04-DPI Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command References(V7)-6W40204-DPI Command Reference
09-WAF commands
09-WAF commands 140.55 KB
WAF commands
The following compatibility matrix shows the support of hardware platforms for WAF:
Hardware
WAF compatibility
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-AI-20, F5000-AI-40, F5000-V30, F5000-C, F5000-S, F5000-M, F5000-A
Yes
F1000-AI-20, F1000-AI-30, F1000-AI-50, F1000-AI-60, F1000-AI-70, F1000-AI-80, F1000-AI-90
Yes
F1003-L, F1005-L, F1010-L
No
F1005, F1010
No
F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090, F1000-V70
Yes
F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140
No
F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332
Yes
F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614
Yes
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK710
No
F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK711
Yes
LSU3FWCEA0, LSUM1FWCEAB0, LSX1FWCEA1
Yes
LSXM1FWDF1, LSUM1FWDEC0, IM-NGFWX-IV, LSQM1FWDSC0, LSWM1FWD0, LSPM6FWD, LSQM2FWDSC0
Yes
vFW1000, vFW2000
Yes
action
Use action to configure the action criterion for WAF signature filtering in a WAF policy.
Use undo action to restore the default.
action { block-source | drop | permit | reset } *
undo action
The action attribute is not used for WAF signature filtering.
WAF policy view
context-admin
block-source: Specifies the block source action.
drop: Specifies the drop action.
permit: Specifies the permit action.
reset: Specifies the reset action.
This command filters the WAF signatures that a WAF policy uses based on the actions associated with the signatures.
You can repeat this command to specify multiple actions in an action criterion. The WAF policy uses a WAF signature if the signature is associated with any of the specified actions.
You cannot use this command during the signature update.
# Configure WAF policy test-policy to use WAF signatures associated with the drop or reset action.
[Sysname] waf policy test-policy
[Sysname-waf-policy-test-policy] action drop reset
display waf policy
attack-category
Use attack-category to specify an attack category criterion to filter WAF signatures in a WAF policy.
Use undo attack-category to delete an attack category criterion.
attack-category { category [ sub-category subcategory ] | all}
undo attack-category { category [ sub-category subcategory | all] }
The attack category attribute is not used for WAF signature filtering.
WAF policy view
context-admin
category: Specifies an attack category by its name. Category names are case insensitive. To view the names of attack categories, enter a question mark (?) after the attack-category keyword.
sub-category subcategory: Specifies a subcategory of the attack category. Subcategory names are case insensitive. To view the names of supported subcategories, enter a question mark (?) after the sub-category keyword. If you do not specify a subcategory, this command matches any WAF signature with a subcategory of the specified attack category.
all: Specifies all attack categories.
This command filters the WAF signatures that a WAF policy uses based on the attack category attribute of the signatures.
You can execute this command multiple times to specify multiple attack category criteria in a WAF policy. The WAF policy uses a WAF signature if the signature matches any of the configured  attack category criteria.
# Configure WAF policy test-policy to use WAF signatures with the SQLInjection attack subcategory of the Vulnerability attack category.
[Sysname-waf-policy-test-policy] attack-category Vulnerability sub-category SQLInjection
display waf policy
display waf policy
Use display waf policy to display WAF policy information.
display waf policy policy-name
context-admin
context-operator
policy-name: Specifies a WAF policy by its name, a case-insensitive string of 1 to 63 characters.
# Display information about WAF policy aa.
<Sysname> display waf policy aa
Protected website: a
  Domain: www.baidu.com
  IP address: 1.1.1.1
  Port: 1
 Protected website: b
  Domain: www.ali.com
  IP address: 1.1.1.2
  Port: 2
Applied CC defense policy: a
Total signature count        : 100
 Pre-defined signature count  : 10
 User-defined signature count: 90
Flags:
  B: Block-source  D: Drop  P: Permit  Rs: Reset  Rd: Redirect  C: Capture  L: L
ogging
  Pre: pre-defined  User: user-defined
Type SigID    Target          SubTarget       Severity Direction Category
  SubCategory     Status  Action
Pre  23723     OperationSystem Any             High     Any       Vulnerability
  RemoteCodeExecu Enable  RsL
Pre  24728     OperationSystem Any             Critical Server    Malware
  Backdoor        Enable  DL
Pre  25066     OperationSystem Any             Critical Any       Malware
  Backdoor        Enable  DL
Pre  25067     OperationSystem Any             Critical Server    Malware
  Backdoor        Enable  RsL
Pre  25824     OperationSystem Any             Critical Server    Vulnerability
  Overflow        Enable  RsL
---- More ----
Protected website
Name of the protected website.
Domain
Domain name of the protected website.
IP address
IPv4 address of the protected website.
Port
Port number of the protected website.
CC defense policy associated in the WAF module.
Total number of WAF signatures.
Total number of predefined WAF signatures.
Total number of user-defined signatures.
Type of the WAF signature:
·     Pre—Predefined WAF signatures.
·     User—User-defined signatures.
SigID
Signature ID.
Target
Attacked target
SubTarget
Attacked subtarget.
Severity
Attack severity level of the signature, Low, Medium, High, or Critical.
Category
Attack category of the signature.
SubCategory
Attack subcategory of the signature.
Status
Status of the WAF signature, Enabled or Disabled.
Action
Actions for matching packets:
·     Block-source—Drops matching packets and adds the sources of the packets to the IP blacklist.
·     Drop—Drops matching packets.
·     Permit—Permits matching packets to pass.
·     Reset—Closes the TCP or UDP connections for matching packets by sending TCP reset messages or ICMP port unreachable messages.
·     Redirect—Redirects matching packets to a webpage.
·     Capture—Captures matching packets.
·     Logging—Logs matching packets.
display waf signature
Use display waf signature to display brief WAF signature information.
display waf signature [ pre-defined ] [ direction { any | to-client | to-server } ] [ category category-name | fidelity { high | low | medium } | severity { critical | high | low | medium } ] *
context-admin
context-operator
pre-defined: Specifies predefined WAF signatures.
user-defined: Specifies user-defined WAF signatures.
direction { any | to-client | to-server }: Specifies a direction attribute. If you do not specify a direction attribute, this command displays WAF signatures with any direction attribute.
·     any: Specifies both directions of a session.
·     to-server: Specifies the client to server direction of a session.
·     to-client: Specifies the server to client direction of a session.
category category-name: Specifies an attack category. To view the names of supported attack categories, enter a question mark (?) after the category keyword. If you do not specify an attack category, this command displays WAF signatures for all attack categories.
fidelity { high | low | medium }: Specifies a fidelity level. If you do not specify a fidelity level, this command displays WAF signatures of all fidelity levels. The fidelity level indicates the attack detection accuracy.
·     low: Specifies the low fidelity.
·     medium: Specifies the medium fidelity.
·     high: Specifies the high fidelity.
severity { critical | high | low | medium }: Specifies an attack severity level. If you do not specify a severity level, this command displays WAF signatures for all severity levels of attacks.
·     low: Specifies the low severity level.
·     medium: Specifies the medium severity level.
·     high: Specifies the high severity level.
·     critical: Specifies the critical severity level.
If you do not specify any options, this command displays all WAF signatures.
# Display predefined WAF signatures of the medium fidelity level.
<Sysname> display waf signature pre-defined fidelity medium
Pre-defined  signatures total:88        failed:0
Flag:
  Pre: predefined   User: user-defined
Type SigID      Direction Severity Fidelity Category      Protocol SigName
Pre  3295       To-client Critical Medium   Vulnerability TCP
Pre  5379       To-client Critical Medium   Vulnerability TCP
Pre  6017       To-client Critical Medium   Vulnerability TCP
Pre  7453       To-server High     Medium   Other         TCP
Pre  10033      To-client High     Medium   Vulnerability TCP
Pre  23227      To-server Medium   Medium   Vulnerability TCP
Pre  23285      To-server Medium   Medium   Vulnerability TCP
Pre  23309      To-server Medium   Medium   Vulnerability TCP
Pre  23482      To-server High     Medium   Vulnerability TCP
Pre  23530      To-server High     Medium   Vulnerability TCP
Pre  23666      To-server High     Medium   Vulnerability TCP
Pre  23722      To-server Medium   Medium   Vulnerability TCP
Pre  23747      To-server Medium   Medium   Vulnerability TCP
Pre  24346      To-client Medium   Medium   Vulnerability TCP
Pre  25044      To-server High     Medium   Vulnerability TCP
Pre  25086      To-server High     Medium   Vulnerability TCP
Pre  25100      To-server High     Medium   Vulnerability TCP
---- More ----
# Display WAF signatures of the high attack severity level.
<Sysname> display waf signature severity high
Total signatures        :45        failed:0
 Pre-defined  signatures total:45        failed:0
 User-defined signatures total:0         failed:0
Flag:
Pre  23192      To-server High     High     Vulnerability TCP
Pre  23448      To-server High     High     Vulnerability TCP
Pre  23474      To-server High     Low      Vulnerability TCP
Pre  24485      To-server High     High     Vulnerability TCP
Pre  30781      To-server High     Medium   Vulnerability TCP
Pre  30807      To-server High     Medium   Vulnerability TCP
Pre  30851      To-server High     Medium   Vulnerability TCP
---- More ----
Total signatures
Pre-defined signature total
User-defined signature total
Total number of user-defined WAF signatures.
SigID
Signature ID.
Direction
Direction attribute of the signature:
·     any—Specifies both directions of a session.
·     To-server—Specifies the client to server direction of a session.
·     To-client—Specifies the server to client direction of a session.
Severity
Fidelity
Fidelity level of the signature, Low, Medium, or High.
Category
Protocol
Protocol attribute of the signature.
SigName
Predefined signature name.
display waf signature library
Use display waf signature library to display WAF signature library information.
context-admin
context-operator
# Display WAF signature library information.
<Sysname> display waf signature library
WAF signature library information:
Type     SigVersion         ReleaseTime               Size (bytes)
Current  1.02               Fri Sep 13 09:05:35 2014  71594
Last     -                  -                         -
Factory  1.00               Fri Sep 11 09:05:35 2014  71394
Version type of the WAF signature library:
·     Current—Current version.
·     Last—Previous version.
·     Factory—Factory default version.
SigVersion
Version number of the WAF signature library.
ReleaseTime
Release time of the WAF signature library.
Size
Size of the WAF signature file in bytes.
Use display waf signature pre-defined to display detailed information about a predefined WAF signature.
display waf signature pre-defined signature-id
context-admin
context-operator
signature-id: Specifies the signature ID. The value range is 1 to 536870911.
# Display detailed information about predefined WAF signature 3295.
<Sysname> display waf signature pre-defined 3295
 Type        : Pre-defined
 Signature ID: 3295
 Status      : Enable
 Action      : Permit & Logging
 Protocol    : TCP
 Severity    : Critical
 Fidelity    : Medium
 Direction   : To-client
 Category    : Vulnerability
 Reference   :
 Description : WEB_SERVER_Possible_HTTP_503_XSS_Attempt_(Internal_Source)
Signature ID
Signature ID.
Status
Action
Name
Name of the WAF signature.
Protocol
Severity
Attack severity, Low, Medium, High, or Critical.
Fidelity
Direction
Category
Reference
Reference for the signature.
Description for the signature.
object-dir
Use object-dir to specify a direction criterion to filter WAF signatures in a WAF policy.
Use undo object-dir to restore the default.
object-dir { client | server } *
undo object-dir
The direction attribute is not used for WAF signature filtering.
WAF policy view
context-admin
client: Specifies the server to client direction.
server: Specifies the client to server direction.
Each WAF signature has a direction attribute that defines the traffic direction to which the signature applies. The direction attribute values include To-server, To-client, and Any.
WAF signatures with the Any direction attribute are always used by a WAF policy, regardless of the settings of this command. For example, if you configure the object-dir client command for a WAF policy, the policy uses WAF signatures with both the To-client and Any direction attributes.
If you execute this command in a WAF policy multiple times, the most recent configuration takes effect.
# Configure WAF policy test-policy to use WAF signatures with the To-client and Any direction attributes.
[Sysname-waf-policy-test-policy] object-dir client
override-current
Use override-current to configure the device to overwrite the current WAF signature library without backing up the library during an automatic signature library update.
Use undo override-current to restore the default.
override-current
Before performing an automatic WAF signature library update, the device backs up the current WAF signature library as the previous version.
Automatic WAF signature library update configuration view
context-admin
Backing up the current WAF signature library requires additional storage space but enables signature library rollback. As a best practice, enable the backup function if there is sufficient storage space.
# Configure the device to overwrite the current WAF signature library without backing up the library during an automatic signature library update.
[Sysname] waf signature auto-update
[Sysname-waf-sig-autoupdate] override-current
waf signature auto-update-now
protected-target
Use protected-target to set a target criterion to filter the WAF signatures in a WAF policy.
Use undo protected-target to remove a target criterion.
protected-target { target [ sub-target subtarget ] | all }
undo protected-target { target [ sub-target subtarget ] | all }
The protected target attribute is not used for WAF signature filtering.
WAF policy view
context-admin
target: Specifies a target by its name. Target names are case insensitive. To view the names of supported targets, enter a question mark (?) after the protected-target keyword.
subtarget: Specifies a subtarget of the target by the subtarget name. Subtarget names are case insensitive. To view the names of supported subtargets, enter a question mark (?) after the sub-target keyword. If you do not specify a subtarget, this command matches any WAF signatures with a subtarget of the specified target.
all: Specifies all targets.
This command filters the WAF signatures that a WAF policy uses based on the protected target attribute of the signatures.
You can execute this command multiple times to specify multiple target criteria in a WAF policy. The WAF policy uses a WAF signature if the signature matches any of the configured target criteria.
# Configure WAF policy test-policy to use WAF signatures with the WebLogic subtarget of the WebServer target.
[Sysname-waf-policy-test-policy] protected-target WebServer sub-target WebLogic
display waf policy
severity-level
Use severity-level to set a severity level criterion to filter the WAF signatures in a WAF policy.
Use undo severity-level to restore the default.
severity-level { critical | high | low | medium } *
undo severity-level
The severity level attribute is not used for WAF signature filtering.
WAF policy view
context-admin
Each WAF signature has a severity level attribute, which indicates the severity level of the attacks matching the signature.
This command filters the WAF signatures that a WAF policy uses based on the severity level attribute of the signatures.
You can specify multiple severity levels in a severity level criterion. The WAF policy uses a WAF signature if the signature matches any of the specified severity levels.
# Configure WAF policy test-policy to use WAF signatures with the critical and medium severity levels.
[Sysname-waf-policy-test-policy] severity-level critical medium
waf policy
signature override
Use signature override to change the status and actions for a predefined WAF signature in a WAF policy.
Use undo signature override to restore the default status and actions for a predefined WAF signature in a WAF policy.
signature override pre-defined signature-id { disable | enable } [ { block-source | drop | permit | redirect | reset } | capture | logging ] *
undo signature override pre-defined signature-id
Predefined WAF signatures use the actions and statuses defined by the system.
WAF policy view
context-admin
signature-id: Specifies a WAF signature ID in the range of 1 to 536870911.
disable: Disables the WAF signature.
enable: Enables the WAF signature.
block-source: Drops matching packets and adds the sources of the packets to the IP blacklist. If the IP blacklist feature is enabled, packets from the blacklisted sources will be blocked for a duration set by the block-period command. If the IP blacklist feature is not enabled, packets from the blacklisted sources are not blocked. For more information about the IP blacklist feature, see Security Configuration Guide. For information about configuring the block period, see "DPI engine commands."
drop: Drops matching packets.
permit: Permits matching packets to pass.
redirect: Redirects matching packets to a webpage.
reset: Closes the TCP connections for matching packets by sending TCP reset messages.
capture: Captures matching packets.
logging: Logs matching packets.
This command is available only for user-defined WAF policies. The signature actions and status in the default WAF policy cannot be modified.
If you execute this command for a signature in a WAF policy multiple times, the most recent configuration takes effect.
# Enable predefined signature 2 for WAF policy test-policy. Specify the drop, capture, and logging actions for the signature.
[Sysname-waf-policy-test-policy] signature override pre-defined 2 enable drop capture logging
blacklist enable (security zone view) (Security Command Reference)
signature override all
Use signature override all to specify the WAF actions for a WAF policy.
Use undo signature override all to restore the default.
signature override all { { block-source | drop | permit | redirect | reset } | capture | logging } *
No actions are specified for a WAF policy and the default actions of WAF signatures are applied to matching packets.
WAF policy view
context-admin
Use this command to specify the global packet processing actions for a WAF policy.
Each WAF signature is defined with default actions for matching packets. You can change the default actions for individual signatures in a WAF policy.
The system selects the actions for packets matching a WAF signature in the following order:
1.     Actions configured for the WAF signature in the WAF policy (by using the signature override command).
2.     Actions configured for the WAF policy.
3.     Default actions of the WAF signature.
# Specify actions drop, logging, and capture for WAF policy test-policy.
[Sysname-waf-policy-test-policy] signature override all drop logging capture
signature override
update schedule
Use update schedule to schedule the time for automatic WAF signature library update.
Use undo update schedule to restore the default.
The device starts updating the WAF signature library at a random time between 01:00:00 and 03:00:00 every day.
context-admin
daily: Updates the WAF signature library every day.
weekly: Updates the WAF signature library every week.
fri: Updates the WAF signature library every Friday.
mon: Updates the WAF signature library every Monday.
sat: Updates the WAF signature library every Saturday.
sun: Updates the WAF signature library every Sunday.
thu: Updates the WAF signature library every Thursday.
tue: Updates the WAF signature library every Tuesday.
wed: Updates the WAF signature library every Wednesday.
start-time time: Specifies the start time in the hh:mm:ss format. The value range is 00:00:00 to 23:59:59.
tingle minutes: Specifies the tolerance time in minutes. The value range is 0 to 120. An automatic library update will occur at a random time between the following time points:
·     Start time minus half the tolerance time.
·     Start time plus half the tolerance time.
# Configure the device to automatically update the WAF signature library every Monday at a random time between 20:25:00 and 20:35:00.
[Sysname-waf-autoupdate] update schedule weekly mon start-time 20:30:00 tingle 10
waf apply policy
Use waf apply policy to apply a WAF policy to a DPI application profile.
Use undo waf apply policy to remove the application.
waf apply policy policy-name mode { alert | protect }
No WAF policy is applied to a DPI application profile.
DPI application profile view
context-admin
mode: Specifies a WAF policy mode.
alert: Only captures or logs matching packets.
protect: Takes all actions specified for signatures to process matching packets
A WAF policy takes effect only after it is applied to a DPI application profile.
You can apply only one WAF policy to a DPI application profile. If you execute this command multiple times, the most recent configuration takes effect.
# Apply WAF policy waf1 to DPI application profile sec. Set the WAF policy mode to protect.
[Sysname] app-profile sec
[Sysname-app-profile-sec] waf apply policy waf1 mode protect
app-profile
waf policy
waf parameter-profile
Use waf { block-source | capture | logging | redirect } parameter-profile to specify a parameter profile for a WAF action.
Use undo waf { block-source | capture | logging | redirect } parameter-profile to remove the parameter profile from a WAF action.
waf { block-source | capture | logging | redirect } parameter-profile parameter-name
No parameter profile is specified for a WAF action.
context-admin
block-source: Specifies a parameter profile for the block-source action.
capture: Specifies a parameter profile for the capture action.
email: Specifies a parameter profile for the email action.
logging: Specifies a parameter profile for the logging action.
redirect: Specifies a parameter profile for the redirect action.
parameter-profile parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters.
Use this command to specify the parameter profile used by a WAF action. A parameter profile is a set of parameters that determine how the action is executed. If you do not specify a parameter profile for an action, or if the specified profile does not exist, the default action parameter settings are used.
For information about configuring parameter profiles, see DPI Configuration Guide.
# Create parameter profile waf1. Set the source IP address blocking period to 1111 seconds.
[Sysname] inspect block-source parameter-profile waf1
[Sysname-inspect-block-source-waf1] block-period 1111
[Sysname-inspect-block-source-waf1] quit
# Specify the parameter profile waf1 for the block-source action.
[Sysname] waf block-source parameter-profile waf1
inspect capture parameter-profile
inspect logging parameter-profile
inspect redirect parameter-profile
waf policy
Use waf policy to create a WAF policy and enter its view, or enter the view of an existing WAF policy.
Use undo waf policy to delete a WAF policy.
undo waf policy policy-name
A WAF policy named default exists.
context-admin
policy-name: Specifies the WAF policy name, a case-insensitive string of 1 to 63 characters. The name cannot be default or contain string protected-website.
You can configure signature filtering criteria, the actions for a signature, and the protected website, and associate a CC defense policy in a WAF policy.
A WAF policy takes effect only after it is applied to a DPI application profile. For more information about a DPI application profile, see DPI Configuration Guide.
You cannot delete WAF policy default.
# Create WAF policy test-policy and enter its view.
app-profile
display waf policy
Use waf signature auto-update to enable automatic WAF signature library update and enter automatic WAF signature library update configuration view.
Use undo waf signature auto-update to disable automatic WAF signature library update.
Automatic WAF signature library update is disabled.
context-admin
After you enable automatic WAF signature library update, the device periodically accesses the official website to download the latest WAF signatures.
# Enable automatic WAF signature library update and enter automatic WAF signature library update configuration view.
update schedule
Use waf signature auto-update-now to trigger an automatic signature library update manually.
context-admin
After you execute this command, the device immediately starts the automatic signature library update process no matter whether automatic signature library update is enabled. The device automatically backs up the current signature library before overwriting it.
You can execute this command anytime you find a new version of signature library on the official website.
# Trigger an automatic signature library update manually.
[Sysname] waf signature auto-update-now
waf signature rollback
Use waf signature rollback to roll back the WAF signature library.
waf signature rollback { factory | last }
context-admin
factory: Rolls back the WAF signature library to the factory default version.
last: Rolls back the WAF signature library to the previous version.
If a WAF signature library update causes exceptions or a high false alarm rate, you can roll back the WAF signature library.
Before performing a WAF signature library rollback, the device backs up the current WAF signature library as the previous version. For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
# Roll back the WAF signature library to the previous version.
[Sysname] waf signature rollback last
override-current
waf signature update
Use waf signature update to manually update the WAF signature library.
waf signature update [ override-current ] file-path
context-admin
override-current: Overwrites the current WAF signature library without backing up the library. For the device to back up the current WAF signature library before overwriting the library, do not specify this keyword.
file-path: Specifies the WAF signature file path, a string of 1 to 255 characters.
If the device cannot access the official website, use one of the following methods to manually update the WAF signature library:
·     Local update—Updates the WAF signature library by using a locally stored update WAF signature file.
Store the update file on the master device for successful signature library update.
The following describes the format of the file-path argument for different update scenarios.
Update scenario
Format of file-path
Remarks
The update file is stored in the current working directory.
filename
To display the current working directory, use the pwd command.
For information about the pwd command, see file system management in Fundamentals Command Reference.
The update file is stored in a different directory on the same storage medium.
filename
Before configuring the waf signature update command, use the cd command to open the directory where the file is stored.
For information about the cd command, see file system management in Fundamentals Command Reference.
The update file is stored on a different storage medium.
path/filename
Before configuring the waf signature update command, use the cd command to open the root directory of the storage medium where the file is stored.
·     FTP/TFTP update—Updates the WAF signature library by using the file stored on an FTP or TFTP server.
Update scenario
Format of file-path
Remarks
The update file is stored on an FTP server.
ftp://username:password@server address/filename
The username parameter represents the FTP login username.
The password parameter represents the FTP login password.
The server address parameter represents the IP address or host name of the FTP server.
Replace the following special characters in the FTP login username and password with their respective escape characters:
·     Colon (:)—%3A or %3a.
·     At sign (@)—%40.
·     Forward slash (/)—%2F or %2f.
The update file is stored on a TFTP server.
tftp://server address/filename
The server address parameter represents the IP address or host name of the TFTP server.
To update the signature library successfully, make sure the device and the FTP or TFTP server can reach each other. If you specify the FTP or TFTP server by its host name, you must also make sure the device can resolve the host name into an IP address through static or dynamic DNS. For more information about DNS, see Layer 3—IP Services Configuration Guide.
# Manually update the WAF signature library by using a WAF signature file stored on a TFTP server.
[Sysname] waf signature update tftp://192.168.0.10/waf-1.0.2-en.dat
# Manually update the WAF signature library by using a WAF signature file stored on an FTP server. The FTP login username and password are user:123 and user@abc/123, respectively.
[Sysname] waf signature update ftp://user%3A123:user%40abc%[email protected]/waf-1.0.2-en.dat
# Manually update the WAF signature library by using a WAF signature file stored on the device. The file is stored in directory cfa0:/waf-1.0.23-en.dat, and the current working directory is cfa0:.
[Sysname] waf signature update waf-1.0.23-en.dat
# Manually update the WAF signature library by using a WAF signature file stored on the device. The file is stored in directory cfa0:/dpi/waf-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd dpi
# Manually update the WAF signature library by using a WAF signature file stored on the device. The file is stored in directory cfb0:/dpi/waf-1.0.23-en.dat, and the current working directory is the cfa0:.
<Sysname> cd cfb0:/
[Sysname] waf signature update dpi/waf-1.0.23-en.dat
