| 00-Preface | 100.04 KB |
Preface
This document describes the hardware information and specifications for the MSR 5600 routers, including views, specifications, and LEDs of the routers and their removable components, as well as slot arrangement and interface numbering.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
