| 00-Preface | 100.84 KB |
Preface
The H3C IE4300-12P-AC & IE4300-12P-PWR Industrial Switches Web-Based Configuration Guide describes the web functions of the IE4300-12P-AC and IE4300-12P-PWR switches, such as web overview, task fundamentals, and configuration examples.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
