06-AP Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C FAT AP Configuration Guide(R5436)-6W10106-AP Management Configuration Guide
01-AP management configuration
01-AP management configuration 65.00 KB
Managing the AP
Configuring the default input power level
The power level of the AP can be high, middle, or low. The AP automatically obtains its input power level from the uplink switch at startup. If the AP fails to obtain its input power level, the AP operates at the configured default input power level.
An AP can be powered through a power adapter or through its PoE or PoE+ ports. The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode
Input power level
·     Power adapter.
·     Multiple PoE+ ports.
·     Combination of PoE and PoE+ ports.
High
·     Single PoE+ port
·     Multiple PoE ports
Middle
Single PoE port
Low
An AP's support for MIMO modes and the USB interface varies by power level, as shown in Table 1.
Table 1 AP's support for MIMO modes and the USB interface
Input power level
Supported MIMO modes
Whether USB interfaces can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
When you configure the default input power level for the AP, make sure the setting matches its power mode. An excessively low input power level prevents the AP from operating correctly. An excessively high input power level causes overload of the AP in case of power shortage.
2.     Configure the default input power level.
Wlan power-level default { high | low | middle }
By default, the default input power level is middle.
Enabling or disabling the USB interface
After you enable the USB interface for the AP, the USB interface becomes active only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
For information about input power levels, see "Configuring the default input power level." For information about MIMO modes, see "Configuring radio management."
Hardware and feature compatibility
Hardware series
Model
Feature compatibility
WA6600 series
WA6628E-T
No
WA5600 series
WA5630X
No
WA5620E-T
No
WA5500 series
WA5530
Yes
WA5530i
No
WA5530X
No
WA5530S
Yes
WA5530-SI
No
WA5530-LI
No
WA5510E-T
No
WA5300 series
WA5340
No
WA5320i
Yes
WA5320i-LI
Yes
WA5320X
No
WA5320X-LI
No
WA5320X-E
No
WA5320X-SI
No
UAP300 series
UAP300
Yes
WAP723 series
WAP723-W2
No
WAP722 series
WAP722X-W2
No
WAP722XS-W2
No
Hardware series
Model
WA530 series
WA538
Yes
WA536
No
WA5330
No
WA530X
No
2.     Enable the USB interface.
usb enable}
By default, the USB interface is disabled on the AP.
Setting a LED lighting mode
You can configure LEDs on the AP to flash in the following modes:
·     quiet—All LEDs are off.
·     awake—All LEDs flash once every minute.
·     always-on—All LEDs are steady on.
·     normal—This mode can identify the running status of an AP.
2.     Set a LED lighting mode.
wlan led-mode { always-on | awake | normal | quiet }
By default, the LED lighting mode is normal.
Specifying a region code
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring the AP.
To prevent regulation violation caused by region code modification, lock the region code.
2.     Enter global configuration view.
wlan global-configuration
3.     Specify a region code.
region-code code
By default, the region code is CN.
4.     (Optional.) Lock the region code.
region-code-lock enable
By default, the region code is not locked.
Enabling GPS information reporting
This feature enables an AP installed with GPS antennas to output GPS information at intervals and send the GPS information to the information center. For more information about the destination and output rules in the information center, see Network Management and Monitoring Configuration Guide.
Hardware series
Model
WA6600 series
WA6628E-T
No
WA5600 series
WA5630X
Yes
WA5620E-T
No
WA5500 series
WA5530
No
WA5530i
No
WA5530X
No
WA5530S
No
WA5530-SI
No
WA5530-LI
No
WA5510E-T
No
WA5300 series
WA5340
No
WA5320i
No
WA5320i-LI
No
WA5320X
Yes
WA5320X-LI
No
WA5320X-E
No
WA5320X-SI
No
UAP300 series
UAP300
No
WAP723 series
WAP723-W2
No
WAP722 series
WAP722X-W2
No
WAP722XS-W2
No
Hardware series
Model
WA530 series
WA538
No
WA536
No
WA5330
No
WA530X
No
2.     Enable GPS information reporting.
wlan gps-report enable
By default, GPS information reporting is disabled.
3.     Set the interval at which a fat AP reports GPS information.
wlan gps-report interval interval
By default, the interval is 5 seconds.
