06-MPLS Configuration Guide
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R3606)-6W10006-MPLS Configuration Guide
08-MPLS L3VPN configuration
08-MPLS L3VPN configuration 2.82 MB
Configuring MPLS L3VPN·· 1
About MPLS L3VPN· 1
Basic MPLS L3VPN architecture· 1
MPLS L3VPN concepts· 1
MPLS L3VPN route advertisement 3
MPLS L3VPN packet forwarding· 4
MPLS L3VPN networking schemes· 4
Inter-AS VPN· 7
Carrier's carrier 12
Nested VPN· 13
HoVPN· 14
OSPF VPN extension· 16
BGP AS number substitution and SoO attribute· 18
MPLS L3VPN FRR· 19
ECMP VPN route redistribution· 21
Protocols and standards· 22
MPLS L3VPN tasks at a glance· 22
Prerequisites for MPLS L3VPN· 23
Configuring the hardware resource allocation mode· 23
Configuring VPN instances· 23
Creating a VPN instance· 24
Associating a VPN instance with a Layer 3 interface· 25
Configuring route related attributes for a VPN instance· 25
Configuring routing between a PE and a CE· 26
Configuring static routing between a PE and a CE· 26
Configuring RIP between a PE and a CE· 26
Configuring OSPF between a PE and a CE· 27
Configuring IS-IS between a PE and a CE· 28
Configuring EBGP between a PE and a CE· 28
Configuring IBGP between a PE and a CE· 30
Configuring routing between PEs· 31
Configuring BGP VPNv4 route control 31
About BGP VPNv4 route control 31
Controlling BGP VPNv4 route advertisement, reception, and saving· 32
Setting a preferred value for received routes· 32
Configuring BGP VPNv4 route reflection· 32
Configuring BGP VPNv4 route attributes· 33
Configuring BGP VPNv4 route filtering· 34
Configuring BGP VPNv4 route dampening· 35
Configuring BGP VPNv4 optimal route selection delay· 35
Setting the delay time for responding to BGP VPNv4 recursive next hop changes· 36
Configuring BGP VPNv4 routes to use private network next hops· 36
Configuring inter-AS VPN· 37
Configuring inter-AS option A· 37
Configuring inter-AS option B· 37
Configuring inter-AS option C (method 1) 38
Configuring inter-AS option C (method 2) 41
Configuring nested VPN· 43
Configuring HoVPN· 45
Configuring the UPE· 45
Configuring the SPE· 45
Specifying the VPN label processing mode on the egress PE· 46
Configuring MPLS L3VPN FRR· 46
About MPLS L3VPN FRR· 46
Restrictions and guidelines· 46
Configuring FRR by using a routing policy· 47
Enabling MPLS L3VPN FRR for the address family· 48
Configuring an OSPF sham link· 49
About OSPF sham links· 49
Prerequisites· 49
Redistributing the loopback interface address· 49
Creating a sham link· 50
Configuring BGP AS number substitution and SoO attribute· 50
Configuring the AIGP attribute· 51
Configuring BGP RT filtering· 52
Configuring the BGP additional path feature· 53
Configuring route replication· 54
Configuring BGP route replication between public and VPN instances· 55
Enabling ECMP VPN route redistribution· 56
Enabling prioritized withdrawal of specific routes· 57
Enabling SNMP notifications for MPLS L3VPN· 57
Enabling logging for BGP route flapping· 57
Display and maintenance commands for MPLS L3VPN· 58
Resetting BGP connections· 58
Displaying and maintaining MPLS L3VPN information· 59
MPLS L3VPN configuration examples· 61
Example: Configuring basic MPLS L3VPN· 61
Example: Configuring a hub-spoke network· 66
Example: Configuring MPLS L3VPN inter-AS option A· 73
Example: Configuring MPLS L3VPN inter-AS option B· 78
Example: Configuring MPLS L3VPN inter-AS option C (method 1) 83
Example: Configuring MPLS L3VPN inter-AS option C (method 2) 90
Example: Configuring MPLS L3VPN carrier's carrier in the same AS· 96
Example: Configuring MPLS L3VPN carrier's carrier in different ASs· 103
Example: Configuring nested VPN· 110
Example: Configuring HoVPN· 119
Example: Configuring an OSPF sham link· 126
Example: Configuring BGP AS number substitution· 130
Example: Configuring BGP AS number substitution and SoO attribute· 134
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for a VPNv4 route· 137
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for an IPv4 route· 139
Example: Configuring MPLS L3VPN FRR through IPv4 route backup for a VPNv4 route· 142
Configuring IPv6 MPLS L3VPN·· 145
About IPv6 MPLS L3VPN· 145
IPv6 MPLS L3VPN network diagram·· 145
IPv6 MPLS L3VPN packet forwarding· 145
IPv6 MPLS L3VPN routing information advertisement 146
IPv6 MPLS L3VPN network schemes and features· 146
Protocols and standards· 147
IPv6 MPLS L3VPN tasks at a glance· 147
Prerequisites for IPv6 MPLS L3VPN· 147
Configuring the hardware resource allocation mode· 148
Configuring VPN instances· 148
Creating a VPN instance· 148
Associating a VPN instance with a Layer 3 interface· 149
Configuring route related attributes for a VPN instance· 149
Configuring routing between a PE and a CE· 150
Configuring IPv6 static routing between a PE and a CE· 150
Configuring RIPng between a PE and a CE· 151
Configuring OSPFv3 between a PE and a CE· 151
Configuring IPv6 IS-IS between a PE and a CE· 153
Configuring EBGP between a PE and a CE· 153
Configuring IBGP between a PE and a CE· 155
Configuring routing between PEs· 156
Configuring BGP VPNv6 route control 156
About BGP VPNv6 route control 156
Specifying a preferred value for BGP VPNv6 routes· 156
Setting the maximum number of received routes· 157
Configuring BGP VPNv6 route reflection· 157
Configuring BGP VPNv6 route attributes· 158
Configuring BGP VPNv6 route filtering· 159
Configuring BGP VPNv6 optimal route selection delay· 160
Setting the delay time for responding to BGP VPNv6 recursive next hop changes· 160
Configuring BGP VPNv6 routes to use private network next hops· 160
Configuring inter-AS IPv6 VPN· 161
Configuring inter-AS IPv6 VPN option A· 161
Configuring inter-AS IPv6 VPN option B· 161
Configuring inter-AS IPv6 VPN option C (method 1) 163
Configuring inter-AS IPv6 VPN option C (method 2) 165
Configuring HoVPN· 168
Configuring the UPE· 168
Configuring the SPE· 168
Configuring IPv6 MPLS L3VPN FRR· 169
About IPv6 MPLS L3VPN FRR· 169
Restrictions and guidelines· 169
Configuring FRR by using a routing policy· 169
Enabling MPLS L3VPN FRR for the address family· 170
Configuring an OSPFv3 sham link· 171
Prerequisites· 171
Redistributing the loopback interface address· 172
Creating a sham link· 172
Configuring BGP AS number substitution and SoO attribute· 173
Configuring the AIGP attribute· 173
Configuring the BGP additional path feature· 174
Configuring route replication· 175
Configuring BGP route replication between public and VPN instances· 176
Enabling prioritized withdrawal of specific routes· 177
Enabling logging for BGP route flapping· 177
Display and maintenance commands for IPv6 MPLS L3VPN· 178
Resetting BGP connections· 178
Displaying IPv6 MPLS L3VPN information· 178
IPv6 MPLS L3VPN configuration examples· 179
Example: Configuring IPv6 MPLS L3VPNs· 179
Example: Configuring a hub-spoke network· 185
Example: Configuring IPv6 MPLS L3VPN inter-AS option A· 192
Example: Configuring IPv6 MPLS L3VPN inter-AS option B· 197
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 1) 202
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 2) 209
Example: Configuring IPv6 MPLS L3VPN carrier's carrier in the same AS· 215
Example: Configuring HoVPN· 222
Example: Configuring an OSPFv3 sham link· 230
Example: Configuring BGP AS number substitution· 234
Example: Configuring BGP AS number substitution and SoO attribute· 238
About MPLS L3VPN
MPLS L3VPN is a L3VPN technology used to interconnect geographically dispersed VPN sites. MPLS L3VPN uses BGP to advertise VPN routes and uses MPLS to forward VPN packets over a service provider backbone. MPLS L3VPN provides flexible networking modes, excellent scalability, and convenient support for MPLS TE.
As shown in Figure 1, a basic MPLS L3VPN architecture has the following types of devices:
·     Customer edge device—A CE device resides on a customer network and has one or more interfaces directly connected to a service provider network. It does not support MPLS.
·     Provider edge device—A PE device resides at the edge of a service provider network and is connected to one or more CEs. All MPLS VPN services are processed on PEs.
·     Provider device—A P device is a core device on a service provider network. It is not directly connected to any CEs. A P device has only basic MPLS forwarding capability and does not handle VPN routing information.
Figure 1 Basic MPLS L3VPN architecture
MPLS L3VPN concepts
Site
A site has the following features:
·     A site is a group of IP systems with IP connectivity that does not rely on any service provider networks.
·     The classification of a site depends on the topology relationship of the devices, rather than the geographical positions. However, the devices at a site are, in most cases, adjacent to each other geographically.
·     The devices at a site can belong to multiple VPNs, which means that a site can belong to multiple VPNs.
·     A site is connected to a provider network through one or more CEs. A site can contain multiple CEs, but a CE can belong to only one site.
Sites connected to the same provider network can be classified into different sets by policies. Only the sites in the same set can access each other through the provider network. Such a set is called a VPN.
VPN instance
VPN instances implement route isolation, data independence, and data security for VPNs.
A VPN instance has the following components:
·     A separate Label Forwarding Information Base (LFIB).
·     An IP routing table.
·     Interfaces bound to the VPN instance.
·     VPN instance administration information, including route distinguishers (RDs), route targets (RTs), and route filtering policies.
To associate a site with a VPN instance, bind the VPN instance to the PE's interface connected to the site. A site can be associated with only one VPN instance, and different sites can be associated with the same VPN instance. A VPN instance contains the VPN membership and routing rules of associated sites.
VPN-IPv4 address
Each VPN independently manages its address space. The address spaces of VPNs might overlap. For example, if both VPN 1 and VPN 2 use the addresses on subnet 10.110.10.0/24, address space overlapping occurs.
BGP cannot process overlapping VPN address spaces. For example, if both VPN 1 and VPN 2 use the subnet 10.110.10.0/24 and each advertise a route destined for the subnet, BGP selects only one of them. This results in the loss of the other route.
Multiprotocol BGP (MP-BGP) can solve this problem by advertising VPN-IPv4 addresses (also called VPNv4 addresses).
Figure 2 VPN-IPv4 address structure
As shown in Figure 2, a VPN-IPv4 address consists of 12 bytes. The first eight bytes represent the RD, followed by a four-byte IPv4 prefix. The RD and the IPv4 prefix form a unique VPN-IPv4 prefix.
An RD can be in one of the following formats:
·     When the Type field is 0, the Administrator subfield occupies two bytes, the Assigned number subfield occupies four bytes, and the RD format is 16-bit AS number:32-bit user-defined number. For example, 100:1.
·     When the Type field is 1, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·     When the Type field is 2, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the Administrator subfield to any private AS number or private IP address.
Route target attribute
MPLS L3VPN uses route target (also called VPN target) community attributes to control the advertisement of VPN routing information. A VPN instance on a PE supports the following types of route target attributes:
·     Export target attribute—A PE sets the export target attribute for VPN-IPv4 routes learned from directly connected sites before advertising them to other PEs.
·     Import target attribute—A PE checks the export target attribute of VPN-IPv4 routes received from other PEs. If the export target attribute matches the import target attribute of a VPN instance, the PE adds the routes to the routing table of the VPN instance.
Route target attributes define which sites can receive VPN-IPv4 routes, and from which sites a PE can receive routes.
Like RDs, route target attributes can be one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 100:1.
·     32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
MP-BGP
MP-BGP supports multiple address families, including IPv4 multicast and VPN-IPv4 address families.
In MPLS L3VPN, MP-BGP advertises VPN-IPv4 routes for VPN sites between PEs.
In a basic MPLS L3VPN, CEs and PEs are responsible for advertising VPN routing information. P devices maintain only the routes within the backbone. A PE maintains only routing information for directly connected VPNs, rather than for all VPNs.
VPN routing information is advertised through the path local CE—ingress PE—egress PE—remote CE.
Route advertisement from the local CE to the ingress PE
The CE advertises standard IPv4 routing information to the ingress PE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
Route advertisement from the ingress PE to the egress PE
The ingress PE performs the following operations:
1.     Adds RDs and route target attributes to these standard IPv4 routes to create VPN-IPv4 routes.
2.     Saves the VPN-IPv4 routes to the routing table of the VPN instance created for the CE.
3.     Advertises the VPN-IPv4 routes to the egress PE through MP-BGP.
PEs can also exchange labels through BGP EVPN routes. For more information, see EVPN Configuration Guide.
Route advertisement from the egress PE to the remote CE
After receiving the VPN-IPv4 routes, the egress PE performs the following operations:
1.     Compares the routes' export target attributes with the local import target attributes.
2.     Adds the routes to the routing table of the VPN instance if the export and local import target attributes match each other.
3.     Restores the VPN-IPv4 routes to the original IPv4 routes.
4.     Advertises those routes to the connected CE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
In a basic MPLS L3VPN (within a single AS), a PE adds the following information into VPN packets:
·     Outer tag—Identifies the public tunnel from the local PE to the remote PE. The public tunnel can be an LSP or an MPLS TE tunnel. A VPN packet can be forwarded along the public tunnel to the remote PE based on the MPLS label.
·     Inner label—Identifies the remote VPN site. The remote PE uses the inner label to forward packets to the target VPN site. MP-BGP advertises inner labels for VPN-IPv4 routes among PEs.
Figure 3 VPN packet forwarding
As shown in Figure 3, a VPN packet is forwarded from Site 1 to Site 2 by using the following process:
1.     Site 1 sends an IP packet with the destination address 1.1.1.2. CE 1 transmits the packet to PE 1.
2.     PE 1 performs the following operations:
a.     Finds the matching VPN route based on the inbound interface and destination address of the packet.
b.     Labels the packet with both the inner label and the outer tag.
c.     Forwards the packet to the public tunnel.
3.     P devices forward the packet to PE 2 by the MPLS label. The label is removed from the packet at the penultimate hop.
4.     PE 2 performs the following operations:
a.     Uses the inner label to find the matching VPN instance to which the destination address of the packet belongs.
b.     Looks up the routing table of the VPN instance for the output interface.
c.     Removes the inner label and forwards the packet out of the interface to CE 2.
5.     CE 2 transmits the packet to the destination through IP forwarding.
When two sites of a VPN are connected to the same PE, the PE directly forwards packets between the two sites through the VPN routing table without adding any tag or label.
In MPLS L3VPNs, route target attributes are used to control the advertisement and reception of VPN routes between sites. They work independently and can be configured with multiple values to support flexible VPN access control and implement multiple types of VPN networking schemes.
Basic VPN networking scheme
In the simplest case, all users in a VPN form a closed user group. They can forward traffic to each other but cannot communicate with any user outside the VPN.
For the basic VPN networking scheme, you must assign a route target to each VPN for identifying the export target attribute and import target attribute of the VPN. Moreover, this route target cannot be used by any other VPNs.
Figure 4 Network diagram for basic VPN networking scheme
As shown in Figure 4, the route target for VPN 1 is 100:1, while that for VPN 2 is 200:1. The two VPN 1 sites can communicate with each other, and the two VPN 2 sites can communicate with each other. However, the VPN 1 sites cannot communicate with the VPN 2 sites.
Hub and spoke networking scheme
The hub and spoke networking scheme is suitable for a VPN where all users must communicate with each other through an access control device.
In a hub and spoke network as shown in Figure 5, configure route targets as follows:
·     On spoke PEs (PEs connected to spoke sites), set the export target to Spoke and the import target to Hub.
·     On the hub PE (PE connected to the hub site), use two interfaces that each belong to a different VPN instance to connect the hub CE. One VPN instance receives routes from spoke PEs and has the import target set to Spoke. The other VPN instance advertises routes to spoke PEs and has the export target set to Hub.
These route targets rules produce the following results:
·     The hub PE can receive all VPN-IPv4 routes from spoke PEs.
·     All spoke PEs can receive VPN-IPv4 routes advertised by the hub PE.
·     The hub PE advertises the routes learned from a spoke PE to the other spoke PEs so the spoke sites can communicate with each other through the hub site.
·     The import target attribute of a spoke PE is different from the export target attribute of any other spoke PE. Any two spoke PEs do not directly advertise VPN-IPv4 routes to each other. Therefore, they cannot directly access each other.
Figure 5 Network diagram for hub and spoke network
A route in Site 1 is advertised to Site 2 by using the following process:
1.     Spoke-CE 1 advertises a route in Site 1 to Spoke-PE 1.
2.     Spoke-PE 1 changes the route to a VPN-IPv4 route and advertises the VPN-IPv4 route to Hub-PE through MP-BGP.
3.     Hub-PE adds the VPN-IPv4 route into the routing table of VPN 1-in, changes it to the original IPv4 route, and advertises the IPv4 route to Hub-CE.
4.     Hub-CE advertises the IPv4 route back to Hub-PE.
5.     Hub-PE adds the IPv4 route to the routing table of VPN 1-out, changes it to a VPN-IPv4 route, and advertises the VPN-IPv4 route to Spoke-PE 2 through MP-BGP.
6.     Spoke-PE 2 changes the VPN-IPv4 route to the original IPv4 route, and advertises the IPv4 route to Site 2.
After spoke sites exchange routes through the hub site, they can communicate with each other through the hub site.
Extranet networking scheme
The extranet networking scheme allows specific resources in a VPN to be accessed by users not in the VPN.
In this networking scheme, if a VPN instance needs to access a shared site, the export target attribute and the import target attribute of the VPN instance must be contained in the import target attribute and the export target attribute of the VPN instance of the shared site, respectively.
Figure 6 Network diagram for extranet networking scheme
As shown in Figure 6, route targets configured on PEs produce the following results:
·     PE 3 can receive VPN-IPv4 routes from PE 1 and PE 2.
·     PE 1 and PE 2 can receive VPN-IPv4 routes advertised by PE 3.
·     Site 1 and Site 3 of VPN 1 can communicate with each other, and Site 2 of VPN 2 and Site 3 of VPN 1 can communicate with each other.
·     PE 3 advertises neither the VPN-IPv4 routes received from PE 1 to PE 2 nor the VPN-IPv4 routes received from PE 2 to PE 1 (routes learned from an IBGP neighbor are not advertised to any other IBGP neighbor). Therefore, Site 1 of VPN 1 and Site 2 of VPN 2 cannot communicate with each other.
Inter-AS VPN
In an inter-AS VPN networking scenario, multiple sites of a VPN are connected to multiple ISPs in different ASs, or to multiple ASs of an ISP.
Inter AS-VPN provides the following solutions:
·     VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
·     EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·     Multihop EBGP redistribution of labeled VPN-IPv4 routes between PEs—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
Inter-AS option A
In this solution, PEs of two ASs are directly connected, and each PE is also the ASBR of its AS. Each PE treats the other as a CE and advertises unlabeled IPv4 unicast routes through EBGP. The PEs associate a VPN instance with a minimum of one interface.
Figure 7 Network diagram for inter-AS option A
As shown in Figure 7, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
1.     PE 1 advertises the VPN routes learned from CE 1 to ASBR 1 through MP-IBGP.
2.     ASBR 1 performs the following operations:
a.     Adds the routes to the routing table of the VPN instance whose import target attribute matches the export target attribute of the routes.
b.     Advertises the routes as IPv4 unicast routes to its CE (ASBR 2) through EBGP.
3.     ASBR 2 adds the IPv4 unicast routes to the routing table of the VPN instance that is bound to the receiving interface, and advertises the routes to PE 3 through MP-IBGP.
4.     PE 3 advertises the received routes to CE 3.
Packets forwarded within an AS are VPN packets that carry two labels. Packets forwarded between ASBRs are common IP packets.
Inter-AS option A is easy to carry out because no special configuration is required on the PEs acting as the ASBRs.
However, it has limited scalability because the PEs acting as the ASBRs must manage all the VPN routes and create VPN instances on a per-VPN basis. This leads to excessive VPN-IPv4 routes on the PEs. Associating a separate interface with each VPN also requires additional system resources.
Inter-AS option B
In this solution, two ASBRs use MP-EBGP to exchange VPN-IPv4 routes that they obtain from the PEs in their respective ASs.
Figure 8 Network diagram for inter-AS option B
As shown in Figure 8, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
Assume that the inner label assigned by PE 1 for the routes is L1.
2.     ASBR 1 advertises the VPN-IPv4 routes to ASBR 2 through MP-EBGP.
Before advertising the routes, ASBR 1 modifies the next hop as its own address, assigns a new inner label (L2) to the routes, and associates L1 with L2.
3.     ASBR 2 advertises the VPN-IPv4 routes to PE 3 through MP-IBGP.
Before advertising the routes, ASBR 2 modifies the next hop as its own address, assigns a new inner label (L3) to the routes, and associates L2 with L3.
A packet is forwarded from CE 3 to CE 1 by using the following process:
1.     PE 3 encapsulates the received packet with two labels, and forwards the encapsulated packet to ASBR 2.
One of the labels is L3, and the other is the outer tag for the public tunnel from PE 3 to ASBR 2.
2.     ASBR 2 removes the outer tag, replaces L3 with L2, and forwards the packet to ASBR 1.
Packets between ASBR 1 and ASBR 2 carry only one inner label.
3.     ASBR 1 replaces L2 with L1, adds the outer tag of the public tunnel from ASBR 1 to PE 1, and forwards the packet to PE 1.
4.     PE 1 removes the inner label and outer tag and forwards the packet to CE 1.
In this solution, ASBRs must receive all inter-AS VPN routes. Therefore, ASBRs cannot filter incoming VPN-IPv4 routes by route targets.
Inter-AS option B has better scalability than option A. However, it requires that ASBRs maintain and advertise VPN routes.
Inter-AS option C
The Inter-AS option A and option B solutions require that the ASBRs maintain and advertise VPN-IPv4 routes. When every AS needs to exchange a great amount of VPN routes, the ASBRs might become bottlenecks, which hinders network extension. Inter-AS option C has better scalability because it makes PEs directly exchange VPN-IPv4 routes.
In this solution, PEs exchange VPN-IPv4 routes over a multihop MP-EBGP session. Each PE must have a route to the peer PE and a label for the route so that the inter-AS public tunnel between the PEs can be set up. Inter-AS option C sets up a public tunnel by using the following methods:
·     Method 1:
a.     The PE and the ASBR within an AS establish a public tunnel by using a label distribution protocol such as LDP.
b.     The local and remote ASBRs advertise labeled IPv4 unicast routes through BGP to establish an inter-AS public tunnel.
Labeled IPv4 unicast route advertisement refers to the process of assigning MPLS labels to IPv4 unicast routes and advertising IPv4 unicast routes and their labels.
·     Method 2:
In method 2, the PE and ASBR within an AS do not need to establish an IBGP peer relationship.
a.     The local ASBR redistributes IGP routes to the BGP routing table, assigns labels to the routes, and advertises the labeled routes to the remote ASBR.
b.     The remote ASBR redistributes BGP routes to the IGP routing table.
c.     The local and remote PEs then can learn the route s to reach each other. After the PEs learn the routes to each other, they establish a public tunnel by using a label distribution protocol such as LDP.
The following is an example of configuring inter-AS option C by using method 1.
Figure 9 Network diagram for inter-AS option C (method 1)
As shown in Figure 9, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
1.     PE 1 advertises the VPN routes learned from CE 1 as VPN-IPv4 routes to PE 3 through multihop MP-EBGP.
Assume that the inner label assigned by PE 1 for the routes is Lx.
2.     PE 3 advertises the received routes to CE 3.
Setting up an inter-AS public tunnel is difficult in this solution. A public tunnel, for example, the one from PE 3 to PE 1, is set up by using the following process:
1.     Within AS 100, the public tunnel from ASBR 1 to PE 1 is set up by using a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on ASBR 1 is L1.
2.     ASBR 1 advertises labeled IPv4 unicast routes to ASBR 2 through EBGP.
The route destined for PE 1 and the label (L2) assigned by ASBR 1 for the route are advertised from ASBR 1 to ASBR 2. The next hop of the route is ASBR 1. The public tunnel from ASBR 2 to ASBR 1 is set up. The incoming label for the public tunnel on ASBR 1 is L2.
3.     ASBR 2 advertises labeled IPv4 unicast routes to PE 3 through IBGP.
The route destined for PE 1 and the label (L3) assigned by ASBR 2 for the route are advertised from ASBR 2 to PE 3. The next hop for the route is ASBR 2. The public tunnel from PE 3 to ASBR 2 is set up. The incoming label for the public tunnel on ASBR 2 is L3, and the outgoing label is L2.
4.     MPLS packets cannot be forwarded directly from PE 3 to ASBR 2. Within AS 200, the public tunnel from PE 3 to ASBR 2 is required to be set up hop by hop through a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on PE 3 is Lv.
After route advertisement and public tunnel setup, a packet is forwarded from CE 3 to CE 1 by using the following process:
1.     PE 3 performs the following routing table lookups for the packet:
a.     Finds a matching route with next hop PE 1 and inner label Lx, and encapsulates the packet with label Lx.
b.     Finds the route to PE 1 with next hop ASBR 2 and label L3, and encapsulates the packet with label L3 as the outer label.
c.     Finds the route to ASBR 2 with outgoing label Lv, and encapsulates the packet with label Lv as the outmost label.
2.     AS 200 transmits the packet to ASBR 2 by the outmost label.
3.     ASBR 2 removes the outmost label, replaces L3 with L2, and forwards the packet to ASBR 1.
4.     ASBR 1 replaces L2 with L1, and forwards the packet.
5.     AS 100 transmits the packet to PE 1 by the outer label.
6.     PE 1 removes the outer label, and forwards the packet to CE 1 according to the inner label Lx.
As shown in Figure 10, to improve scalability, you can specify a route reflector (RR) in each AS to exchange VPN-IPv4 routes with PEs in the same AS. The RR in each AS maintains all VPN-IPv4 routes. The RRs in two ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes.
Figure 10 Network diagram for inter-AS option C using RRs
Carrier's carrier
If a customer of an MPLS L3VPN service provider is also a service provider:
·     The MPLS L3VPN service provider is called the provider carrier or the Level 1 carrier.
·     The customer is called the customer carrier or the Level 2 carrier.
This networking model is referred to as carrier's carrier.
The PEs of the Level 2 carrier directly exchange customer networks over a BGP session. The Level 1 carrier only learns the backbone networks of the Level 2 carrier, without learning customer networks.
For packets between customer networks to travel through the Level 1 carrier, the PE of the Level 1 carrier and the CE of the Level 2 carrier must assign labels to the backbone networks of the Level 2 carrier. The CE of the Level 2 carrier is a PE within the Level 2 carrier network.
Follow these guidelines to assign labels:
·     If the PE and the CE are in the same AS, you must configure IGP and LDP between them. If they are in different ASs, you must configure MP-EBGP to assign labels to IPv4 unicast routes exchanged between them.
·     You must enable MPLS on the CE of the Level 2 carrier regardless of whether the PE and CE are in the same AS.
A Level 2 carrier can be an ordinary ISP or an MPLS L3VPN service provider.
As shown in Figure 11, when the customer carrier is an ordinary ISP, its PEs and CEs run IGP to communicate with each other. The PEs do not need to run MPLS. PE 3 and PE 4 exchange customer network routes (IPv4 unicast routes) through an IBGP session.
Figure 11 Scenario where the Level 2 carrier is an ISP
As shown in Figure 12, when the customer carrier is an MPLS L3VPN service provider, its PEs and CEs must run IGP and LDP to communicate with each other. PE 3 and PE 4 exchange customer network routes (VPN-IPv4 routes) through an MP-IBGP session.
Figure 12 Scenario where the Level 2 carrier is an MPLS L3VPN service provider
As a best practice, establish equal cost LSPs between the Level 1 carrier and the Level 2 carrier if equal cost routes exist between them.
Nested VPN
The nested VPN technology exchanges VPNv4 routes between PEs and CEs of the ISP MPLS L3VPN and allows a customer to manage its own internal VPNs. Figure 13 shows a nested VPN network. On the service provider's MPLS VPN network, there is a customer VPN named VPN A. The customer VPN contains two sub-VPNs, VPN A-1 and VPN A-2.
The service provider PEs consider the customer's network as a common VPN user and do not join any sub-VPNs. The service provider CE devices (CE 1 and CE 2) exchange VPNv4 routes including sub-VPN routing information with the service provider PEs, which implements the propagation of the sub-VPN routing information throughout the customer network.
The nested VPN technology supports both symmetric networking and asymmetric networking. Sites of the same VPN can have the same number or different numbers of internal VPNs. Nested VPN also supports multiple-level nesting of internal VPNs.
Figure 13 Network diagram for nested VPN
In a nested VPN network, routing information is propagated by using the following process:
1.     After receiving VPN routes from customer CEs, a customer PE advertises VPN-IPv4 routes to the provider CEs through MP-BGP.
2.     The provider CEs advertise the VPN-IPv4 routes to a provider PE through MP-BGP.
3.     After receiving a VPN-IPv4 route, the provider PE keeps the customer's internal VPN information, and appends the customer's MPLS VPN attributes on the service provider network. It replaces the RD of the VPN-IPv4 route with the RD of the customer's MPLS VPN on the service provider network. It also adds the export route-target (ERT) attribute of the customer's MPLS VPN on the service provider network to the extended community attribute list of the route. The internal VPN information for the customer is maintained on the provider PE.
4.     The provider PE advertises VPN-IPv4 routes carrying the comprehensive VPN information to the other PEs of the service provider.
5.     After another provider PE receives the VPN-IPv4 routes, it matches the VPN-IPv4 routes to the import targets of its local VPNs. Each local VPN accepts routes of its own and advertises them to provider CEs. If a provider CE (such as CE 7 and CE 8 in Figure 13) is connected to a provider PE through an IPv4 connection, the PE advertises IPv4 routes to the CE. If it is a VPN-IPv4 connection (a customer MPLS VPN network), the PE advertises VPN-IPv4 routes to the CE.
6.     After receiving VPN-IPv4 routes from the provider CE, a customer PE matches those routes to local import targets. Each customer VPN accepts only its own routes and advertises them to connected customer CEs (such as CE 3, CE 4, CE 5, and CE 6 in Figure 13).
HoVPN
Hierarchy of VPN (HoVPN), also called Hierarchy of PE (HoPE), prevents PEs from being bottlenecks and is applicable to large-scale VPN deployment.
HoVPN divides PEs into underlayer PEs (UPEs) or user-end PEs, and superstratum PEs (SPEs) or service provider-end PEs. UPEs and SPEs have different functions and comprise a hierarchical PE. The HoPE and common PEs can coexist in an MPLS network.
Figure 14 Basic architecture of HoVPN
As shown in Figure 14, UPEs and SPEs play the following different roles:
·     A UPE is directly connected to CEs. It provides user access. It maintains the routes of directly connected VPN sites. It does not maintain the routes of the remote sites in the VPN, or it only maintains their summary routes. A UPE assigns inner labels to the routes of its directly connected sites, and advertises the labels along with VPN routes to the SPE through MP-BGP. A UPE features high access capability, small routing table capacity, and low forwarding performance.
·     An SPE is connected to UPEs and resides inside the service provider network. It manages and advertises VPN routes. It maintains all the routes of the VPNs connected through UPEs, including the routes of both the local and remote sites. An SPE advertises routes along with labels to UPEs, including the default routes of VPN instances or summary routes and the routes permitted by the routing policy. By using routing policies, you can control which sites in a VPN can communicate with each other. An SPE features large routing table capacity, high forwarding performance, and fewer interface resources.
Either MP-IBGP or MP-EBGP can run between SPE and UPE. When MP-IBGP runs between SPE and UPEs, the SPE acts as the RR of multiple UPEs and reflects routes between UPEs.
HoVPN supports HoPE recursion:
·     An HoPE can act as a UPE to form a new HoPE with an SPE.
·     An HoPE can act as an SPE to form a new HoPE with multiple UPEs.
HoVPN supports multilevel recursion. In HoPE recursion, the concepts of SPE and UPE are relative. A PE might be the SPE of its underlayer PEs and a UPE of its SPE at the same time.
Figure 15 Recursion of HoPEs
Figure 15 shows a three-level HoPE. The PE in the middle is called the middle-level PE (MPE). MP-BGP runs between SPE and MPE, and between MPE and UPE.
MP-BGP advertises the following routes:
·     All the VPN routes of UPEs to the SPEs.
·     The default routes of the VPN instance of the SPEs or the VPN routes permitted by the routing policies to the UPEs.
The SPE maintains the VPN routes of all sites in the HoVPN. Each UPE maintains only VPN routes of its directly connected sites. An MPE has fewer routes than the SPE but has more routes than a UPE.
OSPF VPN extension
This section describes the OSPF VPN extension. For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
OSPF for VPNs on a PE
If OSPF runs between a CE and a PE to exchange VPN routes, the PE must support multiple OSPF instances to create independent routing tables for VPN instances. Each OSPF process is bound to a VPN instance. Routes learned by an OSPF process are added into the routing table of the bound VPN instance.
OSPF area configuration between a PE and a CE
The OSPF area between a PE and a CE can be either a non-backbone area or a backbone area.
In the OSPF VPN extension application, the MPLS VPN backbone is considered the backbone area (area 0). The area 0 of each site must be connected to the MPLS VPN backbone (physically connected or logically connected through a virtual link) because OSPF requires that the backbone area be contiguous.
BGP/OSPF interaction
If OSPF runs between PEs and CEs, each PE redistributes BGP routes to OSPF and advertises the routes to CEs through OSPF. OSPF considers the routes redistributed from BGP as external routes but the OSPF routes actually belong to the same OSPF domain. This problem can be resolved by configuring the same domain ID for sites in an OSPF domain.
Figure 16 Network diagram for BGP/OSPF interaction
As shown in Figure 16, CE 11, CE 21, and CE 22 belong to the same VPN and the same OSPF domain.
Before domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
1.     PE 1 redistributes OSPF routes from CE 11 into BGP, and advertises the VPN routes to PE 2 through BGP.
2.     PE 2 redistributes the BGP routes to OSPF, and advertises them to CE 21 and CE 22 in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
After domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
1.     PE 1 redistributes OSPF routes into BGP, adds the domain ID to the redistributed BGP VPNv4 routes as a BGP extended community attribute, and advertises the routes to PE 2.
2.     PE 2 compares the domain ID in the received routes with the locally configured domain ID. If they are the same and the received routes are intra-area or inter-area routes, OSPF advertises these routes in Network Summary LSAs (Type 3). Otherwise, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
Routing loop avoidance
Figure 17 Network diagram for routing loop avoidance
As shown in Figure 17, Site 1 is connected to two PEs. When a PE advertises VPN routes learned from MP-BGP to Site 1 through OSPF, the routes might be received by the other PE. This results in a routing loop.
OSPF VPN extension uses the following tags to avoid routing loops:
·     DN bit (for Type 3 LSAs)—When a PE redistributes BGP routes into OSPF and creates Type 3 LSAs, it sets the DN bit for the LSAs. When receiving the Type 3 LSAs advertised by CE 11, the other PE ignores the LSAs whose DN bit is set to avoid routing loops.
·     Route tag (for Type 5 or 7 LSAs)—The two PEs use the same route tag. When a PE redistributes BGP routes into OSPF and creates Type 5 or 7 LSAs, it adds the route tag to the LSAs. When receiving the Type 5 or 7 LSAs advertised by CE 11, the other PE compares the route tag in the LSAs against the local route tag. If they are the same, the PE ignores the LSAs to avoid routing loops.
OSPF sham link
As shown in Figure 18, two routes exist between Site 1 and Site 2 of VPN 1:
·     A route over MPLS backbone—It is an inter-area route if PE 1 and PE 2 have the same domain ID, or is an external route if PE 1 and PE 2 are configured with no domain ID or with different domain IDs.
·     A direct route between CEs—It is an intra-area route that is called a backdoor link.
VPN traffic is always forwarded through the backdoor link because it has a higher priority than the inter-area route. To forward VPN traffic over the inter-area route, you can establish a sham link between the two PEs to change the inter-area route to an intra-area route.
Figure 18 Network diagram for sham link
A sham link is considered a virtual point-to-point link within a VPN and is advertised in a Type 1 LSA. It is identified by the source IP address and destination IP address that are the local PE address and the remote PE address in the VPN address space. Typically, the source and destination addresses are loopback interface addresses with a 32-bit mask.
To add a route to the destination IP address of a sham link to a VPN instance, the remote PE must advertise the source IP address of the sham link as a VPN-IPv4 address through MP-BGP. To avoid routing loops, a PE does not advertise the sham link's destination address.
BGP detects routing loops by examining AS numbers. If EBGP runs between PE and CE, you must assign different AS numbers to geographically different sites or configure the BGP AS number substitution feature to ensure correct transmission of routing information.
The BGP AS number substitution feature allows geographically different CEs to use the same AS number. If the AS_PATH of a route contains the AS number of a CE, the PE replaces the AS number with its own AS number before advertising the route to that CE.
After you enable the BGP AS number substitution feature, the PE performs BGP AS number substitution for all routes and re-advertises them to connected CEs in the peer group.
Figure 19 Application of BGP AS number substitution and SoO attribute
As shown in Figure 19, both Site 1 and Site 2 use the AS number 800. AS number substitution is enabled on PE 2 for CE 2. Before advertising updates received from CE 1 to CE 2, PE 2 substitutes its own AS number 100 for the AS number 800. In this way, CE 2 can correctly receive the routing information from CE 1.
However, the AS number substitution feature also introduces a routing loop in Site 2 because route updates originated from CE 3 can be advertised back to Site 2 through PE 2 and CE 2. To remove the routing loop, you can configure the same SoO attribute on PE 2 for CE 2 and CE 3. PE 2 adds the SoO attribute to route updates received from CE 2 or CE 3, and checks the SoO attribute of route updates to be advertised to CE 2 or CE 3. The SoO attribute of the route updates from CE 3 is the same as the SoO attribute for CE 2, and PE 2 does not advertise route updates to CE 2.
For more information about the SoO attribute, see Layer 3—IP Routing Configuration Guide.
MPLS L3VPN FRR
MPLS L3VPN Fast Reroute (FRR) is applicable to a dual-homed scenario, as shown in Figure 20. By using BFD to detect the primary link, FRR enables a PE to use the backup link when the primary link fails. The PE then selects a new optimal route, and uses the new optimal route to forward traffic.
MPLS L3VPN FRR supports the following types of backup:
·     VPNv4 route backup for a VPNv4 route.
·     VPNv4 route backup for an IPv4 route.
·     IPv4 route backup for a VPNv4 route.
Figure 20 Network diagram
As shown in Figure 20, configure FRR on the ingress node PE 1, and specify the backup next hop for VPN 1 as PE 3. When PE 1 receives a VPNv4 route to CE 2 from both PE 2 and PE 3, it uses the route from PE 2 as the primary link, and the route from PE 3 as the backup link.
Configure BFD for LSPs or MPLS TE tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—PE 3—CE 2.
In this scenario, PE 1 is responsible for primary link detection and traffic switchover.
For more information about BFD for LSPs or MPLS TE tunnels, see "Configuring MPLS OAM."
Figure 21 Network diagram
As shown in Figure 21, configure FRR on the egress node PE 2, and specify the backup next hop for VPN 1 as PE 3. When PE 2 receives an IPv4 route from CE 2 and a VPNv4 route from PE 3 (both routes are destined for VPN 1 connected to CE 2), PE 2 uses the IPv4 route as the primary link, and the VPNv4 route as the backup link.
PE 2 uses ARP or echo-mode BFD to detect the connectivity of the link from PE 2 to CE 2. When the link operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the link fails, PE 2 switches traffic to the link PE 2—PE 3—CE 2, and traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—PE 3—CE 2. This avoids traffic interruption before route convergence completes (switching to the link CE 1—PE 1—PE 3—CE 2).
In this scenario, PE 2 is responsible for primary link detection and traffic switchover.
Figure 22 Network diagram
As shown in Figure 22, configure FRR on PE 1, and specify the backup next hop for VPN 1 as CE 2. When PE 1 receives an IPv4 route from CE 2 and a VPNv4 route from PE 2 (both routes are destined for VPN 1 connected to CE 2), PE 1 uses the VPNv4 route as the primary link, and the IPv4 route as the backup link.
Configure BFD for LSPs or MPLS TE tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—CE 2.
This feature enables a VPN instance to redistribute all routes that have the same prefix and RD into its routing table. Based on the ECMP routes, the device can perform load sharing (as configured by the balance command) or MPLS L3VPN FRR. For more information about the balance command, see BGP in Layer 3—IP Routing Command Reference.
Figure 23 Network diagram
As shown in Figure 23, CE 1 accesses the backbone network through VPN instance VPN1 created on PE 1. The RD of VPN instance VPN1 is 1:1. CE 2 accesses the backbone network through VPN instances created on PE 2 and PE 3. The VPN instances created on PE 2 and PE 3 have the same name VPN2 and the same RD 1:2. VPN instances VPN1 and VPN2 can communicate with each other.
Both PE 2 and PE 3 can advertise routes from CE 2 to PE 1, and the advertised routes have the same RD 1:2. By default, BGP redistributes only the optimal route into the routing table of VPN instance VPN1. After you enable this feature on VPN instance VPN1, BGP redistributes routes from both PE 2 and PE 3 to the routing table of VPN instance VPN1.
·     RFC 3107, Carrying Label Information in BGP-4
·     RFC 4360, BGP Extended Communities Attribute
·     RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
·     RFC 4577, OSPF as the Provider/Customer Edge Protocol for BGP/MPLS IP Virtual Private Networks (VPNs)
Unless otherwise indicated, configure MPLS L3VPN on PEs.
To configure MPLS L3VPN, perform the following tasks:
1.     (Optional.) Configuring the hardware resource allocation mode
2.     Configuring MPLS L3VPN basics
a.     Configuring VPN instances
b.     Configuring routing between a PE and a CE
c.     Configuring routing between PEs
d.     (Optional.) Configuring BGP VPNv4 route control
3.     Configuring advanced MPLS L3VPN networks
¡     Configuring inter-AS VPN
Perform this task when sites of a VPN are connected to different ASs of an ISP.
¡     Configuring nested VPN
Deploy the nest VPN when a large number of VPNs exist and you want to hide from the outside of the customer internal VPNs.
¡     Configuring HoVPN
HoVPN prevents PEs from being bottlenecks and is applicable to large-scale VPN deployment.
4.     (Optional.) Specifying the VPN label processing mode on the egress PE
5.     (Optional.) Configuring MPLS L3VPN FRR
6.     (Optional.) Controlling route advertisement and reception in an MPLS L3VPN network
¡     Configuring an OSPF sham link
¡     Configuring BGP AS number substitution and SoO attribute
¡     Configuring the AIGP attribute
¡     Configuring BGP RT filtering
Perform this task to reduce the number of routes advertised in an MPLS L3VPN.
¡     Configuring the BGP additional path feature
Perform this task to enable BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group to shorten the traffic interruption time.
¡     Configuring route replication
Perform this task to enable a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public network or other VPN instances.
¡     Configuring BGP route replication between public and VPN instances
Perform this task to enable mutual replication of BGP routes between public and VPN instances so that the public and VPN instances can communicate with each other.
¡     Enabling ECMP VPN route redistribution
Perform this task to enable a VPN instance to redistribute all routes that have the same prefix and RD into its routing table to perform load sharing or MPLS L3VPN FRR.
¡     Enabling prioritized withdrawal of specific routes
Perform this task to configure BGP to send the withdrawal messages of specific routes prior to other routes to achieve fast switchover of traffic and reduce the traffic interruption time.
7.     (Optional.) Maintaining MPLS L3VPN networks
¡     Enabling SNMP notifications for MPLS L3VPN
¡     Enabling logging for BGP route flapping
Before you configure basic MPLS L3VPN, perform the following tasks:
1.     Configure an IGP on the PEs and P devices to ensure IP connectivity within the MPLS backbone.
2.     Configure basic MPLS for the MPLS backbone.
3.     Configure MPLS LDP on the PEs and P devices to establish LDP LSPs.
VPNv4 ECMP routes consume hardware resources of the device. If the hardware resources are insufficient, packet forwarding might fail. To address this issue, perform this task to configure the hardware resource allocation mode. As a best practice, use the enhanced hardware resource allocation mode if many VPNv4 ECMP routes exist.
2.     Configure the hardware resource allocation mode.
hardware-resource mpls { l3vpn | normal }
By default, the normal hardware resource allocation mode is used.
All VPN instance configurations are performed on PEs.
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
If you configure an RD for a VPN instance, all address families in the VPN instance must use the same RD as the VPN instance.
If you do not configure an RD for a VPN instance, address families in the VPN instance can use different RDs.
To configure an RD for a VPN instance, make sure either of the following conditions exists:
·     No RDs have been configured for address families in the VPN instance.
In this case, the RD of the VPN instance will be synchronized to all address families in the VPN instance.
·     All address families in the VPN instance use the same RD.
In this case, you must configure the same RD as the address families for the VPN instance.
When you remove the RD from an address family, the RD will also be removed from the VPN instance of the address family.
2.     Set an MPLS label range for all VPN instances.
mpls per-vrf-label range minimum maximum
By default, no MPLS label range is configured for VPN instances.
3.     Create a VPN instance and enter VPN instance view.
4.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
5.     (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
6.     (Optional.) Configure a VPN ID for the VPN instance.
vpn-id vpn-id
By default, no VPN ID is configured for a VPN instance.
7.     (Optional.) Configure an SNMP context for the VPN instance.
By default, no SNMP context is configured.
8.     Enter VPN instance IPv4 address family view.
address-family ipv4
9.     Configure an RD.
By default, no RD is configured.
10.     Specify a label allocation mode.
apply-label { per-instance [ static static-label-value ] | per-route }
By default, BGP allocates a label to each next hop.
If an interface is associated with a VSI or cross-connect, the interface (including its subinterfaces) cannot associate with a VPN instance.
If a subinterface is associated with a VSI or cross-connect, the subinterface cannot associate with a VPN instance.
2.     Enter interface view.
3.     Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and belongs to the public network.
The ip binding vpn-instance command deletes the IP address of the current interface. You must reconfigure an IP address for the interface after configuring the command.
Configurations made in VPN instance view apply to both IPv4 VPN and IPv6 VPN.
IPv4 VPN prefers the configurations in VPN instance IPv4 address family view over the configurations in VPN instance view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2.     Enter VPN instance view or VPN instance IPv4 address family view.
¡     Enter VPN instance view.
¡     Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
3.     Configure route targets.
By default, no route targets are configured.
4.     Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the device from learning too many routes.
5.     Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6.     Apply an export routing policy.
By default, routes to be advertised are not filtered.
7.     Apply a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, only one tunnel is selected (no load balancing) in this order: LSP tunnel, CRLSP tunnel, and SRLSP tunnel.
If the specified tunnel policy does not exist, the default tunnel policy is used.
For information about tunnel policies, see "Configuring tunnel policies. "
Perform this configuration on the PE. On the CE, configure a common static route.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
2.     Configure a static route for a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
Perform this configuration on the PE. On the CE, create a common RIP process.
For more information about RIP, see Layer 3—IP Routing Configuration Guide.
2.     Create a RIP process for a VPN instance and enter RIP view.
rip [ process-id ] vpn-instance vpn-instance-name
A RIP process can belong to only one VPN instance.
3.     Enable RIP on the interface attached to the specified network.
By default, RIP is disabled on an interface.
Perform this configuration on the PE. On the CE, create a common OSPF process.
2.     Create an OSPF process for a VPN instance and enter the OSPF view.
ospf [ process-id | router-id router-id ] * vpn-instance vpn-instance-name
Parameter
router-id router-id
An OSPF process bound to a VPN instance does not use the public network router ID configured in system view. Therefore, you must specify a router ID when creating a process or configure an IP address for a minimum of one interface in the bound VPN instance.
An OSPF process can belong to only one VPN instance.
If you delete a VPN instance, all OSPF processes of the VPN instance are also deleted.
3.     Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPF does not redistribute routes from other routing protocols.
If the vpn-instance-capability simple command is not configured for the OSPF process, the allow-ibgp keyword is optional to redistribute VPNv4 routes learned from MP-IBGP peers. In any other cases, if you do not specify the allow-ibgp keyword, the OSPF process does not redistribute VPNv4 routes learned from MP-IBGP peers.
4.     (Optional.) Set an OSPF domain ID.
The default domain ID is 0.
The domain ID is carried in the routes of the OSPF process. When redistributing routes from the OSPF process, BGP adds the domain ID as an extended community attribute into BGP route.
An OSPF process can be configured with only one primary domain ID. Domain IDs of different OSPF processes can be the same.
All OSPF processes of a VPN must be configured with the same domain ID.
5.     (Optional.) Configure the type codes of OSPF extended community attributes.
The defaults are as follows:
¡     0x0005 for Domain ID.
¡     0x0107 for Router ID.
¡     0x0306 for Route Type.
6.     Create an OSPF area and enter area view.
area area-id
7.     Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
Perform this configuration on the PE. On the CE, configure common IS-IS.
For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
2.     Create an IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IS-IS process can belong to only one VPN instance.
3.     Configure a network entity title for the IS-IS process.
network-entity net
By default, no NET is configured.
4.     Return to system view.
5.     Enter interface view.
6.     Enable the IS-IS process on the interface.
isis enable [ process-id ]
By default, no IS-IS process is enabled on the interface.
Restrictions and guidelines for configuring EBGP between a PE and a CE
After you edit or delete the RD in VPN instance view or VPN instance IPv4 address family view, the device automatically deletes the BGP-VPN IPv4 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured EBGP between a PE and a CE.
Configuring the PE
2.     Enable a BGP instance and enter BGP instance view.
By default, BGP is not enabled.
3.     Enter BGP-VPN instance view.
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see BGP in Layer 3—IP Routing Configuration Guide.
4.     Configure the CE as the VPN EBGP peer.
peer { group-name | ip-address [ mask-length ] } as-number as-number
For more information about this command, see BGP in Layer 3—IP Routing Configuration Guide.
5.     Create the BGP-VPN IPv4 unicast address family and enter its view.
6.     Enable IPv4 unicast route exchange with the specified peer.
By default, BGP does not exchange IPv4 unicast routes with a peer.
7.     Redistribute the routes of the local CE.
A PE must redistribute the routes of the local CE into its VPN routing table so it can advertise them to the peer PE.
8.     Allow the local AS number to appear in the AS_PATH attribute of a received route, and set the maximum number of repetitions.
By default, BGP discards incoming route updates that contain the local AS number.
Execute this command in a hub-spoke network where EBGP is running between a PE and a CE to enable the PE to receive the route updates from the CE.
Configuring the CE
3.     Configure the PE as a BGP peer.
4.     Create the BGP IPv4 unicast address family and enter its view.
5.     Enable IPv4 unicast route exchange with the specified peer or peer group.
By default, BGP does not exchange IPv4 unicast routes with any peer.
6.     Configure route redistribution.
A CE must redistribute its routes to the PE so the PE can advertise them to the peer CE.
Restrictions and guidelines for configuring IBGP between a PE and a CE
Use IBGP between PE and CE only in a basic MPLS L3VPN network. In networks such as Hub&Spoke, Extranet, inter-AS VPN, carrier's carrier, nested VPN, and HoVPN, you cannot use IBGP between PE and CE.
After you edit or delete the RD in VPN instance view or VPN instance IPv4 address family view, the device automatically deletes the BGP-VPN IPv4 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured IBGP between a PE and a CE.
Configuring the PE
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
4.     Configure the CE as the VPN IBGP peer.
7.     Configure the CE as a client of the RR to enable the PE to advertise routes learned from the IBGP peer CE to other IBGP peers.
By default, no RR or RR client is configured.
Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side.
8.     (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
9.     (Optional.) Configure the cluster ID for the RR.
By default, the RR uses its own router ID as the cluster ID.
If multiple RRs exist in a cluster, use this command to configure the same cluster ID for all RRs in the cluster to avoid routing loops.
Configuring the CE
3.     Configure the PE as an IBGP peer.
5.     Enable IPv4 unicast route exchange with the specified peer.
3.     Configure the remote PE as a BGP peer.
4.     (Optional.) Specify the source interface for TCP connections.
peer { group-name | ip-address [ mask-length ] } connect-interface interface-type interface-number
By default, BGP uses the output interface of the optimal route destined for the peer as the source interface.
5.     Create the BGP VPNv4 address family and enter its view.
address-family vpnv4
6.     Enable BGP VPNv4 route exchange with the specified peer.
By default, BGP does not exchange BGP VPNv4 routes with a peer.
About BGP VPNv4 route control
BGP VPNv4 route control is configured similarly with BGP route control, except that it is configured in BGP VPNv4 address family view. For more information about BGP route control, see Layer 3—IP Routing Configuration Guide.
Controlling BGP VPNv4 route advertisement, reception, and saving
3.     Enter BGP VPNv4 address family view.
4.     Advertise a default VPN route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
By default, no default VPN route is advertised to a peer or peer group.
5.     Set the maximum number of routes BGP can receive from a peer or peer group.
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
6.     Save all route updates from a peer or peer group.
By default, BGP does not save route updates from a peer.
Setting a preferred value for received routes
4.     Set a preferred value for routes received from a peer or peer group.
By default, the preferred value for routes received from a peer or peer group is 0.
Configuring BGP VPNv4 route reflection
To ensure the connectivity of IBGP peers, you must establish full-mesh IBGP connections, which costs massive network and CPU resources.
To reduce IBGP connections in the network, you can configure a device as a route reflector (RR) and configure other devices as its clients. You only need to establish IBGP connections between the RR and its clients to enable the RR to forward routes to the clients.
4.     Configure the device as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
5.     (Optional.) Enable route reflection between clients.
6.     (Optional.) Configure a cluster ID for the RR.
7.     (Optional.) Configure a filtering policy for reflected routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, the RR does not filter reflected routes.
8.     (Optional.) Allow the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, RR cannot change the attributes of routes to be reflected.
9.     (Optional.) Specify a peer or peer group as a client of the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any clients.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
Configuring BGP VPNv4 route attributes
4.     Configure the NEXT_HOP attribute.
¡     Set the device as the next hop for routes sent to a peer or peer group.
By default, the device uses its address as the next hop for routes advertised to peers.
¡     Configure the device to not change the next hop of routes advertised to a peer or peer group.
On an RR in an inter-AS option C scenario, you must configure this command to not change the next hop of VPNv4 routes advertised to BGP peers and RR clients.
5.     Configure the AS_PATH attribute.
¡     Allow the local AS number to appear in the AS_PATH attribute of a received route and set the maximum number of repetitions.
By default, BGP discards incoming routes that contain the local AS number.
¡     Remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } public-as-only
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
6.     Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to a peer or peer group.
7.     Configure the SoO attribute for a peer for peer group.
By default, the SoO attribute is not configured.
8.     Configure BGP to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
Configuring BGP VPNv4 route filtering
4.     Filter advertised routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } export [ protocol process-id ]
By default, BGP does not filter advertised routes.
5.     Filter received routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } import
By default, BGP does not filter received routes.
6.     Configure AS_PATH list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, AS_PATH list-based route filtering is not configured.
7.     Configure ACL-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } { export | import }
By default, ACL-based route filtering is not configured.
8.     Configure IP prefix list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list prefix-list-name { export | import }
By default, no IP prefix list-based route filtering is configured.
9.     Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied for a peer.
10.     Enable route target filtering for received BGP VPNv4 routes.
policy vpn-target
By default, route target filtering is enabled for received VPNv4 routes. Only VPNv4 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
Configuring BGP VPNv4 route dampening
This feature enables BGP to not select unstable routes as optimal routes.
This feature applies only to IBGP routes.
If an IBGP peer goes down after you configure this feature, VPNv4 routes coming from the peer are dampened but not deleted.
4.     Configure BGP VPNv4 route dampening.
dampening ibgp[ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
By default, BGP VPNv4 route dampening is not configured.
Configuring BGP VPNv4 optimal route selection delay
4.     Set the BGP VPNv4 optimal route selection delay timer.
By default, the BGP VPNv4 optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Setting the delay time for responding to BGP VPNv4 recursive next hop changes
4.     Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
Configuring BGP VPNv4 routes to use private network next hops
By default, the device does not change the next hop attribute of a received BGP VPNv4 route. The next hop address of a BGP VPNv4 route is a public address. This feature changes the next hop of a BGP VPNv4 route received from a peer or peer group to an IP address in the VPN instance. The outgoing label of the VPNv4 route is also changed to an invalid value. For example, the device received a VPNv4 route and its next hop address is 10.1.1.1, which is a public address by default. After this feature is configured, the next hop address changes to private address 10.1.1.1.
After you configure this feature, the following applies:
·     The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
·     The device receives a BGP VPNv4 route only when its RD is the same as a local RD.
·     When advertising a BGP VPNv4 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
·     If you delete a VPN instance or its RD, BGP VPNv4 routes received from the specified peer or peer group and in the VPN instance will be deleted.
4.     Change the next hop of a BGP VPNv4 route received from a peer or peer group to a VPN instance address.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
By default, the device does not change the next hop attribute of a received BGP VPNv4 route, and the next hop belongs to the public network.
Configuring inter-AS option A
Inter-AS option A applies to scenarios with a few VPNs.
To configure inter-AS option A, create VPN instances on PEs and ASBRs. The VPN instances on PEs are used to allow CEs to access the network. The VPN instances on ASBRs are used to access the peer ASBRs. An ASBR considers the peer ASBR as a CE.
The route targets configured on the PEs must match those configured on the ASBRs in the same AS to make sure VPN routes sent by the PEs (or ASBRs) can be received by the ASBRs (or PEs). Route targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS option B
An ASBR always sets itself as the next hop of VPNv4 routes advertised to an MP-IBGP peer regardless of the peer next-hop-local command.
Configuring a PE
Configure basic MPLS L3VPN, and specify the ASBR in the same AS as an MP-IBGP peer. The route targets for the VPN instances on the PEs in different ASs must match for the same VPN.
Configuring an ASBR
2.     Enable MPLS and LDP on the interface connected to an internal device of the AS:
a.     Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
b.     Enable LDP on the local LSR and enter LDP view.
mpls ldp
By default, LDP is disabled.
c.     Return to system view.
d.     Enter interface view of the interface connected to an internal device of the AS.
e.     Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
f.     Enable MPLS LDP on the interface.
mpls ldp enable
By default, MPLS LDP is disabled on the interface.
g.     Return to system view.
3.     Enable MPLS on the interface connected to the remote ASBR:
a.     Enter interface view of the interface connected to the remote ASBR.
b.     Enable MPLS on the interface.
mpls enable
4.     Enter BGP instance view.
5.     Configure PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
6.     Enter BGP VPNv4 address family view.
7.     Enable BGP to exchange VPNv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange VPNv4 routes with a peer.
8.     Disable route target filtering of received VPNv4 routes.
undo policy vpn-target
Configuring inter-AS option C (method 1)
PEs are not directly connected. For the PEs to establish neighbor relationships, execute the peer ebgp-max-hop command to enable the local device to establish an EBGP session to an indirectly-connected peer.
Before you configure inter-AS option C (method 1), perform the following tasks:
·     Configure BGP on the PE or ASBR to advertise the route to the PE. For more information, see BGP configuration in Layer 3—IP Routing Configuration Guide.
·     Configure VPN instances on PEs.
·     Configure routing between PE and CE.
Configuring a PE
3.     Configure the ASBR in the same AS as an IBGP peer and configure the PE in another AS as an EBGP peer.
5.     Enable BGP to exchange IPv4 unicast routes with the ASBR in the same AS.
6.     Enable BGP to exchange labeled IPv4 routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, BGP cannot exchange labeled routes with any IPv4 peer or peer group.
After you execute this command, BGP exchanges both labeled and unlabeled IPv4 unicast routes with the peer.
7.     (Optional.) Configure BGP to exchange only labeled IPv4 routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-only
By default, BGP can exchange unlabeled IPv4 unicast routes with a peer.
After you execute this command, BGP exchanges only labeled IPv4 unicast routes with the peer.
8.     Return to BGP instance view.
9.     Enter BGP VPNv4 address family view.
10.     Enable BGP to exchange VPNv4 routes with the PE in another AS.
By default, BGP cannot exchange VPNv4 routes with any peer.
11.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
By default, the device uses its address as the next hop of routes advertised to peers.
Configure this command on the RR so the RR does not change the next hop of advertised VPNv4 routes.
Configuring an ASBR
2.     Configure a routing policy:
a.     Create a routing policy, and enter routing policy view.
b.     Match IPv4 routes carrying labels.
if-match mpls-label
By default, no MPLS label match criterion is configured.
You can configure if-match clauses in the routing policy to filter routes. Routes surviving the filtering are assigned labels, and all others are advertised as common IPv4 routes.
c.     Set labels for IPv4 routes.
apply mpls-label
By default, no MPLS label is set for IPv4 routes.
d.     Return to system view.
3.     Enable MPLS and LDP on the interface connected to an internal device of the AS:
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
4.     Enable MPLS on the interface connected to the remote ASBR.
mpls enable
5.     Enter BGP instance view.
6.     Configure the PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
7.     Create BGP IPv4 unicast address family and enter its view.
8.     Enable BGP to exchange IPv4 unicast routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with a peer.
9.     Enable BGP to exchange labeled IPv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with a peer.
10.     (Optional.) Configure BGP to exchange only labeled IPv4 routes with the PE in the same AS and the ASBR in another AS.
11.     Specify the device as the next hop of routes sent to a peer or peer group.
By default, the device does not set itself as the next hop for routes sent to a peer or peer group.
12.     Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied.
Configuring inter-AS option C (method 2)
Before you configure inter-AS option C (method 2), perform the following tasks:
Configuring a PE
3.     Configure the PE in another AS as an EBGP peer.
4.     Enter BGP VPNv4 address family view.
5.     Enable BGP to exchange VPNv4 routes with the the PE in another AS.
6.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
Configuring an ASBR
if-match mpls-label
apply mpls-label
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
6.     Configure the ASBR in another AS as an EBGP peer.
8.     Enable BGP to exchange IPv4 unicast routes with the ASBR in another AS.
9.     Enable BGP to exchange labeled IPv4 routes with the ASBR in another AS.
10.     (Optional.) Configure BGP to exchange only labeled IPv4 routes with the ASBR in another AS.
By default, the device does not set itself as the next hop for routes sent to an IBGP peer or peer group.
When you configure nested VPN, follow these guidelines:
·     The address spaces of sub-VPNs of a VPN cannot overlap.
·     Do not assign nested VPN peers addresses that public network peers use.
·     Nested VPN does not support multihop EBGP. A provider PE and a provider CE must use the addresses of the directly connected interfaces to establish a neighbor relationship.
1.     Connect the customer CE to the customer PE:
a.     Configure VPN instances on the customer PE.
See "Configuring VPN instances."
b.     Configure route exchange between customer PE and customer CE.
See "Configuring routing between a PE and a CE."
2.     Configure the customer PE to exchange sub-VPN routing information with the provider CE:
a.     Configure BGP VPNv4 route exchange between customer PE and provider CE.
See "Configuring routing between PEs."
b.     Execute the following commands in sequence to configure the provider CE to receive all VPNv4 routes (not filter VPNv4 routes by route targets).
This step is not required in a nested VPN network when no provider CE is deployed and the customer PE is connected directly to the provider PE.
3.     Connect the provider CE to the provider PE:
a.     Configure VPN instances on the provider PE.
b.     Configure route exchange between the provider CE and provider PE.
4.     Configure BGP VPNv4 route exchange between the provider PE and provider CE:
This step contains only configurations on the provider PE. For information about configuring the provider CE, see "Configuring routing between PEs." If the customer PE is directly connected to the provider PE, you must configure provider CE settings on the customer PE because the PE also functions as a provider CE.
a.     Execute the following commands in sequence to enter BGP VPNv4 address family view:
b.     Enable nested VPN.
nesting-vpn
By default, nested VPN is disabled.
c.     Return to BGP instance view.
d.     Enter BGP-VPN instance view.
e.     Configure the provider CE as a BGP peer.
f.     Create BGP-VPN VPNv4 address family and enter BGP-VPN VPNv4 address family view.
g.     Enable BGP VPNv4 route exchange with the peer CE or the peer group of the peer CE.
By default, BGP does not exchange VPNv4 routes with any peer.
h.     (Optional.) Configure the SoO attribute for the BGP peer or peer group.
5.     Configure BGP VPNv4 route exchange between provider PEs.
Configuring HoVPN
Configuring the UPE
Configure basic MPLS L3VPN settings on the UPE.
Configuring the SPE
3.     Specify a BGP peer or peer group.
5.     Enable BGP VPNv4 route exchange with the peer or peer group.
6.     Specify the BGP peer or peer group as a UPE.
peer { group-name | ipv4-address [ mask-length ] } upe
By default, no peer is a UPE.
7.     Advertise routes to the UPE.
¡     Advertise a default VPN route to the UPE.
After you configure this command, the device advertises a default route to the UPE, regardless of whether the default route exists in the local routing table. The default route uses the local address as the next hop.
¡     Advertise routes permitted by a routing policy to the UPE.
peer { group-name | ipv4-address [ mask-length ] } upe route-policy route-policy-name export
By default, no route is advertised to the UPE.
Do not configure both commands.
9.     Create a BGP-VPN instance and enter BGP-VPN instance view.
You do not need to associate the VPN instance to an interface on the SPE.
This step adds the learned VPNv4 routes to the BGP routing table of the VPN instance.
An egress PE can process VPN labels in either POPGO or POP mode:
·     POPGO forwarding—Pops the label and forwards the packet out of the output interface corresponding to the label.
·     POP forwarding—Pops the label and forwards the packet through the FIB table.
The POPGO forwarding mode (vpn popgo) and per-VPN instance label allocation mode (label-allocation-mode per-vrf) are mutually exclusive. Do not configure both modes in a BGP instance. For more information about the label-allocation-mode command, see BGP commands in Layer 3—IP Routing Command Reference.
3.     Specify the VPN label processing mode as POPGO forwarding.
vpn popgo
The default is POP forwarding.
About MPLS L3VPN FRR
You can use the following methods to configure MPLS L3VPN FRR:
·     Method 1—Execute the pic command in BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view. The device calculates a backup next hop for each BGP route in the VPN instance if there are two or more unequal-cost routes to reach the destination.
·     Method 2—Execute the fast-reroute route-policy command in BGP-VPN IPv4 unicast address family view to use a routing policy. In the routing policy, specify a backup next hop by using the apply fast-reroute backup-nexthop command. The backup next hop calculated by the device must be the same as the specified backup next hop. Otherwise, the device does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
Executing the pic command in BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view might cause routing loops. Use it with caution.
Configuring FRR by using a routing policy
2.     Configure BFD.
¡     Enable MPLS BFD.
mpls bfd enable
By default, MPLS BFD is disabled.
The mpls bfd enable command applies to VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route.
For more information about this command, see MPLS Command Reference.
¡     Configure the source IP address for BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address for BFD echo packets is not configured.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv4 route backup for an IPv4 route. For more information about this command, see High Availability Command Reference.
3.     Use BFD to test the connectivity of an LSP or MPLS TE tunnel.
¡     Configure BFD to test the connectivity of the LSP for the specified FEC.
mpls bfd dest-addr mask-length [ nexthop nexthop-address [ discriminator local local-id remote remote-id ] ] [ template template-name ]
¡     Configure BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface.
interface tunnel number mode mpls-te
mpls bfd [ discriminator local local-id remote remote-id ] [ template template-name ]
By default, BFD is not configured to test the connectivity of the LSP or MPLS TE tunnel.
This step is required for VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route.
For more information about the commands in this step, see MPLS Command Reference.
4.     Configure a routing policy:
a.     Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
b.     Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ip-address
By default, no backup next hop address is set for FRR.
For more information about the commands, see Layer 3—IP Routing Command Reference.
6.     (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
primary-path-detect bfd echo
By default, ARP is used to detect the connectivity to the next hop.
Use this command if necessary in VPNv4 route backup an IPv4 route.
For more information about this command, see Layer 3—IP Routing Command Reference.
7.     Enter BGP-VPN instance view.
8.     Enter BGP-VPN IPv4 unicast address family view.
9.     Apply a routing policy to FRR.
By default, no routing policy is applied to FRR.
The apply fast-reroute backup-nexthop command can take effect in the routing policy that is being used. Other apply commands do not take effect.
For more information about the command, see BGP commands in Layer 3—IP Routing Command Reference.
Enabling MPLS L3VPN FRR for the address family
2.     Configure BFD.
¡     Enable MPLS BFD.
mpls bfd enable
This command applies to VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route. For more information about this command, see MPLS OAM commands in MPLS Command Reference.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv4 route backup for an IPv4 route. For more information about this command, see BFD commands in High Availability Command Reference.
¡     Use BFD to test the connectivity of the LSP for the specified FEC.
¡     Use BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface.
By default, BFD is not used to test the connectivity of the LSP or MPLS TE tunnel.
For more information about the commands, see MPLS OAM commands in MPLS Command Reference.
5.     (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
6.     Enter BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
¡     Enter BGP VPNv4 address family view.
7.     Enable MPLS L3VPN FRR for the address family.
pic
By default, MPLS L3VPN FRR is disabled.
About OSPF sham links
When a backdoor link exists between the two sites of a VPN, you can create a sham link between PEs to forward VPN traffic through the sham link on the backbone rather than the backdoor link. A sham link is considered an OSPF intra-area route.
The source and destination addresses of the sham link must be loopback interface addresses with 32-bit masks. The loopback interfaces must be bound to VPN instances, and their addresses are advertised through BGP.
Before you configure an OSPF sham link, perform the following tasks:
·     Configure basic MPLS L3VPN (OSPF is used between PE and CE).
·     Configure OSPF in the LAN where customer CEs reside.
Redistributing the loopback interface address
2.     Create a loopback interface and enter loopback interface view.
interface loopback interface-number
3.     Associate the loopback interface with a VPN instance.
By default, the interface is not associated with any VPN instances and belongs to the public network.
4.     Configure an IP address for the loopback interface.
ip address ip-address { mask-length | mask }
By default, no IP address is configured for the loopback interface.
5.     Return to system view.
6.     Enter BGP instance view.
9.     Redistribute direct routes into BGP (including the loopback interface route).
import-route direct
By default, no direct routes are redistributed into BGP.
Creating a sham link
2.     Enter OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
As a best practice, specify a router ID.
3.     Set the external route tag for imported VPN routes.
route-tag tag-value
By default, if BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000 and the last two octets are the local BGP AS number. If the AS number is greater than 65535, the external route tag is 0.
4.     Enter OSPF area view.
area area-id
5.     Configure a sham link.
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
When CEs at different sites have the same AS number, configure the BGP AS number substitution feature to avoid route loss.
When a PE uses different interfaces to connect different CEs in a site, the BGP AS number substitution feature introduces a routing loop. To remove the routing loop, configure the SoO attribute on the PE.
For more information about the BGP AS number substitution feature and the SoO attribute, see "BGP AS number substitution and SoO attribute."
4.     Enable the BGP AS number substitution feature.
peer { ipv4-address [ mask-length ] | group-name } substitute-as
By default, BGP AS number substitution is disabled.
5.     Enter BGP-VPN IPv4 unicast address family view.
6.     (Optional.) Configure the SoO attribute for a BGP peer or peer group.
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative control. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
With this feature enabled, a device processes the AIGP attribute in a received route as follows:
·     If the device sets itself as the next hop for the route, it adds to the AIGP attribute value the IGP metric from itself to the original next hop and advertises the new AIGP attribute value.
·     If the device does not set itself as the next hop for the route, it does not change the AIGP attribute value.
BGP uses the AIGP attribute to select the optimal route as follows:
·     A route carrying the AIGP attribute takes precedence over a route not carrying the AIGP attribute.
·     A route that has a smaller computed AIGP attribute value has a higher priority.
When the AIGP attribute of a route changes, BGP sends update messages for the route.
As a best practice, do not configure the peer aigp command on border devices of an AIGP administrative domain.
When a device receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you configure only the peer aigp command. To enable the device to advertise the AIGP attribute, you must configure both the peer aigp and apply aigp commands. For information about the apply aigp command, see the routing policy configuration in Layer 3—IP Routing Configuration Guide.
4.     Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attribute in routes received from the peer or peer group.
5.     (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
The BGP RT filtering feature reduces the number of routes advertised in an MPLS L3VPN.
After RT filtering is configured, a PE advertises its import target attribute to the peer PEs in the RT filter address family. The peer PEs use the received import target attribute to filter routes and advertise only the routes that match the attribute to the PE.
When a large number of IBGP peers exist, the BGP RT filtering and the route reflection features are used together as a best practice. Route reflection reduces the number of IBGP connections. BGP RT filtering reduces the number of routes advertised in the network.
For more information about the BGP RT filtering commands, see Layer 3—IP Routing Command Reference.
3.     Enter BGP IPv4 RT filter address family view.
address-family ipv4 rtfilter
4.     Enable the device to exchange routing information with a peer or peer group.
By default, the device cannot exchange routing information with a peer or peer group.
5.     (Optional.) Advertise a default route to a peer or peer group.
By default, no default route is advertised.
6.     (Optional.) Set a preferred value for routes received from a peer or peer group.
7.     (Optional.) Configure the device as a route reflector and specify a peer or peer group as its client.
9.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
The BGP additional path (Add-Path) feature enables BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group. When the optimal route fails, the suboptimal route becomes the optimal route, which shortens the traffic interruption time.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP device. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
2.     Enter BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
¡     Execute the following commands in sequence to enter BGP VPNv4 address family view:
¡     Execute the following commands in sequence to enter BGP-VPN VPNv4 address family view:
3.     Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
4.     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group is 1.
5.     Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, the maximum total number of Add-Path optimal routes that can be advertised to all peers is 1.
This command is not supported in BGP-VPN VPNv4 address family view.
6.     (Optional.) Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
In a BGP/MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
The route replication feature provides the following functions:
·     Enables a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public network or other VPN instances.
·     Enables the public network to communicate with a VPN instance by replicating routes from the VPN instance.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this feature to replicate routes from the public network to the VPN instances.
VLINK direct routes are generated based on ARP entries learned by subinterfaces configured with QinQ/Dot1q termination or VLAN interfaces. The route-replicate from vpn-instance protocol direct or route-replicate from public protocol direct command does not replicate VLINK direct routes, which will cause traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes.
Replicating routes from the public network or VPN instances to a VPN instance
2.     Enter VPN instance view.
3.     Enter VPN instance IPv4 address family view.
address-family ipv4
4.     Replicate routes from the public network or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp as-number | direct | static | vlink-direct | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, a VPN instance cannot replicate routes from the public network or other VPN instances.
Replicating routes from a VPN instance to the public network
2.     Enter public instance view.
ip public-instance
3.     Enter public instance IPv4 address family view.
address-family ipv4
4.     Replicate routes from a VPN instance to the public network.
route-replicate from vpn-instance vpn-instance-name protocol { bgp as-number | direct | static | vlink-direct | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, the public network cannot replicate routes from VPN instances.
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, you can configure BGP route replication between public and VPN instances.
After you configure this feature, the public and VPN instances replicate all BGP routes including route attributes from each other.
This feature also enables BGP route replication between VPN instances, so VPNs cannot be isolated. Configure this feature only in specific scenarios, for example, the traffic cleaning scenario.
3.     Enable BGP route replication between public and VPN instances.
route-replicate enable
By default, BGP route replication between public and VPN instances is disabled.
5.     Enter public instance view or public instance IPv4 address family view.
¡     Enter public instance view.
ip public-instance
¡     Execute the following commands in sequence to enter public instance IPv4 address family view:
ip public-instance
address-family ipv4
6.     Apply an import routing policy to the public instance.
7.     Apply an export routing policy to the public instance.
For multiple routes that have the same prefix and RD, a VPN instance redistributes only the optimal route into its routing table by default. This feature enables a VPN instance to redistribute all routes that have the same prefix and RD into its routing table to perform load sharing or MPLS L3VPN FRR.
2.     Enter a BGP address family view.
¡     Enter BGP instance view.
¡     Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡     Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
3.     Enable ECMP VPN route redistribution.
vpn-route cross multipath
By default, ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, a VPN instance redistributes only the optimal route into its routing table.
In BGP IPv4 unicast address family view and BGP IPv6 unicast address family view, this command redistributes ECMP routes to the routing table of the public instance. For more information about the public instance, see EVPN Configuration Guide.
This feature enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast switchover of traffic on the specified routes to available routes to reduce the traffic interruption time.
4.     Enable prioritized withdrawal of the routes that match the specified routing policy.
By default, BGP does not send the withdrawal messages of specific routes prior to other routes.
To report critical MPLS L3VPN events to an NMS, enable SNMP notifications for MPLS L3VPN. For MPLS L3VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Enable SNMP notifications for MPLS L3VPN.
snmp-agent trap enable l3vpn
By default, SNMP notifications for MPLS L3VPN are enabled.
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
3.     Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Display and maintenance commands for MPLS L3VPN
Resetting BGP connections
You can soft-reset or reset BGP sessions to apply new BGP configurations. A soft reset operation updates BGP routing information without tearing down BGP connections. A reset operation updates BGP routing information by tearing down, and then re-establishing BGP connections. Soft reset requires that BGP peers have route refresh capability.
Execute the following commands in user view to soft reset or reset BGP connections:
Soft-reset BGP sessions for the VPNv4 address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } vpnv4 [ vpn-instance vpn-instance-name ]
Soft-reset BGP sessions for the BGP IPv4 RT filter family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 rtfilter
Reset BGP sessions for the VPNv4 address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } vpnv4 [ vpn-instance vpn-instance-name ]
Reset BGP sessions for the BGP IPv4 RT filter family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } ipv4 rtfilter
For more information about the refresh bgp vpnv4 and reset bgp vpnv4 commands, see Layer 3—IP Routing Command Reference.
Displaying and maintaining MPLS L3VPN information
Execute the following display commands in any view and reset commands in user view to display and maintain MPLS L3VPN information:
Display BGP VPNv4 route dampening parameters.
display bgp [ instance instance-name ] dampening parameter vpnv4
Display BGP RT filter peer group information.
display bgp [ instance instance-name ] group ipv4 rtfilter [ group-name group-name ]
Display BGP VPNv4 peer group information.
display bgp [ instance instance-name ] group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name group-name ]
Display BGP RT filter information.
display bgp [ instance instance-name ] ipv4 rtfilter [ peer ipv4-address [ statistics ] | statistics ]
Display BGP RT filter peer information.
display bgp [ instance instance-name ] peer ipv4 rtfilter [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Display BGP VPNv4 peer information.
display bgp [ instance instance-name ] peer vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Display information about dampened BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table dampened vpnv4
Display BGP VPNv4 route flapping information.
display bgp [ instance instance-name ] routing-table flap-info vpnv4 [ ipv4-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ]
Display incoming labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
Display outgoing labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
Display BGP RT filter routing information.
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info ] | [ origin-as as-number ] [ route-target [ advertise-info ] ] | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ]
Display BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | peer ipv6-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
Display incoming labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
Display outgoing labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
Display BGP IPv4 RT filter address family update group information.
display bgp [ instance instance-name ] update-group ipv4 rtfilter [ ipv4-address ]
Display BGP VPNv4 address family update group information.
display bgp [ instance instance-name ] update-group vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address ]
Display BGP peer and routing summary information.
display bgp [ instance instance-name ] vpnv4 summary
Display the FIB of a VPN instance.
display fib vpn-instance vpn-instance-name
Display FIB entries that match the specified destination IP address in the specified VPN instance.
display fib vpn-instance vpn-instance-name ip-address [ mask-length | mask ]
Display the MPLS hardware resource allocation mode.
display hardware-resource [ mpls ]
Display the routing table for a VPN instance.
display ip routing-table vpn-instance vpn-instance-name [ statistics | verbose ]
Display information about a specific or all VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name | count ]
Display OSPF sham link information.
display ospf [ process-id ] sham-link [ area area-id ]
Clear BGP VPNv4 route dampening information and release dampened routes.
reset bgp [ instance instance-name ] dampening vpnv4 [ ipv4-address [ mask | mask-length ] ]
Clear BGP VPNv4 route flapping statistics.
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ]
For more information about the following commands, see BGP commands in Layer 3—IP Routing Command Reference:
·     display ip routing-table
·     display bgp group vpnv4
·     display bgp peer vpnv4
·     display bgp update-group vpnv4
MPLS L3VPN configuration examples
Example: Configuring basic MPLS L3VPN
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attribute 111:1. VPN 2 uses route target attribute 222:2. Users of different VPNs cannot access each other.
A PE and its connected CE use EBGP to exchange VPN routing information.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Figure 24 Network diagram
Device
IP address
Device
IP address
CE 1
HGE1/0/1
10.1.1.1/24
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
HGE1/0/4
172.1.1.2/24
HGE1/0/1
10.1.1.2/24
HGE1/0/5
172.2.1.1/24
HGE1/0/2
10.2.1.2/24
PE 2
Loop0
3.3.3.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/1
10.3.1.2/24
CE 2
HGE1/0/1
10.2.1.1/24
HGE1/0/2
10.4.1.2/24
CE 3
HGE1/0/1
10.3.1.1/24
HGE1/0/4
172.2.1.2/24
CE 4
HGE1/0/1
10.4.1.1/24
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1.     Configure OSPF on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure PE 1.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface hundredgige 1/0/4
[PE1-HundredGigE1/0/4] ip address 172.1.1.1 24
[PE1-HundredGigE1/0/4] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface hundredgige 1/0/4
[P-HundredGigE1/0/4] ip address 172.1.1.2 24
[P-HundredGigE1/0/4] quit
[P] interface hundredgige 1/0/5
[P-HundredGigE1/0/5] ip address 172.2.1.1 24
[P-HundredGigE1/0/5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface hundredgige 1/0/4
[PE2-HundredGigE1/0/4] ip address 172.2.1.2 24
[PE2-HundredGigE1/0/4] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2.     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-HundredGigE1/0/4] mpls enable
[PE1-HundredGigE1/0/4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-HundredGigE1/0/4] mpls enable
[P-HundredGigE1/0/4] mpls ldp enable
[P-HundredGigE1/0/5] mpls enable
[P-HundredGigE1/0/5] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-HundredGigE1/0/4] mpls enable
[PE2-HundredGigE1/0/4] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure VPN instances on PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface hundredgige 1/0/1
[PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/1] ip address 10.1.1.2 24
[PE1-HundredGigE1/0/1] quit
[PE1] interface hundredgige 1/0/2
[PE1-HundredGigE1/0/2] ip binding vpn-instance vpn2
[PE1-HundredGigE1/0/2] ip address 10.2.1.2 24
[PE1-HundredGigE1/0/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface hundredgige 1/0/1
[PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE2-HundredGigE1/0/1] ip address 10.3.1.2 24
[PE2-HundredGigE1/0/1] quit
[PE2] interface hundredgige 1/0/2
[PE2-HundredGigE1/0/2] ip binding vpn-instance vpn2
[PE2-HundredGigE1/0/2] ip address 10.4.1.2 24
[PE2-HundredGigE1/0/2] quit
# Configure IP addresses for the CEs according to Figure 24. (Details not shown.)
# Execute the display ip vpn-instance command on the PEs to display the configuration of the VPN instance, for example, on PE 1.
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  Total IPv4 VPN-Instances configured : 2
  Total IPv6 VPN-Instances configured : 0
  VPN-Instance Name     RD              Address family      Create time
  vpn1                  100:1           IPv4                2012/02/13 12:49:08
  vpn2                  100:2           IPv4                2012/02/13 12:49:20
# Use the ping command on the PEs to verify that the PEs can ping their attached CEs, for example, on PE 1.
[PE1] ping -vpn-instance vpn1 10.1.1.1
Ping 10.1.1.1 (10.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.1: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 10.1.1.1: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 10.1.1.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 10.1.1.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.1.1.1: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
4.     Establish EBGP peer relationships between PEs and CEs, and redistribute VPN routes into BGP:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure the other three CEs in the same way that CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 10.2.1.1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv4 unicast
[PE1-bgp-default-ipv4-vpn2] peer 10.2.1.1 enable
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2 in the same way that PE 1 is configured. (Details not shown.)
# Execute the display bgp peer ipv4 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5.     Create an MP-IBGP peer relationship between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
# Execute the display bgp peer vpnv4 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11        Routes : 11
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         Direct 0    0            10.1.1.2        HGE1/0/1
10.1.1.0/32         Direct 0    0            10.1.1.2        HGE1/0/1
10.1.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.1.1.255/32       Direct 0    0            10.1.1.2        HGE1/0/1
10.3.1.0/24         BGP    255  0            3.3.3.9         HGE1/0/4
127.0.0.0/8         Direct 0    0            127.0.0.1       InLoop0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
The output shows that PE 1 has a route to the remote CE. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (10.3.1.1), but it cannot ping CE 4 (10.4.1.1). (Details not shown.)
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs, and configure MP-IBGP between them to exchange VPN routing information.
Figure 25 Network diagram
Device
IP address
Device
IP address
Spoke-CE 1
HGE1/0/1
10.1.1.1/24
Hub-CE
HGE1/0/1
10.3.1.1/24
Spoke-PE 1
Loop0
1.1.1.9/32
HGE1/0/2
10.4.1.1/24
HGE1/0/1
10.1.1.2/24
Hub-PE
Loop0
2.2.2.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/4
172.1.1.2/24
Spoke-CE 2
HGE1/0/1
10.2.1.1/24
HGE1/0/5
172.2.1.2/24
Spoke-PE 2
Loop0
3.3.3.9/32
HGE1/0/1
10.3.1.2/24
HGE1/0/1
10.2.1.2/24
HGE1/0/2
10.4.1.2/24
HGE1/0/4
172.2.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure Spoke-PE 1.
<Spoke-PE1> system-view
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface hundredgige 1/0/4
[Spoke-PE1-HundredGigE1/0/4] ip address 172.1.1.1 24
[Spoke-PE1-HundredGigE1/0/4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
<Spoke-PE2> system-view
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface hundredgige 1/0/4
[Spoke-PE2-HundredGigE1/0/4] ip address 172.2.1.1 24
[Spoke-PE2-HundredGigE1/0/4] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
<Hub-PE> system-view
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface hundredgige 1/0/4
[Hub-PE-HundredGigE1/0/4] ip address 172.1.1.2 24
[Hub-PE-HundredGigE1/0/4] quit
[Hub-PE] interface hundredgige 1/0/5
[Hub-PE-HundredGigE1/0/5] ip address 172.2.1.2 24
[Hub-PE-HundredGigE1/0/5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the devices to verify that OSPF adjacencies in Full state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display ip routing-table command on the devices to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-HundredGigE1/0/4] mpls enable
[Spoke-PE1-HundredGigE1/0/4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-HundredGigE1/0/4] mpls enable
[Spoke-PE2-HundredGigE1/0/4] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-HundredGigE1/0/4] mpls enable
[Hub-PE-HundredGigE1/0/4] mpls ldp enable
[Hub-PE-HundredGigE1/0/5] mpls enable
[Hub-PE-HundredGigE1/0/5] mpls ldp enable
# Execute the display mpls ldp peer command on the devices to verify that LDP sessions in Operational state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display mpls ldp lsp command on the devices to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface hundredgige 1/0/1
[Spoke-PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[Spoke-PE1-HundredGigE1/0/1] ip address 10.1.1.2 24
[Spoke-PE1-HundredGigE1/0/1] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface hundredgige 1/0/1
[Spoke-PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[Spoke-PE2-HundredGigE1/0/1] ip address 10.2.1.2 24
[Spoke-PE2-HundredGigE1/0/1] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface hundredgige 1/0/1
[Hub-PE-HundredGigE1/0/1] ip binding vpn-instance vpn1-in
[Hub-PE-HundredGigE1/0/1] ip address 10.3.1.2 24
[Hub-PE-HundredGigE1/0/1] quit
[Hub-PE] interface hundredgige 1/0/2
[Hub-PE-HundredGigE1/0/2] ip binding vpn-instance vpn1-out
[Hub-PE-HundredGigE1/0/2] ip address 10.4.1.2 24
[Hub-PE-HundredGigE1/0/2] quit
# Configure IP addresses for the CEs according to Table 2. (Details not shown.)
# Execute the display ip vpn-instance command on the PEs to display the configuration of the VPN instance, for example, on Spoke-PE 1.
[Spoke-PE1] display ip vpn-instance
  Total IPv4 VPN-Instances configured : 1
  vpn1                  100:1           IPv4                2009/04/08 10:55:07
# Use the ping command on the PEs to verify that the PEs can ping their attached CEs, for example, on Spoke-PE 1.
[Spoke-PE1] ping -vpn-instance vpn1 10.1.1.1
56 bytes from 10.1.1.1: icmp_seq=0 ttl=128 time=1.913 ms
56 bytes from 10.1.1.1: icmp_seq=1 ttl=128 time=2.381 ms
56 bytes from 10.1.1.1: icmp_seq=2 ttl=128 time=1.707 ms
56 bytes from 10.1.1.1: icmp_seq=3 ttl=128 time=1.666 ms
56 bytes from 10.1.1.1: icmp_seq=4 ttl=128 time=2.710 ms
round-trip min/avg/max/std-dev = 1.666/2.075/2.710/0.406 ms
4.     Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
# Configure Spoke-CE 1.
<Spoke-CE1> system-view
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] peer 10.1.1.2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv4
[Spoke-CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[Spoke-CE1-bgp-default-ipv4] import-route direct
[Spoke-CE1-bgp-default-ipv4] quit
[Spoke-CE1-bgp-default] quit
# Configure Spoke-CE 2.
<Spoke-CE2> system-view
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] peer 10.2.1.2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv4
[Spoke-CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[Spoke-CE2-bgp-default-ipv4] import-route direct
[Spoke-CE2-bgp-default-ipv4] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
<Hub-CE> system-view
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] peer 10.3.1.2 as-number 100
[Hub-CE-bgp-default] peer 10.4.1.2 as-number 100
[Hub-CE-bgp-default] address-family ipv4
[Hub-CE-bgp-default-ipv4] peer 10.3.1.2 enable
[Hub-CE-bgp-default-ipv4] peer 10.4.1.2 enable
[Hub-CE-bgp-default-ipv4] import-route direct
[Hub-CE-bgp-default-ipv4] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv4
[Spoke-PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[Spoke-PE1-bgp-default-ipv4-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv4
[Spoke-PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[Spoke-PE2-bgp-default-ipv4-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 10.3.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-in] peer 10.3.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 10.4.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 allow-as-loop 2
[Hub-PE-bgp-default-ipv4-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5.     Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv4
[Spoke-PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv4] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv4
[Spoke-PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv4] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv4
[Hub-PE-bgp-default-vpnv4] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv4] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv4] quit
# Execute the display ip routing-table vpn-instance command on the PEs to display the routes to the CEs. This example uses Spoke-PE 1 to verify that the next hop of the route from a Spoke-PE to its connected Spoke-CE is Hub-PE.
[Spoke-PE1] display ip routing-table vpn-instance vpn1
Destinations : 13        Routes : 13
10.2.1.0/24        BGP     255 0           2.2.2.9         HGE1/0/4
10.3.1.0/24        BGP     255 0           2.2.2.9         HGE1/0/4
10.4.1.0/24        BGP     255 0           2.2.2.9         HGE1/0/4
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (255-250+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1 to verify their connectivity.
[Spoke-CE1] ping 10.2.1.1
Ping 10.2.1.1 (10.2.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=250 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=250 time=0.000 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=250 time=0.000 ms
--- Ping statistics for 10.2.1.1 ---
Example: Configuring MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100, and CE 2 accesses the network through PE 2 in AS 200.
Configure inter-AS option A MPLS L3VPN, and use the VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone of each AS.
Figure 26 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
10.1.1.1/24
CE 2
HGE1/0/1
10.2.1.1/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/1
10.1.1.2/24
HGE1/0/1
10.2.1.2/24
HGE1/0/4
172.1.1.2/24
HGE1/0/4
162.1.1.2/24
ASBR-PE1
Loop0
2.2.2.9/32
ASBR-PE2
Loop0
3.3.3.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/4
162.1.1.1/24
HGE1/0/5
192.1.1.1/24
HGE1/0/5
192.1.1.2/24
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
IMPORTANT
IMPORTANT:
1.     Configure IGP on the MPLS backbone.
This example uses OSPF. (Details not shown.)
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Verify that each ASBR-PE and the PE in the same AS can ping each other. (Details not shown.)
# Configure basic MPLS on PE 1, and enable MPLS LDP on the interface connected to ASBR-PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP on the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1] interface hundredgige 1/0/4
[ASBR-PE1-HundredGigE1/0/4] mpls enable
[ASBR-PE1-HundredGigE1/0/4] mpls ldp enable
[ASBR-PE1-HundredGigE1/0/4] quit
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP on the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] interface hundredgige 1/0/4
[ASBR-PE2-HundredGigE1/0/4] mpls enable
[ASBR-PE2-HundredGigE1/0/4] mpls ldp enable
[ASBR-PE2-HundredGigE1/0/4] quit
# Configure basic MPLS on PE 2, and enable MPLS LDP on the interface connected to ASBR-PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
# Execute the display mpls ldp peer command on the devices to verify that the LDP session status is Operational, and that each PE and the ASBR-PE in the same AS have established an LDP neighbor relationship. (Details not shown.)
3.     Configure VPN instances on PEs:
# Configure CE 1.
<CE1> system-view
[CE1] interface hundredgige 1/0/1
[CE1-HundredGigE1/0/1] ip address 10.1.1.1 24
[CE1-HundredGigE1/0/1] quit
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
# Configure CE 2.
<CE2> system-view
[CE2] interface hundredgige 1/0/1
[CE2-HundredGigE1/0/1] ip address 10.2.1.1 24
[CE2-HundredGigE1/0/1] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2-vpn-instance-vpn1] vpn-target 200:1 both
[PE2-HundredGigE1/0/1] ip address 10.2.1.2 24
# On ASBR-PE 1, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface hundredgige 1/0/5
[ASBR-PE1-HundredGigE1/0/5] ip binding vpn-instance vpn1
[ASBR-PE1-HundredGigE1/0/5] ip address 192.1.1.1 24
[ASBR-PE1-HundredGigE1/0/5] quit
# On ASBR-PE 2, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface hundredgige 1/0/5
[ASBR-PE2-HundredGigE1/0/5] ip binding vpn-instance vpn1
[ASBR-PE2-HundredGigE1/0/5] ip address 192.1.1.2 24
[ASBR-PE2-HundredGigE1/0/5] quit
# Execute the display ip vpn-instance command to display VPN instance configurations. Verify that the PEs can ping their attached CEs, and the ASBR-PEs can ping each other. (Details not shown.)
# Configure CE 1.
[CE1] bgp 65001
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] peer 10.2.1.2 as-number 200
[CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[PE2-bgp-default-vpn1] quit
5.     Establish an MP-IBGP peer relationship between each PE and the ASBR-PE in the same AS, and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[PE1-bgp-default-vpnv4] peer 2.2.2.9 next-hop-local
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 192.1.1.2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4-vpn1] peer 192.1.1.2 enable
[ASBR-PE1-bgp-default-ipv4-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 next-hop-local
[ASBR-PE1-bgp-default] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 192.1.1.1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4-vpn1] peer 192.1.1.1 enable
[ASBR-PE2-bgp-default-ipv4-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 next-hop-local
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-default-vpnv4] peer 3.3.3.9 next-hop-local
# Verify that the CEs can learn the interface routes from each other and ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100, and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv4 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv4 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv4 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPN-IPv4 routes.
Figure 27 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
30.0.0.1/8
HGE1/0/1
20.0.0.1/8
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
IMPORTANT
IMPORTANT:
1.     Configure PE 1:
# Configure IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.111.111.111.111.00
[PE1-isis-1] quit
# Configure LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure HundredGigE 1/0/5, and enable IS-IS, MPLS, and LDP on the interface.
[PE1] interface hundredgige 1/0/5
[PE1-HundredGigE1/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-HundredGigE1/0/5] isis enable 1
[PE1-HundredGigE1/0/5] mpls enable
[PE1-HundredGigE1/0/5] mpls ldp enable
[PE1-HundredGigE1/0/5] quit
# Configure Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-HundredGigE1/0/1] ip address 30.0.0.1 8
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv4 peer.
# Redistribute direct routes to the VPN routing table of vpn1.
[PE1-bgp-default-ipv4-vpn1] import-route direct
2.     Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-HundredGigE1/0/5] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-HundredGigE1/0/5] isis enable 1
[ASBR-PE1-HundredGigE1/0/5] mpls enable
[ASBR-PE1-HundredGigE1/0/5] mpls ldp enable
# Configure HundredGigE 1/0/4, and enable MPLS.
[ASBR-PE1-HundredGigE1/0/4] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface hundredgige 1/0/4
# Disable route target based filtering of received VPNv4 routes.
# Configure both IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as VPNv4 peers.
3.     Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-HundredGigE1/0/5] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-HundredGigE1/0/5] isis enable 1
[ASBR-PE2-HundredGigE1/0/5] mpls enable
[ASBR-PE2-HundredGigE1/0/5] mpls ldp enable
[ASBR-PE2-HundredGigE1/0/4] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface hundredgige 1/0/4
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
# Configure both IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv4 peers.
4.     Configure PE 2:
# Enable IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.111.111.111.111.00
[PE2-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface hundredgige 1/0/5
[PE2-HundredGigE1/0/5] ip address 9.1.1.2 255.0.0.0
[PE2-HundredGigE1/0/5] isis enable 1
[PE2-HundredGigE1/0/5] mpls enable
[PE2-HundredGigE1/0/5] mpls ldp enable
[PE2-HundredGigE1/0/5] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-HundredGigE1/0/1] ip address 20.0.0.1 8
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
# Use the following command on PE 1 to verify its connectivity to PE 2.
[PE1] ping -a 30.0.0.1 -vpn-instance vpn1 20.0.0.1
Ping 20.0.0.1 (20.0.0.1) from 30.0.0.1: 56 data bytes, press CTRL_C to break
56 bytes from 20.0.0.1: icmp_seq=0 ttl=255 time=1.208 ms
56 bytes from 20.0.0.1: icmp_seq=1 ttl=255 time=0.867 ms
56 bytes from 20.0.0.1: icmp_seq=2 ttl=255 time=0.551 ms
56 bytes from 20.0.0.1: icmp_seq=3 ttl=255 time=0.566 ms
56 bytes from 20.0.0.1: icmp_seq=4 ttl=255 time=0.570 ms
--- Ping statistics for 20.0.0.1 ---
round-trip min/avg/max/std-dev = 0.551/0.752/1.208/0.257 ms
Example: Configuring MPLS L3VPN inter-AS option C (method 1)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes through IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes through IBGP. PE 1 and PE 2 are MP-EBGP peers and exchange VPNv4 routes.
ASBR-PE 1 and ASBR-PE 2 use routing policies and label the routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Figure 28 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
30.0.0.1/24
HGE1/0/1
20.0.0.1/24
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
CE 1
HGE1/0/1
30.0.0.2/24
CE 2
HGE1/0/1
20.0.0.2/24
IMPORTANT
IMPORTANT:
1.     Configure CE 1:
# Configure an IP address for HundredGigE 1/0/1.
<CE1> system-view
[CE1-HundredGigE1/0/1] ip address 30.0.0.2 24
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 30.0.0.1 as-number 100
[CE1-bgp-default-ipv4] peer 30.0.0.1 enable
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Associate interface HundredGigE 1/0/1 with VPN instance vpn1, and specify the IP address for the interface.
[PE1-HundredGigE1/0/1] ip address 30.0.0.1 24
[PE1] bgp 100
# Enable the capability to advertise labeled routes to IBGP peer 3.3.3.9 and to receive labeled routes from the peer.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-default-vpnv4] peer 5.5.5.9 enable
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE1-bgp-default-vpn1] peer 30.0.0.2 as-number 65001
[PE1-bgp-default-ipv4-vpn1] peer 30.0.0.2 enable
3.     Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure HundredGigE 1/0/4, and enable MPLS on it.
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply the routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to IBGP peer 2.2.2.9 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1 to BGP.
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.1 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4.     Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Configure HundredGigE 1/0/4, and enable MPLS on the interface.
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to IBGP peer 5.5.5.9 and to receive labeled routes from the peer.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.2 and to receive labeled routes from the peer.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
# Associate HundredGigE 1/0/1 with VPN instance vpn1, and specify the IP address for the interface.
[PE2-HundredGigE1/0/1] ip address 20.0.0.1 24
[PE2] bgp 600
# Enable the capability to advertise labeled routes to IBGP peer 4.4.4.9 and to receive labeled routes from the peer.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 20.0.0.2 enable
6.     Configure CE 2:
<CE2> system-view
[CE2-HundredGigE1/0/1] ip address 20.0.0.2 24
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 20.0.0.1 as-number 600
[CE2-bgp-default-ipv4] peer 20.0.0.1 enable
# Execute the display ip routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN inter-AS option C (method 2)
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 29 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
30.0.0.1/24
HGE1/0/1
20.0.0.1/24
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
CE 1
HGE1/0/1
30.0.0.2/24
CE 2
HGE1/0/1
20.0.0.2/24
IMPORTANT
IMPORTANT:
1.     Configure CE 1:
<CE1> system-view
[CE1] bgp 65001
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Enable IS-IS, MPLS, and LDP on interface HundredGigE 1/0/5.
# Enable IS-IS on interface Loopback 0.
# Associate interface HundredGigE 1/0/1 with VPN instance vpn1, and specify an IP address for the interface.
[PE1] bgp 100
3.     Configure ASBR-PE1:
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure interface HundredGigE 1/0/5, and enable IS-IS, MPLS, and LDP on the interface.
# Configure interface Loopback 0, and enable IS-IS on it.
# Create routing policy policy1.
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
6.     Configure CE 2:
# Configure an IP address for interface HundredGigE 1/0/1.
<CE2> system-view
[CE2] bgp 65002
Example: Configuring MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 30. In this scenario:
·     PE 1 and PE 2 are the provider carrier's PE routers. They provide VPN services for the customer carrier.
·     CE 1 and CE 2 are the customer carrier's routers. They are connected to the provider carrier's backbone as CE routers.
·     PE 3 and PE 4 are the customer carrier's PE routers. They provide MPLS L3VPN services for the end customers.
·     CE 3 and CE 4 are customers of the customer carrier.
·     The customer carrier and the provider carrier reside in the same AS.
The key to carrier's carrier deployment is to configure exchange of two kinds of routes:
·     Exchange of the customer carrier's internal routes on the provider carrier's backbone.
·     Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Figure 30 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
CE 3
HGE1/0/1
100.1.1.1/24
CE 4
HGE1/0/1
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
HGE1/0/1
100.1.1.2/24
HGE1/0/1
120.1.1.2/24
HGE1/0/5
10.1.1.1/24
HGE1/0/5
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
HGE1/0/4
10.1.1.2/24
HGE1/0/4
21.1.1.2/24
HGE1/0/5
11.1.1.1/24
HGE1/0/5
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/4
11.1.1.2/24
HGE1/0/4
30.1.1.2/24
HGE1/0/5
30.1.1.1/24
HGE1/0/5
21.1.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure MPLS L3VPN on the provider carrier backbone. Enable IS-IS as the IGP, enable LDP between PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-HundredGigE1/0/5] ip address 30.1.1.1 24
[PE1-HundredGigE1/0/5] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
# On PE 1 or PE 2, execute the following commands:
¡     Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2.     Configure the customer carrier network. Enable IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface hundredgige 1/0/5
[PE3-HundredGigE1/0/5] ip address 10.1.1.1 24
[PE3-HundredGigE1/0/5] isis enable 2
[PE3-HundredGigE1/0/5] mpls enable
[PE3-HundredGigE1/0/5] mpls ldp enable
[PE3-HundredGigE1/0/5] mpls ldp transport-address interface
[PE3-HundredGigE1/0/5] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface hundredgige 1/0/4
[CE1-HundredGigE1/0/4] ip address 10.1.1.2 24
[CE1-HundredGigE1/0/4] isis enable 2
[CE1-HundredGigE1/0/4] mpls enable
[CE1-HundredGigE1/0/4] mpls ldp enable
[CE1-HundredGigE1/0/4] mpls ldp transport-address interface
[CE1-HundredGigE1/0/4] quit
PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
# Configure PE 4 and CE 2 in the same way that PE 3 and CE 1 are configured. (Details not shown.)
3.     Allow CEs of the customer carrier to access PEs of the provider carrier, and redistribute IS-IS routes to BGP and BGP routes to IS-IS on the PEs:
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1-HundredGigE1/0/4] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/4] ip address 11.1.1.2 24
[PE1-HundredGigE1/0/4] isis enable 2
[PE1-HundredGigE1/0/4] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import isis 2
# Configure CE 1.
[CE1] interface hundredgige 1/0/5
[CE1-HundredGigE1/0/5] ip address 11.1.1.1 24
[CE1-HundredGigE1/0/5] isis enable 2
[CE1-HundredGigE1/0/5] mpls enable
[CE1-HundredGigE1/0/5] mpls ldp enable
[CE1-HundredGigE1/0/5] mpls ldp transport-address interface
[CE1-HundredGigE1/0/5] quit
PE 1 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
# Configure PE 2 and CE 2 in the same way that PE 1 and CE 1 are configured. (Details not shown.)
4.     Connect CEs of the end customers and the PEs of the customer carrier:
# Configure CE 3.
<CE3> system-view
[CE3] interface hundredgige 1/0/1
[CE3-HundredGigE1/0/1] ip address 100.1.1.1 24
[CE3-HundredGigE1/0/1] quit
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 100.1.1.2 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface hundredgige 1/0/1
[PE3-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE3-HundredGigE1/0/1] ip address 100.1.1.2 24
[PE3-HundredGigE1/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure PE 4 and CE 4 in the same way that PE 3 and CE 3 are configured. (Details not shown.)
5.     Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 6.6.6.9 enable
[PE3-bgp-default-vpnv4] quit
# Configure PE 4 in the same way that PE 3 is configured. (Details not shown.)
1.     Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
Destinations : 12        Routes : 12
3.3.3.9/32         Direct  0   0           127.0.0.1       InLoop0
4.4.4.9/32         IS_L1   15  10          30.1.1.2        HGE1/0/5
30.1.1.0/24        Direct  0   0           30.1.1.1        HGE1/0/5
30.1.1.0/32        Direct  0   0           30.1.1.1        HGE1/0/5
30.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
30.1.1.255/32      Direct  0   0           30.1.1.1        HGE1/0/5
# Verify that the VPN routing table contains the internal routes of the customer carrier, but it does not contain the VPN routes that the customer carrier maintains.
Destinations : 16        Routes : 16
1.1.1.9/32         IS_L1   15  20          11.1.1.1        HGE1/0/4
2.2.2.9/32         IS_L1   15  10          11.1.1.1        HGE1/0/4
5.5.5.9/32         BGP     255 10          4.4.4.9         HGE1/0/5
6.6.6.9/32         BGP     255 20          4.4.4.9         HGE1/0/5
10.1.1.0/24        IS_L1   15  20          11.1.1.1        HGE1/0/4
11.1.1.0/24        Direct  0   0           11.1.1.2        HGE1/0/4
11.1.1.0/32        Direct  0   0           11.1.1.2        HGE1/0/4
11.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.2        HGE1/0/4
20.1.1.0/24        BGP     255 20          4.4.4.9         HGE1/0/5
2.     Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network, but it does not contain the VPN routes that the customer carrier maintains.
[CE1] display ip routing-table
Destinations : 19        Routes : 19
1.1.1.9/32         IS_L1   15  10          10.1.1.1        HGE1/0/4
2.2.2.9/32         Direct  0   0           127.0.0.1       InLoop0
5.5.5.9/32         IS_L2   15  74          11.1.1.2        HGE1/0/5
6.6.6.9/32         IS_L2   15  74          11.1.1.2        HGE1/0/5
10.1.1.0/24        Direct  0   0           10.1.1.2        HGE1/0/4
10.1.1.0/32        Direct  0   0           10.1.1.2        HGE1/0/4
10.1.1.255/32      Direct  0   0           10.1.1.2        HGE1/0/4
11.1.1.0/24        Direct  0   0           11.1.1.1        HGE1/0/5
11.1.1.0/32        Direct  0   0           11.1.1.1        HGE1/0/5
11.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.1        HGE1/0/5
20.1.1.0/24        IS_L2   15  74          11.1.1.2        HGE1/0/5
3.     Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.9/32         IS_L1   15  10          10.1.1.2        HGE1/0/5
5.5.5.9/32         IS_L2   15  84          10.1.1.2        HGE1/0/5
6.6.6.9/32         IS_L2   15  84          10.1.1.2        HGE1/0/5
10.1.1.0/24        Direct  0   0           10.1.1.1        HGE1/0/5
10.1.1.0/32        Direct  0   0           10.1.1.1        HGE1/0/5
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        HGE1/0/5
11.1.1.0/24        IS_L1   15  20          10.1.1.2        HGE1/0/5
20.1.1.0/24        IS_L2   15  84          10.1.1.2        HGE1/0/5
# Verify that the VPN routing table contains the route to the remote VPN customer.
[PE3] display ip routing-table vpn-instance vpn1
100.1.1.0/24       Direct  0   0           100.1.1.2       HGE1/0/1
100.1.1.0/32       Direct  0   0           100.1.1.2       HGE1/0/1
100.1.1.2/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.255/32     Direct  0   0           100.1.1.2       HGE1/0/1
120.1.1.0/24       BGP     255 0           6.6.6.9         HGE1/0/5
4.     Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5.     Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Example: Configuring MPLS L3VPN carrier's carrier in different ASs
Configure carrier's carrier for the scenario shown in Figure 31. In this scenario:
·     The customer carrier and the provider carrier reside in different ASs.
·     Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-EBGP peer relationship must be established between PE 3 and PE 4.
Figure 31 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
CE 3
HGE1/0/1
100.1.1.1/24
CE 4
HGE1/0/1
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
HGE1/0/1
100.1.1.2/24
HGE1/0/1
120.1.1.2/24
HGE1/0/5
10.1.1.1/24
HGE1/0/5
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
HGE1/0/4
10.1.1.2/24
HGE1/0/4
21.1.1.2/24
HGE1/0/5
11.1.1.1/24
HGE1/0/5
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/4
11.1.1.2/24
HGE1/0/4
30.1.1.2/24
HGE1/0/5
30.1.1.1/24
HGE1/0/5
21.1.1.1/24
IMPORTANT
IMPORTANT:
# Configure PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 200
[PE1-bgp-default] peer 4.4.4.9 as-number 200
# Configure PE 3.
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls ldp
[CE1-ldp] import bgp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] address-family ipv4
[CE1-isis-2-ipv4] import-route bgp
[CE1-isis-2-ipv4] quit
[CE1-isis-2] quit
3.     Allow CEs of the customer carrier to access PEs of the provider carrier:
# Configure PE 1.
[PE1] bgp 200
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 100
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 label-route-capability
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 route-policy csc export
[PE1] route-policy csc permit node 0
[PE1-route-policy-csc-0] apply mpls-label
[PE1-route-policy-csc-0] quit
# Configure CE 1.
[CE1] bgp 100
[CE1-bgp-default] peer 11.1.1.2 as-number 200
[CE1-bgp-default-ipv4] peer 11.1.1.2 enable
[CE1-bgp-default-ipv4] peer 11.1.1.2 label-route-capability
[CE1-bgp-default-ipv4] peer 11.1.1.2 route-policy csc export
[CE1-bgp-default-ipv4] import isis 2
[CE1] route-policy csc permit node 0
[CE1-route-policy-csc-0] apply mpls-label
[CE1-route-policy-csc-0] quit
PE 1 and CE 1 can establish a BGP session and exchange labeled IPv4 unicast routes through BGP.
# Configure CE 3.
<CE3> system-view
[CE3] bgp 65410
# Configure PE 3.
[PE3] bgp 100
5.     Configure an MP-EBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 300
[PE3-bgp-default] peer 6.6.6.9 ebgp-max-hop 10
1.1.1.9/32         BGP     255 10          11.1.1.1        HGE1/0/4
6.6.6.9/32         BGP     255 10          4.4.4.9         HGE1/0/5
2.     Display the routing table on the customer carrier CEs, for example, on CE 1.
Destinations : 17        Routes : 17
6.6.6.9/32         BGP     255 0           11.1.1.2        HGE1/0/5
6.6.6.9/32         IS_L2   15  74          10.1.1.2        HGE1/0/5
Example: Configuring nested VPN
The service provider provides nested VPN services for users, as shown in Figure 32.
·     PE 1 and PE 2 are PE devices on the service provider backbone. Both of them support the nested VPN feature.
·     CE 1 and CE 2 are provider CEs connected to the service provider backbone. Both of them support VPNv4 routes.
·     PE 3 and PE 4 are PE devices of the customer VPN. Both of them support MPLS L3VPN.
·     CE 3 through CE 6 are CE devices of sub-VPNs in the customer VPN.
The key of nested VPN configuration is to understand the processing of routes of sub-VPNs on the service provider PEs:
·     When receiving a VPNv4 route from a provider CE (CE 1 or CE 2, in this example), a provider PE performs the following operations:
a.     Replaces the RD of the VPNv4 route with the RD of the MPLS VPN on the service provider network.
b.     Adds the export target attribute of the MPLS VPN on the service provider network to the extended community attribute list.
c.     Forwards the VPNv4 route.
·     To implement exchange of sub-VPN routes between customer PEs and service provider PEs, MP-EBGP peers must be established between provider PEs and provider CEs.
Figure 32 Network diagram
Table 9 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
HGE1/0/4
10.1.1.2/24
HGE1/0/4
21.1.1.2/24
HGE1/0/5
11.1.1.1/24
HGE1/0/5
20.1.1.1/24
CE 3
HGE1/0/1
100.1.1.1/24
CE 4
HGE1/0/1
120.1.1.1/24
CE 5
HGE1/0/1
110.1.1.1/24
CE 6
HGE1/0/1
130.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/4
11.1.1.2/24
HGE1/0/4
30.1.1.2/24
HGE1/0/5
30.1.1.1/24
HGE1/0/5
21.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
HGE1/0/1
100.1.1.2/24
HGE1/0/1
120.1.1.2/24
HGE1/0/2
110.1.1.2/24
HGE1/0/2
130.1.1.2/24
HGE1/0/5
10.1.1.1/24
HGE1/0/5
20.1.1.2/24
IMPORTANT
IMPORTANT:
1.     Configure MPLS L3VPN on the service provider backbone. Enable IS-IS, enable LDP, and establish an MP-IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
2.     Configure the customer VPN. Enable IS-IS, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
An LDP session and IS-IS neighbor relationship can be established between PE 3 and CE 1.
3.     Connect CE 1 and CE 2 to service provider PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 200
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp-default] peer 11.1.1.2 as-number 100
[CE1-bgp-default-vpn1] address-family ipv4
[CE1-bgp-default-ipv4-vpn1] peer 11.1.1.2 enable
[CE1-bgp-default-ipv4-vpn1] quit
4.     Connect sub-VPN CEs to the customer VPN PEs:
# Configure CE 3.
<CE3> system-view
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 200
# Configure CE 5.
<CE5> system-view
[CE5] interface hundredgige 1/0/1
[CE5-HundredGigE1/0/1] ip address 110.1.1.1 24
[CE5-HundredGigE1/0/1] quit
[CE5] bgp 65411
[CE5-bgp-default] peer 110.1.1.2 as-number 200
[CE5-bgp-default] address-family ipv4 unicast
[CE5-bgp-default-ipv4] peer 110.1.1.2 enable
[CE5-bgp-default-ipv4] import-route direct
[CE5-bgp-default-ipv4] quit
[CE5-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance SUB_VPN1
[PE3-vpn-instance-SUB_VPN1] route-distinguisher 100:1
[PE3-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE3-vpn-instance-SUB_VPN1] quit
[PE3-HundredGigE1/0/1] ip binding vpn-instance SUB_VPN1
[PE3] ip vpn-instance SUB_VPN2
[PE3-vpn-instance-SUB_VPN2] route-distinguisher 101:1
[PE3-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE3-vpn-instance-SUB_VPN2] quit
[PE3] interface hundredgige 1/0/2
[PE3-HundredGigE1/0/2] ip binding vpn-instance SUB_VPN2
[PE3-HundredGigE1/0/2] ip address 110.1.1.2 24
[PE3-HundredGigE1/0/2] quit
[PE3] bgp 200
[PE3-bgp-default] ip vpn-instance SUB_VPN1
[PE3-bgp-default-SUB_VPN1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-SUB_VPN1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN1] quit
[PE3-bgp-default-SUB_VPN1] quit
[PE3-bgp-default] ip vpn-instance SUB_VPN2
[PE3-bgp-default-SUB_VPN2] peer 110.1.1.1 as-number 65411
[PE3-bgp-default-SUB_VPN2] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN2] peer 110.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN2] quit
[PE3-bgp-default-SUB_VPN2] quit
# Configure PE 4, CE 4 and CE 6 in the same way that PE 3, CE 3, and CE 5 are configured. (Details not shown.)
5.     Establish MP-EBGP peer relationship between service provider PEs and their CEs to exchange user VPNv4 routes:
# On PE 1, enable nested VPN, and enable VPNv4 route exchange with CE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] nesting-vpn
[PE1-bgp-default-vpn1] address-family vpnv4
[PE1-bgp-default-vpnv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-vpnv4-vpn1] quit
# On CE 1, enable VPNv4 route exchange with PE 1.
[CE1] bgp 200
[CE1-bgp-default] address-family vpnv4
[CE1-bgp-default-vpnv4] peer 11.1.1.2 enable
# Allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE1-bgp-default-vpnv4] peer 11.1.1.2 allow-as-loop 2
[CE1-bgp-default-vpnv4] undo policy vpn-target
[CE1-bgp-default-vpnv4] quit
6.     Establish MP-IBGP peer relationships between sub-VPN PEs and CEs of the customer VPN to exchange VPNv4 routes of sub-VPNs:
# Configure PE 3.
[PE3] bgp 200
[PE3-bgp-default] peer 2.2.2.9 as-number 200
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default-vpnv4] peer 2.2.2.9 enable
[PE3-bgp-default-vpnv4] peer 2.2.2.9 allow-as-loop 2
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp-default] peer 1.1.1.9 as-number 200
[CE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[CE1-bgp-default-vpnv4] peer 1.1.1.9 enable
1.     Display the public routing table and VPN routing table on the provider PEs, for example, on PE 1:
# Verify that the public routing table contains only routes on the service provider network.
# Verify that the VPN routing table contains sub-VPN routes.
Destinations : 14        Routes : 14
100.1.1.0/24       BGP     255 0           11.1.1.1        HGE1/0/4
110.1.1.0/24       BGP     255 0           11.1.1.1        HGE1/0/4
120.1.1.0/24       BGP     255 0           4.4.4.9         HGE1/0/5
130.1.1.0/24       BGP     255 0           4.4.4.9         HGE1/0/5
2.     Display the VPNv4 routing table on the provider CEs, for example, on CE 1.
# Verify that the VPNv4 routing table on the customer VPN contains internal sub-VPN routes.
[CE1] display bgp routing-table vpnv4
 BGP local router ID is 2.2.2.9
               a - additional-path
 Total number of VPN routes: 4
 Total number of routes from all PEs: 4
 Route distinguisher: 100:1
 Total number of routes: 1
* >i 100.1.1.0/24       1.1.1.9         0          100        0       200 65410?
 Route distinguisher: 101:1
* >i 110.1.1.0/24       1.1.1.9         0          100        0       200 65411?
 Route distinguisher: 200:1
* >e 120.1.1.0/24       11.1.1.2                              0       100 200
        65420?
 Route Distinguisher: 201:1
* >e 130.1.1.0/24       11.1.1.2                              0       100 200
        65421?
3.     Display the VPN routing table on the customer PEs, for example, on PE 3:
# Verify that the VPN routing table contains routes sent by the provider PE to the sub-VPN.
[PE3] display ip routing-table vpn-instance SUB_VPN1
120.1.1.0/24       BGP     255 0           2.2.2.9         HGE1/0/5
4.     Display the routing table on the CEs of sub-VPNs in the customer VPN, for example, on CE 3 and CE 5:
# Verify that the routing table contains the route to the remote sub-VPN on CE 3.
[CE3] display ip routing-table
100.1.1.0/24       Direct  0   0           100.1.1.1       HGE1/0/1
100.1.1.0/32       Direct  0   0           100.1.1.1       HGE1/0/1
100.1.1.1/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.255/24     Direct  0   0           100.1.1.1       HGE1/0/1
120.1.1.0/24       BGP     255 0           100.1.1.2       HGE1/0/1
# Verify that the routing table contains the route to the remote sub-VPN on CE 5.
[CE5] display ip routing-table
110.1.1.0/24       Direct  0   0           110.1.1.1       HGE1/0/1
110.1.1.0/32       Direct  0   0           110.1.1.1       HGE1/0/1
110.1.1.1/32       Direct  0   0           127.0.0.1       InLoop0
110.1.1.255/32     Direct  0   0           110.1.1.1       HGE1/0/1
130.1.1.0/24       BGP     255 0           110.1.1.2       HGE1/0/1
6.     Verify that CE 5 and CE 6 can ping each other. (Details not shown.)
7.     Verify that CE 3 and CE 6 cannot ping each other. (Details not shown.)
Example: Configuring HoVPN
As shown in Figure 33, there are two levels of networks: the backbone and the MPLS VPN networks.
·     SPEs act as PEs to allow MPLS VPNs to access the backbone.
·     UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
·     Performance requirements for the UPEs are lower than those for the SPEs.
·     SPEs advertise routes permitted by routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other and forbidding CE 2 and CE 4 in VPN 2 from communicating with each other.
Figure 33 Network diagram
Table 10 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
10.2.1.1/24
CE 3
HGE1/0/1
10.1.1.1/24
CE 2
HGE1/0/1
10.4.1.1/24
CE 4
HGE1/0/1
10.3.1.1/24
UPE 1
Loop0
1.1.1.9/32
UPE 2
Loop0
4.4.4.9/32
HGE1/0/1
10.2.1.2/24
HGE1/0/1
172.2.1.1/24
HGE1/0/2
10.4.1.2/24
HGE1/0/2
10.1.1.2/24
HGE1/0/3
172.1.1.1/24
HGE1/0/3
10.3.1.2/24
SPE 1
Loop0
2.2.2.9/32
SPE 2
Loop0
3.3.3.9/32
HGE1/0/1
172.1.1.2/24
HGE1/0/1
180.1.1.2/24
HGE1/0/2
180.1.1.1/24
HGE1/0/2
172.2.1.2/24
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1.     Configure UPE 1:
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
<UPE1> system-view
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls ldp
[UPE1-ldp] quit
[UPE1] interface hundredgige 1/0/3
[UPE1-HundredGigE1/0/3] ip address 172.1.1.1 24
[UPE1-HundredGigE1/0/3] mpls enable
[UPE1-HundredGigE1/0/3] mpls ldp enable
[UPE1-HundredGigE1/0/3] quit
# Configure the IGP protocol (OSPF, in this example).
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface hundredgige 1/0/1
[UPE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[UPE1-HundredGigE1/0/1] ip address 10.2.1.2 24
[UPE1-HundredGigE1/0/1] quit
[UPE1] interface hundredgige 1/0/2
[UPE1-HundredGigE1/0/2] ip binding vpn-instance vpn2
[UPE1-HundredGigE1/0/2] ip address 10.4.1.2 24
[UPE1-HundredGigE1/0/2] quit
# Establish an MP-IBGP peer relationship with SPE 1.
[UPE1] bgp 100
[UPE1-bgp-default] peer 2.2.2.9 as-number 100
[UPE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp-default] address-family vpnv4
[UPE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[UPE1-bgp-default-vpnv4] quit
# Establish an EBGP peer relationship with CE 1.
[UPE1-bgp-default] ip vpn-instance vpn1
[UPE1-bgp-default-vpn1] peer 10.2.1.1 as-number 65410
[UPE1-bgp-default-vpn1] address-family ipv4 unicast
[UPE1-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[UPE1-bgp-default-ipv4-vpn1] quit
[UPE1-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 2.
[UPE1-bgp-default] ip vpn-instance vpn2
[UPE1-bgp-default-vpn2] peer 10.4.1.1 as-number 65420
[UPE1-bgp-default-vpn2] address-family ipv4 unicast
[UPE1-bgp-default-ipv4-vpn2] peer 10.4.1.1 enable
[UPE1-bgp-default-ipv4-vpn2] quit
[UPE1-bgp-default-vpn2] quit
[UPE1-bgp-default] quit
2.     Configure CE 1.
<CE1> system-view
[CE1-HundredGigE1/0/1] ip address 10.2.1.1 255.255.255.0
[CE1] bgp 65410
[CE1-bgp-default] peer 10.2.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.2.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
3.     Configure CE 2.
<CE2> system-view
[CE2-HundredGigE1/0/1] ip address 10.4.1.1 255.255.255.0
[CE2] bgp 65420
[CE2-bgp-default] peer 10.4.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 10.4.1.2 enable
4.     Configure UPE 2:
<UPE2> system-view
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls ldp
[UPE2-ldp] quit
[UPE2] interface hundredgige 1/0/1
[UPE2-HundredGigE1/0/1] ip address 172.2.1.1 24
[UPE2-HundredGigE1/0/1] mpls enable
[UPE2-HundredGigE1/0/1] mpls ldp enable
[UPE2-HundredGigE1/0/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface hundredgige 1/0/2
[UPE2-HundredGigE1/0/2] ip binding vpn-instance vpn1
[UPE2-HundredGigE1/0/2] ip address 10.1.1.2 24
[UPE2-HundredGigE1/0/2] quit
[UPE2] interface hundredgige 1/0/3
[UPE2-HundredGigE1/0/3] ip binding vpn-instance vpn2
[UPE2-HundredGigE1/0/3] ip address 10.3.1.2 24
[UPE2-HundredGigE1/0/3] quit
# Establish an MP-IBGP peer relationship with SPE 2.
[UPE2] bgp 100
[UPE2-bgp-default] peer 3.3.3.9 as-number 100
[UPE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp-default] address-family vpnv4
[UPE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[UPE2-bgp-default-vpnv4] quit
# Establish an EBGP peer relationship with CE 3.
[UPE2-bgp-default] ip vpn-instance vpn1
[UPE2-bgp-default-vpn1] peer 10.1.1.1 as-number 65430
[UPE2-bgp-default-vpn1] address-family ipv4 unicast
[UPE2-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[UPE2-bgp-default-ipv4-vpn1] quit
[UPE2-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 4.
[UPE2-bgp-default] ip vpn-instance vpn2
[UPE2-bgp-default-vpn2] peer 10.3.1.1 as-number 65440
[UPE2-bgp-default-vpn2] address-family ipv4 unicast
[UPE2-bgp-default-ipv4-vpn2] peer 10.3.1.1 enable
[UPE2-bgp-default-ipv4-vpn2] quit
[UPE2-bgp-default-vpn2] quit
[UPE2-bgp-default] quit
5.     Configure CE 3.
<CE3> system-view
[CE3-HundredGigE1/0/1] ip address 10.1.1.1 255.255.255.0
[CE3] bgp 65430
[CE3-bgp-default] peer 10.1.1.2 as-number 100
[CE3-bgp-default-ipv4] peer 10.1.1.2 enable
6.     Configure CE 4.
<CE4> system-view
[CE4] interface hundredgige 1/0/1
[CE4-HundredGigE1/0/1] ip address 10.3.1.1 255.255.255.0
[CE4-HundredGigE1/0/1] quit
[CE4] bgp 65440
[CE4-bgp-default] peer 10.3.1.2 as-number 100
[CE4-bgp-default] address-family ipv4 unicast
[CE4-bgp-default-ipv4] peer 10.3.1.2 enable
[CE4-bgp-default-ipv4] import-route direct
[CE4-bgp-default-ipv4] quit
[CE4-bgp-default] quit
7.     Configure SPE 1:
<SPE1> system-view
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
[SPE1] interface hundredgige 1/0/1
[SPE1-HundredGigE1/0/1] ip address 172.1.1.2 24
[SPE1-HundredGigE1/0/1] mpls enable
[SPE1-HundredGigE1/0/1] mpls ldp enable
[SPE1-HundredGigE1/0/1] quit
[SPE1] interface hundredgige 1/0/2
[SPE1-HundredGigE1/0/2] ip address 180.1.1.1 24
[SPE1-HundredGigE1/0/2] mpls enable
[SPE1-HundredGigE1/0/2] mpls ldp enable
[SPE1-HundredGigE1/0/2] quit
# Configure the IGP protocol, OSPF, in this example.
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 2 and UPE 1, and specify UPE 1 as a UPE.
[SPE1] bgp 100
[SPE1-bgp-default] peer 1.1.1.9 as-number 100
[SPE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-default] peer 3.3.3.9 as-number 100
[SPE1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp-default] address-family vpnv4
[SPE1-bgp-default-vpnv4] peer 3.3.3.9 enable
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 enable
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 upe
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 next-hop-local
[SPE1-bgp-default-vpnv4] quit
# Create BGP-VPN instances for VPN instances vpn1 and vpn2, so the VPNv4 routes learned according to the RT attributes can be added into the BGP routing tables of the corresponding VPN instances.
[SPE1-bgp-default] ip vpn-instance vpn1
[SPE1-bgp-default-vpn1] quit
[SPE1-bgp-default] ip vpn-instance vpn2
[SPE1-bgp-default-vpn2] quit
[SPE1-bgp-default] quit
# Advertise to UPE 1 the routes permitted by a routing policy (the routes of CE 3).
[SPE1] ip prefix-list hope index 10 permit 10.1.1.1 24
[SPE1] route-policy hope permit node 0
[SPE1-route-policy-hope-0] if-match ip address prefix-list hope
[SPE1-route-policy-hope-0] quit
[SPE1] bgp 100
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 upe route-policy hope export
8.     Configure SPE 2:
<SPE2> system-view
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
[SPE2] interface hundredgige 1/0/1
[SPE2-HundredGigE1/0/1] ip address 180.1.1.2 24
[SPE2-HundredGigE1/0/1] mpls enable
[SPE2-HundredGigE1/0/1] mpls ldp enable
[SPE2-HundredGigE1/0/1] quit
[SPE2] interface hundredgige 1/0/2
[SPE2-HundredGigE1/0/2] ip address 172.2.1.2 24
[SPE2-HundredGigE1/0/2] mpls enable
[SPE2-HundredGigE1/0/2] mpls ldp enable
[SPE2-HundredGigE1/0/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 1 and UPE 2, and specify UPE 2 as a UPE.
[SPE2] bgp 100
[SPE2-bgp-default] peer 4.4.4.9 as-number 100
[SPE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-default] peer 2.2.2.9 as-number 100
[SPE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp-default] address-family vpnv4
[SPE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 enable
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 upe
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 next-hop-local
[SPE2-bgp-default-vpnv4] quit
[SPE2-bgp-default] ip vpn-instance vpn1
[SPE2-bgp-default-vpn1] quit
[SPE2-bgp-default] ip vpn-instance vpn2
[SPE2-bgp-default-vpn2] quit
[SPE2-bgp-default] quit
# Advertise to UPE 2 the routes permitted by a routing policy (the routes of CE 1).
[SPE2] ip prefix-list hope index 10 permit 10.2.1.1 24
[SPE2] route-policy hope permit node 0
[SPE2-route-policy-hope-0] if-match ip address prefix-list hope
[SPE2-route-policy-hope-0] quit
[SPE2] bgp 100
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 upe route-policy hope export
# Verify that CE 1 and CE3 can learn each other's interface routes and can ping each other. CE 2 and CE 4 cannot learn each other's interface routes and cannot ping each other. (Details not shown.)
Example: Configuring an OSPF sham link
As shown in Figure 34, CE 1 and CE 2 belong to VPN 1. Configure an OSPF sham link between PE 1 and PE 2 so traffic between the CEs is forwarded through the MPLS backbone instead of the backdoor link.
Figure 34 Network diagram
Table 11 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
100.1.1.1/24
CE 2
HGE1/0/1
120.1.1.1/24
HGE1/0/4
20.1.1.1/24
HGE1/0/4
30.1.1.2/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
2.2.2.9/32
Loop1
3.3.3.3/32
Loop1
5.5.5.5/32
HGE1/0/1
100.1.1.2/24
HGE1/0/1
120.1.1.2/24
HGE1/0/4
10.1.1.1/24
HGE1/0/5
10.1.1.2/24
Router A
HGE1/0/5
30.1.1.1/24
HGE1/0/4
20.1.1.2/24
IMPORTANT
IMPORTANT:
1.     Configure OSPF on the customer networks:
# Configure conventional OSPF on CE 1, Router A, and CE 2 to advertise addresses of the interfaces (see Table 11). (Details not shown.)
# Set the cost value to 2 for both the link between CE 1 and Router A, and the link between CE 2 and Router A. (Details not shown.)
# Execute the display ip routing-table command to verify that CE 1 and CE 2 have learned the route to each other. (Details not shown.)
2.     Configure MPLS L3VPN on the backbone:
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] interface hundredgige 1/0/4
[PE1-HundredGigE1/0/4] ip address 10.1.1.1 24
[PE1-HundredGigE1/0/4] mpls enable
[PE1-HundredGigE1/0/4] mpls ldp enable
[PE1-HundredGigE1/0/4] quit
# Configure PE 1 to take PE 2 as an MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# Configure OSPF on PE 1.
[PE1]ospf 1
[PE1-ospf-1]area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface hundredgige 1/0/4
[PE2-HundredGigE1/0/4] ip address 10.1.1.2 24
[PE2-HundredGigE1/0/4] mpls enable
[PE2-HundredGigE1/0/4] mpls ldp enable
[PE2-HundredGigE1/0/4] quit
# Configure PE 2 to take PE 1 as an MP-IBGP peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface hundredgige 1/0/1
[PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/1] ip address 100.1.1.2 24
[PE1-HundredGigE1/0/1] quit
[PE1] ospf 100 vpn-instance vpn1
[PE1-ospf-100] domain-id 10
[PE1-ospf-100] area 1
[PE1-ospf-100-area-0.0.0.1] network 100.1.1.0 0.0.0.255
[PE1-ospf-100-area-0.0.0.1] quit
[PE1-ospf-100] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import-route ospf 100
[PE1-bgp-default-vpn1] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] quit
[PE2] interface hundredgige 1/0/1
[PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE2-HundredGigE1/0/1] ip address 120.1.1.2 24
[PE2-HundredGigE1/0/1] quit
[PE2] ospf 100 vpn-instance vpn1
[PE2-ospf-100] domain-id 10
[PE2-ospf-100] area 1
[PE2-ospf-100-area-0.0.0.1] network 120.1.1.0 0.0.0.255
[PE2-ospf-100-area-0.0.0.1] quit
[PE2-ospf-100] quit
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] import-route ospf 100
[PE2-bgp-default-ipv4-vpn1] import-route direct
# Execute the display ip routing-table vpn-instance command on the PEs. Verify that the path to the peer CE is along the OSPF route across the customer networks, instead of the BGP route across the backbone. (Details not shown.)
4.     Configure a sham link:
# Configure PE 1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ip address 3.3.3.3 32
[PE1-LoopBack1] quit
[PE1] ospf 100
[PE1-ospf-100-area-0.0.0.1] sham-link 3.3.3.3 5.5.5.5
[PE1-ospf-100] quit
# Configure PE 2.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ip address 5.5.5.5 32
[PE2-LoopBack1] quit
[PE2] ospf 100
[PE2-ospf-100-area-0.0.0.1] sham-link 5.5.5.5 3.3.3.3
[PE2-ospf-100] quit
# Execute the display ip routing-table vpn-instance command on the PEs to verify the following results (details not shown):
·     The path to the peer CE is now along the BGP route across the backbone.
·     A route to the sham link destination address exists.
# Execute the display ip routing-table command on the CEs. Verify that the next hop of the OSPF route to the peer CE is the interface connected to the PE (HundredGigE 1/0/1). This means that VPN traffic to the peer CE is forwarded over the backbone. (Details not shown.)
# Verify that a sham link has been established on PEs, for example, on PE 1.
[PE1] display ospf sham-link
          OSPF Process 100 with Router ID 100.1.1.2
                  Sham link
 Area            Neighbor ID     Source IP       Destination IP  State  Cost
 0.0.0.1         120.1.1.2       3.3.3.3         5.5.5.5         P-2-P  1
# Verify that the peer state is Full on PE 1.
[PE1] display ospf sham-link area 1
 Sham link: 3.3.3.3 --> 5.5.5.5
 Neighbor ID: 120.1.1.2        State: Full
 Area: 0.0.0.1
 Cost: 1  State: P-2-P  Type: Sham
 Request list: 0  Retransmit list: 0
Example: Configuring BGP AS number substitution
As shown in Figure 35, CE 1 and CE 2 belong to VPN 1 and are connected to PE 1 and PE 2, respectively. The two CEs have the same AS number, 600.
Configure BGP AS number substitution on the PEs to enable the CEs to communicate with each other.
Figure 35 Network diagram
Table 12 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
10.1.1.1/24
P
Loop0
2.2.2.9/32
HGE1/0/2
100.1.1.1/24
HGE1/0/1
20.1.1.2/24
PE 1
Loop0
1.1.1.9/32
HGE1/0/2
30.1.1.1/24
HGE1/0/1
10.1.1.2/24
PE 2
Loop0
3.3.3.9/32
HGE1/0/2
20.1.1.1/24
HGE1/0/1
10.2.1.2/24
CE 2
HGE1/0/1
10.2.1.1/24
HGE1/0/2
30.1.1.2/24
HGE1/0/2
200.1.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure basic MPLS L3VPN:
¡     Configure OSPF on the MPLS backbone to allow the PEs and P device to learn the routes of the loopback interfaces from each other.
¡     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
¡     Establish MP-IBGP peer relationship between the PEs to advertise VPN IPv4 routes.
¡     Configure the VPN instance of VPN 1 on PE 2 to allow CE 2 to access the network.
¡     Configure the VPN instance of VPN 1 on PE 1 to allow CE 1 to access the network.
¡     Configure BGP as the PE-CE routing protocol, and redistribute routes of CEs into PEs.
For more information about basic MPLS L3VPN configurations, see "Example: Configuring basic MPLS L3VPN."
# Execute the display ip routing-table command on CE 2. The output shows that CE 2 has learned the route to network 10.1.1.0/24, where the interface used by CE 1 to access PE 1 resides. However, it has not learned the route to the VPN (100.1.1.0/24) behind CE 1.
<CE2> display ip routing-table
Destinations : 15        Routes : 15
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         BGP    255  0            10.2.1.2        HGE1/0/1
10.2.1.0/24         Direct 0    0            10.2.1.1        HGE1/0/1
10.2.1.0/32         Direct 0    0            10.2.1.1        HGE1/0/1
10.2.1.1/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.1        HGE1/0/1
200.1.1.0/24        Direct 0    0            200.1.1.1       HGE1/0/2
200.1.1.0/32        Direct 0    0            200.1.1.1       HGE1/0/2
200.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
200.1.1.255/24      Direct 0    0            200.1.1.1       HGE1/0/2
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Execute the display ip routing-table command on CE 1 to verify that CE 1 has not learned the route to the VPN behind CE 2. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. This example uses PE 2.
<PE2> display ip routing-table vpn-instance vpn1
Destinations : 13        Routes : 13
10.1.1.0/24         BGP    255  0            1.1.1.9         HGE1/0/2
10.2.1.0/24         Direct 0    0            10.2.1.2        HGE1/0/1
10.2.1.0/32         Direct 0    0            10.2.1.2        HGE1/0/1
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.2        HGE1/0/1
100.1.1.0/24        BGP    255  0            1.1.1.9         HGE1/0/2
200.1.1.0/24        BGP    255  0            10.2.1.1        HGE1/0/1
# Enable BGP update packet debugging on PE 2. The output shows that PE 2 advertises the route to 100.1.1.0/24, and the AS_PATH is 100 600.
<PE2> terminal monitor
<PE2> terminal logging level 7
<PE2> debugging bgp update vpn-instance vpn1 10.2.1.1 ipv4
<PE2> refresh bgp all export ipv4 vpn-instance vpn1
*Jun 13 16:12:52:096 2012 PE2 BGP/7/DEBUG:
         BGP.vpn1: Send UPDATE to peer 10.2.1.1 for following destinations:
         Origin       : Incomplete
         AS Path      : 100 600
         Next Hop     : 10.2.1.2
         100.1.1.0/24,
# Execute the display bgp routing-table ipv4 peer received-routes command on CE 2 to verify that CE 2 has not received the route to 100.1.1.0/24.
<CE2> display bgp routing-table ipv4 peer 10.2.1.2 received-routes
 Total number of routes: 2
 BGP local router ID is 200.1.1.1
               a - additional-path
* >e 10.1.1.0/24        10.2.1.2                              0       100?
*  e 10.2.1.0/24        10.2.1.2        0                     0       100?
2.     Configure BGP AS number substitution on PE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.1 substitute-as
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[PE2-bgp-default-vpn1] quit
# The output shows that among the routes advertised by PE 2 to CE 2, the AS_PATH of 100.1.1.0/24 has changed from 100 600 to 100 100.
*Jun 13 16:15:59:456 2012 PE2 BGP/7/DEBUG:
         Origin       : Incomplete
         AS Path      : 100 100
         Next Hop     : 10.2.1.2
         100.1.1.0/24,
# Display again the routing information that CE 2 has received, and the routing table.
 Total number of routes: 3
               a - additional-path
* >e 100.1.1.0/24       10.2.1.2                              0       100 100?
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
100.1.1.0/24        BGP    255  0            10.2.1.2        HGE1/0/1
200.1.1.255/32      Direct 0    0            200.1.1.1       HGE1/0/2
# After you also configure BGP AS substitution on PE 1, verify that the GigabitEthernet interfaces of CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3, respectively.
CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
·     To avoid route loss, configure BGP AS number substitution on PEs.
·     To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 36 Network diagram
Table 13 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
100.1.1.1/32
CE 3
Loop0
200.1.1.1 /32
HGE1/0/1
10.1.1.1/24
HGE1/0/1
10.3.1.1/24
CE 2
HGE1/0/1
10.2.1.1/24
PE 2
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
HGE1/0/1
10.2.1.2/24
HGE1/0/1
10.1.1.2/24
HGE1/0/2
40.1.1.1/24
HGE1/0/2
20.1.1.1/24
HGE1/0/3
20.1.1.2/24
HGE1/0/3
30.1.1.1/24
P
Loop0
3.3.3.9/32
PE 3
Loop0
4.4.4.9/32
HGE1/0/1
30.1.1.2/24
HGE1/0/1
10.3.1.2/24
HGE1/0/2
40.1.1.2/24
HGE1/0/2
50.1.1.2/24
HGE1/0/3
50.1.1.1/24
IMPORTANT
IMPORTANT:
¡     Configure the VPN instance of VPN 1 on PE 3 to allow CE 3 to access the network.
2.     Configure BGP AS number substitution:
# Configure BGP AS number substitution on PE 1, PE 2, and PE 3. For more information about the configuration, see "Example: Configuring BGP AS number substitution."
# Display routing information on CE 2. The output shows that CE 2 has learned the route for 100.1.1.1/32 from CE 1. A routing loop has occurred because CE 1 and CE 2 reside in the same site.
Total number of routes: 6
 BGP local router ID is 1.1.1.9
               a - additional-path
*    10.2.1.0/24        10.2.1.2        0                     0       100?
*    10.2.1.1/32        10.2.1.2        0                     0       100?
* >e 10.3.1.0/24        10.2.1.2                              0       100?
* >e 100.1.1.1/32       10.2.1.2                              0       100 100?
* >e 200.1.1.1/32       10.2.1.2                              0       100 100?
3.     Configure BGP SoO attribute:
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
<PE1> system-view
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 soo 1:100
# PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured for the CEs. Display the routing table of CE 2. The output shows that the route 100.1.1.1/32 has been removed.
10.2.1.1/32         Direct 0    0            127.0.0.1       Inloop0
10.3.1.0/24         BGP    255  0            10.2.1.2        HGE1/0/1
200.1.1.1/32        BGP    255  0            10.2.1.2        HGE1/0/1
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for a VPNv4 route
Configure EBGP between CEs and PEs to exchange VPN routes.
Configure OSPF to ensure connectivity between PEs, and configure MP-IBGP to exchange VPNv4 routing information between PEs.
Configure MPLS L3VPN FRR on PE 1 to achieve the following purposes:
·     When the link PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2.
·     When BFD detects that the LSP between PE 1 and PE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 3—CE 2.
Figure 37 Network diagram
Table 14 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
5.5.5.5/32
PE 1
Loop0
1.1.1.1/32
HGE1/0/1
10.2.1.1/24
HGE1/0/1
10.2.1.2/24
PE 2
Loop0
2.2.2.2/32
HGE1/0/2
172.1.1.1/24
HGE1/0/1
172.1.1.2/24
HGE1/0/3
172.2.1.1/24
HGE1/0/2
10.1.1.2/24
CE 2
Loop0
4.4.4.4/32
PE 3
Loop0
3.3.3.3/32
HGE1/0/1
10.1.1.1/24
HGE1/0/1
172.2.1.3/24
HGE1/0/2
10.3.1.1/24
HGE1/0/2
10.3.1.2/24
IMPORTANT
IMPORTANT:
1.     Configure IP addresses and masks for interfaces as shown in Table 14, and configure BGP and MPLS L3VPN. (Details not shown.)
For more information about configuring basic MPLS L3VPN, see "Example: Configuring basic MPLS L3VPN."
2.     Configure MPLS L3VPN FRR on PE 1:
# Configure BFD to test the connectivity of the LSP to 2.2.2.2/32.
<PE1> system-view
[PE1] mpls bfd enable
[PE1] mpls bfd 2.2.2.2 32
# Create routing policy frr, and specify the backup next hop as 3.3.3.3 for the route to 4.4.4.4/32.
[PE1] ip prefix-list abc index 10 permit 4.4.4.4 32
[PE1] route-policy frr permit node 10
[PE1-route-policy] if-match ip address prefix-list abc
[PE1-route-policy] apply fast-reroute backup-nexthop 3.3.3.3
[PE1-route-policy] quit
# Configure FRR for VPN instance vpn1 to use routing policy frr.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] fast-reroute route-policy frr
# Specify the preferred value as 100 for routes received from PE 2. This value is greater than the preferred value (0) for routes from PE 3, so PE 1 prefers the routes from PE 2.
[PE1-bgp-default-vpnv4] peer 2.2.2.2 preferred-value 100
3.     Enable MPLS BFD on PE 2.
<PE2> system-view
[PE2] mpls bfd enable
# Display detailed information about the route to 4.4.4.4/32 on PE 1. The output shows the backup next hop for the route.
[PE1] display ip routing-table vpn-instance vpn1 4.4.4.4 32 verbose
Summary Count : 1
Destination: 4.4.4.4/32
   Protocol: BGP
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m03s
       Cost: 0               Preference: 255
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x102               OrigAs: 300
      NibID: 0x15000002          LastAs: 300
     AttrID: 0x2               Neighbor: 2.2.2.2
      Flags: 0x110060       OrigNextHop: 2.2.2.2
      Label: 1146           RealNextHop: 172.1.1.2
    BkLabel: 1275             BkNextHop: 172.2.1.3
    SRLabel: NULL             BkSRLabel: NULL
   SIDIndex: NULL               InLabel: NULL
  Tunnel ID: 0x401            Interface: HGE1/0/2
BkTunnel ID: 0x409          BkInterface: HGE1/0/3
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for an IPv4 route
Configure MPLS L3VPN FRR on PE 2 to achieve the following purposes:
·     When the link PE 2—CE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2.
·     When BFD detects that the link between PE 2 and CE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—PE 3—CE 2.
Figure 38 Network diagram
Table 15 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
5.5.5.5/32
PE 2
Loop0
2.2.2.2/32
HGE1/0/1
10.2.1.1/24
HGE1/0/1
172.1.1.2/24
PE 1
Loop0
1.1.1.1/32
HGE1/0/2
10.1.1.2/24
HGE1/0/1
10.2.1.2/24
HGE1/0/3
172.3.1.2/24
HGE1/0/2
172.1.1.1/24
PE 3
Loop0
3.3.3.3/32
HGE1/0/3
172.2.1.1/24
HGE1/0/1
172.2.1.3/24
CE 2
Loop0
4.4.4.4/32
HGE1/0/2
10.3.1.2/24
HGE1/0/1
10.1.1.1/24
HGE1/0/3
172.3.1.3/24
HGE1/0/2
10.3.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure IP addresses and masks for interfaces as shown in Table 15, and configure BGP and MPLS L3VPN. (Details not shown.)
2.     Configure MPLS L3VPN FRR on PE 2:
# Configure the source IP address of BFD echo packets as 12.1.1.1.
<PE2> system-view
[PE2] bfd echo-source-ip 12.1.1.1
[PE2] ip prefix-list abc index 10 permit 4.4.4.4 32
[PE2] route-policy frr permit node 10
[PE2-route-policy] if-match ip address prefix-list abc
[PE2-route-policy] apply fast-reroute backup-nexthop 3.3.3.3
[PE2-route-policy] quit
# Use echo-mode BFD to detect the primary route connectivity.
[PE2] bgp 100
[PE2-bgp-default] primary-path-detect bfd echo
[PE2-bgp-default-ipv4-vpn1] fast-reroute route-policy frr
# Specify the preferred value as 200 for BGP routes received from CE 2. This value is greater than the preferred value (0) for routes from PE 3, so PE 2 prefers the routes from CE 2.
[PE2-bgp-default-ipv4-vpn1] peer 10.1.1.1 preferred-value 200
# Display detailed information about the route to 4.4.4.4/32 on PE 2. The output shows the backup next hop for the route.
[PE2] display ip routing-table vpn-instance vpn1 4.4.4.4 32 verbose
Summary Count : 1
   Protocol: BGP
 Process ID: 0
  SubProtID: 0x2                    Age: 01h54m24s
       Cost: 0               Preference: 10
  OrigTblID: 0x0                OrigVrf: vpn1
     AttrID: 0x0               Neighbor: 10.1.1.1
      Flags: 0x10060        OrigNextHop: 10.1.1.1
      Label: NULL           RealNextHop: 10.1.1.1
    BkLabel: 1275             BkNextHop: 172.3.1.3
  Tunnel ID: Invalid          Interface: HGE1/0/2
  Connector: N/A
Example: Configuring MPLS L3VPN FRR through IPv4 route backup for a VPNv4 route
·     When BFD detects that the link between PE 1 and PE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—CE 2.
Figure 39 Network diagram
Table 16 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
5.5.5.5/32
CE 2
Loop0
4.4.4.4/32
HGE1/0/1
10.2.1.1/24
HGE1/0/1
10.1.1.1/24
PE 1
Loop0
1.1.1.1/32
HGE1/0/2
10.3.1.1/24
HGE1/0/1
10.2.1.2/24
PE 2
Loop0
2.2.2.2/32
HGE1/0/2
10.1.1.2/24
HGE1/0/2
10.3.1.2/24
HGE1/0/3
172.2.1.1/24
HGE1/0/3
172.2.1.2/24
IMPORTANT
IMPORTANT:
1.     Configure IP addresses and masks for interfaces as shown in Table 16, and configure BGP and MPLS L3VPN. (Details not shown.)
<PE1> system-view
# Create routing policy frr, and specify the backup next hop as 10.1.1.1 for the route to 4.4.4.4/32.
[PE1-route-policy] apply fast-reroute backup-nexthop 10.1.1.1
[PE1] bgp 100
# Specify the preferred value as 200 for BGP VPNv4 routes received from PE 2. This value is greater than the preferred value (0) for IPv4 unicast routes from CE 2, so PE 1 prefers the routes from PE 2.
[PE1-bgp-default-vpnv4] peer 2.2.2.2 preferred-value 200
<PE2> system-view
Summary Count : 1
   Protocol: BGP
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m04s
      NibID: 0x15000004          LastAs: 300
     AttrID: 0x1               Neighbor: 2.2.2.2
      Label: 1275           RealNextHop: 172.2.1.2
    BkLabel: NULL             BkNextHop: 10.1.1.1
  Tunnel ID: 0x409            Interface: HGE1/0/3
BkTunnel ID: Invalid        BkInterface: HGE1/0/2
Configuring IPv6 MPLS L3VPN
About IPv6 MPLS L3VPN
IPv6 MPLS L3VPN uses BGP to advertise IPv6 VPN routes and uses MPLS to forward IPv6 VPN packets on the service provider backbone.
IPv6 MPLS L3VPN network diagram
Figure 40 shows a typical IPv6 MPLS L3VPN model. The service provider backbone in the IPv6 MPLS L3VPN model is an IPv4 network. IPv6 runs inside the VPNs and between CE and PE. Therefore, PEs must support both IPv4 and IPv6. The PE-CE interfaces of a PE run IPv6, and the PE-P interface of a PE runs IPv4.
Figure 40 Network diagram for the IPv6 MPLS L3VPN model
IPv6 MPLS L3VPN packet forwarding
As shown in Figure 41, the IPv6 MPLS L3VPN packet forwarding procedure is as follows:
1.     The PC at Site 1 sends an IPv6 packet destined for 2001:2::1, the PC at Site 2. CE 1 transmits the packet to PE 1.
2.     Based on the inbound interface and destination address of the packet, PE 1 finds a matching entry from the routing table of the VPN instance, labels the packet with both a private network label (inner label) and a public network label (outer label), and forwards the packet out.
3.     The MPLS backbone transmits the packet to PE 2 by outer label. The outer label is removed from the packet at the penultimate hop.
4.     According to the inner label and destination address of the packet, PE 2 searches the routing table of the VPN instance to determine the outbound interface, and then forwards the packet out of the interface to CE 2.
5.     CE 2 forwards the packet to the destination by IPv6 forwarding.
Figure 41 IPv6 MPLS L3VPN packet forwarding diagram
IPv6 MPLS L3VPN routing information advertisement
The routing information is advertised through the path local CE—ingress PE—egress PE—remote CE.
Routing information advertisement from the local CE to the ingress PE.
The local CE advertises standard IPv6 routing information to the ingress PE over an IPv6 static route, RIPng route, OSPFv3 route, IPv6 IS-IS route, IBGP route, or EBGP route.
Routing information advertisement from the ingress PE to the egress PE.
After receiving the standard IPv6 routes from the CE, the ingress PE performs the following operations:
1.     Adds RDs and route targets to create VPN-IPv6 routes.
2.     Saves the routes to the routing table of the VPN instance created for the CE.
3.     Assigns VPN labels for the routes.
4.     Advertises the VPN-IPv6 routes to the egress PE through MP-BGP.
The egress PE performs the following operations:
1.     Compares the export target attributes of the VPN-IPv6 routes with the import target attributes that it maintains for the VPN instance.
2.     Adds the routes to the routing table of the VPN instance if the export and import target attributes are the same.
The PEs use an IGP to ensure the connectivity between them.
Routing information advertisement from the egress PE to the remote peer CE.
The egress PE restores the original IPv6 routes and advertises them to the remote CE over an IPv6 static route, RIPng route, OSPFv3 route, IPv6 IS-IS route, EBGP, or IBGP route.
IPv6 MPLS L3VPN network schemes and features
IPv6 MPLS L3VPN supports the following network schemes and features:
·     Basic VPN.
·     Inter-AS VPN option A.
·     Inter-AS VPN option B.
·     Inter-AS VPN option C.
·     Carrier's carrier.
·     HoVPN.
·     IPv6 MPLS FRR.
·     OSPFv3 VPN extension. (OSPFv3 Type 3, Type 5, and Type 7 LSAs support the DN bit. By default, OSPFv3 VPN extension uses the DN bit to avoid routing loops.)
·     BGP AS number substitution and SoO.
Protocols and standards
·     RFC 4659, BGP-MPLS IP Virtual Private Network (VPN) Extension for IPv6 VPN
·     RFC 6565, OSPFv3 as a Provider Edge to Customer Edge (PE-CE) Routing Protocol
IPv6 MPLS L3VPN tasks at a glance
Unless otherwise indicated, configure IPv6 MPLS L3VPN on PEs.
To configure IPv6 MPLS L3VPN, perform the following tasks:
1.     (Optional.) Configuring the hardware resource allocation mode
2.     Configuring IPv6 MPLS L3VPN basics:
a.     Configuring VPN instances
b.     Configuring routing between a PE and a CE
c.     Configuring routing between PEs
d.     (Optional.) Configuring BGP VPNv6 route control
3.     Configuring advanced IPv6 MPLS L3VPN networks
¡     Configuring inter-AS IPv6 VPN
Perform this task when sites of a VPN are connected to different ASs of an ISP.
4.     (Optional.) Configuring IPv6 MPLS L3VPN FRR
5.     (Optional.) Controlling MPLS L3VPN route advertisement and reception
¡     Configuring an OSPFv3 sham link
¡     Configuring BGP AS number substitution and SoO attribute
¡     Configuring the AIGP attribute
¡     Configuring the BGP additional path feature
¡     Configuring route replication
¡     Configuring BGP route replication between public and VPN instances
Perform this task to enable mutual replication of BGP routes between public and VPN instances so that the public and VPN instances can communicate with each other.
¡     Enabling prioritized withdrawal of specific routes
6.     (Optional.) Enabling logging for BGP route flapping
Prerequisites for IPv6 MPLS L3VPN
Before configuring IPv6 MPLS L3VPN, perform the following tasks:
1.     Configure an IGP on the PEs and P devices to ensure IP connectivity within the MPLS backbone.
2.     Configure basic MPLS for the MPLS backbone.
3.     Configure MPLS LDP on PEs and P devices to establish LDP LSPs.
VPNv6 ECMP routes consume hardware resources of the device. If the hardware resources are insufficient, packet forwarding might fail. To address this issue, perform this task to configure the hardware resource allocation mode. As a best practice, use the enhanced hardware resource allocation mode if many VPNv6 ECMP routes exist.
2.     Configure the hardware resource allocation mode.
hardware-resource mpls { l3vpn | normal }
By default, the normal hardware resource allocation mode is used
Creating a VPN instance
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
If you configure an RD for a VPN instance, all address families in the VPN instance must use the same RD as the VPN instance.
If you do not configure an RD for a VPN instance, address families in the VPN instance can use different RDs.
To configure an RD for a VPN instance, make sure either of the following conditions exists:
·     No RDs have been configured for address families in the VPN instance.
In this case, the RD of the VPN instance will be synchronized to all address families in the VPN instance.
·     All address families in the VPN instance use the same RD.
In this case, you must configure the same RD as the address families for the VPN instance.
When you remove the RD from an address family, the RD will also be removed from the VPN instance of the address family.
2.     Set an MPLS label range for all VPN instances.
mpls per-vrf-label range minimum maximum
By default, no MPLS label range is configured for VPN instances.
3.     Create a VPN instance and enter VPN instance view.
4.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
5.     (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
6.     (Optional.) Set an ID for the VPN instance.
vpn-id vpn-id
By default, no ID is configured for a VPN instance.
7.     (Optional.) Configure an SNMP context for the VPN instance.
By default, no SNMP context is configured.
8.     Enter VPN instance IPv6 address family view.
address-family ipv6
9.     Configure an RD.
By default, no RD is configured.
10.     Specify a label allocation mode.
apply-label { per-instance [ static static-label-value ] | per-route }
By default, BGP allocates a label to each next hop.
Associating a VPN instance with a Layer 3 interface
If an interface is associated with a VSI or cross-connect, the interface (including its subinterfaces) cannot associate with a VPN instance.
If a subinterface is associated with a VSI or cross-connect, the subinterface cannot associate with a VPN instance.
2.     Enter interface view.
3.     Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and belongs to the public network.
The ip binding vpn-instance command clears the IPv6 address of the interface. Therefore, reconfigure an IPv6 address for the interface after configuring this command.
Configuring route related attributes for a VPN instance
Configurations made in VPN instance view apply to both IPv4 VPN and IPv6 VPN.
IPv6 VPN prefers the configurations in VPN instance IPv6 address family view over the configurations in VPN instance view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2.     Enter VPN instance view or VPN instance IPv6 address family view.
¡     Enter VPN instance view.
¡     Execute the following commands in sequence to enter VPN instance IPv6 address family view:
address-family ipv6
3.     Configure route targets.
By default, no route targets are configured.
4.     Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the PE from storing too many routes.
5.     Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6.     Apply an export routing policy.
By default, routes to be advertised are not filtered.
7.     Apply a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, only one tunnel is selected (no load balancing) in this order: LSP tunnel, CRLSP tunnel, and SRLSP tunnel.
If the specified tunnel policy does not exist, the default tunnel policy is used.
For information about tunnel policies, see "Configuring tunnel policies."
Configuring IPv6 static routing between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common IPv6 static route.
For more information about IPv6 static routing, see Layer 3—IP Routing Configuration Guide.
2.     Configure an IPv6 static route for a VPN instance.
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name nexthop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
Configuring RIPng between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common RIPng process.
For more information about RIPng, see Layer 3—IP Routing Configuration Guide.
2.     Create a RIPng process for a VPN instance and enter RIPng view.
ripng [ process-id ] vpn-instance vpn-instance-name
A RIPng process can belong to only one VPN instance.
3.     Return to system view.
4.     Enter interface view.
5.     Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled on an interface.
Configuring OSPFv3 between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common OSPFv3 process.
For more information about OSPFv3, see Layer 3—IP Routing Configuration Guide.
2.     Create an OSPFv3 process for a VPN instance and enter OSPFv3 view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
An OSPFv3 process can belong to only one VPN instance.
Deleting a VPN instance also deletes all related OSPFv3 processes.
3.     Set the router ID.
router-id router-id
4.     Redistribute BGP routes.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPFv3 does not redistribute routes from other routing protocols.
If the vpn-instance-capability simple command is not configured for the OSPFv3 process, the allow-ibgp keyword is optional to redistribute VPNv6 routes learned from MP-IBGP peers. In any other cases, if you do not specify the allow-ibgp keyword, the OSPFv3 process does not redistribute VPNv6 routes learned from MP-IBGP peers.
5.     (Optional.) Configure OSPFv3 route attributes:
a.     Set an OSPFv3 domain ID.
domain-id { domain-id [ secondary ] | null }
The default domain ID is 0.
When you redistribute OSPFv3 routes into BGP, BGP adds the primary domain ID to the redistributed BGP routes as a BGP extended community attribute.
You can configure the same domain ID for different OSPFv3 processes.
You must configure the same domain ID for all OSPFv3 processes of the same VPN to ensure correct route advertisement.
b.     Configure the type code of an OSPFv3 extended community attribute.
ext-community-type { domain-id type-code1 | route-type type-code2 | router-id type-code3 }
By default, the type codes for domain ID, route type, and router ID are 0x0005, 0x0306, 0x0107, respectively.
c.     Configure an external route tag for redistributed VPN routes.
route-tag tag-value
By default, if BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000. The last two octets are the local BGP AS number. If the AS number is greater than 65535, the external route tag is 0.
d.     Disable setting the DN bit in OSPFv3 LSAs.
disable-dn-bit-set
By default, when a PE redistributes BGP routes into OSPFv3 and creates OSPFv3 LSAs, it sets the DN bit for the LSAs.
This command might cause routing loops. Use it with caution.
e.     Ignore the DN bit in OSPFv3 LSAs.
disable-dn-bit-check
By default, the PE checks the DN bit in OSPFv3 LSAs.
f.     Enable the external route check feature for OSPFv3 LSAs.
route-tag-check enable
By default, the PE does not check the external route tag but checks the DN bit in OSPFv3 LSAs to avoid routing loops.
This command is only for backward compatibility with the old protocol (RFC 4577).
g.     Return to system view.
6.     Enter interface view.
7.     Enable OSPFv3 on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
By default, OSPFv3 is disabled on an interface.
For the command to be executed successfully, make sure the VPN instance to which the OSPFv3 process belongs is the VPN instance bound to the interface.
Configuring IPv6 IS-IS between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common IPv6 IS-IS process.
For more information about IPv6 IS-IS, see Layer 3—IP Routing Configuration Guide.
2.     Create an IPv6 IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IPv6 IS-IS process can belong to only one VPN instance.
3.     Configure a network entity title for the IS-IS process.
network-entity net
By default, no NET is configured.
4.     Create the IS-IS IPv6 unicast address family and enter its view.
5.     Return to system view.
7.     Enable IPv6 for the IS-IS process on the interface.
isis ipv6 enable [ process-id ]
By default, IPv6 is disabled for the IS-IS process on the interface.
Configuring EBGP between a PE and a CE
Restrictions and guidelines configuring EBGP between a PE and a CE
After you edit or delete the RD in VPN instance view or VPN instance IPv6 address family view, the device automatically deletes the BGP-VPN IPv6 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured EBGP between a PE and a CE.
Configuring the PE
2.     Enable a BGP instance and enter BGP instance view.
By default, BGP is not enabled.
3.     Enter BGP-VPN instance view.
4.     Configure the CE as the VPN EBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
5.     Create the BGP-VPN IPv6 unicast address family and enter its view.
Configuration commands in BGP-VPN IPv6 unicast address family view are the same as those in BGP IPv6 unicast address family view. For more information, see BGP in Layer 3—IP Routing Configuration Guide.
6.     Enable IPv6 unicast route exchange with the specified peer.
peer { group-name | ip-address [ prefix-length ] } enable
By default, BGP does not exchange IPv6 unicast routes with a peer.
7.     Redistribute the routes of the local CE.
A PE must redistribute the routes of the local CE into its VPN routing table so that it can advertise them to the peer PE.
8.     (Optional.) Allow the local AS number to appear in the AS_PATH attribute of a received route, and set the maximum number of repetitions.
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
By default, BGP discards incoming route updates that contain the local AS number.
Execute this command in a hub-spoke network where EBGP is running between a PE and a CE to enable the PE to receive the route updates from the CE.
Configuring the CE
3.     Configure the PE as an EBGP peer.
4.     Create the BGP IPv6 unicast address family and enter its view.
5.     Enable IPv6 unicast route exchange with the specified peer.
6.     Configure route redistribution.
A CE must advertise its VPN routes to the connected PE so that the PE can advertise them to the peer CE.
Configuring IBGP between a PE and a CE
Restrictions and guidelines configuring IBGP between a PE and a CE
Use IBGP between PE and CE only in a basic IPv6 MPLS L3VPN network. In networks such as inter-AS VPN and carrier's carrier, you cannot configure IBGP between PE and CE.
After you edit or delete the RD in VPN instance view or VPN instance IPv6 address family view, the device automatically deletes the BGP-VPN IPv6 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured IBGP between a PE and a CE.
Configuring the PE
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
4.     Configure the CE as the VPN IBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } enable
7.     Configure the CE as a client of the RR to enable the PE to advertise routes learned from the IBGP peer CE to other IBGP peers.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
By default, no RR or RR client is configured.
Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side.
8.     (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
9.     (Optional.) Configure the cluster ID for the RR.
By default, the RR uses its own router ID as the cluster ID.
If multiple RRs exist in a cluster, use this command to configure the same cluster ID for all RRs in the cluster to avoid routing loops.
Configuring the CE
3.     Configure the PE as an IBGP peer.
4.     Create the BGP IPv6 unicast family and enter its view.
A CE must redistribute its routes to the PE so the PE can advertise them to the peer CE.
3.     Configure the remote PE as the peer.
4.     Specify the source interface for TCP connections.
By default, BGP uses the outbound interface of the best route to the BGP peer as the source interface.
5.     Create the BGP VPNv6 address family and enter its view.
address-family vpnv6
6.     Enable BGP VPNv6 route exchange with the specified peer.
By default, BGP does not exchange BGP VPNv6 routes with any peer.
About BGP VPNv6 route control
BGP VPNv6 route control is configured similarly with BGP route control, except that it is configured in BGP VPNv6 address family view. For more information about BGP route control, see Layer 3—IP Routing Configuration Guide.
Specifying a preferred value for BGP VPNv6 routes
3.     Enter BGP VPNv6 address family view.
4.     Specify a preferred value for routes received from a peer or peer group.
The default preferred value is 0.
Setting the maximum number of received routes
4.     Set the maximum number of routes BGP can receive from a peer or peer group.
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
Configuring BGP VPNv6 route reflection
To ensure the connectivity of IBGP peers, you must establish full-mesh IBGP connections, which costs massive network and CPU resources.
To reduce IBGP connections in the network, you can configure a device as a route reflector (RR) and configure other devices as its clients. You only need to establish IBGP connections between the RR and its clients to enable the RR to forward routes to the clients.
4.     Configure the local PE as the RR and specify the peer as the client.
By default, no RR or client is configured.
5.     (Optional.) Enable route reflection between clients.
6.     (Optional.) Configure a cluster ID for the RR.
By default, an RR uses its own router ID as the cluster ID.
7.     (Optional.) Configure a filtering policy for reflected routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected routes.
Only IBGP routes whose extended community attribute matches the specified community list are reflected.
By configuring different filtering policies on RRs, you can implement load balancing among the RRs.
8.     (Optional.) Allow the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, RR cannot change the attributes of routes to be reflected.
9.     (Optional.) Specify a peer or peer group as a client of the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any clients.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
Configuring BGP VPNv6 route attributes
4.     Configure the NEXT_HOP attribute.
¡     Set the device as the next hop for routes sent to a peer or peer group.
¡     Configure the device to not change the next hop of routes advertised to a peer or peer group.
By default, the device uses its address as the next hop of routes advertised to peers.
On an RR in an inter-AS option C scenario, you must configure this command to not change the next hop of VPNv6 routes advertised to BGP peers and RR clients.
5.     Configure the AS_PATH attribute.
¡     Allow the local AS number to appear in the AS_PATH attribute of routes received from a peer or peer group and set the maximum number of repetitions.
By default, BGP discards route updates that contain the local AS number.
¡     Remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
6.     Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to any peers or peer groups.
7.     Configure the SoO attribute for a peer for peer group.
By default, the SoO attribute is not configured.
8.     Configure BGP to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
Configuring BGP VPNv6 route filtering
4.     Filter advertised routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-name } export [ protocol process-id ]
By default, BGP does not filter advertised routes.
5.     Filter received routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-name } import
By default, BGP does not filter received routes.
6.     Configure AS_PATH list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, AS_PATH list-based route filtering is not configured.
7.     Configure ACL-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
By default, ACL-based route filtering is not configured.
8.     Configure IPv6 prefix list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-name { export | import }
By default, IPv6 prefix list-based route filtering is not configured.
9.     Apply a routing policy to routes advertised to or received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policy is applied.
10.     Enable route target filtering for received BGP VPNv6 routes.
policy vpn-target
By default, route target filtering is enabled for received VPNv6 routes. Only VPNv6 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
Configuring BGP VPNv6 optimal route selection delay
4.     Set the BGP VPNv6 optimal route selection delay timer.
By default, the BGP VPNv6 optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Setting the delay time for responding to BGP VPNv6 recursive next hop changes
address-family vpnv3
4.     Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
Configuring BGP VPNv6 routes to use private network next hops
By default, the device does not change the next hop attribute of a received BGP VPNv6 route. The next hop address of a BGP VPNv6 route is a public address. This feature changes the next hop of a BGP VPNv6 route received from a peer or peer group to an IP address in the VPN instance. The outgoing label of the VPNv6 route is also changed to an invalid value. For example, the device received a VPNv6 route and its next hop address is 10.1.1.1, which is a public address by default. After this feature is configured, the next hop address changes to private address 10.1.1.1.
After you configure this feature, the following applies:
·     The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
·     The device receives a BGP VPNv6 route only when its RD is the same as a local RD.
·     When advertising a BGP VPNv6 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
·     If you delete a VPN instance or its RD, BGP VPNv6 routes received from the specified peer or peer group and in the VPN instance will be deleted.
4.     Change the next hop of a BGP VPNv6 route received from a peer or peer group to a VPN instance address.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
By default, the device does not change the next hop attribute of a received BGP VPNv6 route, and the next hop belongs to the public network.
Configuring inter-AS IPv6 VPN option A
Inter-AS IPv6 VPN option A applies to scenarios where the number of VPNs and that of VPN routes on the PEs are relatively small.
To configure inter-AS IPv6 option A, perform the following tasks:
·     Configure basic IPv6 MPLS L3VPN on each AS.
·     Configure VPN instances on both PEs and ASBRs. The VPN instances on PEs allow CEs to access the network, and those on ASBRs are for access of the peer ASBRs.
In the inter-AS IPv6 VPN option A solution, for the same IPv6 VPN, the route targets configured on the PEs must match those configured on the ASBRs in the same AS. This makes sure VPN routes sent by the PEs (or ASBRs) can be received by the ASBRs (or PEs). Route targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS IPv6 VPN option B
An ASBR always uses its address as the next hop of VPNv6 routes advertised to an MP-IBGP peer regardless of the configuration of the peer next-hop-local command.
Configuring a PE
Configure basic IPv6 MPLS L3VPN, and specify the ASBR in the same AS as an MP-IBGP peer. The route targets for the VPN instances on the PEs in different ASs must match for the same IPv6 VPN.
Configuring an ASBR
2.     Enable MPLS and LDP on the interface connected to an internal device of the AS:
a.     Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
b.     Enable LDP on the local LSR and enter LDP view.
mpls ldp
By default, LDP is disabled.
c.     Return to system view.
d.     Enter interface view of the interface connected to an internal device of the AS.
e.     Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
f.     Enable MPLS LDP on the interface.
mpls ldp enable
By default, MPLS LDP is disabled on the interface.
3.     Enable MPLS on the interface connected to the remote ASBR:
a.     Enter interface view of the interface connected to the remote ASBR.
b.     Enable MPLS on the interface.
mpls enable
4.     Enter BGP instance view.
5.     Configure PEs in the same AS as IBGP peers and ASBRs in different ASs as EBGP peers.
6.     Enter BGP VPNv6 address family view.
7.     Enable BGP to exchange VPNv6 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange VPNv6 routing information with a peer.
8.     Disable route target filtering of received VPNv6 routes.
undo policy vpn-target
Configuring inter-AS IPv6 VPN option C (method 1)
Before you configure inter-AS option C, perform the following tasks:
·     Configure BGP on the PE or ASBR to advertise the route to the PE. For more information, see BGP configuration in Layer 3—IP Routing Configuration Guide.
·     Configure a VPN instance on the PE.
·     Configure routing between the PE and CE.
Configuring a PE
3.     Configure the ASBR in the same AS as an IBGP peer and the PE in another AS as an EBGP peer
4.     Enter BGP IPv4 unicast address family view.
5.     Enable BGP to exchange BGP IPv4 unicast routes with the ASBR in the same AS.
By default, the PE does not exchange BGP IPv4 unicast routes with any peer.
6.     Enable BGP to exchange labeled routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, the PE does not advertise labeled routes to any IPv4 peer or peer group.
After you execute this command, BGP exchanges both labeled and unlabeled IPv4 unicast routes with the peer.
7.     (Optional.) Configure BGP to exchange only labeled routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-only
By default, BGP can exchange unlabeled routes with a peer.
After you execute this command, BGP exchanges only labeled IPv4 unicast routes with the peer.
8.     Return to BGP instance view.
9.     Enter BGP VPNv6 address family view.
10.     Enable BGP to exchange BGP VPNv6 routing information with the EBGP peer.
By default, the PE does not exchange labeled routes with an IPv4 peer.
11.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
Execute this command on the RR so the RR does not change the next hop of advertised VPNv6 routes.
Configuring an ASBR-PE
2.     Configure a routing policy:
a.     Create a routing policy, and enter routing policy view.
b.     Match IPv4 routes carrying labels.
if-match mpls-label
By default, no MPLS label match criterion is configured.
You can configure if-match clauses in the routing policy to filter routes. Routes surviving the filtering are assigned labels, and all others are advertised as common IPv4 routes.
c.     Set labels for IPv4 routes.
apply mpls-label
By default, no MPLS label is set for IPv4 routes.
d.     Return to system view.
3.     Enable MPLS and LDP on the interface connected to an internal device of the AS:
mpls lsr-id lsr-id
By default, no LSR
b.     Enable LDP for the local LSR and enter LDP view.
mpls ldp
mpls enable
mpls ldp enable
4.     Enable MPLS on the interface connected to the remote ASBR:
mpls enable
5.     Enter BGP instance view.
6.     Configure the PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
7.     Create the BGP IPv4 unicast address family and enter its view.
8.     Enable IPv4 unicast route exchange with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with any peer.
9.     Enable labeled IPv4 route exchange with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with any peer.
10.     (Optional.) Configure BGP to exchange only labeled routes with the PE in the same AS and the ASBR in another AS..
11.     Configure the ASBR to set itself as the next hop of routes advertised to the PE in the local AS.
By default, BGP does not use its address as the next hop of routes.
12.     Apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Configuring inter-AS IPv6 VPN option C (method 2)
Before you configure inter-AS option C (method 2), perform the following tasks:
Configuring a PE
3.     Configure the PE in another AS as an EBGP peer.
4.     Enter BGP VPNv6 address family view.
5.     Enable BGP to exchange BGP VPNv6 routing information with the EBGP peer.
By default, the PE does not exchange VPNv6 routes with a peer.
6.     (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
if-match mpls-label
apply mpls-label
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
6.     Configure the ASBR in another AS as an EBGP peer.
8.     Enable IPv4 unicast route exchange with the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with a peer.
9.     Enable labeled IPv4 route exchange with the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with a peer.
10.     (Optional.) Configure BGP to exchange only labeled routes with the ASBR in another AS.
By default, BGP does not use its address as the next hop of routes advertised to IBGP peers and peer groups.
Configuring HoVPN
Configuring the UPE
Configure basic MPLS L3VPN settings on the UPE.
Configuring the SPE
3.     Specify a BGP peer or peer group.
5.     Enable BGP VPNv4 route exchange with the peer or peer group.
By default, BGP does not exchange VPNv4 routes with any peer.
6.     Specify the BGP peer or peer group as a UPE.
peer { group-name | ipv4-address [ mask-length ] } upe
By default, no peer is a UPE.
7.     Advertise routes to the UPE.
¡     Advertise a default VPN route to the UPE.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
The device advertises a default route using the local address as the next hop to the UPE, regardless of whether the default route exists in the local routing table.
¡     Advertise routes permitted by a routing policy to the UPE.
peer { group-name | ipv4-address [ mask-length ] } upe route-policy route-policy-name export
By default, no route is advertised to the UPE.
Do not execute both commands.
9.     Create a BGP-VPN instance and enter BGP-VPN instance view.
You do not need to associate the VPN instance to an interface on the SPE.
This step adds the learned VPNv4 routes to the BGP routing table of the VPN instance.
About IPv6 MPLS L3VPN FRR
You can use the following methods to configure IPv6 MPLS L3VPN FRR:
·     Method 1—Execute the pic command in BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view. The device calculates a backup next hop for each BGP route in the VPN instance if there are two or more unequal-cost routes to reach the destination.
·     Method 2—Execute the fast-reroute route-policy command in BGP-VPN IPv6 unicast address family view to use a routing policy. In the routing policy, specify a backup next hop by using the apply fast-reroute backup-nexthop command. The backup next hop calculated by the device must be the same as the specified backup next hop. Otherwise, the device does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
Executing the pic command in BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view might cause routing loops. Use it with caution.
Configuring FRR by using a routing policy
2.     Configure BFD.
¡     Enable MPLS BFD.
mpls bfd enable
By default, MPLS BFD is disabled.
The mpls bfd enable command applies to VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route.
For more information about this command, see MPLS Command Reference.
¡     Configure the source IP address for BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address for BFD echo packets is not configured.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv6 route backup for an IPv6 route. For more information about this command, see High Availability Command Reference.
3.     Use BFD to test the connectivity of an LSP or MPLS TE tunnel.
¡     Configure BFD to test the connectivity of the LSP for the specified FEC.
mpls bfd dest-addr mask-length [ nexthop nexthop-address [ discriminator local local-id remote remote-id ] ] [ template template-name ]
¡     Configure BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface.
interface tunnel number mode mpls-te
mpls bfd [ discriminator local local-id remote remote-id ] [ template template-name ]
By default, BFD is not configured to test the connectivity of the LSP or MPLS TE tunnel.
This step is required for VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route.
For more information about the commands in this step, see MPLS Command Reference
4.     Configure a routing policy:
a.     Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
b.     Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ip-address
By default, no backup next hop address is set for FRR.
For more information about the commands, see Layer 3—IP Routing Command Reference.
6.     (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
By default, ARP is used to detect the connectivity to the next hop.
Use this command if necessary in VPNv6 route backup an IPv6 route.
For more information about this command, see Layer 3—IP Routing Command Reference.
7.     Enter BGP-VPN instance view.
8.     Enter BGP-VPN IPv6 unicast address family view.
9.     Apply a routing policy to FRR.
By default, no routing policy is applied to FRR.
The apply fast-reroute backup-nexthop command can take effect in the routing policy that is being used. Other apply commands do not take effect.
For more information about the command, see BGP commands in Layer 3—IP Routing Command Reference.
Enabling MPLS L3VPN FRR for the address family
2.     Configure BFD.
¡     Enable MPLS BFD.
mpls bfd enable
This command applies to VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route. For more information about this command, see MPLS OAM commands in MPLS Command Reference.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv6 route backup for an IPv6 route. For more information about this command, see BFD commands in High Availability Command Reference.
¡     Use BFD to test the connectivity of the LSP for the specified FEC.
¡     Use BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface.
By default, BFD is not used to test the connectivity of the LSP or MPLS TE tunnel.
For more information about the commands, see MPLS OAM commands in MPLS Command Reference.
5.     (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
6.     Enter BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view.
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡     Enter BGP VPNv6 address family view.
7.     Enable FRR for the address family.
pic
By default, FRR is disabled.
Before you configure an OSPFv3 sham link, perform the following tasks:
·     Configure basic IPv6 MPLS L3VPN (OSPFv3 is used between PE and CE).
·     Configure OSPFv3 in the LAN where customer CEs reside.
Redistributing the loopback interface address
2.     Create a loopback interface and enter loopback interface view.
interface loopback interface-number
3.     Associate the loopback interface with a VPN instance.
By default, the interface is not associated with any VPN instances and belongs to the public network.
4.     Configure an IPv6 address for the loopback interface.
See Layer 3—IP Services Configuration Guide.
By default, no IPv6 address is configured for the loopback interface.
6.     Enter BGP-VPN instance view.
7.     Enter BGP-VPN IPv6 unicast address family view.
8.     Redistribute direct routes into BGP (including the loopback interface address).
import-route direct
By default, no direct routes are redistributed into BGP.
Creating a sham link
2.     Enter OSPFv3 view.
3.     Enter OSPFv3 area view.
area area-id
4.     Configure an OSPFv3 sham link.
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit retrans-interval | trans-delay delay ] *
When CEs at different sites have the same AS number, configure the BGP AS number substitution feature to avoid route loss.
When a PE uses different interfaces to connect different CEs in a site, the BGP AS number substitution feature introduces a routing loop. To remove the routing loop, configure the SoO attribute on the PE.
For more information about the BGP AS number substitution feature and the SoO attribute, see "BGP AS number substitution and SoO attribute."
4.     Enable the BGP AS number substitution feature.
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
By default, BGP AS number substitution is disabled.
5.     Enter BGP-VPN IPv6 unicast address family view.
6.     (Optional.) Configure the SoO attribute for a BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } soo site-of-origin
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative control. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
With this feature enabled, a device processes the AIGP attribute in a received route as follows:
·     If the device sets itself as the next hop for the route, it adds to the AIGP attribute value the IGP metric from itself to the original next hop and advertises the new AIGP attribute value.
·     If the device does not set itself as the next hop for the route, it does not change the AIGP attribute value.
BGP uses the AIGP attribute to select the optimal route as follows:
·     A route carrying the AIGP attribute takes precedence over a route not carrying the AIGP attribute.
·     A route that has a smaller computed AIGP attribute value has a higher priority.
When the AIGP attribute of a route changes, BGP sends update messages for the route.
As a best practice, do not configure the peer aigp command on border devices of an AIGP administrative domain.
When a device receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you execute only the peer aigp command. To enable the device to advertise the AIGP attribute, you must execute both the peer aigp and apply aigp commands. For information about the apply aigp command, see the routing policy configuration in Layer 3—IP Routing Configuration Guide.
4.     Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attributes in routes received from the peer or peer group.
5.     (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
The BGP additional path (Add-Path) feature enables BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group. When the optimal route fails, the suboptimal route becomes the optimal route, shortening the traffic interruption time.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP device. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
4.     Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
5.     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group is 1.
6.     Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, the maximum total number of Add-Path optimal routes that can be advertised to all peers is 1.
In an IPv6 BGP/IPv6 MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
The route replication feature provides the following functions:
·     Enables a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public network or other VPN instances.
·     Enables the public network to communicate with a VPN instance by replicating routes from the VPN instance.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this feature to replicate routes from the public network to the VPN instances.
VLINK direct routes are generated based on ND entries learned by subinterfaces configured with QinQ/Dot1q termination or VLAN interfaces. The route-replicate from vpn-instance protocol direct or route-replicate from public protocol direct command does not replicate VLINK direct routes, which will cause traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes.
Replicating routes from the public network or VPN instances to a VPN instance
2.     Enter VPN instance view.
3.     Enter VPN instance IPv6 address family view.
address-family ipv6
4.     Replicate routes from the public network or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp4+ as-number | direct | static | vlink-direct | { isisv6 | ospfv3 | ripng } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, a VPN instance cannot replicate routes from the public network or other VPN instances.
Replicating routes from a VPN instance to the public network
2.     Enter public instance view.
ip public-instance
3.     Enter public instance IPv6 address family view.
address-family ipv6
4.     Replicate routes from a VPN instance to the public network.
route-replicate from vpn-instance vpn-instance-name protocol { bgp4+ as-number | direct | static | vlink-direct | { isisv6 | ospfv3 | ripng } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, the public network cannot replicate routes from VPN instances.
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, you can configure BGP route replication between public and VPN instances.
After you configure this feature, the public and VPN instances replicate all BGP routes including route attributes from each other.
This feature also enables BGP route replication between VPN instances, so VPNs cannot be isolated. Configure this feature only in specific scenarios, for example, the traffic cleaning scenario.
3.     Enable BGP route replication between public and VPN instances.
route-replicate enable
By default, BGP route replication between public and VPN instances is disabled.
4.     Return to system view.
5.     Enter public instance view or public instance IPv6 address family view.
¡     Enter public instance view.
ip public-instance
¡     Execute the following commands in sequence to enter public instance IPv6 address family view:
ip public-instance
address-family ipv6
6.     Apply an import routing policy to the public instance.
7.     Apply an export routing policy to the public instance.
This feature enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast switchover of traffic on the specified routes to available routes to reduce the traffic interruption time.
4.     Enable prioritized withdrawal of the routes that match the specified routing policy.
By default, BGP does not send the withdrawal messages of specific routes prior to other routes.
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
4.     Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Display and maintenance commands for IPv6 MPLS L3VPN
Resetting BGP connections
You can soft-reset or reset BGP sessions to apply new BGP configurations. A soft reset operation updates BGP routing information without tearing down BGP connections. A reset operation updates BGP routing information by tearing down, and then re-establishing BGP connections. Soft reset requires that BGP peers have route refresh capability.
Execute the following commands in user view to soft reset or reset BGP connections:
Manually soft reset BGP sessions for VPNv6 address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } vpnv6
Reset BGP sessions for VPNv6 address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | internal | group group-name } vpnv6
For more information about the refresh bgp vpnv6 and reset bgp vpnv6 commands, see Layer 3—IP Routing Command Reference.
Displaying IPv6 MPLS L3VPN information
Execute the following commands in any view to display IPv6 MPLS L3VPN:
Display the IPv6 routing table for a VPN instance.
display ipv6 routing-table vpn-instance vpn-instance-name [ verbose ]
Display information about a specified VPN instance or all VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name | count ]
Display IPv6 FIB information for a VPN instance.
display ipv6 fib vpn-instance vpn-instance-name [ ipv6-address [ prefix-length ] ]
Display BGP VPNv6 peer group information.
display bgp [ instance instance-name ] group vpnv6 [ group-name group-name ]
Display BGP VPNv6 peer information.
display bgp [ instance instance-name ] peer vpnv6 [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Display BGP VPNv6 routes.
display bgp [ instance instance-name ] routing-table vpnv6 [ [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
Display incoming labels for all BGP VPNv6 routes.
display bgp [ instance instance-name ] routing-table vpnv6 inlabel
Display outgoing labels for all BGP VPNv6 routes.
display bgp [ instance instance-name ] routing-table vpnv6 outlabel
Display BGP VPNv6 address family update group information.
display bgp [ instance instance-name ] update-group vpnv6 [ ipv4-address | ipv6-address ]
Display BGP peer and routing summary information.
display bgp [ instance instance-name ] vpnv6 summary
Display OSPFv3 sham link information.
display ospfv3 [ process-id ] [ area area-id ] sham-link [ verbose ]
For more information about the display ipv6 routing-table, display bgp group vpnv6, display bgp peer vpnv6, and display bgp update-group vpnv6 commands, see Layer 3—IP Routing Command Reference.
IPv6 MPLS L3VPN configuration examples
Example: Configuring IPv6 MPLS L3VPNs
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attributes 111:1. VPN 2 uses route target attributes 222:2. Users of different VPNs cannot access each other.
Run EBGP between CEs and PEs to exchange VPN routing information.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Figure 42 Network diagram
Table 17 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
2001:1::1/96
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
HGE1/0/4
172.1.1.2/24
HGE1/0/1
2001:1::2/96
HGE1/0/5
172.2.1.1/24
HGE1/0/2
2001:2::2/96
PE 2
Loop0
3.3.3.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/1
2001:3::2/96
CE 2
HGE1/0/1
2001:2::1/96
HGE1/0/2
2001:4::2/96
CE 3
HGE1/0/1
2001:3::1/96
HGE1/0/4
172.2.1.2/24
CE 4
HGE1/0/1
2001:4::1/96
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1.     Configure OSPF on the MPLS backbone to ensure IP connectivity among the PEs and the P router:
# Configure PE 1.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface hundredgige 1/0/4
[PE1-HundredGigE1/0/4] ip address 172.1.1.1 24
[PE1-HundredGigE1/0/4] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P router.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface hundredgige 1/0/4
[P-HundredGigE1/0/4] ip address 172.1.1.2 24
[P-HundredGigE1/0/4] quit
[P] interface hundredgige 1/0/5
[P-HundredGigE1/0/5] ip address 172.2.1.1 24
[P-HundredGigE1/0/5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface hundredgige 1/0/4
[PE2-HundredGigE1/0/4] ip address 172.2.1.2 24
[PE2-HundredGigE1/0/4] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2.     Configure basic MPLS and enable MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-HundredGigE1/0/4] mpls enable
[PE1-HundredGigE1/0/4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-HundredGigE1/0/4] mpls enable
[P-HundredGigE1/0/4] mpls ldp enable
[P-HundredGigE1/0/5] mpls enable
[P-HundredGigE1/0/5] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-HundredGigE1/0/4] mpls enable
[PE2-HundredGigE1/0/4] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure IPv6 VPN instances on the PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface hundredgige 1/0/1
[PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/1] ipv6 address 2001:1::2 96
[PE1-HundredGigE1/0/1] quit
[PE1] interface hundredgige 1/0/2
[PE1-HundredGigE1/0/2] ip binding vpn-instance vpn2
[PE1-HundredGigE1/0/2] ipv6 address 2001:2::2 96
[PE1-HundredGigE1/0/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface hundredgige 1/0/1
[PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE2-HundredGigE1/0/1] ipv6 address 2001:3::2 96
[PE2-HundredGigE1/0/1] quit
[PE2] interface hundredgige 1/0/2
[PE2-HundredGigE1/0/2] ip binding vpn-instance vpn2
[PE2-HundredGigE1/0/2] ipv6 address 2001:4::2 96
[PE2-HundredGigE1/0/2] quit
# Configure IP addresses for the CEs according to Figure 42. (Details not shown.)
# Execute the display ip vpn-instance command on the PEs to display information about the VPN instances, for example, on PE 1.
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  Total IPv4 VPN-Instances configured : 0
  Total IPv6 VPN-Instances configured : 2
  VPN-Instance Name     RD              Address family      Create time
  vpn1                  100:1           IPv6                2012/02/13 12:49:08
  vpn2                  100:2           IPv6                2012/02/13 12:49:20
# Use the ping command on the PEs to verify that the PEs can ping their attached CEs, for example, on PE 1.
[PE1] ping ipv6 -vpn-instance vpn1 2001:1::1
Ping6(56 bytes) 2001:1::2 --> 2001:1::1, press CTRL_C to break
56 bytes from 2001:1::1, icmp_seq=0 hlim=64 time=9.000 ms
56 bytes from 2001:1::1, icmp_seq=1 hlim=64 time=1.000 ms
56 bytes from 2001:1::1, icmp_seq=2 hlim=64 time=0.000 ms
56 bytes from 2001:1::1, icmp_seq=3 hlim=64 time=0.000 ms
56 bytes from 2001:1::1, icmp_seq=4 hlim=64 time=0.000 ms
--- Ping6 statistics for 2001:1::1 ---
round-trip min/avg/max/std-dev = 0.000/2.000/9.000/3.521 ms
4.     Establish EBGP peer relationships between the PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 2001:1::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 2001:1::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
# Configure the other CEs (CE 2 through CE 4) in the same way that CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[PE1-bgp-default-ipv6-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2 in the same way that PE 1 is configured. (Details not shown.)
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5.     Configure an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] address-family vpnv6
[PE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[PE1-bgp-default-vpnv6] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] address-family vpnv6
[PE2-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv6] quit
[PE2-bgp-default] quit
# Execute the display bgp peer vpnv6 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ipv6 routing-table vpn-instance command on the PEs.
[PE1] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 2001:1::/96                                 Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : HGE1/0/1                                    Cost      : 0
Destination: 2001:1::2/128                               Protocol  : Direct
Destination: 2001:3::/96                                 Protocol  : BGP4+
NextHop    : ::FFFF:3.3.3.9                              Preference: 255
Interface  : HGE1/0/4                                    Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
[PE1] display ipv6 routing-table vpn-instance vpn2
Destination: 2001:2::/96                                 Protocol  : Direct
Interface  : HGE1/0/2                                    Cost      : 0
Destination: 2001:2::2/128                               Protocol  : Direct
Destination: 2001:4::/96                                 Protocol  : BGP4+
The output shows that PE 1 has routes to the remote CEs. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (2001:3::1), but cannot ping CE 4 (2001:4::1). (Details not shown.)
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through the Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between the Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs. Configure MP-IBGP between the Spoke-PEs and Hub-PE to exchange VPN routing information.
Figure 43 Network diagram
Table 18 Interface and IP address assignment
Device
IP address
Device
IP address
Spoke-CE 1
HGE1/0/1
11::1/64
Hub-CE
HGE1/0/1
13::1/64
Spoke-PE 1
Loop0
1.1.1.9/32
HGE1/0/2
14::1/64
HGE1/0/1
11::2/64
Hub-PE
Loop0
2.2.2.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/4
172.1.1.2/24
Spoke-CE 2
HGE1/0/1
12::1/64
HGE1/0/5
172.2.1.2/24
Spoke-PE 2
Loop0
3.3.3.9/32
HGE1/0/1
13::2/64
HGE1/0/1
12::2/64
HGE1/0/2
14::2/64
HGE1/0/4
172.2.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure Spoke-PE 1.
<Spoke-PE1> system-view
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface hundredgige 1/0/4
[Spoke-PE1-HundredGigE1/0/4] ip address 172.1.1.1 24
[Spoke-PE1-HundredGigE1/0/4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
<Spoke-PE2> system-view
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface hundredgige 1/0/4
[Spoke-PE2-HundredGigE1/0/4] ip address 172.1.1.1 24
[Spoke-PE2-HundredGigE1/0/4] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
<Hub-PE> system-view
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface hundredgige 1/0/4
[Hub-PE-HundredGigE1/0/4] ip address 172.1.1.2 24
[Hub-PE-HundredGigE1/0/4] quit
[Hub-PE] interface hundredgige 1/0/5
[Hub-PE-HundredGigE1/0/5] ip address 172.2.1.2 24
[Hub-PE-HundredGigE1/0/5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the PEs to verify that OSPF adjacencies in Full state have been established between the PEs. Execute the display ip routing-table command on the PEs to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2.     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-HundredGigE1/0/4] mpls enable
[Spoke-PE1-HundredGigE1/0/4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-HundredGigE1/0/4] mpls enable
[Spoke-PE2-HundredGigE1/0/4] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-HundredGigE1/0/4] mpls enable
[Hub-PE-HundredGigE1/0/4] mpls ldp enable
[Hub-PE-HundredGigE1/0/5] mpls enable
[Hub-PE-HundredGigE1/0/5] mpls ldp enable
# Execute the display mpls ldp peer command on the PEs to verify that LDP sessions in Operational state have been established between the PEs. Execute the display mpls ldp lsp command on the PEs to verify that the LSPs have been established by LDP. (Details not shown.)
3.     Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface hundredgige 1/0/1
[Spoke-PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[Spoke-PE1-HundredGigE1/0/1] ip address 11::2 24
[Spoke-PE1-HundredGigE1/0/1] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface hundredgige 1/0/1
[Spoke-PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[Spoke-PE2-HundredGigE1/0/1] ip address 12::2 24
[Spoke-PE2-HundredGigE1/0/1] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface hundredgige 1/0/1
[Hub-PE-HundredGigE1/0/1] ip binding vpn-instance vpn1-in
[Hub-PE-HundredGigE1/0/1] ip address 13::2 24
[Hub-PE-HundredGigE1/0/1] quit
[Hub-PE] interface hundredgige 1/0/2
[Hub-PE-HundredGigE1/0/2] ip binding vpn-instance vpn1-out
[Hub-PE-HundredGigE1/0/2] ip address 14::2 24
[Hub-PE-HundredGigE1/0/2] quit
# Configure IP addresses for the CEs according to Table 18. (Details not shown.)
# Execute the display ip vpn-instance command on the PEs to display the VPN instance configuration. This example uses Spoke-PE 1.
[Spoke-PE1] display ip vpn-instance
  Total IPv6 VPN-Instances configured : 1
  vpn1                  100:1           IPv6                2009/04/08 10:55:07
# Use the ping command on the PEs to verify that the PEs can ping their attached CEs. This example uses Spoke-PE 1.
[Spoke-PE1] ping ipv6 -vpn-instance vpn1 11::1
Ping6(56 bytes) 11::2 --> 11::1, press CTRL_C to break
56 bytes from 11::1, icmp_seq=0 hlim=64 time=0.000 ms
56 bytes from 11::1, icmp_seq=1 hlim=64 time=1.000 ms
56 bytes from 11::1, icmp_seq=2 hlim=64 time=0.000 ms
56 bytes from 11::1, icmp_seq=3 hlim=64 time=1.000 ms
56 bytes from 11::1, icmp_seq=4 hlim=64 time=0.000 ms
--- Ping6 statistics for 11::1 ---
round-trip min/avg/max/std-dev = 0.000/0.400/1.000/0.490 ms
4.     Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
# Configure Spoke-CE 1.
<Spoke-CE1> system-view
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] peer 11::2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv6
[Spoke-CE1-bgp-default-ipv6] peer 11::2 enable
[Spoke-CE1-bgp-default-ipv6] import-route direct
[Spoke-CE1-bgp-default-ipv6] quit
[Spoke-CE1-bgp-default] quit
# Configure Spoke-CE 2.
<Spoke-CE2> system-view
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] peer 12::2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv6
[Spoke-CE2-bgp-default-ipv6] peer 12::2 enable
[Spoke-CE2-bgp-default-ipv6] import-route direct
[Spoke-CE2-bgp-default-ipv6] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
<Hub-CE> system-view
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] peer 13::2 as-number 100
[Hub-CE-bgp-default] peer 14::2 as-number 100
[Hub-CE-bgp-default] address-family ipv6
[Hub-CE-bgp-default-ipv6] peer 13::2 enable
[Hub-CE-bgp-default-ipv6] peer 14::2 enable
[Hub-CE-bgp-default-ipv6] import-route direct
[Hub-CE-bgp-default-ipv6] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 11::1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv6
[Spoke-PE1-bgp-default-ipv6-vpn1] peer 11::1 enable
[Spoke-PE1-bgp-default-ipv6-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 12::1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv6
[Spoke-PE2-bgp-default-ipv6-vpn1] peer 12::1 enable
[Spoke-PE2-bgp-default-ipv6-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 13::1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-in] peer 13::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 14::1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 allow-as-loop 2
[Hub-PE-bgp-default-ipv6-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5.     Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv6
[Spoke-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv6] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv6
[Spoke-PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv6] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv6
[Hub-PE-bgp-default-vpnv6] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv6] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv6] quit
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (64-59+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1.
[Spoke-CE1] ping ipv6 12::1
Ping6(56 bytes) 11::1 --> 12::1, press CTRL_C to break
56 bytes from 12::1, icmp_seq=0 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=1 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=2 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=3 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=4 hlim=59 time=0.000 ms
--- Ping6 statistics for 12::1 ---
Example: Configuring IPv6 MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
Configure IPv6 MPLS L3VPN inter-AS option A, and use VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone of each AS.
Figure 44 Network diagram
Table 19 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
2001:1::1/96
CE 2
HGE1/0/1
2001:2::1/96
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/1
2001:1::2/96
HGE1/0/1
2001:2::2/96
HGE1/0/4
172.1.1.2/24
HGE1/0/4
162.1.1.2/24
ASBR-PE1
Loop0
2.2.2.9/32
ASBR-PE2
Loop0
3.3.3.9/32
HGE1/0/4
172.1.1.1/24
HGE1/0/4
162.1.1.1/24
HGE1/0/5
2002:1::1/96
HGE1/0/5
2002:1::2/96
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
IMPORTANT
IMPORTANT:
1.     Configure an IGP on each MPLS backbone to ensure IP connectivity within the backbone.
This example uses OSPF. Be sure to advertise the route to the 32-bit loopback interface address of each router through OSPF. Use the loopback interface address of a router as the router's LSR ID. (Details not shown.)
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that the PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Execute the ping command to verify that the PEs and ASBR-PEs in the same AS can ping each other. (Details not shown.)
2.     Configure basic MPLS and enable MPLS LDP on each MPLS backbone to establish LDP LSPs:
# Configure basic MPLS on PE 1, and enable MPLS LDP for both PE 1 and the interface connected to ASBR-PE 1.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP for both ASBR-PE 1 and the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1] interface hundredgige 1/0/4
[ASBR-PE1-HundredGigE1/0/4] mpls enable
[ASBR-PE1-HundredGigE1/0/4] mpls ldp enable
[ASBR-PE1-HundredGigE1/0/4] quit
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP for both ASBR-PE 2 and the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] interface hundredgige 1/0/4
[ASBR-PE2-HundredGigE1/0/4] mpls enable
[ASBR-PE2-HundredGigE1/0/4] mpls ldp enable
[ASBR-PE2-HundredGigE1/0/4] quit
# Configure basic MPLS on PE 2, and enable MPLS LDP for both PE 2 and the interface connected to ASBR-PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
# Execute the display mpls ldp session command on the routers to verify that the session status is Operational, and that each PE and the ASBR-PE in the same AS have established an LDP neighbor relationship. (Details not shown.)
3.     Configure a VPN instance on the PEs:
# Configure CE 1.
<CE1> system-view
[CE1] interface hundredgige 1/0/1
[CE1-HundredGigE1/0/1] ipv6 address 2001:1::1 96
[CE1-HundredGigE1/0/1] quit
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
# Configure CE 2.
<CE2> system-view
[CE2] interface hundredgige 1/0/1
[CE2-HundredGigE1/0/1] ipv6 address 2001:2::1 96
[CE2-HundredGigE1/0/1] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] vpn-target 200:1 both
[PE2-HundredGigE1/0/1] ipv6 address 2001:2::2 96
# On ASBR-PE 1, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its attached CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface hundredgige 1/0/5
[ASBR-PE1-HundredGigE1/0/5] ip binding vpn-instance vpn1
[ASBR-PE1-HundredGigE1/0/5] ipv6 address 2002:1::1 96
[ASBR-PE1-HundredGigE1/0/5] quit
# On ASBR-PE 2, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its attached CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface hundredgige 1/0/5
[ASBR-PE2-HundredGigE1/0/5] ip binding vpn-instance vpn1
[ASBR-PE2-HundredGigE1/0/5] ipv6 address 2002:1::2 96
[ASBR-PE2-HundredGigE1/0/5] quit
# Execute the display ip vpn-instance command to display VPN instance information. Verify that each PE can ping its attached CE, and that ASBR-PE 1 and ASBR-PE 2 can ping each other. (Details not shown.)
4.     Establish EBGP peer relationships between PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
[CE1] bgp 65001
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] peer 2001:2::2 as-number 200
[CE2-bgp-default] address-family ipv6
[CE2-bgp-default-ipv6] peer 2001:2::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
[CE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 2001:2::1 as-number 65002
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] peer 2001:2::1 enable
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
5.     Establish an IBGP peer relationship between each PE and the ASBR-PE in the same AS and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 2002:1::2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE1-bgp-default-ipv6-vpn1] peer 2002:1::2 enable
[ASBR-PE1-bgp-default-ipv6-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] address-family vpnv6
[ASBR-PE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv6] quit
[ASBR-PE1-bgp-default] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 2002:1::1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE2-bgp-default-ipv6-vpn1] peer 2002:1::1 enable
[ASBR-PE2-bgp-default-ipv6-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default] address-family vpnv6
[ASBR-PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv6] quit
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 3.3.3.9 enable
# Verify that the CEs can learn the route to each other and can ping each other. (Details not shown.)
Example: Configuring IPv6 MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100, and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv6 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv6 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv6 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPNv6 routes.
Figure 45 Network diagram
Table 20 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
30::1/64
HGE1/0/1
20::1/64
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
IMPORTANT
IMPORTANT:
1.     Configure PE 1:
# Configure IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.111.111.111.111.00
[PE1-isis-1] quit
# Configure LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface HundredGigE 1/0/5, and enable IS-IS, MPLS, and LDP on the interface.
[PE1] interface hundredgige 1/0/5
[PE1-HundredGigE1/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-HundredGigE1/0/5] isis enable 1
[PE1-HundredGigE1/0/5] mpls enable
[PE1-HundredGigE1/0/5] mpls ldp enable
[PE1-HundredGigE1/0/5] quit
# Configure interface Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-HundredGigE1/0/1] ip address 30::1 64
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv6 peer.
# Redistribute direct routes to the VPN routing table of vpn1.
[PE1-bgp-default-ipv6-vpn1] import-route direct
2.     Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-HundredGigE1/0/5] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-HundredGigE1/0/5] isis enable 1
[ASBR-PE1-HundredGigE1/0/5] mpls enable
[ASBR-PE1-HundredGigE1/0/5] mpls ldp enable
# Configure interface HundredGigE 1/0/4, and enable MPLS.
[ASBR-PE1-HundredGigE1/0/4] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface hundredgige 1/0/4
# Disable route target based filtering of received VPNv6 routes.
[ASBR-PE1-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as VPNv6 peers.
[ASBR-PE1-bgp-default-vpnv6] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
3.     Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-HundredGigE1/0/5] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-HundredGigE1/0/5] isis enable 1
[ASBR-PE2-HundredGigE1/0/5] mpls enable
[ASBR-PE2-HundredGigE1/0/5] mpls ldp enable
[ASBR-PE2-HundredGigE1/0/4] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface hundredgige 1/0/4
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv6 peers.
[ASBR-PE2-bgp-default-vpnv6] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-vpnv6] peer 5.5.5.9 enable
4.     Configure PE 2:
# Enable IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.111.111.111.111.00
[PE2-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface hundredgige 1/0/5
[PE2-HundredGigE1/0/5] ip address 9.1.1.2 255.0.0.0
[PE2-HundredGigE1/0/5] isis enable 1
[PE2-HundredGigE1/0/5] mpls enable
[PE2-HundredGigE1/0/5] mpls ldp enable
[PE2-HundredGigE1/0/5] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-HundredGigE1/0/1] ip address 20::1 64
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv6 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[PE2-bgp-default-ipv6-vpn1] import-route direct
# Use the following command on PE 1 to verify its connectivity to PE 2.
[PE1] ping ipv6 -a 30::1 -vpn-instance vpn1 20::1
Ping6(56 data bytes) 30::1-->20::1, press CTRL_C to break
56 bytes from 20::1: icmp_seq=0 hlim=64 time=1.208 ms
56 bytes from 20::1: icmp_seq=1 hlim=64 time=0.867 ms
56 bytes from 20::1: icmp_seq=2 hlim=64 time=0.551 ms
56 bytes from 20::1: icmp_seq=3 hlim=64 time=0.566 ms
56 bytes from 20::1: icmp_seq=4 hlim=64 time=0.570 ms
--- Ping6 statistics for 20::1 in VPN instance vpn1---
round-trip min/avg/max/std-dev = 0.551/0.752/1.208/0.257 ms
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 1)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100. Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by IBGP. PE 1 and PE 2 are MP-EBGP peers to exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Figure 46 Network diagram
Table 21 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
2001::1/64
HGE1/0/1
2002::1/64
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
CE 1
HGE1/0/1
2001::2/64
CE 1
HGE1/0/1
2002::2/64
IMPORTANT
IMPORTANT:
1.     Configure CE 1:
# Configure an IPv6 address for HundredGigE 1/0/1.
<CE1> system-view
[CE1-HundredGigE1/0/1] ipv6 address 2001::2 64
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 2001::1 as-number 100
[CE1-bgp-default-ipv6] peer 2001::1 enable
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure HundredGigE 1/0/5, and enable IS-IS, MPLS, and LDP on the interface.
# Configure Loopback 0 and enable IS-IS on it.
# Create VPN instance vpn1, and configure the RD and route target attributes for it.
[PE1-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
# Associate HundredGigE 1/0/1 with VPN instance vpn1, and specify the IPv6 address for the interface.
[PE1-HundredGigE1/0/1] ipv6 address 2001::1 64
[PE1] bgp 100
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 3.3.3.9.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv6 peer.
[PE1-bgp-default-af-vpnv6] peer 5.5.5.9 enable
[PE1-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE1-bgp-default-vpn1] peer 2001::2 as-number 65001
[PE1-bgp-default-ipv6-vpn1] peer 2001::2 enable
3.     Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure HundredGigE 1/0/4, and enable MPLS on it.
# Configure Loopback 0, and enable IS-IS on it.
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 2.2.2.9.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4.     Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.333.333.333.333.00
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 5.5.5.9.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.444.444.444.444.00
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
[PE2-HundredGigE1/0/1] ipv6 address 2002::1 64
# Enable BGP.
[PE2] bgp 600
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 4.4.4.9.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv6 peer.
[PE2-bgp-default-af-vpnv6] peer 2.2.2.9 enable
[PE2-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE2-bgp-default-vpn1] peer 2002::2 as-number 65002
[PE2-bgp-default-ipv6-vpn1] peer 2002::2 enable
6.     Configure CE 2:
<CE2> system-view
[CE2-HundredGigE1/0/1] ipv6 address 2002::2 64
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 2002::1 as-number 600
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 2002::1 enable
# Execute the display ipv6 routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 2)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and PE 2 are MP-EBGP peers and exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 47 Network diagram
Table 22 Interface and IP address assignment
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
HGE1/0/1
2001::1/64
HGE1/0/1
2002::1/64
HGE1/0/5
1.1.1.2/8
HGE1/0/5
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
HGE1/0/5
1.1.1.1/8
HGE1/0/5
9.1.1.1/8
HGE1/0/4
11.0.0.2/8
HGE1/0/4
11.0.0.1/8
CE 1
HGE1/0/1
2001::2/64
CE 1
HGE1/0/1
2002::2/64
IMPORTANT
IMPORTANT:
1.     Configure CE 1:
<CE1> system-view
[CE1] bgp 65001
2.     Configure PE 1:
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface Loopback 0 and enable IS-IS on it.
# Associate HundredGigE 1/0/1 with VPN instance vpn1, and specify an IPv6 address for the interface.
[PE1] bgp 100
[PE1-bgp-default-vpnv6] peer 5.5.5.9 enable
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Create routing policy policy1.
[ASBR-PE1-route-policy-policy1-1] if-match mpls-label
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
[PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
6.     Configure CE 2:
<CE2> system-view
[CE2] bgp 65002
Example: Configuring IPv6 MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 48. In this scenario:
·     PE 1 and PE 2 are the provider carrier's PE routers. They provide VPN services to the customer carrier.
·     CE 1 and CE 2 are the customer carrier's routers. They are connected to the provider carrier's backbone as CE routers.
·     PE 3 and PE 4 are the customer carrier's PE routers. They provide IPv6 MPLS L3VPN services to end customers.
·     CE 3 and CE 4 are customers of the customer carrier.
·     The customer carrier and the provider carrier reside in the same AS.
The key to the carrier's carrier deployment is to configure exchange of two kinds of routes:
·     Exchange of the customer carrier's internal routes on the provider carrier's backbone.
·     Exchange of the end customers' internal routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Figure 48 Network diagram
Table 23 Interface and IP address assignment
Device
IP address
Device
IP address
CE 3
HGE1/0/1
2001:1::1/96
CE 4
HGE1/0/1
2001:2::1/96
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
HGE1/0/1
2001:1::2/96
HGE1/0/1
2001:2::2/96
HGE1/0/5
10.1.1.1/24
HGE1/0/5
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
HGE1/0/4
10.1.1.2/24
HGE1/0/4
21.1.1.2/24
HGE1/0/5
11.1.1.1/24
HGE1/0/5
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
HGE1/0/4
11.1.1.2/24
HGE1/0/4
30.1.1.2/24
HGE1/0/5
30.1.1.1/24
HGE1/0/5
21.1.1.1/24
IMPORTANT
IMPORTANT:
1.     Configure MPLS L3VPN on the provider carrier backbone. Configure IS-IS as the IGP, enable LDP on PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-HundredGigE1/0/5] ip address 30.1.1.1 24
[PE1-HundredGigE1/0/5] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv4] quit
# On PE 1 or PE 2, execute the following commands:
¡     Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡     Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2.     Configure the customer carrier network. Configure IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface hundredgige 1/0/5
[PE3-HundredGigE1/0/5] ip address 10.1.1.1 24
[PE3-HundredGigE1/0/5] isis enable 2
[PE3-HundredGigE1/0/5] mpls enable
[PE3-HundredGigE1/0/5] mpls ldp enable
[PE3-HundredGigE1/0/5] mpls ldp transport-address interface
[PE3-HundredGigE1/0/5] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface hundredgige 1/0/4
[CE1-HundredGigE1/0/4] ip address 10.1.1.2 24
[CE1-HundredGigE1/0/4] isis enable 2
[CE1-HundredGigE1/0/4] mpls enable
[CE1-HundredGigE1/0/4] mpls ldp enable
[CE1-HundredGigE1/0/4] mpls ldp transport-address interface
[CE1-HundredGigE1/0/4] quit
PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
# Configure PE 4 and CE 2 in the same way that PE 3 and CE 1 are configured. (Details not shown.)
3.     Connect the customer carrier and the provider carrier:
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp allow-ibgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1-HundredGigE1/0/4] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/4] ip address 11.1.1.2 24
[PE1-HundredGigE1/0/4] isis enable 2
[PE1-HundredGigE1/0/4] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import isis 2
# Configure CE 1.
[CE1] interface hundredgige 1/0/5
[CE1-HundredGigE1/0/5] ip address 11.1.1.1 24
[CE1-HundredGigE1/0/5] isis enable 2
[CE1-HundredGigE1/0/5] mpls enable
[CE1-HundredGigE1/0/5] mpls ldp enable
[CE1-HundredGigE1/0/5] mpls ldp transport-address interface
[CE1-HundredGigE1/0/5] quit
PE 1 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
# Configure PE 2 and CE 2 in the same way that PE 1 and CE 1 are configured. (Details not shown.)
4.     Connect end customers and the customer carrier:
# Configure CE 3.
<CE3> system-view
[CE3] interface hundredgige 1/0/1
[CE3-HundredGigE1/0/1] ipv6 address 2001:1::1 96
[CE3-HundredGigE1/0/1] quit
[CE3] bgp 65410
[CE3-bgp-default] peer 2001:1::2 as-number 100
[CE3-bgp-default] address-family ipv6
[CE3-bgp-default-ipv6] peer 2001:1::2 enable
[CE3-bgp-default-ipv6] import-route direct
[CE3-bgp-default-ipv6] quit
[CE3-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface hundredgige 1/0/1
[PE3-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE3-HundredGigE1/0/1] ipv6 address 2001:1::2 96
[PE3-HundredGigE1/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv6 unicast
[PE3-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE3-bgp-default-ipv6-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure PE 4 and CE 4 in the same way that PE 3 and CE 3 are configured. (Details not shown.)
5.     Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv6
[PE3-bgp-default-af-vpnv6] peer 6.6.6.9 enable
[PE3-bgp-default-af-vpnv6] quit
# Configure PE 4 in the same way that PE 3 is configured. (Details not shown.)
1.     Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
[PE1] display ip routing-table
Destinations : 12        Routes : 12
3.3.3.9/32         Direct  0   0           127.0.0.1       InLoop0
4.4.4.9/32         IS_L1   15  10          30.1.1.2        HGE1/0/5
30.1.1.0/24        Direct  0   0           30.1.1.1        HGE1/0/5
30.1.1.0/32        Direct  0   0           30.1.1.1        HGE1/0/5
30.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
30.1.1.255/32      Direct  0   0           30.1.1.1        HGE1/0/5
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Verify that the VPN routing table contains the internal routes of the customer carrier network.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 16        Routes : 16
1.1.1.9/32         IS_L1   15  20          11.1.1.1        HGE1/0/4
2.2.2.9/32         IS_L1   15  10          11.1.1.1        HGE1/0/4
5.5.5.9/32         BGP     255 10          4.4.4.9         HGE1/0/5
6.6.6.9/32         BGP     255 20          4.4.4.9         HGE1/0/5
10.1.1.0/24        IS_L1   15  20          11.1.1.1        HGE1/0/4
11.1.1.0/24        Direct  0   0           11.1.1.2        HGE1/0/4
11.1.1.0/32        Direct  0   0           11.1.1.2        HGE1/0/4
11.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.2        HGE1/0/4
20.1.1.0/24        BGP     255 20          4.4.4.9         HGE1/0/5
2.     Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network.
[CE1] display ip routing-table
Destinations : 19        Routes : 19
1.1.1.9/32         IS_L1   15  10          10.1.1.1        HGE1/0/4
2.2.2.9/32         Direct  0   0           127.0.0.1       InLoop0
5.5.5.9/32         IS_L2   15  74          11.1.1.2        HGE1/0/5
6.6.6.9/32         IS_L2   15  74          11.1.1.2        HGE1/0/5
10.1.1.0/24        Direct  0   0           10.1.1.2        HGE1/0/4
10.1.1.0/32        Direct  0   0           10.1.1.2        HGE1/0/4
10.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.2        HGE1/0/4
11.1.1.0/24        Direct  0   0           11.1.1.1        HGE1/0/5
11.1.1.0/32        Direct  0   0           11.1.1.1        HGE1/0/5
11.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.1        HGE1/0/5
20.1.1.0/24        IS_L2   15  74          11.1.1.2        HGE1/0/5
3.     Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.9/32         IS_L1   15  10          10.1.1.2        HGE1/0/5
5.5.5.9/32         IS_L2   15  84          10.1.1.2        HGE1/0/5
6.6.6.9/32         IS_L2   15  84          10.1.1.2        HGE1/0/5
10.1.1.0/24        Direct  0   0           10.1.1.1        HGE1/0/5
10.1.1.0/32        Direct  0   0           10.1.1.1        HGE1/0/5
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        HGE1/0/5
11.1.1.0/24        IS_L1   15  20          10.1.1.2        HGE1/0/5
20.1.1.0/24        IS_L2   15  84          10.1.1.2        HGE1/0/5
# Verify that the VPN routing table has the remote VPN route.
[PE3] display ipv6 routing-table vpn-instance vpn1
Destination: 2001:2::/96                                 Protocol  : BGP4+
NextHop    : ::FFFF:6.6.6.9                              Preference: 255
Interface  : HGE1/0/5                                    Cost      : 0
4.     Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5.     Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Example: Configuring HoVPN
There are two levels of networks, the backbone and the MPLS VPN networks, as shown in Figure 49.
·     SPEs act as PEs to allow MPLS VPNs to access the backbone.
·     UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
·     Performance requirements for the UPEs are lower than those for the SPEs.
·     SPEs advertise routes permitted by the routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other, and forbidding CE 2 and CE 4 in VPN 2 from communicating with each other.
Figure 49 Network diagram
Table 24 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
2001:1::1/96
CE 3
HGE1/0/1
2001:3::1/96
CE 2
HGE1/0/1
2001:2::1/96
CE 4
HGE1/0/1
2001:4::1/96
UPE 1
Loop0
1.1.1.9/32
UPE 2
Loop0
4.4.4.9/32
HGE1/0/1
2001:1::2/96
HGE1/0/1
172.2.1.1/24
HGE1/0/2
2001:2::2/96
HGE1/0/2
2001:3::2/96
HGE1/0/3
172.1.1.1/24
HGE1/0/3
2001:4::2/96
SPE 1
Loop0
2.2.2.9/32
SPE 2
Loop0
3.3.3.9/32
HGE1/0/1
172.1.1.2/24
HGE1/0/1
180.1.1.2/24
HGE1/0/2
180.1.1.1/24
HGE1/0/2
172.2.1.2/24
IMPORTANT
IMPORTANT:
1.     Configure UPE 1:
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
<UPE1> system-view
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls ldp
[UPE1-ldp] quit
[UPE1] interface hundredgige 1/0/3
[UPE1-HundredGigE1/0/3] ip address 172.1.1.1 24
[UPE1-HundredGigE1/0/3] mpls enable
[UPE1-HundredGigE1/0/3] mpls ldp enable
[UPE1-HundredGigE1/0/3] quit
# Configure the IGP protocol (OSPF, in this example).
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface hundredgige 1/0/1
[UPE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[UPE1-HundredGigE1/0/1] ipv6 address 2001:1::2 96
[UPE1-HundredGigE1/0/1] quit
[UPE1] interface hundredgige 1/0/2
[UPE1-HundredGigE1/0/2] ip binding vpn-instance vpn2
[UPE1-HundredGigE1/0/2] ipv6 address 2001:2::2 96
[UPE1-HundredGigE1/0/2] quit
# Establish an MP-IBGP peer relationship with SPE 1.
[UPE1] bgp 100
[UPE1-bgp-default] peer 2.2.2.9 as-number 100
[UPE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp-default] address-family vpnv6
[UPE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[UPE1-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 1.
[UPE1-bgp-default] ip vpn-instance vpn1
[UPE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[UPE1-bgp-default-vpn1] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[UPE1-bgp-default-ipv6-vpn1] quit
[UPE1-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 2.
[UPE1-bgp-default] ip vpn-instance vpn2
[UPE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[UPE1-bgp-default-vpn2] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[UPE1-bgp-default-ipv6-vpn2] quit
[UPE1-bgp-default-vpn2] quit
[UPE1-bgp-default] quit
2.     Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
3.     Configure CE 2.
<CE2> system-view
[CE2] bgp 65420
[CE2-bgp-default] peer 2001:2::2 as-number 100
4.     Configure UPE 2:
<UPE2> system-view
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls ldp
[UPE2-ldp] quit
[UPE2] interface hundredgige 1/0/1
[UPE2-HundredGigE1/0/1] ip address 172.2.1.1 24
[UPE2-HundredGigE1/0/1] mpls enable
[UPE2-HundredGigE1/0/1] mpls ldp enable
[UPE2-HundredGigE1/0/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface hundredgige 1/0/2
[UPE2-HundredGigE1/0/2] ip binding vpn-instance vpn1
[UPE2-HundredGigE1/0/2] ipv6 address 2001:3::2 96
[UPE2-HundredGigE1/0/2] quit
[UPE2] interface hundredgige 1/0/3
[UPE2-HundredGigE1/0/3] ip binding vpn-instance vpn2
[UPE2-HundredGigE1/0/3] ipv6 address 2001:4::2 96
[UPE2-HundredGigE1/0/3] quit
# Establish an MP-IBGP peer relationship with SPE 2.
[UPE2] bgp 100
[UPE2-bgp-default] peer 3.3.3.9 as-number 100
[UPE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp-default] address-family vpnv6
[UPE2-bgp-default-vpnv6] peer 3.3.3.9 enable
[UPE2-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 3.
[UPE2-bgp-default] ip vpn-instance vpn1
[UPE2-bgp-default-vpn1] peer 2001:3::1 as-number 65430
[UPE2-bgp-default-vpn1] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn1] peer 2001:3::1 enable
[UPE2-bgp-default-ipv6-vpn1] quit
[UPE2-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 4.
[UPE2-bgp-default] ip vpn-instance vpn2
[UPE2-bgp-default-vpn2] peer 2001:4::1 as-number 65440
[UPE2-bgp-default-vpn2] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn2] peer 2001:4::1 enable
[UPE2-bgp-default-ipv6-vpn2] quit
[UPE2-bgp-default-vpn2] quit
[UPE2-bgp-default] quit
5.     Configure CE 3.
<CE3> system-view
[CE3-HundredGigE1/0/1] ipv6 address 2001:3::1 96
[CE3] bgp 65430
[CE3-bgp-default] peer 2001:3::2 as-number 100
[CE3-bgp-default] address-family ipv6 unicast
[CE3-bgp-default-ipv6] peer 2001:3::2 enable
6.     Configure CE 4.
<CE4> system-view
[CE4] interface hundredgige 1/0/1
[CE4-HundredGigE1/0/1] ipv6 address 2001:4::1 96
[CE4-HundredGigE1/0/1] quit
[CE4] bgp 65440
[CE4-bgp-default] peer 2001:4::2 as-number 100
[CE4-bgp-default] address-family ipv6 unicast
[CE4-bgp-default-ipv6] peer 2001:4::2 enable
[CE4-bgp-default-ipv6] import-route direct
[CE4-bgp-default-ipv6] quit
[CE4-bgp-default] quit
7.     Configure SPE 1:
<SPE1> system-view
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
[SPE1] interface hundredgige 1/0/1
[SPE1-HundredGigE1/0/1] ip address 172.1.1.2 24
[SPE1-HundredGigE1/0/1] mpls enable
[SPE1-HundredGigE1/0/1] mpls ldp enable
[SPE1-HundredGigE1/0/1] quit
[SPE1] interface hundredgige 1/0/2
[SPE1-HundredGigE1/0/2] ip address 180.1.1.1 24
[SPE1-HundredGigE1/0/2] mpls enable
[SPE1-HundredGigE1/0/2] mpls ldp enable
[SPE1-HundredGigE1/0/2] quit
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 2 and UPE 1, and specify UPE 1 as a UPE.
[SPE1] bgp 100
[SPE1-bgp-default] peer 1.1.1.9 as-number 100
[SPE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-default] peer 3.3.3.9 as-number 100
[SPE1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp-default] address-family vpnv6
[SPE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 next-hop-local
[SPE1-bgp-default-vpnv6] quit
# Create BGP-VPN instances for VPN instances vpn1 and vpn2, so the VPNv6 routes learned according to the RT attributes can be added into the BGP routing tables of the corresponding VPN instances.
[SPE1-bgp-default] ip vpn-instance vpn1
[SPE1-bgp-default-vpn1] quit
[SPE1-bgp-default] ip vpn-instance vpn2
[SPE1-bgp-default-vpn2] quit
[SPE1-bgp-default] quit
# Advertise to UPE 1 the routes permitted by a routing policy (the routes of CE 3).
[SPE1] ip prefix-list hope index 10 permit 2001:3::1 96
[SPE1] route-policy hope permit node 0
[SPE1-route-policy-hope-0] if-match ip address prefix-list hope
[SPE1-route-policy-hope-0] quit
[SPE1] bgp 100
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe route-policy hope export
8.     Configure SPE 2:
<SPE2> system-view
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
[SPE2] interface hundredgige 1/0/1
[SPE2-HundredGigE1/0/1] ip address 180.1.1.2 24
[SPE2-HundredGigE1/0/1] mpls enable
[SPE2-HundredGigE1/0/1] mpls ldp enable
[SPE2-HundredGigE1/0/1] quit
[SPE2] interface hundredgige 1/0/2
[SPE2-HundredGigE1/0/2] ip address 172.2.1.2 24
[SPE2-HundredGigE1/0/2] mpls enable
[SPE2-HundredGigE1/0/2] mpls ldp enable
[SPE2-HundredGigE1/0/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 1 and UPE 2, and specify UPE 2 as a UPE.
[SPE2] bgp 100
[SPE2-bgp-default] peer 4.4.4.9 as-number 100
[SPE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-default] peer 2.2.2.9 as-number 100
[SPE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp-default] address-family vpnv6
[SPE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 next-hop-local
[SPE2-bgp-default-vpnv6] quit
[SPE2-bgp-default] ip vpn-instance vpn1
[SPE2-bgp-default-vpn1] quit
[SPE2-bgp-default] ip vpn-instance vpn2
[SPE2-bgp-default-vpn2] quit
[SPE2-bgp-default] quit
# Advertise to UPE 2 the routes permitted by a routing policy (the routes of CE 1).
[SPE2] ip prefix-list hope index 10 permit 2001:1::1 96
[SPE2] route-policy hope permit node 0
[SPE2-route-policy-hope-0] if-match ip address prefix-list hope
[SPE2-route-policy-hope-0] quit
[SPE2] bgp 100
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe route-policy hope export
# Verify that CE 1 and CE3 can learn each other's interface routes and can ping each other. CE 2 and CE 4 cannot learn each other's interface routes and cannot ping each other. (Details not shown.)
Example: Configuring an OSPFv3 sham link
As shown in Figure 50, CE 1 and CE 2 belong to VPN 1. Configure an OSPFv3 sham link between PE 1 and PE 2 so traffic between the CEs is forwarded through the MPLS backbone instead of the backdoor link.
Figure 50 Network diagram
Table 25 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
100::1/64
CE 2
HGE1/0/1
120::1/64
HGE1/0/4
20::1/64
HGE1/0/4
30::2/64
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
2.2.2.9/32
Loop1
3::3/128
Loop1
5::5/128
HGE1/0/1
100::2/64
HGE1/0/1
120::2/64
HGE1/0/4
10.1.1.1/24
HGE1/0/5
10.1.1.2/24
Router A
HGE1/0/5
30::1/64
HGE1/0/4
20::2/64
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1.     Configure OSPFv3 on the customer networks:
# Configure conventional OSPFv3 on CE 1, Router A, and CE 2 to advertise addresses of the interfaces (see Table 25). (Details not shown.)
# Set the cost value to 2 for both the link between CE 1 and Router A, and the link between CE 2 and Router A. (Details not shown.)
# Execute the display ipv6 routing-table command to verify that CE 1 and CE 2 have learned the route to each other. (Details not shown.)
2.     Configure IPv6 MPLS L3VPN on the backbone:
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] interface hundredgige 1/0/4
[PE1-HundredGigE1/0/4] ip address 10.1.1.1 24
[PE1-HundredGigE1/0/4] mpls enable
[PE1-HundredGigE1/0/4] mpls ldp enable
[PE1-HundredGigE1/0/4] quit
# Configure PE 1 to take PE 2 as an MP-IBGP peer.
[PE1] bgp 100
# Configure OSPF on PE 1.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface hundredgige 1/0/4
[PE2-HundredGigE1/0/4] ip address 10.1.1.2 24
[PE2-HundredGigE1/0/4] mpls enable
[PE2-HundredGigE1/0/4] mpls ldp enable
[PE2-HundredGigE1/0/4] quit
# Configure PE 2 to take PE 1 as an MP-IBGP peer.
[PE2] bgp 100
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface hundredgige 1/0/1
[PE1-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE1-HundredGigE1/0/1] ipv6 address 100::2 64
[PE1-HundredGigE1/0/1] ospfv3 100 area 1
[PE1-HundredGigE1/0/1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] router-id 100.1.1.1
[PE1-ospfv3-100] domain-id 10
[PE1-ospfv3-100] quit
[PE1] bgp 100
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] quit
[PE2] interface hundredgige 1/0/1
[PE2-HundredGigE1/0/1] ip binding vpn-instance vpn1
[PE2-HundredGigE1/0/1] ipv6 address 120::2 64
[PE2-HundredGigE1/0/1] ospfv3 100 area 1
[PE2-HundredGigE1/0/1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] router-id 120.1.1.1
[PE2-ospfv3-100] domain-id 10
[PE2-ospfv3-100] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE2-bgp-default] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs. Verify that the path to the peer CE is along the OSPFv3 route across the customer networks, instead of the IPv6 BGP route across the backbone. (Details not shown.)
4.     Configure a sham link:
# Configure PE 1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ipv6 address 3::3 128
[PE1-LoopBack1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] area 1
[PE1-ospfv3-100-area-0.0.0.1] sham-link 3::3 5::5
[PE1-ospfv3-100-area-0.0.0.1] quit
# Configure PE 2.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ipv6 address 5::5 128
[PE2-LoopBack1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] area 1
[PE2-ospfv3-100-area-0.0.0.1] sham-link 5::5 3::3
[PE2-ospfv3-100-area-0.0.0.1] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs to verify the following results (details not shown):
·     The path to the peer CE is now along the IPv6 BGP route across the backbone.
·     A route to the sham link destination address exists.
# Execute the display ipv6 routing-table command on the CEs. Verify that the next hop of the OSPFv3 route to the peer CE is the interface connected to the PE (HundredGigE 1/0/1). This means that the VPN traffic to the peer CE is forwarded over the backbone. (Details not shown.)
# Verify that a sham link has been established on PEs, for example, on PE 1.
[PE1] display ospfv3 sham-link
               OSPFv3 Process 100 with Router ID 100.1.1.1
 Sham-link (Area: 0.0.0.1)
 Neighbor ID      State  Instance ID  Destination address
 120.1.1.1        P-2-P  0            5::5
# Verify that the peer state is Full on PE 1.
[PE1] display ospfv3 sham-link verbose
 Source      : 3::3
 Destination : 5::5
 Interface ID: 2147483649
 Neighbor ID : 120.1.1.1, Neighbor state: Full
 Cost: 1  State: P-2-P  Type: Sham  Instance ID: 0
 Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
 Request list: 0  Retransmit list: 0
Example: Configuring BGP AS number substitution
As shown in Figure 51, CE 1 and CE 2 belong to VPN 1, and are connected to PE 1 and PE 2. The two CEs have the same AS number, 600. Configure BGP AS number substitution on the PEs to avoid route loss.
Figure 51 Network diagram
Table 26 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
HGE1/0/1
10:1::2/96
P
Loop0
2.2.2.9/32
HGE1/0/2
100::1/96
HGE1/0/1
20.1.1.2/24
PE 1
Loop0
10.1.1.1/32
HGE1/0/2
30.1.1.1/24
HGE1/0/1
10:1::1/96
PE 2
Loop0
10.1.1.2/32
HGE1/0/2
20.1.1.1/24
HGE1/0/1
10:2::1/96
CE 2
HGE1/0/1
10:2::2/96
HGE1/0/2
30.1.1.2/24
HGE1/0/2
200::1/96
IMPORTANT
IMPORTANT:
1.     Configure basic IPv6 MPLS L3VPN:
¡     Configure OSPF on the MPLS backbone to allow the PEs and P device to learn the routes of the loopback interfaces from each other.
¡     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
¡     Establish an MP-IBGP peer relationship between the PEs to advertise VPN IPv6 routes.
¡     Configure the VPN instance of VPN 1 on PE 1 to allow CE 1 to access the network.
¡     Configure the VPN instance of VPN 1 on PE 2 to allow CE 2 to access the network.
¡     Configure BGP as the PE-CE routing protocol, and redistribute routes of the CEs into the PEs.
For more information about basic IPv6 MPLS L3VPN configurations, see "Example: Configuring IPv6 MPLS L3VPNs."
# Execute the display ipv6 routing-table command on CE 2 to verify that CE 2 has not learned the route to the VPN (100::/96) behind CE 1.
<CE2> display ipv6 routing-table
Destinations : 5 Routes : 5
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 10:2::/96                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : HGE1/0/1                                    Cost      : 0
Destination: 10:2::2/128                                 Protocol  : Direct
Destination: 200::/96                                    Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
# Execute the display ipv6 routing-table command on CE 1 to verify that CE 1 has not learned the route to the VPN behind CE 2. (Details not shown.)
# Execute the display ipv6 routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. This example uses PE 2.
<PE2> display ipv6 routing-table vpn-instance vpn1
Destinations : 6 Routes : 6
Destination: 10:2::1/128                                 Protocol  : Direct
Destination: 100::/96                                    Protocol  : BGP4+
NextHop    : ::FFFF:10.1.1.1                             Preference: 255
Interface  : HGE1/0/2                                    Cost      : 0
Destination: 200::/96                                    Protocol  : BGP4+
NextHop    : 10:2::2                                     Preference: 255
# Enable BGP update packet debugging on PE 2. The output shows that PE 2 has advertised the route for 100::/96, and the AS_PATH is 100 600.
<PE2> terminal monitor
<PE2> terminal logging level 7
<PE2> debugging bgp update vpn-instance vpn1 10:2::2 ipv6
<PE2> refresh bgp all export ipv6 vpn-instance vpn1
*Jun 13 16:12:52:096 2012 PE2 BGP/7/DEBUG:
         BGP_IPV6.vpn1: Send UPDATE to update-group 0 for following destinations:
         Origin       : Incomplete
         AS path      : 100 600
         Next hop     : ::FFFF:10.1.1.1
         100::/96,
*Jun 13 16:12:53:024 2012 PE2 BGP/7/DEBUG:
 BGP.vpn1: Send UPDATE MSG to peer 10:2::2(IPv6-UNC) NextHop: 10:2::1.
# Execute the display bgp routing-table ipv6 peer received-routes command on CE 2 to verify that CE 2 has not received the route to 100::/96.
<CE2> display bgp routing-table ipv6 peer 10:2::1 received-routes
 Total number of routes: 0
2.     Configure BGP AS number substitution:
# Configure BGP AS number substitution on PE 1.
<PE1> system-view
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::2 substitute-as
# Configure BGP AS number substitution on PE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::2 substitute-as
# The output shows that among the routes advertised by PE 2 to CE 2, the AS_PATH of 100::/96 has changed from 100 600 to 100 100.
*Jun 27 18:07:34:420 2013 PE2 BGP/7/DEBUG:
         BGP_IPV6.vpn1: Send UPDATE to peer 10:2::2 for following destinations:
         Origin       : Incomplete
         AS path      : 100 100
         Next hop     : 10:2::1
         100::/96,
# Display again the routing information that CE 2 has received, and the routing table. The output shows that CE 2 has learned the route 100::/96.
 Total number of routes: 1
 BGP local router ID is 12.1.1.3
               a - additional-path
* >e Network : 100::                                    PrefixLen : 96
     NextHop : 10:2::1                                  LocPrf    :
     MED     :
     Path/Ogn: 100 100?
NextHop    : 10:2::1                                     Preference: 255
# Verify that HundredGigE 1/0/2 of CE 1 and HundredGigE 1/0/2 of CE 2 can ping each other. (Details not shown.)
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3. CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
To avoid route loss, configure BGP AS number substitution on PEs.
To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 52 Network diagram
Table 27 Interface and IP address assignment
Device
IP address
Device
IP address
CE 1
Loop0
100::1/96
CE 3
Loop0
200::1/96
HGE1/0/1
10:1::1/96
HGE1/0/1
10:3::1/96
CE 2
HGE1/0/1
10:2::1/96
PE 2
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
HGE1/0/1
10:2::2/96
HGE1/0/1
10:1::2/96
HGE1/0/2
40.1.1.1/24
HGE1/0/2
20.1.1.1/24
HGE1/0/3
20.1.1.2/24
HGE1/0/3
30.1.1.1/24
P
Loop0
3.3.3.9/32
PE 3
Loop0
4.4.4.9/32
HGE1/0/1
30.1.1.2/24
HGE1/0/1
10:3::2/96
HGE1/0/2
40.1.1.2/24
HGE1/0/2
50.1.1.2/24
HGE1/0/3
50.1.1.1/24
IMPORTANT
IMPORTANT:
¡     Configure the VPN instance of VPN 1 on PE 3 to allow CE 3 to access the network.
For more information about basic MPLS L3VPN configurations, see "Example: Configuring IPv6 MPLS L3VPNs."
# Configure BGP AS number substitution on PE 1, PE 2, and PE 3. For more information about the configuration, see "Example: Configuring BGP AS number substitution."
# Display routing information on CE 2. The output shows that CE 2 has learned the route 100::/96 from CE 1. A routing loop has occurred because CE 1 and CE 2 reside in the same site.
<CE2> display bgp routing-table ipv6 peer 10:2::2 received-routes
 Total number of routes: 2
               a - additional-path
     NextHop : 10:2::2                                  LocPrf    :
     MED     :
     Path/Ogn: 100 100?
* >e Network : 200::                                    PrefixLen : 96
     MED     :
     Path/Ogn: 100 100?
3.     Configure BGP SoO attribute:
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
<PE1> system-view
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] peer 10:1::1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] peer 10:2::1 soo 1:100
# PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured. Display the routing table of CE 2. The output shows that the route 100::/96 has been removed.
Destinations : 4 Routes : 4
