16-OpenFlow Command Reference
HomeSupportSwitchesS6800 SeriesReference GuidesCommand ReferencesH3C S6800 Switch Series Command References-Release 26xx-6W10716-OpenFlow Command Reference
Table of Contents
Related Documents
01-OpenFlow commands
01-OpenFlow commands 218.26 KB
OpenFlow commands
active instance
Use active instance to activate an OpenFlow instance.
Use undo active instance to deactivate an OpenFlow instance.
active instance
An OpenFlow instance is not activated.
OpenFlow instance view
If the VLAN configuration or flow table configuration of an activated OpenFlow instance is changed, use this command to reactivate the instance. After the OpenFlow instance is reactivated, it re-establishes connections to controllers if the OpenFlow instance was connected to the controllers before the reactivation.
# Activate OpenFlow instance 1.
[Sysname] openflow instance 1
[Sysname-of-inst-1] active instance
classification
Use classification to configure the OpenFlow instance mode.
Use undo classification to restore the default.
classification { global | vlan vlan-id [ mask vlan-mask ] [ loosen ] }
undo classification
The OpenFlow instance mode is not configured.
global: Specifies the global mode.
vlan: Specifies the VLAN mode.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
vlan-mask: Specifies a VLAN mask in the range of 0 to 4095. The default value is 4095.
loosen: Specifies the loosen mode. If the loosen mode is used, a port belongs to the OpenFlow instance when VLANs associated with the OpenFlow instance overlap with the port's allowed VLANs. If you do not specify the loosen mode, a port belongs to an OpenFlow instance only when VLANs associated with the OpenFlow instance are within the port's allowed VLAN list.
The VLANs to be associated are calculated by a bitwise AND operation on the specified VLAN ID and mask. The VLAN mask supports non-contiguous 1s and ignores all 0 bits. To view the associated VLANs, use the display openflow instance command.
# Enable the VLAN mode for OpenFlow instance 1 and associate OpenFlow instance 1 with VLANs determined by VLAN ID 255 and VLAN mask 7.
[Sysname-of-inst-1] classification vlan 255 mask 7
controller address
Use controller address to specify a controller for an OpenFlow switch and configure the main connection to the controller.
Use undo controller address to delete the main connection to the specified controller.
controller controller-id address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ local address { ip local-ipv4-address | ipv6 local-ipv6-address } [ port local-port-number ] ] [ ssl ssl-policy-name ] [ vrf vrf-name ]
undo controller controller-id address
An OpenFlow instance does not have a main connection to a controller.
controller-id: Specifies a controller by its ID in the range of 0 to 63.
ip ipv4-address: Specifies the IPv4 address of the controller.
ipv6 ipv6-address: Specifies the IPv6 address of the controller.
port port-number: Sets the port number used by the controller to establish TCP connections to the OpenFlow switch. The value range for the port number is 1 to 65535. The default value is 6633.
local address: Specifies the source IP address used to establish TCP connections to the controller. When multiple routes are available between a controller and a switch, you can use this keyword to configure a source IP address for the switch. When the switch restarts or an active/standby switchover occurs, the switch can use the original route to reconnect to the controller without selecting a new route.
ip local-ipv4-address: Specifies the source IPv4 address.
ipv6 local-ipv6-address: Specifies the source IPv6 address.
port local-port-number: Specifies the source port number in the range of 1 to 65535. If you do not specify this option, the system automatically assigns a source port number for establishing the main connection to the controller.
ssl ssl-policy-name: Specifies the SSL client policy that the controller uses to authenticate the OpenFlow switch. The ssl-policy-name argument is a case-insensitive string of 1 to 31 characters. You must configure a separate SSL client policy for the main connection to each controller.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VRF name, the controller is in the public network.
You can specify multiple controllers for an OpenFlow switch. The OpenFlow channel between the OpenFlow switch and each controller can have only one main connection.
The OpenFlow switch uses the main connection to a controller to exchange control messages with the controller to perform the following operations:
·     Receive flow table entries or data from the controller.
·     Report information to the controller.
As a best practice, configure a unicast IP address for a controller. An OpenFlow switch might fail to establish a connection with the controller that does not use a unicast IP address.
As a best practice, configure a unicast source IP address that is the IP address of a port belonging to the OpenFlow instance. If the source IP address is not a unicast address of a port belonging to the OpenFlow instance, the OpenFlow switch might fail to establish a connection with the controller.
# Specify controller 1 for OpenFlow instance 1. The controller's IP address is 1.1.1.1 and the port number is 6666.
[Sysname-of-inst-1] controller 1 address ip 1.1.1.1 port 6666
controller auxiliary
Use controller auxiliary to specify a controller for an OpenFlow switch and configure an auxiliary connection to the controller.
Use undo controller auxiliary to delete the specified auxiliary connection to the specified controller.
controller controller-id auxiliary auxiliary-id transport { tcp | udp | ssl ssl-policy-name } [ address { ip ipv4-address | ipv6 ipv6-address } ] [ port port-number ]
undo controller id auxiliary auxiliary-id
An OpenFlow instance does not have auxiliary connections to a controller.
auxiliary auxiliary-id: Specifies an auxiliary connection ID in the range of 1 to 255.
transport: Specifies the transport layer protocol.
tcp: Specifies TCP connections.
udp: Specifies UDP connections.
port port-number: Sets the port number used to establish TCP connections to the controller. The value range for the port number is 1 to 65535. The default value is 6633.
The OpenFlow channel might have one main connection and multiple auxiliary connections. Auxiliary connections are used to improve the communication performance between the controller and OpenFlow switches.
Make sure the configuration of an auxiliary connection does not conflict with the configuration of the main connection. Otherwise, the auxiliary connection cannot be established.
An auxiliary connection can have a different destination IP address and port number than the main connection. If no destination IP address and port number are specified, the auxiliary connection uses the destination IP address and port number configured for the main connection.
# Specify controller 1 for OpenFlow instance 1 and configure auxiliary connection 1 to the controller.
[Sysname-of-inst-1] controller 10 auxiliary 1 transport tcp
controller connect interval
Use controller connect interval to set the interval for an OpenFlow instance to reconnect to a controller.
Use undo controller connect interval to restore the default.
controller connect interval interval
An OpenFlow instance reconnects to a controller every 60 seconds.
interval: Specifies the reconnection interval in the range of 1 to 120 seconds.
# Configure OpenFlow instance 1 to reconnect to a controller every 10 seconds.
[Sysname-of-inst-1] controller connect interval 10
controller echo-request interval
Use controller echo-request interval to set the echo request interval for an OpenFlow switch.
Use undo controller echo-request interval to restore the default.
controller echo-request interval interval
The echo request interval is 5 seconds for an OpenFlow switch.
interval: Specifies the echo request interval in the range of 1 to 10 seconds.
# Set the echo request interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller echo-request interval 10
controller mode
Use controller mode to set the controller mode for an OpenFlow instance.
Use undo controller mode to restore the default.
The controller mode is multiple.
multiple: Specifies the multiple mode.
single: Specifies the single mode.
In single mode, the OpenFlow switch connects to only one controller at a time. When communication with the current controller fails, the OpenFlow instance connects to the controller with the lowest ID among the rest controllers.
In multiple mode, the OpenFlow switch simultaneously connects to all controllers. If one or more controllers become invalid or disconnected, the OpenFlow switch continues to exchange messages with the rest of the controllers.
# Set all controllers of OpenFlow instance 1 to operate in single mode.
[Sysname-of-inst-1] controller mode single
datapath-id
Use datapath-id to set the datapath ID for an OpenFlow instance.
Use undo datapath-id to restore the default.
datapath-id id
undo datapath-id
The datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address of the device. The lower 16 bits are the instance ID and the upper 48 bits are the bridge MAC address of the device.
id: Specifies the datapath ID for the OpenFlow instance, in the range of 1 to ffffffffffffffff in hexadecimal format.
# Set the datapath ID to 123456 for OpenFlow instance 1.
[Sysname-of-inst-1] datapath-id 123456
default table-miss permit
Use default table-miss permit to change the default action of table-miss flow entries to forward packets to the normal pipeline.
Use undo default table-miss permit to restore the default.
The default action of a table-miss flow entry is to drop packets.
With the default table-miss permit command configured for an OpenFlow instance, all table-miss flow entries of the OpenFlow instance forward packets to the normal pipeline.
When the default table-miss permit command is not configured for an OpenFlow instance, the following rules apply:
·     In versions earlier than R2612, all table-miss flow entries of the OpenFlow drop packets.
·     In R2612 and later versions, two serial extensibility flow tables are supported.
¡     The default action of the table-miss flow entry in extensibility table 1 is Goto-Table.
¡     The default action of the table-miss flow entries in the other flow tables is to drop packets.
# Configure the default action of table-miss flow entries to forward packets to the normal pipeline.
[Sysname-of-inst-1] default table-miss permit
description
Use description to configure a description for an OpenFlow instance.
An OpenFlow instance does not have a description.
# Configure the description as test-desc for OpenFlow instance 1.
[Sysname-of-inst-1] description test-desc
display openflow
Use display openflow to display controller information for an OpenFlow instance.
display openflow instance instance-id { controller [ controller-id ] | listened }
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094.
controller-id: Specifies a controller by its ID in the range of 0 to 63. If you do not specify a controller ID, this command displays information about all controllers for an OpenFlow instance.
listened: Specifies the client that connects to the server that is enabled for the OpenFlow instance.
# Display controller information for OpenFlow instance 100.
<Sysname> display openflow instance 100 controller
OpenFlow instance ID: 100
 Reconnect interval : 60 (s)
 Echo interval      : 5  (s)
 Controller ID           : 1
 Controller IP address   : 192.168.49.49
 Controller port         : 6633
 Local IP address        : 192.0.0.1
 Local port              : 5566
 Controller role         : Equal
 Connect type            : TCP
 Connect state           : Established
 Packets sent            : 9
 Packets received        : 9
 SSL policy              : --
 VRF name                : --
Reconnect interval
Reconnection interval (in seconds) for an OpenFlow instance to reconnect to all controllers.
Echo interval
Connection detection interval (in seconds) at which an OpenFlow instance sends an echo request message to all controllers.
IP address of the controller.
Controller port
TCP port number of the controller.
Local IP address
Source IP address of the controller that is connected to the OpenFlow instance.
Local port
Source TCP port number of the current controller.
Controller role
Role of the controller:
·     Equal—The controller has the same mode as other controllers that are specified for the OpenFlow instance.
·     Master—The controller is the master controller for the OpenFlow instance.
·     Slave—The controller is a subordinate controller for the OpenFlow instance.
If the controller is not configured with any role, this field displays two hyphens (--).
Connect type
Type of the connection between the OpenFlow instance and the controller: TCP or SSL.
Connect state
State of the connection between the OpenFlow instance and the controller: Idle or Established.
Packets sent
Number of packets that have been sent to the controller.
Packets received
Number of packets that have been received from the controller.
SSL policy
Name of the SSL client policy used for SSL connections.
If no SSL client policy is configured, this field displays two hyphens (--).
VRF name
Name of the MPLS L3VPN to which the controller belongs.
If no MPLS L3VPN instance is configured, this field displays two hyphens (--).
display openflow auxiliary
Use display openflow auxiliary to display auxiliary connection information and statistics about received and sent packets for an OpenFlow instance.
display openflow instance instance-id auxiliary [ controller-id [ auxiliary auxiliary-id ] ]
auxiliary auxiliary-id: Specifies an auxiliary connection by its ID in the range of 1 to 255.
# Display auxiliary connection information for OpenFlow instance 100.
<Sysname> display openflow instance 100 auxiliary
Controller ID: 1    Auxiliary connection number: 2
 Auxiliary connection ID : 1
  Controller IP address  : 192.168.49.48
  Connect type           : TCP
  Packets sent           : 9
  SSL policy             : --
 Auxiliary connection ID : 2
   Connect type          : TCP
   Packets sent          : 9
   SSL policy            : --
Total number of auxiliary connections.
ID of an auxiliary connection.
Controller port
Connect type
Type of the connection between the OpenFlow instance and the controller: TCP UDP, or SSL.
Connect state
Packets sent
Packets received
SSL policy
display openflow flow-table
Use display openflow flow-table to display flow table information for an OpenFlow instance.
display openflow instance instance-id flow-table [ table-id ]
table-id: Specifies a flow table by its ID in the range of 0 to 254. If you do not specify a flow table ID, the command displays information about all flow tables for the specified OpenFlow instance.
# Display information about all flow tables for OpenFlow instance 100.
<Sysname> display openflow instance 100 flow-table
Instance 100 flow table information:
Table 0 information:
 Table type: MAC-IP, flow entry count: 1, total flow entry count: 2
MissRule (default) flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: reset_counts
 |no_pkt_counts|no_byte_counts, byte count: --, packet count: --
Match information: any
Instruction information:
 Write actions:
  Drop
Flow entry rule 1 information:
 cookie: 0x0, priority: 1, hard time: 0, idle time: 0, flags: none,
Match information:
 Ethernet destination MAC address: 0000-0000-0001
 Ethernet destination MAC address mask: ffff-ffff-ffff
 VLAN ID: 100, mask: 0xfff
 Write actions:
  Output interface: XGE1/0/4
 Write metadata/mask: 0x0000000000000001/0xffffffffffffffff
 Goto table: 1
Table 1 information:
 Table type: Extensibility, flow entry count: 2, total flow entry count: 2
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: none,
 byte count: 300, packet count: 60
 Write actions:
  Drop
Flow entry rule 1 information: (Not effective)
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem
 |check_overlap, byte count: 8, packet count: 1
Match information:
 Input interface: XGE1/0/3
 Ethernet source MAC address: 0000-0000-0001
 Ethernet source MAC address mask: ffff-ffff-ffff
 Set meter: 100
 Apply actions:
 Write actions:
  Output interface: Controller, send length: 128 bytes
Table information
Information about the flow table.
Table type
Type of the flow table: MAC-IP or Extensibility.
flow entry count
Number of flow entries deployed by the controller.
Total number of flow entries in the table.
Flow entry rule information
Information about the flow entry. If the flow entry does not take effect, this field displays Not effective.
cookie
Cookie ID of the flow entry.
priority
Priority of the flow entry. The larger the value, the higher the priority.
hard time
Hard timeout of the flow entry, in seconds. The flow entry is removed when the timer times out, whether or not the flow entry matches any data stream.
If the flow entry has no hard timeout, the field displays 0.
idle time
Idle timeout of the flow entry, in seconds. The flow entry is removed if the flow entry does not match any data stream during the idle time.
If the flow entry has no idle timeout, the field displays 0.
flags
Flags that the flow entry includes:
·     flow_send_rem—Sends a flow removed message when the flow entry is removed or expires.
·     check_overlap—Checks for overlapping flow entries.
·     reset_counts—Resets flow table counters.
·     no_pkt_counts—Does not count packets.
·     no_byte_counts—Does not count bytes.
If the flow entry does not include any flags, this field displays none.
byte count
Number of bytes that have matched the flow entry.
packet count
Number of packets that have matched the flow entry.
Match information
Contents of the match field of the flow entry (see Table 4).
Contents of the instruction set of the flow entry:
·     Set meter—Sends the matched packet to a specific meter.
·     Goto table—Sends the matched packet to the next flow table for processing.
·     Clear actions—Immediately clears all actions in the action set.
·     Apply actions—Immediately applies specified actions in the action set.
·     Write actions—Writes specified actions into the current action set.
For more information about actions, see Table 5.
Table 4 Match field types
Mask field
Input interface
N/A
Ingress port (see Table 6).
Physical input interface
N/A
Ingress physical port.
Metadata
Metadata mask
Metadata and mask.
Ethernet destination MAC address and mask.
Ethernet source MAC address and mask.
Ethernet type
N/A
Ethernet type of the OpenFlow packet payload.
VLAN ID
Mask
VLAN ID and mask.
VLAN PCP
N/A
VLAN priority.
IP DSCP
N/A
Differentiated Services Code Point (DSCP) value.
IP ECN
N/A
Explicit Congestion Notification (ECN) value in the IP header.
IP protocol
N/A
IPv4 or IPv6 protocol number.
IPv4 source address
Mask
IPv4 source address and mask.
IPv4 destination address
Mask
IPv4 destination address and mask.
TCP source port
Mask
TCP source port and mask.
TCP destination port
Mask
TCP destination port and mask.
UDP source port
Mask
UDP source port and mask.
UDP destination port
Mask
UDP destination port and mask.
ICMPv4 type
N/A
ICMPv4 type.
ICMPv4 code
N/A
ICMPv4 code.
ARP source IPv4 address
Mask
Sender IPv4 address and mask in the ARP payload.
ARP source MAC address
ARP source MAC address mask
Sender MAC address and mask in the ARP payload.
IPv6 source address
IPv6 source address mask
Source IPv6 address and mask.
IPv6 destination address
IPv6 destination address mask
Destination IPv6 address and mask.
IPv6 flow label
Mask
IPv6 flow label and mask.
ICMPv6 type
N/A
ICMPv6 type.
ICMPv6 code
N/A
ICMPv6 code.
Output interface
N/A
Output port.
VRF index
N/A
VPN index.
Fragment
N/A
Fragment.
Physical output interface
N/A
Output physical port.
CVLAN ID
Mask
CVLAN ID and mask.
Experimenter
N/A
Extension matching fields. Address ID represents the unique identifier of an address.
Table 5 Actions
Drop
Drops the matched packet. This action is not defined in the OpenFlow specifications.
Output interface
Sends the packet through a specific port. For more information about ports, see Table 6.
send length
Specifies the max length of bytes to be taken from the packet and sent to the controller.
This field appears only when the reserved port of the controller type is specified as the output port.
Group
Specifies a group table to process the packet.
Set queue
Maps the flow entry to a queue specified by its ID.
Set field
Modifies a field of the packet.
Table 6 Ports
Port name
Ingress port
Output port
Normal
Not supported.
Supported.
Processing the packet by using the normal forwarding process.
Flood
Not supported.
Supported.
Flooding the packet.
Controller
Supported.
Supported.
Sending the packet to the controller.
Local
Supported.
Supported.
Sending the packet to the local CPU.
Any
Not supported.
Not supported.
Special value used in some OpenFlow commands when you do not specify a port.
port name
Supported.
Supported.
Valid physical or logical port on the switch.
display openflow group
Use display openflow group to display group entry information for an OpenFlow instance.
display openflow instance instance-id group [ group-id ]
group-id: Specifies a group by its ID in the range of 0 to 4294967040. If you do not specify a group ID, this command displays information about all group entries for an OpenFlow instance.
# Display group entry information for OpenFlow instance 100.
<Sysname> display openflow instance 100 group
Instance 100 group table information:
 Group count: 2
Group entry 103:
 Type: All, byte count: 55116, packet count: 401
 Bucket 1 information:
Action count 1, watch port: any, watch group: any
Byte count 55116, packet count 401
  Output interface: BAGG100
 Bucket 2 information:
  Byte count --, packet count --
 Referenced information:
  Count: 3
  Flow table 0
  Flow entry: 1, 2, 3
Group entry 104:
 Type: All, byte count: 0, packet count: 0
  Count: 0
Table 7 Command output
Group count
Total number of group entries included in the OpenFlow instance.
Type of the group entry:
·     All—Executes all buckets in the group. This group is used for multicast or broadcast forwarding.
·     Select—Executes one bucket in the group.
·     Indirect—Executes the one defined bucket in the group.
·     Fast failover—Executes the first live bucket.
Bucket
Buckets included in the group table.
Action count
Number of actions included in the bucket.
Byte count
Number of bytes processed by a group or by a bucket.
If this field is not supported, the field displays two hyphens (--).
packet count
Number of packets processed by a group or by a bucket.
watch port
Port whose state affects whether this bucket is live.
watch group
Group whose state affects whether this bucket is live.
Output interface
Output interface included in the group entry.
Information about the group entry used by flow entries.
Count
Total number of flow entries that use the group entry.
Flow table
Flow table to which the flow entries that use the group entry belong.
Flow entry
Flow entries that use the group entry.
Use display openflow instance to display detailed information about an OpenFlow instance.
display openflow instance [ instance-id ]
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094. If you do not specify an instance ID, this command displays detailed information about all OpenFlow instances.
# Display detailed information about OpenFlow instance 100.
Instance 100 information:
Configuration information:
 Description   : test-desc
 Active status : Active
 Inactive configuration:
  None
 Active configuration:
  Classification: VLAN, loosen mode, total VLANs(1)
   2
  In-band management VLAN, total VLANs(0)
   Empty VLAN
  Connect mode: Multiple
  MAC address learning: Disabled
  TCP DSCP value: 10
  Flow table:
   Table ID(type): 0(MAC-IP), count: 0
  Flow-entry max-limit: 65535
  Datapath ID: 0x0000001234567891
  Default table-miss: Drop
  Forbidden port: None
  Qinq Network: Disabled
  TCP connection backup: Enabled
Port information:
 Ten-GigabitEthernet1/0/3
Active channel information:
 Controller 1 IP address: 192.168.49.49  port: 6633
 Controller 2 IP address: 192.168.43.49  port: 6633
Table 8 Command output
Information about the configuration.
Description of the OpenFlow instance.
Active status
OpenFlow instance status: Active or Inactive.
Inactive configuration for the OpenFlow instance.
Active configuration for the OpenFlow instance.
Classification: VLAN, total VLANs
VLANs that are associated with the OpenFlow instance and the total number of these VLANs.
loose mode
The loose mode is used.
Inband management VLANs and the total number of them.
Connect mode
Connection mode of the controller:
·     Single—The OpenFlow instance connects to only one controller at a time.
·     Multiple—The OpenFlow instance can simultaneously connect to multiple controllers.
Whether MAC address learning is disabled: Enabled or Disabled.
TCP DSCP value
DSCP value for OpenFlow packets.
Flow table
Flow table information for the OpenFlow instance.
Table ID(type)
count
Total number of flow entries included in the current flow table.
Maximum number of flow entries allowed in the extensibility flow table.
Datapath ID
Datapath ID of the OpenFlow instance.
Default table-miss
Default action of the table-miss flow entry: Permit or Drop.
Forbidden port
Type of interfaces that are forbidden to be reported to the controller:
·     L3 Physical Interface—Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces.
·     VLAN interface.
Qinq Network
Whether the OpenFlow instance is enabled to perform QinQ tagging for double-tagged packets passing an extensibility flow table:
·     Disabled.
·     Enabled.
Whether OpenFlow connection backup is enabled:
·     Disabled.
·     Enabled.
Port information
Ports that have been added to the OpenFlow instance.
Information about active channels.
IP address
IP address of the controller configured for the OpenFlow instance.
Port
TCP port number that is used to connect to the controller.
Failopen mode
Connection interruption mode for the OpenFlow instance:
·     Standalone.
·     Smart.
·     Secure.
display openflow meter
Use display openflow meter to display meter entry information for an OpenFlow instance.
display openflow instance instance-id meter [ meter-id ]
meter-id: Specifies a meter by its ID in the range of 1 to 4294901760. If you do not specify a meter ID, this command displays information about all meter entries for an OpenFlow instance.
# Display meter entry information for OpenFlow instance 100.
<Sysname> display openflow instance 100 meter
Meter flags: KBPS  -- Rate value in kb/s, PKTPS -- Rate value in packet/sec
             BURST -- Do burst size,      STATS -- Collect statistics
Instance 100 meter table information:
 meter entry count: 2
Meter entry 100 information:
 Meter flags: KBPS
 Band 1 information
 Type: drop, rate: 1024, burst size: 65536
 Byte count: --, packet count: --
  Count: 3
  Flow table: 0
  Flow entry: 1, 2, 3
Meter entry 200 information:
 Meter flags: KBPS
 Band 1 information
 Type: drop, rate: 10240, burst size: 655360
  Count: 0
Table 9 Command output
Group entry count
Total number of meter entries that the OpenFlow instance has.
Meter flags
Flags configured for the meter:
·     KBPS—The rate value is in kbps.
·     PKTPS—The rate value is in pps.
·     BURST—The burst size field in the band is used and the length of the packet or byte burst is determined by the burst size.
·     STATS—Meter statistics are collected.
Band
Bands contained in the meter.
Type of the band:
·     drop—Discard the packet.
·     dscp remark—Modify the drop precedence of the DSCP field in the IP header of the packet.
Rate
Rate value above which the corresponding band applies to packets.
Burst size
Length of the packet or byte burst to consider for applying the meter.
Byte count
Number of bytes processed by a band.
packet count
Number of packets processed by a band.
Information about the meter entry used by flow entries.
Count
Total number of flow entries that use the meter entry.
Flow table
Flow table to which the flow entries that use the meter entry belong.
Flow entry
Flow entries that use the meter entry.
display openflow summary
Use display openflow summary to display brief OpenFlow instance information.
# Display brief OpenFlow instance information.
<Sysname> display openflow summary
Fail-open mode: Se - Secure mode, Sa - Standalone mode
ID    Status    Datapath-ID         Channel    Table-num  Port-num  Reactivate
1     Active    0x0000000100001221  Connected  2          8         N
10    Inactive  -                   -          -          -         -
4094  Active    0x00000ffe00001221  Failed(Sa) 2          0         N
Table 10 Command output
ID
OpenFlow instance ID.
Status
Activation status of the OpenFlow instance:
·     Active—The OpenFlow instance has been activated.
·     Inactive—The OpenFlow instance has not been activated.
Datapath-ID
If the OpenFlow instance is not activated, this field displays a hyphen (-).
Channel
Status of the OpenFlow channel to the controller:
·     Connected—An OpenFlow channel has been established.
·     Failed(Se)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the secure connection interruption mode.
·     Failed(Sm)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the smart connection interruption mode.
·     Failed(Sa)—The OpenFlow channel is disconnected from the controller, and the OpenFlow instance uses the standalone connection interruption mode.
Table num
Number of flow tables that the OpenFlow instance has.
Port num
Number of ports that belong to the OpenFlow instance.
Reactivate
Whether the OpenFlow instance is required to be reactivated. N indicates the configuration is unchanged and the OpenFlow instance is not required to be reactivated.
fail-open mode
Use fail-open mode to set the connection interruption mode for an OpenFlow switch.
Use undo fail-open mode to restore the default.
fail-open mode { secure | smart | standalone }
undo fail-open mode
The connection interruption mode is secure, and the controller deploys the table-miss flow entry (the action is Drop) to the OpenFlow instance.
secure: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is discarded.
smart: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers. If the output action in a matching flow entry is to forward traffic to a controller, the traffic is forwarded in normal process.
standalone: Configures the OpenFlow switch to use the normal forwarding process after it is disconnected from all controllers.
# Set the connection interruption mode to standalone for OpenFlow instance 1.
[Sysname-of-inst-1] fail-open mode standalone
flow-entry max-limit
Use flow-entry max-limit to set the maximum number of entries for the extensibility flow table on an OpenFlow switch.
Use undo flow-entry max-limit to restore the default.
flow-entry max-limit limit-value
The extensibility flow table can have a maximum of 65535 flow entries.
limit-value: Specifies the maximum number of flow entries. The value range for this argument is 1 to 65535.
If the number of extensibility flow table entries deployed from a controller to an OpenFlow switch exceeds the maximum, the switch sends a deployment failure notification to the controller.
# Configure OpenFlow instance 1 to have a maximum of 256 entries in the extensibility flow table.
[Sysname-of-inst-1] flow-entry max-limit 256
flow-log disable
Use flow-log disable to disable logging for successful flow table modifications.
Use undo flow-log disable to restore the default.
flow-log disable
Logging for successful flow table modifications is enabled.
# Disable logging for successful flow table modifications for OpenFlow instance 1.
[Sysname-of-inst-1] flow-log disable
flow-table
Use flow-table to create a flow table for an OpenFlow instance.
Use undo flow-table to restore the default.
flow-table { [ ingress-vlan ingress-table-id ] [ { extensibility extensibility-table-id }&<1-2> | mac-ip mac-ip-table-id ] * [ egress-vlan egress-table-id ] }
undo flow-table
An OpenFlow instance has an extensibility flow table with ID 0.
ingress-vlan ingress-table-id: Specifies a VLAN tagging flow table by its ID in the range of 0 to 254. If you specify this option, the device tags all incoming packets matching the table.
extensibility extensibility-table-id: Specifies an extensibility flow table by its ID in the range of 0 to 254.
mac-ip mac-ip-table-id: Specifies a MAC-IP flow table by its ID in the range of 0 to 254.
egress-vlan egress-table-id: Specifies a VLAN untagging flow table by its ID in the range of 0 to 254. If you specify this option, the device untags all outgoing packets matching the table.
Only R2612 and later versions support two serial extensibility flow tables.
Create flow tables for an OpenFlow instance before you activate the OpenFlow instance.
The ID you enter for an extensibility flow table must be larger than the ID for an MAC-IP flow table.
If you specify the ingress-vlan ingress-table-id option, make sure the VLAN tagging flow table has the smallest ID among all flow tables. If you specify the egress-vlan egress-table-id option, make sure the VLAN untagging flow table has the largest ID among all flow tables. The VLAN tagging flow table and untagging flow table take effect only when the following conditions are met:
·     The OpenFlow instance is configured to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
·     The OpenFlow instance uses the standalone connection interruption mode.
# Create a MAC-IP flow table with ID 0 and an extensibility flow table with ID 1 for OpenFlow instance 1.
[Sysname-of-inst-1] flow-table mac-ip 0 extensibility 1
qinq-network enable
forbidden packet-in arp controller
Use forbidden packet-in arp controller to configure controllers to which ARP packets are forbidden to be reported.
Use undo forbidden packet-in arp controller to restore the default.
forbidden packet-in arp controller controller-id-list
undo forbidden packet-in arp controller [ controller-id-list ]
No controllers to which ARP packets are forbidden to be reported are configured.
controller-id-list: Specifies a space-separated list of a maximum of 10 controller items. Each item specifies a controller ID or a range of controller IDs in the form of controller-id1 to controller-id2. The value range for controller IDs is 0 to 63. The value for the controller-id2 argument must be equal to or greater than the value for the controller-id1 argument. If you do not specify the controller-id-list argument, the undo form of this command restores all configuration of this feature to the default.
# Forbid the device not to report ARP packets to controller 0.
[Sysname-of-inst-1] forbidden packet-in arp controller 0
forbidden port
Use forbidden port to forbid an OpenFlow instance from reporting ports of the specified types to controllers.
Use undo forbidden port to restore the default.
forbidden port { l3-physical-interface | vlan-interface } *
undo forbidden port
All ports that belong to an OpenFlow instance are reported to the controllers.
l3-physical-interface: Specifies Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces that belong to an OpenFlow instance.
vlan-interface: Specifies VLAN interfaces that belong to an OpenFlow instance.
# Forbid OpenFlow instance 1 from reporting VLAN interfaces that belong to the OpenFlow instance to controllers.
[Sysname-of-inst-1] forbidden port vlan-interface
in-band management vlan
Use in-band management vlan to configure inband management VLANs for an OpenFlow instance.
Use undo in-band management vlan to restore the default.
in-band management vlan { vlan-id [ to vlan-id ] } &<1-10>
No inband management VLANs are configured for an OpenFlow instance.
By default, traffic in VLANs associated with an OpenFlow instance is forwarded in OpenFlow forwarding process. The OpenFlow instance cannot use these VLANs to connect to the controller.
You can use this command to specify inband management VLANs for an OpenFlow instance. Traffic in inband management VLANs is forwarded in the normal forwarding process instead of the OpenFlow forwarding process. Inband management VLANs are used by an OpenFlow instance to connect to controllers.
# Configure VLAN 10 as the inband management VLAN for OpenFlow instance 1.
[Sysname-of-inst-1] in-band management vlan 10
listening port
Use listening port to enable an SSL server for an OpenFlow instance.
Use undo listening port to restore the default.
listening port port-number ssl ssl-policy-name
undo listening port
No SSL server is enabled for an OpenFlow instance.
port-number: Specifies the SSL server port number in the range of 1 to 65535.
ssl ssl-policy-name: Specifies the SSL server policy name, a case-insensitive string of 1 to 31 characters.
Typically, an OpenFlow instance acts as the TCP/SSL client and actively connects to the controller (SSL server).
You can configure this feature to enable an SSL server for an OpenFlow instance. After an SSL server is enabled for an OpenFlow instance, the controller acts as an SSL client and actively connects to the OpenFlow instance.
To re-configure the SSL server, first execute the undo form of the command to delete the existing SSL server configuration.
# Enable an SSL server with the port number 20000 for OpenFlow instance 1.
[Sysname-of-inst-1] listening port 20000 ssl ssl_name
loop-protection enable
Use loop-protection enable to enable loop guard for an OpenFlow instance.
Use undo loop-protection enable to restore the default.
Loop guard is disabled for an OpenFlow instance.
After an OpenFlow instance is deactivated, loops might occur in VLANs associated with the OpenFlow instance. To avoid loops, you can enable loop guard for the OpenFlow instance. This feature enables the deactivated OpenFlow instance to create a flow entry for dropping all traffic in theses VLANs.
# Enable loop guard for OpenFlow instance 1.
[Sysname-of-inst-1] loop-protection enable
mac-ip dynamic-mac aware
Use mac-ip dynamic-mac aware to configure an OpenFlow instance to support dynamic MAC addresses.
Use undo mac-ip dynamic-mac aware to restore the default.
An OpenFlow instance does not support dynamic MAC addresses and ignores dynamic MAC address messages sent from controllers.
This command configures an OpenFlow instance to support querying and deleting dynamic MAC addresses in only MAC-IP flow tables. The OpenFlow instance does not send change events for the dynamic MAC addresses to controllers.
# Configure OpenFlow instance 1 to support dynamic MAC addresses.
[Sysname-of-inst-1] mac-ip dynamic-mac aware
mac-learning forbidden
Use mac-learning forbidden to configure OpenFlow to forbid MAC address learning in VLANs associated with an OpenFlow instance.
Use undo mac-learning forbidden to restore the default.
MAC address learning is allowed for VLANs associated with an OpenFlow instance.
# Forbid MAC address learning in VLANs associated with OpenFlow instance 1.
[Sysname-of-inst-1] mac-learning forbidden
openflow instance
Use openflow instance to create an OpenFlow instance and enter its view, or enter the view of an existing OpenFlow instance.
Use undo openflow instance to remove an OpenFlow instance.
undo openflow instance instance-id
No OpenFlow instances exist.
# Create OpenFlow instance 1 and enter OpenFlow instance view.
[Sysname-of-inst-1]
openflow lossless enable
Use openflow lossless enable to enable packet loss prevention for OpenFlow forwarding.
Use undo openflow lossless enable to disable packet loss prevention for OpenFlow forwarding.
Packet loss prevention for OpenFlow forwarding is disabled.
In R2612 and later versions, when packet loss prevention is enabled, the device drops a packet that meets the following conditions:
·     The output action of the packet is to forward the packet in the normal forwarding process.
·     The interface associated with the normal forwarding process is configured with an ACL to drop the packet.
Packet loss prevention ensures successful OpenFlow forwarding without packet loss. In an OpenFlow network, packet loss might occur on the switch during the flow entry deployment process. Packet loss then causes OpenFlow forwarding errors. For example, traffic is mistakenly sent to controllers and the controllers deploy faulty flow entries.
When this feature is enabled, the OpenFlow matching ability is decreased. For example, packets cannot be matched by IPv6 address.
Do not enable this feature in non-OpenFlow networks. Otherwise, the forwarding efficiency and matching ability might be decreased.
After you enable or disable packet loss prevention on a switch, save the configuration and restart the switch to make the configuration take effect.
# Enable packet loss prevention for OpenFlow forwarding.
[Sysname] openflow lossless enable
 Enable lossless traffic function? [Y/N]:y
 For the setting to take effect, save the configuration, and then reboot the device.
openflow normal-forward vlan
Use openflow normal-forward vlan to exclude the specified VLANs from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
Use undo openflow normal-forward vlan to restore the default.
openflow normal-forward vlan { vlan-id [ to vlan-id ] } &<1-10>
No VLANs are excluded from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
The VLANs to be associated with an OpenFlow instance are calculated by a bitwise AND operation on the VLAN ID and mask. Use this command to exclude VLANs in which traffic is required to be forwarded in the normal forwarding process from the calculated VLANs. Traffic in the excluded VLANs is forwarded in the normal forwarding process instead of the OpenFlow forwarding process.
# Exclude VLAN 10 from the VLANs in which traffic is forwarded in the OpenFlow forwarding process.
[Sysname] openflow normal-forward vlan 10
openflow shutdown
Use openflow shutdown to shut down an interface by OpenFlow.
Use undo openflow shutdown to restore the default.
openflow shutdown
An interface is not shut down by OpenFlow.
Only R2612 and later versions support this command in Layer 3 Ethernet interface view and Layer 2 aggregate interface view.
After an interface is shut down by OpenFlow, the Current state field displays OFP DOWN in the display interface command output.
You can use the undo openflow shutdown command to bring up an interface shut down by OpenFlow. The interface can also be brought up by port modification messages from controllers.
# Shut down Ten-GigabitEthernet 1/0/1 by OpenFlow.
[Sysname-Ten-GigabitEthernet1/0/1] openflow shutdown
permit-port-type member-port
Use permit-port-type member-port to allow link aggregation member ports to be in the deployed flow tables.
Use undo permit-port-type to restore the default.
Link aggregation member ports cannot be in the deployed flow tables.
# Configure OpenFlow instance 1 to allow link aggregation member ports to be in the deployed flow tables.
[Sysname-of-inst-1] permit-port-type member-port
precedence dynamic arp
Use precedence dynamic arp to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
Use undo precedence dynamic to restore the default.
undo precedence dynamic arp
An OpenFlow instance does not allow dynamic ARP entries to overwrite OpenFlow ARP entries.
This command increases the precedence of dynamic ARP entries to overwrite OpenFlow ARP entries.
OpenFlow ARP entries are generated based only on the MAC-IP flow table of an OpenFlow instance.
# Configure OpenFlow instance 1 to allow dynamic ARP entries to overwrite OpenFlow ARP entries.
[Sysname-of-inst-1] precedence dynamic arp
protocol-packet filter slow
Use protocol-packet filter slow to create a highest-priority flow entry for dropping slow protocol packets.
Use undo protocol-packet filter to restore the default.
An OpenFlow instance does not have a highest-priority flow entry for dropping slow protocol packets.
The flow entry created by using this command has a higher priority than the flow entries deployed by controllers.
The slow protocols include LACP, LAMP, and OAM.
# Create a highest-priority flow entry for OpenFlow instance 1 to drop slow protocol packets.
[Sysname-of-inst-1] protocol-packet filter slow
qinq-network enable
Use qinq-network enable to enable an OpenFlow instance to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
Use undo qinq-network enable to restore the default.
qinq-network enable
A double-tagged packet becomes single-tagged after it passes an extensibility flow table.
Execute this command to make double-tagged packets keep double-tagged after the packets pass an extensibility flow table.
# Enable OpenFlow instance 1 to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
[Sysname-of-inst-1] qinq-network enable
flow-table
refresh ip-flow
Use refresh ip-flow to refresh all Layer 3 flow entries in the MAC-IP flow tables for an OpenFlow instance.
refresh ip-flow
Layer 3 flow entries in the MAC-IP flow tables might be overwritten. In such cases, you can use this command to obtain all Layer 3 flow entries in the MAC-IP flow tables from the controller again.
# Refresh all Layer 3 flow entries in the MAC-IP flow tables for OpenFlow instance 1.
[Sysname-of-inst-1] refresh ip-flow
reset openflow instance statistics
Use reset openflow instance statistics to clear statistics on packets that a controller sends and receives for an OpenFlow instance.
reset openflow instance instance-id { controller [ controller-id ] | listened } statistics
controller-id: Specifies a controller by its ID in the range of 0 to 63. If you do not specify a controller ID, this command clears statistics on packets that all controllers send and receive for an OpenFlow instance.
listened: Specifies the client that connects to the server enabled for the OpenFlow instance.
# Clear statistics on packets that all controllers send and receive for OpenFlow instance 1.
<Sysname> reset openflow instance 1 controller statistics
tcp dscp
Use tcp dscp to set a DSCP value for OpenFlow packets.
Use undo tcp dscp to restore the default.
tcp dscp dscp-value
undo tcp dscp
The DSCP value for OpenFlow packets is not set.
dscp-value: Specifies a DSCP value for OpenFlow packets, in the range of 0 to 63.
# Set the DSCP value to 63 for OpenFlow packets.
[Sysname-of-inst-1] tcp dscp 63
tcp-connection backup
Use tcp-connection backup to enable OpenFlow connection backup.
Use undo tcp-connection backup to disable OpenFlow connection backup.
OpenFlow connection backup is enabled.
This command enables an OpenFlow instance to back up OpenFlow connections established over TCP. This prevents connection interruption when an active/standby switchover occurs.
# Disable OpenFlow connection backup for OpenFlow instance 1.
[Sysname-of-inst-1] undo tcp-connection backup
