11-WLAN Advanced Features Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Points Anchor AC Mode Command References(E2442 R2442)-6W10011-WLAN Advanced Features Command Reference
01-WLAN optimization commands
01-WLAN optimization commands 124.70 KB
IMPORTANT
IMPORTANT:
Use WLAN optimization commands under the guidance of H3C Support.
option 4-way-handshake resend
Use option 4-way-handshake resend to set the maximum number of retransmissions for an EAPOL-Key packet and the retransmission interval.
Use undo option 4-way-handshake resend to restore the default.
option 4-way-handshake resend max-count [ interval interval ]
The maximum number of retransmissions for an EAPOL-Key packet is three, and the retransmission interval is 300 milliseconds.
Service template view
resend max-count: Specifies the maximum number of retransmissions for an EAPOL-Key packet, in the range of 0 to 3.
interval interval: Specifies the retransmission interval in the range of 200 to 500 milliseconds.
In Robust Security Network Association (RSNA) authentication, an AP and a client use EAPOL-Key packets in the four-way handshake to negotiate the keys. After that, the AP and the client periodically exchange EAPOL-Key packets to update the keys.
During key negotiation or update, the AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
The system starts to count the retries when the maximum number of retransmissions is reached.
To ensure successful RSN key negotiation or update, you can increase the maximum number of retransmissions and the maximum number of retries for an EAPOL-Key packet.
For more information about RSN key negotiation or update, see "Configuring WLAN security."
# In service template view, set the maximum number of retransmissions for an EAPOL-Key packet to one and the retransmission interval to 400 milliseconds.
[Sysname] wlan service-template service1
[Sysname-wlan-st-svervice1] option 4-way-handshake resend 1 interval 400
option 4-way-handshake retry
Use option 4-way-handshake retry to set the maximum number of retries for an EAPOL-Key packet and the retry interval.
Use undo option 4-way-handshake retry to restore the default.
option 4-way-handshake retry max-count [ interval interval ]
The maximum number of retries for an EAPOL-Key packet is three, and the retry interval is 5 seconds.
retry max-count: Specifies the maximum number of retries for an EAPOL-Key packet, in the range of 0 to 3.
interval interval: Specifies the retry interval in the range of 2 to 5 seconds.
During RSN key negotiation or update, an AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
If you execute this command for multiple times, the most recent configuration takes effect.
# In service template view, set the maximum number of retries for an EAPOL-Key packet to two and the retry interval to 3 seconds.
[Sysname-wlan-st-service1] option 4-way-handshake retry 2 interval 3
option broadcast-multicast-buffer
Use option broadcast-multicast-buffer enable to enable multicast and broadcast buffering.
Use option broadcast-multicast-buffer disable to disable multicast and broadcast buffering.
Use undo option broadcast-multicast-buffer to restore the default.
option broadcast-multicast-buffer { disable | enable [ limit limit ] }
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, multicast and broadcast buffering is enabled.
Radio view
limit limit: Specifies the maximum number of multicast or broadcast packets that can be buffered. The value range for the limit argument is 1 to 600 and the default value is 100.
With this feature enabled, the AC stops sending broadcast and multicast packets and buffers them if an associated client is in sleep state. This mechanism affects the performance of real-time multicast applications.
With this feature disabled, the AC directly sends all broadcast and multicast packets regardless of whether an associated client is in sleep state.
# Disable multicast and broadcast buffering for AP ap1.
[Sysname] wlan ap ap1 model WA6330
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] option broadcast-multicast-buffer disable
# Disable multicast and broadcast buffering for APs with model WA6330 in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6330
[Sysname-wlan-ap-group-1-ap-model-WA6330] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option broadcast-multicast-buffer disable
option capacity-adjust
Use option capacity-adjust enable to enable transmit power adjustment.
Use option capacity-adjust disable to disable transmit power adjustment.
Use undo capacity-adjust to restore the default.
option capacity-adjust { disable | enable [ all ] { increase | decrease } value }
undo option capacity-adjust
In an AP group's radio view, transmit power adjustment is disabled.
Radio view
all: Configures transmit power adjustment for all rates. If you do not specify this keyword, the command configures transmit power adjustment for mandatory rates.
increase: Increases the transmit power.
decrease: Decreases the transmit power.
value: Specifies the transmit power adjustment value in the range of 1 to 27 dBm.
This feature enables an AP to use the adjusted transmit power to transmit packets.
# Enable transmit power adjustment for AP ap1, and increase the transmit power by 1 dBm for all rates.
[Sysname-wlan-ap-ap1-radio-1] option capacity-adjust all increase 1
# Enable transmit power adjustment for APs with model WA6330 in AP group apgroup1, and increase the transmit power by 1 dBm for all rates.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6330
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option capacity-adjust all increase 1
option channel-reuse-optimization
Use option channel-reuse-optimization enable to enable channel reuse.
Use option channel-reuse-optimization disable to disable channel reuse.
Use undo option channel-reuse-optimization to restore the default.
option channel-reuse-optimization { disable | enable level level }
In an AP group's radio view, channel reuse is disabled.
Radio view
level level: Specifies the channel reuse level in the range of 1 to 10. The recommended channel reuse level is 6.
This feature enables an AP to ignore packets with a signal strength lower than the specified channel reuse level. This mechanism enables the AP to obtain more radio resources and improves the performance of APs working on the same channel.
# Enable channel reuse for AP ap1 and set the channel reuse level to 5.
[Sysname-wlan-ap-ap1-radio-1] option channel-reuse-optimization enable level 5
# Enable channel reuse for APs with model WA6330 in AP group 1 and set the channel reuse level to 5.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option channel-reuse-optimization enable level 5
option channel-share
Use option channel-share enable to enable channel sharing.
Use option channel-share disable to disable channel sharing.
Use undo channel-share to restore the default.
option channel-share { disable | enable power-level power-level }
undo channel-share
In an AP group's radio view, channel sharing is disabled.
Radio view
power-level power-level: Specifies the power level for channel sharing, in the range of 1 to 40. The recommended value is 30.
When this feature is enabled, an AP sends or does not send packets according to whether the detected signals are stronger or weaker than the specified power level. This mechanism avoids channel collision and interference.
# Enable channel sharing for AP ap1 and set the power level to 30.
[Sysname-wlan-ap-ap1-radio-1] option channel-share enable power-level 30
# Enable channel sharing for APs with model WA6330 in AP group apgroup1 and set the power level to 30.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option channel-share enable power-level 30
option client hide-node-protection
Use option client hide-node-protection enable to enable hidden node protection.
Use option client hide-node-protection disable to disable hidden node protection.
Use undo option client hide-node-protection to restore the default.
option client hide-node-protection { disable | enable }
In an AP group's radio view, hidden node protection is disabled.
Radio view
This command takes effect only on 802.11g, 802.11n, and 802.11ac clients.
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
# Enable hidden node protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option client hide-node-protection enable
# Enable hidden node protection for APs with model WA6330 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option client hide-node-protection enable
option client reconnect
Use option client reconnect enable to enable AP-triggered client reassociation.
Use option client reconnect disable to disable AP-triggered client reassociation.
Use undo option client reconnect to restore the default.
option client reconnect { disable | enable [ rssi rssi-value ] [ interval interval ] }
In an AP group's radio view, AP-triggered client reassociation is disabled.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. The default and recommended RSSI thresholds are 10 and 20, respectively.
interval interval: Specifies the interval at which an AP detects the signal strength of the clients. The value range for the interval argument is 3 to 10 seconds and the default interval is 3 seconds.
This feature enables an AP to send deauthentication frames to a client when the AP detects that the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
# Enable AP-triggered client reassociation for AP ap1. Set the RSSI threshold and detection interval to 30 and 5 seconds, respectively.
[Sysname-wlan-ap-ap1-radio-1] option client reconnect enable rssi 30 interval 5
# Enable AP-triggered client reassociation for APs with model WA6330 in AP group 1. Set the RSSI threshold and detection interval to 30 and 5 seconds, respectively.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option client reconnect enable rssi 30 interval 5
option client reject
Use option client reject enable to enable an AP to reject weak-signal clients.
Use option client reject disable to disable an AP from rejecting weak-signal clients.
Use undo option client reject to restore the default.
option client reject { disable | enable [ rssi rssi-value ] }
In an AP group's radio view, a radio does not reject weak-signal clients.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. Both the default and recommended RSSI thresholds are 10.
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
# Enable AP ap1 to reject clients with an RSSI lower than 30 dBm.
[Sysname-wlan-ap-ap1-radio-1] option client reject enable rssi 30
# Enable APs with model WA6330 in AP group 1 to reject clients with an RSSI lower than 30 dBm.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option client reject enable rssi 30
option dot11n-restraint
Use option dot11n-restraint enable to enable 802.11n packet suppression.
Use option dot11n-restraint disable to disable 802.11n packet suppression.
Use undo dot11n-restraint to restore the default.
option dot11n-restraint { disable | enable packet-number packet-number packet-length packet-length } [ inbound | outbound ] [ tid tid-number ]
undo option dot11n-restraint
In an AP group's radio view, 802.11n packet suppression is disabled.
Radio view
packet-number packet-number: Specifies the maximum number of MPDUs that can be aggregated into an A-MPDU, in the range of 1 to 64. The recommended value is 8.
packet-length packet-length: Specifies the maximum A-MPDU length, in the range of 2000 to 380000 bytes. The recommended value is 6000.
inbound: Specifies 802.11n packet suppression in the inbound direction.
outbound: Specifies 802.11n packet suppression in the outbound direction.
tid tid-number: Specifies a traffic identifier, in the range of 0 to 7. The queue type varies by TID value.
·     0 and 3—AC-BE queue.
·     1 and 2—AC-BK queue.
·     4 and 5—AC-VI queue.
·     6 and 7—AC-VO queue.
If you do not specify this option, 802.11n packet suppression applies to all types of packets.
Perform this task to suppress 802.11n packets by defining the maximum number of aggregated MPDUs and the maximum A-MPDU length. The two thresholds take effect at the same time. If either threshold is reached, the AP stops aggregation and sends the A-MPDU.
# Enable 802.11n packet suppression for AP ap1. Set the maximum number of MPDUs that can be aggregated into an A-MPDU and the maximum A-MPDU length to 30 and 10000 bytes, respectively.
[Sysname-wlan-ap-ap1-radio-1] option dot11n-restraint enable packet-number 30 packer-length 10000
# Enable 802.11n packet suppression for APs with model WA6330 in AP group apgroup1. Set the maximum number of MPDUs that can be aggregated into an A-MPDU and the maximum A-MPDU length to 30 and 10000 bytes, respectively.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option dot11n-restraint enable packet-number 30 packer-length 10000
option immediate-transmit
Use option immediate-transmit enable to enable immediate packet sending.
Use option immediate-transmit disable to disable immediate packet sending.
Use undo immediate-transmit to restore the default.
option immediate-transmit { disable | enable }
In an AP group's radio view, immediate packet sending is disabled.
Radio view
When you enable this feature, APs do not detect channel collision before sending packets to save system resources and improve network throughput. Enabling this feature might cause hidden node problems. When you disable this feature, wireless devices send RTS/CTS packets to avoid channel collision.
# Disable immediate packet sending for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option immediate-transmit disable
# Disable immediate packet sending for APs with model WA6330 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option immediate-transmit disable
option keep-active
Use option keep-active enable to enable decreasing the sleep interval of wireless clients.
Use option keep-active disable to disable decreasing the sleep interval of wireless clients.
Use undo option keep-active to restore the default.
option keep-active { disable | enable }
In an AP group's radio view, decreasing the sleep interval of wireless clients is disabled.
Radio view
A wireless client in sleep state listens for traffic indication map (TIM) information in beacon frames to determine whether the associated AP has buffered packets for it. This feature enables an AP to modify the TIM information in beacon frames to decrease the sleep interval of wireless clients to improve transmission efficiency.
# Enable decreasing the sleep interval of wireless clients for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option keep-active enable
# Enable decreasing the sleep interval of wireless clients for APs with model WA6330 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option keep-active enable
option max-interfer-threshold
Use option max-interfer-threshold enable to set the maximum interference threshold.
Use option max-interfer-threshold disable to remove the configuration.
Use undo max-interfer-threshold to restore the default.
option max-interfer-threshold { disable | enable value }
In an AP group's radio view, the maximum interference threshold is not set.
Radio view
value: Specifies the maximum interference threshold in the range of 20 to 120 dBm. The recommended value is 50.
# Set the maximum interference threshold to 30 dBm for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option max-interfer-threshold enable 30
# Set the maximum interference threshold to 30 dBm for APs with model WA6330 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option max-interfer-threshold enable 30
option non-local-packet rate-limit cir
Use option non-local-packet rate-limit cir to set a rate limit for packets destined to radios on other APs.
Use undo option non-local-packet rate-limit cir to restore the default.
option non-local-receive rate-limit cir cir
undo option non-local-receive rate-limit cir
No rate limit is set for packets destined to radios on other APs.
Radio view
cir cir: Specifies the CIR for packets destined to radios on other APs, in the range of 1 to 1300000 Kbps.
After you enable the scanning service (such as wireless probing, WLAN location, and WIPS) for an AP, a radio on the AP might receive packets destined to radios on a different AP than the radio. Such packets will increase the CPU usage and decrease the processing efficiency for packets destined to radios on the AP.
To address this issue, configure this command to set a rate limit for packets destined to radios on other APs.
# Set the CIR to 8 Kbps for packets destined to radios on other APs.
[Sysname-wlan-ap-ap1-radio-1] option non-local-packet rate-limit cir 8000
option optimize-link-performance
Use option optimize-link-performance { inbound | outbound } enable to enable link performance optimization.
Use option optimize-link-performance { inbound | outbound } disable to disable link performance optimization.
Use undo optimize-link-performance to restore the default.
option optimize-link-performance { inbound | outbound } { disable | enable } [ value ]
undo optimize-link-performance { inbound | outbound }
In an AP group's radio view, link performance optimization is disabled.
Radio view
inbound: Optimizes downlink performance.
outbound: Optimizes uplink performance.
value: Specifies the packet fragmentation threshold in the range of 0 to 2048 bytes.
# Enable uplink performance optimization for AP ap1 and set the packet fragmentation threshold to 100 bytes.
[Sysname-wlan-ap-ap1-radio-1] option optimize-link-performance outbound enable 100
# Enable uplink performance optimization for APs with model WA6330 in AP group apgroup1 and set the packet fragmentation threshold to 100 bytes.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option optimize-link-performance outbound enable 100
option roam-navigation
Use option roam-navigation enable to enable roaming navigation.
Use option roam-navigation disable to disable roaming navigation.
Use undo option roam-navigation to restore the default.
option roam-navigation { disable | enable rssi rssi-value { beacon-power power-value | probe-response-power power-value } }
In an AP group's radio view, roaming navigation is disabled.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 1 to 50. The recommended RSSI threshold is 20.
beacon-power power-value: Specifies the transmit power for beacon frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
probe-response-power power-value: Specifies the transmit power for probe response frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
If you set the transmit power for beacons or probe responses, the system uses the default transmit power to transmit other packets.
# Enable roaming navigation for AP ap1. Set the RSSI threshold to 10 and the transmit power for beacon frames to 10 dBm.
[Sysname-wlan-ap-ap1-radio-1] option roam-navigation enable rssi 10 beacon-power 10
# Enable roaming navigation for APs with model WA6330 in AP group apgroup1. Set the RSSI threshold to 10 and the transmit power for probe response frames to 10 dBm.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-1] option roam-navigation enable rssi 10 probe-response-power 10
option signal-ignore
Use option signal-ignore enable to enable an AP to ignore weak signals.
Use option signal-ignore disable to disable an AP from ignoring weak signals.
Use undo option signal-ignore to restore the default.
option signal-ignore { disable | enable rssi rssi-value }
In an AP group's radio view, a radio does not ignore weak signals.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 1 to 30. The recommended RSSI threshold is 10.
This feature enables an AP to ignore packets with a signal strength lower than the specified RSSI threshold. Enabling this feature might cause collisions and interference among devices on the same channel.
# Enable AP ap1 to ignore weak signals and set the RSSI threshold to 10.
[Sysname-wlan-ap-ap1-radio-1] option signal-ignore enable rssi 10
# Enable APs with model WA6330 in AP group 1 to ignore weak signals and set the RSSI threshold to 10.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] option signal-ignore enable rssi 10
option tpc
Use option tpc enable to enable per-packet transmit power control.
Use option tpc disable to disable per-packet transmit power control.
Use undo option tpc to restore the default.
option tpc { disable | enable [ minpower minpower | powerstep powerstep | rssistep rssistep | rssithreshold rssithreshold ] }
undo option tpc
In an AP group's radio view, per-packet transmit power control is disabled.
Radio view
minpower minpower: Specifies the minimum transmit power in the range of 1 to 27. The default value is 10.
powerstep powerstep: Specifies the step value for transmit power decrease, in the range of 1 to 15. The default value is 5.
rssistep rssistep: Specifies the step value for RSSI adjustment, in the range of 1 to 20. The default value is 10.
rssithreshold rssithreshold: Specifies the RSSI threshold for per-packet transmit power control, in the range of 20 to 95. The default value is 65.
This feature enables an AP to dynamically perform transmit power control on a per packet basis. For example, the AP reduces the transmit power when it sends packets to a client with high RSSI. This feature can reduce power consumption, radiation, and interference to improve user experience.
This feature is not applicable to 5 GHz radios of 802.11ac APs.
# Enable per-packet transmit power control for AP ap1, and set the minimum transmit power to 20.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] option tpc enable minpower 20
# Enable per-packet transmit power control for APs with model WA6330 in AP group apgroup1, and set the minimum transmit power to 20.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6330-radio-2] option tpc enable minpower 20
rrop software-retry
Use rrop software-retry enable to enable software retransmission and set the maximum number of software retransmissions.
Use rrop software-retry disable to disable software retransmission.
Use undo rrop software-retry to restore the default.
rrop software-retry { unicast [ eap ] | broadcast-multicast } enable count count
rrop software-retry { unicast [ eap ] | broadcast-multicast } disable
undo rrop software-retry { unicast [ eap ] | broadcast-multicast }
In an AP group's radio view, the maximum number of software retransmissions varies by device model.
Radio view
unicast: Configures software retransmission for unicast packets.
eap: Configures software retransmission for EAP packets.
broadcast-multicast: Configures software retransmission for broadcast and multicast packets.
count count: Specifies the maximum number of software retransmissions, in the range of 0 to 16.
# Set the maximum number of software retransmissions for EAP packets to the default for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] undo rrop software-retry unicast eap
# Set the maximum number of software retransmissions for broadcast and multicast packets to the default for radio 1 of APs with model WA6330 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6330-radio-1] undo rrop software-retry broadcast-multicast
sacp roam-optimize traffic-hold enable
Use sacp roam-optimize traffic-hold enable to enable data transmission holding during roaming.
Use undo sacp roam-optimize traffic-hold enable to disable data transmission holding during roaming.
sacp roam-optimize traffic-hold enable [ advanced ]
Data transmission holding during roaming is disabled.
advanced: Enables advanced data transmission holding during roaming. If you do not specify this keyword, only data transmission holding during roaming is enabled.
With data transmission holding during roaming enabled, the device caches the packets during client roaming and sends the packets to the client after the client roams successfully to reduce the packet loss during client roaming. With data transmission holding during roaming disabled, the device ages out the cached packets after a period of time and will not send the packets to the client. As a best practice, enable this feature in a scenario that is sensitive to packet loss.
With advanced data transmission holding during roaming enabled, the device caches the data packets and sends the cached packets to the client to reduce the packet loss when the client signal strength is lower than the RSSI threshold specified by client anti-sticky. With advanced data transmission holding during roaming disabled, the device ages out the cached packets after a period of time and will not send the packets to the client. As a best practice, enable advanced data transmission holding during roaming in the BSS roaming scenario enabled with client anti-sticky.
To make this feature take effect, enable client association at the AC and enable the AC to forward client data traffic.
This feature is not supported in an AC hierarchy network or inter-AC roaming network.
# Enable data transmission holding during roaming.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] sacp roam-optimize traffic-hold enable
wlan client inspect
Use wlan client inspect enable to enable client inspection.
Use wlan client inspect disable to disable client inspection.
Use undo wlan client inspect to restore the default.
wlan client inspect { disable | enable }
In AP view, an AP uses the configuration in AP group view.
In AP group view, client inspection is disabled.
AP view
AP group view
The client inspection feature enables you to view information about packets exchanged and time consumed in each stage of the client association process.
In the current software version, the client inspection feature supports only client association, client association failure, and IP address lease extension events.
# Enable client inspection for AP ap1.
[Sysname-wlan-ap-ap1] wlan client inspect enable
# Enable client inspection for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-ap-group-group1] wlan client inspect enable
