01-Text | 619.91 KB |
The screenshots in this document are subject to change over time.
About HDM
Hardware Device Management (HDM) is a control unit for device management. HDM simplifies device configuration process, provides device component information, monitors device operation, and remotely controls the device. HDM can operate independently of the device and operating system based on intelligent microprocessors, dedicated memory, dedicated and shared network ports.
HDM features
HDM provides abundant features as described in Table 1.
Web-based management |
Provides a user-friendly Web-based management interface for easy management. |
Various management interfaces |
Provides abundant management interfaces, such as IPMI, HTTPS, SNMP, RESTful, and Redfish, to meet various system integration requirements. |
IPMI v1.5 and IPMI v2.0 compliance |
Provides a standard management interface for standard management system integration. |
Remote control |
Provides remote access to the device through KVM and virtual media, enabling device monitoring and management anywhere anytime. |
Critical OS event screenshot and video recording |
Takes a screenshot or records a video upon a critical OS event (for example, a crash) for future troubleshooting. |
Video recording |
Records operations on the device. |
Sideband and VLAN |
Supports VLANs and the sideband technology that allows for flexible network management. |
LDAP |
Simplifies user management and enhances management security by managing users on the LDAP server. |
All-round device monitoring, alarming, and event logging |
Monitors device operation, for example, temperature, voltage, and fan speed, and generates alarms and logs if any event occurs, such as drive failure or power supply failure. |
Smart Hardware Diagnosis (SHD) |
Supports SHD for component fault diagnosis, bringing ease to fault location and faulty component replacement. |
Out-of-band RAID management |
Supports out-of-band RAID monitoring and configuration to improve RAID configuration efficiency and management capability. |
Primary/backup image switchover |
Enables startup by using the backup image if the system crashes, which enhances system availability. |
Sign in to HDM
The following information describes the prerequisites for a successful sign-in to HDM, the default sign-in parameters, the sign-in procedure, and password change.
Prepare for an HDM sign-in
Before you sign in to the HDM Web interface, make sure all preparation requirements are met.
Set up the HDM client
HDM does not require installation of client software. You can use a Web browser to access HDM.
Make sure the browser and resolution setting of the configuration terminal meet the requirements in Table 2.
Table 2 Browser and resolution requirements
Browsers |
Resolution |
Google Chrome 48.0 (or higher) Mozilla Firefox 50.0 (or higher) Internet Explorer 11 (or higher) |
Minimum: 1366*768 Recommended: 1600*900 (or higher) |
Connect the device to the network
Connect either of the following network ports on the device to the network:
· HDM shared network port—Transmits HDM management traffic and device data traffic simultaneously.
· HDM dedicated network port—Transmits only HDM management traffic.
Obtain the HDM sign-in settings
To sign in to HDM, you must obtain its management IP address and user account information.
On first sign-in, use the default settings in Table 3.
Table 3 Default HDM sign-in settings
Item |
Default setting |
IP address |
HDM shared network port: DHCP HDM dedicated network port: 192.168.1.2/24 |
Username |
admin |
Password (case-sensitive) |
You can obtain the HDM management IP address from the POST screen of the BIOS. As shown in Figure 1, the POST screen displays the IPv4 addresses of the shared and dedicated network ports at the upper right corner, and the IPv6 addresses at the lower left corner.
Figure 1 Obtaining the HDM management IP address
Sign in to HDM
By default, the session timeout is 30 minutes. If no operation is performed within 30 minutes, the system signs you out.
After five consecutive password check failures, your account will be locked for five minutes.
For security purposes, change the default username and password at the first sign-in, and update your password periodically.
1. Open the browser, and enter the HDM management IP address. This section uses Microsoft Internet Explorer 11.0 and https://192.168.1.2 as an example.
2. On the security certificate page that opens, click Continue to this website (not recommended).
3. (Optional.) To change the language, click for
English and
for Chinese on the HDM sign-in page.
4. Enter the username and password, and then click Sign in.
If this is the first sign-in, enter the default username (admin) and password (Password@_). The password is case sensitive.
Figure 2 HDM sign-in page
Change a password
As a best practice, change the username and password for security purposes at first sign-in.
To change the password:
1. In the navigation pane, select Configuration > User Accounts.
2. In the work pane, click Settings.
3. In the dialog box that opens, configure the password policy, and then click OK, as shown in Figure 4.
Figure 4 Configuring the password policy
4. Click Edit in the Actions column for user admin, as shown in Figure 3.
5. In the dialog box that opens, enter a new password, confirm the new password, and then click OK, as shown in Figure 5.
For more information about password setting requirements, see HDM online help.
Figure 5 Changing the password for a user account
Use HDM
HDM Web interface
To access the online help for an interface,
click the button at the upper right corner of that
interface.
The HDM Web interface contains three sections as shown in Figure 6.
Figure 6 HDM Web interface layout
Table 4 HDM Web interface description
Update HDM firmware
Only one user can update firmware at a time. If multiple users attempt to update firmware, only the one who first started the update can perform this operation. When you successfully start a firmware update, HDM automatically signs out all the other users that try to start a firmware update.
Do not refresh the HDM webpage during the update.
For the firmware to be updated successfully, do not perform the following tasks from the Web interface during the update process:
· Change network settings, including dedicated and shared network ports, VLAN, network port mode, Ethernet adapter, DNS, and network port mode.
· Configure NTP settings.
· Configure security settings, including access service, firewall, and SSL.
· View the device power status or change power capping settings.
· Perform the following maintenance tasks:
¡ Import or export configuration.
¡ Restore the factory default.
¡ Restart HDM.
¡ Perform primary/backup switchover.
¡ Restart CPLD.
To avoid HDM or operating system errors, do not power on, power off, or power cycle the device during the update.
The following remote console menus are not available during the update:
· Keyboard menu in the KVM console.
· Send Keys and Hot Keys menus in the H5 KVM console.
Update HDM firmware from HDM
HDM supports one primary firmware image and one backup firmware image, and it always runs the primary image. HDM firmware update updates the backup firmware image.
To minimize the impact on HDM services, HDM uses the following procedure to update HDM firmware:
1. When you update HDM firmware, HDM replaces the backup firmware image with the uploaded update image.
2. At the restart after the update, HDM changes the roles of primary and backup HDM images. Then, HDM restarts with the update image, which is now the primary image.
For more information about primary/backup switchover, see HDM online help.
· Sign in to the HDM Web interface. For more information, see "Sign in to HDM."
· Obtain the up-to-date HDM firmware image from the H3C website, and store the image file on the local PC. To avoid update failure, make sure the update image file contains a vendor signature and is not corrupt.
· To avoid configuration loss caused by inadvertent mistakes, back up the HDM configuration file.
1. In the navigation pane, select Maintenance > Update Firmware.
Figure 7 Update Firmware page
2. In the work pane, perform the following tasks:
a. Select an image upload method.
- If you select Local, select HDM as the firmware type. Then, browse to the update image file and select it.
- If you select TFTP, enter the IP address of the interface used for file upload and enter the image name. Then, select HDM as the firmware type.
b. Select the HDM restart method after the update is complete. You can have HDM automatically restart when the update is complete or manually restart HDM later.
c. (Optional.) To remove all user-configured settings after you update HDM firmware, select Enabled for Restore factory default.
d. Click Next.
CAUTION: The Restore factory default option removes all user configured settings when HDM starts up with the new firmware. When you select this option, make sure you understand its impact on the services. If this option is selected, you must use the default user account settings at the first sign-in to HDM after its firmware is updated. |
3. Verify that the new firmware image version is correct, and then click Next.
The firmware update starts and the system displays the update progress.
4. Follow the system instructions to complete the update.
5. If you selected manual restart, restart HDM manually. For more information, see HDM online help.
If you selected automatic restart, HDM restarts automatically.
6. To update the backup image, perform a primary/backup switchover, and then repeat the update process.
7. Re-sign in to HDM. Verify that the HDM firmware image has been updated.
FAQs
Fault diagnosis and location
HDM takes a bluescreen of death (BSoD) screenshot and video recording upon a system crash. When the system fails and restarts, you can view the BSoD screenshot or the video for troubleshooting.
HDM Web interface access failures
Table 5 describes the possible causes and solutions for HDM Web interface access failures.
Table 5 Causes and solutions for HDM Web interface access failures
HDM Web interface access failure reason |
Solution |
Network connection issue |
The HDM network port is disconnected. |
Connect the network cable for the HDM network port correctly. |
An incorrect HDM management IP address is used. |
Use the IP address of the HDM management interface for access. |
The local PC and HDM network port are not on the same network segment. |
Make sure the local PC and HDM network port are on the same network segment. |
Browser cache not cleared |
The firmware of HDM has been upgraded recently, but the browser cache is not cleared. |
Clear the browser cache and then re-sign in to HDM. |
Incorrect access information |
The username does not exist. |
User a username that has been created. At the first sign-in, use the default username and password. |
The password is not correct. |
Use the correct password. The password is case sensitive. |
