- 04-Network Connectivity
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-ARP commands
- 10-IP addressing commands
- 11-DHCP commands
- 12-DHCPv6 commands
- 13-DNS commands
- 14-IP performance optimization commands
- 15-IPv6 basics commands
- 16-Basic IP routing commands
- 17-Static routing commands
- 18-IPv6 static routing commands
- 19-IGMP snooping commands
- 20-MLD snooping commands
| 00-Preface | 100.09 KB |
Preface
This command reference describes network connectivity related configuration commands. It includes the following feature modules:
· MAC address table.
· Ethernet link aggregation.
· VLAN.
· Loop detection
· Spanning tree
· LLDP.
· Layer 2 forwarding.
· Port isolation
· PPP.
· ARP.
· IP addressing.
· DHCP.
· DHCPv6.
· DNS.
· NAT.
· IP performance optimization.
· IPv6 basics.
· IP routing basics.
· Static routing.
· IPv6 static routing.
· IGMP snooping.
· MLD snooping.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access points (anchor ac mode).
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
