- 14-Security Command Reference
- 01-ACL commands
- 02-Time range commands
- 03-User profile commands
- 04-Public key management commands
- 05-PKI commands
- 06-IPsec commands
- 07-SSH commands
- 08-SSL commands
- 09-Session management commands
- 10-Attack detection and prevention commands
- 11-ARP attack protection commands
- 12-ND attack defense commands
- 13-Crypto engine commands
- 14-Connection limit commands
- 15-Password control commands
| 09-Session management commands | 199.08 KB |
display session aging-time application
display session aging-time state
display session relation-table
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table multicast ipv4
display session table multicast ipv6
reset session statistics multicast
reset session table multicast ipv4
reset session table multicast ipv6
session state-machine mode loose
Use display session aging-time application to display the aging time for sessions of different application layer protocols or applications.
# Display the aging time for sessions of different application layer protocols and applications.
<Sysname> display session aging-time application
Application Aging time(s)
bootpc 120
bootps 120
dns 1
ftp 3600
ftp-data 240
gprs-data 60
gprs-sig 60
gtp-control 60
gtp-user 60
h225 3600
h245 3600
https 600
ils 3600
l2tp 120
mgcp-callagent 60
mgcp-gateway 60
netbios-dgm 3600
netbios-ns 3600
netbios-ssn 3600
ntp 120
pptp 3600
qq 120
ras 300
rip 120
rsh 60
rtsp 3600
sccp 3600
sip 300
snmp 120
snmptrap 120
sqlnet 600
stun 600
syslog 120
tacacs-ds 120
tftp 60
who 120
xdmcp 3600
others: 1200
Application |
Name of an application layer protocol or an application. |
Aging time(s) |
Aging time in seconds. |
others:1200 |
All application layer protocols and applications whose aging time is 1200 seconds is displayed as others. |
Use display session aging-time stat to display the aging time for sessions in different protocol states.
# Display the aging time for sessions in different protocol states.
<Sysname> display session aging-time state
State Aging Time(s)
SYN 10
TCP-EST 3600
FIN 10
UDP-OPEN 10
UDP-READY 30
ICMP-REQUEST 30
ICMP-REPLY 10
RAWIP-OPEN 30
RAWIP-READY 60
UDPLITE-OPEN 30
UDPLITE-READY 60
DCCP-REQUEST 30
DCCP-EST 3600
DCCP-CLOSEREQ 30
SCTP-INIT 30
SCTP-EST 3600
SCTP-SHUTDOWN 30
ICMPV6-REQUEST 60
ICMPV6-REPLY 30
TCP-TIME-WAIT 2
TCP-CLOSE 2
State |
Protocol state. |
Aging Time(s) |
Use display session relation-table to display relation entries.
display session relation-table { ipv4 | ipv6 }
ipv4: Specifies IPv4 relation entries.
ipv6: Specifies IPv6 relation entries.
# Display all IPv4 relation entries.
<Sysname> display session relation-table ipv4
Source IP/port: 192.168.1.100/-
Destination IP/port: 192.168.2.100/99
DS-Lite tunnel peer: -
VPN instance/VLAN ID/Inline ID: 1/-/-
Protocol: TCP(6) TTL: 1234s App: FTP-DATA
Source IP/port: -/-
Destination IP/port: 192.168.2.200/1212
Protocol: TCP(6) TTL: 3100s App: H225
Total entries found: 2
# Display all IPv6 relation entries.
<Sysname> display session relation-table ipv6
Source IP: 2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6) TTL: 567s App: FTP-DATA
Total entries found: 1
Source IP/port |
Source IP address and port number of the session. If the IP or port number is not specified, this field displays a hyphen (-). For an IPv6 relation entry, the source port number is not displayed. |
Destination IP/port |
Destination IP address and port number of the session. |
DS-Lite tunnel peer |
Peer tunnel interface address of the DS-Lite tunnel to which the session belongs. If no peer tunnel interface address is specified, a hyphen (-) is displayed. |
VPN instance/VLAN ID/ Inline ID |
MPLS L3VPN instances are not supported in the current software version. MPLS L3VPN instance to which the relation entry belongs. VLAN and inline to which the relation entry belongs during Layer 2 forwarding. If a parameter is not specified, a hyphen (-) is displayed for the proper field. |
Protocol |
Transport layer protocol. |
TTL |
Remaining lifetime of the relation entry, in seconds. |
App |
Application layer protocol. |
Total entries found |
Total number of found relation entries. |
Use display session statistics to display unicast session statistics.
display session statistics [ history-max | summary ]
history-max: Displays history statistics of the maximum unicast sessions and the maximum unicast session establishment rates. If you do not specify this keyword, the command displays all unicast session statistics.
summary: Displays summary information about unicast session statistics. If you do not specify this keyword, the command displays detailed information about unicast session statistics.
If you do not specify any parameters, this command displays detailed information about the current unicast session statistics.
# Display detailed information about unicast session statistics.
<Sysname> display session statistics
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
UDP-Lite sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
History average sessions per second:
Past hour: 1
Past 24 hours: 0
Past 30 days: 0
History average session establishment rate:
Past hour: 0/s
Past 24 hours: 0/s
Past 30 days: 0/s
Current relation-table entries: 0
Relation table establishment rate: 0/s
Session establishment rate: 0/s
TCP: 0/s
UDP: 0/s
ICMP: 0/s
ICMPv6: 0/s
UDP-Lite: 0/s
SCTP: 0/s
DCCP: 0/s
RAWIP: 0/s
Received TCP : 0 packets 0 bytes
Received UDP : 118 packets 13568 bytes
Received ICMP : 105 packets 8652 bytes
Received ICMPv6 : 0 packets 0 bytes
Received UDP-Lite : 0 packets 0 bytes
Received SCTP : 0 packets 0 bytes
Received DCCP : 0 packets 0 bytes
Received RAWIP : 0 packets 0 bytes
Current sessions |
Total number of unicast sessions. |
TCP sessions |
Number of TCP sessions. |
UDP sessions |
Number of UDP sessions. |
ICMP sessions |
Number of ICMP sessions. |
ICMPv6 sessions |
Number of ICMPv6 sessions. |
UDP-Lite sessions |
Number of UDP-Lite sessions. |
SCTP sessions |
Number of SCTP sessions. |
DCCP sessions |
Number of DCCP sessions. |
RAWIP sessions |
Number of Raw IP sessions. |
DNS sessions |
Number of DNS unicast sessions. |
FTP sessions |
Number of FTP unicast sessions. |
GTP sessions |
Number of GTP unicast sessions. |
H323 sessions |
Number of H.323 unicast sessions. |
HTTP sessions |
Number of HTTP unicast sessions. |
ILS sessions |
Number of ILS unicast sessions. |
MGCP sessions |
Number of MGCP unicast sessions. |
NBT sessions |
Number of NBT unicast sessions. |
PPTP sessions |
Number of PPTP unicast sessions. |
RSH sessions |
Number of RSH unicast sessions. |
RTSP sessions |
Number of RTSP unicast sessions. |
SCCP sessions |
Number of SCCP unicast sessions. |
SIP sessions |
Number of SIP unicast sessions. |
SMTP sessions |
Number of SMTP unicast sessions. |
SQLNET sessions |
Number of SQLNET unicast sessions. |
SSH sessions |
Number of SSH unicast sessions. |
TELNET sessions |
Number of Telnet unicast sessions. |
TFTP sessions |
Number of TFTP unicast sessions. |
XDMCP sessions |
Number of XDMCP unicast sessions. |
History statistics of average sessions per second. |
The average number of sessions per second in the most recent hour. |
The average number of sessions per second in the most recent 24 hours. |
The average number of sessions per second in the most recent 30 days. |
History statistics of average session establishment rates. |
The average session establishment rate in the most recent hour. |
The average session establishment rate in the most recent 24 hours. |
The average session establishment rate in the most recent 30 days. |
Current relation-table entries |
Total number of relation entries. |
Relation table establishment rate |
Rate of relation table establishment. |
Session establishment rate |
Unicast session establishment rate, and rates for establishing unicast sessions of different protocols. |
Received TCP |
Number of received TCP packets and bytes. |
Received UDP |
Number of received UDP packets and bytes. |
Received ICMP |
Number of received ICMP packets and bytes. |
Received ICMPv6 |
Number of received ICMPv6 packets and bytes. |
Received UDP-Lite |
Number of received UDP-Lite packets and bytes. |
Received SCTP |
Number of received SCTP packets and bytes. |
Received DCCP |
Number of received DCCP packets and bytes. |
Received RAWIP |
Number of received Raw IP packets and bytes. |
# Display summary information about unicast session statistics.
<Sysname> display session statistics summary
Sessions TCP UDP Rate TCP rate UDP rate
3 0 0 0/s 0/s 0/s
Table 5 Command output
Sessions |
TCP |
Number of TCP unicast sessions. |
UDP |
Number of UDP unicast sessions. |
Rate |
Rate of unicast session creation. |
TCP rate |
Rate of TCP unicast session creation. |
UDP rate |
Rate of UDP unicast session creation. |
# Display history statistics of the maximum unicast sessions and maximum unicast session establishment rates.
<Sysname> display session statistics history-max
Max sessions: 20084 Time: 2017-03-04 12:03:53
Max session establishment rate: 9080/s Time: 2017-03-04 12:03:53
Max TCP sessions: 20084 Time: 2017-03-04 12:03:53
Max TCP session establishment rate: 9080/s Time: 2017-03-04 12:03:53
Max UDP sessions: 0 Time: 2017-03-04 12:03:53
Max UDP session establishment rate: 0 Time: 2017-03-04 12:03:53
Table 6 Command output
Max sessions |
History statistics of the maximum unicast sessions. |
Max session establishment rate |
History statistics of the maximum rate at which unicast sessions were created. |
Max TCP sessions |
History statistics of the maximum TCP unicast sessions. |
Max TCP session establishment rate |
History statistics of the maximum rate at which TCP unicast sessions were created. |
Max UDP sessions |
History statistics of the maximum UDP unicast sessions. |
Max UDP session establishment rate |
History statistics of the maximum rate at which UDP unicast sessions were created. |
Use display session statistics ipv4 to display IPv4 unicast session statistics.
display session statistics ipv4 { destination-ip destination-ip | destination-port destination-port| protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port } *
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv6 unicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv4 protocol.
source-ip source-ip: Specifies a source IPv4 address for a unicast session.
source-zone source-zone-name: Specifies a source security zone by its name, a case-insensitive string of 1 to 31 characters.
If you do not specify any parameters, this command displays all IPv4 unicast session statistics.
# Display statistics for unicast sessions from IP address 111.15.111.66.
<Sysname> display session statistics ipv4 source-ip 111.15.111.66
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
# Display statistics for IPv4 unicast TCP sessions.
<Sysname> display session statistics ipv4 protocol tcp
Current sessions: 3
TCP sessions: 3
Table 7 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMP sessions |
Number of ICMP unicast sessions. |
UDP-Lite sessions |
Number of UDP-Lite unicast sessions. |
SCTP sessions |
Number of SCTP unicast sessions. |
DCCP sessions |
Number of DCCP unicast sessions. |
RAWIP sessions |
Number of Raw IP unicast sessions. |
DNS sessions |
FTP sessions |
GTP sessions |
H323 sessions |
HTTP sessions |
ILS sessions |
MGCP sessions |
NBT sessions |
PPTP sessions |
RSH sessions |
RTSP sessions |
SCCP sessions |
SIP sessions |
SMTP sessions |
SQLNET sessions |
SSH sessions |
TELNET sessions |
TFTP sessions |
XDMCP sessions |
Use display session statistics ipv6 to display IPv6 unicast session statistics.
display session statistics ipv6 { destination-ip destination-ip | destination-port destination-port | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port } *
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session.
protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv6 protocol.
source-ip source-ip: Specifies a source IPv6 address for a unicast session.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv6 unicast session. The value range for the source-port argument is 0 to 65535.
# Display statistics for unicast sessions from IPv6 address 100::2.
<Sysname> display session statistics ipv6 source-ip 100::2
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMPv6 sessions: 3
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
DNS sessions: 0
FTP sessions: 0
GTP sessions: 0
H323 sessions: 0
HTTP sessions: 0
ILS sessions: 0
MGCP sessions: 0
NBT sessions: 0
PPTP sessions: 0
RSH sessions: 0
RTSP sessions: 0
SCCP sessions: 0
SIP sessions: 0
SMTP sessions: 0
SQLNET sessions: 0
SSH sessions: 0
TELNET sessions: 0
TFTP sessions: 0
XDMCP sessions: 0
# Display statistics for IPv6 unicast TCP sessions.
<Sysname> display session statistics ipv6 protocol tcp
Current sessions: 3
TCP sessions: 3
Table 8 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMPv6 sessions |
Number of ICMPv6 unicast sessions. |
UDP-Lite sessions |
SCTP sessions |
DCCP sessions |
RAWIP sessions |
DNS sessions |
FTP sessions |
GTP sessions |
H323 sessions |
HTTP sessions |
ILS sessions |
MGCP sessions |
NBT sessions |
PPTP sessions |
RSH sessions |
RTSP sessions |
SCCP sessions |
SIP sessions |
SMTP sessions |
SQLNET sessions |
SSH sessions |
TELNET sessions |
TFTP sessions |
XDMCP sessions |
Use display session statistic multicast to display multicast session statistics.
# Display information about multicast session statistics.
<Sysname> display session statistics multicast
Current sessions: 0
History max sessions: 0 Time: 2017-04-25 11:28:00
History max session establishment rate: 0/s Time: 2017-04-25 11:28:00
Received: 0 packets 0 bytes
Sent : 0 packets 0 bytes
Table 9 Command output
Current sessions |
Total number of multicast sessions. |
Rate of multicast session creation. |
History max sessions |
History statistics of the maximum multicast sessions. |
History max session establishment rate |
History statistics of the maximum rate at which multicast sessions were created. |
Received |
Number of received multicast packets and bytes. |
Sent |
Number of sent multicast packets and bytes. |
display session table ipv4
Use display session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
display session table ipv4 [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] [ verbose ]
responder: Displays entries of IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 unicast sessions from the initiator to the responder.
application application-name: Specifies an application protocol by its name. The application-name argument is a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a unicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a unicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session. The value range for the source-port argument is 0 to 65535.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
verbose: Displays detailed information about IPv4 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast session entries.
If you do not specify any parameters, this command displays all IPv4 unicast session entries.
# Display brief information about all IPv4 unicast session entries.
<Sysname> display session table ipv4
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
Protocol: TCP(6)
Inbound interface: Vlan-interface 100
Total sessions found: 1
# Display detailed information about all IPv4 unicast session entries.
<Sysname> display session table ipv4 verbose
Initiator:
Protocol: TCP(6)
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.18/1877
Protocol: TCP(6)
Inbound interface: Vlan-interface 101
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Table 10 Command output
Initiator |
Information about the unicast session from the initiator to the responder. |
Responder |
Information about the unicast session from the responder to the initiator. |
Address of the DS-Lite tunnel peer. When the unicast session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
MPLS L3VPN instances are not supported in the current software version. MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
Inbound interface |
Interface on which packets are received. |
State |
Unicast session state. |
Application |
Application layer protocol, FTP or DNS. If it is an unknown protocol identified by an unknown port, this field displays OTHER. |
Start time |
Unicast session establishment time. |
TTL |
Remaining lifetime of the unicast session, in seconds. |
Initiator->Responder |
Number of packets and bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and bytes from the responder to the initiator. |
Total sessions found |
Total number of found unicast session entries. |
display session table ipv6
Use display session table ipv6 to display information about IPv6 unicast session entries that match specific criteria.
display session table ipv6 [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } } * ] [ verbose ]
responder: Displays entries of IPv6 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv6 unicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a unicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a unicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
verbose: Displays detailed information about IPv6 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 unicast session entries.
If you do not specify any parameters, this command displays all IPv6 unicast session entries.
# Display brief information about all IPv6 unicast session entries.
<Sysname> display session table ipv6
Initiator:
Source IP/port: 2011::2/58473
Destination IP/port: 2011::8/32768
Protocol: IPV6-ICMP(58)
# Display detailed information about all IPv6 unicast session entries.
<Sysname> display session table ipv6 verbose
Initiator:
Responder:
Source IP/port: 2011::8/58473
Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER
Start time: 2011-07-29 19:23:41 TTL: 55s
Initiator->Responder: 1 packets 104 bytes
Table 11 Command output
Initiator |
Responder |
Address of the DS-Lite tunnel peer. When the unicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instances are not supported in the current software version. MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the unicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Inbound interface |
State |
Application |
Start time |
TTL |
Use display session table multicast ipv4 to display information about IPv4 multicast session entries that match specific criteria.
display session table multicast ipv4 [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
responder: Displays entries of IPv4 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a multicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a multicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session. The value range for the source-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 multicast session entries.
If you do not specify any parameters, this command displays all IPv4 multicast session entries.
# Display brief information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4
Inbound initiator:
Source IP/port: 3.3.3.4/1609
Destination IP/port: 232.0.0.1/1025
Protocol: UDP(17)
Outbound interface list:
Vlan-interface 101
Vlan-interface 102
Total sessions found: 3
# Display detailed information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4 verbose
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: 232.0.0.1/1025
Destination IP/port: 3.3.3.4/1609
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22 TTL: 18s
Initiator->Responder: 1 packets 84 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: Vlan-interface 101
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: Vlan-interface 102
State: UDP_OPEN
Application: OTHER
Table 12 Command output
Inbound initiator |
Information about the multicast session from the initiator to the responder on the inbound interface. |
Inbound responder |
Information about the multicast session from the responder to the initiator on the inbound interface. |
Outbound initiator |
Information about the multicast session from the initiator to the responder on the outbound interface. |
Outbound responder |
Information about the multicast session from the responder to the initiator on the outbound interface. |
Address of the DS-Lite tunnel peer. If the multicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instances are not supported in the current software version. MPLS L3VPN instance to which the multicast session belongs. VLAN and inline to which the multicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Multicast session state. |
Application |
Start time |
Time when the multicast session was created. |
TTL |
Remaining lifetime of the multicast session, in seconds. |
Inbound interface |
Inbound interface of the first packet from the initiator to responder. |
Outbound interface |
Outbound interface of the first packet from the initiator to responder. |
Outbound interface list |
Outbound interfaces of the first packet from the initiator to responder. |
Total number of found multicast session entries. |
Use display session table multicast ipv6 to display information about IPv6 multicast session entries that match specific criteria.
display session table multicast ipv6 [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
responder: Displays entries of IPv6 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a multicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a multicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
verbose: Displays detailed information about IPv6 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 multicast session entries.
If you do not specify any parameters, this command displays all IPv6 multicast session entries.
# Display brief information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6
Inbound initiator:
Source IP/port: 3::4/1617
Destination IP/port: FF0E::1/1025
Protocol: UDP(17)
Vlan-interface 101
Vlan-interface 102
# Display detailed information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6 verbose
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: FF0E::1/1025
Destination IP/port: 3::4/1617
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58 TTL: 23s
Initiator->Responder: 5 packets 520 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Table 13 Command output
Inbound initiator |
Inbound responder |
Protocol |
Transport layer protocol: · DCCP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Application |
Start time |
TTL |
Inbound interface |
reset session relation-table
Use reset session relation-table to clear relation entries.
reset session relation-table [ ipv4 | ipv6 ]
If you do not specify any parameters, this command clears all relation entries.
# Clear all IPv4 relation entries.
<Sysname> reset session relation-table ipv4
Use reset session statistics to clear unicast session statistics.
# Clear all unicast session statistics.
<Sysname> reset session statistics
Use reset session statistics multicast to clear multicast session statistics.
# Clear all multicast session statistics.
<Sysname> reset session statistics multicast
reset session table
Use reset session table to clear IP unicast session entries.
reset session table
# Clear all unicast session entries.
<Sysname> reset session table
reset session table ipv4
Use reset session table ipv4 to clear information about IPv4 unicast session entries that match specific criteria.
reset session table ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a unicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
If you do not specify any parameters, this command clears all IPv4 unicast session entries on the public network.
# Clear all IPv4 unicast session entries.
<Sysname> reset session table ipv4
# Clear the IPv4 unicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6
Use reset session table ipv6 to clear information about IPv6 unicast session entries that match the specified criteria.
reset session table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a unicast session from the initiator to the responder.
If you do not specify any parameters, this command clears all IPv6 unicast session entries on the public network.
# Clear all IPv6 unicast session entries.
<Sysname> reset session table ipv6
# Clear the IPv6 unicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table ipv6 source-ip 2011::0002
Use reset session table multicast to clear IP multicast session entries.
# Clear all multicast session entries.
<Sysname> reset session table multicast
Use reset session table multicast ipv4 to clear information about IPv4 multicast session entries that match specific criteria.
reset session table multicast ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a multicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
If you do not specify any parameters, this command clears all IPv4 multicast session entries on the public network.
# Clear all IPv4 multicast session entries.
<Sysname> reset session table multicast ipv4
# Clear the IPv4 multicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
Use reset session table multicast ipv6 to clear information about IPv6 multicast session entries that match specific criteria.
reset session table multicast ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a multicast session from the initiator to the responder.
If you do not specify any parameters, this command clears all IPv6 multicast session entries on the public network.
# Clear all IPv6 multicast session entries.
<Sysname> reset session table multicast ipv6
# Clear the IPv6 multicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
Use session aging-time application to set the aging time for sessions of an application layer protocol or an application.
Use undo session aging-time application to restore the default. If you do not specify an application layer protocol or an application, this command restores the default aging time for all sessions of the supported application layer protocols and applications.
session aging-time application application-name time-value
undo session aging-time application [ application-name ]
The aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
· BOOTPC sessions: 120 seconds.
· BOOTPS sessions: 120 seconds.
· DNS sessions: 1 second.
· FTP sessions: 3600 seconds.
· FTP-DATA sessions: 240 seconds.
· GPRS-DATA sessions: 60 seconds.
· GPRS-SIG sessions: 60 seconds.
· GTP-CONTROL sessions: 60 seconds.
· GTP-USER sessions: 60 seconds.
· H.225 sessions: 3600 seconds.
· H.245 sessions: 3600 seconds.
· HTTPS sessions: 600 seconds.
· ILS sessions: 3600 seconds.
· L2TP sessions: 120 seconds.
· MGCP-CALLAGENT sessions: 60 seconds.
· MGCP-GATEWAY sessions: 60 seconds.
· NETBIOS-DGM sessions: 3600 seconds.
· NETBIOS-NS sessions: 3600 seconds.
· NETBIOS-SSN sessions: 3600 seconds.
· NTP sessions: 120 seconds.
· PPTP sessions: 3600 seconds.
· QQ sessions: 120 seconds.
· RAS sessions: 300 seconds.
· RIP sessions: 120 seconds.
· RSH sessions: 60 seconds.
· RTSP session: 3600 seconds.
· SCCP sessions: 3600 seconds.
· SIP sessions: 300 seconds.
· SNMP sessions: 120 seconds.
· SNMPTRAP sessions: 120 seconds.
· SQLNET sessions: 600 seconds.
· STUN sessions: 600 seconds.
· SYSLOG sessions: 120 seconds.
· TACACS-DS sessions: 120 seconds.
· TFTP sessions: 60 seconds.
· WHO sessions: 120 seconds.
· XDMCP sessions: 3600 seconds.
application-name: Specifies an application layer protocol or an application by its name, a case-insensitive string of 1 to 63 characters. Valid characters can be digits, letters, hyphens (-), and underscores (_). The names invalid and other are not allowed. The application layer protocol or application must exist on the device.
time-value: Specifies the aging time in seconds. The value range 1 to 100000.
This command sets the aging time for stable sessions of the specified application layer protocols or applications. For TCP sessions, the stable state is ESTABLISHED. For UDP sessions, the stable state is READY.
For sessions of application layer protocols or applications that are not supported by this command, the aging time is set by the session aging-time state command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for FTP sessions to 1800 seconds.
[Sysname] session aging-time application ftp 1800
# Set the aging time for 126WebEmail sessions to 1800 seconds.
[Sysname] session aging-time application 126WebEmail 1800
Use session aging-time state to set the aging time for the sessions in a protocol state.
Use undo session aging-time state to restore the default for the sessions in a protocol state. If you do not specify a protocol state, this command restores all aging time for sessions in different protocol states to the default.
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
The aging time for sessions in different protocol states is as follows:
· FIN_WAIT: 30 seconds.
· ICMP-REPLY: 30 seconds.
· ICMP-REQUEST: 60 seconds.
· RAWIP-OPEN: 30 seconds.
· RAWIP-READY: 60 seconds.
· TCP SYN-SENT and SYN-RCV: 30 seconds.
· TCP-CLOSE: 2 seconds.
· TCP ESTABLISHED: 3600 seconds.
· TCP TIME-WAIT: 2 seconds.
· UDP-OPEN: 30 seconds.
· UDP-READY: 60 seconds.
fin: Specifies the TCP FIN_WAIT state.
icmp-reply: Specifies the ICMP REPLY state.
icmp-request: Specifies the IGMP REQUEST state.
rawip-open: Specifies the RAWIP-OPEN state.
rawip-ready: Specifies the RAWIP-READY state.
syn: Specifies the TCP SYN-SENT and SYN-RCV states.
tcp-close: Specifies the TCP CLOSE state.
tcp-est: Specifies the TCP ESTABLISHED state.
tcp-time-wait: Specifies the TCP TIME-WAIT state.
udp-open: Specifies the UDP OPEN state.
udp-ready: Specifies the UDP READY state.
time-value: Specifies the aging time in seconds. The value range is 1 to 100000.
This command sets the aging time for stable sessions of the application layer protocols that are not supported by the session aging-time application command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for TCP sessions in SYN-SENT and SYN-RCV states to 60 seconds.
[Sysname] session aging-time state syn 60
Use session persistent acl to specify persistent sessions.
Use undo session persistent acl to restore the default.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ] acl-number
No persistent sessions exist.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
aging-time time-value: Specifies the aging time for persistent sessions in hours. The value range for the time-value argument is 0 to 360, and the default value is 24. To disable the aging for persistent sessions, set the value to 0.
This command is effective only on TCP sessions in ESTABLISHED state.
For a TCP session in ESTABLISHED state, the priority of the aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
The configuration of persistent sessions applies only to new sessions. It has no effect on existing sessions.
Repeat this command to use multiple ACLs to specify persistent sessions.
# Specify IPv4 ACL 2000 for identifying persistent sessions and set the aging time to 72 hours.
[Sysname] session persistent acl 2000 aging-time 72
# Specify IPv6 ACL 3000 for identifying persistent sessions and set the aging time to 100 hours.
[Sysname] session persistent acl ipv6 3000 aging-time 100
Use session state-machine mode loose to set the mode of session state machine to loose.
Use undo session state-machine mode loose to restore the default.
The session state machine is in strict mode.
For asymmetric-path networks, if session synchronization is disabled, to prevent the device from dropping packets abnormally, set the mode of the session state machine to loose.
As a best practice, use the default setting on symmetric-path networks.
# Set the mode of session state machine to loose.
[Sysname] session state-machine mode loose
session statistics enable
Use session statistics enable to enable session statistics collection for software fast forwarding.
Use undo session statistics enable to disable session statistics collection for software fast forwarding.
Session statistics collection is disabled for software fast forwarding.
This command enables the device to collect the session-based outbound and inbound packets and bytes for software fast forwarding.
To display statistics per session, use the display session table command. To display statistics per packet type, use the display session statistics command.
This command is CPU and memory intensive. Before using this command, make sure you fully understand its impact on system performance.
# Enable session statistics collection for software fast forwarding.
[Sysname] session statistics enable
