- 03-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-Port isolation commands
- 06-VLAN commands
- 07-MVRP commands
- 08-Loopback, null, and inloopback interface commands
- 09-QinQ commands
- 10-VLAN mapping commands
- 11-Loop detection commands
- 12-Spanning tree commands
- 13-LLDP commands
- 14-L2PT commands
- 15-Service loopback group commands
14-L2PT commands | 59.85 KB |
L2PT commands
display l2protocol statistics
Use display l2protocol statistics to display Layer 2 Protocol Tunneling (L2PT) statistics.
display l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command displays L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
# Display L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
<Sysname> display l2protocol statistics
L2PT statistics information on interface Bridge-Aggregation1:
Protocol Encapsulated Decapsulated Forwarded Dropped
CDP 0 0 0 0
DLDP 0 3 0 0
EOAM 0 2 0 0
GVRP 8 4 9 2
LACP 0 0 0 0
LLDP 0 3 0 0
MVRP 0 0 0 0
PAGP 0 1 0 0
PVST 0 0 0 0
STP 5 5 5 0
Tunnel N/A N/A 100 10
VTP 0 6 0 0
UDLD 0 0 0 0
L2PT statistics information on interface GigabitEthernet1/0/1:
CDP 0 0 0 0
DLDP 2 3 3 0
EOAM 5 2 9 0
GVRP 8 4 9 2
LACP 0 0 0 0
LLDP 3 3 3 3
MVRP 0 0 0 0
PAGP 5 1 7 3
PVST 0 0 0 0
STP 5 5 5 0
VTP 0 6 0 0
UDLD 0 0 0 0
Encapsulated |
Number of encapsulated packets. The number increases by 1 when the interface receives and encapsulates a protocol packet from a customer network. For protocol Tunnel, which represents tunneled packets, this field displays N/A. |
Decapsulated |
Number of decapsulated packets. The number increases by 1 when the interface receives and decapsulates a tunneled packet from the service provider network. For protocol Tunnel, which represents tunneled packets, this field displays N/A. |
Forwarded |
Number of forwarded packets. The number increases by 1 when the interface receives a protocol packet and forwards it. The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and forwards it. If no interface of the PE is connected to customer networks, the number does not increase. |
Dropped |
Number of dropped packets. The number increases by 1 when the interface receives a protocol packet and drops it. Protocol packets dropped by hardware are not counted. The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and drops it. |
l2protocol tunnel dot1q
Use l2protocol tunnel dot1q to enable L2PT for a protocol.
Use undo l2protocol tunnel dot1q to disable L2PT for a protocol.
In Layer 2 Ethernet interface view:
l2protocol { cdp | dldp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
undo l2protocol { cdp | dldp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
In Layer 2 aggregate interface view:
l2protocol { cdp | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
undo l2protocol { cdp | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
L2PT is disabled for all protocols.
cdp: Specifies CDP.
dldp: Specifies DLDP.
eoam: Specifies EOAM.
gvrp: Specifies GVRP.
lacp: Specifies LACP.
lldp: Specifies LLDP. L2PT for LLDP supports LLDP packets from only nearest bridge agents.
mvrp: Specifies MVRP.
pagp: Specifies PAgP.
pvst: Specifies PVST.
stp: Specifies STP.
udld: Specifies UDLD.
vtp: Specifies VTP.
Before you enable L2PT for a protocol on a port, perform the following tasks:
· Enable the protocol on the CE, and disable the protocol on the port.
· Enable L2PT only on customer-facing PE ports. If you enable L2PT on ports connected to the service provider network, L2PT determines that the ports are connected to a customer network.
· Disable the protocol (for example, STP) on the PE ports connecting to an aggregate interface on a CE when the following conditions exist:
¡ The protocol is running on the aggregate interface on the CE.
¡ The aggregate interface on the CE connects to an L2PT-enabled port on the PE.
Do not enable L2PT on a port that is going to join a service loopback group.
You can enable L2PT on member ports of a Layer 2 aggregation group, but the configuration does not take effect.
# Disable STP and enable L2PT for STP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo stp enable
[Sysname-GigabitEthernet1/0/1] l2protocol stp tunnel dot1q
# Disable STP and enable L2PT for STP on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo stp enable
[Sysname-Bridge-Aggregation1] l2protocol stp tunnel dot1q
l2protocol drop
l2protocol tunnel-dmac
Use l2protocol tunnel-dmac to set the destination multicast MAC address for tunneled packets.
Use undo l2protocol tunnel-dmac to restore the default.
l2protocol tunnel-dmac mac-address
The tunneled packets use 010f-e200-0003 as the destination multicast MAC address.
mac-address: Specifies a destination multicast MAC address. The available addresses are 0100-0ccd-cdd0, 0100-0ccd-cdd1, 0100-0ccd-cdd2, and 010f-e200-0003.
# Set the destination multicast MAC address to 0100-0ccd-cdd0 for tunneled packets.
[Sysname] l2protocol tunnel-dmac 0100-0ccd-cdd0
reset l2protocol statistics
Use reset l2protocol statistics to clear L2PT statistics.
reset l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command clears L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
# Clear L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
<Sysname> reset l2protocol statistics
