06-VPN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command References(V7)-6W40206-VPN Command Reference
05-L2TP commands
05-L2TP commands 198.33 KB
L2TP commands
allow l2tp
Use allow l2tp to configure an L2TP network server (LNS) to accept Layer 2 Tunneling Protocol (L2TP) tunneling requests from an L2TP access concentrator (LAC), and to specify a VT interface for tunnel setup.
Use undo allow to restore the default.
allow l2tp virtual-template virtual-template-number [ remote remote-name ]
undo allow
An LNS denies L2TP tunneling requests from any LACs.
L2TP group view
context-admin
virtual-template virtual-template-number: Specifies a VT interface by its number. An LNS dynamically creates virtual access (VA) interfaces based on the configuration of a VT interface. Each VA interface is used to carry data for a different L2TP session.
The following compatibility matrixes show the value ranges for the VT interface number:
Hardware
Value range
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-AI-20, F5000-AI-40, F5000-V30, F5000-C, F5000-S, F5000-M, F5000-A
1 to 1024
F1000-AI-20, F1000-AI-30, F1000-AI-50, F1000-AI-60, F1000-AI-70, F1000-AI-80, F1000-AI-90
1 to 1024
F1003-L, F1005-L, F1010-L
1 to 1024
F1005, F1010
1 to 1024
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090, F1000-V70
1 to 1024
F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140
1 to 1024
F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332
1 to 1024
F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
1 to 1024
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710
1 to 1024
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711
1 to 1024
LSU3FWCEA0, LSUM1FWCEAB0, LSX1FWCEA1
1 to 1024
LSXM1FWDF1, LSUM1FWDEC0, IM-NGFWX-IV, LSQM1FWDSC0, LSWM1FWD0, LSPM6FWD, LSQM2FWDSC0
1 to 1024
vFW1000, vFW2000
0 to 1023
remote remote-name: Specifies the name of the tunnel peer (LAC) initiating tunneling requests, a case-sensitive string of 1 to 31 characters.
The allow l2tp command is available only on L2TP groups in LNS mode.
Make sure the specified name of the tunnel peer is consistent with the local name configured on the LAC.
If you execute this command multiple times for an L2TP group, the most recent configuration takes effect.
For L2TP group 1, if you do not specify the remote remote-name option, an LNS accepts tunneling requests from any LACs. In this case, L2TP group 1 acts as the default L2TP group. For L2TP groups other than L2TP group 1, the remote remote-name option must be configured.
The allow l2tp command is available only on LNSs.
·     When an LAC that initiates a tunneling request is the tunnel peer configured in an L2TP group, the LNS uses the tunnel parameters configured in this group for tunnel setup.
·     When the LAC is not the tunnel peer configured in any L2TP group, the LNS performs one of the following operations:
¡     Uses the tunnel parameters for the default L2TP group if it exists.
¡     Fails to set up a tunnel with the LAC if the default L2TP group does not exist.
As a best practice, configure a default L2TP group on the LNS in the following cases:
·     LACs (such as hosts with Windows 2000 Beta 2 installed) include blank local names in their tunneling requests.
·     The LNS sets up tunnels with multiple LACs by using the same tunnel parameters.
# Specify L2TP group 1 as the default L2TP group, and specify Virtual-Template 1 for tunnel setup. For L2TP group 2, configure the LNS to accept the L2TP tunneling request initiated by the peer (LAC) named aaa, and specify Virtual-Template 2 for tunnel setup.
[Sysname] l2tp-group 1 mode lns
[Sysname-l2tp1] allow l2tp virtual-template 1
[Sysname-l2tp1] quit
[Sysname] l2tp-group 2 mode lns
[Sysname-l2tp2] allow l2tp virtual-template 2 remote aaa
tunnel name
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) is interface baudrate divided by 1000.
Virtual PPP interface view
context-admin
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Virtual-PPP 10 to 100 kbps.
[Sysname] interface virtual-ppp 10
[Sysname-Virtual-PPP10] bandwidth 100
default
Use default to restore the default settings for a virtual PPP interface.
default
context-admin
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Virtual-PPP 10.
[Sysname-Virtual-PPP10] default
description
The description of an interface is the interface-name plus Interface. For example, the default description of Virtual-PPP254 is Virtual-PPP254 Interface.
context-admin
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of Virtual-PPP 10 to virtual-interface.
[Sysname-Virtual-PPP10] description virtual-interface
display interface virtual-ppp
Use display interface virtual-ppp to display information about virtual PPP interfaces.
display interface [ virtual-ppp [ interface-number ] ] [ brief [ description | down ] ]
context-admin
context-operator
virtual-ppp [ interface-number ]: Specifies an existing virtual PPP interface by its number in the range of 0 to 255. If you do not specify the virtual-ppp keyword, this command displays information about all interfaces. If you specify the virtual-ppp keyword but you do not specify an interface, this command displays information about all virtual PPP interfaces.
down: Displays information about the interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in any state.
# Display detailed information about Virtual-PPP 10.
<Sysname> display interface virtual-ppp 10
Virtual-PPP10
Line protocol state: DOWN
Description: Virtual-PPP10 Interface
Bandwidth: 100000kbps
Hold timer: 10 seconds, retry times: 5
Internet address: 10.0.0.1/24 (primary)
Link layer protocol: PPP
LCP: initial
Physical: L2TP, baudrate: 100000000 bps
Input: 154 packets, 1880 bytes, 0 drops
Output: 155 packets, 1875 bytes, 0 drops
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is up both administratively and physically.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Bandwidth
Expected bandwidth of the interface.
Hold timer
Interval in seconds for the interface to send keepalive packets.
retry times
Maximum number of keepalive retransmission attempts. A link is removed after the maximum number of retransmission attempts is reached.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
Link layer protocol
Link layer protocol of the interface: PPP.
Physical
Physical type of the interface: L2TP.
baudrate
Baud rate of the interface.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Average rate of inbound traffic in the last 300 seconds.
Average rate of outbound traffic in the last 300 seconds.
Total number of inbound packets, total number of inbound bytes, and total number of dropped inbound packets.
Total number of outbound packets, total number of outbound bytes, and total number of dropped outbound packets.
# Display summary information about virtual PPP interface Virtual-PPP 10.
<Sysname> display interface virtual-ppp 10 brief
Protocol: (s) - spoofing
VPPP10               ADM  DOWN     10.0.0.1
# Display information about the virtual PPP interfaces in physically down state and the causes.
<Sysname> display interface virtual-ppp brief down
VPPP9                ADM  Administratively
VPPP10               ADM  Administratively
VPPP12               ADM  Administratively
# Display summary information about virtual PPP interface Virtual-PPP 10, including the complete interface description.
<Sysname> display interface Virtual-PPP 10 brief description
Summary information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
display l2tp session
Use display l2tp session to display information about L2TP sessions.
display l2tp session [ statistics ]
context-admin
context-operator
statistics: Displays statistics for L2TP sessions.
# Display statistics for L2TP sessions.
<Sysname> display l2tp session statistics
Total number of sessions: 1
# Display information about L2TP sessions.
LocalSID      RemoteSID      LocalTID      State
89            36245          10878         Established
LocalSID
Local session ID.
RemoteSID
Remote session ID.
LocalTID
Local tunnel ID.
Session state:
·     Idle.
·     Wait-tunnel—Waits for the tunnel to be established.
·     Wait-reply—Waits for an Incoming-Call-Reply (ICRP) message indicating the call is accepted.
·     Wait-connect—Waits for an Incoming-Call-Connected (ICCN) message.
·     Established.
display l2tp session temporary
Use display l2tp session temporary to display information about temporary L2TP sessions.
context-admin
context-operator
# Display information about temporary L2TP sessions.
<Sysname> display l2tp session temporary
Total number of temporary sessions: 6
2298        0            19699       Wait-tunnel
42805       0            19699       Wait-tunnel
17777       0            19699       Wait-tunnel
58284       0            19699       Wait-tunnel
33256       0            19699       Wait-tunnel
8228        0            19699       Wait-tunnel
LocalSID
Local session ID.
RemoteSID
Remote session ID.
LocalTID
Local tunnel ID.
Session state:
·     Idle.
·     Wait-reply—Waits for an ICRP message indicating the call is accepted.
·     Wait-connect—Waits for an ICCN message.
display l2tp tunnel
Use display l2tp tunnel to display information about L2TP tunnels.
display l2tp tunnel [ statistics ]
context-admin
context-operator
statistics: Displays statistics for L2TP tunnels.
# Display statistics for L2TP tunnels.
<Sysname> display l2tp tunnel statistics
Total number of tunnels: 1
# Display information about L2TP tunnels.
LocalTID RemoteTID State         Sessions RemoteAddress    RemotePort RemoteName
10878    21        Established   1        20.1.1.2         1701       lns
Table 5 Command output
LocalTID
Local tunnel ID.
RemoteTID
Remote tunnel ID.
Tunnel state:
·     Idle.
·     Wait-reply.
·     Wait-connect.
·     Established.
·     Stopping.
Sessions
Number of sessions within the tunnel.
RemoteAddress
IP address of the peer.
RemotePort
UDP port number of the peer.
RemoteName
Name of the tunnel peer.
reset l2tp tunnel
display l2tp va-pool
Use display l2tp va-pool to display information about L2TP VA pools.
context-admin
context-operator
# Display information about L2TP VA pools.
<Sysname> display l2tp va-pool
VT interface          Size      Unused      State
Virtual-Template1     1000      900         Normal
Table 6 Command output
VT interface
VT interface that uses the VA pool.
Size
VA pool capacity set for L2TP users.
Unused
VA pool capacity available for L2TP users.
Current state of the VA pool:
·     Creating—The VA pool is being created.
·     Destroying—The VA pool is being removed.
·     Normal—The VA pool has been created.
l2tp virtual-template va-pool
Use interface virtual-ppp to create a virtual PPP interface and enter its view, or enter the view of an existing virtual PPP interface.
Use undo interface virtual-ppp to delete a virtual PPP interface.
interface virtual-ppp interface-number
undo interface virtual-ppp interface-number
No virtual PPP interface exists.
context-admin
interface-number: Specifies a virtual PPP interface by its number in the range of 0 to 255.
A virtual PPP interface is required on the LAC for establishing an LAC-auto-initiated L2TP tunnel.
# Create Virtual-PPP 10 and enter its view.
ip dscp
Use ip dscp to set the DSCP value of L2TP packets.
Use undo ip dscp to restore the default.
ip dscp dscp-value
undo ip dscp
The DSCP value of L2TP packets is 0.
L2TP group view
context-admin
dscp-value: Specifies the DSCP value of L2TP packets, in the range of 0 to 63.
The DSCP field is the IP ToS byte. This field marks the priority of IP packets for forwarding. This command sets the DSCP value for the IP packet when L2TP encapsulates a PPP frame into an IP packet.
# Set the DSCP value of L2TP packets to 50.
[Sysname] l2tp-group 1 mode lac
[Sysname-l2tp1] ip dscp 50
l2tp enable
Use l2tp enable to enable L2TP.
Use undo l2tp enable to disable L2TP.
l2tp enable
undo l2tp enable
L2TP is disabled.
context-admin
For L2TP configurations to take effect, you must enable L2TP.
# Enable L2TP.
[Sysname] l2tp enable
l2tp icrq-limit
Use l2tp icrq-limit to set the maximum number of incoming call request (ICRQ) packets that the LNS can process per second.
Use undo l2tp icrq-limit to restore the default.
l2tp icrq-limit number
The maximum number of ICRQ packets that the LNS can process per second is not limited.
context-admin
number: Specifies the ICRQ packet processing limit in the range of 1 to 1000.
To avoid device performance degradation and make sure the LNS can process ICRQ requests correctly, use this command to adjust the ICRQ packet processing rate limit.
# Set the maximum number of ICRQ packets that the LNS can process per second to 200.
[Sysname] l2tp icrq-limit 200
Use l2tp virtual-template va-pool to create a VA pool.
Use undo l2tp virtual-template va-pool to delete a VA pool.
l2tp virtual-template template-number va-pool va-volume
undo l2tp virtual-template template-number va-pool
No VA pool exists.
context-admin
virtual-template template-number: Specifies an existing VT interface by its number to use the VA pool.
va-pool va-volume: Specifies the maximum number of VA interfaces contained in the VA pool, in the range of 1 to 65534.
The LNS creates a VA interface for an L2TP session to exchange packets with the LAC, and it deletes the VA interface when the user goes offline. Creating and deleting VA interfaces take time. If a large number of users are coming online or going offline, the performance of L2TP connection establishment and termination will be degraded.
You can configure a VA pool to improve the performance. A VA pool contains a group of VA interfaces. The LNS selects a VA interface from the pool for a requesting user and places the interface back to the VA pool when the user goes offline. This mechanism speeds up the establishment and termination of L2TP connections. When a VA pool is exhausted, the system still creates a VA interface for an L2TP connection and deletes it when the user goes offline.
When you configure a VA pool, follow these guidelines:
·     A VT interface can be associated with only one VA pool. To change the capacity of a VA pool, delete the previous configuration, and reconfigure the VA pool.
·     Creating or deleting a VA pool takes time. During the process of creating or deleting a VA pool, users can come online or go offline, but the VA pool does not take effect.
·     The system might create a VA pool that contains VA interfaces less than the specified number because of insufficient resources. In this case, you can use the display l2tp va-pool command to view the number of available VA interfaces and current state of the VA pool.
·     Create a VA pool with an appropriate capacity, because a VA pool occupies much system memory.
·     Deleting a VA pool does not log off the users who are using VA interfaces in the VA pool.
# Create a VA pool with a capacity of 1000 VA interfaces for Virtual-template 2.
[Sysname] l2tp virtual-template 2 va-pool 1000
l2tp-auto-client
Use l2tp-auto-client to trigger an LAC to automatically establish an L2TP tunnel.
Use undo l2tp-auto-client to delete the automatically established L2TP tunnel.
l2tp-auto-client l2tp-group group-number
An LAC does not automatically establish an L2TP tunnel.
context-admin
l2tp-group group-number: Specifies an L2TP group by its number in the range of 1 to 65535. The LAC uses tunnel parameters of the L2TP group to establish the tunnel.
The L2TP group specified must be an existing one in LAC mode.
An L2TP tunnel automatically established in LAC-auto-initiated mode exists until you delete the tunnel by using the undo l2tp-auto-client or undo l2tp-group group-number command.
# Trigger the LAC to automatically establish an L2TP tunnel by using the tunnel parameters of L2TP group 10.
[Sysname-Virtual-PPP1] l2tp-auto-client l2tp-group 10
l2tp-group
l2tp-group
Use l2tp-group to create an L2TP group and enter its view, or enter the view of an existing L2TP group.
Use undo l2tp-group to delete an L2TP group.
l2tp-group group-number [ mode { lac | lns } ]
No L2TP group exists.
context-admin
mode: Specifies a mode for the L2TP group.
lac: Specifies the LAC mode.
lns: Specifies the LNS mode.
To create a new L2TP group, you must specify the mode keyword. To enter the view of an existing L2TP group, you do not need to specify this keyword.
In L2TP group view, you can configure L2TP tunnel parameters, such as tunnel authentication and flow control.
A device can have L2TP groups in both LAC and LNS modes at the same time.
# Create L2TP group 2 in LAC mode, and enter its view.
[Sysname] l2tp-group 2 mode lac
[Sysname-l2tp2]
allow l2tp
lns-ip
user
lns-ip
Use lns-ip to specify LNS IP addresses on an LAC.
Use undo lns-ip to remove the specified LNS IP addresses on an LAC.
lns-ip { ip-address }&<1-5>
undo lns-ip
No LNS IP addresses are specified on an LAC.
L2TP group view
context-admin
{ ip-address }&<1-5>: Specifies LNS IP addresses. &<1-5> indicates that you can enter a maximum of five IP addresses.
The LAC initiates an L2TP tunneling request to its specified LNSs consecutively in their configuration order until it receives an acknowledgment from an LNS. The LNS then becomes the tunnel peer.
The lns-ip command is available only on L2TP groups in LAC mode.
# Specify the LNS IP address as 202.1.1.1.
[Sysname-l2tp1] lns-ip 202.1.1.1
mtu
Use mtu to set the MTU size of an interface.
mtu size
undo mtu
The MTU size of a virtual PPP interface is 1500 bytes.
context-admin
size: Specifies the MTU size in bytes. The value range is 128 to 1500.
The MTU size of an interface affects the fragmentation and reassembly of IP packets on the interface.
For the configured MTU size to take effect, you must execute the shutdown command and then the undo shutdown command on the interface.
# Set the MTU size of Virtual-PPP 10 to 1400 bytes.
[Sysname-Virtual-PPP10] mtu 1400
ppp access-control enable
Use ppp access-control enable to enable L2TP-based EAD.
Use undo ppp access-control enable to disable L2TP-based EAD.
L2TP-based EAD is disabled.
VT interface view
context-admin
This command does not apply to PPP sessions that already exist on the VT interface. It only applies to newly created PPP sessions on the VT interface.
Different ACLs can be used for different users if the VT interface is used as the access interface for the LNS.
L2TP-based EAD enables the LNS to transparently pass CAMS/IMC packets to the iNode client to inform the client of EAD server information, such as the IP address.
# Enable L2TP-based EAD.
[Sysname] interface virtual-template 10
[Sysname-Virtual-Template10] ppp access-control enable
reset counters interface virtual-ppp
Use reset counters interface virtual-ppp to clear the statistics for virtual PPP interfaces.
reset counters interface [ virtual-ppp [ interface-number ] ]
context-admin
virtual-ppp [ interface-number ]: Specifies a virtual PPP interface by its number in the range of 0 to 255. If you specify neither virtual-ppp nor interface-number, this command clears the statistics for all interfaces. If you specify virtual-ppp but not interface-number, this command clears the statistics for all virtual PPP interfaces. If you specify both virtual-ppp and interface-number, this command clears the statistics for the specified virtual PPP interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
# Clear the statistics for Virtual-PPP 10.
<Sysname> reset counters interface virtual-ppp 10
reset l2tp tunnel
Use reset l2tp tunnel to disconnect tunnels and all sessions within the tunnels.
reset l2tp tunnel { id tunnel-id | name remote-name }
context-admin
id tunnel-id: Specifies a tunnel by its local ID in the range of 1 to 65535.
name remote-name: Specifies L2TP tunnels by the tunnel peer name, a case-sensitive string of 1 to 31 characters.
When the number of user connections is 0 or a network fault occurs, you can disconnect the L2TP tunnel by using this command on either the LAC or LNS. After the tunnel is disconnected, all sessions within it are disconnected.
If you specify a tunnel peer name, all tunnels with the tunnel peer name will be disconnected. If no tunnel with the tunnel peer name exists, nothing happens.
A tunnel disconnected by force can be re-established when a client makes a call.
# Disconnect all tunnels with the tunnel peer name of aaa.
<Sysname> reset l2tp tunnel name aaa
display l2tp tunnel
shutdown
Use shutdown to shut down a virtual PPP interface.
Use undo shutdown to bring up a virtual PPP interface.
shutdown
A virtual PPP interface is up.
context-admin
# Shut down Virtual-PPP 10.
[Sysname-Virtual-PPP10] shutdown
source-ip
Use source-ip to configure the source IP address of L2TP tunnel packets.
Use undo source-ip to restore the default.
source-ip ip-address
undo source-ip
The source IP address of L2TP tunnel packets is the IP address of the egress interface.
L2TP group view
context-admin
ip-address: Specifies the source IP address of L2TP tunnel packets.
This command is available only on an L2TP group in LAC mode.
For high availability, as a best practice, use the IP address of a loopback interface as the source IP address of L2TP tunnel packets.
# Configure the source IP address of L2TP tunnel packets as 2.2.2.2.
[Sysname-l2tp1] source-ip 2.2.2.2
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
context-admin
seconds: Specifies the interval at which the LAC or the LNS sends keepalive packets, in the range of 0 to 32767 seconds.
A virtual PPP interface sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface fails to receive keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 20 seconds for Virtual-PPP 10.
[Sysname-Virtual-PPP10] timer-hold 20
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5.
context-admin
retries: Specifies the maximum number of keepalive attempts in the range of 1 to 255.
To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for Virtual-PPP 10.
[Sysname-Virtual-PPP10] timer-hold retry 10
timer-hold
Use tunnel authentication to enable L2TP tunnel authentication.
Use undo tunnel authentication to disable L2TP tunnel authentication.
L2TP tunnel authentication is enabled.
L2TP group view
context-admin
Tunnel authentication prevents the local end from establishing L2TP tunnels with illegal remote ends.
You can enable tunnel authentication on both sides or either side.
To ensure a successful tunnel establishment when tunnel authentication is enabled on both sides or either side, set the same non-null key on the LAC and the LNS. To set the tunnel authentication key, use the tunnel password command.
When neither side is enabled with tunnel authentication, the key settings of the LAC and the LNS do not affect the tunnel establishment.
For tunnel security, enable tunnel authentication.
# Enable L2TP tunnel authentication.
[Sysname-l2tp1] tunnel authentication
tunnel password
tunnel avp-hidden
Use tunnel avp-hidden to enable transferring AVP data in hidden mode.
Use undo tunnel avp-hidden to restore the default.
tunnel avp-hidden
AVP data is transferred over the tunnel in plaintext mode.
L2TP group view
context-admin
L2TP uses AVPs to transmit tunnel negotiation parameters, session negotiation parameters, and user authentication information. This feature can hide sensitive AVP data, such as user passwords. This feature encrypts AVP data with the key configured by using the tunnel password command before transmission.
The tunnel avp-hidden command can be configured for L2TP groups in both LAC and LNS modes. However, it does not take effect on L2TP groups in LNS mode.
For this command to take effect, you must enable tunnel authentication by using the tunnel authentication command.
# Enable transferring AVP data in hidden mode.
[Sysname-l2tp1] tunnel avp-hidden
tunnel password
tunnel flow-control
Use tunnel flow-control to enable L2TP session flow control.
Use undo tunnel flow-control to disable L2TP session flow control.
tunnel flow-control
L2TP session flow control is disabled.
L2TP group view
context-admin
This feature adds sequence numbers to transmitted packets and uses them to reorder packets arriving out of order and to detect lost packets.
This feature takes effect on both sent and received L2TP data messages. The L2TP sessions support this feature if either the LAC or LNS is enabled with this feature.
When the device acts as an LAC, a change in the flow control status on the LNS causes the same change in the flow control status of L2TP sessions. When the device acts as an LNS, a change in the flow control status on the LAC does not affect the flow control status of L2TP sessions.
# Enable L2TP session flow control.
[Sysname-l2tp1] tunnel flow-control
tunnel name
Use tunnel name to specify the local tunnel name.
Use undo tunnel name to restore the default.
tunnel name name
undo tunnel name
The local tunnel name is the device name. For more information about the device name, see Fundamentals Configuration Guide.
L2TP group view
context-admin
name: Specifies the local tunnel name, a case-sensitive string of 1 to 31 characters.
# Specify the local tunnel name as itsme.
[Sysname-l2tp1] tunnel name itsme
sysname (Fundamentals Command Reference)
tunnel password
Use tunnel password to configure the key for tunnel authentication.
Use undo tunnel password to restore the default.
tunnel password { cipher | simple } string
No key is configured for tunnel authentication.
L2TP group view
context-admin
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
For the tunnel authentication key change to take effect, change the tunnel authentication key before tunnel negotiation is performed.
# Configure the key for tunnel authentication to a plaintext key yougotit.
[Sysname-l2tp1] tunnel password simple yougotit
tunnel timer hello
Use tunnel timer hello to set the Hello interval.
Use undo tunnel timer hello to restore the default.
tunnel timer hello hello-interval
The Hello interval is 60 seconds.
L2TP group view
context-admin
hello-interval: Specifies the interval at which the LAC or the LNS sends Hello packets, in the range of 60 to 1000 seconds.
The device sends Hello packets at the set interval. This prevents the L2TP tunnels and sessions from being removed due to timeouts.
You can set different Hello intervals for the LNS and LAC.
# Set the Hello interval to 90 seconds.
[Sysname-l2tp1] tunnel timer hello 90
tunnel window receive
Use tunnel window receive to set the receiving window size for an L2TP tunnel.
Use undo tunnel window receive to restore the default.
tunnel window receive size
The receiving window size for an L2TP tunnel is 1024.
L2TP group view
context-admin
size: Specifies the receiving window size in the range of 1 to 5000. It is the number of packets that can be buffered at the local end.
To enable the device to process a larger number of disordered packets, use this command to enlarge the receiving window size for an L2TP tunnel.
The device uses a receiving window to reorder disordered packets based on packet sequence numbers.
If the sequence number of a packet is within the receiving window but does not equal the minimum value of the window, the device performs the following operations:
1.     The device buffers the packet.
2.     The minimum value and maximum value of the receiving window increment by one.
3.     The device continues to check the next arriving packet.
If the sequence number of a packet equals the minimum value of the receiving window, the device performs the following operations:
1.     The device processes the packet.
3.     The device checks buffered packets for a packet with the sequence number equal to the new minimum value of the receiving window.
4.     If no required packet is found, the device checks the next arriving packet.
If the sequence number of a packet is not within the receiving window, the device drops the packet.
In the L2TP tunnel establishment process, the device uses the value specified in L2TP group view as the receiving window size.
Changing the receiving window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
# Set the receiving window size for L2TP group 1 to 128.
[Sysname-l2tp1] tunnel window receive 128
tunnel window send
tunnel window send
Use tunnel window send to set the sending window size for an L2TP tunnel.
Use undo tunnel window send to restore the default.
tunnel window send size
The sending window size for an L2TP tunnel is 0, which means using the value of the receiving window size carried in messages sent by the peer end in the tunnel establishment process.
L2TP group view
context-admin
size: Specifies the sending window size for an L2TP tunnel, in the range of 0 to 1024. It is the maximum number of packets the device can send to a peer end when the device receives no response from the peer end. If the messages from the peer end carry no receiving window size in the tunnel establishment process, the sending window size for the device is 4.
The packet processing capability of a peer end might mismatch the receiving window size of the peer end in some networks. For example, the actual packet processing capability of the peer end is 10, but the receiving window size of the peer end is 20. To ensure stable L2TP services, you can adjust the sending window size for the device to match the actual packet processing capability of the peer end.
The sending window size set in L2TP group view is obtained in the L2TP tunnel establishment process.
·     If the sending window size is 0, the device uses the default sending window size.
·     If the sending window size is not 0, the device uses the specified value as the sending window size.
Changing the sending window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
# Set the sending window size for L2TP group 1 to 128.
[Sysname-l2tp1] tunnel window send 128
user
Use user to configure the condition for the LAC to initiate tunneling requests.
Use undo user to restore the default.
user { domain domain-name | fullusername user-name }
undo user
No condition is configured for the LAC to initiate tunneling requests.
L2TP group view
context-admin
domain domain-name: Configures the LAC to initiate tunneling requests to the LNS when the domain name of a user matches a configured domain name. The domain-name argument represents the domain name of the user and is a case-insensitive string of 1 to 24 characters.
fullusername user-name: Configures the LAC to initiate tunneling requests to the LNS when the username of a user matches a configured full username. The domain-name argument represents the username of the user and is a case-sensitive string of 1 to 255 characters.
The LAC initiates tunneling requests to the LNS only when the domain name or the username of a user matches a configured domain name or a configured full username.
This command is available only on L2TP groups in LAC mode.
# Configure the LAC to initiate tunneling requests to the LNS when the username of the user is [email protected].
[Sysname-l2tp1] user fullusername [email protected]
vpn-instance
Use vpn-instance to assign a tunnel peer to a VPN.
Use undo vpn-instance to restore the default.
undo vpn-instance
A tunnel peer belongs to the public network.
L2TP group view
context-admin
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
This command enables the device to transmit L2TP control messages and data messages in the specified VPN by searching the routing table in that VPN.
When one L2TP endpoint is in a VPN, assign the peer endpoint to the VPN for correct packet forwarding between the two endpoints.
The tunnel peer and the physical port connecting to the tunnel peer should belong to the same VPN. The VPN to which this physical port belongs is configured by using the ip binding vpn-instance command.
The specified VPN must already exist.
# Assign the tunnel peer to VPN vpn1.
<Sysname>system-view
[Sysname-l2tp1] vpn-instance vpn1
ip vpn-instance (VPN Command Reference)
ip binding vpn-instance (VPN Command Reference)
