| 00-Preface | 101.73 KB |
Preface
The H3C S12500-X & S12500X-AF documentation set includes 17 command references. These references describe the commands and command syntax options available for the H3C S12500-X & S12500X-AF Switch Series running Release 1135 and later.
The Fundamentals Command Reference describes commands that help you get started with the device.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S12500-X & S12500X-AF series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device. |
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Obtaining documentation
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
