08-Radio Resources Management
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2442 R2442)-6W10008-Radio Resources Management
07-Spectrum management commands
07-Spectrum management commands 47.95 KB
channel-capability mode
Use channel-capability mode to set the client channel capability match mode.
Use undo channel-capability mode to restore the default.
channel-capability mode { all | none | partial }
Client channel capabilities are not checked.
Radio interface view
all: Specifies the all mode. A client is allowed to associate with a radio only when all its supported channels match the radio's supported channels.
none: Specifies the none mode. Client channel capabilities are not checked.
partial: Specifies the partial mode. A client is allowed to associate with a radio as long as one of its supported channels matches any one of the radio's supported channels.
This command is available only for 5 GHz radios.
# Set the client channel capability match mode to all.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] spectrum-management enable
[Sysname-WLAN-Radio1/0/2] channel-capability mode all
spectrum-management
channel-switch mode
Use channel-switch mode to set the channel switch mode.
Use undo channel-switch mode to restore the default.
channel-switch mode { continuous | suspend }
All online clients stop sending frames during channel switch.
continuous: Configures the online clients to continue sending frames during channel switch.
suspend: Configures the online clients to stop sending frames during channel switch until channel switch is complete.
# Set the channel switch mode to continuous.
[Sysname-WLAN-Radio1/0/2] channel-switch mode continuous
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4620i-ACN-radio-1] channel-switch mode continuous
spectrum-management
power-capability mode
Use power-capability mode to set the transmit power capability match mode.
Use undo power-capability mode to restore the default.
power-capability mode { all | none | partial }
Client transmit power capabilities are not checked.
all: Specifies the all mode. A client is allowed to associate with a radio only when all its transmit power capabilities match the radio's transmit power capabilities.
none: Specifies the none mode. Client transmit power capabilities are not checked.
partial: Specifies the partial mode. A client is allowed to associate with a radio as long as one of its transmit power capabilities matches the radio's transmit power capabilities.
This command takes effect only when you enable spectrum management or radio resource measurement.For more information about radio resource measurement, see Radio Resource Management Configuration Guide.
# Set the client power capability match mode to all.
[Sysname-WLAN-Radio1/0/2] power-capability mode all
resource-measure
spectrum-management
power-constraint mode
Use power-constraint mode to set the power constraint mode.
Use undo power-constraint mode to restore the default.
power-constraint mode { auto [ anpi-interval anpi-interval-value ] | manual power-constraint }
The power constraint mode is auto.
auto: Specifies the auto mode.
anpi-interval anpi-interval-value: Adds a value to the average noise power indicator (ANPI) for the device to calculate the power constraint value, in the range of 0 to 30 in dBm. The default value is 10 dBm.
manual power-constraint: Specifies the power constraint value in the range of 0 to 30 dBm.
If you specify the auto mode, the device calculates the power constraint value by using this formula: power-constraint = Received Channel Power Indicator (RCPI) minus (ANPI + anpi-interval-value).
This command takes effect only when you enable spectrum management or radio resource measurement. For more information about radio resource measurement, see Radio Resource Management Configuration Guide.
# Set the power constraint mode to manual and set the power constraint value to 5 dBm.
[Sysname-WLAN-Radio1/0/2] power-constraint mode manual 5
resource-measure
spectrum-management
spectrum-management
Use spectrum-management enable to enable spectrum management.
Use spectrum-management disable to disable spectrum management.
Use undo spectrum-management to restore the default.
spectrum-management { disable | enable }
Spectrum management is disabled.
# Enable spectrum management.
