00-Preface | 75.69 KB |
Preface
The H3C Access Points Anchor AC Mode Web-Based Configuration Guide describes the web functions of the APs(anchor ac mode), such as quick start, web overview, wireless service configuration, security and authentication related configurations, QoS configuration, and advanced settings.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access points (anchor ac mode).
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
