- 04-Network Connectivity
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-ARP commands
- 10-IP addressing commands
- 11-DHCP commands
- 12-DHCPv6 commands
- 13-DNS commands
- 14-IP performance optimization commands
- 15-IPv6 basics commands
- 16-Basic IP routing commands
- 17-Static routing commands
- 18-IPv6 static routing commands
- 19-IGMP snooping commands
- 20-MLD snooping commands
| 07-LLDP commands | 201.49 KB |
display lldp local-information
display lldp neighbor-information
lldp ignore-pvid-inconsistency
lldp management-address-format string
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer notification-interval
LLDP commands
Use display lldp local-information to display local LLDP information.
global: Displays the global local LLDP information.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify any keywords or arguments, the command displays all local LLDP information, which includes the following:
· The global LLDP information.
· The LLDP information about the LLDP-enabled ports in up state.
# Display all local LLDP information.
<Sysname> display lldp local-information
Chassis ID : 00e0-fc00-5600
System name : Sysname
System description :
H3C Comware Platform Software, Software Version 7.1.064, ESS 2442
H3C WA6638
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
System capabilities supported : Bridge, WlanAccessPoint, Router, Customer Bridg
e, Service Bridge
System capabilities enabled : Bridge, Router, Customer Bridge
MED information:
Device class : Connectivity device
MED inventory information of master board:
HardwareRev : Ver.A
FirmwareRev : 7.12
SoftwareRev : 7.1.064, ESS 2442
SerialNum : 219801A1NQ8183E00007
Manufacturer name : H3C
Model name : WA6638
Asset tracking identifier : Unknown
LLDP local-information of port 2[GigabitEthernet1/0/2]:
Port ID type : Interface name
Port ID : GigabitEthernet1/0/2
Port description : GigabitEthernet1/0/2 Interface
LLDP agent nearest-bridge management address:
Management address type : IPv4
Management address : 192.168.80.60
Management address interface ID : Unknown
Management address OID : 0
LLDP agent nearest-nontpmr management address:
Management address : 192.168.80.61
LLDP agent nearest-customer management address:
Management address : 192.168.80.62
Port VLAN ID(PVID): 1
Port and protocol VLAN ID(PPVID) : 0
Port and protocol VLAN supported : No
Port and protocol VLAN enabled : No
VLAN name of VLAN 1: VLAN 0001
Management VLAN ID : 0
Link aggregation enabled : No
Aggregation port ID : 0
Auto-negotiation enabled : Yes
OperMau : Speed(1000)/Duplex(Full)
Power port class : PD
PSE power supported : NO
PSE power enabled : NO
PSE pairs control ability : NO
Power pairs : Signal
Port power classification : Class 0
Maximum frame size : 1600
Transmit Tw : 0 us
Receive Tw : 0 us
Fallback Tw : 0 us
Echo Transmit Tw : 0 us
Echo Receive Tw : 0 us
PoE PSE power source : Unknown
Port PSE priority : Unknown
Port available power value : 0.0 w
Chassis ID |
Bridge MAC address of the device. |
System capabilities supported |
Supported capabilities: · Bridge—Switching is supported. · Router—Routing is supported. · WlanAccessPoint—The local device can act as a wireless AP. · Repeater—Signal repeating is supported. · Telephone—The local device can act as a telephone. · DocsisCableDevice—The local device can act as a DOCSIS-compliant cable device. · StationOnly—The local device can act as a station only. · Customer Bridge—The customer bridge feature is supported. · Service Bridge—The service bridge feature is supported. · TPMR—The TPMR feature is supported. · Other—Features other than those listed above are supported. |
System capabilities enabled |
Enabled capabilities: · Bridge—Switching is enabled. · Router—Routing is enabled. · WlanAccessPoint—The local device is acting as a wireless AP. · Repeater—Signal repeating is enabled. · Telephone—The local device is acting as a telephone. · DocsisCableDevice—The local device is acting as a DOCSIS-compliant cable device. · StationOnly—The local device is acting as a station only. · Customer Bridge—The customer bridge feature is enabled. · Service Bridge—The service bridge feature is enabled. · TPMR—The TPMR feature is enabled. · Other—Features other than those listed above are enabled. |
Device class |
MED device class: · Connectivity device—Network device. · Class I—Normal terminal device. It requires the basic LLDP discovery services. · Class II—Media terminal device. It supports media streams, and can also act as a normal terminal device. · Class III—Communication terminal device. It supports the IP communication systems of end users, and can also act as a normal terminal device or media terminal device. |
MED inventory information of master board |
MED inventory information about the MPU. |
HardwareRev |
Hardware version. |
FirmwareRev |
Firmware version. |
SoftwareRev |
Software version. |
SerialNum |
Serial number. |
Manufacturer name |
Device manufacturer. |
Model name |
Device model. |
Port ID type |
Port ID type: · MAC address. · Interface name. |
Port ID |
Port ID, the value of which depends on the port ID type. |
Management address interface type |
Numbering type of the interface identified by the management address. |
Management address interface ID |
Index of the interface identified by the management address. |
Management address OID |
Management address object ID. |
Port VLAN ID(PVID) |
Port VLAN ID. |
Port and protocol VLAN ID(PPVID) |
Port protocol VLAN ID. |
Port and protocol VLAN supported |
Indicates whether protocol VLAN is supported on the port. |
Port and protocol VLAN enabled |
Indicates whether protocol VLAN is enabled on the port. |
Link aggregation supported |
Indicates whether link aggregation is supported on the port. |
Link aggregation enabled |
Indicates whether link aggregation is enabled on the port. |
Aggregation port ID |
Member port ID, which is 0 when link aggregation is disabled. |
Auto-negotiation supported |
Indicates whether autonegotiation is supported on the port. |
Auto-negotiation enabled |
Indicates whether autonegotiation is enabled on the port. |
OperMau |
Speed and duplex state of the port. |
Power port class |
PoE port class: · PSE—Power sourcing equipment. · PD—Powered device. |
PSE power supported |
Indicates whether the device can operate as a PSE. |
PSE power enabled |
Indicates whether the device is operating as a PSE. |
PSE pairs control ability |
Indicates whether the pair selection ability is available. |
Power pairs |
Power supply mode: · Signal—Uses data pairs to supply power. · Spare—Uses spare pairs to supply power. |
Port power classification |
Power class of the PD: · Class 0. · Class 1. · Class 2. · Class 3. · Class 4. |
Power priority |
· Unknown. · Critical. · High. · Low. |
PoE PSE power source |
PSE power source type: · Unknown—Unknown power supply. · Primary—Primary power supply. · Backup—Backup power supply. |
Port PSE priority |
PoE power supply priority of PSE ports: · Unknown. · Critical. · High. · Low. |
Port available power value |
Available PoE power on PSE ports, or power needed on PD ports, in watts. |
Transmit Tw |
Sleep time of the local client, in μs. |
Receive Tw |
Sleep time of the peer client expected by the local client, in μs. |
Fallback Tw |
Candidate sleep time of the peer client expected by the local client, in μs. |
Echo Transmit Tw |
Sleep time of the peer client, in μs. This field displays zero when one of the following cases occurs: · The local client has not received the sleep time of the peer client. · The sleep time of the peer client is 0 μs. |
Echo Receive Tw |
Sleep time of the local client expected by the peer client, in μs. This field displays zero when one of the following cases occurs: · The local client has not received the expected sleep time from the peer client. · The sleep time of the local client expected by the peer client is 0 μs. |
Use display lldp neighbor-information to display the LLDP information received from the neighboring devices.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the LLDP information that all ports receive from the neighboring devices.
agent: Specifies an agent type. If you do not specify an agent type, the command displays the LLDP information that all LLDP agents receive from the neighboring devices.
nearest-bridge: Specifies nearest bridge agents.
nearest-customer: Specifies nearest customer bridge agents.
nearest-nontpmr: Specifies nearest non-TPMR bridge agents.
verbose: Displays the detailed LLDP information that the local device receives from the neighboring devices. If you do not specify this keyword, the command displays the brief LLDP information that the local device receives from the neighboring devices.
list: Displays the LLDP information that the local device receives from the neighboring devices in the form of a list.
system-name system-name: Displays the LLDP information that the local device receives from a neighboring device specified by its system name. The system-name argument is a string of 1 to 255 characters. If you do not specify this option, the command displays the LLDP information that the local device receives from all neighboring devices in a list.
# Display detailed LLDP information that the nearest bridge agents on all ports received from the neighboring devices.
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
LLDP Neighbor index : 1
Update time : 0 days, 0 hours, 1 minutes, 1 seconds
Chassis type : MAC address
Chassis ID : 000f-0055-0002
Time to live : 121
Port description : GigabitEthernet1/0 Interface
H3C Comware Platform Software, Software Version 7.1.064,Release 5534
H3C WA6638
System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
Management address : 192.168.1.55
Link aggregation enabled : Yes
Aggregation port ID : 52
Power port class : PSE
PSE power supported : Yes
PSE power enabled : Yes
PSE pairs control ability : No
Port power classification : Class 4
Power type : Type 2 PSE
Power source : Primary
Power priority : Low
PD requested power value : 0.0 w
PSE allocated power value : 25.5 w
Maximum frame size : 1500
# Display brief LLDP information that all LLDP agents received from all neighboring devices.
LLDP neighbor-information of port 2 [GigabitEthernet1/0/2]:
LLDP neighbor index : 3
ChassisID/subtype : 0011-2233-4400/MAC address
PortID/subtype : 000c-29f5-c71f/MAC address
Capabilities : Bridge, Router, Customer Bridge
LLDP neighbor index : 6
PortID/subtype : 000c-29f5-c715/MAC address
Capabilities : None
LLDP agent nearest-nontpmr:
Capabilities : None
# Display brief LLDP information that all LLDP agents received from the neighboring devices in a list.
Chassis ID : * -- --Nearest nontpmr bridge neighbor
# -- --Nearest customer bridge neighbor
Default -- -- Nearest bridge neighbor
System Name Local Interface Chassis ID Port ID
System1 GE1/0/2 000f-e25d-ee91 GigabitEthernet1/0/2
LLDP neighbor-information of port 1 |
LLDP information received through port 1. |
Update time |
Time when LLDP information about a neighboring device was last updated. |
LLDP mac type |
Type of the neighbor MAC address: · Nearest bridge. · Nearest customer bridge. · Nearest non-TPMR bridge. |
Chassis type |
Chassis ID type: · Chassis component. · Interface alias. · Port component. · MAC address. · Network address (ipv4). · Interface name. · Locally assigned—Locally-defined chassis type other than those listed above. |
Chassis ID |
ID that identifies the LLDP sending device, which can be a MAC address, a network address, an interface, or some other value, depending on the chassis ID type of the neighboring device. |
Port ID type |
Port ID type: · Interface alias. · Port component. · MAC address. · Network address (ipv4). · Interface name. · Agent circuit ID. · Locally assigned—Locally-defined port ID type other than those listed above. |
Port ID |
Value of the type of the port ID. |
System name |
System name of the neighboring device. |
System description |
System description of the neighboring device. |
Capabilities supported on the neighboring device: · Repeater—Signal repeating is supported. · Bridge—Switching is supported. · WlanAccessPoint—The neighboring device can act as a wireless AP. · Router—Routing is supported. · Telephone—The neighboring device can act as a telephone. · DocsisCableDevice—The neighboring device can act as a DOCSIS-compliant cable device. · StationOnly—The neighboring device can act as a station only. · Customer Bridge—The customer bridge feature is enabled. · Service Bridge—The service bridge feature is enabled. · TPMR—The TPMR feature is enabled. · Other—Features other than those listed above are supported. |
Capabilities enabled on the neighboring device: · Repeater—Signal repeating is enabled. · Bridge—Switching is enabled. · WlanAccessPoint—The neighboring device is acting as a wireless AP. · Router—Routing is enabled. · Telephone—The neighboring device is acting as a telephone. · DocsisCableDevice—The neighboring device is acting as a DOCSIS-compliant cable device. · StationOnly—The neighboring device is acting as a station only. · Customer Bridge—The customer bridge feature is enabled. · Service Bridge—The service bridge feature is enabled. · TPMR—The TPMR feature is enabled. · Other—Features other than those listed above are supported. |
Indicates whether link aggregation is supported. |
Indicates whether link aggregation is enabled. |
OperMau |
Speed and duplex state on the port. |
Power port class |
PSE power enabled |
Power pairs |
Power type |
Power supply type: · Type 1 PD. · Type 2 PD. · Type 1 PSE. · Type 2 PSE. |
Power source |
Power source: · When the power supply type is PSE, options are: ¡ Unknown—Unknown power supply. ¡ Primary—Primary power supply. ¡ Backup—Backup power supply. ¡ Reserved. · When the power supply type is PD, options are:: ¡ Unknown—Unknown power supply. ¡ PSE—PSE power supply. ¡ Local—Local power supply. ¡ PSE and local—PSE and local power supplies. |
Power priority |
PD requested power value |
2-pair single-signature PD requested power in watts. |
PSE allocated power value |
2-pair single-signature PSE allocated power in watts. |
TLV type |
Unknown basic TLV type. |
TLV information |
Information contained in the unknown basic TLV type. |
Unknown organizationally-defined TLV |
Unknown organizationally specific TLV. |
TLV OUI |
OUI of the unknown organizationally specific TLV. |
TLV subtype |
Unknown organizationally specific TLV subtype. |
Index |
Unknown organization index. |
Capabilities |
Capabilities enabled on the neighboring device: · Repeater—Signal repeating is enabled. · Bridge—Switching is enabled. · WlanAccessPoint—The neighboring device is acting as a wireless AP. · Router—Routing is enabled. · Telephone—The neighboring device is acting as a telephone. · DocsisCableDevice—The neighboring device is acting as a DOCSIS-compliant cable device. · StationOnly—The neighboring device is acting as a station only. · Other—Features other than those listed above are supported. · None—The neighboring device does not advertise this TLV. |
Local Interface |
Local port that receives the LLDP information. |
Chassis ID : * -- -- Nearest nontpmr bridge neighbor #-- -- Nearest customer bridge neighbor |
Chassis ID flag: · An asterisk (*) indicates the nearest non-TPMR bridge neighbor. · A pound sign (#) indicates the nearest customer bridge neighbor. |
display lldp statistics
Use display lldp statistics to display the global LLDP statistics or the LLDP statistics of a port.
global: Displays the global LLDP statistics.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the statistics for all LLDP agents.
If you do not specify any keywords or arguments, the command displays the global LLDP statistics and the LLDP statistics of all ports.
# Display the global LLDP statistics and the LLDP statistics of all ports.
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted : 1
The number of LLDP neighbor information dropped : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted : 0
The number of LLDP frames received : 0
The number of LLDP frames discarded : 0
The number of LLDP error frames : 0
The number of LLDP TLVs discarded : 0
The number of LLDP TLVs unrecognized : 0
The number of CDP frames transmitted : 0
The number of CDP frames received : 0
The number of CDP frames discarded : 0
The number of CDP error frames : 0
LLDP agent nearest-customer:
# Display the LLDP statistics for the nearest customer bridge agents on GigabitEthernet 1/0/1.
<Sysname> display lldp statistics interface gigabitethernet 1/0/1 agent nearest-customer
LLDP statistics global information |
Global LLDP statistics. |
LLDP neighbor information last change time |
Time when the neighbor information was last updated. |
The number of LLDP neighbor information inserted |
Number of times neighbor information was added. |
The number of LLDP neighbor information deleted |
Number of times neighbor information was removed. |
The number of LLDP neighbor information dropped |
Number of times neighbor information was dropped due to lack of available memory space. |
display lldp status
Use display lldp status to display LLDP status.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the global LLDP status and the LLDP status of all ports.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the status information for all LLDP agents.
# Display the global LLDP status and the LLDP status of each port.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 5
Transmit interval : 30s
Fast transmit interval : 1s
Transmit max credit : 5
Hold multiplier : 4
Reinit delay : 2s
Trap interval : 5s
Fast start times : 3
LLDP status information of port 1 [GigabitEthernet1/0/1]:
Port status of LLDP : Enable
Admin status : TX_RX
Trap flag : No
MED trap flag : No
Polling interval : 0s
Number of LLDP neighbors : 5
Number of MED neighbors : 2
Number of CDP neighbors : 0
Number of sent optional TLV : 12
Trap flag : No
MED trap flag : No
Trap flag : No
MED trap flag : No
Bridge mode of LLDP |
LLDP bridge mode: service-bridge or customer-bridge. |
Global status of LLDP |
Indicates whether LLDP is globally enabled. |
LLDP neighbor information last changed time |
Transmit interval |
LLDP frame transmission interval. |
Hold multiplier |
TTL multiplier. |
Reinit delay |
LLDP reinitialization delay. |
Transmit max credit |
Token bucket size for sending LLDP frames. |
Trap interval |
Trap transmission interval. |
Fast start times |
Number of LLDP frames sent each time fast LLDP frame transmission is triggered. |
Port 1 |
LLDP status of port 1. |
Port status of LLDP |
Indicates whether LLDP is enabled on the port. |
Admin status |
LLDP operating mode of the port: · TX_RX—The port can send and receive LLDP frames. · Rx_Only—The port can only receive LLDP frames. · Tx_Only—The port can only send LLDP frames. · Disable—The port cannot send or receive LLDP frames. |
Trap Flag |
Indicates whether trapping is enabled. |
Polling interval |
LLDP polling interval, which is 0 when LLDP polling is disabled. |
Number of neighbors |
Number of LLDP neighbors connecting to the port. |
Number of MED neighbors |
Number of MED neighbors connecting to the port. |
Number of CDP neighbors |
Number of CDP neighbors connecting to the port. |
Number of sent optional TLV |
Number of optional TLVs contained in an LLDP frame sent through the port. |
Number of received unknown TLV |
Number of unknown TLVs contained in a received LLDP frame. |
display lldp tlv-config
Use display lldp tlv-config to display the types of advertisable optional LLDP TLVs of a port.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays the types of advertisable optional TLVs of all ports.
agent: Specifies an LLDP agent type. If you do not specify an agent type, the command displays the types of advertisable optional LLDP TLVs for all LLDP agents.
# Display the types of advertisable optional LLDP TLVs of GigabitEthernet 1/0/1.
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES YES
System Name TLV YES YES
System Description TLV YES YES
System Capabilities TLV YES YES
Management Address TLV YES YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV YES YES
Port And Protocol VLAN ID TLV YES YES
VLAN Name TLV YES YES
DCBX TLV NO NO
EVB TLV NO NO
Link Aggregation TLV YES YES
Management VID TLV YES YES
Congestion notification TLV NO NO
IEEE 802.3 extend TLV:
MAC-Physic TLV YES YES
Power via MDI TLV YES YES
Maximum Frame Size TLV YES YES
Energy-Efficient Ethernet TLV NO NO
LLDP-MED extend TLV:
Network Policy TLV YES YES
Location Identification TLV NO NO
Extended Power via MDI TLV YES YES
Inventory TLV YES YES
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES NO
System Name TLV YES NO
System Description TLV YES NO
System Capabilities TLV YES NO
Management Address TLV YES NO
Port VLAN ID TLV YES NO
Port And Protocol VLAN ID TLV YES NO
VLAN Name TLV YES NO
DCBX TLV NO NO
EVB TLV YES YES
Link Aggregation TLV YES NO
Management VID TLV NO NO
MAC-Physic TLV YES NO
Power via MDI TLV YES NO
Maximum Frame Size TLV YES NO
Network Policy TLV YES NO
Extended Power via MDI TLV YES NO
Inventory TLV YES NO
NAME STATUS DEFAULT
Basic optional TLV:
DCBX TLV NO NO
EVB TLV NO NO
Table 5 Command output
LLDP tlv-config of port 1 |
Advertisable optional TLVs of port 1. |
NAME |
TLV type. |
STATUS |
Indicates whether the type of TLV is sent through a port. |
DEFAULT |
Indicates whether the type of TLV is sent through a port by default. |
Basic optional TLV |
Basic optional TLVs: · Port Description TLV. · System Name TLV. · System Description TLV. · System Capabilities TLV. · Management Address TLV. · Congestion notification TLV. |
IEEE 802.1 extended TLV |
IEEE 802.1 organizationally specific TLVs: · Port VLAN ID TLV. · Port and protocol VLAN ID TLV. · VLAN name TLV. · DCBX TLV. DCBX TLVs are not supported in the current software version. · EVB TLV. EVB TLVs are not supported in the current software version. · Management VID TLV. |
IEEE 802.3 extended TLV |
IEEE 802.3 organizationally specific TLVs: · MAC-Physic TLV. · Power via MDI TLV. · Link aggregation TLV. · Maximum frame size TLV. |
LLDP-MED extend TLV |
LLDP-MED TLVs: · Capabilities TLV. · Network Policy TLV. · Extended Power-via-MDI TLV. · Location Identification TLV. · Inventory TLV. |
Inventory TLV |
Inventory TLVs: · Hardware Revision TLV. · Firmware Revision TLV. · Software Revision TLV. · Serial Number TLV. · Manufacturer Name TLV. · Model name TLV. · Asset ID TLV. |
Energy-Efficient Ethernet TLV |
Indicates the Energy-Efficient Ethernet TLV. |
lldp admin-status
Use lldp admin-status to set the LLDP operating mode.
Use undo lldp admin-status to restore the default.
In Layer 2 Ethernet interface view:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
In Layer 2 aggregate interface view:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
The nearest bridge agent operates in TxRx mode, and the nearest customer bridge agent and nearest non-TPMR bridge agent operate in Disable mode.
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the operating mode for nearest bridge agents.
disable: Specifies the Disable mode. A port in this mode cannot send or receive LLDP frames.
rx: Specifies the Rx mode. A port in this mode can only receive LLDP frames.
tx: Specifies the Tx mode. A port in this mode can only send LLDP frames.
txrx: Specifies the TxRx mode. A port in this mode can send and receive LLDP frames.
# Set the LLDP operating mode to Rx for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer admin-status rx
lldp check-change-interval
Use lldp check-change-interval to enable LLDP polling and set the polling interval.
Use undo lldp check-change-interval to disable LLDP polling.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command enables LLDP polling and sets the polling interval for nearest bridge agents.
interval: Sets the LLDP polling interval in the range of 1 to 30 seconds.
# Enable LLDP polling and set the polling interval to 30 seconds for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer check-change-interval 30
lldp enable
Use lldp enable to enable LLDP on a port.
Use undo lldp enable to disable LLDP on a port.
lldp enable
undo lldp enable
LLDP is enabled on a port.
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp global enable
lldp encapsulation snap
Use lldp encapsulation snap to set the encapsulation format for LLDP frames to SNAP.
Use undo lldp encapsulation to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
The encapsulation format for LLDP frames is Ethernet II.
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the LLDP frame encapsulation format for nearest bridge agents.
# Set the encapsulation format for LLDP frames to SNAP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count
Use lldp fast-count to set the number of LLDP frames sent each time fast LLDP frame transmission is triggered.
Use undo lldp fast-count to restore the default.
lldp fast-count count
Four LLDP frames are sent each time fast LLDP frame transmission is triggered.
count: Sets the number of LLDP frames sent each time fast LLDP frame transmission is triggered. The value range is 1 to 8.
# Configure the device to send five LLDP frames each time fast LLDP frame transmission is triggered.
[Sysname] lldp fast-count 5
lldp global enable
Use lldp global enable to enable LLDP globally.
Use undo lldp global enable to disable LLDP globally.
lldp global enable
LLDP is disabled globally.
# Disable LLDP globally.
[Sysname] undo lldp global enable
lldp enable
lldp hold-multiplier
Use lldp hold-multiplier to set the TTL multiplier.
Use undo lldp hold-multiplier to restore the default.
lldp hold-multiplier value
The TTL multiplier is 4.
value: Sets the TTL multiplier in the range of 2 to 10.
The TTL TLV carried in an LLDPDU determines how long the device information carried in the LLDPDU can be saved on a recipient device.
By setting the TTL multiplier, you can set the TTL of locally sent LLDP frames. The TTL is expressed by using the following formula:
TTL = Min (65535, (TTL multiplier × LLDP frame transmission interval + 1))
As the expression shows, the TTL can be up to 65535 seconds.
# Set the TTL multiplier to 6.
Use lldp ignore-pvid-inconsistency to disable LLDP PVID inconsistency check.
Use undo lldp ignore-pvid-inconsistency to enable LLDP PVID inconsistency check.
LLDP PVID inconsistency check is enabled.
Default command level
By default, when the system receives an LLDP packet, it compares the PVID value contained in packet with the PVID configured on the receiving interface. If the two PVIDs do not match, a log message will be printed to notify the user.
You can disable PVID inconsistency check if different PVIDs are required on a link.
# Disable LLDP PVID inconsistency check.
[Sysname] lldp ignore-pvid-inconsistency
Use lldp management-address-format string to set the encoding format of the management address to string.
Use undo lldp management-address-format to restore the default.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
The encoding format of the management address is numeric.
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command sets the encoding format of the management address for nearest bridge agents.
LLDP neighbors must use the same encoding format for the management address. If a neighbor encodes its management address in string format, set the encoding format of the management address to string on the connecting port. This guarantees normal communication with the neighbor.
# Set the encoding format of the management address to string for the nearest customer bridge agents on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer management-address-format string
lldp max-credit
Use lldp max-credit to set the token bucket size for sending LLDP frames.
Use undo lldp max-credit to restore the default.
lldp max-credit credit-value
The token bucket size for sending LLDP frames is 5.
credit-value: Specifies the token bucket size for sending LLDP frames, in the range of 1 to 100.
# Set the token bucket size for sending LLDP frames to 10.
[Sysname] lldp max-credit 10
lldp mode
Use lldp mode to configure LLDP to operate in service bridge mode.
Use undo lldp mode to restore the default.
lldp mode service-bridge
undo lldp mode
LLDP operates in customer bridge mode.
service-bridge: Specifies the service bridge mode.
The LLDP agent types supported by LLDP depend on the LLDP bridge mode:
· Service bridge mode—LLDP supports nearest bridge agents and nearest non-TPMR bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in a VLAN.
· Customer bridge mode—LLDP supports nearest bridge agents, nearest non-TPMR bridge agents, and nearest customer bridge agents. LLDP processes the LLDP frames with destination MAC addresses for these agents and transparently transmits the LLDP frames with other destination MAC addresses in a VLAN.
The bridge mode configuration takes effect only when LLDP is enabled globally. If LLDP is disabled globally, LLDP can only operate in customer bridge mode.
# Configure LLDP to operate in service bridge mode.
[Sysname] lldp mode service-bridge
lldp global enable
Use lldp notification med-topology-change enable to enable LLDP-MED trapping.
Use undo lldp notification med-topology-change enable to disable LLDP-MED trapping.
LLDP-MED trapping is disabled.
# Enable LLDP-MED trapping on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp notification med-topology-change enable
Use lldp notification remote-change enable to enable LLDP trapping.
Use undo lldp notification remote-change enable to disable LLDP trapping.
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP trapping is disabled.
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command enables LLDP trapping for nearest bridge agents.
# Enable LLDP trapping for the nearest customer bridge agent on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer notification remote-change enable
lldp timer fast-interval
Use lldp timer fast-interval to set an interval for fast LLDP frame transmission.
Use undo lldp timer fast-interval to restore the default.
The interval for fast LLDP frame transmission is 1 second.
interval: Sets an interval for fast LLDP frame transmission, in the range of 1 to 3600 seconds.
# Set the interval for fast LLDP frame transmission to 2 seconds.
[Sysname] lldp timer fast-interval 2
Use lldp timer notification-interval to set the LLDP trap and LLDP-MED trap transmission interval.
Use undo lldp timer notification-interval to restore the default.
The LLDP trap and LLDP-MED trap transmission interval is 30 seconds.
interval: Sets the LLDP trap and LLDP-MED trap transmission interval in the range of 5 to 3600 seconds.
# Set both the LLDP trap and LLDP-MED trap transmission interval to 8 seconds.
lldp timer reinit-delay
Use lldp timer reinit-delay to set the LLDP reinitialization delay.
Use undo lldp timer reinit-delay to restore the default.
lldp timer reinit-delay delay
The LLDP reinitialization delay is 2 seconds.
delay: Sets the LLDP reinitialization delay in the range of 1 to 10 seconds.
# Set the LLDP reinitialization delay to 4 seconds.
lldp timer rx-timeout
Use lldp timer rx-timeout to set the timeout for receiving LLDP frames and enable the device to report no LLDP neighbor events.
Use undo lldp timer rx-timeout to restore the default.
lldp timer rx-timeout timeout
No timeout is set for receiving LLDP frames, and the device does not report no LLDP neighbor events.
timeout: Sets the timeout for receiving LLDP frames, in the range of 30 to 32768 seconds.
This command can detect only directly connected LLDP neighbors.
When you use this command, make sure the following requirements are met:
· LLDP is enabled.
· Interfaces are physically up.
· Nearest bridge agents operate in Rx or TxRx mode.
After this command is executed, the device restarts the timeout timer for receiving LLDP frames on an interface in one of the following situations:
· When LLDP is enabled, the interface state changes from down to up.
· When the interface is physically up, LLDP is enabled.
· When LLDP is enabled and the interface is physically up, the mode of nearest bridge agents is changed from disabled to Rx or TxRx.
If an interface has not received any LLDP frames when the timeout timer expires, the device reports a no LLDP neighbor event to the NETCONF module.
To avoid misdetection, make sure the timeout for receiving LLDP frames is greater than the LLDP frame transmission interval.
# Set the timeout for receiving LLDP frames to 30 seconds.
[Sysname] lldp timer rx-timeout 30
lldp timer tx-interval
Use lldp timer tx-interval to set the LLDP frame transmission interval.
Use undo lldp timer tx-interval to restore the default.
The LLDP frame transmission interval is 30 seconds.
interval: Sets the LLDP frame transmission interval in the range of 5 to 32768 seconds.
# Set the LLDP frame transmission interval to 20 seconds.
lldp tlv-enable
Use lldp tlv-enable to configure the types of advertisable TLVs on a port.
Use undo lldp tlv-enable to disable the advertising of the specified types of TLVs on a port.
· For nearest bridge agents:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy [ vlan-id ] | power-over-ethernet | location-id } }
· For nearest non-TPMR bridge agents:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
· For nearest customer bridge agents:
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | congestion-notification | port-vlan-id | link-aggregation } }
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
On Layer 2 Ethernet interfaces:
· Nearest bridge agents can advertise all types of LLDP TLVs except the following types:
¡ Location identification TLVs.
¡ Port and protocol VLAN ID TLVs.
¡ VLAN name TLVs.
¡ Management VLAN ID TLVs.
· Nearest non-TPMR bridge agents do not advertise any TLVs.
· Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs.
On Layer 2 aggregate interfaces:
· Nearest customer bridge agents can advertise basic TLVs and IEEE 802.1 organizationally specific TLVs. Among the IEEE 802.1 organizationally specific TLVs, only port and protocol VLAN ID TLVs, VLAN name TLVs, and management VLAN ID TLVs are supported.
agent: Specifies an LLDP agent type. If you do not specify an agent type in Ethernet interface view, the command configures the types of advertisable TLVs for nearest bridge agents.
all: Advertises all TLVs of the specified type. This keyword enables the interface to advertise following TLVs:
· All basic LLDP TLVs if the all keyword is specified for basic-tlv.
· All IEEE 802.1 organizationally specific LLDP TLVs if the all keyword is specified for dot1-tlv.
· All IEEE 802.3 organizationally specific LLDP TLVs if the all keyword is specified for dot3-tlv.
· All LLDP-MED TLVs except location identification TLVs if the all keyword is specified for med-tlv.
basic-tlv: Advertises basic LLDP TLVs.
management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ]: Advertises management address TLVs. The ipv6 keyword indicates that the management address to be advertised is in IPv6 format. The ip-address argument specifies the management address to be advertised. The interface loopback interface-number option specifies the management address as the IP address of a loopback interface specified by its number. By default, the following rules apply:
· When you execute the lldp tlv-enable command:
¡ For a Layer 2 Ethernet or aggregate interface, the IPv4 or IPv6 address of the VLAN interface that meets the following requirements will be advertised as the management address:
- In up state.
- The corresponding VLAN ID is the lowest among the VLANs permitted on the interface.
If you specify the ipv6 keyword, the IPv6 address of the VLAN interface will be advertised. If you do not specify the ipv6 keyword, the IPv4 address of the VLAN interface will be advertised.
If none of the VLAN interfaces of the permitted VLANs is assigned an IPv4 or IPv6 address or all VLAN interfaces are down, the MAC address of the interface will be advertised.
· When you execute the undo lldp tlv-enable command:
¡ For a Layer 2 Ethernet interface or Layer 2 aggregate interface:
- If you do not specify ip-address, ipv6, or interface loopback interface-number, the interface does not advertise any management address TLVs.
- If you specify ip-address, ipv6, or interface loopback interface-number, the interface advertises the default management address TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
congestion-notification: Advertises QCN TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id [ vlan-id ]: Advertises port and protocol VLAN ID TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port.
vlan-name [ vlan-id ]: Advertises VLAN name TLVs. The vlan-id argument specifies a VLAN ID in the TLVs to be advertised. The VLAN ID is in the range of 1 to 4094, and the default is the lowest VLAN ID on the port. If you do not specify a VLAN ID and the port is not assigned to any VLAN, the PVID of the port is advertised.
management-vid [ mvlan-id ]: Advertises management VLAN ID TLVs. The mvlan-id argument specifies a management VLAN ID in the TLVs to be advertised. The management VLAN ID is in the range of 1 to 4094. If you do not specify this option, the value 0 is advertised, which means that the LLDP agent is not configured with a management VLAN ID.
link-aggregation: Advertises link aggregation TLVs.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power in MDI TLVs and power stateful control TLVs.
med-tlv: Advertises LLDP-MED TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises the following TLVs: hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID.
location-id: Advertises location identification TLVs.
civic-address: Inserts the typical address information about the network device in location identification TLVs .
device-type: Sets a device type value in the range of 0 to 2:
· Value 0 specifies a DHCP server.
· Value 1 specifies a network device.
· Value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code defined in ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information. ca-type represents the address information type in the range of 0 to 255. ca-value represents address information, a string of 1 to 250 characters. &<1-10> indicates that you can specify up to 10 ca-type ca-value pairs.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Sets the telephone number for emergencies, a string of 10 to 25 characters.
network-policy [ vlan-id ]: Advertises network policy TLVs. The vlan-id argument specifies the voice VLAN ID to be advertised, in the range of 1 to 4094.
power-over-ethernet: Advertises extended power-via-MDI TLVs.
Nearest bridge agents are not supported on aggregate interfaces.
You can enable the device to advertise multiple types of TLVs by using this command without the all keyword specified.
If the MAC/PHY configuration/status TLV is not advertisable, none of the LLDP-MED TLVs will be advertised whether or not they are advertisable. If the LLDP-MED capabilities TLV is not advertisable, the other LLDP-MED TLVs will not be advertised regardless of whether or not they are advertisable.
The port and protocol VLAN ID, VLAN name, and management VLAN ID TLVs in IEEE 802.1 organizationally specific LLDP TLVs can be configured only for nearest bridge agents. The configuration can be inherited by nearest customer bridge agents and nearest non-TPMR bridge agents.
# Enable the nearest customer bridge agents on GigabitEthernet 1/0/1 to advertise link aggregation TLVs of the IEEE 802.1 organizationally specific TLVs.
[Sysname-GigabitEthernet1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
