- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-Object policy commands
- 07-IP source guard commands
- 08-AAA commands
- 09-User identification commands
- 10-Password control commands
- 11-Portal commands
- 12-MAC authentication commands
- 13-IPoE commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Server connection detection commands
- 21-ARP attack protection commands
- 22-ND attack defense commands
- 23-uRPF commands
- 24-IP-MAC binding commands
- 25-APR commands
- 26-Keychain commands
- 27-Crypto engine commands
- 28-MAC learning through a Layer 3 device commands
| 02-Security policy commands | 246.88 KB |
description (security policy rule view)
description (security policy view)
destination-ip-host (IPv4 security policy view)
destination-ip-host (IPv6 security policy view)
destination-ip-range (IPv4 security policy view)
destination-ip-range (IPv6 security policy view)
destination-ip-subnet (IPv4 security policy view)
destination-ip-subnet (IPv6 security policy view)
display security-policy statistics
display security-policy switch-result
reset security-policy statistics
security-policy config-logging send-time
security-policy switch-from object-policy
source-ip-host (IPv4 security policy view)
source-ip-host (IPv6 security policy view)
source-ip-range (IPv4 security policy view)
source-ip-range (IPv6 security policy view)
source-ip-subnet (IPv4 security policy view)
accelerate enhanced enable
Use accelerate enhanced enable to manually activate rule matching acceleration.
context-admin
Rule matching acceleration enhances connection establishment and packet forwarding performance, especially for a device using multiple rules to match packets from multiple users.
Rule matching acceleration does not take effect on newly added, modified, and moved rules unless the feature is activated for the rules. By default, the system automatically activates rule matching acceleration for such rules at specific intervals. The interval is 2 seconds if 100 or fewer rules exist and 20 seconds if over 100 rules exist.
To activate rule matching acceleration immediately after a rule change, you can execute this command.
If no rule change is detected, the system does not perform an activation operation.
Insufficient memory can cause rule matching acceleration failures. Unaccelerated rules do not take effect, and rules that have been accelerated are not affected.
# Activate rule matching acceleration.
[Sysname] security-policy ip
[Sysname-security-policy-ip] accelerate enhanced enable
action
Use action to set the action for a security policy rule.
action { drop | pass }
The action for a security policy rule is drop.
Security policy rule view
context-admin
drop: Discards matched packets.
pass: Allows matched packets to pass.
# Set the action for security policy rule rule1 to drop.
[Sysname-security-policy-ip] rule 0 name rule1
[Sysname-security-policy-ip-0-rule1] action drop
app-group
Use app-group to specify an application group as a filtering criterion of a security policy rule.
Use undo app-group to remove the specified application group filtering criterion from a security policy rule.
app-group app-group-name
undo app-group [ app-group-name ]
No application group is specified as a filtering criterion for a security policy rule.
context-admin
app-group-name: Specifies the name of an application policy, a case-insensitive string of 1 to 63 characters. The name cannot be invalid or other. If you do not specify this argument when executing the undo app-group command, the command removes all application groups from the rule. For more information about application groups, see APR in Security Configuration Guide.
You can execute the command multiple times to specify multiple application groups as the filtering criteria.
# Specify application groups app1 and app2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] app-group app1
[Sysname-security-policy-ip-0-rule1] app-group app2
app-group
application
Use application to specify an application as a filtering criterion of a security policy rule.
Use undo application to remove the specified application filtering criterion from a security policy rule.
application application-name
undo application [ application-name ]
No application is specified as a filtering criterion for a security policy rule.
context-admin
application-name: Specifies the name of an application, a case-insensitive string of 1 to 63 characters. The name cannot be invalid or other. If you do not specify this argument when executing the undo application command, the command removes all applications from the rule. For more information about applications, see APR in Security Configuration Guide.
You can execute the command multiple times to specify multiple applications as the filtering criteria.
For the application filtering criteria to be identified, you must permit the dependent applications to pass through.
# Specify applications 139Mail and 51job as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] application 139Mail
[Sysname-security-policy-ip-0-rule1] application 51job
nbar application
port-mapping
counting enable
Use counting enable to enable statistics collection for matched packets.
Use undo counting enable to disable statistics collection for matched packets.
counting enable
Statistics collection for matched packets is disabled.
context-admin
This feature enables the device to collect statistics about matched packets. The collected statistics can be viewed by executing the display security-policy statistics command.
# Enable matched packet statistics collection for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] counting enable
Use description to configure a description for a security policy rule.
No description is configured for a security policy rule.
context-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This rule is used for source-ip ip1 for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] description This rule is used for source-ip ip1
display object-policy ip
display object-policy ipv6
Use description to configure a description for the IPv4 or IPv6 security policy.
No description is configured for the IPv4 or IPv6 security policy.
context-admin
# Configure the description as zone-pair security office to library for the IPv4 security policy.
[Sysname-security-policy-ip] description zone-pair security office to library
destination-ip
Use destination-ip to specify a destination IP address object group as a filtering criterion of a security policy rule.
Use undo destination-ip to remove the specified destination IP address object group from a security policy rule.
destination-ip object-group-name
undo destination-ip [ object-group-name ]
No destination IP address object group is specified as a filtering criterion for a security policy rule.
context-admin
object-group-name: Specifies the name of a destination IP address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo destination-ip command, the command removes all destination IP address object groups from the rule. For more information about object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple destination IP address object groups as the filtering criteria.
If you specify a nonexistent object group, the device automatically creates the specified object group with empty configuration. A rule that contains an object group with empty configuration does not match any packets.
# Specify destination IP address object groups client1 and client2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip client1
[Sysname-security-policy-ip-0-rule1] destination-ip client2
object-group
Use destination-ip-host to specify a destination IPv4 host address as a filtering criterion of a security policy rule.
Use undo destination-ip-host to remove the specified destination IPv4 host address from a security policy rule.
destination-ip-host ip-address
undo destination-ip-host [ ip-address ]
No destination IPv4 host address is specified as a filtering criterion for a security policy rule.
IPv4 security policy rule view
context-admin
ip-address: Specifies the IPv4 address of a host. If you do not specify this argument when executing the undo command, the command removes all destination IPv4 host addresses from the rule.
You can execute the command multiple times to specify multiple destination IPv4 host addresses as the filtering criteria.
If you specify an IP address that has been configured as a destination host filtering criterion, the command execution fails and the system prompts an error.
For a security policy rule, the sum of configured destination host addresses, destination subnets, destination address ranges, and destination object groups cannot exceed 1024. If the limit has been reached, any command execution to add such a filtering criterion fails and the system prompts an error.
# Specify destination IPv4 host address 192.167.0.1 as the filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip-host 192.167.0.1
Use destination-ip-host to specify a destination IPv6 host address as a filtering criterion of a security policy rule.
Use undo destination-ip-host to remove the specified destination IPv6 host address from a security policy rule.
destination-ip-host ipv6-address
undo destination-ip-host [ ipv6-address ]
No destination IPv6 host address is specified as a filtering criterion for a security policy rule.
IPv6 security policy rule view
context-admin
Ipv6-address: Specifies the IPv6 address of a host. If you do not specify this argument when executing the undo command, the command removes all destination IPv6 host addresses from the rule.
You can execute the command multiple times to specify multiple destination IPv6 host addresses as the filtering criteria.
# Specify destination IPv6 host address 192::167:1 as the filtering criteria of IPv6 security policy rule rule1.
[Sysname] security-policy ipv6
[Sysname-security-policy-ipv6] rule 0 name rule1
[Sysname-security-policy-ipv6-0-rule1] destination-ip-host 192::167:1
Use destination-ip-range to specify a destination IPv4 address range as a filtering criterion of a security policy rule.
Use undo destination-ip-range to remove the specified destination IPv4 address range from a security policy rule.
destination-ip-range ip-address1 ip-address2
undo destination-ip-range [ ip-address1 ip-address2 ]
No destination IPv4 address range is specified as a filtering criterion for a security policy rule.
context-admin
ip-address1 ip-address2: Specifies an IPv4 address range. The ip-address1 argument represents the start IP address and the ip-address2 argument represents the end IP address. If you do not specify the arguments when executing the undo command, the command removes all destination IPv4 address ranges from the rule.
You can execute the command multiple times to specify multiple destination IPv4 address ranges as the filtering criteria.
If you specify an IP address range that has been configured as a destination IP range filtering criterion, the command execution fails and the system prompts an error.
When you specify an IP address range, follow these restrictions and guidelines:
· If the start IP address is the same as the end IP address, the command creates a host address filtering criteria.
· If the start IP address and the end IP address define a subnet, the command creates a subnet filtering criteria.
· If ip-address1 is greater than ip-address2, the system automatically adjusts the range to [ ip-address2, ip-address1 ].
# Specify destination IPv4 address range 192.165.0.100 to 192.165.0.200 as the filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip-range 192.165.0.100 192.165.0.200
Use destination-ip-range to specify a destination IPv6 address range as a filtering criterion of a security policy rule.
Use undo destination-ip-range to remove the specified destination IPv6 address range from a security policy rule.
destination-ip-range ipv6-address1 ipv6-address2
undo destination-ip-range [ ipv6-address1 ipv6-address2 ]
No destination IPv6 address range is specified as a filtering criterion for a security policy rule.
context-admin
ipv6-address1 ipv6-address2: Specifies an IPv6 address range. The ipv6-address1 argument represents the start IP address and the ipv6-address2 argument represents the end IP address. If you do not specify the arguments when executing the undo command, the command removes all destination IPv6 address ranges from the rule.
You can execute the command multiple times to specify multiple destination IPv6 address ranges as the filtering criteria.
· If ipv6-address1 is greater than ipv6-address2, the system automatically adjusts the range to [ ipv6-address2, ipv6-address1 ].
# Specify destination IPv6 address range 192:165::100 to 192:165::200 as the filtering criteria of IPv6 security policy rule rule1.
[Sysname-security-policy-ipv6-0-rule1] destination-ip-range 192:165::100 192:165::200
Use destination-ip-subnet to specify a destination IPv4 subnet as a filtering criterion of a security policy rule.
Use undo destination-ip-subnet to remove the specified destination IPv4 subnet from a security policy rule.
destination-ip-subnet ip-address { mask-length | mask }
undo destination-ip-subnet [ ip-address { mask-length | mask } ]
No destination IPv4 subnet is specified as a filtering criterion for a security policy rule.
context-admin
ip-address { mask-length | mask }: Specifies an IPv4 subnet. You can specify the mask length or the mask in dotted decimal notation. The mask length is in the range of 0 to 32. If you set the mask length to 32 or the mask to 255.255.255.255, the command creates a host address filtering criterion. If you do not specify the arguments when executing the undo command, the command removes all destination IPv4 subnets from the rule.
You can execute the command multiple times to specify multiple destination IPv4 subnets as the filtering criteria.
If you specify a subnet that has been configured as a destination subnet filtering criterion, the command execution fails and the system prompts an error.
# Specify the destination subnet with IP address 192.167.0.0 and mask length 24 as a filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip-subnet 192.167.0.0 24
# Specify the destination subnet with IP address 192.166.0.0 and mask 255.255.0.0 as a filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip-subnet 192.166.0.0 255.255.0.0
Use destination-ip-subnet to specify a destination IPv6 subnet as a filtering criterion of a security policy rule.
Use undo destination-ip-subnet to remove the specified destination IPv6 subnet from a security policy rule.
destination-ip-subnet ipv6-address prefix-length
undo destination-ip-subnet [ ipv6-address prefix-length ]
No destination IPv6 subnet is specified as a filtering criterion for a security policy rule.
context-admin
ipv6-address prefix-length: Specifies an IPv6 subnet. The prefix length is in the range of 1 to 128. If you set the prefix length to 128, the command creates a host address filtering criterion. If you do not specify the arguments when executing the undo command, the command removes all destination IPv4 subnets from the rule.
You can execute the command multiple times to specify multiple destination IPv6 subnets as the filtering criteria.
# Specify the destination subnet with IP address 192::167:0 and prefix length 64 as a filtering criteria of IPv6 security policy rule rule1.
[Sysname-security-policy-ipv6-0-rule1] destination-ip-subnet 192::167:0 64
destination-zone
Use destination-zone to specify a destination security zone as a filtering criterion of a security policy rule.
Use undo destination-zone to remove the specified destination security zone from a security policy rule.
destination-zone destination-zone-name
undo destination-zone [ destination-zone-name ]
No destination security zone is specified as a filtering criterion for a security policy rule.
context-admin
object-group-name: Specifies the name of a destination security zone, a case-insensitive string of 1 to 31 characters. If you do not specify this argument when executing the undo destination-zone command, the command removes all destination security zones from the rule. For more information about security zones, see Security Configuration Guide.
You can execute the command multiple times to specify multiple destination security zones as the filtering criteria.
# Specify destination security zones trust and server as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-zone trust
[Sysname-security-policy-ip-0-rule1] destination-zone server
security-zone
disable
Use disable to disable a security policy rule.
Use undo disable to enable a security policy rule.
disable
undo disable
A security policy rule is enabled.
context-admin
# Disable security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] disable
Use display security-policy to display information about the specified security policy.
display security-policy { ip | ipv6 }
context-admin
context-operator
ip: Specifies the IPv4 security policy.
ipv6: Specifies the IPv6 security policy.
# Display information about the IPv4 security policy.
<Sysname> display security-policy ip
Security-policy ip
rule 0 name der (Inactive)
action pass
profile er
vrf re
logging enable
counting enable
time-range dere
track positive 23
session aging-time 5000
session persistent aging-time 2400
source-zone trust
source-ip erer
service ftp
app-group ere
application 110Wang
user der
user-group ere
Rule ID and rule name. |
action pass |
Rule action: · pass—Allows matched packets to pass. · drop—Drops matched packets. |
profile app-profile-name |
DPI application profile applied to the rule. |
vrf vrf-name |
MPLS L3VPN instance whose packets can be filtered by the rule. |
time-range time-range-name |
Time range during which the rule is in effect. |
track negative 1 (Active) |
Track entry and track entry state associated with the security policy rule. |
session aging-time time-value |
Session aging time. |
session persistent aging-time time-value |
Persistent session aging time. |
source-zone zone-name |
Source security zone that acts as a filtering criterion. |
destination-zone zone-name |
Destination security zone that acts as a filtering criterion. |
source-ip object-group-name |
Source IP address object group that acts as a filtering criterion. |
destination-ip object-group-name |
Destination IP address object group that acts as a filtering criterion. |
service object-group-name |
Service object group that acts as a filtering criterion. |
app-group app-group-name |
Application group that acts as a filtering criterion. |
application application-name |
Application that acts as a filtering criterion. |
user user-name |
User that acts as a filtering criterion. |
user-group user-group-name |
User group that acts as a filtering criterion. |
security-policy ip
Use display security-policy statistics to display security policy statistics.
display security-policy statistics { ip | ipv6 } [ rule rule-name ]
context-admin
context-operator
rule rule-name: Specifies a security policy rule by its name, a case-insensitive string of 1 to 127 characters. If you do not specify this option, the command displays statistics about all security policy rules of the specified IP version.
# Display statistics about IPv4 security policy rule abc.
<Sysname> display security-policy statistics ip rule abc
rule 0 name abc
action: pass (5 packets, 1000 bytes)
rule id name rule-name |
action |
x packets, y bytes |
The rule has matched x packets, a total of y bytes. This field is displayed only if the counting enable or the logging enable command has been executed for the rule. |
Use display security-policy switch-result to display the security policy switching result.
context-admin
context-operator
If the security-policy switch-from object-policy command has not been executed, nothing is displayed. Otherwise, the switching result is displayed even if the switching operation failed.
# Display the result of a successful security policy switching.
<Sysname> display security-policy switch-result
Time: 2017-03-13 18-11-17
Result: Successful
Object policy file: flash:/chenlu_concon.cfg
Security policy file: flash:/chenlu_concon_secp.cfg
# Display the result of a failed security policy switching.
Time: 2017-03-13 18-11-15
Result: Failed
Object policy file: flash:/chenlu_convert.cfg
Security policy file: flash:/chenlu_convert_secp.cfg
Failure reason: The switching operation fails because the source or destination security zone is set to any for the zone pair and the action of an object policy rule is set to drop.
Time |
Switching time in the format of year-month-day hour-minute-second. |
Result |
Switching result: · Successful. · Failed. |
Failure reason |
This field is displayed only for a failed switching operation. |
group move
Use group move to move a security policy rule group to change the match order of security policy rules.
group move group-name1 { after | before } { group group-name2 | rule rule-name }
Security policy view
context-admin
group-name1: Specifies the name of the security policy rule group to be moved, a case-insensitive string of 1 to 63 characters.
after: Moves the security policy rule group to the place after the target security policy rule group or the target security policy rule.
before: Moves the security policy rule group to the place before the target security policy rule group or the target security policy rule.
group group-name2: Specifies the name of the target security policy rule group, a case-insensitive string of 1 to 63 characters.
rule rule-name: Specifies the name of the target security policy rule, a case-insensitive string of 1 to 127 characters.
If you specify a target security policy rule that belongs to a security policy rule group, follow these restrictions and guidelines:
· If the target rule is neither the start nor end rule of the group, you cannot move a security policy rule group to the place before or after the rule.
· If the target rule is the start rule of the group, you can only move a security policy rule group to the place before the rule.
· If the target rule is the end rule of the group, you can only move a security policy rule group to the place after the rule.
# Move security policy rule group group1 to the place before security policy rule group group2.
[Sysname-security-policy-ip] group move group1 before group group2
group name
Use group name to create a security policy rule group and add security policy rules to the group, or add security policy rules to an existing security policy rule group.
Use undo group name to delete a security policy rule group.
group name group-name [ from rule-name1 to rule-name2 ] [ description description-text ] [ disable | enable ]
undo group name group-name [ description | include-member ]
No security policy rule group exists.
context-admin
group-name: Specifies a security policy rule group name, a case-insensitive string of 1 to 63 characters.
from rule-name1: Specifies the start rule of a rule list. The rule-name1 argument represents the security policy rule name, a case-insensitive string of 1 to 127 characters.
to rule-name2: Specifies the end rule of the rule list. The rule-name2 argument represents the security policy rule name, a case-insensitive string of 1 to 127 characters.
description description-text: Specifies the security policy description, a case-sensitive string of 1 to 127 characters. By default, no description is specified for a security policy rule group.
disable: Disables the security policy rule group.
enable: Enables the security policy rule group. By default, a security policy rule group is enabled.
include-member: Specifies security policy rules in the security policy rule group.
Security policy rule grouping allows users to enable, disable, delete, and move security policy rules in batches.
A security policy rule in a security policy rule group takes effect only when both the rule and the group are enabled.
To add a list of security policy rules, make sure the end rule is listed behind the start rule and the specified rules do not belong to any other security policy rule group.
When you execute the undo command, follow these restrictions and guidelines:
· The undo group name group-name command deletes only the specified security policy rule group.
· The undo group name group-name description command deletes only the description for the specified security policy rule group.
· The undo group name group-name include-member command deletes both the specified security policy rule group and all the security policy rules in the group.
# Create security policy rule group group1, add security policy rules rule-name1 through rule-name10 to the group, and specify the group description as marketing.
[Sysname-security-policy-ip] group name group1 from rule-name1 to rule-name10 enable description marketing
group rename
Use group rename to rename a security policy rule group.
group rename old-name new-name
context-admin
old-name: Specifies the name of a security policy rule group, a case-insensitive string of 1 to 63 characters.
new-name: Specifies a new name for the security policy rule group, a case-insensitive string of 1 to 63 characters.
# Rename security policy rule group group1 to group2.
[Sysname-security-policy-ip] group rename group1 group2
logging enable
Use logging enable to enable logging for matched packets.
Use undo logging enable to disable logging for matched packets.
logging enable
undo logging enable
Logging for matched packets is disabled.
context-admin
This feature enables the security policy module to send log messages to the information center when packets match a security policy.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output packet matching logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view packet matching logs stored on the device, use the display logbuffer command or open the security policy log page from the Web interface of the device. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable matched packet logging for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] logging enable
move rule
Use move rule to change the rule match order of a security policy rule.
move rule rule-id before insert-rule-id
context-admin
rule-id: Specifies the ID of a rule, in the range of 0 to 65534.
insert-rule-id: Specifies the ID of the target rule before which a rule is inserted. The target rule ID is in the range of 0 to 65535. If you specify 65535 as the target rule ID, the rule is moved to the end of the list.
The system does not execute the command in the following situations:
· You specify the same value for the rule-id and insert-rule-id arguments.
· You specify a nonexistent rule.
# Insert rule 5 before rule 2 for the IPv4 security policy.
[Sysname-security-policy-ip] move rule 5 before 2
rule
security-policy ip
move rule name
Use move rule name to move a security policy rule by rule name.
move rule name rule-name1 { { after | before } name rule-name2 | bottom | down | top | up }
context-admin
rule-name1: Specifies the name of the rule to move, a case-insensitive string of 1 to 127 characters.
after: Move the rule to the place after the destination rule.
before: Move the rule to the place before the destination rule.
name rule-name2: Specify the name of the destination rule, a case-insensitive string of 1 to 127 characters.
bottom: Move the rule to the end of the security policy.
down: Move the rule down one place.
top: Move the rule to the beginning of the security policy.
up: Move the rule up one place.
You can move a rule to change its packet matching priority.
# Move rule rule1 to the place before rule rule2.
[Sysname-security-policy-ip] move rule name rule1 before name rule2
rule
security-policy ip
parent-group
Use parent-group to specify a security policy rule group for a security policy rule.
Use undo parent-group to restore the default.
parent-group group-name
undo parent-group
A security policy rule does not belong to any security policy rule group.
context-admin
group-name: Specifies the name of a security policy rule group, a case-insensitive string of 1 to 63 characters.
# Assign security policy rule rule1 to security policy rule group group1.
[Sysname-security-policy-ip] rule 1 name rule1
[Sysname-security-policy-ip-1-rule1] parent-group group1
profile
Use profile to apply a DPI application profile to a security policy rule.
Use undo profile to remove the DPI application profile applied to a security policy rule.
undo profile
No DPI application profile is applied to a security policy rule.
context-admin
app-profile-name: Specifies the name of a DPI application profile, a case-insensitive string of 1 to 63 characters. For more information about DPI application profiles, see DPI engine in DPI Configuration Guide.
This feature enables the device to perform DPI on packets matching the specified rule. For more information about DPI, see DPI Configuration Guide.
This feature takes effect only when the rule action is pass.
# Apply DPI application profile p1 to IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] action pass
[Sysname-security-policy-ip-0-rule1] profile p1
action pass
app-profile (DPI Command Reference)
Use reset security-policy statistics to clear security policy statistics.
reset security-policy statistics [ ip | ipv6 ] [ rule rule-name ]
context-admin
If you do not specify any keyword or option, the command clears all security policy statistics.
# Clear the security policy statistics about IPv4 security policy rule abc.
<Sysname> reset security-policy statistics ip rule abc
rule
Use rule to create a security policy rule and enter its view, or enter the view of an existing security policy rule.
Use undo rule to delete the specified security policy rule.
rule { rule-id | [ rule-id ] name rule-name }
undo rule { rule-id | name rule-name } *
No security policy rules exist.
context-admin
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify an ID for the rule, the system automatically assigns the rule the integer next to the greatest ID being used. If the greatest ID is 65534, the system assigns the rule the smallest unused number in the range.
rule-name: Specifies a globally unique rule name, a case-insensitive string of 1 to 127 characters. The name cannot be default. You must specify a rule name when creating a rule.
# Create an IPv4 security policy rule with rule ID 0 and rule name rule1.
display security-policy ipv6
rule rename
Use rule rename to rename a security policy rule.
rule rename old-name new-name
context-admin
old-name: Specifies the current name, a case-insensitive string of 1 to 127 characters.
new-name: Specifies the new name, a case-insensitive string of 1 to 127 characters. The name must be globally unique and cannot be default.
# Change the name of security policy rule rule1 to rule2.
[Sysname-security-policy-ip] rule rename rule1 rule2
rule
security-policy ip
security-policy
Use security-policy to enter security policy view.
Use undo security-policy to delete all configurations in security policy view.
undo security-policy { ip | ipv6 }
No configurations exist in security policy view.
context-admin
# Enter IPv4 security policy view.
Use security-policy config-logging send-time to set the time at which the device fast outputs security policy settings as logs every day.
Use undo security-policy config-logging send-time to restore the default.
security-policy config-logging send-time time
The device fast outputs security policy settings as logs every day at 0 o'clock.
context-admin
time: Specify the time at which the device fast outputs security policy settings as logs, in the format of hh:mm. The value range for the hh argument is 00 to 23 and the value range for the mm argument is 00 to 59.
After the customlog format security-policy sgcc command is executed, the device fast outputs settings of enabled security policies as logs in SGCC format every day at the specified time. For more information about fast log output, see Network Management and Monitoring Configuration Guide.
# Configure the device to fast output security policy settings as logs every day at 13:15.
<Sysname>system-view
[Sysname] security-policy config-loggging send-time 13:15
customlog format security-policy sgcc (Network Management and Monitoring Command Reference)
customlog host export security-policy (Network Management and Monitoring Command Reference)
security-policy disable
Use security-policy disable to disable the security policy feature.
Use undo security-policy disable to enable the security policy feature.
The security policy feature is enabled.
context-admin
Security policy settings take effect only when the security policy feature is enabled.
After the device starts up, the device automatically executes the security-policy disable command to disable the security policy feature if object policy settings exist in the configuration file. If object policy settings do not exist in the configuration file, the device enables the security policy feature.
Security policies and object policies cannot take effect at the same time on a device. If security policy is enabled, object policies lose effect at the first time security policy view is entered. If you are to manually configure security policies item by item based on object policy settings, keep the security policy feature disabled until you finish the configuration.
After a configuration rollback from security policies to object policies, disable the security feature for the object policies to take effect.
# Disable the security policy feature.
[Sysname] security-policy disable
Use security-policy switch-from object-policy to switch object policy settings to security policy settings.
security-policy switch-from object-policy object-filename security-filename
context-admin
object-filename: Specifies the configuration file to be switched by its name, a case-sensitive string of 1 to 255 characters. The name must end with .cfg and cannot contain forward slashes (/). Make sure the specified configuration file exist in the root directory of the storage medium.
security-filename: Specifies the name of the configuration file to be created, a case-sensitive string of 1 to 255 characters. The name must end with .cfg and cannot contain forward slashes (/). The created configuration file will be saved in the root directory of the storage medium.
This feature enables you to achieve fast switching from object policy settings to security policy settings.
For the switched security policy settings to take effect, reboot the device after the switching process completes.
# Switch object policy settings in configuration file startup.cfg to security policy settings.
[Sysname] security-policy switch-from object-policy startup.cfg startup_secp.cfg
Configuration switching begins...
Object policies in the specified configuration file have been switched to security policies.
This command will reboot the device. Continue? [Y/N]:
service
Use service to specify a service object group as a filtering criterion of a security policy rule.
Use undo service to remove the specified service object group from a security policy rule.
service { object-group-name | any }
undo service [ object-group-name | any ]
No service object group is specified as a filtering criterion for a security policy rule.
context-admin
object-group-name: Specifies the name of a service object group, a case-insensitive string of 1 to 31 characters.
any: Specifies all service object groups.
You can execute the command multiple times to specify multiple service object groups as the filtering criteria.
If you specify neither an object group nor the any keyword when executing the undo service command, the command removes all service object groups from the security policy rule.
# Specify service object groups http and ftp as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] service http
[Sysname-security-policy-ip-0-rule1] service ftp
object-group
service-port
Use service-port to specify a service port as a filtering criterion of a security policy rule.
Use undo service-port to remove the specified service port range from a security policy rule.
service-port protocol [ { destination { { eq | lt | gt } port | range port1 port2 } | source { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ]
undo service-port [ protocol [ { destination { { eq | lt | gt } port | range port1 port2 } | source { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] ]
No service port is specified as a filtering criterion for a security policy rule.
context-admin
protocol: Specify the number or name of a protocol. The value range for protocol numbers is 0 to 255. Available protocol names include tcp, udp, icmp, and icmpv6, whose protocol numbers are 6, 17, 1, and 58, respectively.
destination: Specifies the destination port. This configuration takes effect only when the protocol is TCP or UDP.
source: Specifies the source port. This configuration takes effect only when the protocol is TCP or UDP.
eq: Specifies the specified port.
lt: Specifies all ports whose port numbers are smaller than the specified port. If you specify this keyword, the specified port number cannot be 0.
gt: Specifies all ports whose port numbers are larger than the specified port. If you specify this keyword, the specified port number cannot be 65535.
port: Specifies a port number in the range of 0 to 65535.
range port1 port2: Specifies a range of port numbers. The port1 argument represents the start port and the port2 argument represents the end port. Each port number is in the range of 0 to 65535.
icmp-type: Specifies an ICMP message type in the range of 0 to 255. This configuration takes effect only when the protocol is ICMP.
icmp-code: Specifies the ICMP message code in the range of 0 to 255.
icmpv6-type: Specifies an ICMPv6 message type in the range of 0 to 255. This configuration takes effect only when the protocol is ICMPv6.
icmpv6-code: Specifies the ICMPv6 message code in the range of 0 to 255.
You can execute this command multiple times to specify multiple service ports as the filtering criteria.
If you specify a service port that has been configured as a service port filtering criterion, the command execution fails.
For a security policy rule, the sum of configured service object groups and service ports cannot exceed 1024. If the limit has been reached, any command execution to add such a filtering criterion fails and the system prompts an error.
When you specify the range keyword, following these restrictions and guidelines:
· If port1 is the same as port2, the command takes effect as if you specified the eq keyword.
· If port1 is 0, the command takes effect as if you specified the lt keyword with port2 as the specified port.
· If port2 is 65535, the command takes effect as if you specified the gt keyword with port1 as the specified port.
· If port1 is larger than port2, the system automatically changes the port range to [port2, port1].
If you do not specify any keyword or argument when executing the undo command, the command removes all service ports from the security policy rule.
# Specify TCP destination and source ports as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] service-port tcp destination range 100 200 source eq 100
# Specify ICMP destination and source ports as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] service-port icmp 100 150
session aging-time
Use session aging-time to set the session aging time for a security policy rule.
Use undo session aging-time to restore the default.
The session aging time is not configured for a security policy rule.
context-admin
time-value: Specifies the aging time in the range of 1 to 2000000 seconds.
This command sets the aging time for stable sessions created for packets matching the specified security policy rule, and takes effect only on newly created sessions.
If the aging time is not configured for a rule, the stable sessions use the aging time set by using the session aging-time application or the session aging-time state command. For more information about session management, see Security Configuration Guide.
The session aging time for unstable sessions is one hour.
# Set the session aging time to 5000 seconds for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] session aging-time 5000
session persistent acl
Use session persistent aging-time to set the aging time for persistent sessions.
Use undo session persistent aging-time to restore the default.
The persistent session aging time is not configured for a security policy rule.
context-admin
time-value: Specifies the aging time in the range of 0 to 24000 hours. If you set the aging time to 0, persistent sessions do not age out.
This command is effective only on TCP sessions in ESTABLISHED state.
It sets the aging time for persistent sessions created for packets matching the specified security policy rule, and takes effect only on newly created sessions.
The aging time configured by using this command takes precedence over the aging times configured by using the session aging-time and session persistent acl commands.
# Set the persistent session aging time to one hour for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] session persistent aging-time 1
source-ip
Use source-ip to specify a source IP address object group as a filtering criterion of a security policy rule.
Use undo source-ip to remove the specified source IP address object group from a security policy rule.
undo source-ip [ object-group-name ]
No source IP address object group is specified as a filtering criterion for a security policy rule.
context-admin
object-group-name: Specifies the name of a source IP address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo source-ip command, the command removes all source IP address object groups from the rule. For more information about object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple source IP address object groups as the filtering criteria.
# Specify source IP address object groups server1 and server2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip server1
[Sysname-security-policy-ip-0-rule1] source-ip server2
object-group
Use source-ip-host to specify a source IPv4 host address as a filtering criterion of a security policy rule.
Use undo source-ip-host to remove the specified source IPv4 host address from a security policy rule.
source-ip-host ip-address
undo source-ip-host [ ip-address ]
No source IPv4 host address is specified as a filtering criterion for a security policy rule.
context-admin
ip-address: Specifies the IPv4 address of a host. If you do not specify this argument when executing the undo command, the command removes all source IPv4 host addresses from the security policy rule.
You can execute the command multiple times to specify multiple source IPv4 host addresses as the filtering criteria.
If you specify an IP address that has been configured as a source host filtering criterion, the command execution fails and the system prompts an error.
For a security policy rule, the sum of configured source host addresses, source subnets, source address ranges, and source object groups cannot exceed 1024. If the limit has been reached, any command execution to add such a filtering criterion fails and the system prompts an error.
# Specify source IPv4 host address 192.167.0.1 as the filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip-host 192.167.0.1
Use source-ip-host to specify a source IPv6 host address as a filtering criterion of a security policy rule.
Use undo source-ip-host to remove the specified source IPv6 host address from a security policy rule.
source-ip-host ipv6-address
undo source-ip-host [ ipv6-address ]
No source IPv6 host address is specified as a filtering criterion for a security policy rule.
context-admin
ipv6-address: Specifies the IPv6 address of a host. If you do not specify this argument when executing the undo command, the command removes all source IPv6 host addresses from the security policy rule.
You can execute the command multiple times to specify multiple source IPv6 host addresses as the filtering criteria.
# Specify source IPv6 host address 192::167:1 as the filtering criteria of IPv6 security policy rule rule1.
[Sysname-security-policy-ipv6-0-rule1] source-ip-host 192::167:1
Use source-ip-range to specify a source IPv4 address range as a filtering criterion of a security policy rule.
Use undo source-ip-range to remove the specified source IPv4 address range from a security policy rule.
source-ip-range ip-address1 ip-address2
undo source-ip-range [ ip-address1 ip-address2 ]
No source IPv4 address range is specified as a filtering criterion for a security policy rule.
context-admin
ip-address1 ip-address2: Specifies an IPv4 address range. The ip-address1 argument represents the start IP address and the ip-address2 argument represents the end IP address. If you do not specify the arguments when executing the undo command, the command removes all source IPv4 address ranges from the security policy rule.
You can execute the command multiple times to specify multiple source IPv4 address ranges as the filtering criteria.
If you specify an IP address range that has been configured as a source IP range filtering criterion, the command execution fails and the system prompts an error.
# Specify source IPv4 address range 192.165.0.100 to 192.165.0.200 as the filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip-range 192.165.0.100 192.165.0.200
Use source-ip-range to specify a source IPv6 address range as a filtering criterion of a security policy rule.
Use undo source-ip-range to remove the specified source IPv6 address range from a security policy rule.
source-ip-range ipv6-address1 ipv6-address2
undo source-ip-range [ ipv6-address1 ipv6-address2 ]
No source IPv6 address range is specified as a filtering criterion for a security policy rule.
context-admin
ipv6-address1 ipv6-address2: Specifies an IPv6 address range. The ipv6-address1 argument represents the start IP address and the ipv6-address2 argument represents the end IP address. If you do not specify the arguments when executing the undo command, the command removes all source IPv6 address ranges from the security policy rule.
You can execute the command multiple times to specify multiple source IPv6 address ranges as the filtering criteria.
# Specify source IPv6 address range 192::165:100 to 192::165:200 as the filtering criteria of IPv6 security policy rule rule1.
[Sysname-security-policy-ipv6-0-rule1] source-ip-range 192::165:100 192::165:200
Use source-ip-subnet to specify a source IPv4 subnet as a filtering criterion of a security policy rule.
Use undo source-ip-subnet to remove the specified source IPv4 subnet from a security policy rule.
source-ip-subnet ip-address { mask-length | mask }
undo source-ip-subnet [ ip-address { mask-length | mask } ]
No source IPv4 subnet is specified as a filtering criterion for a security policy rule.
context-admin
ip-address { mask-length | mask }: Specifies an IPv4 subnet. You can specify the mask length or the mask in dotted decimal notation. The mask length is in the range of 0 to 32. If you set the mask length to 32 or the mask to 255.255.255.255, the command creates a host address filtering criterion. If you do not specify the arguments when executing the undo command, the command removes all source IPv4 subnets from the security policy rule.
You can execute the command multiple times to specify multiple source IPv4 subnets as the filtering criteria.
If you specify a subnet that has been configured as a source subnet filtering criterion, the command execution fails and the system prompts an error.
# Specify the source subnet with IP address 192.167.0.0 and mask length 24 as a filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip-subnet 192.167.0.0 24
# Specify the source subnet with IP address 192.166.0.0 and mask 255.255.0.0 as a filtering criteria of IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip-subnet 192.166.0.0 255.255.0.0
source-ip-subnet (IPv6 security policy view)
Use source-ip-subnet to specify a source IPv6 subnet as a filtering criterion of a security policy rule.
Use undo source-ip-subnet to remove the specified source IPv6 subnet from a security policy rule.
source-ip-subnet ipv6-address prefix-length
undo source-ip-subnet [ ipv6-address prefix-length ]
No source IPv6 subnet is specified as a filtering criterion for a security policy rule.
context-admin
ipv6-address prefix-length: Specifies an IPv6 subnet. The prefix length is in the range of 1 to 128. If you set the prefix length to 128, the command creates a host address filtering criterion. If you do not specify the arguments when executing the undo command, the command removes all source IPv6 subnets from the security policy rule.
You can execute the command multiple times to specify multiple source IPv6 subnets as the filtering criteria.
# Specify the source subnet with IPv6 address 192: 167::0 and prefix length 64 as a filtering criteria of IPv6 security policy rule rule1.
[Sysname-security-policy-ipv6-0-rule1] source-ip-subnet 192:167::0 64
source-mac
Use source-mac to specify a source MAC address object group as a filtering criterion of a security policy rule.
Use undo source-mac to remove the specified source MAC address object group from a security policy rule.
source-mac object-group-name
undo source-mac [ object-group-name ]
No source MAC address object group is specified as a filtering criterion for a security policy rule.
context-admin
object-group-name: Specifies the name of a source MAC address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo source-mac command, the command removes all source MAC address object groups from the rule. For more information about MAC address object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple source MAC address object groups as the filtering criteria.
# Specify source MAC address object groups mac1 and mac2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-mac mac1
[Sysname-security-policy-ip-0-rule1] source-mac mac2
object-group
source-zone
Use source-zone to specify a source security zone as a filtering criterion of a security policy rule.
Use undo source-zone to remove the specified source security zone from a security policy rule.
source-zone source-zone-name
undo source-zone [ source-zone-name ]
No source security zone is specified as a filtering criterion for a security policy rule.
context-admin
source-zone-name: Specifies the name of a source security zone, a case-insensitive string of 1 to 31 characters. If you do not specify this argument when executing the undo source-zone command, the command removes all source security zones from the rule. For more information about security zones, see Security Configuration Guide.
You can execute the command multiple times to specify multiple source security zones as the filtering criteria.
# Specify source security zones trust and dmz as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-zone trust
[Sysname-security-policy-ip-0-rule1] source-zone dmz
security-zone
time-range
Use time-range to specify the time range during which a security policy rule is in effect.
Use undo time-range to restore the default.
undo time-range
A security policy rule is in effect at any time.
context-admin
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. For more information about time ranges, see ACL and QoS Configuration Guide.
# Enable security policy rule rule1 to be in effect during time range work.
[Sysname-security-policy-ip-0-rule1] time-range work
time-range (ACL and QoS Command Reference)
track
Use track to associate a security policy rule with a track entry.
Use undo track to disassociate a security policy rule from the track entry.
track { negative | positive } track-entry-number
undo track
No track entry is associated with a security policy rule.
context-admin
negative: Specifies the Negative state of a track entry.
positive: Specifies the Positive state of a track entry.
track-entry-number: Specifies the number of a track entry, in the range of 1 to 1024. For more information about Track, see Network Management and Monitoring Configuration Guide.
Use this command to enable the collaboration between the track module and a security policy rule. The collaboration operates as follows:
· If a rule is associated with the Negative state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Negative state.
¡ Sets the rule state to Inactive if the track entry is in Positive state.
· If a rule is associated with the Positive state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Positive state.
¡ Sets the rule state to Inactive if the track entry is in Negative state.
# Associate security policy rule rule1 with the Positive state of track entry 10.
[Sysname-security-policy-ip-0-rule1] track positive 10
track bfd (Network Management and Monitoring Command Reference)
track interface (Network Management and Monitoring Command Reference)
track ip route reachability (Network Management and Monitoring Command Reference)
track nqa (Network Management and Monitoring Command Reference)
user
Use user to specify a user as a filtering criterion of a security policy rule.
Use undo user to remove the specified user filtering criterion from a security policy rule.
user username [ domain domain-name ]
undo user [ username [ domain domain-name ] ]
No user is specified as a filtering criterion for a security policy rule.
context-admin
username: Specifies a username, a case-sensitive string of 1 to 55 characters. The name cannot be a, al, or all and cannot contain backslashes (\), vertical bars (|), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), or at signs (@). If you do not specify this argument when executing the undo user command, the command removes all users from the rule. For more information about users and identity domains, see user identification in Security Configuration Guide.
domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The string cannot contain forward slashes (/), backslashes (\), vertical bars (|), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), or at signs (@). If you do not specify this option, the command matches the user among users that do not belong to any identity domain.
You can execute the command multiple times to specify multiple users as the filtering criteria.
# Specify users usera and userb in identity domain test as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] user usera domain test
[Sysname-security-policy-ip-0-rule1] user userb domain test
user-identity enable
user-identity static-user
user-group
Use user-group to specify a user group as a filtering criterion of a security policy rule.
Use undo user-group to remove the specified user group filtering criterion from a security policy rule.
user-group user-group-name [ domain domain-name ]
undo user-group [ user-group-name [ domain domain-name ] ]
No user group is specified as a filtering criterion for a security policy rule.
context-admin
user-group-name: Specifies the name of a user group, a case-insensitive string of 1 to 200 characters. If you do not specify this argument when executing the undo user-group command, the command removes all user groups from the rule. For more information about user groups and identity domains, see user identification in Security Configuration Guide.
domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The string cannot contain forward slashes (/), backslashes (\), vertical bars (|), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), or at signs (@). If you do not specify this option, the command matches the user group among user groups that do not belong to any identity domain.
You can execute the command multiple times to specify multiple user groups as the filtering criteria.
# Specify user groups groupa and groupb in identity domain test as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] user-group groupa domain test
[Sysname-security-policy-ip-0-rule1] user-group groupb domain test
user-group
vrf
Use vrf to configure a security policy rule to take effect on received packets of the specified MPLS L3VPN instance.
Use undo vrf to restore the default.
vrf vrf-name
undo vrf
A security policy rule takes effect on received packets of the public network.
Security policy rule view
context-admin
vrf-name: Specifies the name of an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
# Configure security policy rule rule1 to take effect on received packets of MPLS L3VPN instance vpn1.
[Sysname-security-policy-ip] rule 0 name rule1
