04-Network Connectivity
HomeSupportReference GuidesCommand ReferencesH3C Access Points Anchor AC Mode Command References(E2442 R2442)-6W10004-Network Connectivity
15-IPv6 basics commands
15-IPv6 basics commands 330.56 KB
IPv6 basics commands· 1
display ipv6 fib· 1
display ipv6 icmp statistics· 2
display ipv6 interface· 4
display ipv6 interface prefix· 8
display ipv6 neighbors· 9
display ipv6 neighbors count 10
display ipv6 pathmtu· 11
display ipv6 prefix· 12
display ipv6 rawip· 13
display ipv6 rawip verbose· 14
display ipv6 statistics· 17
display ipv6 tcp· 21
display ipv6 tcp verbose· 22
display ipv6 udp· 26
display ipv6 udp verbose· 27
ipv6 address· 30
ipv6 address anycast 31
ipv6 address auto· 31
ipv6 address auto link-local 32
ipv6 address eui-64· 33
ipv6 address link-local 34
ipv6 address prefix-number· 35
ipv6 extension-header drop enable· 36
ipv6 hop-limit 36
ipv6 hoplimit-expires enable· 37
ipv6 icmpv6 error-interval 38
ipv6 icmpv6 multicast-echo-reply enable· 39
ipv6 icmpv6 source· 39
ipv6 mtu· 40
ipv6 nd autoconfig managed-address-flag· 40
ipv6 nd autoconfig other-flag· 41
ipv6 nd dad attempts· 42
ipv6 nd ns retrans-timer 42
ipv6 nd nud reachable-time· 43
ipv6 nd ra dns search-list 44
ipv6 nd ra dns search-list suppress· 45
ipv6 nd ra dns server 46
ipv6 nd ra dns server suppress· 47
ipv6 nd ra halt 48
ipv6 nd ra hop-limit unspecified· 49
ipv6 nd ra interval 50
ipv6 nd ra invalid-delegated-prefix advertise enable· 50
ipv6 nd ra no-advlinkmtu· 51
ipv6 nd ra prefix· 52
ipv6 nd ra router-lifetime· 53
ipv6 nd router-preference· 54
ipv6 neighbor 54
ipv6 neighbor link-local minimize· 56
ipv6 neighbor stale-aging· 56
ipv6 neighbors max-learning-num·· 57
ipv6 pathmtu· 58
ipv6 pathmtu age· 58
ipv6 prefer temporary-address· 59
ipv6 prefix· 60
ipv6 redirects enable· 60
ipv6 temporary-address· 61
ipv6 unreachables enable· 62
local-proxy-nd enable· 63
proxy-nd enable· 63
reset ipv6 neighbors· 64
reset ipv6 pathmtu· 65
reset ipv6 statistics· 65
display ipv6 fib
Use display ipv6 fib to display IPv6 FIB entries.
display ipv6 fib [ ipv6-address [ prefix-length ] ]
ipv6-address: Displays IPv6 FIB entries for a destination IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 FIB entries.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128. If you do not specify the prefix length, this command displays the IPv6 FIB entry longest matching the IPv6 address.
# Display all IPv6 FIB entries for the public network.
<Sysname> display ipv6 fib
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination: ::1                                            Prefix length: 128
Nexthop     : ::1                                            Flags: UH
Time stamp : 0x1                                            Label: Null
Interface  : InLoop0                                        Token: Invalid
Destination count
Total number of destination addresses.
FIB entry count
Total number of IPv6 FIB entries.
Destination
Destination address.
Prefix length
Prefix length of the destination address.
Nexthop
Next hop address.
Flags
Route flag:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Black hole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Recursive route.
·     F—Fast re-route.
Time stamp
Time when the IPv6 FIB entry was generated.
Label
Inner MPLS label. For IPv6 FIB entries for the public network, this field displays Null.
Outgoing interface.
Token
Label switched path index number.
Use display ipv6 icmp statistics to display ICMPv6 packet statistics.
# Display ICMPv6 packet statistics.
<Sysname> display ipv6 icmp statistics
  Input: bad code                 0           too short                   0
          checksum error          0           bad length                  0
          path MTU changed        0           destination unreachable  0
          too big                   0           parameter problem         0
          echo request             0           echo reply                 0
          neighbor solicit        0           neighbor advertisement   0
          router solicit          0           router advertisement      0
          redirect                  0           router renumbering        0
 output: parameter problem      0           echo request                0
          echo reply               0           unreachable no route      0
          unreachable admin       0           unreachable beyond scope 0
          unreachable address    0           unreachable no port       0
          too big                   0           time exceed transit      0
          time exceed reassembly 0           redirect                   0
          ratelimited              0           other errors               0
bad code
Number of received packets with error codes.
too short
Number of received packets with the length too short.
checksum error
Number of received packets with checksum errors.
bad length
Number of received packets with incorrect packet size.
path MTU changed
Number of received packets with path MTU changed.
Number of destination unreachable packets that have been received.
too big
Number of received or sent oversized packets.
parameter problem
Number of received or sent packets with incorrect parameters.
echo request
Number of received or sent echo request packets.
echo reply
Number of received or sent echo reply packets.
neighbor solicit
Number of received NS packets.
Number of received NA packets.
router solicit
Number of received RS packets.
Number of received RA packets.
redirect
Number of received or sent redirect packets.
router renumbering
Number of received packets with router renumbering.
Number of sent packets to report the error that no route is available to the destination.
unreachable admin
Number of sent packets to report the error that the communication with the destination is administratively prohibited.
unreachable beyondscope
Number of sent packets to report the error that the source addresses is beyond the scope.
unreachable address
Number of address unreachable packets that have been sent.
unreachable no port
Number of port unreachable packets that have been sent.
time exceed transit
Number of sent packets to report the time exceeded in transmit error.
Number of sent packets to report the fragment reassembly time exceeded error.
ratelimited
Number of packets that were not sent out because of the rate limit.
other errors
Number of sent packets with other errors.
Use display ipv6 interface to display IPv6 interface information.
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
brief: Displays brief IPv6 interface information, including physical status, link-layer protocols, and IPv6 address. If you do not specify the keyword, this command displays detailed IPv6 interface information, including IPv6 configuration and operating information, and IPv6 packet statistics.
If you do not specify an interface, this command displays IPv6 information about all interfaces.
If you specify only the interface-type argument, this command displays IPv6 information about the interfaces of the specified type.
If you specify both the interface-type and the interface-number arguments, this command displays IPv6 information about the specified interface.
# Display IPv6 information about VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state: UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322 [TENTATIVE]
  Global unicast address(es):
    10::1234:56FF:FE65:4322, subnet is 10::/64 [TENTATIVE] [AUTOCFG]
      [valid lifetime 4641s/preferred lifetime 4637s]
    20::1234:56ff:fe65:4322, subnet is 20::/64 [TENTATIVE] [EUI-64]
    30::1, subnet is 30::/64 [TENTATIVE] [ANYCAST]
    40::2, subnet is 40::/64 [TENTATIVE] [DHCP]
    50::3, subnet is 50::/64 [TENTATIVE]
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FF65:4322
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                     0
  InTooShorts:                    0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                   0
  InBadOptions:                   0
  ReasmReqds:                     0
  ReasmOKs:                       0
  InFragDrops:                    0
  InFragTimeouts:                0
  OutFragFails:                   0
  InDelivers:                     0
  OutRequests:                    0
  OutForwDatagrams:              0
  InNoRoutes:                     0
  OutFragOKs:                     0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:            0
  OutMcastPkts:                  0
GigabitEthernet1/0/1 current state
Physical state of the interface:
·     Administratively DOWN—The interface has been administratively shut down by using the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     UP—The administrative and physical states of the interface are both up.
Link layer state of the interface:
·     DOWN—The link layer protocol state of the interface is down.
·     UP—The link layer protocol state of the interface is up.
IPv6 is enabled
IPv6 is enabled on the interface. This feature is automatically enabled after an IPv6 address is configured for an interface.
link-local address
Link-local address of the interface.
Global unicast addresses of the interface.
IPv6 address states:
·     TENTATIVE—Initial state. DAD is being performed or is to be performed on the address.
·     DUPLICATE—The address is not unique on the link.
·     PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state.
·     DEPRECATED—The address is beyond the preferred lifetime but in the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined for the address are processed correctly.
If a global unicast address is not manually configured, the following notations indicate how the address is obtained:
·     AUTOCFG—Stateless autoconfigured.
·     DHCP—Assigned by a DHCPv6 server.
·     EUI-64—Manually configured EUI-64 IPv6 address.
·     RANDOM—Random address automatically generated.
If the address is a manually configured anycast address, it is noted with ANYCAST.
valid lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are valid.
preferred lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are preferred.
Addresses of the multicast groups that the interface has joined.
MTU
MTU of the interface.
DAD is enabled.
·     If DAD is enabled, this field displays the number of attempts to send an NS message for DAD (set by using the ipv6 nd dad attempts command).
·     If DAD is disabled, this field displays ND DAD is disabled. To disable DAD, set the number of attempts to 0.
ND reachable time
Time during which a neighboring device is reachable.
Interval for retransmitting an NS message.
Hosts obtained IPv6 addresses through stateless autoconfiguration.
InReceives
Received IPv6 packets, including error messages.
InTooShorts
Received IPv6 packets that are too short. For example, the received IPv6 packet is less than 40 bytes.
InTruncatedPkts
Received IPv6 packets with a length less than the payload length field specified in the packet header.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the hop limit field specified in the packet header.
InBadHeaders
Received IPv6 packets with incorrect basic headers.
InBadOptions
Received IPv6 packets with incorrect extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of reassembled IPv6 packets.
InFragDrops
Received IPv6 fragments that are discarded because of certain errors.
InFragTimeouts
Received IPv6 fragments that are discarded because the amount of time they stay in the system buffer exceeds the specified interval.
OutFragFails
IPv6 packets that fail to be fragmented on the output interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that are delivered to user protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 user protocols.
OutForwDatagrams
IPv6 packets forwarded by the interface.
InNoRoutes
Received IPv6 packets that are discarded because no matching route can be found.
InTooBigErrors
Received IPv6 packets that fail to be forwarded because they exceeded the Path MTU.
OutFragOKs
Fragmented IPv6 packets on the output interface.
OutFragCreates
Number of IPv6 fragments on the output interface.
InMcastPkts
Received IPv6 multicast packets.
InMcastNotMembers
Received IPv6 multicast packets that are discarded because the interface is not in the multicast group.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
Received IPv6 packets that are discarded due to invalid destination addresses.
InDiscards
Received IPv6 packets that are discarded due to resource problems rather than packet errors.
OutDiscards
IPv6 packets that fail to be sent due to resource problems rather than packet errors.
# Display brief IPv6 information about all interfaces.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                                 Physical Protocol IPv6 Address
Vlan-interface1                          down      down      Unassigned
Vlan-interface2                          up         up        2001::1
Vlan-interface100                        up         up        Unassigned
(s): spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link is temporarily established on demand or does not exist.
Name of the interface.
Physical
·     *down—The interface has been administratively shut down by using the shutdown command.
·     down—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     up—The administrative and physical states of the interface are both up.
Protocol
Link layer protocol state of the interface:
·     down—The network layer protocol state of the interface is down.
·     up—The network layer protocol state of the interface is up.
IPv6 Address
IPv6 address of the interface.
·     If multiple global unicast addresses are configured, this field displays the lowest address.
·     If no global unicast address is configured, this field displays the link-local address.
·     If no address is configured, this field displays Unassigned.
Use display ipv6 interface prefix to display IPv6 prefix information for an interface.
# Display IPv6 prefix information for VLAN-interface 10.
<Sysname> display ipv6 interface vlan-interface10 prefix
Prefix: 1001::/65                                          Origin: ADDRESS
Age:    -                                                     Flag:   AL
Lifetime(Valid/Preferred): 2592000/604800
Prefix: 2001::/64                                          Origin: STATIC
Age:    -                                                     Flag:   L
Lifetime(Valid/Preferred): 3000/2000
Prefix: 3001::/64                                          Origin: RA
Age:    600                                                   Flag:   A
Lifetime(Valid/Preferred): -
Table 5 Command output
Filed
Prefix
IPv6 address prefix.
Origin
How the prefix is generated:
·     STATIC—Manually configured by using the ipv6 nd ra prefix command.
·     RA—Advertised in RA messages after stateless autoconfiguration is enabled.
·     ADDRESS—Generated by a manually configured address.
Age
Aging time in seconds. If the prefix does not age out, this field displays a hyphen (-).
Flag
Flags carried in RA messages. If no flags are available, this field displays a hyphen (-).
·     L—The address with the prefix is directly reachable on the link.
·     A—The prefix is used for stateless autoconfiguration.
Lifetime
Lifetime in seconds advertised in RA messages. If the prefix does not need to be advertised, this field displays a hyphen (-).
·     Valid—Valid lifetime of the prefix.
·     Preferred—Preferred lifetime of the prefix.
ipv6 nd ra prefix
Use display ipv6 neighbors to display IPv6 neighbor information.
display ipv6 neighbors { ipv6-address | all | dynamic | interface interface-type interface-number | static | vlan vlan-id } [ verbose ]
ipv6-address: Specifies the IPv6 address of a neighbor whose information is displayed.
all: Displays information about all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information about all neighbors acquired dynamically.
static: Displays information about all neighbors configured statically.
vlan vlan-id: Displays information about neighbors in the specified VLAN. The value range for VLAN ID is 1 to 4094.
verbose: Displays detailed neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
Type: S-Static    D-Dynamic    O-Openflow    R-Rule    I-Invalid
IPv6 address                   Link layer     VID  Interface      State T  Age
FE80::200:5EFF:FE32:B800    0000-5e32-b800 N/A  GE1/0/1        REACH D  10
# Display detailed information about all neighbors.
<Sysname> display ipv6 neighbors all verbose
IPv6 Address: FE80::200:5EFF:FE32:B800
Link Layer  : 0000-5e32-b800      VID : N/A  Interface: GE1/0/1
State        : REACH                 Type: IS   Age      : -
Vpn-instance: No Vrf
Nickname    : 0x0
Table 6 Command output
IPv6 Address
IPv6 address of the neighbor.
Link Layer
Link layer address (MAC address) of the neighbor.
VID
VLAN or virtual switch instance (VSI) to which the interface connected to a neighbor belongs.
Interface connected to the neighbor.
State of the neighbor:
·     INCMP—The address is being resolved. The link layer address of the neighbor is unknown.
·     REACH—The neighbor is reachable.
·     STALE—Whether the neighbor is reachable is unknown. The device does not verify the reachability any longer unless data is sent to the neighbor.
·     DELAY—Whether the neighbor is reachable is unknown. The device sends an NS message after a delay.
·     PROBE—Whether the neighbor is reachable is unknown. The device sends an NS message to verify the reachability of the neighbor.
Neighbor information type:
·     Static—Statically configured.
·     Dynamic—Dynamically obtained.
·     O—Learned from the OpenFlow module. This field is not supported in the current software version.
·     R—Learned from the Portal module.
·     Invalid—Invalid.
Age
A hyphen (-) indicates a static entry.
For a dynamic entry, this field displays the elapsed time in seconds. If the neighbor is never reachable, this field displays a pound sign (#).
Vpn-instance
Name of a VPN or [No Vrf] with no VPN configured.
Nickname
Nickname of a neighbor entry. The name is a string of four hexadecimal numbers.
ipv6 neighbor
Use display ipv6 neighbors count to display the number of neighbor entries.
display ipv6 neighbors { { all | dynamic | static } | interface interface-type interface-number | vlan vlan-id } count
all: Displays the total number of all neighbor entries, including neighbor entries created dynamically and configured statically.
dynamic: Displays the total number of neighbor entries created dynamically.
static: Displays the total number of neighbor entries configured statically.
vlan vlan-id: Displays the total number of neighbor entries in the specified VLAN. The value range for VLAN ID is 1 to 4094.
# Display the total number of neighbor entries created dynamically.
<Sysname> display ipv6 neighbors dynamic count
 Total number of dynamic entries: 2
Use the display ipv6 pathmtu command to display IPv6 Path MTU information.
display ipv6 pathmtu { ipv6-address | { all | dynamic | static } [ count ] }
ipv6-address: Specifies the destination IPv6 address for which the Path MTU information is to be displayed.
all: Displays all Path MTU information for the public network.
dynamic: Displays all dynamic Path MTU information.
static: Displays all static Path MTU information.
count: Displays the total number of Path MTU entries.
# Display all Path MTU information.
<Sysname> display ipv6 pathmtu all
IPv6 destination address                PathMTU   Age   Type
1:2::3:2                                   1800       -      Static
1:2::4:2                                   1400       10     Dynamic
1:2::5:2                                   1280       10     Dynamic
# Displays the total number of Path MTU entries.
<Sysname> display ipv6 pathmtu all count
Total number of entries: 3
Table 7  Command output
PathMTU
Path MTU value on the network path to an IPv6 address.
Age
Time for a Path MTU to live. For a static Path MTU, this field displays a hyphen (-).
Path MTU type:
·     Dynamic—Dynamically negotiated.
Total number of Path MTU entries.
ipv6 pathmtu
reset ipv6 pathmtu
display ipv6 prefix
Use display ipv6 prefix to display information about IPv6 prefixes, including dynamic and static prefixes.
prefix-number: Specifies the ID of an IPv6 prefix, in the range of 1 to 1024. If you do not specify an IPv6 prefix ID, this command displays information about all IPv6 prefixes.
A static IPv6 prefix is configured by using the ipv6 prefix command.
A dynamic IPv6 prefix is obtained from the DHCPv6 server, and its prefix ID is configured by using the ipv6 dhcp client pd command. For more information about prefix generation, see DHCPv6 client configuration in Network Connectivity Configuration Guide .
# Display information about all IPv6 prefixes.
<Sysname> display ipv6 prefix
Number  Prefix                                     Type
1        1::/16                                     Static
2        11:77::/32                                Dynamic
# Display information about the IPv6 prefix with prefix ID 1.
<Sysname> display ipv6 prefix 1
Number: 1
Type  : Dynamic
Prefix: ABCD:77D8::/32
Preferred lifetime 90 sec, valid lifetime 120 sec
Table 8 Command output
Number
Prefix ID.
Prefix type:
·     Static—Static IPv6 prefix.
·     Dynamic—Dynamic IPv6 prefix.
Prefix
Prefix and its length. If no prefix is obtained, this field displays Not-available.
Preferred lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
Valid lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
ipv6 dhcp client pd
ipv6 prefix
display ipv6 rawip
Use display ipv6 rawip to display brief information about IPv6 RawIP connections.
display ipv6 rawip
# Display brief information about IPv6 RawIP connections.
<Sysname> display ipv6 rawip
Local Addr            Foreign Addr        Protocol PCB
2001:2002:2003:2     3001:3002:3003:3   58        0x0000000000000009
004:2005:2006:20     004:3005:3006:30
07:2008                07:3008
2002::100             2002::138            58        0x0000000000000008
::                     ::                     58        0x0000000000000002
Table 9 Command output
Local Addr
Local IPv6 address.
Foreign Addr
Peer IPv6 address.
Protocol
Protocol number.
PCB
PCB index.
Use display ipv6 rawip verbose to display detailed information about IPv6 RawIP connections.
display ipv6 rawip verbose [ pcb pcb-index ]
pcb pcb-index: Displays detailed information about IPv6 RawIP connections of the specified PCB. The value range for the pcb-index argument is 1 to 16.
# Display detailed information about an IPv6 RawIP connection.
<Sysname> display ipv6 rawip verbose
Total RawIP socket number: 1
 Creator: ping ipv6[320]
 State: N/A
 Options: N/A
 Error: 0
 Type: 3
 Protocol: 58
 Connection info: src = ::, dst = ::
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Inpcb vflag: INP_IPV6
 Hop limit: 255 (minimum hop limit: 0)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 10 Command output
Total number of IPv6 RawIP sockets.
Creator
Task name of the socket. The process number is in the square brackets.
Socket state:
·     NOFDREF—The user has closed the connection.
·     ISCONNECTED—The connection has been established.
·     ISCONNECTING—The connection is being established.
·     ISDISCONNECTING—The connection is being interrupted.
·     ASYNC—Asynchronous mode.
·     ISDISCONNECTED—The connection has been terminated.
·     PROTOREF—Indicates strong protocol reference.
·     N/A—None of above state.
Options
Socket options:
·     SO_DEBUG—Records socket debugging information.
·     SO_ACCEPTCONN—Enables the server to listen connection requests.
·     SO_REUSEADDR—Allows the local address reuse.
·     SO_KEEPALIVE—Requires the protocol to test whether the connection is still alive.
·     SO_DONTROUTE—Bypasses the routing table query for outgoing packets because the destination is in a directly connected network.
·     SO_BROADCAST—Supports broadcast packets.
·     SO_LINGER—Closes the socket. The system can still send remaining data in the socket send buffer.
·     SO_OOBINLINE—Stores the out-of-band data in the input queue.
·     SO_REUSEPORT—Allows the local port reuse.
·     SO_TIMESTAMP—Records the timestamps of the input packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
·     SO_NOSIGPIPE—Disables the socket from sending data. As a result, a sigpipe cannot be established when a return failure occurs.
·     SO_TIMESTAMPNS—Has a similar function with the timestamp, accurate to nanoseconds.
·     SO_KEEPALIVETIME—Sets a keepalive time. This option is supported in TCP.
·     SO_FILTER—Supports setting the packet filter criterion. This option is available for OSI Socket and RawIP.
·     SO_USCBINDEX—Obtains the user profile index from the received packets.
·     N/A—No options are set.
Error
Error code.
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     drop—Number of dropped packets.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     RCVATMARK—Receiving tag.
¡     N/A—None of the above states.
Displays send buffer information in the following order:
·     cc—Used space.
Socket type:
·     1SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of protocol using the socket. 58 represents ICMP.
Connection info
Connection information, including source and destination IPv6 addresses.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IPv6 options.
·     INP_RECVRETOPTS—Receives replied IPv6 options.
·     INP_RECVDSTADDR—Receives destination IPv6 address.
·     INP_HDRINCL—Provides the entire IPv6 header.
·     INP_REUSEADDR—Reuses the IPv6 address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     IN6P_IPV6_V6ONLY—Only supports IPv6 protocol stack.
·     IN6P_PKTINFO—Receives the source IPv6 address and input interface of the packet.
·     IN6P_HOPLIMIT—Receives the hop limit.
·     IN6P_HOPOPTS—Receives the hop-by-hop options extension header.
·     IN6P_DSTOPTS—Receives the destination options extension header.
·     IN6P_RTHDR—Receives the routing extension header.
·     IN6P_RTHDRDSTOPTS—Receives the destination options extension header preceding the routing extension header.
·     IN6P_TCLASS—Receives the traffic class of the packet.
·     IN6P_AUTOFLOWLABEL—Attaches a flow label automatically.
·     IN6P_RFC2292—Uses the API specified in RFC 2292.
·     IN6P_MTU—Discovers differences in the MTU size of every link along a given data path. TCP does not support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_USEICMPSRC—Uses the specified IPv6 address as the source IPv6 address for outgoing ICMP packets.
·     INP_SYNCPCB—Waits until Internet PCB is synchronized.
·     N/A—None of the above flags.
Inpcb extflag
Extension flags in the Internet PCB:
·     INP_EXTRCVPVCIDX—Records the PVC index of the received packet.
·     INP_RCVPWID—Records the PW ID of the received packet.
Inpcb vflag
IP version flag in the Internet PCB:
·     INP_IPV4—IPv4 protocol.
·     INP_IPV6—IPv6 protocol.
·     INP_IPV6PROTO—Creates an Internet PCB based on IPv6 protocol.
·     INP_TIMEWAIT—In TIMEWAIT state.
·     INP_ONESBCAST—Sends broadcast packets.
·     INP_DROPPED—Protocol dropped flag.
·     INP_SOCKREF—Strong socket reference.
·     INP_DONTBLOCK—Do not block synchronization of the Internet PCB.
Hop limit
Hop limit in the Internet PCB.
Send VRF
VRF from which packets are sent.
Receive VRF
VRF from which packets are received.
Use display ipv6 statistics to display IPv6 and ICMPv6 packet statistics.
# Display IPv6 and ICMPv6 packet statistics.
<Sysname> display ipv6 statistics
  IPv6 statistics:
    Sent packets:
      Total:      0
        Sent locally:         0            Forwarded:              0
        Raw packets:          0            Discarded:              0
        Fragments:            0            Fragments failed:      0
        Routing failed:       0
    Received packets:
      Total:      0
        Received locally:     0            Hop limit exceeded:  0
        Fragments:             0            Reassembled:           0
        Reassembly failures:  0            Reassembly timeout:  0
        Format errors:         0            Option errors:        0
        Protocol errors:      0
  ICMPv6 statistics:
    Sent packets:
      Total:      0
        Unreachable:           0             Too big:                0
        Hop limit exceeded:   0             Reassembly timeouts: 0
        Parameter problems:   0
        Echo requests:         0             Echo replies:          0
        Neighbor solicits:    0             Neighbor adverts:     0
        Router solicits:      0             Router adverts:        0
        Redirects:             0              Router renumbering:   0
      Send failed:
        Rate limitation:      0             Other errors:          0
    Received packets:
      Total:      0
        Checksum errors:      0             Too short:              0
        Bad codes:             0
        Parameter problems:   0             Unknown error types:   0
        Unknown info types:   0
      Deliver failed:
        Bad length:           0
Table 11 Command output
IPv6 statistics:
Sent packets:
Total:
Sent locally:
Forwarded:
Raw packets:
Discarded:
Fragments:
Fragments failed:
Routing failed:
Statistics for sent IPv6 packets:
·     Total—Total number of packets that have been locally sent and forwarded.
·     Sent locally—Number of locally sent packets.
·     Forwarded—Number of forwarded packets.
·     Raw packets—Number of packets sent by using a raw socket.
·     Discarded—Number of discarded packets.
·     Fragments—Number of sent fragments.
·     Fragments failed—Number of fragments that were failed to send.
·     Routing failed—Number of packets with routing failures.
Received packets:
Total:
Received locally:
Hop limit exceeded:
Fragments:
Reassembled:
Reassembly timeout:
Format errors:
Option errors:
Protocol errors:
Statistics for received IPv6 packets:
·     Total—Total number of received packets.
·     Received locally—Number of received packets that are destined for the device.
·     Hop limit exceeded—Number of packets with hop limit exceeded.
·     Fragments—Number of received fragments.
·     Reassembled—Number of reassembled packets.
·     Reassembly failures—Number of packets with reassembly failures.
·     Reassembly timeout—Number of packets with reassembly timed out.
·     Format errors—Number of packets with format errors.
·     Option errors—Number of packets with option errors.
·     Protocol errors—Number of packets with protocol errors.
ICMPv6 statistics:
ICMPv6 message statistics.
Sent packets:
Total:
Unreached:
Too big:
Hop limit exceeded:
Parameter problems:
Echo requests:
Echo replies:
Neighbor solicits:
Neighbor adverts:
Router solicits:
Router adverts:
Redirects:
Router renumbering
Sent failed:
Rate limitation:
Other errors:
Statistics for sent ICMPv6 messages:
·     Total—Total number of sent messages.
·     Unreached—Number of Destination Unreachable messages.
·     Too big—Number of Packet Too Big messages.
·     Hop limit exceeded—Number of Hop Limit Exceeded messages.
·     Reassembly timeouts—Number of Fragment Reassembly Time Exceeded messages.
·     Parameter problems—Number of Parameter Problem messages.
·     Echo requests—Number of Echo Requests.
·     Echo replies—Number of Echo Replies.
·     Neighbor solicits—Number of Neighbor Solicitation messages.
·     Neighbor adverts—Number of Neighbor Advertisement messages.
·     Router solicits—Number of Router Solicitation messages.
·     Router adverts—Number of Router Advertisement messages.
·     Redirects—Number of Redirect messages.
·     Router renumbering—Number of Router Renumbering messages. This field is not supported in the current software version.
·     Sent failed—Number of messages that were failed to send locally.
·     Rate limitation—Number of unsent messages because of rate limiting.
·     Other errors—Number of messages with other errors.
Received packets:
Total:
Checksum errors:
Too short:
Bad codes:
Unreachable:
Too big:
Hop limit exceeded:
Parameter problems:
Echo requests:
Echo replies:
Neighbor solicits:
Neighbor adverts:
Router solicits:
Router adverts:
Redirects:
Router renumbering:
Unknown info types:
Deliver failed:
Bad length:
Statistics for received ICMPv6 messages:
·     Total—Total number of received messages.
·     Checksum errors—Number of messages with checksum errors.
·     Too short—Number of messages with a too short length.
·     Bad codes—Number of messages with error codes.
·     Unknown error types—Number of messages with unknown error types.
·     Unknown info types—Number of messages with unknown information types.
·     Deliver failed—Number of messages with local delivery failures.
·     Bad length—Number of messages with error length.
display ipv6 tcp
Use display ipv6 tcp to display brief information about IPv6 TCP connections.
display ipv6 tcp
# Display brief information about IPv6 TCP connections.
<Sysname> display ipv6 tcp
*: TCP MD5 Connection
 LAddr->port         FAddr->port       State        PCB
*2001:2002:2003:2   3001:3002:3003:3 ESTABLISHED 0x000000000000c387
07:2008->1200        07:3008->1200
2001::1->23          2001::5->1284     ESTABLISHED 0x0000000000000008
2003::1->25          2001::2->1283     LISTEN       0x0000000000000009
Table 12 Command output
Indicates that the TCP connection uses MD5 authentication.
LAddr->port
Local IPv6 address and port number.
FAddr->port
Peer IPv6 address and port number.
IPv6 TCP connection state:
·     CLOSED—The server receives a disconnection request's reply from the client.
·     LISTEN—The server is waiting for connection requests.
·     SYN_SENT—The client is waiting for the server to reply to the connection request.
·     SYN_RCVD—The server receives a connection request.
·     ESTABLISHED—The server and client have established connections and can transmit data bidirectionally.
·     CLOSE_WAIT—The server receives a disconnection request from the client.
·     FIN_WAIT_1—The client is waiting for the server to reply to a disconnection request.
·     CLOSING—The server and client are waiting for peer's disconnection reply when receiving disconnection requests from each other.
·     LAST_ACK—The server is waiting for the client to reply to a disconnection request.
·     FIN_WAIT_2—The client receives a disconnection reply from the server.
·     IME_WAIT—The client receives a disconnection request from the server.
PCB
PCB index.
Use display ipv6 tcp verbose to display detailed information about IPv6 TCP connections.
display ipv6 tcp verbose [ pcb pcb-index ]
pcb pcb-index: Displays detailed information about IPv6 TCP connections of the specified PCB. The value range for the pcb-index argument is 1 to 16.
# Display detailed information about an IPv6 TCP connection.
<Sysname> display ipv6 tcp verbose
 Creator: bgpd[199]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/state): 0 / 65536 / 1 / 0 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65536 / 512 / N/A
 Type: 1
 Protocol: 6
 Connection info: src = 2001::1->179 ,  dst = 2001::2->4181
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 13 Command output
TCP inpcb number
Number of IPv6 TCP Internet PCBs.
tcpcb number
Number of IPv6 TCP PCBs (excluding PCBs of TCP in TIME_WAIT state).
NSR standby
ID of the IRF member device and number of the slot where the NSR standby card resides. This field displays N/A if no NSR standby card is present.
Creator
Socket state:
Options
Socket options:
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Number of the protocol using the socket. 6 represents TCP.
Connection info
Connection information, including source IPv6 address, source port number, destination IPv6 address, and destination port number.
Inpcb flags
Inpcb extflag
·     INP_EXTDONTDROP—Does not drop the received packet.
·     INP_EXLISTEN—Listening socket.
Inpcb vflag
IP version flags in the Internet PCB:
Hop limit
Connection state
·     TIME_WAIT—The client receives a disconnection request from the server.
TCP options
TCP options:
·     TF_MD5SIG—Enables MD5 signature.
·     TF_PASSWORD—The MD5 password is configured.
·     TF_NODELAY—Disables the Nagle algorithm that buffers the sent data inside the TCP.
·     TF_NOOPT—No TCP options.
·     TF_NOPUSH—Forces TCP to delay sending any TCP data until a full sized segment is buffered in the TCP buffers.
·     TF_BINDFOREIGNADDR—Binds the peer IP address.
·     TF_NSR—Enables TCP NSR.
·     TF_REQ_SCALE—Enables the TCP window scale option.
·     TF_REQ_TSTMP—Enables the time stamp option.
·     TF_SACK_PERMIT—Enables the TCP selective acknowledgement option.
NSR state
NSR state of the TCP connection:
·     CLOSED—Closed (initial) state.
·     CLOSING—The connection is to be closed.
·     ENABLED—The connection backup is enabled.
·     OPEN—The connection synchronization has started.
·     PENDING—The connection backup is not ready.
·     READY—The connection backup is ready.
·     SMOOTH—The connection data is being smoothed.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
Send VRF
Receive VRF
display ipv6 udp
Use display ipv6 udp to display brief information about IPv6 UDP connections.
display ipv6 udp
# Displays brief information about IPv6 UDP connections.
<Sysname> display ipv6 udp
 LAddr->port         FAddr->port         PCB
 2001:2002:2003:2   3001:3002:3003:3   0x000000000000c387
 2001::1->23         2001::5->1284       0x0000000000000008
 2003::1->25         2001::2->1283       0x0000000000000009
Table 14 Command output
LAddr->port
FAddr->port
PCB
PCB index.
Use display ipv6 udp verbose to display detailed information about IPv6 UDP connections.
display ipv6 udp verbose [ pcb pcb-index ]
pcb pcb-index: Displays detailed information about IPv6 UDP connections of the specified PCB. The value range for the pcb-index argument is 1 to 16.
# Display detailed information about an IPv6 UDP connection.
<Sysname> display ipv6 udp verbose
Total UDP socket number: 1
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Type: 2
 Protocol: 17
 Connection info: src = ::->69, dst = ::->0
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 15 Command output
Total number of IPv6 UDP sockets.
Creator
Task name of the socket. The progress number is in the square brackets.
Socket state:
Options
Socket options:
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Number of the protocol using the socket. 17 represents UDP.
Connection info
Inpcb flags
Inpcb extflag
Inpcb vflag
Hop limit
Send VRF
Receive VRF
ipv6 address
Use ipv6 address to configure an IPv6 global unicast address for an interface.
Use undo ipv6 address to delete an IPv6 global unicast address of the interface.
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No IPv6 global unicast address is configured for an interface.
Interface view
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 1 to 128.
Like public IPv4 addresses, IPv6 global unicast addresses are assigned to ISPs. This type of address allows for prefix aggregation to reduce the number of global routing entries.
If you do not specify any parameters, the undo ipv6 address command deletes all IPv6 addresses of an interface.
# Set the IPv6 global unicast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64
Use ipv6 address anycast to configure an IPv6 anycast address for an interface.
Use undo ipv6 address anycast to delete the IPv6 anycast address of the interface.
undo ipv6 address { ipv6-address prefix-length | ipv6-address/prefix-length } anycast
No IPv6 anycast address is configured for an interface.
Interface view
ipv6-address: Specifies an IPv6 anycast address.
# Set the IPv6 anycast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 anycast
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 anycast
ipv6 address auto
Use ipv6 address auto to enable the stateless address autoconfiguration feature on an interface, so that the interface can automatically generate a global unicast address.
Use undo ipv6 address auto to disable this feature.
ipv6 address auto
The stateless address autoconfiguration feature is disabled.
Interface view
After a global unicast address is generated through stateless autoconfiguration, a link-local address is generated automatically.
To delete the global unicast address and the link-local address that are automatically generated, use either of the following commands:
·     undo ipv6 address auto
·     undo ipv6 address
# Enable stateless address autoconfiguration on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address auto
Use ipv6 address auto link-local to automatically generate a link-local address for an interface.
Use undo ipv6 address auto link-local to restore the default.
No link-local address is configured on an interface. A link-local address is automatically generated after an IPv6 global unicast address is configured for the interface.
Interface view
Link-local addresses are used for neighbor discovery and stateless autoconfiguration on the local link. Packets using link-local addresses as the source or destination addresses cannot be forwarded to other links.
After an IPv6 global unicast address is configured for an interface, a link-local address is automatically generated. This link-local address is the same as the one generated by using the ipv6 address auto link-local command.
The undo ipv6 address auto link-local command deletes only the link-local addresses generated through the ipv6 address auto link-local command. If the undo command is executed on an interface with an IPv6 global unicast address configured, the interface still has a link-local address.
You can also manually assign an IPv6 link-local address for an interface by using the ipv6 address link-local command. Manual assignment takes precedence over automatic generation for IPv6 link-local addresses.
·     If you first use automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated address.
·     If you first use manual assignment and then automatic generation, both of the following occur:
¡     The automatically generated link-local address does not take effect.
¡     The link-local address of an interface is still the manually assigned address.
If you delete the manually assigned address, the automatically generated link-local address takes effect.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address eui-64
Use ipv6 address eui-64 to configure an EUI-64 IPv6 address for an interface.
Use undo ipv6 address eui-64 to delete an EUI-64 IPv6 address from an interface.
undo ipv6 address { ipv6-address prefix-length | ipv6-address/prefix-length } eui-64
No EUI-64 IPv6 address is configured for an interface.
Interface view
ipv6-address prefix-length: Specifies an IPv6 address and IPv6 prefix length. The ipv6-address and prefix-length arguments specify the prefix of an EUI-64 IPv6 address. The value range for the prefix-length argument is 1 to 64. The IPv6 address and IPv6 prefix length support the following formats:
·     ipv6-address/prefix-length. For example: 2001::1/64.
·     ipv6-address prefix-length. For example: 2001::1 64.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface ID. To display the EUI-64 IPv6 address, use the display ipv6 interface command.
The prefix length of an EUI-64 IPv6 address cannot be greater than 64.
# Configure an EUI-64 IPv6 address for VLAN-interface 100. The prefix of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the device.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 eui-64
Use ipv6 address link-local to configure a link-local address for the interface.
Use undo ipv6 address link-local to restore the default.
undo ipv6 address ipv6-address link-local
No link-local address is configured for the interface.
Interface view
ipv6-address: Specifies an IPv6 link-local address. The first 10 bits of an address must be 1111111010 (binary). The first group of hexadecimals in the address must be FE80 to FEBF.
Manual assignment takes precedence over automatic generation.
If you use automatic generation, and then use manual assignment, the manually assigned link-local address overwrites the one that is automatically generated.
If you use manual assignment and then use automatic generation, both of the following occur:
·     The automatically generated link-local address does not take effect.
·     The manually assigned link-local address of an interface remains.
After you delete the manually assigned address, the automatically generated link-local address takes effect. For automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
Use ipv6 address prefix-number to specify an IPv6 prefix for an interface to automatically generate an IPv6 global unicast address and advertise the prefix.
Use undo ipv6 address prefix-number to restore the default.
No IPv6 prefix is specified for IPv6 address autoconfiguration.
Interface view
prefix-number: Specifies an IPv6 prefix by its ID in the range of 1 to 1024. The specified IPv6 prefix can be manually configured or obtained through DHCPv6.
sub-prefix: Specifies the sub-prefix bit and host bit for the IPv6 global unicast address.
prefix-length: Specifies the sub-prefix length in the range of 1 to 128.
This command enables an interface to automatically generate an IPv6 global unicast address based on the specified IPv6 prefix, sub-prefix bit, and host bit.
An interface can generate only one IPv6 global unicast address based on the prefix specified by using the ipv6 address command. To configure the interface to generate a new IPv6 address, execute the undo ipv6 address command to delete the configuration, and then execute the ipv6 address command.
# Configure a static IPv6 prefix AAAA::/16 and assign ID 1 to the prefix. Configure VLAN-interface 100 to use this prefix to generate the IPv6 address AAAA:CCCC:DDDD::10/32 and advertise this prefix.
[Sysname] ipv6 prefix 1 AAAA::/16
[Sysname-Vlan-interface100] ipv6 address 1 BBBB:CCCC:DDDD::10/32
# Configure VLAN-interface 10 to obtain an IPv6 prefix through DHCPv6 and assign ID 2 to the obtained prefix. Configure VLAN-interface 100 to use the obtained prefix to generate the IPv6 address AAAA:CCCC:DDDD::10/32 and advertise the prefix.
[Sysname-Vlan-interface10] ipv6 dhcp client pd 2 rapid-commit option-group 1
[Sysname-Vlan-interface10] quit
[Sysname-Vlan-interface100] ipv6 address 2 BBBB:CCCC:DDDD::10/32
ipv6 prefix
ipv6 dhcp client pd
Use ipv6 extension-header drop enable to enable a device to discard IPv6 packets that contain extension headers.
Use undo ipv6 extension-header drop enable to disable a device from discarding IPv6 packets that contain extension headers.
A device does not discard IPv6 packets that contain extension headers.
This feature enables a device to discard a received IPv6 packet in which the extension headers cannot be processed by the device.
# Enable the device to discard IPv6 packets that contain extension headers.
[Sysname] ipv6 extension-header drop enable
ipv6 hop-limit
Use ipv6 hop-limit to set the Hop Limit field in the IPv6 header.
Use undo ipv6 hop-limit to restore the default.
ipv6 hop-limit value
undo ipv6 hop-limit
The hop limit is 64.
value: Specifies the number of hops, in the range of 1 to 255.
The hop limit determines the number of hops that an IPv6 packet generated by the device can travel.
The device advertises the hop limit in RA messages. All RA message receivers use the advertised value to fill in the Hop Limit field for IPv6 packets to be sent. To disable the device from advertising the hop limit, use the ipv6 nd ra hop-limit unspecified command.
# Set the maximum number of hops to 100.
[Sysname] ipv6 hop-limit 100
Use ipv6 hoplimit-expires enable to enable sending ICMPv6 time exceeded messages.
Use undo ipv6 hoplimit-expires to disable sending ICMPv6 time exceeded messages.
undo ipv6 hoplimit-expires enable
Sending ICMPv6 time exceeded messages is enabled.
ICMPv6 time exceeded messages are sent to the source of IPv6 packets after the device discards IPv6 packets because hop or reassembly times out.
To prevent too many ICMPv6 error messages from affecting device performance, disable this feature. Even with the feature disabled, the device still sends fragment reassembly time exceeded messages.
# Disable sending ICMPv6 time exceeded messages.
[Sysname] undo ipv6 hoplimit-expires enable
Use ipv6 icmpv6 error-interval to set the bucket size and the interval for tokens to arrive in the bucket for ICMPv6 error messages.
Use undo ipv6 icmpv6 error-interval to restore the default.
The bucket allows a maximum of 10 tokens, and a token is placed in the bucket every 100 milliseconds.
interval: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds. To disable the ICMPv6 rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200.
This command limits the rate at which ICMPv6 error messages are sent. Use this command to prevent network congestion caused by excessive ICMPv6 error messages generated within a short period. A token bucket algorithm is used with one token representing one ICMPv6 error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMPv6 error message is sent. When the bucket is empty, ICMPv6 error messages are not sent until a new token is placed in the bucket.
# Set the bucket size to 40 tokens and the interval for tokens to arrive in the bucket to 200 milliseconds for ICMPv6 error messages.
[Sysname] ipv6 icmpv6 error-interval 200 40
Use ipv6 icmpv6 multicast-echo-reply enable to enable replying to multicast echo requests.
Use undo ipv6 icmpv6 multicast-echo-reply to restore the default.
undo ipv6 icmpv6 multicast-echo-reply enable
The device is disabled from replying to multicast echo requests.
If a host is configured to reply to multicast echo requests, an attacker can use this mechanism to attack the host. For example, the attacker can send an echo request to a multicast address with Host A as the source. All hosts in the multicast group will send echo replies to Host A.
To prevent attacks, do not enable the device to reply to multicast echo requests unless necessary.
# Enable replying to multicast echo requests.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
ipv6 icmpv6 source
Use ipv6 icmpv6 source to specify an IPv6 address as the source address for outgoing ICMPv6 packets.
Use undo ipv6 icmpv6 source to remove the specified IPv6 source address for outgoing ICMPv6 packets.
ipv6 icmpv6 source ipv6-address
No IPv6 source address for outgoing ICMPv6 packets is specified. The device uses the IPv6 address of the sending interface as the source IPv6 address for outgoing ICMPv6 packets.
It is a good practice to specify the IPv6 address of the loopback interface as the source IPv6 address for outgoing ping echo request and ICMPv6 error messages. This feature helps users to easily locate the sending device.
# Specify IPv6 address 1::1 as the source address for outgoing ICMPv6 packets.
[Sysname] ipv6 icmpv6 source 1::1
ipv6 mtu
Use ipv6 mtu to configure the interface MTU for IPv6 packets.
Use undo ipv6 mtu to restore the default MTU.
ipv6 mtu size
undo ipv6 mtu
The interface MTU is not configured.
Interface view
size: Specifies the MTU size in bytes. The value range for this argument is 1280 to 1587.
IPv6 routers do not support packet fragmentation. After an IPv6 router receives an IPv6 packet, if the packet size is larger than the MTU of the forwarding interface, the router discards the packet. Meanwhile, the router sends the MTU to the source host through an ICMPv6 packet — Packet Too Big message. The source host fragments the packet according to the MTU and resends it. To reduce the extra flow overhead resulting from packet drops, set an appropriate interface MTU for your network.
# Set the interface MTU for IPv6 packets to 1280 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 mtu 1280
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
The M flag is set to 0 in RA advertisements. Hosts receiving the advertisements will obtain IPv6 addresses through stateless autoconfiguration.
Interface view
The M flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain IPv6 addresses.
·     If the M flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from an DHCPv6 server) to obtain IPv6 addresses.
·     If the M flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration. Stateless autoconfiguration generates IPv6 addresses according to link-layer addresses and the prefix information in the RA advertisements.
# Set the M flag to 1 in RA advertisements to be sent.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig other-flag to restore the default.
The O flag is set to 0 in RA advertisements. Hosts receiving the advertisements will acquire other information through stateless autoconfiguration.
Interface view
The O flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from a DHCPv6 server) to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration to obtain configuration information other than IPv6 addresses.
# Set the O flag to 0 in RA advertisements to be sent.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
Use ipv6 nd dad attempts to set the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
ipv6 nd dad attempts interval
The number of attempts to send an NS message for DAD is 1.
Interface view
interval: Specifies the number of attempts to send an NS message for DAD, in the range of 0 to 600. If it is set to 0, DAD is disabled.
An interface sends an NS message for DAD after obtaining an IPv6 address.
If the interface does not receive a response within the time specified by using ipv6 nd ns retrans-timer, it resends an NS message.
If the interface receives no response after making the maximum sending attempts, the interface uses the obtained address.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message.
Use undo ipv6 nd ns retrans-timer to restore the default.
The local interface sends NS messages at every an interval of 1000 milliseconds, and the Retrans Timer field in the RA messages sent is 0. The interval for retransmitting an NS message is determined by the receiving device.
Interface view
value: Specifies the interval value in the range of 1000 to 4294967295 milliseconds.
If a device does not receive a response from the peer within the specified interval, the device resends an NS message. The device retransmits an NS message at the specified interval and uses the interval value to fill the Retrans Timer field in RA messages to be sent.
# Specify VLAN-interface 100 to retransmit NS messages every 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
Use ipv6 nd nud reachable-time to set the neighbor reachable time on an interface.
Use undo ipv6 nd nud reachable-time to restore the default.
The neighbor reachable time on the local interface is 30000 milliseconds, and the value of the Reachable Time field in RA messages is 0. The reachable time is determined by the receiving device.
Interface view
time: Specifies the neighbor reachable time in the range of 1 to 3600000 milliseconds.
If the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor reachable within the specified reachable time. If the device must send a packet to the neighbor after the specified reachable time expires, the device reconfirms whether the neighbor is reachable. The device sets the specified value as the neighbor reachable time on the local interface and uses the value to fill the Reachable Time field in RA messages to be sent.
# Set the neighbor reachable time on VLAN-interface 100 to 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
Use ipv6 nd ra dns search-list to specify DNS suffix information to be advertised in RA messages.
Use undo ipv6 nd ra dns search-list to remove a DNS suffix from RA message advertisement.
undo ipv6 nd ra dns search-list domain-name
DNS suffix information is not specified and RA messages do not contain DNS suffix options.
Interface view
domain-name: Specifies a DNS suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, aabbcc.com. The DNS suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
seconds: Specifies the lifetime of the DNS suffix, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS suffix is infinite.
infinite: Sets the lifetime of the DNS suffix to infinite.
seqno: Specifies the sequence number of the DNS suffix, in the range of 0 to 4294967295. The sequence number for a DNS suffix must be unique. A smaller sequence number represents a higher priority.
The DNS search list (DNSSL) option in RA messages provides DNS suffix information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS suffix through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS suffix is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS suffixes on an interface. One DNSSL option contains one DNS suffix. All DNSSL options are sorted in ascending order of the sequence number of the DNS suffix.
The sequence number uniquely identifies a DNS suffix. To modify a DNS suffix or its sequence number, you must first use the undo ipv6 nd ra dns search-list command to remove the DNS suffix from RA message advertisement.
After you execute the ipv6 nd ra dns search-list command, the device immediately sends an RA message with the existing and newly specified DNS suffix information.
After you execute the undo ipv6 nd ra dns search-list command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS suffixes, including DNS suffixes specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS suffixes.
Each time the device sends an RA message from an interface, it immediately refreshes the RA message advertisement interval for that interface.
# Specify the DNS suffix as com, the suffix lifetime as infinite, and the sequence number as 1 for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns search-list com infinite sequence 1
ipv6 nd ra dns search-list suppress
ipv6 nd ra interval
Use ipv6 nd ra dns search-list suppress to enable DNS suffix suppression in RA messages.
Use undo ipv6 nd ra dns search-list suppress to disable DNS suffix suppression in RA messages.
DNS suffix suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS suffixes in RA messages on an interface. If you specify a new DNS suffix or remove a DNS suffix on the interface, the device immediately sends an RA message without any DNSSL options.
RA messages are suppressed by default. To disable RA message suppression, use the undo ipv6 nd ra halt command.
Whether enabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends two RA messages. In the first message, the lifetime for DNS suffixes is 0 seconds. The second RA message does not contain any DNSSL options.
·     If the interface has no DNS suffix information specified, no RA messages are triggered.
Whether disabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends an RA message containing the DNS suffix information.
# Enable DNS suffix suppression in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
Use ipv6 nd ra dns server to specify DNS server information to be advertised in RA messages.
Use undo ipv6 nd ra dns server to remove a DNS server from RA message advertisement.
undo ipv6 nd ra dns server ipv6-address
DNS server information is not specified and RA messages do not contain DNS server options.
Interface view
ipv6-address: Specifies the IPv6 address of the DNS server, which must be a global unicast address or a link-local address.
seconds: Specifies the lifetime of the DNS server, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS server is infinite.
infinite: Sets the lifetime of the DNS server to infinite.
sequence seqno: Specifies the sequence number of the DNS server, in the range of 0 to 4294967295. The sequence number for a DNS server must be unique. A smaller sequence number represents a higher priority.
The DNS server option in RA messages provides DNS server information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS server through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS server is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS servers on an interface. One DNS server option contains one DNS server. All DNS server options are sorted in ascending order of the DNS server sequence number.
The sequence number uniquely identifies a DNS server. To modify the IPv6 address or sequence number of a DNS server, you must first use the undo ipv6 nd ra dns server command to remove the DNS server from RA message advertisement.
After you execute the ipv6 nd ra dns server command, the device immediately sends an RA message with the existing and newly specified DNS server options.
After you execute the undo ipv6 nd ra dns server command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS servers, including the DNS servers specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS servers.
# Specify the DNS server address as 2001:10::100, the server lifetime as infinite, and the sequence number as 1 for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns server 2001:10::100 infinite sequence 1
ipv6 nd ra dns server suppress
ipv6 nd ra interval
Use ipv6 nd ra dns server suppress to enable DNS server suppression in RA messages.
Use undo ipv6 nd ra dns server suppress to disable DNS server suppression in RA messages.
DNS server suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS server addresses in RA messages on an interface. If you specify a new DNS server or remove a DNS server on the interface, the device immediately sends an RA message without any DNS server options.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends two RA messages. In the first message, the lifetime for DNS server addresses is 0 seconds. The second RA message does not contain any DNS server options.
·     If the interface has no DNS server information specified or no AAA-authorized DNS server address assigned, no RA messages are triggered.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends an RA message containing the DNS server information.
# Enable DNS server suppression in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns server suppress
ipv6 nd ra halt
Use ipv6 nd ra halt to suppress an interface from advertising RA messages.
Use undo ipv6 nd ra halt to disable this feature.
ipv6 nd ra halt
An interface is suppressed from sending RA messages.
Interface view
# Disable RA message suppression on VLAN-interface 100.
[Sysname-Vlan-interface100] undo ipv6 nd ra halt
Use ipv6 nd ra hop-limit unspecified to specify unlimited hops in RA messages.
Use undo ipv6 nd ra hop-limit unspecified to restore the default.
The maximum number of hops in the RA messages is limited to 64.
Interface view
To set the maximum number of hops to a value rather than the default setting, use the ipv6 hop-limit command.
# Specify unlimited hops in the RA messages on VLAN-interface 100.
[Sysname-Vlan-interface10] ipv6 nd ra hop-limit unspecified
ipv6 hop-limit
ipv6 nd ra interval
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages.
Use undo ipv6 nd ra interval to restore the default.
The maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Interface view
max-interval: Specifies the maximum interval value in seconds, in the range of 4 to 1800.
min-interval: Specifies the minimum interval value in the range of 3 seconds to three-fourths of the maximum interval.
The device advertises RA messages randomly between the maximum interval and the minimum interval.
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra router-lifetime
ipv6 nd ra invalid-delegated-prefix advertise enable
Use ipv6 nd ra invalid-delegated-prefix advertise enable to enable advertising invalid delegated prefixes.
Use undo ipv6 nd ra invalid-delegated-prefix advertise enable to diable advertising invalid delegated prefixes.
Advertising invalid delegated prefixes is disabled.
Interface view
An interface can generate an IPv6 address based on a prefix, which is assigned by the DHCPv6 server. When the assigned prefix goes invalid, the device does not advertise RA messages for the event by default. In this case, endpoints that use this prefix are not aware of the event, and continue using the IPv6 addresses generated based on the prefix, causing communication failures. To avoid this problem, you can use this feature. When a DHCPv6 server-assigned prefix goes invalid, the device sends out RA messages immediately. In the message, the preferred lifetime and valid lifetime are both set to 0, announcing that the prefix is invalid. Upon receiving the advertisement, endpoints will no longer use the IPv6 addresses generated based on the prefix. For more information about DHCPv6 server, see DHCPv6 server configuration in Network Connectivity Configuration Guide.
# Enable advertising invalid delegated prefixes on VLAN-interface 200.
[Sysname] interface vlan-interface 200
[Sysname-Vlan-interface200] ipv6 nd ra invalid-delegated-prefix advertise enable
ipv6 dhcp client pd
ipv6 nd ra halt
ipv6 nd ra no-advlinkmtu
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
RA messages contain the MTU option.
Interface view
The MTU option in the RA messages specifies the link MTU to ensure that all nodes on the link use the same MTU.
# Turn off the MTU option in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to restore the default.
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
No prefix information is configured for RA messages. Instead, the IPv6 address of the interface sending RA messages is used as the prefix information.
If the IPv6 address is manually configured, the prefix uses the fixed valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (7 days).
If the IPv6 address is automatically obtained (through DHCP, for example), the prefix uses the valid and preferred lifetime of the IPv6 address.
Interface view
ipv6-prefix: Specifies the IPv6 prefix.
prefix-length: Specifies the prefix length of the IPv6 address.
valid-lifetime: Specifies the valid lifetime of a prefix, in the range of 0 to 4294967295 seconds. The default value is 2592000 seconds (30 days).
preferred-lifetime: Specifies the preferred lifetime of a prefix used for stateless autoconfiguration, in the range of 0 to 4294967295 seconds. The preferred lifetime cannot be longer than the valid lifetime. The default value is 604800 seconds (7 days).
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If you do not specify this keyword, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If you do not specify this keyword, the address with the prefix is directly reachable on the link.
no-advertise: Disables the device from advertising the prefix specified in this command. If you do not specify this keyword, the device advertises the prefix specified in this command.
After hosts on the same link receive RA messages, they can use the prefix information in the RA messages for stateless autoconfiguration.
A prefix specified without a parameter in this command preferentially uses the default settings configured by using the ipv6 nd ra prefix default command. If the default settings are unavailable, the prefix uses the following settings:
·     Valid lifetime of 2592000 seconds (30 days).
·     Preferred lifetime of 604800 seconds (7 days).
·     The prefix is used for stateless autoconfiguration.
·     The address with the prefix is directly reachable on the link.
·     The prefix is advertised in RA messages.
# Configure the prefix information in RA messages on VLAN-interface 100.
Method 1:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
Method 2:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100 64 100 10
Use ipv6 nd ra router-lifetime to set the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
The router lifetime in RA messages is three times as long as the maximum interval for advertising RA messages.
Interface view
time: Specifies the router lifetime in the range of 0 to 9000 seconds. If the value is set to 0, the router does not act as the default router.
The router lifetime in RA messages specifies how long the router sending the RA messages acts as the default router. Hosts receiving the RA messages check this value to determine whether to use the sending router as the default router. If the router lifetime is 0, the router cannot be used as the default router.
The router lifetime in RA messages must be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 nd ra interval
ipv6 nd router-preference
Use ipv6 nd router-preference to set a router preference in RA messages.
Use undo ipv6 nd router-preference to restore the default.
The router preference is medium.
Interface view
high: Sets the router preference to the highest setting.
low: Sets the router preference to the lowest setting.
medium: Sets the router preference to the medium setting.
A hosts selects a router with the highest preference as the default router.
When router preferences are the same in RA messages, a host selects the router corresponding to the first received RA message as the default gateway.
# Set the router preference in RA messages to the highest on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd router-preference high
ipv6 neighbor
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to delete a neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
No static neighbor entries exist.
ipv6-address: Specifies the IPv6 address of the static neighbor entry.
mac-address: Specifies the MAC address (48 bits) of the static neighbor entry, in the format of H-H-H.
vlan-id: Specifies the VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Specifies a Layer 2 port of the static neighbor entry by its type and number.
interface interface-type interface-number: Specifies a Layer 3 interface of the static neighbor entry by its type and number.
A neighbor entry stores information about a link-local node. The entry can be created dynamically through NS and NA messages, or configured statically.
The device uniquely identifies a static neighbor entry by using the neighbor's IPv6 address and the number of the Layer 3 interface that connects to the neighbor. You can configure a static neighbor entry by using either of the following methods:
·     Method 1—Associate a neighbor IPv6 address and link-layer address with the Layer 3 interface of the local node.
·     Method 2—Associate a neighbor IPv6 address and link-layer address with a Layer 2 port in a VLAN containing the local node.
You can use either of the previous configuration methods to configure a static neighbor entry for a VLAN interface.
·     If Method 1 is used, the neighbor entry is in INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry goes into REACH state.
·     If Method 2 is used, the port specified by port-type port-number must belong to the VLAN specified by vlan-id and the corresponding VLAN interface must already exist. After the static neighbor entry is configured, the device associates the VLAN interface with the IPv6 address to uniquely identify the static neighbor entry. The entry will be in REACH state.
You can use the undo ipv6 neighbor command to delete both static and dynamic neighbor entries.
To delete a neighbor entry for a VLAN interface, specify only the corresponding VLAN interface.
# Configure a static neighbor entry for VLAN-interface 1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 interface Vlan-interface 1
display ipv6 neighbors
reset ipv6 neighbors
Use ipv6 neighbor link-local minimize to minimize link-local ND entries.
Use undo ipv6 neighbor link-local minimize to restore the default.
All ND entries are assigned to the driver.
Perform this command to minimize link-local ND entries assigned to the driver. Link-local ND entries refer to ND entries that contain link-local addresses.
With this feature enabled, the device does not add newly learned link-local ND entries whose link local addresses are not the next hop of any route to the driver. This saves driver resources.
This feature affects only newly learned link-local ND entries rather than existing ND entries.
# Minimize link-local ND entries.
[Sysname] ipv6 neighbor link-local minimize
ipv6 neighbor stale-aging
Use ipv6 neighbor stale-aging to set the aging timer for ND entries in stale state.
Use undo ipv6 neighbor stale-aging to restore the default.
The aging timer for ND entries in stale state is 240 minutes.
aging-time: Specifies the aging timer for ND entries in stale state, in the range of 1 to 1440 minutes.
This aging time applies to all ND entries in stale state. If an ND entry in stale state is not updated before the timer expires, it moves to the delay state. If it is still not updated in 5 seconds, the ND entry moves to the probe state. The device sends an NS message for detection a maximum of three times. If no response is received, the device deletes the ND entry.
# Set the aging timer for ND entries in stale state to 120 minutes.
[Sysname] ipv6 neighbor stale-aging 120
ipv6 neighbors max-learning-num
Use ipv6 neighbors max-learning-num to set the maximum number of dynamic neighbor entries that an interface can learn. This prevents the interface from occupying too many neighbor table resources.
Use undo ipv6 neighbors max-learning-num to restore the default.
The default for this command is the maximum value of the max-number argument.
Layer 2 interface view
max-number: Specifies the maximum number of dynamic neighbor entries that an interface can learn. The value ranges is 0 to 2048.
The device can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table.
When the number of dynamic neighbor entries reaches the threshold, the interface stops learning neighbor information.
# Set the maximum number of dynamic neighbor entries that VLAN-interface 100 can learn to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
ipv6 pathmtu
Use ipv6 pathmtu to set a static Path MTU for an IPv6 address.
Use undo ipv6 pathmtu to delete the Path MTU configuration for an IPv6 address.
ipv6 pathmtu ipv6-address value
undo ipv6 pathmtu ipv6-address
No static Path MTU is set.
value: Specifies the Path MTU of the specified IPv6 address, in the range of 1280 to 10240 bytes.
You can set a static Path MTU for a destination IPv6 address. When a source host sends a packet through an interface, it compares the interface MTU with the static Path MTU of the specified destination IPv6 address. If the packet size is larger than the smaller one of the two values, the host fragments the packet according to the smaller value.
# Set a static Path MTU for an IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
display ipv6 pathmtu
reset ipv6 pathmtu
ipv6 pathmtu age
Use ipv6 pathmtu age to set the aging time for a dynamic Path MTU.
Use undo ipv6 pathmtu age to restore the default.
ipv6 pathmtu age age-time
The aging time for dynamic Path MTU is 10 minutes.
age-time: Specifies the aging time for Path MTU in minutes, in the range of 10 to 100.
After the path MTU from a source host to a destination host is dynamically determined, the source host sends subsequent packets to the destination host based on this MTU. After the aging time expires, the following events occur:
·     The dynamic Path MTU is removed.
·     The source host determines a dynamic path MTU through the Path MTU mechanism again.
The aging time is invalid for a static Path MTU.
# Set the aging time for a dynamic Path MTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 prefer temporary-address
Use ipv6 prefer temporary-address to enable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
Use undo ipv6 prefer temporary-address to disable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
The system is disabled to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
The temporary address feature enables the system to generate and preferentially use the temporary IPv6 address of the sending interface as the source address of a packet. If the temporary IPv6 address cannot be used because of a DAD conflict, the system uses the public IPv6 address.
# Enable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of the packet.
[Sysname] ipv6 prefer temporary-address
ipv6 address auto
ipv6 nd ra prefix
ipv6 temporary-address
ipv6 prefix
Use ipv6 prefix to configure a static IPv6 prefix.
Use undo ipv6 prefix to delete a static IPv6 prefix.
undo ipv6 prefix prefix-number
No static IPv6 prefix is configured.
prefix-number: Specifies a prefix ID in the range of 1 to 1024.
ipv6-prefix/prefix-length: Specifies a prefix and its length. The value range for the prefix-length argument is 1 to 128.
To modify an existing static prefix, execute the undo ipv6 prefix command to delete the existing static prefix, and then execute the ipv6 prefix command.
Dynamic IPv6 prefixes obtained from DHCPv6 servers cannot be manually removed or modified.
A static IPv6 prefix can have the same prefix ID with a dynamic IPv6 prefix, but the static one takes precedence over the dynamic one.
# Create static IPv6 prefix 2001:0410::/32 with prefix ID 1.
[Sysname] ipv6 prefix 1 2001:0410::/32
display ipv6 prefix
ipv6 redirects enable
Use ipv6 redirects enable to enable sending ICMPv6 redirect messages.
Use undo ipv6 redirects enable to disable sending ICMPv6 redirect messages.
Sending ICMPv6 redirect messages is disabled.
The default gateway sends an ICMPv6 redirect message to the source of an IPv6 packet to inform the source of a better first hop.
Sending ICMPv6 redirect messages enables hosts that hold few routes to establish routing tables and find the best route. Because this feature adds host routes into the routing tables, host performance degrades when there are too many host routes. As a result, sending ICMPv6 redirect messages is disabled by default.
# Enable sending ICMPv6 redirect messages.
[Sysname] ipv6 redirects enable
Use ipv6 temporary-address to enable the temporary IPv6 address feature.
Use undo ipv6 temporary-address to restore the default.
The system does not generate any temporary IPv6 address.
valid-lifetime: Specifies the valid lifetime for temporary IPv6 addresses, in the range of 600 to 4294967295 seconds. The default valid lifetime is 604800 seconds (7 days).
preferred-lifetime: Specifies the preferred lifetime for temporary IPv6 addresses, in the range of 600 to 4294967295 seconds. The default preferred lifetime is 86400 seconds (1 day).
You must enable stateless autoconfiguration before enabling the temporary address feature.
The valid lifetime for temporary IPv6 addresses must be greater than or equal to the preferred lifetime for temporary IPv6 addresses.
In stateless address autoconfiguration, an interface automatically generates an IPv6 global unicast address by using the address prefix in the received RA message and the interface ID. On an IEEE 802 interface (such as an Ethernet interface or a VLAN interface), the interface ID is generated based on the interface's MAC address and is globally unique. An attacker can exploit this rule to easily identify the sending device.
To fix the vulnerability, you can enable the temporary address feature. An IEEE 802 interface generates the following addresses:
·     Public IPv6 address—Includes an address prefix in the RA message and a fixed interface ID generated based on the interface's MAC address.
·     Temporary IPv6 address—Includes an address prefix in the RA message and a random interface ID generated through MD5.
When the valid lifetime of a temporary IPv6 address expires, the system deletes the address and generates a new one. This enables the system to send packets with different source addresses through the same interface. The preferred lifetime and valid lifetime for a temporary IPv6 address are determined as follows:
·     The preferred lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The preferred lifetime of the address prefix in the RA message.
¡     The preferred lifetime configured for temporary IPv6 addresses minus DESYNC_FACTOR (a random number in the range of 0 to 600 seconds).
·     The valid lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The valid lifetime of the address prefix.
¡     The valid lifetime configured for temporary IPv6 addresses.
# Enable the system to generate a temporary IPv6 address.
[Sysname] ipv6 temporary-address
ipv6 address auto
ipv6 nd ra prefix
ipv6 unreachables enable
Use ipv6 unreachables enable to enable sending ICMPv6 destination unreachable messages.
Use undo ipv6 unreachables to disable sending ICMPv6 destination unreachable messages.
undo ipv6 unreachables enable
Sending ICMPv6 destination unreachable messages is disabled.
If the device fails to forward a received IPv6 packet because of a destination unreachable error, it performs the following operations:
·     Drops the packet.
·     Sends an ICMPv6 destination unreachable message to the source.
If the device is generating ICMPv6 destination unreachable messages incorrectly, disable sending ICMPv6 destination unreachable messages to prevent attack risks.
# Enable sending ICMPv6 destination unreachable messages.
[Sysname] ipv6 unreachables enable
local-proxy-nd enable
Use local-proxy-nd enable to enable local ND proxy.
Use undo local-proxy-nd enable to disable local ND proxy.
Local ND proxy is disabled.
VLAN interface view
# Enable local ND proxy on VLAN-interface 100.
[Sysname-Vlan-interface100] local-proxy-nd enable
proxy-nd enable
proxy-nd enable
Use proxy-nd enable to enable common ND proxy.
Use undo proxy-nd enable to disable common ND proxy.
proxy-nd enable
Common ND proxy is disabled.
VLAN interface view
# Enable common ND proxy on VLAN-interface 100.
[Sysname-Vlan-interface100] proxy-nd enable
Use reset ipv6 neighbors to clear IPv6 neighbor information.
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | static }
all: Clears static and dynamic neighbor information for all interfaces.
dynamic: Clears dynamic neighbor information for all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information for the interface specified by its type and number.
static: Clears static neighbor information for all interfaces.
# Clear neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors all
This will delete all the entries. Continue? [Y/N]:Y
# Clear dynamic neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors dynamic
This will delete all the dynamic entries. Continue? [Y/N]:Y
# Clear all neighbor information for GigabitEthernet 1/0/1.
<Sysname> reset ipv6 neighbors interface gigabitethernet 1/0/1
This will delete all the dynamic entries by the interface you specified. Continue? [Y/N]:Y
ipv6 neighbor
reset ipv6 pathmtu
Use reset ipv6 pathmtu to clear the Path MTU information.
all: Clears all Path MTUs.
dynamic: Clears all dynamic Path MTUs.
static: Clears all static Path MTUs.
# Clear all Path MTUs.
<Sysname> reset ipv6 pathmtu all
reset ipv6 statistics
Use reset ipv6 statistics to clear IPv6 and ICMPv6 packet statistics.
# Clear IPv6 and ICMPv6 packet statistics.
<Sysname> reset ipv6 statistics
display ipv6 statistics
