03-Layer 2-LAN Switching Configuration Guide
HomeSupportSwitchesS6861 SeriesConfigure & DeployConfiguration GuidesH3C S6861 Switch Series Configuration Guide-Release 26xx-6W10203-Layer 2-LAN Switching Configuration Guide
15-Cut-through forwarding configuration
15-Cut-through forwarding configuration 32.19 KB
Configuring cut-through forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
To configure cut-through forwarding:
Step
Remarks
N/A
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of dropped.
