HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10301-Fundamentals Configuration Guide
03-Login management configuration
03-Login management configuration 286.32 KB
Login overview
The first time you access the device, you can only log in to the CLI through the console port. After login, you can change console login parameters or configure other access methods, including Telnet, SSH, SNMP, and RESTful.
Telnet and HTTP-based RESTful access are not supported in FIPS mode.
Table 1 Login methods at a glance
Login method
Default settings and minimum configuration requirements
Login configuration
CLI login:
Configuring CLI login
·           Local console login
By default, local console login is enabled and does not require authentication. The default user role is network-admin. To improve device security, configure password or scheme authentication for the AUX line immediately after you log in to the device for the first time.
Configuring local console login
·           Telnet login
By default, Telnet login is disabled.
To enable Telnet login, perform the following tasks:
·           Enable the Telnet server feature.
·           Assign an IP address to a Layer 3 interface and make sure the interface and the Telnet client can reach each other.
·           Configure an authentication mode for VTY login users. By default, password authentication is used but no password is configured.
·           Assign a user role to VTY login users. By default, a VTY login user is assigned the network-operator user role.
Configuring Telnet login
·           SSH login
By default, SSH login is disabled.
To enable SSH login, perform the following tasks:
·           Enable the SSH server feature and configure SSH attributes.
·           Assign an IP address to a Layer 3 interface. Make sure the interface and the SSH client can reach each other.
·           Configure scheme authentication for VTY login users. By default, password authentication is used.
Configuring SSH login
SNMP access
By default, SNMP access is disabled.
To enable SNMP access, perform the following tasks:
·           Assign an IP address to a Layer 3 interface. Make sure the interface and the NMS can reach each other.
·           Configure SNMP basic parameters.
Accessing the device through SNMP
RESTful access
By default, RESTful access is disabled.
To enable RESTful access, perform the following tasks:
·           Assign an IP address to a Layer 3 interface. Make sure the interface and the RESTful access user's host can reach each other.
·           Enable RESTful access over HTTP or RESTful access over HTTPS.
·           Configure a local user account for RESTful access and assign a user role to the account. By default, the network-operator user role is assigned to the account.
·           Assign HTTP or HTTPS service to the user. By default, no service type is assigned to a local user.
Configuring RESTful access over HTTP
Using the console port for the first device access
To log in through the console port, prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
To log in through the console port:
1.      Connect the DB-9 female connector of the console cable to the serial port of the PC.
2.      Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a terminal to the console port
3.      If the PC is off, turn on the PC.
4.      On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
¡  Bits per second—9600 bps.
¡  Flow control—None.
¡  Parity—None.
¡  Stop bits—1.
¡  Data bits—8.
5.      Power on the device and press Enter as prompted.
The default user view prompt <H3C> appears. You can enter commands to configure or manage the device. To get help, enter ?.
By default, you can log in to the CLI through the console port. After you log in, you can configure other CLI login methods, including Telnet and SSH.
To prevent illegal access to the CLI and control user behavior, perform the following tasks as required:
·           Configure login authentication.
·           Assign user roles.
·           Configure command authorization and command accounting.
·           Use ACLs to filter unauthorized logins.
This chapter describes how to configure and use CLI login methods, including login authentication, user roles, and common user line settings. For more information about command authorization, command accounting, and unauthorized access filtering, see "Controlling user access to the device."
CLI overview
User lines
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
The device supports the user lines listed in Table 2. Different user lines require different login methods.
Table 2 CLI login method and user line matrix
User line
Login method
AUX line
Console port.
Virtual type terminal (VTY) line
Telnet or SSH.
User line numbering
Every user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence of console, TTY, AUX, and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. TTY lines are numbered starting from 1 and incrementing by 1. All other types of user lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods, as shown in Table 2. When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, four VTY lines (0 to 3) are configured, of which VTY 0 and VTY 3 are idle. When a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
Login authentication modes
You can configure login authentication to prevent illegal access to the device CLI.
In non-FIPS mode, the device supports the following login authentication modes:
·           None—Disables authentication. This mode allows access without authentication and is insecure.
·           Password—Requires password authentication. A user must provide the correct password at login.
·           Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
In FIPS mode, the device supports only the scheme authentication mode.
Different login authentication modes require different user line configurations, as shown in Table 3.
Table 3 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.      Set the authentication mode to password.
2.      Set a password.
Scheme
3.      Set the authentication mode to scheme.
4.      Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·           In none or password authentication mode, the device assigns the user roles specified for the user line.
·           In scheme authentication mode, the device uses the following rules to assign user roles:
¡  For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
¡  For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
FIPS compliance
Telnet login is not supported in FIPS mode.
You can connect a terminal to the console port of the device to log in and manage the device, as shown in Figure 2. For the login procedure, see "Using the console port for the first device access."
Figure 2 Logging in through the console port
By default, console login is enabled both locally and remotely and it does not require authentication. The default user role is network-admin. To improve device security, configure password or scheme authentication for the AUX line immediately after you log in to the device for the first time.
To configure console login, perform the following tasks:
Tasks at a glance
Remarks
(Required.) Perform one of the following tasks:
·           Disabling authentication for console login
·           Configuring password authentication for console login
·           Configuring scheme authentication for console login
In FIPS mode, only the scheme authentication mode is supported.
(Optional.) Configuring common AUX line settings
N/A
Console login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
1.      Enter system view.
N/A
2.      Enter AUX line view or class view.
·           Enter AUX line view:
line aux first-number [ last-number ]
·           Enter AUX line class view:
line class aux
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
A setting in user line class view does not take effect for current online users. It takes effect only for new login users.
3.      Disable authentication.
authentication-mode none
In non-FIPS mode, authentication is disabled for the AUX line by default.
In FIPS mode, scheme authentication is enabled for the AUX line by default.
CAUTION CAUTION:
When authentication is disabled, users can log in to the device through the line or line class without authentication. For security purpose, disable authentication with caution.
4.      Assign a user role.
user-role role-name
By default, an AUX line user is assigned the network-admin user role.
After you finish this configuration task, a user can log in through the console port without authentication.
Step
Remarks
N/A
line class aux
3.      Enable password authentication.
authentication-mode password
In FIPS mode, scheme authentication is enabled by default.
CAUTION CAUTION:
When you enable password authentication, you must also configure an authentication password for the line or line class. If no authentication password is configured, you cannot log in to the device through the line or line class at the next time.
4.      Set a password.
set authentication password { hash | simple } password
By default, no password is set.
5.      Assign a user role.
user-role role-name
After you finish this configuration task, a user must provide the configured password when logging in through the console port.
Step
Remarks
N/A
line class aux
3.      Enable scheme authentication.
authentication-mode scheme
CAUTION CAUTION:
When you enable scheme authentication, make sure an authentication user account is available. If no authentication user account is available, you cannot log in to the device through the line or line class at the next time.
To use scheme authentication, you must also perform the following tasks:
·           Configure login authentication methods in ISP domain view.
·           For remote authentication, configure a RADIUS, HWTACACS, or LDAP scheme.
·           For local authentication, create a local user account and configure the relevant attributes.
After you finish this configuration task, a user must provide the configured username and password when logging in through the console port.
Some common settings for an AUX line take effect immediately and can interrupt the current session. Use a login method different from console login to log in to the device before you change AUX line settings.
After you change AUX line settings, adjust the settings on the configuration terminal accordingly for a successful login.
To configure common settings for an AUX line:
Step
Remarks
N/A
line class aux
3.      Set the transmission rate.
speed speed-value
By default, the transmission rate is 9600 bps.
This command is not available in AUX line class view.
4.      Specify the parity.
By default, a user line does not use parity.
5.      Specify the number of stop bits for a character.
stopbits { 1 | 1.5 | 2 }
The default is 1.
Stop bits indicate the end of a character. The more the stop bits, the slower the transmission.
6.      Specify the number of data bits for a character.
databits { 7 | 8 }
The default is 8.
Configure this command depending on the character coding type. For example, set the number of data bits to 7 for standard ASCII characters. Set the number of data bits to 8 for extended ASCII characters.
7.      Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
8.      Specify the escape key.
escape-key { character | default }
By default, pressing Ctrl+C terminates a command.
9.      Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
10.   Configure the flow control mode.
flow-control { none | software }
By default, the flow control mode is none.
11.   Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports ANSI and VT100 terminal display types. As a best practice, specify VT100 type on both the device and the configuration terminal. If either side uses the ANSI type, a display problem might occur when a command line has more than 80 characters. For example, a cursor positioning error might occur.
12.   Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends up to 24 lines to the terminal at a time when pausing between screens of output is enabled.
To disable pausing between screens of output, set the value to 0.
13.   Set the size for the command history buffer.
history-command max-size value
By default, the buffer saves up to 10 history commands.
14.   Set the CLI connection idle-timeout timer.
By default, the CLI connection idle-timeout timer is 10 minutes.
If no interaction occurs between the device and the user within the idle-timeout interval, the system automatically terminates the user connection on the user line.
If you set the timeout timer to 0, the connection will not be aged out.
15.   Specify the command to be automatically executed for login users on the lines.
auto-execute command command
By default, no command is specified for auto execution.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not available in AUX line view or AUX line class view.
CAUTION CAUTION:
Use this command with caution. If this command is used on a user line, users that log in to the device through this user line might fail to configure the system.
16.   Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The undo shell command is not available in AUX line view.
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
By default, Telnet login is disabled on the device. To configure Telnet login, you must first log in to the device through any other method.
Configuring the device as a Telnet server
Tasks at a glance
(Required.) Enabling Telnet server
·           Disabling authentication for Telnet login
·           Configuring password authentication for Telnet login
·           Configuring scheme authentication for Telnet login
(Optional.) Setting the maximum number of concurrent Telnet users
(Optional.) Setting the DSCP value for outgoing Telnet packets
(Optional.) Configuring common VTY line settings
Telnet login configuration changes do not take effect for current online users. They take effect only for new login users.
Step
Remarks
N/A
2.      Enable the Telnet server.
telnet server enable
By default, the Telnet server is disabled.
Step
Remarks
N/A
2.      Enter VTY line view or class view.
·           Enter VTY line view:
line vty first-number [ last-number ]
·           Enter VTY line class view:
line class vty
In non-FIPS mode, password authentication is enabled for VTY lines by default.
In VTY line view, this command is associated with the protocol inbound command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
CAUTION CAUTION:
4.      (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user is assigned the network-operator user role.
After you finish this configuration task, a user can Telnet to the device without authentication, as shown in the following example:
* no decompiling or reverse-engineering shall be allowed.                    *
<H3C>
If the maximum number of login users has been reached, the login attempt fails and the message "All user lines are used, please try later!" appears.
Step
Remarks
N/A
line class vty
CAUTION CAUTION:
4.      Set a password.
5.      (Optional.) Assign a user role.
user-role role-name
After you finish this configuration task, a user must provide the configured password when Telnetting to the device, as shown in the following example:
Password:
<H3C>
Step
Remarks
N/A
line class vty
CAUTION CAUTION:
After you finish this configuration task, a user must provide the configured username and password when Telnetting to the device, as shown in the following example:
login: admin
Password:
<H3C>
If the maximum number of login users has been reached, the login attempt fails and the message "All lines are used, please try later!" appears.
Step
Remarks
N/A
2.      Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
The default is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
The DSCP value is carried in the ToS or Traffic class field of an IP or IPv6 packet to indicate the transmission priority of the packet.
To set the DSCP value for outgoing Telnet packets:
Step
Remarks
N/A
2.      Set the DSCP value for outgoing Telnet packets.
·           For a Telnet server running IPv4:
telnet server dscp dscp-value
·           For a Telnet server running IPv6:
By default, the DSCP value is 48.
Specifying the Telnet service port number
Step
Remarks
N/A
2.      Specify the Telnet service port number.
By default, the Telnet service port number is 23.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command, the system automatically disconnects the Telnet session. Typically, you configure the auto-execute command telnet X.X.X.X command on the device so the device redirects a Telnet user to the host at X.X.X.X. The connection to the current device is closed when the user terminates the Telnet connection to X.X.X.X.
To configure common settings for VTY lines:
Step
Remarks
N/A
line class vty
3.      Enable the terminal service.
shell
By default, the terminal service is enabled on all user lines.
4.      Specify the supported protocols.
By default, both Telnet and SSH are supported.
A protocol change does not take effect for current online users. It takes effect only for new login users.
In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
5.      Specify the shortcut key for terminating a task.
The default setting is Ctrl+C.
6.      Set the user line locking key.
lock-key key-string
7.      Specify the terminal display type.
The default terminal display type is ANSI.
8.      Set the maximum number of lines of command output to send to the terminal at a time.
9.      Set the size for the command history buffer.
The default size is 10 history commands.
10.   Set the CLI connection idle-timeout timer.
11.   Specify the command to be automatically executed for login users on the user lines.
IMPORTANT IMPORTANT:
Before you configure this command and save the configuration, make sure you can access the CLI to modify the configuration through other VTY user lines or AUX user lines.
Using the device to log in to a Telnet server
You can use the device as a Telnet client to log in to a Telnet server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 3 Telnetting from the device to a Telnet server
To use the device to log in to a Telnet server:
Step
Remarks
N/A
2.      (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.      Exit to user view.
N/A
4.      Use the device to log in to a Telnet server.
·           Log in to an IPv4 Telnet server:
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } | dscp dscp-value ] *
·           Log in to an IPv6 Telnet server:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } | dscp dscp-value ] *
N/A
Enabling logging for denied Telnet login attempts
Only clients permitted by the Telnet login control ACL can Telnet to the device. This logging feature generates log messages for Telnet login attempts that are denied by the Telnet login control ACL, and sends the messages to the information center.
For information about log message output, see the information center in Network Management and Monitoring Configuration Guide.
To enable logging for denied Telnet login attempts:
Step
Remarks
N/A
2.      Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
telnet server acl-deny-log enable
By default, logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
SSH offers a secure method to remote login. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
By default, SSH login is disabled on the device. To configure SSH login, you must first log in to the device through any other method.
Configuring the device as an SSH server
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
To configure the device as an SSH server:
Step
Remarks
N/A
2.      Create local key pairs.
·           In non-FIPS mode:
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 ] | rsa } [ name key-name ]
·           In FIPS mode:
public-key local create { dsa | ecdsa [ secp256r1 | secp384r1 ] | rsa } [ name key-name ]
By default, no local key pairs are created.
3.      Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
4.      (Optional.) Create an SSH user and specify the authentication mode.
·           In non-FIPS mode:
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign { pki-domain domain-name | publickey keyname } }
·           In FIPS mode:
ssh user username service-type stelnet authentication-type { password | password-publickey assign { pki-domain domain-name | publickey keyname } }
By default, no SSH user is configured on the device.
5.      Enter VTY line view or class view.
line class vty
6.      Enable scheme authentication.
In FIPS mode, scheme authentication is enabled for VTY lines by default.
7.      (Optional.) Specify the protocols for the user lines to support.
·           In non-FIPS mode:
·           In FIPS mode:
protocol inbound ssh
In non-FIPS mode, both Telnet and SSH are supported by default.
In FIPS mode, SSH is supported by default.
8.      Exit to system view.
N/A
9.      (Optional.) Configure common settings for VTY lines.
See "Configuring common VTY line settings."
N/A
10.   (Optional.) Set the maximum number of concurrent SSH users.
The default is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
Using the device to log in to an SSH server
You can use the device as an SSH client to log in to an SSH server. If the server is located in a different subnet than the client, make sure the two devices can reach each other.
Figure 4 Logging in to an SSH server from the device
Perform the following tasks in user view:
Log in to an IPv4 SSH server.
ssh2 server
Log in to an IPv6 SSH server.
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Displaying and maintaining CLI login
Remarks
Display online CLI users.
display users [ all ]
N/A
Display user line information.
display line [ num1 | { aux | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Release a user line.
free line { num1 | { aux | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { aux | vty } num2 }
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to manage and monitor the device.
Figure 5 SNMP access diagram
The device supports SNMPv1, SNMPv2c, and SNMPv3, and can cooperate with various network management software products. However, the device and the NMS must use the same SNMP version.
By default, SNMP access is disabled. To configure SNMP access, you must first log in to the device through any other method.
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
·           Send RESTful requests to the device to pass authentication.
·           Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
RESTful access is disabled by default. To configure RESTful access, you must first log in through the console port.
FIPS compliance
RESTful access over HTTP is not supported in FIPS mode.
Step
Remarks
N/A
2.      Enable RESTful access over HTTP.
restful http enable
By default, RESTful access over HTTP is disabled.
3.      Create a local user and enter local user view.
By default, no local user is configured.
4.      Configure a password for the local user.
The password is saved in hashed form.
By default, no password is configured for a local user.
5.      (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful access user.
6.      (Optional.) Use an ACL to control TCP connections from RESTful clients.
By default, all RESTful clients can establish TCP connections to the device.
This command is available in Release 2612P06 and later.
7.      Specify the HTTP service for the local user.
service-type http
By default, no service type is specified for a local user.
Configuring RESTful access over HTTPS
Step
Remarks
N/A
2.      Enable RESTful access over HTTPS.
restful https enable
By default, RESTful access over HTTPS is disabled.
·           In non-FIPS mode:
·           In FIPS mode:
password
7.      Specify the HTTPS service for the local user.
service-type https
Use ACLs to prevent unauthorized access, and configure command authorization and accounting to monitor and control user behavior. For more information about ACLs, see ACL and QoS Configuration Guide.
FIPS compliance
Telnet and HTTP are not supported in FIPS mode.
Controlling Telnet and SSH logins
Use different types of ACLs to filter Telnet and SSH logins by different match criteria:
·           Basic ACL (2000 to 2999)—Source IP address.
·           Advanced ACL (3000 to 3999)—Source IP address and destination IP address.
·           Ethernet frame header ACL (4000 to 4999)—Source MAC address.
If an applied ACL does not exist or does not have any rules, no user login restriction is applied. If the ACL exists and has rules, only users permitted by the ACL can access the device through Telnet or SSH.
Configuration procedures
To control Telnet logins:
Step
Remarks
N/A
2.      Apply an ACL to filter Telnet logins.
·           telnet server acl [ mac ] acl-number
·           telnet server ipv6 acl [ ipv6 | mac ] acl-number
By default, no ACL is used to filter Telnet logins.
To control SSH logins:
Step
Remarks
N/A
2.      Apply an ACL to filter SSH logins.
·           ssh server acl [ mac ] acl-number
·           ssh server ipv6 acl [ ipv6 | mac ] acl-number
By default, no ACL is used to filter SSH logins.
For more information about these two commands, see Security Command Reference.
Configuration example
Network requirements
As shown in Figure 6, the device is a Telnet server.
Configure the device to permit only Telnet packets sourced from Host A and Host B.
Figure 6 Network diagram
# Configure an ACL to permit packets sourced from Host A and Host B.
[Sysname] acl basic 2000 match-order config
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
Controlling SNMP access
Use a basic ACL (2000 to 2999) to control SNMP access by source IP address. To access the requested MIB view, an NMS must use a source IP address permitted by the ACL. If the ACL does not exist or does not have any rules, no user login restriction is applied.
To control SNMPv1 or SNMPv2c access:
Step
Remarks
N/A
2.      Configure the SNMP access right.
·           (Method 1.) Create an SNMP community and specify ACLs for the community:
¡  In VACM mode:
snmp-agent community { read | write } [ simple | cipher ] community-name [ mib-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
¡  In RBAC mode:
snmp-agent community [ simple | cipher ] community-name user-role role-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·           (Method 2.) Create an SNMPv1/v2c group and add a user to the group, specifying ACLs for the group and user:
a.   snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
b.   snmp-agent usm-user { v1 | v2c } user-name group-name [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
To control SNMPv3 access:
Step
Remarks
N/A
2.      Create an SNMPv3 group, specifying ACLs for the group.
In non-FIPS mode:
snmp-agent
group v3 group-name [ authentication | privacy ] [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
In FIPS mode:
snmp-agent
group v3 group-name { authentication | privacy } [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
N/A
3.      Create an SNMPv3 user, specifying ACLs for the user.
In non-FIPS mode:
·           In VACM mode:
snmp-agent
usm-user v3 user-name group-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·           In RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
In FIPS mode:
·           In VACM mode:
snmp-agent
usm-user v3 user-name group-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
·           In RBAC mode:
snmp-agent usm-user v3 user-name user-role role-name [ remote { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl { ipv4-acl-number | name ipv4-acl-name } | acl ipv6 { ipv6-acl-number | name ipv6-acl-name } ] *
As shown in Figure 7, the device is running SNMP.
Configure the device to allow Host A and Host B to access the device through SNMP.
Figure 7 Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
# Associate the ACL with the SNMP community and the SNMP group.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
Configuring command authorization
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands.
After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
The command authorization method can be different from the user login authorization method.
This section provides the procedure for configuring command authorization. To make the command authorization feature take effect, you must configure a command authorization method in ISP domain view. For more information, see Security Configuration Guide.
To configure command authorization:
Step
Remarks
N/A
2.      Enter user line view or user line class view.
·           Enter user line view:
line { first-number1 [ last-number1 ] | { aux | vty } first-number2 [ last-number2 ] }
·           Enter user line class view:
line class { aux | vty }
In non-FIPS mode, authentication is disabled for AUX lines, and password authentication is enabled for VTY lines by default.
CAUTION CAUTION:
4.      Enable command authorization.
By default, command authorization is disabled, and the commands available for a user only depend on the user role.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
As shown in Figure 8, Host A needs to log in to the device to manage the device.
Configure the device to perform the following operations:
·           Allow Host A to Telnet in after authentication.
·           Use the HWTACACS server to control the commands that the user can execute.
·           If the HWTACACS server is not available, use local authorization.
Figure 8 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other. Make sure the device and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
[Device] telnet server enable
# Enable scheme authentication for user lines VTY 0 through VTY 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
# Enable command authorization for the user lines.
[Device-line-vty0-63] command authorization
[Device-line-vty0-63] quit
# Create HWTACACS scheme tac.
[Device] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[Device-hwtacacs-tac] primary authentication 192.168.2.20 49
[Device-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[Device-hwtacacs-tac] key authentication simple expert
[Device-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Device-hwtacacs-tac] user-name-format without-domain
[Device-hwtacacs-tac] quit
# Configure the system-defined domain (system).
[Device] domain system
# Use HWTACACS scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[Device-isp-system] authentication login hwtacacs-scheme tac local
[Device-isp-system] authorization command hwtacacs-scheme tac local
[Device-isp-system] quit
# Create local user monitor. Set the simple password to 123, the service type to Telnet, and the default user role to level-1.
[Device] local-user monitor
[Device-luser-manage-monitor] password simple 123
[Device-luser-manage-monitor] service-type telnet
[Device-luser-manage-monitor] authorization-attribute user-role level-1
Configuring command accounting
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
This section provides only the procedure for configuring command accounting. To make the command accounting feature take effect, you must configure a command accounting method in ISP domain view. For more information, see Security Configuration Guide.
To configure command accounting:
Step
Remarks
N/A
CAUTION CAUTION:
4.      Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
As shown in Figure 9, users need to log in to the device to manage the device.
Configure the device to send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 9 Network diagram
# Enable command accounting for user line AUX 0.
[Device] line aux 0
[Device-line-aux0] command accounting
[Device-line-aux0] quit
# Enable command accounting for user lines VTY 0 through VTY 63.
[Device-line-vty0-63] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[Device-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[Device-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain (system) to use the HWTACACS scheme for command accounting.
[Device-isp-system] accounting command hwtacacs-scheme tac
