10-WLAN Traffic Optimization
HomeSupportReference GuidesCommand ReferencesH3C Anchor Command References(R5436)-6W10110-WLAN Traffic Optimization
01-WLAN multicast optimization commands
01-WLAN multicast optimization commands 98.62 KB
display wlan ipv6 multicast-optimization entry
Use display wlan ipv6 multicast-optimization entry to display IPv6 multicast optimization entry information.
display wlan ipv6 multicast-optimization entry [ client mac-address [ group group-ip [ source source-ip ] ] ]
client mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Display information about all IPv6 multicast optimization entries.
<Sysname> display wlan ipv6 multicast-optimization entry
Total 2 clients reported
 Client: 0000-0000-0001
  Reported from AP 1 on radio 1
  Total number of groups: 1
  Group: FF25::1
    Version: MLDv2
    Mode: Include
    Duration: 00h 02m 03s
    Sources: 3
      Source: 1::1
      Source: 1::2
        Duration: 00h 02m 15s
      Source: 1::3
        Duration: 00h 02m 45s
 Client: 0000-0000-0002
  Group: FF25::2
    Version: MLDv2
    Mode: Include
    Duration: 00h 01m 09s
    Sources: 3
      Source: 1::1
        Duration: 00h 01m 11s
      Source: 1::2
      Source: 1::3
        Duration: 00h 01m 45s
Number of clients in the multicast optimization entry table.
Client
MAC address of the client.
Group
Multicast group address.
Version
Version of the multicast group:
·     MLDv1.
·     MLDv2.
Mode
WLAN multicast optimization mode of the multicast group:
·     Include—Multicast packets destined to the multicast group are converted to unicast packets if the multicast source address exists in the source address list obtained from MLDv2 reports.
·     Exclude—Multicast packets destined to the multicast group are not converted to unicast packets if the multicast source address does not exist in the source address list obtained from MLDv2 reports.
This field always displays Exclude for MLDv1 multicast groups.
Duration
Lifetime of the multicast optimization entry for the multicast group or multicast source.
Source
Multicast source address.
display wlan multicast-optimization entry
Use display wlan multicast-optimization entry to display IPv4 multicast optimization entry information.
display wlan multicast-optimization entry [ client mac-address [ group group-ip [ source source-ip ] ] ]
client mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Display information about all IPv4 multicast optimization entries.
<Sysname> display wlan multicast-optimization entry
  Group: 226.0.0.1
    Version: IGMPv3
    Mode: Include
    Duration: 00h 03m 03s
    Sources: 3
      Source: 27.0.0.1
        Duration: 00h 03m 32s
      Source: 27.0.0.2
        Duration: 00h 03m 15s
      Source: 27.0.0.3
  Total number of groups: 2
  Group: 226.0.0.1
    Version: IGMPv3
    Mode: Include
    Sources: 3
      Source: 27.0.0.1
        Duration: 00h 02m 32s
      Source: 27.0.0.2
      Source: 27.0.0.3
        Duration: 00h 02m 23s
  Group: 226.0.0.2
    Version: IGMPv3
    Mode: Include
    Sources: 2
      Source: 27.0.0.1
        Duration: 00h 01m 12s
      Source: 27.0.0.2
Client
Group
Version
·     IGMPv1v2—IGMPv1 or IGMPv2.
·     IGMPv3.
Mode
·     Include—Multicast packets destined to the multicast group are converted to unicast packets if the multicast source address exists in the source address list obtained from IGMPv3 reports.
·     Exclude—Multicast packets destined to the multicast group are not converted to unicast packets if the multicast source address does not exist in the source address list obtained from IGMPv3 reports.
This field always displays Exclude for IGMPv1/v2 multicast groups.
Duration
Source
ipv6 multicast-optimization enable
Use ipv6 multicast-optimization enable to enable IPv6 WLAN multicast optimization.
Use undo ipv6 multicast-optimization enable to disable IPv6 WLAN multicast optimization.
IPv6 WLAN multicast optimization is disabled.
Service template view
# Enable IPv6 WLAN multicast optimization for service template 1.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] ipv6 multicast-optimization enable
Use multicast-optimization enable to enable IPv4 WLAN multicast optimization.
Use undo multicast-optimization enable to disable IPv4 WLAN multicast optimization.
IPv4 WLAN multicast optimization is disabled.
# Enable IPv4 WLAN multicast optimization for service template 1.
[Sysname-wlan-st-1] multicast-optimization enable
reset wlan ipv6 multicast-optimization entry
Use reset wlan ipv6 multicast-optimization entry to clear IPv6 multicast optimization entries.
reset wlan ipv6 multicast-optimization entry { all | client mac-address [ group group-ip [ source source-ip ] ] }
all: Specifies all IPv6 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Clear all IPv6 multicast optimization entries for the client with MAC address 1011-2222-3334.
<Sysname> reset wlan ipv6 multicast-optimization entry client 1011-2222-3334
reset wlan ipv6 multicast-optimization entry group
Use reset wlan ipv6 multicast-optimization entry group to clear IPv6 multicast optimization entries for the specified multicast group.
reset wlan ipv6 multicast-optimization entry group group-ip [ source source-ip ]
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified multicast group.
# Clear IPv6 multicast optimization entries for the multicast group with IPv6 address FF28::1.
<Sysname> reset wlan ipv6 multicast-optimization entry group FF28::1
reset wlan multicast-optimization entry
Use reset wlan multicast-optimization entry to clear IPv4 multicast optimization entries.
reset wlan multicast-optimization entry { all | client mac-address [ group group-ip [ source source-ip ] ] }
all: Specifies all IPv4 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Clear all IPv4 multicast optimization entries for the client with MAC address 1011-2222-3334.
<Sysname> reset wlan multicast-optimization entry client 1011-2222-3334
reset wlan multicast-optimization entry group
Use reset wlan multicast-optimization entry group to clear IPv4 multicast optimization entries for the specified multicast group.
reset wlan multicast-optimization entry group group-ip [ source source-ip ]
group-ip: Specifies a multicast group by its address.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified multicast group.
# Clear IPv4 multicast optimization entries for the multicast group with address 235.1.1.1.
<Sysname> reset wlan multicast-optimization entry group 235.1.1.1
wlan ipv6 multicast-optimization aging-time
Use wlan ipv6 multicast-optimization aging-time to set the aging time for IPv6 multicast optimization entries.
Use undo wlan ipv6 multicast-optimization aging-time to restore the default.
wlan ipv6 multicast-optimization aging-time aging-value
The aging time is 260 seconds for IPv6 multicast optimization entries.
aging-value: Specifies the aging time for IPv6 multicast optimization entries, in the range of 60 to 3600 seconds.
# Set the aging time to 600 seconds for IPv6 multicast optimization entries.
[Sysname] wlan ipv6 multicast-optimization aging-time 600
wlan ipv6 multicast-optimization client entry-limit
Use wlan ipv6 multicast-optimization client entry-limit to set the limit for IPv6 multicast optimization entries per client.
Use undo wlan ipv6 multicast-optimization client entry-limit to restore the default.
wlan ipv6 multicast-optimization client entry-limit [ limit-value ]
No limit is set for IPv6 multicast optimization entries per client.
limit-value: Specifies the limit for IPv6 multicast optimization entries per client, in the range of 8 to 1024. The default value is 256.
Configure this command to limit the number of multicast optimization entries that an AP maintains for each client to prevent a client from occupying excessive system resources.
# Set the limit to 64 for IPv6 multicast optimization entries per client.
[Sysname] wlan ipv6 multicast-optimization client entry-limit 64
wlan ipv6 multicast-optimization entry client-limit
Use wlan ipv6 multicast-optimization entry client-limit to configure an IPv6 multicast optimization policy.
Use undo wlan ipv6 multicast-optimization entry client-limit to restore the default.
wlan ipv6 multicast-optimization entry client-limit [ limit-value ] [ drop | multicast | unicast ]
No IPv6 multicast optimization policies exist and an AP performs WLAN multicast optimization for all clients.
limit-value: Specifies the threshold for the number of clients that WLAN multicast optimization supports, in the range of 1 to 256. The default value is 8.
drop: Configures an AP to drop a multicast packet when the number of clients to receive the packet exceeds the threshold.
multicast: Configures an AP to forward a multicast packet to all clients when the number of clients to receive the packet exceeds the threshold.
unicast: Configures an AP to process a multicast packet as follows when the number of clients to receive the packet exceeds the threshold:
·     Convert the multicast packet to unicast packets.
·     Send the unicast packets to only n (n equal to the specified threshold) clients that are randomly selected.
Use this command to configure the maximum number of clients that WLAN multicast optimization supports and define the action an AP takes when the limit is reached.
If you do not specify an action, an AP performs unicast forwarding.
# Set the threshold for the number of clients that WLAN multicast optimization supports to 32, and specify the unicast forwarding mode.
[Sysname] wlan ipv6 multicast-optimization entry client-limit 32 unicast
wlan ipv6 multicast-optimization global entry-limit
Use wlan ipv6 multicast-optimization global entry-limit to set the limit for IPv6 multicast optimization entries.
Use undo wlan ipv6 multicast-optimization global entry-limit to restore the default.
wlan ipv6 multicast-optimization global entry-limit [ limit-value ]
No limit is set for IPv6 multicast optimization entries.
limit-value: Specifies the limit for IPv6 multicast optimization entries, in the range of 8 to 8192. The default value is 1024.
When the number of multicast optimization entries reaches the limit, the AP stops creating new entries until the number falls below the limit. This action saves system resources.
# Set the limit for IPv6 multicast optimization entries to 512.
[Sysname] wlan ipv6 multicast-optimization global entry-limit 512
wlan ipv6 multicast-optimization packet-rate-limit
Use wlan ipv6 multicast-optimization packet-rate-limit to set the maximum number of MLD packets that can be received from clients within the specified period.
Use undo wlan ipv6 multicast-optimization packet-rate-limit to restore the default.
wlan ipv6 multicast-optimization packet-rate-limit [ interval interval-value | threshold threshold-value ] *
No limit is set for the number of MLD packets that can be received from clients.
interval interval-value: Specifies the interval for calculating the incoming MLD packet rate. The value range is 60 to 3600 seconds. The default setting is 60 seconds.
threshold threshold-value: Specifies the threshold on the number of incoming MLD packets over the specified interval. The value range is 1 to 100000. The default threshold is 100.
If the number of MLD packets received from clients reaches the threshold within the specified interval, the AP stops receiving MLD packets from clients until the next period.
# Configure an AP to receive a maximum of 240 MLD packets every 120 seconds.
[Sysname] wlan ipv6 multicast-optimization packet-rate-limit interval 120 threshold 240
wlan multicast-optimization aging-time
Use wlan multicast-optimization aging-time to set the aging time for IPv4 multicast optimization entries.
Use undo wlan multicast-optimization aging-time to restore the default.
wlan multicast-optimization aging-time aging-value
The aging time is 260 seconds for IPv4 multicast optimization entries.
aging-value: Specifies the aging time for IPv4 multicast optimization entries, in the range of 60 to 3600 seconds.
# Set the aging time to 600 seconds for IPv4 multicast optimization entries.
[Sysname] wlan multicast-optimization aging-time 600
wlan multicast-optimization client entry-limit
Use wlan multicast-optimization client entry-limit to set the limit for IPv4 multicast optimization entries per client.
Use undo wlan multicast-optimization client entry-limit to restore the default.
wlan multicast-optimization client entry-limit [ limit-value ]
No limit is set for IPv4 multicast optimization entries per client.
limit-value: Specifies the limit for IPv4 multicast optimization entries per client, in the range of 8 to 1024. The default value is 256.
# Set the limit to 64 for IPv4 multicast optimization entries per client.
[Sysname] wlan multicast-optimization client entry-limit 64
wlan multicast-optimization entry client-limit
Use wlan multicast-optimization entry client-limit to configure an IPv4 multicast optimization policy.
Use undo wlan multicast-optimization entry client-limit to restore the default.
wlan multicast-optimization entry client-limit [ limit-value ] [ drop | multicast | unicast ]
No IPv4 multicast optimization policies exist and an AP performs WLAN multicast optimization for all clients.
Use this command to configure the maximum number of clients that WLAN multicast optimization supports and define the action an AP takes when the limit is reached. If you do not specify an action, the AP performs unicast forwarding.
[Sysname] wlan multicast-optimization entry client-limit 32 unicast
wlan multicast-optimization global entry-limit
Use wlan multicast-optimization global entry-limit to set the limit for IPv4 multicast optimization entries.
Use undo wlan multicast-optimization global entry-limit to restore the default.
wlan multicast-optimization global entry-limit [ limit-value ]
No limit is set for IPv4 multicast optimization entries.
limit-value: Specifies the limit for IPv4 multicast optimization entries, in the range of 8 to 8192. The default value is 1024.
# Set the limit for IPv4 multicast optimization entries to 512.
[Sysname] wlan multicast-optimization global entry-limit 512
wlan multicast-optimization packet-rate-limit
Use wlan multicast-optimization packet-rate-limit to set the maximum number of IGMP packets that can be received from clients within the specified period.
Use undo wlan multicast-optimization packet-rate-limit to restore the default.
wlan multicast-optimization packet-rate-limit [ interval interval-value | threshold threshold-value ] *
No limit is set for the number of IGMP packets that can be received from clients within the specified period.
interval interval-value: Specifies the interval for calculating the incoming IGMP packet rate. The value range is 60 to 3600 seconds. The default setting is 60 seconds.
threshold threshold-value: Specifies the threshold on the number of incoming IGMP packets over the specified interval. The value range is 1 to 100000. The default threshold is 100.
If the number of IGMP packets received from clients reaches the threshold within the specified interval, the AP stops receiving IGMP packets from clients until the next period.
# Configure an AP to receive a maximum of 240 IGMP packets from clients every 120 seconds.
[Sysname] wlan multicast-optimization packet-rate-limit interval 120 threshold 240
