10-WLAN Advanced Features Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2442 R2442)-6W10010-WLAN Advanced Features Command Reference
01-WLAN optimization commands
01-WLAN optimization commands 84.15 KB
IMPORTANT
IMPORTANT:
Use WLAN optimization commands under the guidance of H3C Support.
option capacity-adjust
Use option capacity-adjust enable to enable transmit power adjustment.
Use option capacity-adjust disable to disable transmit power adjustment.
Use undo capacity-adjust to restore the default.
option capacity-adjust { disable | enable [ all ] { increase | decrease } value }
undo option capacity-adjust
Transmit power adjustment is disabled.
Radio interface view
all: Configures transmit power adjustment for all rates. If you do not specify this keyword, the command configures transmit power adjustment for mandatory rates.
increase: Increases the transmit power.
decrease: Decreases the transmit power.
value: Specifies the transmit power adjustment value in the range of 1 to 27 dBm.
This feature enables an AP to use the adjusted transmit power to transmit packets.
# Enable transmit power adjustment and increase the transmit power by 1 dBm for all rates.
[Sysname]interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] option capacity-adjust all increase 1
option client fast-forwarding
Use option client fast-forwarding enable to enable fast forwarding of AP-to-client data frames.
Use undo option client fast-forwarding to disable fast forwarding of AP-to-client data frames.
option client fast-forwarding enable level level-value
Fast forwarding of AP-to-client data frames is disabled.
level level-value: Specifies the fast forwarding level in the range of 1 to 4.
This feature enables an AP to forward data frames to clients without extra processing (such as verification and counting) to improve processing efficiency.
# Enable fast forwarding of AP-to-client data frames.
[Sysname-WLAN-Radio1/0/1] option client fast-forwarding enable level 1
option client hide-node-protection
Use option client hide-node-protection enable to enable hidden node protection.
Use undo option client hide-node-protection to disable hidden node protection.
Hidden node protection is disabled.
This command takes effect only on 802.11g, 802.11n, and 802.11ac clients.
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
# Enable hidden node protection.
[Sysname-WLAN-Radio1/0/1] option client hide-node-protection enable
option client reconnect
Use option client reconnect enable to enable AP-triggered client reassociation.
Use undo option client reconnect to disable AP-triggered client reassociation.
option client reconnect enable [ rssi rssi-value ] [ interval interval ]
AP-triggered client reassociation is disabled.
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. The default and recommended RSSI thresholds are 10 and 20, respectively.
interval interval: Specifies the interval at which an AP detects the signal strength of the clients. The value range for the interval argument is 3 to 10 seconds and the default interval is 3 seconds.
This feature enables an AP to send deauthentication frames to a client when the AP detects that the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
# Enable AP-triggered client reassociation, and set the RSSI threshold and detection interval to 30 and 5 seconds, respectively.
[Sysname-WLAN-Radio1/0/1] option client reconnect enable rssi 30 interval 5
option client reject
Use option client reject enable to enable an AP to reject weak-signal clients.
Use undo option client reject to disable an AP from rejecting weak-signal clients.
option client reject enable [ rssi rssi-value ]
Weak-signal clients are not rejected.
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. Both the default and recommended RSSI thresholds are 10.
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
# Enable the AP to reject clients with an RSSI lower than 30 dBm.
[Sysname-WLAN-Radio1/0/1] option client reject enable rssi 30
option dot11n-restraint
Use option dot11n-restraint enable to enable 802.11n packet suppression.
Use option dot11n-restraint disable to disable 802.11n packet suppression.
Use undo dot11n-restraint to restore the default.
option dot11n-restraint { disable | enable packet-number packet-number packet-length packet-length } [ inbound | outbound ] [ tid tid-number ]
undo option dot11n-restraint
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware series
Model
Command compatibility
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
802.11n packet suppression is disabled.
packet-number packet-number: Specifies the maximum number of MPDUs that can be aggregated into an A-MPDU, in the range of 1 to 64. The recommended value is 8.
packet-length packet-length: Specifies the maximum A-MPDU length, in the range of 2000 to 380000 bytes. The recommended value is 6000.
inbound: Specifies 802.11n packet suppression in the inbound direction.
outbound: Specifies 802.11n packet suppression in the outbound direction.
tid tid-number: Specifies a traffic identifier, in the range of 0 to 7. The queue type varies by TID value.
·     0 and 3—AC-BE queue.
·     1 and 2—AC-BK queue.
·     4 and 5—AC-VI queue.
·     6 and 7—AC-VO queue.
If you do not specify this option, 802.11n packet suppression applies to all types of packets.
Perform this task to suppress 802.11n packets by defining the maximum number of aggregated MPDUs and the maximum A-MPDU length. The two thresholds take effect at the same time. If either threshold is reached, the AP stops aggregation and sends the A-MPDU.
# Enable 802.11n packet suppression. Set the maximum number of MPDUs that can be aggregated into an A-MPDU and the maximum A-MPDU length to 30 and 10000 bytes, respectively.
[Sysname-WLAN-Radio1/0/1] option dot11n-restraint enable packet-number 30 packer-length 10000
option keep-active
Use option keep-active enable to enable decreasing the sleep interval of wireless clients.
Use option keep-active disable to disable decreasing the sleep interval of wireless clients.
Use undo option keep-active to restore the default.
option keep-active { disable | enable }
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
Decreasing the sleep interval of wireless clients is disabled.
A wireless client in sleep state listens for traffic indication map (TIM) information in beacon frames to determine whether the associated AP has buffered packets for it. This feature enables an AP to modify the TIM information in beacon frames to decrease the sleep interval of wireless clients to improve transmission efficiency.
# Enable decreasing the sleep interval of wireless clients.
[Sysname-WLAN-Radio1/0/1] option keep-active enable
option probe-response-try
Use option probe-response-try enable to set the maximum number of probe response attempts.
Use option probe-response-try disable to remove the configuration.
Use undo probe-response-try to restore the default.
option probe-response-try { disable | enable number }
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
The maximum number of probe response attempts is not limited.
number: Specifies the maximum number of probe response attempts, in the range of 1 to 16.
Perform this task to reduce the number of probe responses sent by a radio to save resources and improve network performance.
# Set the maximum number of probe response attempts to 10.
[Sysname-WLAN-Radio1/0/1] option probe-response-try enable 10
option roam-navigation
Use option roam-navigation enable to enable roaming navigation.
Use option roam-navigation disable to disable roaming navigation.
Use undo option roam-navigation to restore the default.
option roam-navigation { disable | enable rssi rssi-value { beacon-power power-value | probe-response-power power-value } }
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
Roaming navigation is disabled.
rssi rssi-value: Specifies the RSSI threshold in the range of 1 to 50. The recommended RSSI threshold is 20.
beacon-power power-value: Specifies the transmit power for beacon frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
probe-response-power power-value: Specifies the transmit power for probe response frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
If you set the transmit power for beacons or probe responses, the system uses the default transmit power to transmit other packets.
# Enable roaming navigation. Set the RSSI threshold to 10 and the transmit power for beacon frames to 10 dBm.
[Sysname-WLAN-Radio1/0/1] option roam-navigation enable rssi 10 probe-response-power 10
rrop software-retry
Use rrop software-retry enable to enable software retransmission and set the maximum number of software retransmissions.
Use rrop software-retry disable to disable software retransmission.
Use undo rrop software-retry to restore the default.
rrop software-retry { unicast [ eap ] | broadcast-multicast } enable count count
rrop software-retry { unicast [ eap ] | broadcast-multicast } disable
undo rrop software-retry { unicast [ eap ] | broadcast-multicast }
The maximum number of software retransmissions varies by device model.
unicast: Configures software retransmission for unicast packets.
eap: Configures software retransmission for EAP packets.
broadcast-multicast: Configures software retransmission for broadcast and multicast packets.
count count: Specifies the maximum number of software retransmissions, in the range of 0 to 16.
# Set the maximum number of software retransmissions for EAP packets to the default.
[Sysname-WLAN-Radio1/0/1] undo rrop software-retry unicast eap
wlan client inspect
Use wlan client inspect enable to enable client inspection.
Use undo wlan client inspect to restore the default.
Client inspection is disabled.
The client inspection feature enables you to view information about packets exchanged and time consumed in each stage of the client association process.
In the current software version, the client inspection feature supports only client association, client association failure, and IP address lease extension events.
# Enable client inspection.
[Sysname] wlan client inspect enable
