09-WLAN Roaming Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Points Anchor AC Mode Configuration Guides(E2442 R2442)-6W10009-WLAN Roaming Configuration Guide
01-WLAN roaming configuration
01-WLAN roaming configuration 86.38 KB
Configuring WLAN roaming
About WLAN roaming
WLAN roaming enables clients to seamlessly roam among APs in an ESS while retaining their IP address and authorization information during the roaming process.
WLAN roaming mechanism
Clients can roam between devices in the same mobility group.
Intra-AC roaming enables clients to roam among APs that are managed by the same AC.
Figure 1 Intra-AC roaming
As shown in Figure 1, intra-AC roaming uses the following procedure:
1.     The client comes online from AP 1, and the AC creates a roaming entry for the client.
2.     The client roams to AP 2. The AC examines the roaming entry for the client and determines whether to perform fast roaming.
If the client uses RSN + 802.1X authentication and carries the same PMKID as the AC, fast roaming is used, and the client can associate with AP 2 without reauthentication. If it is not, the client must be reauthenticated before associating with AP 2.
Restrictions and guidelines: WLAN roaming configuration
For a service template where an AP is configured as the client authenticator, WLAN roaming is not supported. For more information about client authentication, see User Access and Authentication Configuration Guide.
Enabling SNMP notifications for WLAN roaming
To report critical WLAN roaming events to an NMS, enable SNMP notifications for WLAN roaming. For WLAN roaming event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for WLAN roaming.
snmp-agent trap enable wlan mobility
By default, SNMP notifications for WLAN roaming are disabled.
Display and maintenance commands for WLAN roaming
Display roam-track information for a client on the AC.
display wlan mobility roam-track mac-address mac-address
WLAN roaming configuration examples
Example: Configuring intra-AC roaming
As shown in Figure 2, configure intra-AC roaming to enable the client to roam from AP 1 to AP 2. The two APs are managed by the same AC.
Figure 2 Network diagram
# Create a service template named service, set the SSID to 1, and enable the service template.
<AC> system-view
[AC] wlan service-template service
[AC-wlan-st-service] ssid 1
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6330
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Bind the service template to radio 1 of AP 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
# Create a manual AP named ap2, and specify the AP model and serial ID.
[AC] wlan ap ap2 model WA6330
[AC-wlan-ap-ap2] serial-id 219801A28N819CE0003T
# Bind the service template to radio 1 of AP 2.
[AC-wlan-ap-ap2] radio 1
[AC-wlan-ap-ap2-radio-1] radio enable
[AC-wlan-ap-ap2-radio-1] service-template service
[AC-wlan-ap-ap2-radio-1] quit
[AC-wlan-ap-ap2] quit
# Enable the client to come online from AP 1. (Details not shown.)
# Verify that the client has associated with AP 1, and the roaming status is N/A, which indicates that the client has not performed any roaming.
[AC] display wlan client verbose
Total number of clients: 1
MAC address                        : 9cd3-6d9e-6778
IPv4 address                       : 10.1.1.114
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : ap1
Radio ID                           : 1
Channel                            : 36
SSID                               : 1
BSSID                              : 000f-e200-4444
VLAN ID                            : 1
Sleep count                        : 242
Wireless mode                      : 802.11ac
Channel bandwidth                  : 80MHz
SM power save                      : Enabled
SM power save mode                 : Dynamic
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
Supported HT MCS set               : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15, 16, 17, 18, 19, 20,
                                     21, 22, 23
Supported rates                    : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/11
Authentication method              : Open system
Security mode                      : PRE-RSNA
AKM mode                           : Not configured
Cipher suite                       : N/A
User authentication mode           : Bypass
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forward policy name                : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
# Verify that the AC has a roaming entry for the client.
[AC] display wlan mobility roam-track mac-address 9cd3-6d9e-6778
Total entries  : 1
Current entries: 1
BSSID           Created at           Online time       AC IP address  RID  AP name
000f-e200-4444  2016-06-14 11:12:28  00hr 01min 16sec  127.0.0.1      1    ap1
# Enable the client roam to AP 2. (Details not shown.)
# Verify that the client has associated with AP 2, and the roaming status is Intra-AC roam.
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 2
AP name                            : ap2
Channel                            : 36
Radio ID                           : 1
SSID                               : 1
BSSID                              : 000f-e203-7777
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Cipher suite                       : N/A
Roam status                        : Intra-AC roam
Online time                        : 0days 0hours 5minutes 13seconds
# Verify that the AC has updated the roaming entry for the client.
Total entries  : 2
Current entries: 2
000f-e203-7777  2016-06-14 11:12:28  00hr 01min 02sec     127.0.0.1      1    ap2
000f-e200-4444  2016-06-14 11:12:04  00hr 03min 51sec     127.0.0.1      1    ap1
