| 05-802.1X client commands | 67.79 KB |
display dot1x supplicant
Use display dot1x supplicant to display 802.1X authentication information about 802.1X clients.
display dot1x supplicant [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays 802.1X authentication information about 802.1X clients for all interfaces.
# Display 802.1X authentication information about the 802.1X client on GigabitEthernet 1/0/1.
<Sysname> display dot1x supplicant interface gigabitethernet 1/0/1
GigabitEthernet1/0/1
Username : aaa
EAP method : PEAP-MSCHAPv2
Dot1x supplicant : Enabled
Anonymous identifier : bbb
SSL client policy : policy_1
FSM state : Init
EAPOL-Start packets : 0
Username |
802.1X client username. |
EAP method |
802.1X client EAP authentication method: · MD5. · PEAP-GTC. · PEAP-MSCHAPv2. · TTLS-GTC. · TTLS-MSCHAPv2. |
Dot1x supplicant |
Status of the 802.1X client feature: · Enabled. · Disabled. |
Anonymous identifier |
802.1X client anonymous identifier. |
SSL client policy |
SSL client policy used by the 802.1X client feature. |
FSM state |
802.1X client authentication state: · Init—The authentication process starts. · Connecting—The 802.1X client is connecting to the authenticator. · Authenticating—The 802.1X client is being authenticated. · Authenticated—The 802.1X client has been authenticated. · Held—The 802.1X client is waiting for authentication. |
EAPOL-Start packets |
Number of sent EAPOL-Start packets. |
dot1x supplicant anonymous identify
Use dot1x supplicant anonymous identify to configure an 802.1X client anonymous identifier.
Use undo dot1x supplicant anonymous identify to restore the default.
dot1x supplicant anonymous identify identifier
No 802.1X client anonymous identifier exists.
Ethernet interface view
identifier: Specifies an 802.1X client anonymous identifier, a case-sensitive string of 1 to 253 characters.
At the first authentication phase, packets sent to the authenticator are not encrypted. The use of an 802.1X client anonymous identifier prevents the 802.1X client username from being disclosed at the first phase. The 802.1X client-enabled device sends the anonymous identifier to the authenticator instead of the 802.1X client username. The 802.1X client username will be sent to the authenticator in encrypted packets at the second phase.
If no 802.1X client anonymous identifier is configured, the device sends the 802.1X client username in the first phase.
The configured 802.1X client anonymous identifier takes effect only if one of the following EAP authentication methods is used:
· PEAP-MSCHAPv2.
· PEAP-GTC.
· TTLS-MSCHAPv2.
· TTLS-GTC.
If the MD5-Challenge EAP authentication is used, the configured 802.1X client anonymous identifier does not take effect. The device uses the 802.1X client username at the first authentication phase.
Do not configure the 802.1X client anonymous identifier if the vendor-specific authentication server cannot identify anonymous identifiers.
# Configure the 802.1X client anonymous identifier as bbb on a port.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant anonymous identify bbb
dot1x supplicant enable
dot1x supplicant username
dot1x supplicant eap-method
Use dot1x supplicant eap-method to specify an 802.1X client EAP authentication method.
Use undo dot1x supplicant eap-method to restore the default.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
The MD5-Challenge authentication is used as the 802.1X client EAP authentication method.
md5: Specifies the MD5-challenge EAP authentication method.
peap-gtc: Specifies the PEAP-GTC EAP authentication method.
peap-mschapv2: Specifies the PEAP-MSCHAPv2 EAP authentication method
ttls-gtc: Specifies the TTLS-GTC EAP authentication method.
ttls-mschapv2: Specifies the TTLS-MSCHAPv2 EAP authentication method.
Make sure the specified 802.1X client EAP authentication method is supported by the authentication server.
# Specify PEAP-GTC as the 802.1X client EAP authentication method on a port.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant eap-method peap-gtc
Use dot1x supplicant enable to enable the 802.1X client feature.
Use undo dot1x supplicant enable to disable the 802.1X client feature.
The 802.1X client feature is disabled.
Make sure you have configured 802.1X authentication on the authenticator before you use this command.
If the 802.1X client-enabled device is an AP that has online clients, disabling the 802.1X client feature will log off all the online clients.
# Enable the 802.1X client feature on a port.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant enable
dot1x supplicant password
Use dot1x supplicant password to set an 802.1X client password.
Use undo dot1x supplicant password to restore the default.
dot1x supplicant password { cipher | simple } string
No 802.1X client password exists.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 127 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
# Set the 802.1X client password to 123456 in plaintext form on a port.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant password simple 123456
dot1x supplicant ssl-client-policy
Use dot1x supplicant ssl-client-policy to specify an SSL client policy for an 802.1X client-enabled device.
Use undo dot1x supplicant ssl-client-policy to restore the default.
dot1x supplicant ssl-client-policy policy-name
undo dot1x supplicant ssl-client-policy policy-name
An 802.1X client-enabled device uses the default SSL client policy.
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters. Make sure the specified SSL client policy already exists.
If the PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication is used, the 802.1X authentication process is as follows:
· The first phase—The device acts as an SSL client to negotiate with the SSL server.
The SSL client uses the SSL parameters specified in the specified SSL client policy to establish a connection to the SSL server for negotiation. The SSL parameters include a PKI domain, supported cipher suites, and the SSL version.
· The second phase—The device uses the negotiated result to encrypt and transmit the interchanged authentication packets.
If the MD5-Challenge authentication is used, the device does not use an SSL client policy during the authentication process.
#Specify the SSL client policy policy_1 to be used by an 802.1X client-enabled device on the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant ssl-client-policy policy_1
ssl client-policy
Use dot1x supplicant username to configure an 802.1X client username.
Use undo dot1x supplicant username to restore the default.
dot1x supplicant username username
No 802.1X client username exists.
username: Specifies the 802.1X client username, a case-sensitive string of 1 to 253 characters.
802.1X client usernames can include domain names. The supported domain name delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
If a username string includes multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For more information about the domain name delimiters, see the dot1x domain-delimiter command in "802.1X commands."
# Configure the 802.1X client username as aaa on a port.
[Sysname-GigabitEthernet1/0/1] dot1x supplicant username aaa
