| 03-WLAN DRS configuration | 74.74 KB |
Restrictions: Hardware compatibility with WLAN DRS
Configuring DRS information reporting to the Oasis server
WLAN DRS configuration examples
Configuring WLAN DRS
About WLAN DRS
DPI report statistics (DRS) classifies and stores user application and URL session information detected by DPI and sends the information to the Oasis server as configured.
Hardware series |
Model |
WLAN DRS compatibility |
WX2500H series |
WX2508H-PWR-LTE WX2510H WX2540H WX2560H |
Yes |
WX3000H series |
WX3010H WX3010H-X WX3024H WX3024H-L |
Yes: · WX3010H · WX3010H-X · WX3024H No: · WX3010H-L · WX3024H-L |
WX3500H series |
WX3508H WX3510H WX3520H WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
Yes |
Access controller modules |
LSQM1WCMX20 LSQM1WCMX40 LSUM1WCME0 LSUM1WCMX20RT LSUM1WCMX40RT |
Yes |
Hardware series |
Model |
WX1800H series |
WX1804H WX1810H WX1820H WX1840H |
Yes |
WX3800H series |
WX3820H WX3840H |
Yes |
WX5800H series |
WX5860H |
Yes |
WLAN DRS tasks at a glance
To configure WLAN DRS, perform the following tasks:
1. Enabling DRS
2. (Optional.) Configuring DRS information reporting to the Oasis server
Enabling DRS
DRS classifies user application and URL session information detected by DPI, and stores the statistics in file drs.db in the bash directory of the local SQL database.
You can view the statistics on the local database by using SQL database statements or from the Web interface.
1. Enter system view.
2. Enable DRS.
wlan drs [ ipv6 ] enable
By default, DRS is disabled.
3. (Optional.) Enable DRS for wired clients.
wlan drs wired-statistics enable
By default, DRS for wired clients is disabled.
This feature enables the AC to send a specific number of DRS entries to the Oasis server at the specified interval.
2. Enabling DRS information reporting to the Oasis server.
wlan drs report-oasis enable
By default, the reporting feature is enabled.
3. Set the DRS information reporting interval and the number of entries to be reported every time.
wlan drs report-oasis { app | url } [ interval interval | number number ] *
By default, the AC reports 10 DRS entries to the Oasis server every 1000 milliseconds.
Example: Configuring WLAN DRS
As shown in Figure 1, enable DRS for the AC to get user application and URL session information, and enable the AC to report DRS entries to the Oasis server at the specified interval.
1. Configure a VLAN interface:
# Create VLAN 100 and assign an IP address to VLAN-interface 100.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 10.1.9.58 16
[AC-Vlan-interface100] quit
2. Configure wireless services:
# Create service template service1.
[AC] wlan service-template service1
# Set the SSID to drs.
[AC-wlan-st-service1] ssid drs
# Assign clients coming online through the service template to VLAN 100.
[AC-wlan-st-service1] vlan 100
# Enable the service template.
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
3. Create a manual AP:
# Create manual AP ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 219801A0CNC138011454
# Bind service template service1 to radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
4. Configure DRS:
# Enable DRS.
# Set the DRS information reporting interval to 500 seconds, and the number of entries to be reported every time to 20.
[AC] wlan drs report-oasis app interval 500 number 20
[AC] wlan drs report-oasis url interval 500 number 20
# Verify that you can view application and URL session records from the Web interface.
