12-FCoE Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S12500-X & S12500X-AF Switch Series Command References-Release 113x-6W10112-FCoE Command Reference
Table of Contents
Related Documents
01-Text
01-Text 596.30 KB
FCoE commands· 1
FCoE mode commands· 1
display fcoe-mode· 1
fcoe-mode· 1
VFC interface commands· 3
bandwidth· 3
bind interface· 3
default 5
description· 5
display interface vfc· 6
fc mode (VFC interface view) 9
interface vfc· 10
reset counters interface· 10
shutdown· 11
FCoE commands· 11
display fcoe· 11
fcoe enable· 12
fcoe fcf-priority· 13
fcoe fcmap· 14
fcoe fka-adv-period· 14
fcoe global fcf-priority· 16
VSAN commands· 17
display vsan port-member 17
port trunk vsan· 18
vsan· 18
Fabric building commands· 19
allowed-domain-id· 19
display fc domain· 20
display fc domain-list 21
display fc ess· 22
display fc login· 24
display fc name-service database· 25
display fc scr-table· 27
display fc switch-wwn· 28
display fc timer 29
domain auto-reconfigure enable· 29
domain configure enable· 30
domain restart 31
domain-id· 32
fabric-name· 33
fc domain rcf-reject 33
fc name-service auto-discovery· 34
fc timer distributed-services· 35
fc timer error-detect 35
fc timer resource-allocation· 36
fc wwn default-fc4-type· 37
priority· 38
rscn aggregation enable· 39
rscn aggregation timer 39
snmp-agent trap enable fc-fabric· 40
snmp-agent trap enable fc-name-service· 41
timer distributed-services· 42
timer error-detect 42
timer resource-allocation· 43
wwn area-port-id· 44
FC routing and forwarding commands· 45
display fc exchange· 45
display fc fib· 47
display fc routing-table· 48
display fspf graceful-restart 51
display fspf lsdb· 52
display fspf neighbor 54
display fspf statistics· 55
fc route-static· 56
fspf cost 57
fspf dead-interval 58
fspf enable· 59
fspf graceful-restart 59
fspf graceful-restart helper 60
fspf graceful-restart interval 61
fspf hello-interval 61
fspf min-ls-arrival 62
fspf min-ls-interval 63
fspf retransmit-interval 63
fspf silent 64
fspf spf-hold-time· 64
reset fspf counters· 65
FC zone commands· 66
delete zone database all 66
display zone· 66
display zone member 68
display zone statistics· 69
display zone status· 70
display zone-alias· 72
display zoneset 73
display zoneset active· 74
member (zone view) 76
member (zone alias view) 78
member (zone set view) 79
pairwise-zoning enable· 80
reset zone statistics· 81
snmp-agent trap enable fc-zone· 81
zone clone· 82
zone default-zone permit 83
zone hard-zoning enable· 84
zone merge-control restrict 84
zone mode enhanced· 85
zone name· 86
zone rename· 87
zone-alias clone· 87
zone-alias name· 88
zone-alias rename· 89
zoneset activate· 89
zoneset clone· 90
zoneset distribute· 91
zoneset distribute full 92
zoneset name· 92
zoneset rename· 93
FIP snooping commands· 94
display fip-snooping enode· 94
display fip-snooping fcf 94
display fip-snooping flushing-rules· 95
display fip-snooping rules· 96
display fip-snooping sessions· 97
fip-snooping enable· 98
fip-snooping fc-map· 99
fip-snooping port-mode· 99
FCS commands· 100
fcs discovery start 100
fcs discovery stop· 101
display fcs discovery status· 101
display fcs database· 102
display fcs ie· 104
display fcs port 106
FDMI commands· 109
display fdmi database· 109
FC ping commands· 113
fcping· 113
FC tracert commands· 114
fctracert 114
Index· 116
FCoE commands
FCoE require a license to run on the switch.
The switch supports FCoE only when it operates in advanced mode. For an operating mode change to take effect, you must perform the following tasks:
1.     Save the running configuration to the next-startup configuration file.
2.     Delete the .mdb file for the next-startup configuration file.
3.     Reboot the switch.
For more information about licensing and system operating modes, see Fundamentals Configuration Guide.
FCoE mode commands
display fcoe-mode
Use display fcoe-mode to display the FCoE mode of the switch.
display fcoe-mode
# Display the FCoE mode of the switch.
<Sysname> display fcoe-mode
The FCoE mode is FCF.
The FCoE mode is TRANSIT.
The FCoE mode is NONE.
fcoe-mode
fcoe-mode
Use fcoe-mode to configure an FCoE mode for the switch.
Use undo fcoe-mode to restore the default.
fcoe-mode { fcf | transit }
undo fcoe-mode
A switch operates in non-FCoE mode and does not provide any FCoE capabilities.
fcf: Specifies the FCF mode.
transit: Specifies the Transit mode.
The switch supports the following FCoE modes:
·     FCF mode—A switch operating in this mode is called an FCF switch. Its VFC interfaces support E mode (E_Port) and F mode (F_Port).
·     Transit mode—A switch operating in this mode is called a Transit switch. Its Ethernet interfaces can operate in ENode mode or FCF mode.
An FCoE-capable switch can operate in the following modes:
·     FCF mode—When the switch is operating in this mode, it can perform one of the following operations:
¡     Connect to the E_Port on another FCF switch through its E_Port.
¡     Connect to the N_Port on a node through its F_Port.
·     Transit mode—When the switch is operating in this mode, you can perform one of the following tasks:
¡     Configure an Ethernet interface to operate in ENode mode, so that the Ethernet interface can receive traffic from only an ENode.
¡     Configure an Ethernet interface to operate in FCF mode, so that the Ethernet interface can receive traffic from only an FCF switch.
·     Non-FCoE mode—When the switch is operating in this mode, it is a standard switch and does not provide any FCoE capabilities.
The switch can only convert from non-FCoE mode to one FCoE mode, or vice versa. It cannot convert directly among FCoE modes. To convert among FCoE modes, first convert the switch to non-FCoE mode. Converting the switch to non-FCoE mode also clears FCoE-related configurations in the original FCoE mode.
# Configure the switch to operate in FCF mode.
[Sysname] fcoe-mode fcf
# Convert the switch operating in FCF mode to Transit mode.
[Sysname] undo fcoe-mode
All current FC configuration will be lost. Continue? [Y/N]:y
[Sysname] fcoe-mode transit
display fcoe-mode
bandwidth
Use bandwidth to set the expected bandwidth for a VFC interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) of a VFC interface is the interface baud rate divided by 1000.
VFC interface view
The expected bandwidth determines the cost of the interface, which is used for route calculation.
By default, the baud rate of a VFC interface is 10 Gbps.
# Set the expected bandwidth to 50 kbps for interface VFC 1.
[Sysname] interface vfc 1
[Sysname-Vfc1] bandwidth 50
bind interface
Use bind interface to bind a VFC interface to an Ethernet interface. Ethernet interfaces in this command refer to Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
Use undo bind interface to delete a VFC-to-Ethernet interface binding.
bind interface interface-type interface-number [ mac mac-address ]
undo bind interface
A VFC interface is not bound to any Ethernet interfaces.
VFC interface view
interface-type interface-number: Specifies an interface by its type and number. The interface type can be one of the following:
·     Layer 2 Ethernet interface.
·     Layer 2 aggregate interface.
mac mac-address: Specifies the peer FCoE MAC address, six bytes in the format of XXXX-XXXX-XXXX.
To make a VFC interface work, bind it to a physical Ethernet interface. The VFC interface then sends and receives packets through the Ethernet interface.
To use one physical link to carry multiple VFC interfaces, you must bind these VFC interfaces to different peer FCoE MAC addresses. However, you can bind them to one Ethernet interface. The FCoE MAC address identifies the device that communicates with a VFC interface. For a point-to-multipoint network, the FCoE MAC address is required. For a point-to-point network, the FCoE MAC address is optional.
You can use the display fcoe command to display the FCoE MAC address of a switch. You can display the FCoE MAC address of an ENode through some software or the NMS.
A VFC interface can be bound to only one Ethernet interface and to only one FCoE MAC address.
An Ethernet interface can be bound to multiple VFC interfaces, but an FCoE MAC address can be bound to only one VFC interface.
To successfully bind a VFC interface to a Layer 2 Ethernet interface, make sure the Layer 2 Ethernet interface is FCoE capable.
When you bind a VFC interface to a Layer 2 aggregate interface, follow these restrictions and guidelines:
·     To successfully bind a VFC interface to a Layer 2 aggregate interface, make sure all member ports of the Layer 2 aggregate interface are FCoE capable. Also, make sure new member ports of the Layer 2 aggregate interface are FCoE capable.
·     The binding to a Layer 2 aggregate interface does not take effect when you perform the following tasks:
¡     Bind one VFC interface to a Layer 2 aggregate interface.
¡     Bind another VFC interface to a Layer 2 Ethernet interface that is a member port of the Layer 2 aggregate interface.
# Bind interface VFC 4 to interface FortyGigE 1/0/1 and FCoE MAC address 000c-2999-eacd.
[Sysname] interface vfc 4
[Sysname-Vfc4] bind interface fortygige 1/0/1 mac 000c-2999-eacd
# Bind interface VFC 5 to interface Bridge-aggregation 1 and FCoE MAC address 000c-2888-eacd.
[Sysname] interface vfc 5
[Sysname-Vfc5] bind interface bridge-aggregation 1 mac 000c-2888-eacd
·     display fcoe
·     display interface vfc
default
Use default to restore the default settings for a VFC interface.
default
VFC interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface VFC 1.
[Sysname-Vfc1] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to set a description for a VFC interface.
The description of a VFC interface is interface name Interface, for example, Vfc 1 Interface.
VFC interface view
text: Specifies an interface description, a case-sensitive string of 1 to 255 characters.
The description helps users identify the role of an interface.
# Set the description to Vfcport1 for interface VFC 1.
[Sysname-Vfc1] description Vfcport1
Use display interface vfc to display VFC interface information.
display interface [ vfc [ interface-number ] ] [ brief [ description | down ] ]
interface-number: Specifies a VFC interface by its number in the range of 1 to 1024.
brief: Displays brief information about interfaces. If you do not specify this keyword, the command displays detailed information about interfaces.
description: Displays complete interface descriptions.
down: Displays information about the interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify the vfc keyword, this command displays information about all interfaces supported by the switch.
If you specify the vfc keyword, this command displays information about all VFC interfaces.
If you specify a VFC interface, this command displays information about the specified VFC interface.
# Display detailed information about interface VFC 1.
<Sysname> display interface vfc 1
Vfc1
Current state: UP
Line protocol state: UP
Description: Vfc1 Interface
Bandwidth: 10000000kbps
Maximum Transmit Unit: 2112
Link layer protocol is FC
Port WWN is 66:66:66:63:66:64:61:30
FC mode is E, state is E
Support the VSAN protocol
VSAN tagging mode is Tagging
EVFP common VSAN: 1
Bound interface is FortyGigE1/0/1, Bound MAC is 000c-2933-eacd
VSAN of physical-UP state: 1
Current state
Physical state and administrative state of the VFC interface:
·     DOWN (Administratively)—The interface is administratively shut down by using the shutdown command.
·     DOWN—The interface is administratively up but physically down.
·     UP—The interface is up both administratively and physically.
Line protocol state
Link layer protocol state of the VFC interface: DOWN or UP.
Bandwidth
Expected bandwidth of the VFC interface.
IP packet processing capability. If the VFC interface is not assigned an IP address, this field displays Disabled.
FC mode
Mode of the VFC interface.
state
Operating mode of the VFC interface through negotiation.
Indicates the VFC interface supports the VSAN protocol.
VSAN tagging mode
Link type of the interface: Trunk (Tagging) or Access (Non tagging).
VFC interfaces support only Tagging.
EVFP common VSAN
Indicates that the common VSANs are in up state through the EVFP negotiation.
This field is displayed only after the link comes up.
Bound interface
Physical interface bound to the VFC interface.
Bound MAC
FCoE MAC address bound to the VFC interface.
List of VSANs that are physically up.
Time when the interface statistics were last cleared by using the reset counters interface command. Never indicates that the interface statistics have never been cleared since switch startup.
# Display brief information about interface VFC 1.
<Sysname> display interface vfc 1 brief
Brief information on VFC interface(s):
Admin Mode: auto - auto; E - e port; F - f port; NP - n port proxy
Oper Mode: E - e port; F - f port; NP - n port proxy;
           TE - trunking e port; TF - trunking f port;
           TNP - trunking n port proxy
Interface  Admin Admin Oper Status Bind
           Mode  Trunk Mode        Interface
                 Mode
Vfc1       F     on    TF   UP     FGE1/0/1 0102-0304-0506
Name of the VFC interface.
Admin Mode
User-configured VFC interface mode:
·     E.
·     F.
Admin Trunk Mode
User-configured trunk mode for the VFC interface: on.
Oper Mode
Negotiated mode (link layer negotiation) in which the VFC interface is operating:
·     E—The VFC interface is operating in E mode as an access port.
·     F—The VFC interface is operating in F mode as an access port.
·     TE—The VFC interface is operating in E mode as a trunk port.
·     TF—The VFC interface is operating in F mode as a trunk port.
If negotiation is not initiated or fails, this field displays two hyphens (--).
Status
Negotiated state (link layer negotiation) for the VFC interface:
·     UP.
·     DOWN.
Bind Interface
Ethernet interface and FCoE MAC address bound to the VFC interface.
This field is empty when the VFC interface does not have bound Ethernet interface and FCoE MAC address.
# Display the descriptions of VFC interfaces.
<sysname> display interface vfc brief description
Interface    Description
Vfc1         Vfc1 Interface
Vfc2         Vfc2 Interface
# Display information about and the causes of the VFC interfaces in physically down state.
<Sysname> display interface vfc brief down
Brief information on interface(s) under bridge mode:
Vfc1                 ADM  Administratively
Brief information about Layer 2 interfaces.
Link status:
·     ADM—The interface has been shut down by the network administrator. To bring up the interface, execute the undo shutdown command.
·     Stby—The interface is a standby interface.
Interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been administratively shut down. To bring up the interface, execute the undo shutdown command.
Cause
Causes for the physical state of the VFC interface to be Down:
·     Not connected—Physical connections do not exist (possibly because the network cable is disconnected or faulty).
·     Administratively—The interface was shut down by using the shutdown command. To bring up the interface, use the undo shutdown command.
Use fc mode to set the mode of a VFC interface.
Use undo fc mode to restore the default.
fc mode { e | f }
undo fc mode
The mode of a VFC interface is F.
VFC interface view
e: Specifies the E mode.
f: Specifies the F mode.
# Set the mode to E for interface VFC 1.
[Sysname-Vfc1] fc mode e
interface vfc
Use interface vfc to create a VFC interface and enter its view. If the VFC interface already exists, this command leads you to VFC interface view directly.
Use undo interface vfc to delete a VFC interface.
interface vfc interface-number
undo interface vfc interface-number
No VFC interface exists.
interface-number: Specifies the number of the VFC interface, in the range of 1 to 1024.
A VFC interface is a logical interface manually created on the FCF switch to simulate the functionality of a physical FC interface.
# Create interface VFC 1 and enter its view.
[Sysname-Vfc1]
Use reset counters interface to clear statistics for VFC interfaces.
reset counters interface [ vfc [ number ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify the vfc keyword, this command clears statistics for all interfaces.
If you specify the vfc keyword, this command clears statistics for all VFC interfaces.
If you specify a VFC interface, this command clears statistics for the specified VFC interface.
# Clear statistics for interface VFC 1.
<Sysname> reset counters interface vfc 1
shutdown
Use shutdown to shut down a VFC interface.
Use undo shutdown to bring up a VFC interface.
shutdown
A VFC interface is up.
VFC interface view
# Bring up interface VFC 1.
[Sysname-Vfc1] undo shutdown
FCoE commands
display fcoe
Use display fcoe to display global FCoE configuration.
display fcoe
# Display global FCoE configuration.
  FCoE MAC    : 0000-1234-0202
  FC-MAP      : 0efc25
  FCF Priority: 128
  FKA period  : 8 seconds
FCoE MAC
FCoE MAC address of the switch.
FC-MAP
FC-MAP value.
FCF Priority
System FCF priority.
FKA period
Interval at which a VFC interface sends Discovery Solicitations and unsolicited Discovery Advertisements.
·     fcoe fcmap
·     fcoe fka-adv-period
·     fcoe global fcf-priority
fcoe enable
Use fcoe enable to enable FCoE in a VLAN and map the VLAN to a VSAN.
Use undo fcoe enable to disable FCoE in a VLAN.
fcoe enable [ vsan vsan-id ]
undo fcoe enable
FCoE is disabled in a VLAN.
VLAN view
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command maps the VLAN to a VSAN with the same ID as the VLAN. For VLANs 3840 to 4094, you must specify VSANs to be mapped.
FCoE cannot be enabled in VLAN 1.
Do not enable FCoE in a reserved VLAN. If you enable FCoE in a reserved VLAN, the VFC interfaces assigned to the mapped VSAN as trunk ports cannot come up. For more information about reserved VLANs, see Layer 2—LAN Switching Command Reference.
VSANs are mapped to VLANs on a one-to-one basis.
An FCoE-capable VLAN allows only FCoE traffic. All member ports in an FCoE-capable VLAN are isolated and will not form loops. To prevent FCoE links from being blocked, do not enable STP or other loop detection protocols in an FCoE-enabled VLAN. A Layer 2 protocol enabled in an FCoE-capable VLAN runs based on the topology where all member ports in the FCoE-capable VLAN are isolated at Layer 2.
When you use a VFC interface to transmit packets, the Ethernet interface bound to the VFC interface might allow multiple VLANs. You must enable FCoE in the same VLAN and map the VLAN to the same VSAN on both ends. Then, the packets from the VSAN are tagged with the VLAN tag and transmitted within the VLAN.
# Enable FCoE in VLAN 4 and map VLAN 4 to VSAN 6.
[Sysname] vlan 4
[Sysname-vlan4] fcoe enable vsan 6
fcoe fcf-priority
Use fcoe fcf-priority to set the FCF priority for a VFC interface.
Use undo fcoe fcf-priority to restore the default.
fcoe fcf-priority priority
The FCF priority of a VFC interface is 128.
VFC interface view
priority: Specifies the FCF priority for the VFC interface, in the range of 0 to 255. The smaller the value, the higher the priority.
This command takes effect on only VFC interfaces operating in F mode. You can configure this command on VFC interfaces operating in E mode, but it does not take effect.
The VFC interface FCF priority is used in the fcf priority field in an unsolicited Discovery Advertisement.
An ENode selects the FCF switch with the highest priority from the FCF switches sending Discovery Advertisements and sends a FLOGI request to it for login.
# Set the FCF priority to 12 for interface VFC 1.
[Sysname-Vfc1] fcoe fcf-priority 12
fcoe fcmap
Use fcoe fcmap to set an FC-MAP value.
Use undo fcoe fcmap to restore the default.
fcoe fcmap fc-map
undo fcoe fcmap
The FC-MAP value is 0x0EFC00.
fc-map: Specifies an FC-MAP value in the range of 0x0EFC00 to 0x0EFCFF.
An FC-MAP value identifies an FCoE network. Switches in the same FCoE network must have the same FC-MAP value.
After an FC-MAP value is set, VFC interfaces perform an FIP renegotiation.
# Set the FC-MAP value to 0x0EFCFF.
[Sysname] fcoe fcmap 0efcff
Changing the FC-MAP will flap all VFC interfaces. Continue? [Y/N]:
fcoe fka-adv-period
Use fcoe fka-adv-period to set an FKA advertisement interval.
Use undo fcoe fka-adv-period to restore the default.
fcoe fka-adv-period fka-adv-period
The FKA advertisement interval is 8 seconds.
fka-adv-period: Specifies an FKA advertisement interval value in the range of 4 to 600 seconds.
The FKA advertisement interval determines the length of time the switch takes to detect the disconnection of a virtual link.
A switch uses the following process to maintain the virtual link established with a peer switch:
1.     The switch sends unsolicited Discovery Advertisements every FKA advertisement interval out of its VFC interfaces in E mode.
The FKA advertisement interval value is carried in unsolicited Discovery Advertisements.
2.     After receiving an unsolicited Discovery Advertisement, the peer switch maintains the status of the virtual link and records the FKA advertisement interval value.
If the peer switch fails to receive an unsolicited Discovery Advertisement within 2.5 FKA advertisement intervals, it deletes the virtual link.
A switch uses the following process to maintain the virtual link established with a peer ENode:
3.     The switch sends unsolicited Discovery Advertisements every FKA advertisement interval out of its VFC interfaces in F mode.
4.     After receiving an unsolicited Discovery Advertisement, the peer ENode maintains the status of the virtual link and records the FKA advertisement interval value.
If the peer ENode fails to receive an unsolicited Discovery Advertisement within 2.5 FKA advertisement intervals, it deletes the virtual link.
In addition, the ENode sends keepalive frames to the switch every FKA advertisement interval value. This value is obtained from unsolicited Discovery Advertisements received from the switch. After receiving a keepalive frame, the switch maintains the status of the virtual link. If the switch fails to receive a keepalive frame within 2.5 FKA advertisement intervals, it deletes the virtual link.
When setting the FKA advertisement interval value on an FCF switch, use Table 5 as a reference to avoid service disruption.
Table 5 Recommended values for different application scenarios
Recommended value
Application scenarios
Remarks
Less than 90 seconds
Connected to servers, storage devices, or third-party switches.
According to FC-BB-5, the upper limit of the FKA advertisement interval value is 90 seconds. In this scenario, a single-MPU FCF switch will experience FCoE traffic disruption during an ISSU reboot for the following reasons:
·     The ISSU reboot takes more than 225 (2.5*90) seconds.
·     The peer deletes the virtual link for failing to receive unsolicited Discovery Advertisements within 225 seconds.
60–90 seconds
Active/standby switchover on the switch takes more than 2.5 x 60 seconds because of the amount of FCoE configuration.
ISSU reboot on a dual-MPU switch takes more than 2.5 x 60 seconds because of the amount of FCoE configuration.
For more information about ISSU, see Fundamentals Configuration Guide.
300–600 seconds
ISSU reboot on a single-MPU switch to which no nodes are attached.
During an ISSU reboot on a single-MPU switch, the switch cannot send unsolicited Discovery Advertisements or keepalive frames.
# Set the FKA advertisement interval to 20 seconds.
[Sysname] fcoe fka-adv-period 20
Use fcoe global fcf-priority to set the system FCF priority.
Use undo fcoe global fcf-priority to restore the default.
fcoe global fcf-priority priority
The system FCF priority is 128.
priority: Specifies the system FCF priority in the range of 0 to 255. The smaller the value, the higher the priority.
This command takes effect on all VFC interfaces operating in F mode.
The system FCF priority is used in the fcf priority field in an unsolicited Discovery Advertisement.
# Set the system FCF priority to 12.
[Sysname] fcoe global fcf-priority 12
VSAN commands
Use display vsan port-member to display the member interfaces of a VSAN.
display vsan [ vsan-id ] port-member
vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the member interfaces of each VSAN.
# Display the member interfaces of each VSAN.
<Sysname> display vsan port-member
VSAN 1:
  Access Ports:
  Trunk Ports:
    Vfc1
VSAN 2:
  Access Ports:
  Trunk Ports:
    Vfc4
VSAN 10:
  Access Ports:
  Trunk Ports:
VSAN 100:
  Access Ports:
  Trunk Ports:
    Vfc4              Vfc5           Vfc6
port trunk vsan
Use port trunk vsan to assign a VFC interface to a list of VSANs as a trunk port.
Use undo port trunk vsan to remove a VFC interface from a list of VSANs as a trunk port.
port trunk vsan vsan-id-list
undo port trunk vsan vsan-id-list
A VFC interface is not assigned to any VSANs as a trunk port.
VFC interface view
vsan-id-list: Specifies a space-separated list of up to 10 VSAN items. Each item specifies a VSAN or a range of VSANs in the form of vsan-id1 to vsan-id2. The value for vsan-id2 must be greater than or equal to the value for vsan-id1.
# Assign interface VFC 1 to VSANs 1, 2, 10, and 20 through 100.
[Sysname-Vfc1] port trunk vsan 1 to 2 10 20 to 100
vsan
Use vsan to create a VSAN and enter VSAN view. If the VSAN already exists, this command directly leads you to VSAN view.
Use undo vsan to delete a VSAN.
vsan vsan-id
undo vsan vsan-id
Only the default VSAN (VSAN 1) exists.
You cannot create or delete VSAN 1, because it is the system-default VSAN. You can create VSANs 2 to 3839.
The maximum number of VSANs (including VSAN 1) that can be created is 256.
# Create VSAN 10 and enter its view.
[Sysname] vsan 10
[Sysname-vsan10]
allowed-domain-id
Use allowed-domain-id to configure an allowed domain ID list for a VSAN.
Use undo allowed-domain-id to restore the default.
allowed-domain-id domain-id-list
undo allowed-domain-id domain-id-list
The allowed domain ID list includes domain IDs 1 to 239.
VSAN view
domain-id-list: Specifies a space-separated list of up to 8 domain items. Each item specifies a domain ID or a range of domain IDs in the form of domain-id1 to domain-id2. The value for domain-id2 must be greater than or equal to the value for domain-id1. The value range for the domain-id argument is 1 to 239.
To successfully configure an allowed domain ID list on the principal switch, make sure all assigned and locally configured domain IDs are included in the list. After you configure an allowed domain ID list, the principal switch assigns only domain IDs available in the allowed list.
To successfully configure an allowed domain ID list on a non-principal switch, make sure the runtime domain ID of the switch is included in the allowed list. After you configure an allowed domain ID list on a non-principal switch, the following rules apply:
·     The locally configured domain ID must be included in the allowed list. Otherwise, the domain ID configuration fails.
·     The principal switch must assign a domain ID that is included in the allowed list of the non-principal switch. Otherwise, the non-principal switch refuses the assigned domain ID and isolates its interface connected to the principal switch.
As a best practice, configure the same allowed domain ID list for all switches in a VSAN.
# Configure VSAN 1 to allow domains 3 through 10.
[Sysname] vsan 1
[Sysname-vsan1] allowed-domain-id 3 to 10
display fc domain
Use display fc domain to display the domain information of a VSAN.
display fc domain [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the domain information of all VSANs.
The displayed domain information includes runtime and configuration information of the local switch and runtime information of the principal switch.
# Display the domain information of VSAN 1.
<Sysname> display fc domain vsan 1
Domain Information of VSAN 1:
    Running time information:
        State: Stable
        Switch WWN: 41:6e:64:69:61:6d:6f:21
        Fabric name: 41:6e:64:69:61:6d:6f:21
        Priority: 2
        Domain ID: 100
    Configuration information:
        Domain configure: Enabled
        Domain auto-reconfigure: Disabled
        Priority: 128
        Domain ID: 100 (static)
    Principal switch running time information:
        Priority: 2
    Path               Interface
    Downstream         Vfc1
    Downstream         Vfc2
    Downstream         Vfc4
Table 6 Command output
Running status:
·     Stable—The configuration is finished.
·     Unstable—The configuration is not finished.
Switch WWN
WWN of the local switch.
Fabric name
Name of the fabric.
Priority
Running priority of the local switch.
Domain ID
Runtime domain ID of the local switch.
Configuration of the local switch.
Domain configure
State of the fabric configuration feature:
·     Enabled.
·     Disabled.
State of the automatic reconfiguration feature:
·     Enabled.
·     Disabled.
Fabric name
Fabric name configured on the switch.
Priority
Locally configured priority of the switch.
Domain ID
Locally configured domain ID. The field in the parentheses can be one of the following:
·     static.
·     preferred.
Runtime information of the principal switch.
Priority
Running priority of the principal switch.
Path
Path type of the interface:
·     Upstream—Upstream principal link.
·     Downstream—Downstream principal link.
Local VFC interface.
Use display fc domain-list to display the list of domain IDs dynamically assigned in a VSAN.
display fc domain-list [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the lists of domain IDs dynamically assigned in all VSANs.
For a dynamically built fabric, this command displays the list of domain IDs dynamically assigned in a VSAN and includes the following information:
·     The total number of domains.
·     Mappings between domain IDs and switch WWNs.
# Display the list of domain IDs dynamically assigned in VSAN 1.
<Sysname> display fc domain-list vsan 1
Domain list of VSAN 1:
  Number of domains: 3
  Domain ID    WWN
  0xc8(200)    20:01:00:05:30:00:47:df [Principal]
  0x63(99)     20:01:00:0d:ec:08:60:c1 [Local]
  0x61(97)     50:00:53:0f:ff:f0:10:06
Table 7 Command output
Domain list of VSAN
Domain ID list of the VSAN.
Number of domains
Total number of domains.
WWN
WWN of the switch. Principal indicates a principal switch, and Local indicates a local switch.
display fc ess
Use display fc ess to display the Exchange Switch Support (ESS) negotiation result, including the following information:
·     The capabilities of the local switch after the ESS negotiation.
·     The capabilities of the remote switch after the ESS negotiation.
display fc ess [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the ESS negotiation results of all VSANs.
# Display the ESS negotiation result in VSAN 2.
<Sysname> display fc ess vsan 2
ESS info of VSAN 2:
  Domain: 210
    Directory Server Capability:
      Accept large name server objects: Yes
      Accept small name server objects: No
      Accept large + FC-4 Features name server objects: No
      Accept small + FC-4 Features name server objects: No
      Support receiving ACCept with 0 length: Yes
    Fabric Controller Capability:
     Support receiving the SW_RSCN Request: Yes
    Fabric Configuration Server Capability:
      Support basic configuration services: Yes
      Support platform configuration services: No
      Support topology discovery configuration services: Yes
      Support enhanced configuration services: Yes
    Enhanced Zone Server Capability:
      Support enhanced zoning management: Yes
Table 8 Command output
Domain
Domain ID of the switch.
List of directory server capabilities.
Indicates whether the switch supports accepting large name server objects.
A large name server object contains the symbolic name of the N_Port and the symbolic name of the node in addition to the information of a small name server object.
Indicates whether the switch supports accepting small name server objects.
A small name server object contains only the basic information, and does not contain the symbolic name of the N_Port, the symbolic name of the node, or information about supported FC-4 features.
Indicates whether the switch supports accepting large + FC-4-feature name server objects.
Indicates whether the switch supports accepting small + FC-4-feature name server objects.
Indicates whether the switch supports accepting an ACCEPT reply whose payload is 0.
List of fabric controller capabilities.
Indicates whether the switch supports accepting an SW_RSCN (Registered State Change Notification) request.
display fc login
Use display fc login to display the node login information of VSANs.
display fc login [ vsan vsan-id ] [ count ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the node login information of all VSANs.
count: Displays the total number of logged-in nodes.
# Display the node login information of VSAN 1.
<Sysname> display fc login vsan 1
Interface VSAN FCID     Node WWN                Port WWN
Vfc1      1    0x010000 21:01:00:1b:32:a0:fa:18 21:01:00:1b:32:a0:fa:17
# Display the number of logged-in nodes for VSAN 1.
<Sysname> display fc login vsan 1 count
Total entries: 1
# Display the number of logged-in nodes for each VSAN and the total number of logged-in nodes.
<Sysname> display fc login count
VSAN        Entries
1           1
2           1
Total entries: 2
Table 9 Command output
Interface on the switch connected to the node.
VSAN
VSAN ID.
FCID
FC address assigned by the switch to the node.
Port WWN
WWN of the port connecting the node to the switch.
Entries
Number of logged-in nodes for a VSAN.
Total Entries
Total number of logged-in nodes.
Use display fc name-service database to display the name server database.
display fc name-service database [ vsan vsan-id [ fcid fcid ] ] [ verbose ]
display fc name-service database [ vsan vsan-id ] count
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the name server database information of all VSANs.
fcid fcid: Specifies an FC address in the range of 0x010000 to 0xEFFFFF (hexadecimal). If you do not specify an FC address, this command displays the name server database entries of all FC addresses.
verbose: Displays detailed information about the name service database. If you do not specify this keyword, the command displays brief information about the name server database.
count: Displays the number of name service entries.
# Display brief information about the name server database in VSAN 1.
<Sysname> display fc name-service database vsan 1
VSAN 1:
  FCID     Type               PWWN(vendor)                      FC4-type:feature
  0x030001 0x01(N)            20:00:00:05:30:00:25:a3           SCSI-FCP
Table 10 Command output
FCID
FC address of the N_Port.
Port type registered by the node with the switch:
·     0x00(Unidentified)—No port type is registered.
·     0x01(N)—N_Port, which directly connects to the fabric.
·     0x02(NL)—NL_Port, which connects to the fabric through an arbitrated loop.
·     0x03(F/NL)—F_Port or NL_Port.
·     0x7f(Nx)—N_Port, NL_Port, or F_Port, or NL_Port.
·     0x81(F)—F_Port, which connects to an N_Port.
·     0x82(FL)—FL_Port, which connects to an NL_Port.
·     0x84(E)—E_Port, which connects to an E_Port or B_Port.
·     0x85(B)—B_Port. The ports on a bridge that connect two E_Ports are called B_Ports.
·     0xXX(Unknown)Port types other than the preceding ones.
Typically, only N_Ports and NL_Ports will be registered by a node.
PWWN(vendor)
WWN of the N_Port (name of vendor).
FC4-type:feature
FC4 type feature entry (when this command displays brief information, up to two FC4 type feature entries are displayed):
·     FC4 type—Includes SCSI-FCP, LLC/SNAP, SW_ILS, SNMP, GS3, VI, and NPV.
·     Feature—Includes supporting Initiator, Target, or Initiator/Target.
# Display detailed information about the name service database.
<Sysname> display fc name-service database verbose
VSAN:1     FCID:0x030001
  Port-WWN(vendor): 20:00:00:05:30:00:25:a3
  Node-WWN: 20:00:00:05:30:00:25:9e
  Class: 2,3
  Node-IP-addr: 192.168.0.52
  FC4-types(FC4_features): SCSI-FCP
  Symbolic-port-name:
  Symbolic-node-name:
  Port-type: 0x01(N)
  Fabric-port-WWN: 30:30:30:30:65:33:64:6
  Hard-addr: 0x000000
VSAN:1     FCID:0x030200
  Port-WWN(vendor): 20:00:00:5a:c9:28:c7:01
  Node-WWN: 10:00:00:5a:c9:28:c7:01
  Class: 3
  Node-IP-addr: 192.168.6.171
  FC4-types(FC4_features): NPV
  Symbolic-port-name: NPV-Sysname:Vfc1
  Symbolic-node-name: NPV-Sysname
  Port-type: 0x01(N)
  Fabric-port-WWN: 22:0a:00:05:30:00:26:1e
  Hard-addr: 0x000000
--- Total 2 entries ---
# Display the number of name service entries for VSAN 1.
<Sysname> display fc name-service database vsan 1 count
Total entries: 2
Table 11 Command output
FCID
Port-WWN(vendor)
Node-WWN
WWN of the node.
Class
Class of service.
Node-IP-addr
IP address of the node.
FC4-types(FC4 features)
FC4 type (feature) entries:
Symbolic-port-name
Symbolic name, which is used for describing the N_Port.
Symbolic-node-name
Symbolic name, which is used for describing the node.
Port-type
Fabric-port-WWN
WWN of the F_Port.
Hard-addr
Hardware address of the N_Port.
Total entries
Number of entries in the VSAN.
Use display fc scr-table to display the State Change Registration (SCR) list of N_Ports.
display fc scr-table [ vsan vsan-id ] [ count ]
vsan vsan-id: Displays the SCR list in the specified VSAN. The vsan-id argument is in the range of 1 to 3839. If you do not specify a VSAN, this command displays the SCR lists of all VSANs.
count: Displays the number of SCR entries.
# Display the SCR list.
<Sysname> display fc scr-table
SCR table for VSAN 1:
FCID         REGISTERED FOR
0x1b0300     fabric detected rscns
0x010121     nx_port detected rscns
# Display the number of SCR entries.
<Sysname> display fc scr-table vsan 1 count
Total entries: 2
Table 12 Command output
SCR table for VSAN
SCR list in a VSAN.
FCID
REGISTERED FOR
Type of Registered State Change Notification (RSCN) messages:
·     fabric detected rscnsAccepts all RSCN messages sent by the switches in the fabric.
·     nx_port detected rscnsAccepts all RSCN messages sent by N_Ports.
·     full detected rscnsAccepts all RSCN messages.
Total entries
Number of SCR entries in the VSAN.
Use display fc switch-wwn to display the switch WWN.
# Display the switch WWN.
<Sysname> display fc switch-wwn
Switch WWN is 10:00:00:0d:ec:ff:a3:25
display fc timer
Use display fc timer to display fabric timers.
display fc timer [ distributed-services | error-detect | resource-allocation ] [ vsan vsan-id ]
distributed-services: Displays the distributed service timeout period, in milliseconds.
error-detect: Displays the error detection timeout period, in milliseconds.
resource-allocation: Displays the resource allocation timeout period, in milliseconds.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays global fabric timer information.
If you do not specify the distributed-services, error-detect, or resource-allocation keyword, this command displays all fabric timers.
# Display all the fabric timers for VSAN 1.
<Sysname> display fc timer vsan 1
Timer of VSAN 1:
  Distributed-services timer: 5000 ms
  Error-detect timer:         2000 ms
  Resource-allocation timer:  10000 ms
Use domain auto-reconfigure enable to enable automatic reconfiguration in a VSAN.
Use undo domain auto-reconfigure enable to disable automatic reconfiguration in a VSAN .
Automatic reconfiguration is disabled in a VSAN.
VSAN view
This command takes effect only when the fabric configuration feature is enabled.
A fabric reconfiguration triggers a principal switch selection process.
A disruptive reconfiguration is automatically performed if the domain ID lists overlap when two fabrics are merged.
A nondisruptive reconfiguration is automatically performed when one of the following conditions exists:
·     When two fabrics are merged, the principal switch information of the two fabrics is different, and the domain ID lists are not empty and do not overlap.
·     A principal link in a fabric goes down.
# Enable the automatic reconfiguration feature in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain auto-reconfigure enable
Use domain configure enable to enable the fabric configuration feature in a VSAN.
Use undo domain configure enable to disable the fabric configuration feature in a VSAN.
The fabric configuration feature is enabled in a VSAN.
VSAN view
To dynamically build a fabric, you must enable the fabric configuration feature on switches. After you enable the fabric configuration feature on FCF switches, the switches exchange messages to select the principal switch. Then, the principal switch dynamically assigns domain IDs to all switches in the fabric.
To statically build a fabric, you must disable the fabric configuration feature on switches and manually configure a unique domain ID for each switch. After you disable the fabric configuration feature on FCF switches, the switches will not select a principal switch and cannot obtain domain IDs dynamically.
# Enable the fabric configuration feature in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain configure enable
domain restart
Use domain restart to manually initiate a fabric reconfiguration in a VSAN.
domain restart [ disruptive ]
VSAN view
disruptive: Initiates a disruptive reconfiguration. If you do not specify this keyword, the command initiates a nondisruptive reconfiguration.
A fabric reconfiguration can be disruptive or nondisruptive.
·     Disruptive reconfiguration—Floods Reconfigure Fabric (RCF) frames throughout the fabric and notifies all switches to perform a disruptive reconfiguration. During the reconfiguration procedure, each switch clears all data and performs renegotiation, and data transmission in the fabric is disrupted.
·     Nondisruptive reconfiguration—Floods Build Fabric (BF) frames throughout the fabric and notifies all switches to perform a nondisruptive reconfiguration. During the reconfiguration procedure, each switch tries to save the last running data for its domain ID to remain unchanged. Thus, data transmission in the fabric is not disrupted.
For fabric settings that do not take effect immediately (for example, switch priority), you can perform a disruptive reconfiguration to make them take effect.
# Manually initiate a disruptive reconfiguration in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain restart disruptive
The command may cause traffic interruption. Continue? [Y/N]:y
domain-id
Use domain-id to configure a domain ID for the switch in a VSAN.
Use undo domain-id to restore the default.
domain-id domain-id { preferred | static }
undo domain-id
The domain ID is 0 preferred in a VSAN.
VSAN view
domain-id: Specifies a domain ID in the range of 1 to 239.
preferred: Specifies the domain ID as preferred.
static: Specifies the domain ID as static.
The upper-layer protocol identifies only the WWNs, but FCF switches use domain IDs to route and forward packets. Domain IDs are assigned on a per-VSAN basis and have a default value of 0, which cannot distinguish switches. Therefore, you must statically configure or dynamically assign domain IDs for FCF switches.
In the static domain ID assignment method, the ID type configuration does not affect the assignment result.
In the dynamic domain ID assignment method, the principal switch assigns a domain ID to each switch in the fabric.
·     If a non-principal switch fails to get the configured preferred domain ID from the principal switch, it accepts any other domain ID assigned by the principal switch.
·     If a non-principal switch fails to get the configured static domain ID, it does not accept any other domain ID and isolates the upstream principal link.
As a best practice, configure domain IDs of the same type for all switches in a VSAN.
# Configure static domain ID 55 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain-id 55 static
Non-disruptive reconfiguration or isolating the switch may be performed. Continue? [Y/N]:
fabric-name
Use fabric-name to set a fabric name in a VSAN.
Use undo fabric-name to restore the default.
fabric-name name
undo fabric-name
The fabric name is the WWN of the switch.
VSAN view
name: Specifies a fabric name, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
An FCF switch supports assigning a fabric name to each VSAN, in the same format as the WWN (a 64-bit address).
Set fabric names only when you build a fabric statically. You must set the same fabric name in a VSAN on all switches in the fabric. In a dynamically built fabric, each VSAN uses the WWN of the principal switch as the fabric name.
# Set the fabric name to 10:11:12:13:14:15:16:17 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] fabric-name 10:11:12:13:14:15:16:17
Use fc domain rcf-reject to configure a VFC interface to reject the RCF requests received in a VSAN.
Use undo fc domain rcf-reject to restore the default.
fc domain rcf-reject vsan vsan-id
undo fc domain rcf-reject vsan vsan-id
A VFC interface does not reject the RCF requests received in a VSAN.
VFC interface view
In a stable fabric, to avoid unnecessary disruptive reconfigurations, you can configure an interface to reject the RCF requests received in a VSAN. With this feature, when the interface receives an RCF request in the VSAN, the switch replies with a reject message and isolates the VFC interface.
# Configure interface VFC 1 to reject the RCF requests received in VSAN 1.
[Sysname-Vfc1] fc domain rcf-reject vsan 1
Use fc name-service auto-discovery to enable SCSI-FCP information autodiscovery in a VSAN.
Use undo fc name-service auto-discovery to disable SCSI-FCP information autodiscovery in a VSAN.
SCSI-FCP information autodiscovery is enabled in a VSAN.
VSAN view
In some situations, for example, when a node logs out and then logs back in, the node does not register SCSI-FCP support. As a result, the node does not have a Feature value. This might cause communication failure between the node and other nodes.
This feature enables the switch to automatically obtain SCSI-FCP support and the Feature value by sending a PRLI packet to the node that is logging in. Then, the switch stores the SCSI-FCP information in the name service database.
After this feature is enabled, nodes with older-model HBAs might not actively register name service information with the switch.
# Enable SCSI-FCP information autodiscovery in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fc name-server auto-discovery
Use fc timer distributed-services to set the global distributed service timeout period.
Use undo fc timer distributed-services to restore the default.
fc timer distributed-services value
The global distributed service timeout period is 5000 milliseconds.
value: Specifies the distributed service timeout period in the range of 5000 to 10000 milliseconds.
The distributed service timeout period can be set in system view or VSAN view.
The setting in system view takes effect on all VSANs. The setting in VSAN view takes effect only on the current VSAN.
If you set the distributed service timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global distributed service timeout period to 6000 milliseconds.
[Sysname] fc timer distributed-services 6000
Use fc timer error-detect to set the global error detection timeout period.
Use undo fc timer error-detect to restore the default.
fc timer error-detect value
The global error detection timeout period is 2000 milliseconds.
value: Specifies the error detection timeout period in the range of 1000 to 10000 milliseconds.
The error detection timeout period can be set in system view or VSAN view.
If you set the error detection timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global error detection timeout period to 6000 milliseconds.
[Sysname] fc timer error-detect 6000
timer error-detect
Use fc timer resource-allocation to set the global resource allocation timeout period.
Use undo fc timer resource-allocation to restore the default.
fc timer resource-allocation value
The global resource allocation timeout period is 10000 milliseconds.
value: Specifies the resource allocation timeout period in the range of 5000 to 10000 milliseconds.
The resource allocation timeout period can be set in system view or VSAN view.
If you set the resource allocation timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global resource allocation timeout period to 6000 milliseconds.
[Sysname] fc timer resource-allocation 6000
Use fc wwn default-fc4-type to configure the default FC4 information for a node.
Use undo fc wwn default-fc4-type to delete the default FC4 information of a node.
fc wwn wwn-value default-fc4-type { type-value feature feature-map | scsi-fcp feature { feature-map | both | initiator | target } }
undo fc wwn wwn-value default-fc4-type { type-value | scsi-fcp }
The default FC4 information for a node is not configured.
wwn-value: Specifies an N_Port by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal).
type-value: Specifies a supported FC4-Type by its value in the range of 0 to 255. The FC4-Type field is 256 bits, each of which represents an FC4-Type. If a bit is set to 1, the FC4-Type that the bit represents is supported. Only one bit can be set to 1 at the same time.
scsi-fcp: Specifies the supported FC4-Type as SCSI-FCP, which has a type-value of 8.
feature feature-map: Specifies the Feature value for the supported FC4-Type. The value range for feature-map is 0 to 15. The Feature field is 4 bits, each of which represents a Feature. If a bit is set to 1, the Feature that the bit represents is supported. Multiple bits can be set to 1 at the same time. For example, if the value is set to 15, the node supports four Features of the FC4-Type. If the value is set to 0, the node supports none of the four Features. When you specify supported FC4-Type as SCSI-FCP, you can configure the following keywords:
·     initiator: Specifies support for the initiator Feature, which has a feature-map of 2.
·     target: Specifies support for the target Feature, which has a feature-map of 1.
·     both: Specifies support for both initiator and target Features, which has a feature-map of 3.
The switch records the default FC4 information in the name service database for a node when the following conditions exist:
·     The node does not register FC4 information.
·     The switch fails to obtain SCSI-FCP information from the node.
The switch replaces the default FC4 information with the registered FC4 information or obtained SCSI-FCP information when one of the following events occurs:
·     A node registers FC4 information.
·     The switch obtains the SCSI-FCP information.
You can configure only one combination of FC4-Type and Feature at a time.
# Configure the default FC4 information for the node with WWN 00:00:00:11:22:33:44:55.
[Sysname] fc wwn 00:00:00:11:22:33:44:55 default-fc4-type scsi-fcp feature target
[Sysname] fc wwn 00:00:00:11:22:33:44:55 default-fc4-type 9 feature 7
priority
Use priority to set the switch priority in a VSAN.
Use undo priority to restore the default.
priority value
undo priority
The switch priority is 128 in a VSAN.
VSAN view
value: Specifies the switch priority in the range of 1 to 254. A smaller value indicates a higher priority.
The priority is set on a per-VSAN basis, and one FCF switch can have different priorities in different VSANs. The FCF switch with the highest priority in a VSAN will become the principal switch in that VSAN.
To make the switch priority setting take effect, perform a disruptive reconfiguration by using the domain restart disruptive command.
# Set the switch priority to 64 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] priority 64
domain restart
Use rscn aggregation enable to enable RSCN aggregation in a VSAN.
Use undo rscn aggregation enable to disable RSCN aggregation in a VSAN.
RSCN aggregation is disabled in a VSAN.
VSAN view
For multiple change events occurring within the RSCN aggregation timer interval, RSCN aggregation places the FC addressees of multiple nodes with changes into a single RSCN. This feature reduces the number of RSCNs sent to the concerned registered nodes.
As a best practice, enable RSCN aggregation and set the same RSCN aggregation timer value on all switches in a VSAN.
# Enable RSCN aggregation in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] rscn aggregation enable
Use rscn aggregation timer to set the RSCN aggregation timer.
Use undo rscn aggregation timer to restore the default.
rscn aggregation timer time
The RSCN aggregation timer is 2000 milliseconds.
VSAN view
time: Specifies the RSCN aggregation timer value in the range of 100 to 2000 milliseconds.
The RSCN aggregation timer takes effect only when RSCN aggregation is enabled.
# Set the RSCN aggregation timer to 1500 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] rscn aggregation timer 1500
Use snmp-agent trap enable fc-fabric to enable SNMP notifications for the fabric module.
Use undo snmp-agent trap enable fc-fabric to disable SNMP notifications for the fabric module.
snmp-agent trap enable fc-fabric [ domain-id-change | fabric-change ] *
undo snmp-agent trap enable fc-fabric [ domain-id-change | fabric-change ] *
All SNMP notifications for the fabric module are disabled.
domain-id-change: Specifies domain ID changes.
fabric-change: Specifies fabric changes.
If you do not specify any keywords, this command enables all SNMP notifications for the fabric module.
After you enable SNMP notifications for domain ID changes, the switch generates a notification when its domain ID changes in a VSAN. The notification includes the VSAN ID, the switch WWN, and the new domain ID.
After you enable SNMP notifications for fabric changes, the switch generates a notification when it sends or receives a BF or RCF frame for fabric reconfiguration. The notification includes the VSAN ID for fabric reconfiguration.
Generated notifications are sent to the SNMP module. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for domain ID changes.
[Sysname] snmp-agent trap enable fc-fabric domain-id-change
# Enable SNMP notifications for fabric changes.
[Sysname] snmp-agent trap enable fc-fabric fabric-change
Use snmp-agent trap enable fc-name-service to enable SNMP notifications for the name service module.
Use undo snmp-agent trap enable fc-name-service to disable SNMP notifications for the name service module.
snmp-agent trap enable fc-name-service [ login| logout ] *
undo snmp-agent trap enable fc-name-service [ login| logout ] *
All SNMP notifications for the name service module are disabled.
login: Specifies node login.
logout: Specifies node logout.
If you do not specify any keywords, this command enables all SNMP notifications for the name service module.
After you enable SNMP notifications for node login or logout, the switch generates a notification when a node registers or deregisters its name service information with the switch. The notification includes the VSAN ID, the switch WWN, and the WWN of the N_Port.
# Enable SNMP notifications for node login.
[Sysname] snmp-agent trap enable fc-name-service login
Use timer distributed-services to set the distributed service timeout period for a VSAN.
Use undo timer distributed-services to restore the default.
The distributed service timeout period is 5000 milliseconds.
VSAN view
# Set the distributed service timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer distributed-services 6000
timer error-detect
Use timer error-detect to set the error detection timeout period for a VSAN.
Use undo timer error-detect to restore the default.
The error detection timeout period is 2000 milliseconds.
VSAN view
# Set the error detection timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer error-detect 6000
Use timer resource-allocation to set the resource allocation timeout period for a VSAN.
Use undo timer resource-allocation to restore the default.
The resource allocation timeout period is 10000 milliseconds.
VSAN view
# Set the resource allocation timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer resource-allocation 6000
wwn area-port-id
Use wwn area-port-id to bind the WWN of an N_Port to an FC address in a VSAN.
Use undo wwn area-port-id to delete a WWN-to-FC address binding.
wwn wwn-value area-port-id area-port-id-value
undo wwn wwn-value area-port-id
The WWN of an N_Port is not bound to any FC address.
VSAN view
wwn-value: Specifies the WWN of the N_Port, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
area-port-id-value: Specifies the area ID and port ID in the format of xxxx, where x is a hexadecimal number. The first two digits indicate the area ID, and the last two digits indicate the port ID.
The switch assigns the FC address bound to an N_Port when the N_Port requests an FC address. However, if the N_Port has been assigned another FC address or the FC address has been assigned to another N_Port, the binding fails.
The WWN of an N_Port can be bound to only one FC address and vice versa.
# In VSAN 1, bind the N_Port (WWN is 33:e8:00:05:30:00:16:df) to an FC address (area ID is ab and port ID is 12).
[Sysname] vsan 1
[Sysname-vsan1] wwn 33:e8:00:05:30:00:16:df area-port-id ab12
FC routing and forwarding commands
display fc exchange
Use display fc exchange to display the FC exchange entries.
In standalone mode:
display fc exchange { link | protocol } [ slot slot-number ]
display fc exchange link verbose [ slot slot-number [ exid exid ] ]
In IRF mode:
display fc exchange { link | protocol } [ chassis chassis-number slot slot-number ]
display fc exchange link verbose [ chassis chassis-number slot slot-number [ exid exid ] ]
link: Displays link exchange entries.
protocol: Displays protocol exchange entries.
verbose: Displays detailed information about link exchange entries.
exid exid: Displays link exchange entries for an exchange ID in the range of 0 to 65534. If you do not specify an exchange ID, this command displays all link exchange entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays exchange entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays exchange entries for the global active MPU. (In IRF mode.)
The exchange is a basic concept of FC. All data frames and control frames are transmitted based on the exchange. An exchange indicates one data exchange between communication entities and can contain multiple bidirectional packet exchanges.
An exchange pair (initiating exchange and responding exchange) must be created for each data exchange. Service classes that provide reliable transmission services (classes 1, 2, and 6) perform packet acknowledgment, error detection, and packet retransmission based on the exchange pair.
Exchanges include the following categories:
·     Protocol exchange—Created only at the server end based on the protocol number and VSAN ID and used to monitor connection establishment.
·     Link exchange—Created at both ends based on the exchange ID and used for packet exchange.
# (In standalone mode.) Display the protocol exchange entries.
<Sysname> display fc exchange protocol slot 1
 Local_ID:EXID     Remote_ID:EXID     State       Slot  Protocol
 0x000000:65535    0x000000:65535     LISTEN      1     6
# (In IRF mode.) Display the protocol exchange entries.
<Sysname> display fc exchange protocol chassis 1 slot 2
 Local_ID:EXID     Remote_ID:EXID     State       Chassis Slot  Protocol
 0x000000:65535    0x000000:65535     LISTEN      1       2     13
# (In standalone mode.) Display the link exchange entries.
<Sysname> display fc exchange link slot 2
 0x060501:1024     0x010001:1025      ESTABLISHED 2     8
# (In IRF mode.) Display the link exchange entries.
<Sysname> display fc exchange link chassis 3 slot 5
 0x060501:1024     0x010001:1025      ESTABLISHED 3       5     11
# Display detailed information about the link exchange entries.
<Sysname> display fc exchange link verbose slot 1
 slot: 1
 protocol: 8
 connection info: Local = 0x090801:1155 ,  Remote = 0x050001:1089
 PCB flags: 0x2
 FC Class: FC_CLASS_F
 connection state: ESTABLISHED
 VSAN ID: 25
Table 13 Command output
Local_ID:EXID/Local
FC address and exchange ID of the local end.
This field is ignored for a protocol exchange.
Remote_ID:EXID/Remote
FC address and exchange ID of the peer end.
State/connection state
Connection state of the FC exchange:
·     PREPARE—The protocol exchange is successfully bound, or the link exchange is waiting for the response packet.
·     LISTEN—The protocol exchange is monitoring the connection.
·     ESTABLISHED—The connection has been established.
·     ABTS—An ABTS was sent due to a connection timeout or error, and the ABTS ACK is being expected.
·     BA_ACC—An ABTS was received, an BA_ACC is replied, and an ACC ACK is being expected.
·     ABTS_ACK—An ABTS ACK was received, and a BA_ACC is being expected.
·     CLOSED—The connection is closed.
Slot/slot
Card where the FC exchange is created.
Protocol/protocol
FC protocol number.
PCB flags
FC exchange state flags:
·     0x1—The value 0 indicates the sending end, and 1 indicates the replying end.
·     0x2—The value 0 means there is no initiative, and 1 means there is initiative.
·     0x4—The value 1 indicates the first packet of the exchange.
·     0x8—The value 1 indicates that the exchange is waiting to be aged.
FC Class
FC connection service level (FC_CLASS_3 requires no ACK):
·     FC_CLASS_1.
·     FC_CLASS_2.
·     FC_CLASS_3.
·     FC_CLASS_F.
·     FC_CLASS_6.
display fc fib
Use display fc fib to display the FC FIB entries.
display fc fib [ fcid [ mask-length ] ] vsan vsan-id
fcid: Specifies a destination FC address in the range of 0x000000 to 0xFFFFFF (hexadecimal).
mask-length: Specifies the mask length for the destination address, in the range of 0 to 24.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 4095.
The switch looks up the VSAN ID and FC address in the FC FIB for the outgoing interface.
If you specify both a destination FC address and the mask length, this command displays FC FIB entries for the specified FC address and mask length.
If you specify only a destination FC address, this command displays FC FIB entries for the specified FC address according to the longest matching rule.
If you do not specify a destination FC address or the mask length, this command displays all FC FIB entries.
# Display all the FC FIB entries in VSAN 18.
<Sysname> display fc fib vsan 18
FC FIB information in VSAN 18:
  Destination count: 6
  FIB entry count: 7
  Destination/Mask              Interface
  0x030100/16                   Vfc1
  0x030100/16                   Vfc2
  0x030100/24                   Vfc3
  0xfffc01/24                   InLoop0
  0xfffffa/24                   InLoop0
  0xfffffc/24                   InLoop0
  0xfffffd/24                   InLoop0
# Display the FC FIB entries for the specified FC address according to the longest matching rule.
<Sysname> display fc fib 030100 vsan 18
  Destination count: 1
  FIB entry count: 1
  0x030100/24                   Vfc3
# Display the FC FIB entries for the specified FC address and mask length.
<Sysname> display fc fib 030100 16 vsan 18
  FIB entry count: 2
  0x030100/16                   Vfc1
  0x030100/16                   Vfc2
Table 14 Command output
Destination count
Number of destination addresses.
FIB entry count
Number of FIB entries, including equal-cost routes.
Destination/Mask
Destination address/mask length.
Outgoing interface.
display fc routing-table
Use display fc routing-table to display the FC routing table.
display fc routing-table [ vsan vsan-id ] [ statistics | verbose ]
display fc routing-table vsan vsan-id fcid [ mask | mask-length ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 4095. If you do not specify a VSAN, this command displays routing information of all VSANs.
fcid: Specifies the destination FC address for static FC routes, in the range of 0x010000 to 0xFFFFFF (hexadecimal).
mask: Specifies a hexadecimal mask for the FC address. This argument is used together with the fcid argument. The value of this argument can be 0xFF0000, 0xFFFF00, or 0xFFFFFF. If you do not specify a hexadecimal mask, this command displays the routing information for the FC address fcid with masks 0xFF0000, 0xFFFF00, and 0xFFFFFF.
mask-length: Specifies the mask length for the FC address. This argument is used together with the fcid argument. The value of this argument can be 8, 16, or 24. If you do not specify the mask length, this command displays the routing information for the FC address fcid with mask length values 8, 16, and 24.
statistics: Displays the statistics for the FC routing table.
verbose: Displays detailed information about the FC routing table.
The routing table stores routes discovered by various routing protocols. You can use this command to display brief information, detailed information, and statistics about the routing table.
If you do not specify the statistics or verbose keyword, this command displays brief information about the FC routing table.
The brief information contains information about only active routes. The detailed information contains information about both active and inactive routes.
# Display brief information about all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5
Routing Table: VSAN 5
  Destinations : 5          Routes : 8
  Destination/mask   Protocol   Preference   Cost     Interface
  0x040000/8         FSPF       20           100      Vfc10
  0x040000/8         FSPF       20           100      Vfc20
  0x040000/8         FSPF       20           100      Vfc30
  0x040000/8         FSPF       20           100      Vfc40
  0xfffc01/24        DIRECT     0            0        InLoop0
  0xfffffa/24        DIRECT     0            0        InLoop0
  0xfffffc/24        DIRECT     0            0        InLoop0
  0xfffffd/24        DIRECT     0            0        InLoop0
# Display detailed information about all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5 verbose
  Destinations : 5          Routes : 5
  Destination/mask: 0x120000/8
          Protocol: STATIC
        Preference: 10
              Cost: 0
         Interface: Vfc1
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffc01/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffa/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffc/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffd/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
Table 15 Command output
VSAN
VSAN number.
Destination/mask
FC address/mask.
Protocol
Protocol type:
·     DIRECT—Direct routes.
·     STATIC—Static routes.
·     FSPFFSPF routes.
Preference
Route preference.
Cost
Route cost.
Outgoing interface.
Route state: Active or Inactive.
Age
Lifetime of the route in the routing table, in the format of XXhXXmXXs.
# Display the statistics for all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5 statistics
  Protocol  route       active      added       deleted
  DIRECT    4           4           4           0
  STATIC    1           1           1           0
  FSPF      0           0           0           0
  Total     5           5           5           0
Table 16 Command output
VSAN
VSAN number.
Protocol
Protocol type:
·     FSPF—FSPF routes.
route
Number of routes of the specified protocol type.
active
Number of active routes of the specified protocol type.
added
Number of added routes of the specified protocol type.
deleted
Number of deleted routes of the specified protocol type.
Total
Total number of routes.
fc route-static
display fspf graceful-restart
Use display fspf graceful-restart to display FSPF GR status information.
display fspf graceful-restart [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays FSPF GR status information for all VSANs.
The SPF GR status information includes the following details:
·     Whether GR restarter is enabled.
·     Whether GR helper is enabled.
·     Number of GR restarters being restarted.
·     Number of GR helpers assisting in restarting the local switch.
# Display FSPF GR status information.
<Sysname> display fspf graceful-restart
Graceful-restart capability      : Disable
Helper capability                : Enable
Graceful-restart period          : 120 seconds
FSPF graceful restart information of VSAN 1:
  Number of neighbors under helper : 0
  Number of restarting neighbors   : 0
FSPF graceful restart information of VSAN 2:
Table 17 Command output
Indicates whether GR restarter capability is enabled: Enable or Disable.
Helper capability
Indicates whether GR helper capability is enabled: Enable or Disable.
Number of neighbors acting as GR helpers.
Number of neighbors acting as GR restarters.
·     fspf graceful-restart
·     fspf graceful-restart helper
·     fspf graceful-restart interval
display fspf lsdb
Use display fspf lsdb to display FSPF link state database (LSDB) information.
display fspf lsdb [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays LSDB information for all VSANs.
The FSPF LSDB information includes the total number of link state records (LSRs) and information about each LSR.
# Display FSPF LSDB information.
<Sysname> display fspf lsdb
FSPF LSDB information of VSAN 1(01):
  Total LSR count: 2
    FSPF Link State Database for Domain 01
      LSR Type                  : 1
      LSR Age                   : 0
      LSR Incarnation number    : 0x80000008
      LSR Checksum              : 0x7deb
      Number of links           : 1
      NbrDomainID    IfIndex    NbrIfIndex    LinkType    Cost
      2              0x68       0x68          1           265
    FSPF Link State Database for Domain 02
      LSR Type                  : 1
      LSR Age                   : 6
      LSR Checksum              : 0x7dea
      Number of links           : 1
      1              0x68       0x68          1           265
Table 18 Command output
LSDB information for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
LSDB information for a domain ID (switch).
LSR Type
LSR type, which can only be Switch Link Record (0x01).
LSR instance number.
NbrDomainID
Neighbor domain ID.
IfIndex
Outgoing interface index of the local switch.
NbrIfIndex
Neighbor interface index.
Link Type
Link type:
·     0x01—Point-to-point.
·     0xF0-FF—Vendor-defined.
Cost
Link cost.
display fspf neighbor
Use display fspf neighbor to display FSPF neighbor information.
display fspf neighbor [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information about all FSPF neighbors.
The FSPF neighbor information includes the following details:
·     Neighbor domain ID.
·     Neighbor interface index.
·     Outgoing interface index of the local switch.
·     Remaining dead interval of the neighbor.
·     Neighbor state.
# Display FSPF neighbor information.
<Sysname> display fspf neighbor
FSPF neighbor information of VSAN 1(01):
  Interface   NbrDomain   IfIndex   NbrIfIndex   Dead Time   State
  Vfc1        2           0x68      0x68         00:01:06    Full
Table 19 Command output
FSPF neighbor information for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
Interface name of the local switch.
NbrDomain
Neighbor domain ID in decimal.
IfIndex
NbrIfIndex
Dead Time
Remaining dead interval of the neighbor. If no hello packet is received from the neighbor after this interval, the neighbor state changes to Init.
Neighbor state:
·     Down—The neighbor does not start negotiation.
·     Init—The neighbor has started negotiation.
·     DB_Exchange—The neighbor has been discovered.
·     DB_Wait—The local switch has sent the LSR.
·     DB_Ack_Wait—The neighbor has sent the LSR.
·     Full—Synchronization is complete.
display fspf statistics
Use display fspf statistics to display FSPF statistics.
display fspf statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the FSPF statistics for all VSANs.
FSPF statistics contain global statistics and interface statistics.
·     Global statisticsContain the current number of SPF calculations, number of error packets, total number of packets received and sent.
·     Interface statisticsContain the total number of packets received and sent on each interface.
# Display FSPF statistics.
<Sysname> display fspf statistics
FSPF statistics of VSAN 1(01):
  SPF computing count: 6
  Statistics counters:
    Bad packet       : 0      Neighbor unknown   : 0
    Timer mismatch   : 0      Neighbor state low : 0
    Bad LSR          : 0
  Packet statistics:
    Type          Input        Output
    HELLO         50           50
    LSU           5            5
    LSA           4            4
  Interface Vfc1 statistics:
    Type          Input        Output
    HELLO         50           50
    LSU           5            5
    LSA           4            4
Table 20 Command output
FSPF statistics for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
SPF computing count
Number of SPF calculations.
Packet statistics on the interface.
Bad packet
Number of error packets.
Timer mismatch
Number of packets whose hello or dead interval does not match that of the neighbor.
Bad LSR
Number of error LSRs.
Neighbor unknown
Number of packets received from unknown neighbors.
Neighbor state low
Number of LSUs and LSAs received in Init state.
Packet type: Hello, LSU, or LSA.
Input
Number of packets received.
Output
Number of packets sent.
reset fspf counters
fc route-static
Use fc route-static to configure a static FC route.
Use undo fc route-static to delete a static FC route.
fc route-static fcid { mask | mask-length } interface-type interface-number [ cost cost-value ]
undo fc route-static fcid { mask | mask-length } interface-type interface-number
No static FC route exists.
VSAN view
fcid: Specifies the destination FC address of the static FC route, in the range of 0x010000 to 0xFFFFFF (hexadecimal).
mask: Specifies a hexadecimal mask for the FC address. This argument is used together with the fcid argument. The value of this argument can only be 0xFF0000.
mask-length: Specifies the mask length for the FC address. This argument is used together with the fcid argument. The value of this argument can only be 8.
interface-type interface-number: Specifies the outgoing interface of the static FC route, which must be an existing VFC interface on the FCF switch.
cost cost-value: Specifies the cost of the route, in the range of 0 to 65535. The default is 0.
Static routes are manually configured by an administrator. After an administrator configures a static route, an FC frame to the specified destination is forwarded along the static route.
In a simple network, static routes are enough for implementing network connectivity. When the network fails or the network topology changes, you must manually modify the static routes.
Static routes support equal-cost routes. When you configure multiple equal-cost static routes to the same destination but with different outgoing interfaces, equal-cost routes are generated.
# Add a static FC route with the following parameters:
·     The destination FC address is 0x010000.
·     The mask length is 8.
·     The outgoing interface is VFC 4.
·     The cost is 20.
[Sysname] vsan 5
[Sysname-vsan5] fc route-static 010000 8 vfc 4 cost 20
fspf cost
Use fspf cost to set the FSPF cost for a VFC interface in a VSAN.
Use undo fspf cost to restore the default.
fspf cost value vsan vsan-id
undo fspf cost vsan vsan-id
The FSPF cost for a VFC interface in a VSAN is 100.
VFC interface view
value: Specifies the FSPF cost in the range of 1 to 65535.
Each link has a cost. The route selection algorithm uses this value to determine the best route. The smaller the interface FSPF cost, the smaller the link cost.
# Set the FSPF cost to 1000 for interface VFC 1 in VSAN 4.
[Sysname] interface vfc 1
[Sysname-Vfc1] fspf cost 1000 vsan 4
fspf dead-interval
Use fspf dead-interval to set the dead interval for a VFC interface in a VSAN.
Use undo fspf dead-interval to restore the default.
fspf dead-interval value vsan vsan-id
undo fspf dead-interval vsan vsan-id
The dead interval for a VFC interface in a VSAN is 80 seconds.
VFC interface view
value: Specifies the dead interval in the range of 2 to 65535 seconds.
After two switches establish a neighbor relationship, they send hello packets at the hello interval to each other to maintain the neighbor relationship. The dead interval specifies the time during which at least one hello packet must be received from a neighbor before the neighbor is considered nonexistent and is removed.
The dead interval must be greater than the hello interval and must be the same at the two ends of a link.
# Set the dead interval to 100 seconds for interface VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf dead-interval 100 vsan 4
fspf hello-interval
fspf enable
Use fspf enable to enable FSPF in a VSAN.
Use undo fspf enable to disable FSPF in a VSAN.
fspf enable
undo fspf enable
FSPF is enabled after a VSAN is created.
VSAN view
FSPF-related features work in a VSAN only after you enable FSPF in the VSAN.
# Enable FSPF in VSAN 4.
[Sysname] vsan 4
[Sysname-vsan4] fspf enable
Use fspf graceful-restart to enable FSPF GR.
Use undo fspf graceful-restart to disable FSPF GR.
FSPF GR is disabled.
FSPF graceful restart (GR) ensures nonstop forwarding of traffic by backing up FSPF configuration information in one of the following situations:
·     A protocol restart (for example, the FSPF process restart triggered by the process command).
·     An active/standby switchover.
GR involves the following roles:
·     GR restarter—GR-capable device where a protocol restart or active/standby switchover occurs.
·     GR helper—The GR restarter's neighboring device that assists in the GR process.
# Enable FSPF GR.
[Sysname] fspf graceful-restart
·     display fspf graceful-restart
Use fspf graceful-restart helper to enable FSPF GR helper.
Use undo fspf graceful-restart helper to disable FSPF GR helper.
FSPF GR helper is enabled.
The switch can assist the GR restarter in completing the GR process only after FSPF GR helper is enabled on the switch.
# Enable FSPF GR helper.
[Sysname] fspf graceful-restart helper
Use fspf graceful-restart interval to set the maximum FSPF GR interval.
Use undo fspf graceful-restart interval to restore the default.
fspf graceful-restart interval interval-value
The maximum FSPF GR interval is 120 seconds.
interval-value: Specifies the maximum FSPF GR interval in the range of 40 to 1800 seconds.
If the GR restarter fails to complete the GR process within the maximum FSPF GR interval, it immediately exits the GR process.
# Set the maximum FSPF GR interval to 100 seconds.
[Sysname] fspf graceful-restart interval 100
fspf hello-interval
Use fspf hello-interval to set the hello interval for a VFC interface in a VSAN.
Use undo fspf hello-interval to restore the default.
fspf hello-interval value vsan vsan-id
undo fspf hello-interval vsan vsan-id
The hello interval for a VFC interface in a VSAN is 20 seconds.
VFC interface view
value: Specifies the hello interval in the range of 1 to 65534 seconds.
The hello interval specifies the time between the hello packets sent periodically by the switch to discover and maintain neighbor relationships.
The hello interval must be smaller than the dead interval and must be the same at the two ends of a link.
# Set the hello interval to 10 seconds for interface VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf hello-interval 10 vsan 4
fspf dead-interval
fspf min-ls-arrival
Use fspf min-ls-arrival to set the minimum LSR arrival interval for a VSAN.
Use undo fspf min-ls-arrival to restore the default.
fspf min-ls-arrival value
The minimum LSR arrival interval for a VSAN is 1 second.
VSAN view
value: Specifies the minimum LSR arrival interval in the range of 0 to 60 seconds.
The minimum LSR arrival interval specifies the interval between received LSR updates in a VSAN. Any LSR updates that arrive before this interval expires are dropped. This helps avoid frequent SPF calculations caused by LSDB updating.
# Set the minimum LSR arrival interval to 10 seconds for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf min-ls-arrival 10
fspf min-ls-interval
Use fspf min-ls-interval to set the minimum LSR refresh interval for a VSAN.
Use undo fspf min-ls-interval to restore the default.
fspf min-ls-interval value
The minimum LSR refresh interval for a VSAN is 5 seconds.
VSAN view
value: Specifies the minimum LSR refresh interval in the range of 1 to 60 seconds.
The minimum LSR refresh interval specifies the interval at which LSRs are refreshed. To reduce SPF calculations and LSR flooding in a fabric caused by frequent LSR refreshing, the switch cannot refresh local LSRs within this interval.
# Set the minimum LSR refresh interval to 10 seconds for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf min-ls-interval 10
fspf retransmit-interval
Use fspf retransmit-interval to set the LSR retransmission interval for a VFC interface in a VSAN.
Use undo fspf retransmit-interval to restore the default.
fspf retransmit-interval value vsan vsan-id
undo fspf retransmit-interval vsan vsan-id
The LSR retransmission interval for a VFC interface in a VSAN is 5 seconds.
VFC interface view
value: Specifies the LSR retransmission interval in the range of 1 to 65535 seconds.
The LSR retransmission interval specifies the time to wait for an LSR acknowledgment from the neighbor before retransmitting the LSR.
# Set the LSR retransmission interval to 10 seconds for interface VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf retransmit-interval 10 vsan 4
fspf silent
Use fspf silent to disable FSPF for a VFC interface in a VSAN.
Use undo fspf silent to enable FSPF for a VFC interface in a VSAN.
fspf silent vsan vsan-id
undo fspf silent vsan vsan-id
FSPF is enabled on a VFC interface in a VSAN.
VFC interface view
With FSPF enabled, a VFC interface can participate in the SPF calculation. To avoid SPF calculations on an interface, disable FSPF on the interface.
# Disable FSPF for interface VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf silent vsan 4
fspf spf-hold-time
Use fspf spf-hold-time to set the shortest SPF calculation interval in a VSAN.
Use undo fspf spf-hold-time to restore the default.
fspf spf-hold-time value
The shortest SPF calculation interval is 0 seconds in a VSAN.
VSAN view
value: Specifies the shortest SPF calculation interval in the range of 0 to 60 seconds.
When the LSDB changes, SPF calculations occur, which consume CPU resources. To prevent frequent SPF calculations from consuming too many CPU resources, you can set the shortest SPF calculation interval.
The shortest SPF calculation interval defines the minimum interval between two consecutive SPF calculations. Setting a small value means that FSPF responds quickly to fabric changes by recalculating routes in a VSAN. A small value consumes more CPU resources.
# Set the shortest SPF calculation interval to 10 seconds in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf spf-hold-time 10
reset fspf counters
Use reset fspf counters to clear FSPF statistics.
reset fspf counters [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command clears the FSPF statistics for all VSANs.
# Clear FSPF statistics for VSAN 2.
<Sysname> reset fspf counters vsan 2
FC zone commands
delete zone database all
Use delete zone database all to delete zone database information.
VSAN view
You can delete the zone database for the specified VSAN, including all zone sets, zones, and zone aliases, but not the active zone set.
# Delete zone database information for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] delete zone database all
This operation will delete all information of the zone database except active zone set. Continue?[Y/N]:
display zone
Use display zone to display zone information.
display zone [ [ name zone-name ] vsan vsan-id ]
name zone-name: Specifies a zone by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
Table 21 Special characters
Caret
Dollar sign
Minus sign
Underscore
_
If you specify both a zone and a VSAN, this command displays information about the specified zone in the specified VSAN.
If you specify only a VSAN, this command displays information about all zones in the specified VSAN.
If you do not specify a zone or a VSAN, this command displays information about all zones in all VSANs.
# Display information about all zones in all VSANs.
<Sysname> display zone
VSAN 1:
  zone name z1
    fcid 0x111111 initiator
    fcid 0x222222 target
    pwwn 11:11:11:11:22:22:22:22
    fwwn 02:0e:30:30:33:33:32:35
  zone name z2
    fcid 0x111111
    zone-alias name za1
    fcid 0x333333 initiator
VSAN 2:
VSAN 3:
Table 22 Command output
fcid
FC address of a zone member.
pwwn
pWWN of a zone member.
fwwn
fWWN of a zone member.
initiator
target
Role of the zone member. If no role is indicated, the member has both roles.
·     member (zone view)
·     zone clone
·     zone name
·     zone rename
display zone member
Use display zone member to display parent information for a zone member.
display zone member { fcid fcid | fwwn fwwn | pwwn pwwn | zone-alias zone-alias-name } [ vsan vsan-id ]
fcid fcid: Specifies a zone member by its FC address, in the format of xxxxxx, where x is a hexadecimal number.
fwwn fwwn: Specifies a zone member by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
pwwn pwwn: Specifies a zone member by its pWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
zone-alias zone-alias-name: Specifies a zone alias name, a case-sensitive string of 1 to 64 characters. A zone alias name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays parent information for zone members in all VSANs.
You can use this command to display parent information for a zone member specified by its FC address, pWWN, fWWN, or zone alias.
Parent information contains the following:
·     Zones and zone aliases to which the specified zone member belongs.
·     Zones to which the zone aliases belong.
·     VSANs to which the zones and zone aliases belong.
If a zone alias is not assigned to any zones, only the parent VSANs are displayed for the zone alias.
# Display parent information for zone member with FC address 010000 in VSAN 1.
<Sysname> display zone member fcid 010000 vsan 1
fcid 0x010000
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
# Display parent information for zone member with pWWN 11:22:33:44:55:66:77:88 in all VSANs.
<Sysname> display zone member pwwn 11:22:33:44:55:66:77:88
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
  VSAN 3:
    zone z1
# Display parent information for zone member with fWWN 12:22:33:44:55:66:77:88 in all VSANs.
<Sysname> display zone member fwwn 12:22:33:44:55:66:77:88
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
  VSAN 3:
 zone z1
# Display parent information for a zone alias named za1 in VSAN 1.
<Sysname> display zone member zone-alias za1 vsan 1
zone-alias za1
  VSAN 1:
    zone z1
    zone z2
Table 23 Command output
fcid
FC address of the zone member for which parent information is displayed.
pwwn
pWWN of the zone member for which parent information is displayed.
fwwn
fWWN of the zone member for which parent information is displayed.
·     member (zone alias view)
display zone statistics
Use display zone statistics to display zone packet statistics.
display zone statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays zone packet statistics for all VSANs.
# Display zone packet statistics for VSAN 2.
<Sysname>display zone statistics vsan 2
Zone statistics of VSAN 2:
Message type      Sent          Received
Merge Request     19            23
Merge Accept      17            18
Merge Reject      6             1
Change Request    144           18
Change Accept     0             0
Change Reject     0             0
Table 24 Command output
Merge Request
Number of Merge Request packets.
Merge Accept
Number of Merge Accept packets.
Merge Reject
Number of Merge Reject packets.
Change Request
Number of Distribution Request packets.
Change Accept
Number of Distribution Accept packets.
Change Reject
Number of Distribution Reject packets.
reset zone statistics
display zone status
Use display zone status to display the zoning configuration and status.
display zone status[ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the zoning configuration and status in all VSANs.
The zoning configuration and status include the following information:
·     Zoning mode.
·     Default zone policy.
·     Distribution and merge type.
·     Zone database information (numbers of existing zone sets, zones, and zone aliases).
·     Zoning status.
# Display the zoning configuration and status in all VSANs.
<Sysname> display zone status
VSAN 1:
  Mode: basic
  Default zone: deny
  Distribute: active only
  Hard-zoning: enabled
  Full zoning database:
    Zonesets: 10, Zones: 20, Zone-aliases: 0
  Status: merging
VSAN 2:
  Mode: enhanced
  Default zone: permit
  Status: distributing
Table 25 Command output
Mode
Zoning mode: basic or enhanced.
Default zone
Default zone policy:
·     deny—Deny members in the default zone from accessing each other.
·     permit—Allow members in the default zone to access each other.
Distribute
Distribution and merge type:
·     active only—Incomplete distribution and merge.
·     full—Complete distribution and merge.
In enhanced zoning mode, zone distribution and merge are not affected by the distribution and merge type. The distribution and merge type is not displayed for the enhanced zoning mode.
Hard-zoning
Indicates whether hard zoning is enabled or disabled:
·     enabled—Hard zoning is in effect.
·     disabled (Administratively)—Hard zoning is not in effect because it is manually disabled.
·     disabled (No enough hardware resource)—Hard zoning is not in effect because hardware resources are insufficient.
Full Zoning Database
Zone database information, including the numbers of zone sets, zones, and zone aliases in a VSAN.
Status
Zoning status:
·     merging—Zone merge is in progress.
·     distributing—Zone distribution is in progress.
·     FreeNeither zone merge nor zone distribution is in progress.
·     zone default-zone permit
·     zoneset distribute full
display zone-alias
Use display zone-alias to display zone alias information.
display zone-alias [ [ name zone-alias-name ] vsan vsan-id ]
name zone-alias-name: Specifies a zone alias by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
If you specify both a zone alias and a VSAN, this command displays information about the specified zone alias in the specified VSAN.
If you specify only a VSAN, this command displays information about all zone aliases in the specified VSAN.
If you do not specify a zone alias or a VSAN, this command displays information about all zone aliases in all VSANs.
# Display information about all zone aliases in all VSANs.
<Sysname> display zone-alias
VSAN 1:
  zone-alias name za1
  zone-alias name za2
    fcid 0x111111
    fwwn 12:11:11:11:22:22:22:22
VSAN 2:
  zone-alias name za1
Table 26 Command output
fcid
pwwn
fwwn
initiator
target
·     zone-alias clone
·     zone-alias name
·     zone-alias rename
display zoneset
Use display zoneset to display zone set information.
display zoneset [ [ name zoneset-name ] vsan vsan-id ]
name zoneset-name: Specifies a zone set by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
If you specify both a zone set and a VSAN, this command displays information about the specified zoneset in the specified VSAN.
If you specify only a VSAN, this command displays information about all zonesets in the specified VSAN.
If you do not specify a zone set or a VSAN, this command displays information about all zone sets in all VSANs.
# Display information about all zone sets in all VSANs.
<Sysname> display zoneset
VSAN 1:
  zoneset name zs1
    zone name z1
      fcid 0x111111
      fcid 0x222222
    zone name z2
      fcid 0x111111
      zone-alias name za1
        fcid 0x111112
  zoneset name zs2
    zone name z1
VSAN 2:
VSAN 3:
  zoneset name zs1
    zone name z1
Table 27 Command output
fcid
pwwn
·     member (zone set view)
·     zoneset clone
·     zoneset name
·     zoneset rename
display zoneset active
Use display zoneset active to display information about the active zone set.
display zoneset active [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information about active zone sets in all VSANs.
A VSAN can have only one active zone set.
The following rules apply to the command output:
·     Zone members are displayed in the order of FC address, pWWN, and fWWN. Zone members specified by the same identifier are displayed in ascending order of ASCII codes corresponding to the identifier values.
·     For a zone member that exists in the local name service database, this command prefixes an asterisk (*) to the related line.
¡     If a zone member is specified by its pWWN, the switch performs the following operations:
-     Queries the associated FC address of the zone member from the name service database and displays the FC address.
-     Appends the pWWN enclosed in brackets ([]) to the FC address.
¡     If a zone member is specified by its fWWN, the switch displays FC addresses of all N_Ports that log in through the F_Port. Each FC address is followed by the fWWN enclosed in brackets ([]).
·     For a zone member that does not exist in the local name service database, only the configuration content is displayed.
·     Zone members cannot be displayed by zone alias in the active zone set. If a zone in the activated zone set has members with a zone alias, the non-overlapping N_Port members in the zone alias are added to the zone.
·     If members of the default zone are allowed to access each other, this command displays valid members in the default zone by FC address. Valid members in the default zone are members that have registered with the name service database and are not part of the active zone set.
# Display information about the active zone sets in all VSANs.
<Sysname> display zoneset active
  VSAN 1:
    zoneset name zs1
      zone name z1
        *fcid 0x222222
        *fcid 0x111111 [pwwn 11:11:11:11:11:11:11:11]
      zone name z2
        fcid 0x123456
        pwwn 11:11:11:11:11:11:11:12
        *fcid 0x333333 [pwwn 33:33:33:33:33:33:33:33]
      zone name #default-zone#
        *fcid 0x20abcd
        *fcid 0xabcdef
  VSAN 2:
  VSAN 3:
    zoneset name zs1
      zone name z1
        fcid 0x123456
        *fcid 0x222221 [fwwn 22:22:22:22:22:22:22:22]
        *fcid 0x222222 [fwwn 22:22:22:22:22:22:22:22]
        *fcid 0x222223 [fwwn 22:22:22:22:22:22:22:22]
        fwwn aa:bb:cc:dd:ee:ff:00:11
# Display information about the active zoneset in VSAN 1.
<Sysname> display zoneset active vsan 1
  VSAN 1:
    zoneset name zs1
      zone name z1
        *fcid 0x222222
      zone name z2
        fcid 0x123456
      zone name #default_zone#
        *fcid 0x20abcd
        *fcid 0xabcdef
Table 28 Command output
*fcid
FC address of a zone member that exists in the local name service database.
fcid
FC address of a zone member that does not exist in the local name service database.
pwwn
fwwn
zoneset activate name
member (zone view)
Use member to add a member to a zone.
Use undo member to remove a member from a zone.
member{ { fcid fcid | fwwn fwwn | pwwn pwwn } [ initiator | target ] | zone-alias zone-alias-name }
undo member { fcid fcid | fwwn fwwn | pwwn pwwn | zone-alias zone-alias-name }
No member exists in a new zone.
Zone view
fcid fcid: Specifies a member by its FC address, in the format of xxxxxx, where x is a hexadecimal number.
fwwn fwwn: Specifies a member F_Port by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. Adding an F_Port to a zone adds all N_Ports that log in through the F_Port to that zone.
pwwn pwwn: Specifies a member by its pWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
initiator: Specifies a member as an initiator. If you do not specify the initiator or target keyword, the member acts as both an initiator and a target.
target: Specifies a member as a target. If you do not specify the initiator or target keyword, the member acts as both an initiator and a target.
zone-alias zone-alias-name: Specifies an existing zone alias by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
You can also use this command to change the role (initiator, target, or both) of a member.
If the role of a member is specified by using the same identifier (FC address, pWWN, fWWN, or zone alias) multiple times, the role of the member is the role most recently specified.
If the role of a member is specified by using different identifiers multiple times, the role of the member is the union of the specified roles. For example, if a member is specified as an initiator by using its FC address and specified as a target by using its pWWN, the member acts as both an initiator and a target.
The role of a member can be configured only in enhanced zoning mode and takes effect only when the Pairwise feature is enabled.
# Create a zone named z1 and enter its view.
[Sysname] vsan 1
[Sysname-vsan1] zone name z1
[Sysname-vsan1-zone-z1]
# Add an N_Port with FC address 010000 to zone z1 as an initiator.
[Sysname-vsan1-zone-z1] member fcid 010000 initiator
# Add an N_Port with pWWN 01:02:03:04:05:06:07:08 to zone z1 as a target.
[Sysname-vsan1-zone-z1] member pwwn 01:02:03:04:05:06:07:08 target
# Change the role of N_Port with pWWN 01:02:03:04:05:06:07:08 back to both initiator and target.
# Add an F_Port with fWWN 08:07:06:05:04:03:02:01 to zone z1 as both an initiator and a target.
[Sysname-vsan2-zone-z1] member fwwn 08:07:06:05:04:03:02:01
# Add zone alias za1 (existing) to zone z1.
[Sysname-vsan1-zone-z1] member zone-alias za1
·     display zone
·     display zone member
·     pairwise-zoning enable
·     zone name
·     zone-alias name
Use member to add a member to a zone alias.
Use undo member to remove a member from a zone alias.
member{ fcid fcid | fwwn fwwn | pwwn pwwn } [ initiator | target ]
undo member{ fcid fcid | fwwn fwwn | pwwn pwwn }
No member exists in a new zone alias.
Zone alias view
fwwn fwwn: Specifies a member F_Port by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. Adding an F_Port to a zone alias adds all N_Ports that log in through the F_Port to that zone alias.
You can also use this command to change the role of a member.
# Create a zone alias named za1 and enter its view.
[Sysname] vsan 1
[Sysname-vsan1] zone-alias name za1
[Sysname-vsan1-zone-alias-za1]
# Add an N_Port with FC address 010000 to zone alias za1 as an initiator.
[Sysname-vsan1-zone-alias-za1] member fcid 010000 initiator
# Add an N_Port with pWWN 01:02:03:04:05:06:07:08 to zone alias za1 as a target.
[Sysname-vsan1-zone-alias-za1] member pwwn 01:02:03:04:05:06:07:08 target
# Add an F_Port with fWWN 08:07:06:05:04:03:02:01 to zone alias za1 as both an initiator and a target.
[Sysname-vsan2-zone-alias-za1] member fwwn 08:07:06:05:04:03:02:01
·     display zone-alias
·     zone-alias name
Use member to add a zone to a zone set.
Use undo member to remove a zone from a zone set.
member zone-name
undo member zone-name
No zone exists in a zone set.
Zone set view
zone-name: Specifies an existing zone by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
# Create a zone named z1.
[Sysname] vsan 1
[Sysname-vsan1-zone-z1] quit
# Create a zone set named zs1 and enter its view.
[Sysname] zoneset name zs1
[Sysname-vsan1-zoneset-zs1]
# Add zone z1 to zone set zs1.
[Sysname-vsan1-zoneset-zs1] member z1
·     display zoneset
·     zone name
·     zoneset name
Use pairwise-zoning enable to enable the Pairwise feature for a zone.
Use undo pairwise-zoning enable to restore the default.
The Pairwise feature is disabled for a zone.
Zone view
This feature is supported only in enhanced zoning mode.
The Pairwise feature runs on a per-zone basis. For the Pairwise feature to take effect, you must reactivate the active zone set after enabling the Pairwise feature.
The following roles are defined for zone members:
·     Initiator—Typically a server.
·     Target—Typically a storage device.
You can specify the role of a member as an initiator, a target, or both when adding the member. A member can have different roles in different zones.
When the Pairwise feature is disabled for a zone, member roles do not take effect in that zone.
When the Pairwise feature is enabled for a zone:
·     An initiator member can access target members.
·     A target member can access initiator members.
·     A member acting as both an initiator and a target can access both target members and initiator members.
The Pairwise feature status is distributed to the entire fabric when you configure the zoneset activate or zoneset distribute command.
# Enable the Pairwise feature for zone z1.
[Sysname] vsan 2
[Sysname-vsan2] zone name z1
[Sysname-vsan2-zone-z1] pairwise-zoning enable
·     zoneset activate
Use reset zone statistics to clear zone packet statistics.
reset zone statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command clears zone packet statistics for zones in all VSANs.
# Clear zone packet statistics for VSAN 2.
<Sysname> reset zone statistics vsan 2
snmp-agent trap enable fc-zone
Use snmp-agent trap enable fc-zone to enable SNMP notifications for the zone module.
Use undo snmp-agent trap enable fc-zone to disable SNMP notifications for the zone module.
snmp-agent trap enable fc-zone [ activation-completed | defaultzone-change | hardzone-change | merge-failed | merge-succeeded ] *
undo snmp-agent trap enable fc-zone [ activation-completed | defaultzone-change | hardzone-change | merge-failed | merge-succeeded ] *
All SNMP notifications for the zone module are disabled.
activation-completed: Enables SNMP notifications for zone set activation or deactivation.
defaultzone-change: Enables SNMP notifications for default zone policy changes.
hardzone-change: Enables SNMP notifications for hard zoning status changes.
merge-failed: Enables SNMP notifications for merge failures.
merge-succeeded: Enables SNMP notifications for merge successes.
If you do not specify any keywords, this command enables all SNMP notifications for the zone module.
After you enable SNMP notifications for the zone module, the switch generates notifications for important events of the zone module and sends the notifications to the SNMP module. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for default zone policy changes.
[Sysname] snmp-agent trap enable fc-zone defaultzone-change
zone clone
Use zone clone to create a zone by copying an existing zone.
zone clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone to be copied, a case-sensitive string of 1 to 64 characters. A source zone name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
dest-name: Specifies the name of the destination zone, a case-sensitive string of 1 to 64 characters. A destination zone name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
# Create a zone named z2 by copying z1.
[Sysname-vsan1] zone clone z1 z2
·     display zone
·     zone name
Use zone default-zone permit to allow members in the default zone to access each other.
Use undo zone default-zone permit to deny members in the default zone from accessing each other.
Members in the default zone cannot access each other.
VSAN view
In enhanced zoning mode, the switch distributes the default zone policy with other zone data. In basic zoning mode, you must manually configure a consistent default zone policy across the fabric.
When the switch performs a zoning mode switchover, it also distributes the default zone policy with other zone data.
In enhanced zoning mode, a zone merge requires that the default zone policy is the same on all participating switches. Otherwise, the merge fails, and the links between the switches are isolated.
# Allow members in the default zone to access each other.
[Sysname] vsan 1
[Sysname-vsan1] zone default-zone permit
·     display zone status
·     zone mode enhanced
·     zoneset activate
zone hard-zoning enable
Use zone hard-zoning enable to enable hard zoning in a VSAN.
Use undo zone hard-zoning enable to disable hard zoning in a VSAN.
Hard zoning is enabled in a VSAN.
VSAN view
Soft zoning is always in effect. Hard zoning takes effect only when the hardware resources are sufficient for deploying zone rules.
To improve the security for a VSAN, you can enable hard zoning for the VSAN. After hard zoning is enabled for a VSAN, the system begins to deploy all zone rules of the VSAN.
When soft zoning can meet the access control requirements of a VSAN, you can disable hard zoning for the VSAN to save the hardware resources. After hard zoning is disabled for a VSAN, the system clears the hardware zone rules already deployed for the VSAN and stops deploying new zone rules.
In enhanced zoning mode, the switch distributes hard zoning status with other zone data. In basic zoning mode, you must manually configure hard zoning to ensure consistency across the fabric.
To view the hard zoning status, use the display zone status command.
Do not configure this command when the switch is merging or distributing zones.
# Disable hard zoning in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] undo zone hard-zoning enable
display zone status
zone merge-control restrict
Use zone merge-control restrict to set the merge control mode to Restrict.
Use undo zone merge-control restrict to restore the default.
The merge control mode is Allow.
VSAN view
This command is supported only in enhanced zoning mode.
Two merge control modes are available: Restrict and Allow. For more information about the Restrict and Allow merge control modes, see FCoE Configuration Guide.
In enhanced zoning mode, the merge control mode affects the result of a merge operation. Also, a merge operation can succeed only when the merge control mode is the same on both participating switches. If the merge operation fails, the link connecting the participating switches is isolated.
To ensure a consistent merge control mode across the fabric, use the zone activate or zone distribute command after you configure this command.
# Set the merge control mode to Restrict for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] zone merge-control restrict
# Set the merge control mode to Allow for VSAN 2.
[Sysname-vsan2] undo zone merge-control restrict
·     zoneset activate
zone mode enhanced
Use zone mode enhanced to enable the enhanced zoning mode in a VSAN.
Use undo zone mode enhanced to restore the default.
zone mode enhanced
The basic zoning mode is enabled in a VSAN.
VSAN view
A zoning mode switchover causes a zone distribution to ensure zoning mode consistency across the fabric. You can switch from basic zoning to enhanced zoning only if the following conditions are met:
·     All switches in the fabric support the enhanced zoning mode.
·     No invalid static routes exist in the fabric.
After enhanced zoning is enabled on a switch, the switch checks ESS negotiation results for enhanced zoning support of other switches.
The switch performs ESS negotiation with all switches that appear in its routing table as destinations, including unreachable destinations in invalid static routes. The switch assumes that unreachable destinations do not support enhanced zoning.
After you change the zoning mode, the switch distributes the change to the entire fabric. If the distribution fails, the system prints a log message, and the change takes effect only on the local switch. In this case,  to ensure zoning mode consistency across the fabric, manually trigger a complete distribution.
For a switchover from enhanced zoning to basic zoning, if the size of the active zone set exceeds the system limit in basic zoning mode, the switchover fails.
# Enable the enhanced zoning mode in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] zone mode enhanced
The zoning database in this switch would be distributed throughout the fabric. Continue? [Y/N]:y
zone name
Use zone name to create a zone and enter its view. If the zone has been created, this command leads you to the zone view directly.
Use undo zone name to delete a zone.
zone name zone-name
undo zone name zone-name
VSAN view
zone-name: Specifies a zone name, a case-sensitive string of 1 to 64 characters. A zone name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
display zone
zone rename
Use zone rename to rename a zone.
zone rename old-name new-name
VSAN view
old-name: Specifies the name of the zone to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
new-name: Specifies the new zone name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
# Rename zone z1 as z2.
[Sysname-vsan1] zone rename z1 z2
·     display zone
·     zone name
zone-alias clone
Use zone-alias clone to copy a zone alias.
zone-alias clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone alias to be copied, a case-sensitive string of 1 to 64 characters. A source zone alias name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
dest-name: Specifies the name of the destination zone alias, a case-sensitive string of 1 to 64 characters. A destination zone alias name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
# Create a zone alias named za1.
[Sysname] vsan 1
[Sysname-vsan1-zone-alias-za1] quit
# Create a zone alias named za2 by copying zone alias za1.
[Sysname-vsan1] zone-alias clone za1 za2
·     zone-alias name
zone-alias name
Use zone-alias name to create a zone alias and enter its view. If the zone alias has been created, this command leads you to the zone alias view directly.
Use undo zone-alias name to delete a zone alias.
zone-alias name zone-alias-name
undo zone-alias name zone-alias-name
VSAN view
zone-alias-name: Specifies the zone alias name, a case-sensitive string of 1 to 64 characters. A zone alias name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
display zone-alias
zone-alias rename
Use zone-alias rename to rename a zone alias.
zone-alias rename old-name new-name
VSAN view
old-name: Specifies the name of the zone alias to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
new-name: Specifies the new zone alias name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
# Rename zone alias za1 as za2.
[Sysname-vsan1] zone-alias rename za1 za2
·     zone-alias name
zoneset activate
Use zoneset activate to activate a zone set and distribute it to the entire fabric.
Use undo zoneset activate to delete the active zone set and distribute the deletion to the entire fabric.
zoneset activate name zoneset-name
VSAN view
name zoneset-name: Specifies the zone set to be activated by its name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
Each VSAN can have multiple zone sets. However, only one zone set can be effective at a time. It is called the active zone set. The active zone set must contain at least one N_Port member and determines access control over N_Ports.
In basic zoning mode, if the size of the zone set to be activated exceeds the system limit, the activation fails. In either basic or enhanced zoning mode, the system prints a log message if the activation fails. To ensure a consistent active zone set across the fabric, reactivate the zone set.
In basic zoning mode, the distribution type specified by using the zoneset distribute full command applies to distribution operations triggered by the zoneset activate command.
[Sysname] vsan 1
# Add an N_Port with the FC address as 010000 to zone z1.
# Create a zone set named zs1.
[Sysname-vsan1] zoneset name zs1
[Sysname-vsan1-zoneset-zs1] quit
# Activate zone set zs1 and distribute it to the entire fabric.
[Sysname-vsan1] zoneset activate name zs1
·     display zoneset active
zoneset clone
Use zoneset clone to create a zone set by copying an existing zone set.
zoneset clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone set to be copied, a case-sensitive string of 1 to 64 characters. A source zone set name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
dest-name: Specifies the name of the destination zone set, a case-sensitive string of 1 to 64 characters. A destination zone set name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
# Create a zone set named zs1 by copying zone set zs2.
[Sysname-vsan1] zoneset clone zs1 zs2
·     display zoneset
·     zoneset name
zoneset distribute
Use zoneset distribute to trigger a one-time complete distribution, distributing both the active zone set and zone database.
zoneset distribute
VSAN view
After activating a zone set by using the zoneset activate command, you can modify the zone database configuration. The zoneset distribute command distributes the active zone set and the modified zone database to the entire fabric without changing the active zone set.
If the distribution fails, the system prints a log message. To ensure zone data consistency across the fabric, perform a new distribution.
# Trigger a complete distribution.
[Sysname] vsan 1
[Sysname-vsan1] zoneset distribute
Use zoneset distribute full to set the zone distribution and merge type to complete.
Use undo zoneset distribute full to restore the default.
The zone distribution and merge type is incomplete.
VSAN view
This command can be configured only in basic zoning mode. In enhanced zoning mode, the zone distribution and merge type is always complete, and this command is not supported.
Complete distribution (or merge) distributes (or merges) both the active zone set and zone database. Incomplete distribution (or merge) distributes (or merges) only the active zone set.
The set distribution type applies to distribution operations triggered by the zoneset activate command instead of the zoneset distribute command.
The set merge type applies to all merge operations.
# Set the zone distribution and merge type to complete.
[Sysname] vsan 1
[Sysname-vsan1] zoneset distribute full
·     zoneset activate
zoneset name
Use zoneset name to create a zone set and enter its view. If the zone set has been created, this command leads you to the zone set view directly.
Use undo zoneset name to delete a zone set.
zoneset name zoneset-name
undo zoneset name zoneset-name
VSAN view
zoneset-name: Specifies the zone set name, a case-sensitive string of 1 to 64 characters. A zone set name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
display zoneset
zoneset rename
Use zoneset rename to rename a zone set.
zoneset rename old-name new-name
VSAN view
old-name: Specifies the name of the zone set to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
new-name: Specifies the new zone set name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special characters (see Table 21). It must start with a letter.
[Sysname] vsan 1
# Rename zone set zs1 as zs2.
[Sysname-vsan1] zoneset rename zs1 zs2
·     display zoneset
·     zoneset name
FIP snooping commands
display fip-snooping enode
Use display fip-snooping enode to display ENode information obtained by the Transit switch.
display fip-snooping enode [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays ENode information for all VLANs.
# Display ENode information obtained by the Transit switch.
<Sysname> display fip-snooping enode
VLAN 2:
Interface   ENode WWN                ENode MAC
FGE1/0/1    21:01:00:1b:32:a0:fa:18  000c-2999-eacd
Table 29 Command output
Ethernet interface connecting the Transit switch to the ENode.
ENode MAC
FCoE MAC address of the ENode.
display fip-snooping fcf
Use display fip-snooping fcf to display FCF switch information obtained by the Transit switch.
display fip-snooping fcf [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays FCF switch information for all VLANs.
# Display FCF switch information obtained by the Transit switch.
<Sysname> display fip-snooping fcf
VLAN 3:
Interface   FCF MAC        FCF WWN                 Fabric Name             ENode
FGE1/0/1    000c-2999-eacd 66:66:66:63:66:64:61:30 41:6e:64:69:61:6d:6f:21 1
FGE1/0/2    000c-2999-eaad 66:66:66:63:66:64:61:31 41:6e:64:69:61:6d:6f:22 2
Table 30 Command output
Ethernet interface connecting the Transit switch to the FCF switch.
FCF MAC
FCoE MAC address of the FCF switch.
ENode
Number of ENodes attached to an FCF switch.
display fip-snooping flushing-rules
Use display fip-snooping flushing-rules to display the FIP snooping rules that are being flushed.
display fip-snooping flushing-rules [ enode | fcf ] [ vlan vlan-id ]
enode: Displays the ENode FIP snooping rules that are being flushed.
fcf: Displays the FCF FIP snooping rules that are being flushed.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays the FIP snooping rules that are being flushed for all VLANs.
Only the FIP snooping rules that have been flushed can filter FCoE frames. FIP snooping rules that are being flushed cannot filter FCoE frames.
If you do not specify either enode or fcf, this command displays both ENode and FCF FIP snooping rules that are being flushed.
# Display the FIP snooping rules that are being flushed.
<Sysname> display fip-snooping flushing-rules
VLAN 2:
  FCF flushing-rules information:
    Interface   Source MAC/Mask      Destination MAC/Mask
    FGE1/0/1    0000-1234-0212/48    0efc-0034-0111/24
  ENode flushing-rules information:
    FGE1/0/2    0efc-0034-0202/48    0000-1234-0101/48
VLAN 5:
    FGE1/0/3    0000-1234-2212/48    0efc-0034-2111/24
Table 31 Command output
Ethernet interface on the Transit switch.
display fip-snooping rules
Use display fip-snooping rules to display the FIP snooping rules that have been flushed.
In standalone mode:
display fip-snooping rules [ enode | fcf ] [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display fip-snooping rules [ enode | fcf ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
enode: Displays the ENode FIP snooping rules that have been flushed.
fcf: Displays the FCF FIP snooping rules that have been flushed.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays the FIP snooping rules that have been flushed for all VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the FIP snooping rules that have been flushed on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the FIP snooping rules that have been flushed on all cards of all IRF member devices. (In IRF mode.)
If you do not specify the enode or fcf keyword, this command displays both ENode and FCF FIP snooping rules that have been flushed.
# Display the FIP snooping rules that have been flushed.
<Sysname> display fip-snooping rules slot 1
Slot 1:
  VLAN 2:
    FCF rules information:
      Interface   Source MAC/Mask     Destination MAC/Mask   Context
      FGE1/0/1    0000-1234-0202/48   0efc-0034-0101/24      ffffffff
    ENode rules information:
      FGE1/0/2    0efc-0034-0102/48   0000-1234-0201/48      ffffffff
  VLAN 4:
      FGE1/0/3   0000-1234-1202/48    0efc-0034-1101/24      ffffffff
Table 32 Command output
Context
Driver context.
display fip-snooping sessions
Use display fip-snooping sessions to display information about FIP snooping sessions (connections between ENodes and FCF switches).
display fip-snooping sessions [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about FIP snooping sessions for all VLANs.
# Display information about FIP snooping sessions.
<Sysname> display fip-snooping sessions
VLAN 2:
FCF MAC         ENode MAC       VN_Port MAC     VN_Port WWN
0000-1234-0202  0000-1234-0100  0efc-00ae-0002  41:6e:64:69:61:6d:6f:21
Table 33 Command output
FCF MAC
ENode MAC
VN_Port MAC
MAC address of a VN_Port.
fip-snooping enable
Use fip-snooping enable to enable FIP snooping in a VLAN.
Use undo fip-snooping enable to disable FIP snooping in a VLAN.
fip-snooping enable
FIP snooping is disabled in a VLAN.
VLAN view
To enable a VLAN on a Transit switch to process FCoE frames and FIP frames, enable FIP snooping for the VLAN.
# Enable FIP snooping in VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] fip-snooping enable
fip-snooping fc-map
Use fip-snooping fc-map to set an FC-MAP value for a VLAN.
Use undo fip-snooping fc-map to restore the default.
fip-snooping fc-map fc-map
The FC-MAP value for a VLAN is 0x0EFC00.
VLAN view
fc-map: Specifies an FC-MAP value in the range of 0x0EFC00 to 0x0EFCFF.
You can use the fcoe fcmap command to set the FC-MAP value in a frame sent out of an FCF switch. You can use the fip-snooping fc-map command to set an FC-MAP value for a VLAN on a Transit switch.
When an Ethernet interface in the FIP snooping VLAN receives a frame from the FCF switch, the following rules apply:
·     If the FC-MAP value in the incoming frame is the same as the value set for the FIP snooping VLAN, the Ethernet interface forwards the frame.
·     If the FC-MAP value in the incoming frame is different from the value set for the FIP snooping VLAN, the Ethernet interface drops the frame.
# Set the FC-MAP value to 0x0EFCFF for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan 10] fip-snooping fc-map 0efcff
Changing the FC-MAP will flap all interfaces. Continue[Y/N]?
fcoe fcmap
fip-snooping port-mode
Use fip-snooping port-mode to configure the mode of an Ethernet interface.
Use undo fip-snooping port-mode to restore the default.
fip-snooping port-mode { enode | fcf }
An Ethernet interface operates in ENode mode.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
enode: Specifies the ENode mode.
fcf: Specifies the FCF mode.
Ethernet interfaces on a Transit switch can operate in ENode mode or FCF mode.
·     An Ethernet interface connected to an ENode must be configured to operate in ENode mode.
·     An Ethernet interface connected to an FCF switch must be configured to operate in FCF mode.
# Configure interface FortyGigE 1/0/2 to operate in FCF mode.
[Sysname] interface fortygige 1/0/2
[Sysname-FortyGigE1/0/2] fip-snooping port-mode fcf
FCS commands
fcs discovery start
Use fcs discovery start to start a topology discovery in VSANs.
fcs discovery start [ age interval ] vsan vsan-list
age interval: Specifies the aging time for the topology discovery information, in the range of 300 to 86400 seconds. The default is 900 seconds.
vsan vsan-list: Specifies a VSAN by its ID or a range of VSANs in the form of vsan-id to vsan-id. The value range for the vsan-id argument is 1 to 3839.
# Start a topology discovery in VSAN 1 through VSAN 100.
[Sysname] fcs discovery start vsan 1 to 100
·     display fcs database
·     display fcs discovery status
·     display fcs ie
·     display fcs port
fcs discovery stop
Use fcs discovery stop to stop the topology discovery in VSANs.
fcs discovery stop vsan vsan-list
# Stop the topology discovery in VSAN 1 through VSAN 100.
[Sysname] fcs discovery stop vsan 1 to 100
fcs discovery start
Use display fcs discovery status to display the topology discovery status.
display fcs discovery status [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command display the topology discovery status in all VSANs.
# Display the topology discovery status in all VSANs.
<Sysname> display fcs discovery status
VSAN    Discovery Status
1       inProgress
2       completed
3       localOnly
·     fcs discovery start
·     fcs discovery stop
Use display fcs database to display the local FCS database information, including IE attributes and port attributes.
display fcs database [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command display the FCS database information in all VSANs.
# Display the FCS database information in all VSANs.
<Sysname> display fcs database
FCS Local Database in VSAN 1:
  IE WWN                   : 10:00:00:11:22:00:01:01
  Domain ID                : 0x01
  Management address list  : snmp://192.168.6.100
                             snmp://192.168.0.100
  Fabric name              : 10:01:00:11:22:00:01:01
  Logical name             : IE-Sysname1
  Information list         : H3C#H3C S12510-X#Version 7.1.045, Ess 1133
  IE ports:
    Interface   Port WWN                  Port type  Attached port WWNs
    Vfc2        2f:15:01:11:22:00:01:01   F_Port     2f:15:01:11:22:00:01:02
                                                     2f:15:01:11:22:00:01:03
                                                     2f:15:01:11:22:00:01:04
    Vfc1        38:00:00:11:22:00:01:01   E_Port     38:00:00:11:22:00:01:02
  IE WWN                   : 10:00:00:11:22:00:01:02
  Domain ID                : 0x02
  Management address list  : snmp://192.168.6.101
  Logical name             : IE-Sysname2
  IE ports:
    -           2f:15:01:11:22:00:01:01   F_Port     2f:15:01:11:22:00:01:02
    -           38:00:00:11:22:00:01:01   E_Port     38:00:00:11:22:00:01:02
FCS Local Database in VSAN 2:
  Domain ID                : 0x01
  Fabric name              : 10:02:00:11:22:00:01:01
  IE ports:
Table 34 Command output
·     snmp://192.168.6.100—SNMP is supported by the IE, and the management IP address is 192.168.6.100.
·     Unknown—No management IP address is obtained from the IE.
·     NA—No management IP address is configured on the IE.
Fabric name
Name of the fabric where the IE resides.
Unknown indicates that the fabric name is not obtained from the IE.
Logical name
Device name of the IE.
Unknown indicates that the device name is not obtained from the IE.
Information list
Includes vendor name, model name/number, and release code.
Unknown indicates that the information list is not obtained from the IE.
Interface name.
The interface name is displayed for only interfaces on the local IE. For interfaces on non-local IEs, a hyphen (-) is displayed.
Port type
Port mode: E_Port or F_Port.
Unknown is displayed for port modes other than E_Port and F_Port.
Attached port WWNs
WWNs of connected ports.
NA indicates that the port does not connect to any ports.
fcs discovery start
display fcs ie
Use display fcs ie to display the IE information.
display fcs ie [ vsan vsan-id ] [ nwwn wwn ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the IE information in all VSANs.
nwwn wwn: Specifies a node by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal). If you do not specify a node, this command displays the IE information for all the nodes in a VSAN.
verbose: Displays detailed IE information. If you do not specify this keyword, the command displays brief IE information.
# Display the IE information in all VSANs.
<Sysname> display fcs ie
IE List for VSAN 1:
  IE WWN                   Domain ID   Mgmt addr list           Logical name
  10:00:00:11:22:00:01:01  0x01        snmp://192.168.6.100     Sysname
  10:00:00:11:22:00:01:02  0x02        snmp://192.168.6.101     Sysname
  Total 2 IEs in Fabric.
IE List for VSAN 2:
  Total 1 IEs in Fabric.
# Display the IE information in VSAN 1.
<Sysname> display fcs ie vsan 1
IE List for VSAN 1:
# Display the brief IE information for the node with WWN 10:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs ie vsan 1 nwwn 10:00:00:11:22:00:01:01
# Display the detailed IE information for the node with WWN 10:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs ie vsan 1 nwwn 10:00:00:11:22:00:01:01 verbose
IE Attributes:
  IE type                : Switch
  Domain ID              : 0x01
  Logical name           : Sysname
  Management address list: snmp://192.168.6.100
  Information list       :
    Vendor name      : H3C
    Model name/number: H3C S12510-X
    Release code     : Version 7.1.045, Ess 1133
# Display the detailed IE information in all VSANs.
<Sysname> display fcs ie verbose
IE List for VSAN 1:
  IE Attributes:
    IE type                : Switch
    Domain ID              : 0x01
    Information list       :
      Vendor name      : H3C
IE List for VSAN 2:
  IE Attributes:
    IE type                : Switch
    Domain ID              : 0x01
    Information list       :
      Vendor name      : H3C
Table 35 Command output
IE type
The IE type can only be Switch.
Unknown is displayed for all other types.
Fabric name
Logical name
Mgmt addr list
Information list
fcs discovery start
display fcs port
Use display fcs port to display port information.
display fcs port [ vsan vsan-id ] [ pwwn wwn ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command display the port information in all VSANs.
pwwn wwn: Specifies a port by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal). If you do not specify a port, this command displays information about all ports in a VSAN.
verbose: Displays detailed port information. If you do not specify this keyword, the command displays brief port information.
# Display the port information for all VSANs.
<Sysname> display fcs port
Port List for VSAN 1:
  IE WWN: 10:00:00:11:22:00:01:01
    Port WWN                  Port type    Tx type             Module type
    2f:15:01:11:22:00:01:01   Unknown      Shortwave Laser     SFP with Serial ID
    38:00:00:11:22:00:01:01   E_Port       Shortwave Laser     SFP with Serial ID
    Total 2 switch-ports in IE.
  IE WWN: 10:00:00:11:22:00:01:02
    38:00:00:11:22:00:01:02   E_Port       Shortwave Laser     SFP with Serial ID
    Total 1 switch-ports in IE.
Port List for VSAN 2:
# Display the brief port information for the port with WWN 38:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs port vsan 1 pwwn 38:00:00:11:22:00:01:01
# Display the detailed port information for the port with WWN 38:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs port vsan 1 pwwn 38:00:00:11:22:00:01:01 verbose
Port Attributes:
  Port WWN                         : 38:00:00:11:22:00:01:01
  Port type                        : E_Port
  Tx type                          : Shortwave Laser
  Module type                      : SFP with Serial ID
  Port number                      : 465
  Attached port WWNs               : 2f:15:01:11:22:00:01:02
  Port state                       : Offline
  Port speed capability            : 10Gbps, 16Gbps
  Port speed operation             : 10Gbps
  Port zoning enforcement status   : Soft, Hard
Table 36 Command output
Port type
Tx type
Transmitter type of the port:
·     10GBASE-CX4.
·     10GBASE-ER 1550nm laser.
·     10GBASE-EW 1550nm laser.
·     10GBASE-LR 1310nm laser.
·     10GBASE-LW 1310nm laser.
·     10GBASE-LX4 WWDM 1300nm laser.
·     10GBASE-SR 850nm laser.
·     10GBASE-SW 850nm laser.
·     Electrical-EL.
·     Long wave laser cost reduced-LC(1310nm).
·     Long wave laser-LL(1550nm).
·     Short wave laser-SN(850nm).
Unknown is displayed for cable types other than the preceding ones.
Module type
Transceiver module type of the port:
·     GBIC with serial ID.
·     GBIC without serial ID.
·     GLM.
·     QSFP.
·     SFP-DWDM.
·     SFP with serial ID.
·     SFP without serial ID.
·     X2-DWDM.
·     X2 Medium.
·     X2 short.
·     X2 Tall.
·     XENPAK.
·     XFP.
·     XPAX Medium.
·     XPAX short.
·     XPAX Tall.
Other is displayed for transceiver module types other than the preceding ones.
Unknown is displayed when the transceiver module type cannot be obtained.
Port number
Port index.
Attached port WWNs
If the port does not connect to any ports, this field displays NA.
Port state
Current port state:
·     Online—The port link is connected.
·     Offline—The port link is not connected.
·     Unknown—Port state other than Online and Offline.
The supported speed can be one or more of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
Unknown is displayed for speeds other than the preceding ones.
The current speed can only be one of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
Unknown is displayed for speeds other than the preceding ones. Speed not established is displayed when the current port state is Offline.
Zoning type supported by the port: soft zoning or hard zoning.
Soft zoning and hard zoning can be both supported. NA is displayed when neither of them is supported.
fcs discovery start
FDMI commands
display fdmi database
Use display fdmi database to display the FDMI database information.
display fdmi database [ vsan vsan-id ] [ hba-id hba-id ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the FDMI database information for all VSANs.
hba-id hba-id: Specifies an HBA by its ID in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal).
verbose: Displays detailed FDMI database information. If you do not specify this keyword, the command displays brief FDMI database information.
# Display the brief FDMI database information for all VSANs.
<Sysname> display fdmi database
Registered HBA List for VSAN 1:
  HBA ID                        Port WWNs
  21:00:00:11:22:00:01:02       21:00:00:11:22:00:01:02
                                21:00:00:c0:dd:13:cc:d6
                                21:00:00:c0:dd:13:cc:d7
  38:00:00:11:22:00:01:01       21:00:00:c0:dd:13:cc:d4
                                21:00:00:c0:dd:13:cc:d5
Registered HBA List for VSAN 2:
  HBA ID                        Port WWNs
Table 37 Command output
Port WWNs
WWNs of the ports on the HBA.
# Display brief information about the HBA 38:00:00:11:22:00:01:01 in the FDMI database for VSAN 1.
<Sysname> display fdmi database vsan 1 hba-id 38:00:00:11:22:00:01:01
  HBA ID                        Port WWNs
# Display the detailed FDMI database information for VSAN 1.
<Sysname> display fdmi database vsan 1 verbose
  HBA ID: 38:00:00:11:22:00:01:01
    Node WWN: 20:00:00:c0:dd:13:cc:d5
    Manufacturer: QLogic Corporation
    Serial num: RFC1001S63347
    Model: QLE8152
    Model description: QLogic QLE8152 Fibre Channel Adapter
    Hardware version: 2.1
    Driver version: 9.1.9.17
    ROM version: 3.00
    Firmware version: 5.04.01
    OS name/version: Microsoft Windows Server 2003 R2 for x86
    CT payload len: 2112
      Port WWN: 21:00:00:c0:dd:13:cc:d5
        Supported FC4 types: FCP
        Supported speed: 10Gbps
        Current speed: 10Gbps
        Maximum frame size: 2048
        OS device name: S05131F
        Host name: S05131F
Table 38 Command output
Node WWN
WWN of the node where the HBA resides.
OS name/version
Operating system name and version number of the HBA.
CT payload len
Maximum length of CT payload allowed by the HBA.
The CT payload includes the basic header and extended header of CT packets, but not the FC header.
Port WWN
WWN of the port on the HBA.
Supported FC4 types
The supported FC4 types include:
·     FCP—Fibre Channel Protocol.
·     GS3.
·     IP.
·     LLC/SNAP.
·     NPV.
·     SNMP.
·     SW-ILS.
·     VI.
Supported speed
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
·     32 Gbps.
·     40 Gbps.
Unknown is displayed for speeds other than the preceding ones. Speed not established is displayed when the supported speed cannot be determined.
Current speed
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
·     32 Gbps.
·     40 Gbps.
Unknown is displayed for speeds other than the preceding ones. Speed not established is displayed when the current speed cannot be determined.
OS device name
Operating system name of the port.
FC ping commands
fcping
Use fcping to FCping an address.
fcping [ -c count | -t timeout ] * fcid fcid vsan vsan-id
-c count: Specifies the number of echo requests to be sent, in the range of 0 to 2147483647 and defaulting to 5. The value of 0 indicates that echo requests are continuously sent until you manually stop sending them.
-t timeout: Specifies the timeout value for an echo reply, in the range of 1 to 10 seconds. The default is 5 seconds. If the source does not receive an echo reply within the timeout period, it considers the echo reply timed out.
fcid fcid: Specifies the destination address.
·     If the destination is a node, the fcid argument indicates the FC address of the node.
·     If the destination is an FCF switch, the fcid argument indicates the  switch's domain controller address FFFCxx (xx is the domain ID of the switch). For example, if the domain ID of the destination switch is 3, its domain controller address is FFFC03.
To abort the FC ping operation during the execution of this command, press Ctrl+C.
# FCping the address FFFC02 in VSAN 1.
<Sysname> fcping fcid fffc02 vsan 1
FCPING fcid 0xfffc02: 128 data bytes, press CTRL_C to break.
Reply from 0xfffc02: bytes = 128 time = 1.281 ms
Reply from 0xfffc02: bytes = 128 time = 0.890 ms
Reply from 0xfffc02: bytes = 128 time = 0.889 ms
Reply from 0xfffc02: bytes = 128 time = 0.892 ms
Reply from 0xfffc02: bytes = 128 time = 0.894 ms
--- 0xfffc02 fcping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 0.889/0.969/1.281 ms
The output shows that all FC ping packets were successfully received.
# FCping the address FFFC01 in VSAN 1.
<Sysname> fcping fcid fffc01 vsan 1
FCPING fcid 0xfffc01: 128 data bytes, press CTRL_C to break.
fcping: sendto: No route to host
fcping: sendto: ^C
--- 0xfffc01 fcping statistics ---
3 packet(s) transmitted
0 packet(s) received
100.00% packet loss
The output shows that FC ping packets were not received.
Table 39 Command output
Identify whether the device with destination address FFFC02 is reachable.
128 data bytes
Number of data bytes in each echo request.
During the execution of the command, press Ctrl+C to abort the FC ping operation.
The echo reply was received from the device whose destination address is 0xfffc02.
·     bytes—Number of data bytes in the echo reply.
·     time—Response time.
Request time out
No echo reply was received within the timeout period.
Echo requests failed to be delivered.
Statistics on the data received and sent in the FC ping operation.
Number of echo requests sent.
Number of echo replies received.
0.00% packet loss
Percentage of packets not responded to the total number of packets sent.
Minimum/average/maximum response time, in milliseconds.
FC tracert commands
fctracert
Use fctracert to detect bidirectional routing information between the local end and a destination. The destination can be a node or FCF switch.
fctracert [ -t timeout ] fcid fcid vsan vsan-id
-t timeout: Specifies the timeout value for the entire FC tracert process, in the range of 1 to 10 seconds. The default is 5 seconds.
vsan vsan-id: Specifies an existing VSAN by its ID in the range of 1 to 3839.
The bidirectional routing information includes WWNs and domain controller addresses of all switches on a round trip. The switch supports a maximum of 255 hops for a round trip.
To abort the FC tracert operation during the execution of this command, press Ctrl+C.
# Detect bidirectional routing information between the local end and a node with FC address 0xd70000 in VSAN 1.
<Sysname> fctracert fcid d70000 vsan 1
Route present for: 0xd70000, press CTRL_C to break.
20:00:00:0b:46:00:02:82(0xfffcd5)
20:00:00:05:30:00:18:db(0xfffcd7)
Fctracert completed.
Table 40 Command output
Route present for
Path from a source to a destination.
During the execution of the command, press Ctrl+C to abort the FC tracert operation.
WWN value.
0xfffcd5
Domain controller address FFFCxx of the switch, where xx is the domain ID of the switch.
Fctracert uncompleted.
The FC tracert operation fails to be completed for the following possible reasons:
·     Resource is not enough.
·     Max hops reached.
·     Fabric is being built.
·     No route to destination port.
·     Destination port is not in fabric.
·     Destination port and source port are not in the same zone.
Service is unavailable.
The FC tracert service is not started, or internal processing fails.
Index
A B D F I M P R S T V W Z
A
allowed-domain-id,19
B
bandwidth,3
bind interface,3
D
default,5
delete zone database all,66
description,5
display fc domain,20
display fc domain-list,21
display fc ess,22
display fc exchange,45
display fc fib,47
display fc login,24
display fc name-service database,25
display fc routing-table,48
display fc scr-table,27
display fc switch-wwn,28
display fc timer,29
display fcoe,11
display fcoe-mode,1
display fcs database,102
display fcs discovery status,101
display fcs ie,104
display fcs port,106
display fdmi database,109
display fip-snooping enode,94
display fip-snooping fcf,94
display fip-snooping flushing-rules,95
display fip-snooping rules,96
display fip-snooping sessions,97
display fspf graceful-restart,51
display fspf lsdb,52
display fspf neighbor,54
display fspf statistics,55
display interface vfc,6
display vsan port-member,17
display zone,66
display zone member,68
display zone statistics,69
display zone status,70
display zone-alias,72
display zoneset,73
display zoneset active,74
domain auto-reconfigure enable,29
domain configure enable,30
domain restart,31
domain-id,32
F
fabric-name,33
fc domain rcf-reject,33
fc mode (VFC interface view),9
fc name-service auto-discovery,34
fc route-static,56
fc timer distributed-services,35
fc timer error-detect,35
fc timer resource-allocation,36
fc wwn default-fc4-type,37
fcoe enable,12
fcoe fcf-priority,13
fcoe fcmap,14
fcoe fka-adv-period,14
fcoe global fcf-priority,16
fcoe-mode,1
fcping,113
fcs discovery start,100
fcs discovery stop,101
fctracert,114
fip-snooping enable,98
fip-snooping fc-map,99
fip-snooping port-mode,99
fspf cost,57
fspf dead-interval,58
fspf enable,59
fspf graceful-restart,59
fspf graceful-restart helper,60
fspf graceful-restart interval,61
fspf hello-interval,61
fspf min-ls-arrival,62
fspf min-ls-interval,63
fspf retransmit-interval,63
fspf silent,64
fspf spf-hold-time,64
I
interface vfc,10
M
member (zone alias view),78
member (zone set view),79
member (zone view),76
P
pairwise-zoning enable,80
port trunk vsan,18
priority,38
R
reset counters interface,10
reset fspf counters,65
reset zone statistics,81
rscn aggregation enable,39
rscn aggregation timer,39
S
shutdown,11
snmp-agent trap enable fc-fabric,40
snmp-agent trap enable fc-name-service,41
snmp-agent trap enable fc-zone,81
T
timer distributed-services,42
timer error-detect,42
timer resource-allocation,43
V
vsan,18
W
wwn area-port-id,44
Z
zone clone,82
zone default-zone permit,83
zone hard-zoning enable,84
zone merge-control restrict,84
zone mode enhanced,85
zone name,86
zone rename,87
zone-alias clone,87
zone-alias name,88
zone-alias rename,89
zoneset activate,89
zoneset clone,90
zoneset distribute,91
zoneset distribute full,92
zoneset name,92
zoneset rename,93
