06-AP Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C FAT AP Command References(R5436)-6W10106-AP Management Command Reference
01-AP management commands
01-AP management commands 87.81 KB
region-code
Use region-code to specify a region code.
region-code code
The region code is CN.
Global configuration view
code: Specifies a region code. For more information about region codes, see Table 1.
Table 1 Region code information
Country
Code
Country
Code
Andorra
AD
Korea, Republic of Korea
KR
United Arab Emirates
AE
Kenya
KE
Albania
AL
Kuwait
KW
Armenia
AM
Kazakhstan
KZ
Australia
AU
Lebanon
LB
Argentina
AR
Liechtenstein
LI
Australia
AT
Sri Lanka
LK
Azerbaijan
AZ
Lithuania
LT
Bosnia and Herzegovina
BA
Luxembourg
LU
Belgium
BE
Latvia
LV
Bulgaria
BG
Libyan
LY
Bahrain
BH
Morocco
MA
Brunei Darussalam
BN
Monaco
MC
Bolivia
BO
Moldova
MD
Brazil
BR
Macedonia
MK
Bahamas
BS
Macau
MO
Belarus
BY
Martinique
MQ
Belize
BZ
Malta
MT
Canada
CA
Mauritius
MU
Switzerland
CH
Mexico
MX
Cote d'ivoire
CI
Malay Archipelago
MY
Chile
CL
Namibia
NA
China
CN
Nigeria
NG
Colombia
CO
Nicaragua
NI
Costarica
CR
Netherlands
NL
Serbia
RS
Norway
NO
Cyprus
CY
New Zealand
NZ
Czech Republic
CZ
Oman
OM
Germany
DE
Panama
PA
Denmark
DK
Peru
PE
Dominica
DO
Poland
PL
Algeria
DZ
Philippines
PH
Ecuador
EC
Pakistan
PK
Estonia
EE
Puerto Rico
PR
Egypt
EG
Portugal
PT
Spain
ES
Paraguay
PY
Faroe Islands
FO
Qatar
QA
Finland
FI
Romania
RO
France
FR
Russian Federation
RU
Britain
GB
Saudi Arabia
SA
Georgia
GE
Sweden
SE
Gibraltar
GI
Singapore
SG
Greenland
GL
Slovenia
SI
Guadeloupe
GP
Slovak
SK
Greece
GR
San Marino
SM
Guatemala
GT
Salvador
SV
Guyana
GY
Syrian
SY
Honduras
HN
Thailand
TH
Hong Kong
HK
Tunisia
TN
Croatia
HR
Turkey
TR
Hungary
HU
Trinidad and Tobago
TT
Iceland
IS
, Province of China
TW
India
IN
Ukraine
UA
Indonesia
ID
United States of America
US
Ireland
IE
Uruguay
UY
Israel
IL
Uzbekistan
UZ
Iraq
IQ
The Vatican City State
VA
Italy
IT
Venezuela
VE
Iran
IR
Virgin Islands
VI
Jamaica
JM
Vietnam
VN
Jordan
JO
Yemen
YE
Japan
JP
South Africa
ZA
Democratic People's Republic of Korea
KP
Zimbabwe
ZW
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
# Specify the global region code.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-ie
Use region-code-ie to include or exclude region codes in beacon frames and probe responses and specify the installation environment type.
Use undo region-code-ie to restore the default.
region-code-ie { disable | enable { any | indoor | outdoor } }
undo region-code-ie
Beacon frames and probe responses contain region codes and the installation environment type is any.
Service template view
disable: Excludes region codes in beacon frames and probe responses.
enable: Includes region codes in beacon frames and probe responses.
any: Specifies APs that can be installed both indoors and outdoors.
indoor: Specifies APs that can only be installed indoors.
outdoor: Specifies APs that can only be installed outdoors.
If you bind different service templates to radios of an AP, make sure the service templates are specified with the same installation environment type.
# Include region codes in beacon frames and probe responses and specify the type of installation environment as indoor.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] region-code-ie enable indoor
region-code
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
The region code is not locked.
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
usb
Use usb enable to enable the USB interface on the AP.
Use undo usb to restore the default.
usb enable
undo usb enable
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware series
Model
Command compatibility
WA6600 series
WA6628E-T
No
WA5600 series
WA5630X
No
WA5620E-T
No
WA5500 series
WA5530
Yes
WA5530i
No
WA5530X
No
WA5530S
Yes
WA5530-SI
No
WA5530-LI
No
WA5510E-T
No
WA5300 series
WA5340
No
WA5320i
Yes
WA5320i-LI
Yes
WA5320X
No
WA5320X-LI
No
WA5320X-E
No
WA5320X-SI
No
UAP300 series
UAP300
Yes
WAP723 series
WAP723-W2
No
WAP722 series
WAP722X-W2
No
WAP722XS-W2
No
Hardware series
Model
WA530 series
WA538
Yes
WA536
No
WA5330
No
WA530X
No
The USB interface is disabled.
This command takes effect only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
# Enable the USB interface.
[Sysname] usb enable
Use wlan global-configuration to enter global configuration view.
The configuration priorities for an AP in AP view, AP group view, and global configuration view are in descending order. If no settings are configured in one view, the settings in the view with a lower priority are used. If no settings are configured in any one of the three views, the AP uses the default configuration in the view that has the lowest priority.
# Enter global configuration view.
wlan gps-report enable
Use wlan gps-report enable to enable GPS information reporting.
Use undo wlan gps-report enable to disable GPS information reporting.
Hardware series
Model
WA6600 series
WA6628E-T
No
WA5600 series
WA5630X
Yes
WA5620E-T
No
WA5500 series
WA5530
No
WA5530i
No
WA5530X
No
WA5530S
No
WA5530-SI
No
WA5530-LI
No
WA5510E-T
No
WA5300 series
WA5340
No
WA5320i
No
WA5320i-LI
No
WA5320X
Yes
WA5320X-LI
No
WA5320X-E
No
WA5320X-SI
No
UAP300 series
UAP300
No
WAP723 series
WAP723-W2
No
WAP722 series
WAP722X-W2
No
WAP722XS-W2
No
Hardware series
Model
WA530 series
WA538
No
WA536
No
WA5330
No
WA530X
No
GPS information reporting is disabled.
This feature enables an AP installed with GPS antennas to output GPS information at intervals and send the GPS information to the information center. For more information about the destination and output rules in the information center, see Network Management and Monitoring Configuration Guide.
# Enable GPS information reporting.
[Sysname] wlan gps-report enable
wlan gps-report interval
Use wlan gps-report interval to set the interval at which the AP reports GPS information.
Use undo wlan gps-report interval to restore the default.
wlan gps-report interval interval
Hardware series
Model
WA6600 series
WA6628E-T
No
WA5600 series
WA5630X
Yes
WA5620E-T
No
WA5500 series
WA5530
No
WA5530i
No
WA5530X
No
WA5530S
No
WA5530-SI
No
WA5530-LI
No
WA5510E-T
No
WA5300 series
WA5340
No
WA5320i
No
WA5320i-LI
No
WA5320X
Yes
WA5320X-LI
No
WA5320X-E
No
WA5320X-SI
No
UAP300 series
UAP300
No
WAP723 series
WAP723-W2
No
WAP722 series
WAP722X-W2
No
WAP722XS-W2
No
Hardware series
Model
WA530 series
WA538
No
WA536
No
WA5330
No
WA530X
No
An AP reports GPS information every 5 seconds.
interval: Specifies an interval in the range of 1 to 100 seconds.
This feature takes effect only when GPS information reporting is enabled.
# Set the interval at which the AP reports GPS information to 1 second.
[Sysname] wlan gps-report interval 1
wlan led-mode
Use wlan led-mode to set the LED mode.
Use undo wlan led-mode to restore the default.
wlan led-mode { always-on | awake | normal | quiet }
undo wlan led-mode
The LED mode is normal.
always-on: Specifies the always-on mode. In this mode, all LEDs are steady on.
awake: Specifies the awake mode. In this mode, all the LEDs flash once every minute.
normal: Specifies the normal mode. How LEDs flash in this mode varies by AP model. For more information, see the installation guide for the AP.
quiet: Specifies the quiet mode. In this mode, all the LEDs are off.
# Set the LED mode to awake.
[Sysname] wlan led-mode awake
wlan power-level
Use wlan power-level to set the default input power level of the AP.
Use undo wlan power-level to restore the default.
wlan power-level default { high | low | middle }
undo wlan power-level default
The default input power level of the AP is middle.
high: Specifies the high default input power level.
low: Specifies the low default input power level.
middle: Specifies the middle default input power level.
Configure this command in case the AP cannot obtain its input power level at startup from the uplink switch.
The power level of an AP can be high, middle, or low. An AP automatically learns its input power level from the uplink switch at startup. If the learning operation fails, the AP operates at the input power level specified by this command.
The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode
Input power level
·     Power adapter.
·     Multiple PoE+ ports.
·     Combination of PoE and PoE+ ports.
High
·     Single PoE+ port
·     Multiple PoE ports
Middle
Single PoE port
Low
An AP's support for MIMO modes and the USB interface varies by power level, as shown in Table 2.
Table 2 AP's support for MIMO modes and the USB interface
Input power level
MIMO modes
Whether the USB interface can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
# Set the default input power level to low for the AP.
[Sysname] wlan power-level default low
