feature.
Flags
Aggregate Interface
Name of the aggregate interface.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
System ID
Local system ID, containing the local system LACP priority and the local system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Index—Port index.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Index and Flag field are not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port.
·     Priority—Priority of the peer port.
·     Index—Index of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 4096.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
When the system is operating in enhanced Layer 2 mode, to enable a Layer 3 aggregate subinterface to forward traffic, you must configure the subinterface to terminate the VLAN whose number is the same as the subinterface number. To configure VLAN termination, use the vlan-type dot1q vid vlan-id command. For more information about the system operating mode, see device management configuration in Fundamentals Configuration Guide.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
vlan-type dot1q vid
jumboframe enable
Use jumboframe enable to allow the jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames with a maximum length of 12288 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 12288. If you do not specify this argument, the default frame length is used.
# Enable the support for jumbo frames on Bridge-Aggregation 1, setting the maximum jumbo frame size to the default.
[Sysname-Bridge-Aggregation1] jumboframe enable
# Enable the support for jumbo frames on Route-Aggregation 1, setting the maximum jumbo frame size to the default.
[Sysname-Route-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Sysname-Bridge-Aggregation1] lacp edge-port
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] lacp mode passive
lacp period short
Use lacp period short to set the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not set the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Set the short LACP timeout interval (3 seconds) on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] lacp period short
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
All S-MLAG devices must use the same LACP system MAC address.
The LACP system MAC address configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system MAC address to send LACPDUs. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command takes effect only on aggregate interfaces in S-MLAG groups. Aggregate interfaces not in S-MLAG groups do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
All S-MLAG devices must use the same LACP system priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
Use link-aggregation bfd to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ipv4-address destination ipv4-address
undo link-aggregation bfd [ ipv4 ]
BFD is disabled for an aggregation group.
ipv4: Specifies IPv4 BFD.
source: Specifies the source IP address of BFD sessions.
destination: Specifies the destination IP address of BFD sessions.
ipv4-address: Specifies an IPv4 address. The address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
# Enable IPv4 BFD for Layer 2 aggregation group 1, and specify the source and destination IPv4 addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
# Enable IPv4 BFD for Layer 3 aggregation group 1, and specify the source and destination IPv4 addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation bfd-compatible enable to enable BFD compatible mode on an aggregate interface.
Use undo link-aggregation bfd-compatible enable to disable BFD compatible mode on an aggregate interface.
BFD compatible mode is disabled on aggregate interfaces.
BFD compatible mode enables BFD to operate correctly on an aggregate link whose remote end is a third-party device that implements BFD differently from the device.
With BFD compatible mode enabled, all member ports in an aggregation group establish BFD sessions with their peer ports. The BFD sessions are not deleted or re-established when the aggregation states of the member ports change.
# Enable BFD compatible mode on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation bfd-compatible enable
# Enable BFD compatible mode on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
Use link-aggregation capability to configure the link aggregation capability for the device.
Use undo link-aggregation capability to restore the default.
link-aggregation capability max-group max-group-number max-selected-port max-selected-port-number
The device supports a maximum of 1024 aggregation groups, and each aggregation group can contain a maximum of 16 Selected ports.
max-group max-group-number: Specifies the maximum number of aggregation groups that the device supports. The value for the max-group-number argument can be 64, 128, 256, 512, or 1024.
max-selected-port max-selected-port-number: Specifies the maximum number of Selected ports per aggregation group. The value for the max-selected-port-number argument can be 16, 32, 64, 128, or 256.
After you execute this command, save the configuration and reboot the device for the configuration to take effect. Before rebooting the device, make sure you know the possible impact on the network.
This command fails if the number of existing aggregation groups exceeds the configured maximum number.
If you create aggregation groups after executing the link-aggregation capability command and the number of aggregation groups exceeds the configured number, some aggregation groups are deleted at the next reboot.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
For link aggregation to operate correctly, set the same link aggregation capability for both ends of an aggregate link.
If you execute this command multiple times, the most recent configuration takes effect at the next reboot.
# Configure the device to support a maximum of 1024 aggregation groups and a maximum of 16 Selected ports per aggregation group.
[Sysname] link-aggregation capability max-group 1024 max-selected-port 16
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Please save the configuration, and reboot the device.
Use link-aggregation global load-sharing algorithm to configure a link aggregation load sharing algorithm.
Use undo link-aggregation global load-sharing algorithm to restore the default.
link-aggregation global load-sharing algorithm algorithm-number
The device uses link aggregation load sharing algorithm 3.
algorithm algorithm-number: Specifies an algorithm by its number in the range of 1 to 11.
This command is intended to help you optimize load sharing performance when the default load sharing mode is used. It does not take effect on per-flow load sharing.
Each load sharing algorithm represents a CRC calculation method.
You can use a load sharing algorithm and a hash seed individually or in combination to obtain the optimal load sharing performance.
When you try each algorithm or algorithm and seed combination, use the display counters command to verify the load sharing result.
# Specify algorithm 1 as the link aggregation load sharing algorithm.
[Sysname] link-aggregation global load-sharing algorithm 1
display counters (Interface Command Reference)
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | ip-protocol | source-ip | source-mac | source-port } *
The device distributes traffic on link aggregations based on the following information:
·     Destination and source IP addresses.
·     Destination and source MAC addresses.
·     Destination and source ports.
·     Ingress port.
·     IP protocol type.
destination-ip: Load shares traffic based on destination IP addresses.
destination-mac: Load shares traffic based on destination MAC addresses.
destination-port: Load shares traffic based on destination ports.
ingress-port: Load shares traffic based on ingress ports.
ip-protocol: Load shares traffic based on IP protocol types.
source-ip: Load shares traffic based on source IP addresses.
source-mac: Load shares traffic based on source MAC addresses.
source-port: Load shares traffic based on source ports.
If an unsupported load sharing mode is set, an error prompt appears.
The device supports any combination of the keywords in the link-aggregation global load-sharing mode command.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
Use link-aggregation global load-sharing offset to set a hash offset to adjust the load balancing hash results on link aggregations.
Use undo link-aggregation global load-sharing offset to restore the default.
link-aggregation global load-sharing offset offset-value
No hash offset is configured for load sharing on link aggregations.
offset-value: Specifies a hash offset. The value range for this argument is 0 to 15.
IMPORTANT
IMPORTANT:
Misuse of this command causes unbalanced traffic distribution. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
If undesirable traffic imbalance occurs on link aggregations, you can use this command to adjust the load sharing results on link aggregations.
# Set the hash offset to 2 for the load balancing hash results on link aggregations.
[Sysname] link-aggregation global load-sharing offset 2
Use link-aggregation global load-sharing seed to configure a link aggregation load sharing hash seed.
Use undo link-aggregation global load-sharing seed to restore the default.
link-aggregation global load-sharing seed seed-number
No hash seed is configured.
seed seed-number: Specifies a seed in the range of 0 to FFFF.
The load sharing hash seed is used in hashing.
# Specify 1023 (3FF in hexadecimal format) as the link aggregation load sharing hash seed.
[Sysname] link-aggregation global load-sharing seed 3FF
Use link-aggregation global load-sharing tunnel to set the load sharing mode for tunneled traffic on link aggregations.
Use undo link-aggregation global load-sharing tunnel to restore the default.
link-aggregation global load-sharing tunnel { all | inner | outer }
No load sharing mode is configured for tunneled traffic.
all: Distributes tunneled traffic based on the inner IP header and outer IP header.
inner: Distributes tunneled traffic based on the inner IP header.
outer: Distributes tunneled traffic based on the outer IP header.
This command sets the criterion used by aggregation groups to distribute tunneled traffic for load sharing.
# Set the load sharing mode to inner IP header for tunneled traffic on link aggregations.
[Sysname] link-aggregation global load-sharing tunnel inner
Use link-aggregation ignore speed to configure an aggregation group to ignore port speed in setting the aggregation states of member ports.
Use undo link-aggregation ignore speed to restore the default.
An aggregation group does not ignore port speed in setting the aggregation states of member ports.
IMPORTANT
IMPORTANT:
·     When you execute this command or its undo form, the operational key changes and the aggregate interface flaps temporarily.
·     This command might cause traffic loss on Selected ports operating at a speed lower than the other Selected ports in the aggregation group when traffic is distributed among the ports.
This command allows ports at a different speed than the reference port to become Selected by ignoring the port speed during operational key calculation.
You must configure the same port speed ignoring setting at the two ends of a static configuration to ensure that the peer ports are placed in the same aggregation state. This requirement does not apply to a dynamic aggregation, on which the two ends negotiate the aggregation state of the peer ports automatically.
# Configure Layer 2 aggregation group 1 to ignore port speed in setting the aggregation states of member ports.
[Sysname-Bridge-Aggregation1] link-aggregation ignore speed
# Configure Layer 3 aggregation group 1 to ignore port speed in setting the aggregation states of member ports.
[Sysname-Route-Aggregation1] link-aggregation ignore speed
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to remove the specified ignored VLANs for a Layer 2 aggregate interface.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
This command takes effect only when the link type of the Layer 2 aggregate interface is hybrid or trunk.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
·     The port is shut down by using the shutdown command.
·     The slot that hosts the port reboots, but the aggregation group contains Selected ports on other slots.
The device does not redirect traffic to member ports that become Selected during the traffic redirection process.
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode flexible
The group-specific load sharing mode is the same as the global load sharing mode.
Blade aggregate interface view
flexible: Load shares traffic flexibly based on the packet types (Layer 2 protocol packet, IPv4 packet, or IPv6 packet).
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
# Configure Layer 3 aggregation group 1 to load share packets based on destination IP addresses.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-ip
Use link-aggregation mode to set the aggregation mode of an aggregation group.
Use undo link-aggregation mode to restore the default.
link-aggregation mode { dynamic | static }
An aggregation group operates in static aggregation mode.
dynamic: Specifies dynamic mode and enables LACP.
static: Specifies static mode.
Aggregation mode change might cause Selected member ports to become Unselected. When you change the aggregation mode, make sure you understand the impact of the change on services.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface HundredGigE 1/0/2.
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] link-aggregation port-priority 64
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
An aggregation group can contain a maximum of 16 Selected ports.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 256.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
For a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
For a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 256.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
link-aggregation selected-port minimum percentage
Use link-aggregation selected-port minimum percentage to set the minimum percentage of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum percentage to restore the default.
link-aggregation selected-port minimum percentage number
The minimum percentage of Selected ports is not set for an aggregation group.
number: Specifies the minimum percentage of Selected ports. The value range for this argument is 1 to 100.
CAUTION
CAUTION:
After you execute this command, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
·     The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
·     The limit set by using the link-aggregation selected-port minimum command.
The system calculates the minimum percentage of Selected ports based on the total number of member ports in an aggregation group, including the member ports on an absent card. To view the total number of member ports in an aggregation group, execute the display link-aggregation verbose all-configuration command.
For the device to calculate the minimum number of Selected ports correctly, save the running configuration and reboot the device after you execute the link-aggregation selected-port minimum percentage command.
# Set the minimum percentage of Selected ports to 50% for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum percentage 50
# Set the minimum percentage of Selected ports to 50% for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 10.
You can configure this feature to suppress link-down events, link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for an event type, the most recent configuration takes effect on that event type.
When you configure suppression interval settings on an aggregate interface, make sure its peer interface is also an aggregate interface in the same aggregation mode. In addition, the suppression interval settings must be the same between the peer aggregate interfaces.
As a best practice, use the default setting in an S-MLAG environment.
# Set the link-down event suppression interval to 500 milliseconds on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-delay down msec 500
# Set the link-down event suppression interval to 500 milliseconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down msec 500
mac-address
Use mac-address to set the MAC address for an aggregate interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is manually assigned to an aggregate interface.
mac-address: Specifies the MAC address in the format of H-H-H.
By default, all aggregate interfaces on a device use the same MAC address and aggregate interfaces on different devices use different MAC addresses.
Make sure the MAC address you assign to an aggregate interface meets the following requirements:
·     The MAC address must have the same value as the base MAC address in the 36 most significant bits.
·     The MAC address must not be lower than the base MAC address plus 90 (decimal).
For more information about the base MAC address, see Layer 2—LAN Switching Configuration Guide.
# Set the MAC address to 0001-0001-0001 for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mac-address 1-1-1
mtu
Use mtu to set the MTU for a Layer 3 aggregate interface or subinterface.
mtu size [ spread ]
undo mtu [ spread ]
The MTU for Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies the MTU in bytes, in the range of 46 to 9008.
spread: Issues the MTU of the interface to all its subinterfaces. This keyword is available only in Layer 3 aggregate interface view.
When you set the MTU of a Layer 3 aggregate interface, you can specify the spread keyword to issue the MTU setting to all its subinterfaces. If you do not specify the spread keyword, the MTU setting takes effect only on the Layer 3 aggregate interface.
On an aggregate subinterface, the MTU set in subinterface view takes precedence over the MTU inherited from the aggregate interface.
# Set the MTU to 1430 bytes for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to an aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number in the range of 1 to 4096.
A Layer 2 Ethernet interface can be assigned only to a Layer 2 aggregation group. A Layer 3 Ethernet interface can be assigned only to a Layer 3 aggregation group.
# Assign Layer 2 Ethernet interface HundredGigE 1/0/1 to Layer 2 aggregation group 1.
[Sysname-HundredGigE1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface HundredGigE 1/0/2 to Layer 3 aggregation group 2.
[Sysname-HundredGigE1/0/2] port link-aggregation group 2
port s-mlag group
Use port s-mlag group to assign an aggregate interface to an S-MLAG group.
Use undo port s-mlag group to restore the default.
port s-mlag group group-id
An aggregate interface is not in any S-MLAG group.
group-id: Specifies an S-MLAG group number in the range of 1 to 1024.
You can assign only Layer 2 aggregate interfaces in dynamic mode to an S-MLAG group.
Each S-MLAG group can contain only one aggregate interface on each device.
# Assign Bridge-Aggregation 1 to S-MLAG group 1.
[Sysname-Bridge-Aggregation1] port s-mlag group 1
reset counters interface
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics for all interfaces.
If you specify only an aggregate interface type, the command clears statistics for all aggregate interfaces of the specified type.
# Clear statistics for Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
# Clear statistics for Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> reset counters interface route-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-type interface-number1 argument must be equal to or greater than the value for the interface-type interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface.
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
# Bring up Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] undo shutdown
