11-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS6861 SeriesConfigure & DeployConfiguration GuidesH3C S6861 Switch Series Configuration Guide-Release 26xx-6W10211-Network Management and Monitoring Configuration Guide
12-sFlow configuration
12-sFlow configuration 94.65 KB
Configuring sFlow
sFlow is a traffic monitoring technology.
As shown in Figure 1, the sFlow system involves an sFlow agent embedded in a device and a remote sFlow collector. The sFlow agent collects interface counter information and packet information and encapsulates the sampled information in sFlow packets. When the sFlow packet buffer is full, or the aging timer (fixed to 1 second) expires, the sFlow agent performs the following actions:
·     Encapsulates the sFlow packets in the UDP datagrams.
·     Sends the UDP datagrams to the specified sFlow collector.
The sFlow collector analyzes the information and displays the results. One sFlow collector can monitor multiple sFlow agents.
sFlow provides the following sampling mechanisms:
·     Flow sampling—Obtains packet information.
·     Counter sampling—Obtains interface counter information.
Figure 1 sFlow system
Protocols and standards
·     RFC 3176, InMon Corporation's sFlow: A Method for Monitoring Traffic in Switched and Routed Networks
·     sFlow.org, sFlow Version 5
sFlow configuration task list
Tasks at a glance
(Required.) Configuring the sFlow agent and sFlow collector information
Perform one or both of the following tasks:
·     Configuring flow sampling
·     Configuring counter sampling
Step
Remarks
N/A
2.     (Optional.) Configure an IP address for the sFlow agent.
sflow agent { ip ipv4-address | ipv6 ipv6-address }
By default, no IP address is configured for the sFlow agent. The device periodically checks whether the sFlow agent has an IP address. If the sFlow agent does not have an IP address, the device automatically selects an IPv4 address for the sFlow agent but does not save the IPv4 address in the configuration file.
·     As a best practice, manually configure an IP address for the sFlow agent.
·     Only one IP address can be configured for the sFlow agent on the device, and a newly configured IP address overwrites the existing one.
3.     Configure the sFlow collector information.
sflow collector collector-id [ vpn-instance vpn-instance-name ] { ip ipv4-address | ipv6 ipv6-address } [ port port-number | datagram-size size | time-out seconds | description string ] *
By default, no sFlow collector information is configured.
4.     (Optional.) Specify the source IP address of sFlow packets.
sflow source { ip ipv4-address | ipv6 ipv6-address } *
By default, the source IP address is determined by routing.
Perform this task to configure flow sampling on an Ethernet interface. The sFlow agent performs the following tasks:
1.     Samples packets on that interface according to the configured parameters.
2.     Encapsulates the packets into sFlow packets.
3.     Encapsulates the sFlow packets in the UDP packets and sends the UDP packets to the specified sFlow collector.
To configure flow sampling:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface view or Layer 3 Ethernet interface view.
N/A
3.     (Optional.) Set the flow sampling mode.
sflow sampling-mode random
N/A
4.     Enable flow sampling and specify the number of packets out of which flow sampling samples a packet on the interface.
sflow sampling-rate rate
By default, flow sampling is disabled.
As a best practice, set the sampling interval to 2n that is greater than or equal to 8192, for example, 32768.
5.     (Optional.) Set the maximum number of bytes (starting from the packet header) that flow sampling can copy per packet.
sflow flow max-header length
The default setting is 128 bytes.
As a best practice, use the default setting.
6.     Specify the sFlow collector for flow sampling.
sflow flow collector collector-id
By default, no sFlow collector is specified for flow sampling.
Perform this task to configure counter sampling on an Ethernet interface. The sFlow agent performs the following tasks:
1.     Periodically collects the counter information on that interface.
2.     Encapsulates the counter information into sFlow packets.
To configure counter sampling:
Step
Remarks
N/A
N/A
3.     Enable counter sampling and set the counter sampling interval.
sflow counter interval interval
By default, counter sampling is disabled.
4.     Specify the sFlow collector for counter sampling.
sflow counter collector collector-id
By default, no sFlow collector is specified for counter sampling.
Displaying and maintaining sFlow
Display sFlow configuration.
display sflow
sFlow configuration example
Network requirements
As shown in Figure 2, perform the following tasks:
·     Configure flow sampling in random mode and counter sampling on Ten-GigabitEthernet 1/0/1 of the device to monitor traffic on the port.
·     Configure the device to send sampled information in sFlow packets through Ten-GigabitEthernet 1/0/3 to the sFlow collector.
Figure 2 Network diagram
Configuration procedure
1.     Configure the IP addresses and subnet masks for interfaces, as shown in Figure 2. (Details not shown.)
2.     Configure the sFlow agent and configure information about the sFlow collector:
# Configure the IP address for the sFlow agent.
[Device] sflow agent ip 3.3.3.1
# Configure information about the sFlow collector. Specify the sFlow collector ID as 1, IP address as 3.3.3.2, port number as 6343 (default), and description as netserver.
[Device] sflow collector 1 ip 3.3.3.2 description netserver
3.     Configure counter sampling:
# Enable counter sampling and set the counter sampling interval to 120 seconds on Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling.
[Device-Ten-GigabitEthernet1/0/1] sflow counter collector 1
4.     Configure flow sampling:
# Enable flow sampling and set the flow sampling mode to random and sampling interval to 32768.
[Device-Ten-GigabitEthernet1/0/1] sflow sampling-mode random
[Device-Ten-GigabitEthernet1/0/1] sflow sampling-rate 32768
# Specify sFlow collector 1 for flow sampling.
[Device-Ten-GigabitEthernet1/0/1] sflow flow collector 1
Verifying the configurations
# Verify the following items:
·     Ten-GigabitEthernet 1/0/1 enabled with sFlow is active.
·     The counter sampling interval is 120 seconds.
·     The flow sampling interval is 32768 (one packet is sampled from every 32768 packets).
[Device-Ten-GigabitEthernet1/0/1] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 3.3.3.1(CLI)
Source address:
Collector information:
ID    IP              Port  Aging      Size VPN-instance Description
1     3.3.3.2         6343  N/A        1400              netserver
Port information:
Interface      CID   Interval(s) FID   MaxHLen Rate     Mode      Status
XGE1/0/1       1     120         1     128     32768    Random    Active
Troubleshooting sFlow configuration
The remote sFlow collector cannot receive sFlow packets
Symptom
The remote sFlow collector cannot receive sFlow packets.
Analysis
The possible reasons include:
·     The sFlow collector is not specified.
·     sFlow is not configured on the interface.
·     The IP address of the sFlow collector specified on the sFlow agent is different from that of the remote sFlow collector.
·     No IP address is configured for the Layer 3 interface that sends sFlow packets.
·     An IP address is configured for the Layer 3 interface that sends sFlow packets. However, the UDP datagrams with this source IP address cannot reach the sFlow collector.
·     The physical link between the device and the sFlow collector fails.
·     The sFlow collector is bound to a non-existent VPN.
·     The length of an sFlow packet is less than the sum of the following two values:
¡     The length of the sFlow packet header.
¡     The number of bytes that flow sampling can copy per packet.
Solution
To resolve the problem:
1.     Use the display sflow command to verify that sFlow is correctly configured.
2.     Verify that a correct IP address is configured for the device to communicate with the sFlow collector.
3.     Verify that the physical link between the device and the sFlow collector is up.
4.     Verify that the VPN bound to the sFlow collector already exists.
5.     Verify that the length of an sFlow packet is greater than the sum of the following two values:
¡     The number of bytes (as a best practice, use the default setting) that flow sampling can copy per packet.
