16-OpenFlow Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S12500-X & S12500X-AF Switch Series Command References-Release 113x-6W10116-OpenFlow Command Reference
Table of Contents
Related Documents
01-Text
01-Text 179.19 KB
OpenFlow commands
In this chapter, an OpenFlow switch is the same as an OpenFlow instance, unless otherwise specified.
active instance
Use active instance to activate or reactivate an OpenFlow instance.
Use undo active instance to deactivate an OpenFlow instance.
active instance
An OpenFlow instance is not activated.
OpenFlow instance view
An OpenFlow instance takes effect only after it is activated.
Reactivating an OpenFlow instance refreshes the configuration data and interrupts communication with the controllers.
You can reactivate an OpenFlow instance by using the active instance command after you deactivate the OpenFlow instance by using the undo active instance command.
# Activate OpenFlow instance 1.
[Sysname] openflow instance 1
[Sysname-of-inst-1] active instance
classification global
Use classification global to enable the global mode for an OpenFlow instance.
Use undo classification to remove the configuration.
undo classification
An OpenFlow instance is in the VLAN mode.
If you execute the classification global and classification vlan commands multiple times, the most recent configuration takes effect.
By default, an OpenFlow instance is in the VLAN mode. When an OpenFlow instance is associated with VLANs, the flow entries take effect only on packets within those VLANs.
When the global mode is enabled for an OpenFlow instance, the flow entries take effect on packets within the network. All interfaces on the device belong to the OpenFlow instance, including VLAN interfaces, Layer 2 or Layer 3 Ethernet interfaces.
# Enable the global mode for OpenFlow instance 1.
[Sysname-of-inst-1] classification global
classification vlan
classification vlan
Use classification vlan to associate VLANs with an OpenFlow instance.
Use undo classification to cancel the association.
classification vlan vlan-id [ mask vlan-mask ] [ loosen ]
undo classification
An OpenFlow instance is not associated with any VLANs.
vlan-id: Specifies the VLAN ID in the range of 1 to 4094.
vlan-mask: Specifies a VLAN mask in the range of 0 to 4095. The default value is 4095.
loosen: Specifies the loosen mode. If the loosen mode is used, a port belongs to the OpenFlow instance when VLANs associated with the OpenFlow instance overlap with the port's allowed VLANs. Otherwise, a port belongs to an OpenFlow instance only when VLANs associated with the OpenFlow instance are within the port's allowed VLAN list.
The system calculates the VLANs to be associated according to the specified VLAN ID and mask. To view the associated VLANs, use the display openflow instance command.
# Associate an OpenFlow instance with a list of VLANs determined by VLAN ID 255 and VLAN mask 7.
[Sysname-of-inst-1] classification vlan 255 mask 7
controller address
Use controller address to specify a controller for an OpenFlow switch and configure the main connection to the controller.
Use undo controller address to remove the configuration.
controller controller-id address ip ip-address [ port port-number ] [ local address ip ip-address [ port port-number ] ] [ ssl ssl-policy-name ] [ vrf vrf-name ]
undo controller controller-id address
An OpenFlow instance does not have a main connection to a controller.
controller-id: Specifies a controller by its ID in the range of 0 to 63.
ip ip-address: Specifies the IPv4 address of the controller or the device.
local address: Specifies the IPv4 address that the device uses to establish connections with the controller.
port port-number: Specifies the port number that the device or the controller uses to establish TCP connections between them. The value range for the port number is 1 to 65535. The default value is 6633.
ssl ssl-policy-name: Specifies the SSL client policy that the controller uses to authenticate the OpenFlow switch. The policy name is a case-insensitive string of 1 to 31 characters.
vrf vrf-name: Specifies the VPN to which the controller belongs. The VRF name is the VRF instance name of MPLS L3VPN and is a case-insensitive string of 1 to 31 characters.
You can specify multiple controllers for an OpenFlow switch. The OpenFlow channel between the OpenFlow switch and each controller can have only one main connection.
The OpenFlow switch exchanges control messages with a controller through the main connection to perform the following operations:
·     Receive flow table entries or data.
·     Report information to the controller.
# Specify controller 10 for OpenFlow instance 1. The controller's IP address is 1.1.1.1 and the port number is 6666.
[Sysname-of-inst-1] controller 10 address ip 1.1.1.1 port 6666
controller connect interval
Use controller connect interval to set the reconnection interval for an OpenFlow instance.
Use undo controller connect interval to restore the default.
controller connect interval interval-value
The reconnection interval is 60 seconds for an OpenFlow instance.
interval-value: Specifies the reconnection interval in the range of 10 to 120 seconds.
The OpenFlow instance waits a reconnection interval before it attempts to reconnect to a controller.
# Set the reconnection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller connect interval 10
controller echo-request interval
Use controller echo-request interval to set the connection detection interval for an OpenFlow switch.
Use undo controller echo-request interval to restore the default.
controller echo-request interval interval-value
The connection detection interval is 5 seconds for an OpenFlow switch.
interval-value: Specifies the connection detection interval in the range of 1 to 10 seconds.
The connection detection interval specifies the interval at which the OpenFlow switch sends an Echo Request message to a controller.
As a best practice to reduce the CPU load, set the connection detection interval to a large value.
# Set the connection detection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller echo-request interval 10
controller mode
Use controller mode to configure the connection mode for an OpenFlow instance to establish connections to controllers.
Use undo controller mode to restore the default.
The connection mode is multiple.
multiple: Configures the connection mode as multiple for the OpenFlow instance to establish connections to controllers.
single: Configures the connection mode as single for the OpenFlow instance to establish connections to controllers.
When the connection mode is single, an OpenFlow establishes a connection to only one controller at a time, and the other controllers back up the controller. When the connection is broken, the OpenFlow instance attempts to connect to the next controller until it successfully establishes a connection.
When the connection mode is multiple, an OpenFlow instance can establish connections to all controllers at a time. When one or more controllers fail or one or more controller connections are broken, the OpenFlow switch can operate correctly.
# Configure the connection mode as single for OpenFlow instance 1.
[Sysname-of-inst-1] controller mode single
datapath-id
Use datapath-id to set the datapath ID for an OpenFlow instance.
Use undo datapath-id to restore the default.
datapath-id datapath-id
undo datapath-id
The datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address. The upper 16 bits are the instance ID and the lower 48 bits are the bridge MAC address.
datapath-id: Specifies the datapath ID for an OpenFlow instance. The argument is a hexadecimal number and the value range is 1 to 0xFFFFFFFFFFFFFFFF.
# Set the datapath ID to 0x123456 for OpenFlow instance 1.
[Sysname-of-inst-1] datapath-id 123456
description
Use description to set a description for an OpenFlow instance.
An OpenFlow instance does not have a description.
text: Specifies a description for the OpenFlow instance, which is a case-insensitive string of 1 to 255 characters and must start with an English letter.
# Set the description to test-desc for OpenFlow instance 1.
[Sysname-of-inst-1] description test-desc
default table-miss permit
Use default table-miss permit to change the default action of table-miss flow entries to forward packets to the normal pipeline.
Use undo default table-miss permit to restore the default.
The default action of table-miss flow entries is to drop packets.
# Change the default action of table-miss flow entries to forward packets to the normal pipeline.
[Sysname-of-inst-1] default table-miss permit
display openflow controller
Use display openflow controller to display controller information for an OpenFlow instance.
display openflow instance instance-id controller [ controller-id ]
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094.
controller-id: Specifies a controller by its ID in the range of 0 to 63. If no controller ID is specified, this command displays information about all controllers for an OpenFlow instance.
The controller information includes connection information and packet statistics.
# Display controller information for OpenFlow instance 100.
<Sysname> display openflow instance 100 controller
Instance 10 controller information:
 Reconnect interval: 60 (s)
 Echo interval     : 5  (s)
 Controller ID           : 1
 Controller IP address   : 192.168.49.49
 Controller port         : 6633
 Controller role         : --
 Connect type            : TCP
 Connect state           : Idle
 Packets sent            : 0
 Packets received        : 0
 SSL policy              : --
 VRF name                : --
Reconnect interval
Reconnection interval (in seconds) for an OpenFlow instance to reconnect to all controllers.
Echo interval
Interval (in seconds) at which an OpenFlow instance sends an Echo Request message to all controller.
IP address of the controller.
Controller port
TCP port number of the controller.
Controller role
Role of the controller:
·     Equal—The controller has the same mode as other controllers that are specified for the OpenFlow instance.
·     Master—The controller is the master controller for the OpenFlow instance.
·     Slave—The controller is a slave controller for the OpenFlow instance.
If the controller is not configured with any role, this field displays two hyphens (--).
Connect type
Type of the connection between the OpenFlow instance and the controller: TCP or SSL.
Connect state
State of the connection between the OpenFlow instance and the controller: Idle or Established.
Packets sent
Number of packets that have been sent to the controller.
Packets received
Number of packets that have been received from the controller.
SSL policy
Name of the SSL client policy used for SSL connections.
If no SSL client policy controller is configured, this field displays two hyphens (--).
display openflow flow-table
Use display openflow flow-table to display flow table information for an OpenFlow instance.
display openflow instance instance-id flow-table [ table-id ]
table-id: Specifies a flow table by its ID in the range of 0 to 254.
If you do not specify a flow table ID, the command displays information about all flow tables for the specified OpenFlow instance.
# Display information about all flow tables for OpenFlow instance 10.
<Sysname> display openflow instance 10 flow-table
Instance 10 flow table information:
Table 0 information:
 Table type: MAC-IP, flow entry count: 1, total flow entry count: 2
MissRule (default) flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: reset_counts
 |no_pkt_counts|no_byte_counts, byte count: --, packet count: --
Match information: any
Instruction information:
 Write actions:
  Drop
Flow entry 1 information:
 cookie: 0x0, priority: 1, hard time: 0, idle time: 0, flags: none,
Match information:
 Ethernet destination MAC address: 0000-0000-0001
 Ethernet destination MAC address mask: ffff-ffff-ffff
 VLAN ID: 100, mask: 0xfff
 Write actions:
  Output interface: XGE1/0/4
 Write metadata/mask: 0x0000000000000001/0xffffffffffffffff
 Goto table: 1
Table 1 information:
 Table type: Extensibility, flow entry count: 2, total flow entry count: 2
MissRule Flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: none,
 byte count: --, packet count: 60
 Write actions:
  Drop
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem
 |check_overlap, byte count: --, packet count: 1
Match information:
 Input interface: XGE1/0/3
 Ethernet source MAC address: 0000-0000-0001
 Ethernet source MAC address mask: ffff-ffff-ffff
 Set meter: 100
 Apply actions:
 Write actions:
  Output interface: Controller, send length: 128 bytes
Table type
Type of the flow table: MAC-IP or Extensibility.
flow entry count
Number of flow entries deployed by controllers.
Total number of flow entries in the table.
cookie
Cookie ID of the flow entry.
priority
Priority of the flow entry. A larger value indicates a higher priority.
hard time
Hard timeout of the flow entry, in seconds. The flow entry is aged out immediately after the hard timeout expires.
If the flow entry has no hard timeout, the field displays 0.
idle time
Idle timeout of the flow entry, in seconds. The flow entry is aged out if no packet matches the entry within the idle timeout.
If the flow entry has no idle timeout, the field displays 0.
flags
Flags that the flow entry includes:
·     flow_send_rem—Sends a flow removed message when the flow entry is removed or expires.
·     check_overlap—Checks for overlapping flow entries.
·     reset_counts—Resets flow table counters.
·     no_pkt_counts—Does not count packets.
·     no_byte_counts—Does not count bytes.
If the flow entry does not include any flags, this field displays none.
byte count
Number of bytes that have matched the flow entry.
packet count
Number of packets that have matched the flow entry.
Match information
Contents in the Match field of the flow entry (see Table 3).
Contents in the Instruction field of the flow entry:
·     Set meter—Sends the matched packet to a specified meter.
·     Write metadata/mask—Writes the masked metadata value into the metadata fields of the matched packet.  Metadata is used for passing messages between flow tables.
·     Write metadata mask—Mask of the metadata value to be written.
·     Goto table—Sends the matched packet to the next flow table for processing.
·     Clear actions—Immediately clears all actions in the action set of the matched packet.
·     Apply actions—Immediately applies specified actions in the action set of the matched packet.
·     Write actions—Writes specified actions into the action set of the matched packet.
For more information about actions, see Table 4.
Table 3 Match information
Match field
Match field mask
Input interface
N/A
Ingress port (see Table 5).
Physical input interface
N/A
Ingress physical port.
Mask
Ethernet destination MAC address and mask.
Mask
Ethernet source MAC address and mask.
Ethernet type
N/A
Ethernet type of the OpenFlow packet payload.
VLAN ID
Mask
VLAN ID and mask.
VLAN PCP
N/A
VLAN priority.
IP DSCP
N/A
Differentiated Services Code Point (DSCP)  value.
IP ECN
N/A
Explicit Congestion Notification (ECN) value in the IP header.
IP protocol
N/A
IPv4 protocol number.
IPv4 source address
Mask
IPv4 source address and mask.
IPv4 destination address
Mask
IPv4 destination address and mask.
TCP source port
Mask
TCP source port and mask.
TCP destination port
Mask
TCP destination port and mask.
UDP source port
Mask
UDP source port and mask.
UDP destination port
Mask
UDP destination port and mask.
ICMPv4 type
N/A
ICMPv4 type.
ICMPv4 code
N/A
ICMPv4 code.
ARP source IPv4 address
Mask
Sender IPv4 address and mask in the ARP payload.
ARP source MAC address
Mask
Sender MAC address and mask in the ARP payload.
Table 4 Actions
Drop
Drops the matched packet.
Output interface
Sends the packet through a specified port. For more information about ports, see Table 5.
send length
Specifies the length of bytes to be taken from the packet and be sent to the controller.
Group
Specifies a group to process the packet.
Set queue
Maps the flow entry to a queue specified by ID.
Set field
Modifies a specific field of the packet.
Table 5 Ports
Port name
Ingress port
Output port
Table
Not supported.
Supported.
Start flow table in the OpenFlow workflow.
Normal
Not supported.
Supported.
Normal forwarding workflow of the switch.
Flood
Not supported.
Supported.
Flooding workflow.
All
Not supported.
Supported.
All ports.
Controller
Supported.
Supported.
Channel connected to the controller.
Local
Supported.
Supported.
Local CPU.
XGE1/0/3 (port name)
Supported.
Supported.
Name of a physical or logical port, such as a link aggregation port.
display openflow group
Use display openflow group to display the group table information for an OpenFlow instance.
display openflow instance instance-id group [ group-id ]
group-id: Specifies a group by its ID in the range of 0 to 4294967040. If this argument is not specified, the command displays information about all group entries of the OpenFlow instance.
The group entries are used by flow entries to make the OpenFlow device support more packet forwarding functions, for example, multicast and broadcast. Each group table contains multiple action buckets. The actions in the buckets of a group entry are performed for packets matching the group entry.
You cannot configure group entries on the OpenFlow devices. Instead, you can configure group entries on the controller and issue the group entries to the OpenFlow device.
# Display the group table information for OpenFlow instance 10.
<Sysname> display openflow instance 10 group
Instance 10 group table information:
 Group count: 1
Group entry 1:
 Type: All, byte count: 55116, packet count: 401
 Bucket 1 information:
  Action count 1, watch port: any, watch group: any
  Byte count 55116, packet count 401
  Output interface: XGE1/0/11
 Bucket 2 information:
  Byte count --, packet count --
  Output interface: XGE1/0/12
 Referenced information:
  Count: 3
  Flow table 0
  Flow entry: 1, 2, 3
Table 6 Output description
Group count
Number of group entries contained in the OpenFlow instance.
Group table type. All indicates all buckets in the group are executed. This group is used for multicast or broadcast forwarding.
Action count
Number of actions in the action bucket.
Byte count
Number of bytes processed by the action bucket. Two hyphens (--) are displayed when the field is not supported.
packet count
Number of packets processed by the action bucket. Two hyphens (--) are displayed when the field is not supported.
watch port
Ports that affect the action bucket status.
watch group
Group table IDs of the ports that affect the action bucket status.
Output interface
Output interface in the group table.
Information about the flow entries referencing group entries.
Count
Number of flow entries that reference group entries.
Flow table
ID of the flow table to which the flow entries referencing the group entries belong.
Flow entry
IDs of flow entries referencing group entries.
Use display openflow instance to display the detailed information for an OpenFlow instance.
display openflow instance [ instance-id ]
# Display the detailed information of OpenFlow instances.
Instance 10 information:
Configuration information:
 Description   : test-desc
 Active status : Active
 Inactive configuration:
  Classification: Global
  Flow table:
   Table ID(type): 0(MAC-IP)
   Table ID(type): 1(Extensibility)
  Default table-miss: Permit
  Forbidden port: VLAN interface
 Active configuration:
  Classification : VLAN, loosen mode, total VLANs(1)
   2
  In-band management VLAN, total VLANs(0)
   Empty VLAN
  Connect mode: Multiple
  Mac address learning: Enabled
  Flow table:
   Table ID(type): 0(MAC-IP), count: 0
  Flow-entry max-limit: 65535
  Datapath ID: 0x0000001234567891
  Default table-miss: Drop
  Forbidden port: None
Port information:
 Ten-GigabitEthernet1/0/3
Active channel information:
 Controller 1 IP address: 192.168.49.49  port: 6633
 Controller 2 IP address: 192.168.43.49  port: 6633
Table 7 Command output
Description of the OpenFlow instance.
Active status
Activation status of the OpenFlow instance.
Inactive OpenFlow instance configuration.
Active OpenFlow instance configuration.
Classification VLAN, loosen mode, total VLANs
VLANs associated with the OpenFlow instance, the total number of these VLANs.
Inband management VLANs and the total number of inband management VLANs. empty VLAN is displayed when no inband management VLAN is configured.
Connect mode
Connection mode for the OpenFlow instance to establish connections to controllers:
·     multiple—The connection mode is multiple for the OpenFlow instance to establish connections to controllers.
·     single—The connection mode is single for the OpenFlow instance to establish connections to controllers.
Whether MAC address learning is enabled in the VLANs associated with the OpenFlow instance:
·     Enabled—MAC address learning is enabled in the VLANs associated with the OpenFlow instance.
·     Disabled—MAC address learning is disabled in the VLANs associated with the OpenFlow instance.
Maximum number of flow entries allowed in the extensibility flow table.
Datapath ID
Datapath ID of the OpenFlow instance.
Default table-miss
Default action of the table-miss flow entry:
·     Permit—Forward packets to the normal pipeline.
·     Drop—Drop packets.
Forbidden port
Port types forbidden to be reported to controllers:
·     VLAN interface.
·     Virtual Switch Interface.
Port information
Ports added to the OpenFlow instance.
Flow table
Flow table information of the OpenFlow instance.
Table ID(type)
Flow table ID (flow table type). The flow table type can be MAC-IP or Extensibility.
count
Total number of flow entries in the flow table.
Information about active control channels.
Controller id IP address:  port:
Brief information of controllers which have established connections to the OpenFlow instance. This field is displayed only when the OpenFlow instance has established connections to controllers.
Failopen mode
Connection interruption mode when the OpenFlow instance is disconnected from all controllers (this field is displayed only when the OpenFlow instance is disconnected from all controllers):
·     secure—The OpenFlow switch uses flow tables for traffic forwarding after it is disconnected from all controllers.
·     standalone—The OpenFlow switch uses the normal forwarding process after it is disconnected from all controllers.
display openflow meter
Use display openflow meter to display meter entry information for an OpenFlow instance.
display openflow instance instance-id meter [ meter-id ]
meter-id: Specifies a meter by its ID in the range of 0 to 4294901760. If no meter ID is specified, this command displays information about all meter entries for an OpenFlow instance.
# Display meter entry information for OpenFlow instance 10.
<Sysname> display openflow instance 10 meter
Meter flags: KBPS  -- Rate value in kb/s, PKTPS -- Rate value in packet/sec
             BURST -- Do burst size,      STATS -- Collect statistics
Instance 10 meter table information:
 meter entry count: 2
Meter entry 100 information:
 Meter flags: KBPS
 Band 1 information
 Type: drop, rate: 1024, burst size: 65536
 Byte count: --, packet count: 0
 Referencedinformation:
  Count: 3
  Flow table: 0
  Flow entry: 1, 2, 3
Meter entry 200 information:
 Meter flags: KBPS
 Band 1 information
 Type: drop, rate: 10240, burst size: 655360
 Byte count: --, packet count: --
  Count: 0
Table 8 Command output
Group entry count
Total number of meter entries included in the OpenFlow instance.
Meter flags
Flags configured for the meter:
·     KBPS—The rate value is in kbps.
·     PKTPS—The rate value is in pps.
·     BURST—The burst size field in the band is used and the length of the packet or byte burst is determined by the burst size.
·     STATS—Meter statistics are collected.
Band
Bands included in the meter.
Type of the band:
·     drop—Discard the packet.
·     dscp remark—Modify the drop precedence of the DSCP field in the IP header of the packet.
Rate
Rate value above which the corresponding band may apply to packets.
Burst size
Length of the packet or byte burst to consider for applying the meter.
Byte count
Number of bytes processed by a band.
If this field is not supported, the field displays two hyphens (--).
packet count
Number of packets processed by a band.
Information about the meter entry referenced by flow entries.
Count
Total number of flow entries that reference the meter entry.
Flow table
Flow table to which the flow entries that reference the meter entry belong.
Flow entry
Flow entries that reference the meter entry.
display openflow summary
Use display openflow summary to display summary OpenFlow instance information, including OpenFlow instance ID, activation status, and datapath ID.
display openflow instance summary
# Display summary information about OpenFlow instances.
<Sysname> display openflow summary
Fail Open mode: Se -- secure mode, Sa -- standalone mode
Reactive flags: Y -- Need active instance,
                N -- Needn't active instance
ID    Status    Datapath-ID         Channel    Table-num  Port-num  Reactivate
1     active    0x0000000100001221  Connected       2         8       Y
10    deactive           -             -            -         -       -
4094  active    0x00000ffe00001221  Failed(Sa)        2         0     N
Table 9 Command output
ID
OpenFlow instance ID.
Status
Activation status of the OpenFlow instance:
·     active—The OpenFlow instance is active.
·     deactive—The OpenFlow instance is inactive.
Datapath-ID
Datapath ID of the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive.
Channel
Status of the secure channel between the OpenFlow instance and the controller:
·     connected—The secure channel between the OpenFlow instance and the controller has been established.
·     Failed(Se)—The secure channel between the OpenFlow instance and the controller has been disconnected, and the OpenFlow instance is operating in secure mode.
·     Failed(Sa)—The channel between the OpenFlow instance and the controller has been disconnected, and the OpenFlow instance is operating in standalone mode.
Table-num
Number of flow tables in the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive.
Port-num
Number of ports belonging to the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive.
Reactivate
Indicates whether the OpenFlow instance needs to be reactivated:
·     Y—The OpenFlow instance needs to be reactivated.
·     N—The OpenFlow instance does not need to be reactivated.
fail-open mode
Use fail-open mode to set the connection interruption mode for an OpenFlow switch.
Use undo fail-open mode to restore the default.
fail-open mode { secure | standalone }
undo fail-open mode
The connection interruption mode is secure, and the controller deploys the table-miss flow entry (the action is Drop) to the OpenFlow instance.
secure: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers.
standalone: Configures the OpenFlow switch to use the normal forwarding process after it is disconnected from all controllers.
# Set the connection interruption mode to standalone for OpenFlow instance 1.
[Sysname-of-inst-1] fail-open mode standalone
flow-entry max-limit
Use flow-entry max-limit to set the maximum number of entries for each extensibility flow table.
Use undo flow-entry max-limit to restore the default.
flow-entry max-limit limit-value
An extensibility flow table has a maximum of 65535 flow entries.
limit-value: Specifies the maximum number of flow entries, in the range of 1 to 65535.
# Configure OpenFlow instance 1 to have a maximum of 256 entries in each extensibility flow table.
[Sysname-of-inst-1] flow-entry max-limit 256
flow-log disable
Use flow-log disable to disable logging for successful flow table modifications.
Use undo flow-log disable to restore the default.
flow-log disable
Logging for successful flow table modifications is enabled.
This command is available in Release 1138P01 and later versions.
# Disable logging for successful flow table modifications for OpenFlow instance 1.
[Sysname-of-inst-1] flow-log disable
flow-table
Use flow-table to configure a flow table for an OpenFlow instance.
Use undo flow-table to restore the default.
flow-table { extensibility extensibility-table-id | mac-ip mac-ip-table-id }*
undo flow-table
An OpenFlow instance has an extensibility flow table whose ID is 0.
extensibility extensibility-table-id: Specifies an extensibility flow table by its ID in the range of 0 to 254.
mac-ip mac-ip-table-id: Specifies a MAC-IP flow table by its ID in the range of 0 to 254.
You can specify only one MAC-IP flow table and one extensibility flow table for an OpenFlow instance. For an OpenFlow instance, the MAC-IP flow table ID must be smaller than the extensibility flow table ID.
Configure flow tables before you activate an OpenFlow instance.
# Configure a MAC-IP flow table with ID 0 and an extensibility flow table with ID 1 for OpenFlow instance 1.
[Sysname-of-inst-1] flow-table mac-ip 0 extensibility 1
forbidden port
Use forbidden port to forbid an OpenFlow instance to report ports of the specified types to controllers.
Use undo forbidden port to restore the default.
forbidden port { vlan-interface | vsi-interface } *
undo forbidden port
All ports that belong to an OpenFlow instance are reported to the controllers.
vlan-interface: Forbids reporting VLAN interfaces that belong to an OpenFlow instance to controllers.
vsi-interface: Forbids reporting VSI interfaces that belong to an OpenFlow instance to controllers.
# Forbid OpenFlow instance 1 to report VLAN interfaces that belong to the OpenFlow instance to controllers.
[Sysname-of-inst-1] forbidden port vlan-interface
in-band management vlan
Use in-band management vlan to configure inband management VLANs.
Use undo in-band management vlan to restore the default.
in-band management vlan vlan-list
No inband management VLAN is configured for an OpenFlow instance.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
The inband management VLANs must be a subset of the VLANs associated with the OpenFlow instance.
This command is applicable only to OpenFlow instances in VLAN mode.
# Configure VLAN 10 as an inband management VLAN in OpenFlow instance 1.
[Sysname-of-inst-1] in-band management vlan 10
mac-ip dynamic-mac aware
Use mac-ip dynamic-mac aware to configure OpenFlow to support dynamic MAC addresses.
Use undo mac-ip dynamic-mac aware to restore the default.
An OpenFlow instance ignores dynamic MAC address messages sent from controllers.
When a MAC-IP flow table is configured for an OpenFlow switch, you can configure OpenFlow to support querying and deleting dynamic MAC addresses in the table.
When this command is configured, the OpenFlow switch does not send change events for the dynamic MAC addresses to controllers.
# Configure OpenFlow instance 1 to support dynamic MAC addresses.
[Sysname-of-inst-1] mac-ip dynamic-mac aware
openflow instance
Use openflow instance to create an OpenFlow instance and enter OpenFlow instance view.
Use undo openflow instance to remove an OpenFlow instance.
undo openflow instance instance-id
No OpenFlow instance exists.
# Create OpenFlow instance 1, and enter the OpenFlow instance view.
[Sysname-of-inst-1]
permit-port-type member-port
Use permit-port-type member-port to allow link aggregation member ports to be in the deployed flow tables.
Use undo permit-port-type to remove the configuration.
Link aggregation member ports cannot be in the deployed flow tables.
# Configure OpenFlow instance 1 to allow link aggregation member ports to be in the deployed flow tables.
[Sysname-of-inst-1] permit-port-type member-port
refresh ip-flow
Use refresh ip-flow to refresh all Layer 3 flow entries in the MAC-IP flow table for an OpenFlow instance.
refresh ip-flow
# Refresh all Layer 3 flow entries in the MAC-IP flow table for OpenFlow instance 1.
[Sysname-of-inst-1] refresh ip-flow
reset openflow instance controller statistics
Use reset openflow instance controller statistics to clear statistics about packets that a controller sends and receives for an OpenFlow instance.
reset openflow instance instance-id controller [ controller-id ] statistics
controller-id: Specifies a controller by its ID in the range of 0 to 63. If you do not specify this argument, the command clears statistics about packets that all controllers send and receive for an OpenFlow instance.
# Clear statistics about packets that all controllers send and receive for OpenFlow instance 1.
<Sysname> reset openflow instance 1 controller statistics
Index
A C D F I M O P R
A
active instance,1
C
classification global,1
classification vlan,2
controller address,3
controller connect interval,4
controller echo-request interval,4
controller mode,5
D
datapath-id,6
default table-miss permit,7
description,6
display openflow controller,8
display openflow flow-table,9
display openflow group,13
display openflow instance,14
display openflow meter,16
display openflow summary,18
F
fail-open mode,19
flow-entry max-limit,20
flow-log disable,20
flow-table,21
forbidden port,22
I
in-band management vlan,22
M
mac-ip dynamic-mac aware,23
O
openflow instance,24
P
permit-port-type member-port,24
R
refresh ip-flow,25
reset openflow instance controller statistics,25
