- 11-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-CWMP configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance configuration
- 11-Mirroring configuration
- 12-sFlow configuration
- 13-Information center configuration
- 14-VCF fabric configuration
- 15-Cloud connection configuration
- 16-SmartMC configuration
- 17-WiNet configuration
- 18-EPA configuration
| 18-EPA configuration | 130.27 KB |
Restrictions: Software version compatibility with EPA
Restrictions and guidelines: EPA configuration
Display and maintenance commands for EPA
Configuring EPA
About EPA
Endpoint Analysis (EPA) allows you to monitor associations and disassociations of endpoints (for example, cameras and IP phones) connecting to an H3C device.
Application scenarios
Non-SmartMC (or Non-WiNet) networking
As shown in Figure 1, the device configured with EPA monitors associations and disassociations of endpoints connecting to it. The device can be a standalone device or an IRF fabric. For an IRF fabric, EPA monitors endpoints connecting to all members. The collected association and disassociation information will be reported to the master device for processing.
Figure 1 Non-SmartMC (or Non-WiNet) networking
SmartMC (or WiNet) networking
In a SmartMC (or WiNet) network as shown in Figure 2, EPA settings are configured only on the commander. The members report association and disassociation information about their associated endpoints to the commander. The commander records such information about all associated endpoints in the network, and deploys EPA settings to the members.
You can view EPA information in the entire network on the commander.
Figure 2 SmartMC (or WiNet) networking
Working mechanism
EPA monitors endpoint associations and disassociations by monitoring the generation and aging of MAC address entries learned by devices. A device configured with EPA can monitor only endpoints in the same subnet as the endpoint access port on the device.
For more information about MAC address entries, see Layer 2—LAN Switching Configuration Guide.
Collecting endpoint association information
If a device configured with EPA learns a new MAC address entry, it compares the MAC address and VLAN ID with the configured EPA monitor rules.
· If a match is found, the device determines that a monitored endpoint came online.
¡ In a non-SmartMC (or WiNet) network, the device records the endpoint association event locally.
¡ In a SmartMC (or WiNet) network, if the device is the commander, it records the endpoint association event locally. If the device is a member, it reports the event to the commander.
· If no match is found, the device determines that the endpoint is not a monitored endpoint and does not record the endpoint association event.
Collecting endpoint disassociation information
When the MAC address entry of an endpoint ages out, the device determines that the endpoint went offline.
· In a non-SmartMC (or WiNet) network, the device records the endpoint disassociation event locally for 7 days.
· In a SmartMC (or WiNet) network, the commander records the endpoint disassociation event for 7 days.
Synchronizing information in a SmartMC (or WiNet) network
In a SmartMC (or WiNet) network, endpoint monitor rules are configured on the commander and deployed to all members by the commander. The rules take effect on both the commander and members. If a member detects an association or disassociation event of a monitored endpoint, it reports the event to the commander for statistics collection and analysis.
You can view endpoint associations and disassociations that occurred in the entire network from the commander. For more information about SmartMC (or WiNet), see "Configuring SmartMC (or WiNet)."
This feature is supported only in Release 6328 or later.
Do not use the mac-address dynamic command to configure dynamic MAC address entries for monitored endpoints. If you do so, the system might fail to identify endpoint association events.
When you configure endpoint monitor rules, follow these restrictions and guidelines:
· To configure multiple rules to monitor an endpoint in different VLANs, make sure the specified VLAN ranges in these rules do not overlap with each other.
· As a best practice to ensure the optimal EPA performance, specify the VLANs in which an endpoint will be monitored.
· If you configure a rule to monitor an endpoint in all VLANs, make sure the endpoint will not come online from over 10 VLANs.
· You can configure a maximum of 1024 monitor rules. As a best practice to ensure the optimal EPA performance, do not configure over 512 monitor rules.
· You can specify a rule ID when creating a monitor rule. If you do not specify the ID, the system assigns the smallest available ID to the rule.
· You cannot execute the epa monitor-rule command multiple times to edit an existing rule. To edit an existing rule, use the undo epa monitor-rule command to delete the rule and then create the rule again.
When you configure EPA in a SmartMC (or WiNet) network, follow these restrictions and guidelines:
· Make sure all devices in the network support EPA.
· You can configure endpoint monitor rules only on the commander.
· Configure the same aging time for MAC address entries on all devices in the SmartMC (or WiNet) network. Otherwise, endpoint association and disassociation analysis on the commander might be inaccurate. For more information about MAC address entries, see Layer 2—LAN Switching Configuration Guide.
· To view endpoint association and disassociation events in a SmartMC (or WiNet) network, execute the display epa monitor-information command on the commander instead of a member. If you execute the command on a member, the command displays only association events of endpoints connecting to the member.
Configuring EPA
1. Enter system view.
2. Create an endpoint monitor rule.
epa monitor-rule [ monitor-rule-id ] mac mac-address [ mask mac-mask ] [ vlan vlan-id ]
By default, no endpoint monitor rules exist.
Disabling EPA logging
By default, the EPA module logs endpoint associations and disassociations. If a monitored endpoint comes online or goes offline frequently, the device will generate a large number of log entries. In this case, to avoid affecting device performance, disable EPA logging as a best practice.
2. Disable EPA logging.
epa online-offline-log disable
By default, EPA logging is enabled.
Task |
Command |
Display endpoint association and disassociation information detected by EPA. |
display epa monitor-information [ online | offline ] [ device device-id | mac mac-address [ vlan vlan-id ] ] |
