01-Text
Installing the H3Linux operating system and the SNA Installer platform
Obtaining the operating system image
Installing the H3Linux operating system and the SNA Installer platform on a server
Logging in to the SNA Installer platform
Configuring cluster parameters
Creating an SNA Installer cluster
Obtaining the device information file
Registering a license for the first time
Registering an upgrade license
Managing SNA Center components
Upgrading the SNA Installer platform
Upgrade through image uploading
Upgrade through platform reinstallation
Upgrading the H3Linux OS and the SNA Installer platform
Appendix A SNA Center software dependencies
Introduction
H3C SeerNetwork Architecture (SNA) Center is the core component of the next-generation smart network SNA to provide unified network management, control, analysis, and service orchestration. The SNA Center is able to coordinate services in different management zones to simplify operations and reduce operation costs. It detects network conditions in real time and allows intent-based or network condition-based analysis to bring automated service deployment and risk prediction. This makes networks more simple, intelligent, and effective.
The SNA Center can be deployed only in a cluster with three master nodes on the SNA Installer.
This document describes how to deploy the SNA Center and its components. As shown in Figure 1, follow these steps to deploy the SNA Center and its components.
Figure 1 SNA Center deployment flowchart
Preparing for installation
Hardware requirements
IMPORTANT: For correct operation of the SNA Installer, install it on a physical server rather than a virtual machine. |
The server hardware requirements depend on the SNA Center deployment scheme. Table 1 describes the hardware requirements for deploying only controllers in the SNA Center. Table 2 describes the hardware requirements for deploying controllers and the SeerAnalyzer in the SNA Center.
Table 1 Hardware requirements for deploying only controllers in the SNA Center
Item |
CPU |
Memory size |
Drive |
Ethernet port |
Minimal configuration (supports only essential functions, inadequate for actual service deployment) |
x86-64 (Intel 64/AMD 64) 16 cores 2.0 GHz or above |
64 GB or above |
500 GB or above of 7.2K RPM SATA/SAS HDDs One RAID controller with 1G cache memory of RAID 0, RAID 1, or RAID 10 |
2 × 10Gbps or above Ethernet ports + 2 × 1Gbps or above Ethernet ports |
Recommended configuration (supports all functions) |
128 GB or above |
1 TB or above of 7.2K RPM SATA/SAS HDDs One RAID controller with 1G cache memory of RAID 0, RAID 1, or RAID 10 |
Table 2 Hardware requirements for deploying controllers and the SeerAnalyzer in the SNA Center
Item |
CPU |
Memory size |
Drive |
Ethernet ports |
256 GB or above |
x86-64 (Intel 64/AMD 64) 24 cores 2.0 GHz or above |
256 GB or above |
2 TB or above of 7.2K RPM SATA/SAS HDDs One RAID controller with 1G cache memory of RAID 0, RAID 1, or RAID 10 |
Software requirements
Device |
Requirements |
Server |
Operating system: Support for CentOS 7.5 or higher versions |
Client |
Browser for login: Google Chrome 60 or higher |
NOTE: Software on which the SNA Center depends will be installed automatically during SNA Center installation and no extra operations are required. For more information about the software dependencies, see "Appendix A SNA Center software dependencies." |
Pre-installation checklist
Table 3 Pre-installation checklist
Item |
Requirements |
Result |
Server |
Hardware |
The CPU, memory, disk, and NIC settings are as required. |
Software |
· The server supports operating system CentOS 7.5 or its higher versions. · The system time settings are configured correctly. As a best practice, configure NTP on each node and specify the same time source for all the nodes. |
Client |
Google Chrome 60 or a higher version is installed on the client. |
IMPORTANT: · Installing the H3Linux operating system on a server that already has an operating system installed replaces the existing operating system. To avoid data loss, back up data before you install the H3Linux operating system. · As a best practice, set the server's next startup mode to UEFI. · When using HDM to install the operating system for H3C servers, do not use KVM to install the same image simultaneously for multiple servers. · A power failure during the installation might cause installation failure of some service components. For function integrity, perform a reinstallation if a power failure has occurred during the installation process. |
This section describes the installation procedure on a server without an operating system installed.
To install the H3Linux operating system, first obtain file SNA_CENTER-PACKAGE-version.iso of the required version. version represents the software version number. The image file contains the installation packages of the operating system, SNA Installer, SNA Center, license server, and software dependencies.
1. Use the remote console on the server to load the ISO image through the virtual optical drive.
2. Configure the server to boot from the virtual optical drive and then restart the server.
The INSTALLATION SUMMARY page opens.
Figure 2 INSTALLATION SUMMARY page
3. (Optional.) In the SOFTWARE area, click LICENSE SERVER, and then select Install License Server to install the license server.
NOTE: · You can install the license server on two or three nodes in the SNA Installer cluster to achieve HA or on only one server that is in or out of the cluster. As a best practice, install the license server on all the three master nodes. For more information about license server HA, see H3C License Server Installation Guide. · If you install the license server on a server that is not in the cluster, make sure the server can communicate with all the three master nodes in the cluster. |
Figure 3 LICENSE SERVER page
4. In the SYSTEM area, click NETWORK & HOST NAME. On the NETWORK & HOST NAME page, perform the following tasks:
a. Enter a new host name in the Host name field and then click Apply.
IMPORTANT: · The host names of the nodes in a cluster must be different. A host name must be a string of up to 63 characters. It can contain only lower-case letters, digits, hyphens (-), and dots (.) but cannot start or end with a hyphen (-) or dot (.). · You cannot change the host name after the installation. If you must change it, contact the after-sales engineer. |
b. Click Configure to enter the network configuration page.
IMPORTANT: Configure network settings for only one NIC and disable the other NICs. |
Figure 4 NETWORK & HOST NAME page
5. Configure the network settings as follows:
a. Click the General tab, select Automatically connect to this network when it is available, and retain the default setting for the All users may connect to this network field.
Figure 5 General settings
b. Click the IPv4 Settings tab, select Manual from the Method field, and then click Add to add an IPv4 address for the server. You must specify a gateway for the server when adding an IPv4 address.
CAUTION: The 172.17.0.0/16 and 172.18.0.0/16 network segments are used by Docker and Harbor. To avoid unavailability of the SNA Installer cluster, do not add an IPv4 address in either network segment. |
Figure 6 Configuring an IPv4 address for the server
c. Click Save to save the configuration.
6. On the NETWORK & HOST NAME page, verify that the NIC settings are correct and the NICs are in correct state. Then, click Done to return to the INSTALLATION SUMMARY page.
Figure 7 NETWORK & HOST NAME page
7. Click Begin Installation to start the installation. During the installation process, you will be prompted to configure USER SETTINGS as shown in Figure 8. You can set the root password for the system at the prompt or set the password after the installation as shown in Figure 9.
Figure 8 Setting the root password
Figure 9 Setting the root password
IMPORTANT: Before the system restarts, terminate the connection to the virtual optical drive used for ISO image loading. |
After the installation is complete, the system reboots to finish the installation of the operating system. If you set the root password after the installation, click Finish configuration for the system to restart.
The H3Linux login page opens after the system restarts.
Figure 10 H3Linux login page
8. Use the root password to access the H3Linux operating system and execute the systemctl status matrix command to view the installation result. The installation succeeds if the active state is active (running).
[root@sna001 ~]# systemctl status matrix
matrix.service - Matrix Server
Loaded: loaded (/usr/lib/systemd/system/matrix.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2019-04-11 00:44:51 CST; 18h ago
Main PID: 1180 (karaf)
Installing the SNA Center
1. Select one from the three master nodes for logging in to SNA Installer.
2. Enter https://sna_Installer_ip_address:8443/matrix/ui in the address bar and then press Enter. sna_Installer_ip_address represents the IP address of the master node. 8443 represents the default port number.
Figure 11 SNA Installer platform login page
3. Select a language, enter the username and password, and then click Log in.
The default username is admin and the default password is matrix123.
The system opens the deployment wizard at the first login. On the Configure cluster parameters page, configure cluster parameters as shown in Table 4 and then click Apply. After the system displays a message that the cluster parameters are configured or modified successfully, click Next.
Figure 12 Configuring cluster parameters
Table 4 Cluster parameters description
Item |
Cluster internal virtual IP |
Enter the IP address for internal communication. The mask length is set to 32 and the IP address cannot be modified once configured. This address must be in the same network segment as the master nodes. |
VIP |
Enter the IP address for northbound interface services. The mask length is set to 32. This address must be in the same network segment as the master nodes. |
Service IP pool |
Specify an address pool for IP assignment to services in the cluster. This address cannot conflict with other network segments in the deployment environment. By default, the address pool is 10.96.0.0/16. |
Container IP pool |
Specify an address pool for IP assignment to containers. This address cannot conflict with other network segments in the deployment environment. By default, the address pool is 177.177.0.0/16. |
Use internal NTP server |
Select whether to use the internal NTP server. If you select No, you must specify an NTP server. |
NTP server IP |
Enter the IP address of an NTP server. The IP address cannot be the same as the IP address of any node in the cluster. |
Deploy NFS shared storage |
Select whether to deploy NFS shared storage. If you select External, you must specify an external storage path. In this configuration, select Undeployed. |
External storage path |
Specify the external storage path for the NFS server. |
1. In the Master node area, click the plus icon.
Figure 13 Creating a cluster
2. Configure node parameters as shown in Table 5 and then click Apply.
Figure 14 Configuring node parameters
Table 5 Node parameter description
Item |
Type |
Displays the node type. Options include Master and Worker. This field cannot be modified. |
IP address |
Specify the IP address of the node. |
Username |
Specify the username for the root user to access the operating system. |
Password |
Specify the password for the root user to access the operating system. |
3. Add the other two master nodes in the same way the first master node is added.
Figure 15 Master node configuration completed
4. Click Start deployment.
Figure 16 Deployment in process
When the deployment progress of each node
reaches 100%, the deployment finishes. The tile that has a star icon at
the left corner represents the primary master node.
Figure 17 Cluster deployment completed
5. Click Next.
The page that opens displays the content of the decoded SNA Center installation package obtained by the SNA Installer platform automatically.
1. Click the right chevron button to
enter the configuration page.
Figure 18 Installing SNA Installer applications
2. Configure the parameters as needed. If you are to deploy the SeerAnalyzer component, configure big data-related parameters in the snac-be configuration item, as shown in Table 6.
Figure 19 Deploying SNA Installer applications
Item |
DCIps |
Specify the IP addresses of the Big Data cluster nodes 1, 2, and 3. Use commas to separate the IP addresses. |
DCnames |
Specify the domain names of the Big Data cluster nodes 1, 2, and 3. Use commas to separate the domain names. |
DC_virtual_ip |
Specify the virtual IP address of the Big Data cluster (IP address of the primary master node). |
DC_pwd |
Specify the password for logging in to the Big Data cluster through SSH. |
DCsshServerport |
Specify the SSH service port for the Big Data cluster. |
3. Click Deploy.
The page displays that SNA Center has been deployed after the deployment finishes. You can click the link to access the SNA Center login page or click Completed to enter the SNA Installer application list. The application list displays information about deployed components, as shown in Figure 21.
Figure 20 Component deployment completed
Logging in to the SNA Center
1. Enter http://sna_center_ip_address: 10080/portal/ in the address bar and then press Enter. sna_center_ip_address represents the VIP of the SNA Installer cluster.
Figure 22 SNA Center login page
2. Select a language, enter the username and password, and then click Log in.
The default username is admin and the default password is admin@h3c.
Figure 23 SNA Center homepage
Registering the SNA Center
After you install the SNA Center, you can use complete features and functions of the SNA Center for a 180-day trial period. After the trial period expires, you must get your SNA Center licensed.
To register the SNA Center:
1. Log in to the license server and obtain the device information file for the license server.
2. Log in to the H3C website and use the license keys and device information file to apply for license files.
3. Upload the license files to the license server and connect the SNA Center to the license server.
NOTE: A license file might become invalid if the following hardware changes occur on the server: · NIC forbidden for use, new NIC start, NIC replacement, or NIC damage. · CPU replacement. |
1. Enter http://license_ip_address:8090/ in the address bar and then press Enter. If HA is not configured, license_ip_address represents the IP address of the server that hosts the license server. If HA is configured, license_ip_address represents the virtual IP address or the IP address of the master license server.
2. Select a language, enter the username and password, and then click Login.
3. Select License Management > License Files.
4. On the License Files page, click Export DID.
Applying for license files
To apply for a license file for the SNA Center for the first time, see "Registering a license for the first time." For any subsequent license file applications, see "Registering an upgrade license."
A license key is required for each license file application.
1. Go to the H3C website at http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/ and select Register the First Time.
2. From the Product category list, select New Network_H3C SNA Center.
3. Provide the license, device, and contact information as described in Table 7.
Item |
License information |
Enter the license key. |
Device information |
Upload the device information file. |
Contact information |
Enter your contact information. Items marked with an asterisk (*) are required. |
4. Enter the verification code and select I accept all terms of H3C Legal Statement, and then click Get activation key or file.
5. Save the activation file to the PC.
1. Go to the H3C Website at http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/ and select Register Upgrade Licenses.
3. Provide the license, device, and contact information as described in Table 8.
Item |
4. Enter the verification code and select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Licensing
1. Upload the license files to the license server and add a license client.
a. Log in to the license server. Select License Management > License Files.
b. On the License Files page, click Install license file.
c. In the dialog box that opens, click Browse… to select the license files saved locally. Then, click OK.
After the license files are uploaded, licensing information is displayed on the License Files page.
d. Select Configuration > License Clients. On the page that opens, click Add.
e. Enter client information such as client name and password, and then click OK.
2. Log in to the SNA Center to obtain licensing information.
a. Click Settings on the top navigation bar and then select License from the left navigation pane.
b. In the License Server Info area, provide the IP address, username, password, and port number as described in Table 9.
Table 9 License server information
Item |
IP address |
Specify the IP address configured on the license server used for internal communication in the SNA Installer cluster. |
Port number |
Specify the service port number of the license server. The default value is 5555. |
Username |
Specify the username configured on the license server. |
Password |
Specify the user password configured on the license server. |
c. Click Connect to connect the controller to the license server.
The SNA Center automatically obtains licensing information after connecting to the license server.
IMPORTANT: You can deploy, upgrade, and uninstall SNA Center components only on the SNA Center. |
Different scenarios require different components. This section uses the Layer 2 campus network scenarios to illustrate the procedures.
Deploying components
Preparing for deployment
1. Use Table 10 to identify the required components.
Table 10 Required components for each scenario
Scenario |
Component |
Component installation package |
Campus network |
VCFC-Campus |
VCFC-CAMPUS-version-MATRIX.zip |
vDHCP Server |
vDHCPS-version-X64.zip |
Cloud DC |
VCFC-DataCenter |
VCFC_DC-version-MATRIX.zip |
vDHCP Server |
WAN |
VCFC-WAN |
VCFCWAN-version.zip |
Config Channel (optional) |
ConfigChannel-version.zip |
vDHCP Server (optional) |
Intelligent Analysis Engine |
SeerAnalyzer |
SEERANALYZER-version-MATRIX.zip |
Config Channel |
Campus network + Intelligent Analysis Engine |
Oasis Platform |
oasis-version.zip |
NOTE: · version in an installation package name represents the software version number. · Cloud DC and WAN scenarios are not supported in the current software version. |
2. To deploy the SeerAnalyzer component, modify the configuration file to configure big data-related parameters if you did not specify the parameters during SNA deployment. For more information about the parameters to specify, see step 2 in "Installing the SNA Center."
3. Enable Ethernet adapters on the server that hosts the SNA Center. For the Layer 2 campus network scenarios, you must enable two Ethernet adapters. For any other scenarios, enable only one Ethernet adapter.
To enable an Ethernet adapter:
a. Access the server that hosts the SNA Center remotely.
b. Access the configuration file of an Ethernet adapter. This procedure uses Ethernet adapter ens34 as an example.
[root@sna001 /]# vi /etc/sysconfig/network-scripts/ifcfg-ens34
c. Set the BOOTPROTO field to none to specify no boot-time protocol and set the ONBOOT field to yes to activate the Ethernet adapter at system startup.
Figure 24 Modifying the configuration file of an Ethernet adapter
d. Execute the ifdown and ifup commands in sequence to reboot the Ethernet adapter.
[root@sna001 /]# ifdown ens34
[root@sna001 /]# ifup ens34
e. Execute the ifconfig command to verify that the Ethernet adapter is in UP state.
Deploying a component
Uploading the component installation package
1. Log in to the SNA Center, click Settings, and then select Components > Components.
2. Click Upload to upload the component installation package and then click Next.
Figure 25 Uploading the component installation package
Selecting a component
Select the component to be installed, configure the other settings as required, and then click Next.
Figure 26 Selecting a component (1)
Figure 27 Selecting a component (2)
Table 11 Component description
Item |
Remarks |
Campus network |
Specify the VCF controller for setting up a campus network to implement campus network automation, user access control automation, and policy automation. |
You must specify a network scheme. |
Layer 2 network scheme |
Enables automatically deployed devices to communicate with the VCFC-Campus controller at Layer 2. The controller can use devices' IP addresses to manage the devices automatically. |
You must configure a management network and a default network. For information about the network diagram, see Figure 28. |
Layer 3 network scheme |
Enables automatically deployed devices to communicate with the VCFC-Campus controller at Layer 3. |
You must configure routes in the automated device association template to enable online devices to reach the controller in the management network. For information about the network diagram, see Figure 29. |
Cloud DC |
Specify the VCF controller for setting up a cloud DC network to implement DC network automation and dynamically manage virtual networks and network services. |
N/A |
WAN |
Specify the VCF controller for setting up a WAN to implement service automation and intelligent traffic scheduling for WAN backbone networks, vertical networks, and branch networks. |
N/A |
Specify the intelligent analysis engine, which collects network data through telemetry technologies, and analyzes and processes the data through big data and AI to implement intelligent assurance and prediction for network services. |
N/A |
Public Service |
Specify services shared by multiple scenarios mentioned above. Options include Config Channel and vDHCP server. vDHCP Server is used for automated device deployment. The SNA Center deploys a dual-node cluster for the vDHCP servers based on the predefined policies. |
N/A |
Figure 28 Layer 2 campus network
Figure 29 Layer 3 campus network
Configuring network settings
1. Determine the number of networks and subnets to be created.
¡ For the Layer 2 campus network, create two networks, one as the management network and the other as the default network.
¡ For the Layer 3 campus network, cloud DC, and WAN, create one network.
¡ For the Intelligent Analysis Engine, no network is required. Click Next to proceed to the next step.
2. Create networks and subnets and configure network settings.
If you create different networks that use the same uplink interface, configure different VLANs for the networks to isolate network traffic.
The subnet address range and address pool are used to assign IP addresses to components. Make sure the address range of each subnet contains a minimum of 32 addresses. As a best practice, use Table 12 to determine the address pool size for a subnet.
Table 12 Number of IP addresses required for a subnet
Component |
Number of default network's IP addresses |
Number of management network's IP addresses |
Maximum cluster members |
Default cluster members |
VCFC-Campus |
Number of cluster members + 1 (secondary cluster IP) |
Number of cluster members + 1 (cluster IP) |
32 |
3 |
VCFC-DataCenter |
N/A |
32 |
3 |
VCFC-WAN |
N/A |
5 |
3 |
vDHCP Server |
Number of cluster members |
2 |
2 |
The total number of IP addresses required for a subnet is the sum of IP addresses required by all components for the subnet scenario. For information about components for a scenario, see Table 10.
For example, to deploy a Layer 2 campus network, if the VCFC-Campus cluster has 32 members and the vDHCP cluster has 2 members, the number of required IP addresses for a subnet is as follows:
¡ For a default network subnet: 32 + 1 + 2=35.
¡ For a management network subnet: 32 + 1 + 3=36.
3. Click Next.
Figure 30 Configuring network settings (1)
Figure 31 Configuring network settings (2)
Binding networks
Bind networks to the components and then click Next.
IMPORTANT: · For vDHCP services to be used by the campus network, specify the same management network, default network, and subnets for the VCFC-Campus and the vDHCP components. · In a cloud DC scenario, to deploy the VCFC-DataCenter and vDHCP components on different networks, you must specify a management network for each of the two components and ensure Layer 3 reachability between the two components. |
Figure 32 Binding networks to components (1)
Figure 33 Binding networks to components (2)
On the page that opens, verify that the component settings are correct, and then click Deploy.
A component automatically gets an IP address from the IP address pool of the subnet bound to it. To modify the IP address, click Modify and then specify another IP address for the component. The IP address specified must be in the IP address range of the subnet bound to the component.
Figure 34 Verifying the configuration (1)
The system starts to deploy the components. For a Layer 2 campus network, the system assigns an IP address in the management network as the primary cluster IP and an IP address in the default network as the secondary cluster IP. For a Layer 3 campus network or a cloud DC network, the system assigns an IP address in the management network as the primary cluster IP.
The page displays the deployment progress as shown in Figure 35.
Viewing deployed component information
1. Select Components > Components.
2. Click the right chevron button to expand component information.
Figure 36 Deployed component list
3. To view detailed information, click the icon for the target component.
Upgrading a component
1. Log in to the SNA Center and then select Components > Components.
Figure 37 Deployed component list
2. Click the right chevron button for the target component to expand component information, and then
click the upgrade icon
3. Upload the installation package.
4. Select the package and then click Deploy.
Figure 38 Select an installation package for upgrade
5. If the upgrade fails, click Roll Back to roll back to the previous version.
Uninstalling a component
1. Log in to the SNA Center and select Components > Components.
2. Select the target component and then click .
Figure 39 Uninstalling a component
Uninstalling the SNA Center
1. Log in to the SNA Installer platform.
2. Select Deploy from the top navigation bar and then select Application from the left navigation pane.
3. Click the delete icon
for the SNA
Center application.
4. In the confirmation dialog box that opens, click OK.
Figure 40 Uninstalling the SNA Center
Upgrading the software
This chapter describes procedures for upgrading the SNA Center, SNA Installer, and H3Linux OS. You can upgrade the SNA Installer alone or upgrade it together with the H3Linux OS.
Upgrading the SNA Installer does not affect operation of the SNA Center.
Upgrading the SNA Center
To upgrade the SNA Center, you must uninstall the existing SNA Center and then install the new version. This operation retains the SNA Center configuration and the deployed SNA Center components are still available after the upgrade.
To upgrade the SNA Center:
1. Log in to the SNA Installer platform and uninstall the existing SNA Center. For more information, see "Uninstalling the SNA Center."
3. Click the icon to upload the new
version of the SNA Center installation package.
The uploaded package will be displayed on the Deployment Procedure page.
Figure 41 Deployment process page
4. Install the new version SNA Center. For more information, see "Installing the SNA Center."
You can upgrade the SNA Installer platform on a node by using the following methods:
· Upload image for upgrade—Upgrade through image uploading from the Web interface. You can use this method to upgrade only secondary master nodes. To upgrade a primary master node by using this method, first switch the primary master node to a secondary node.
· Upgrade in background—Upload through platform reinstallation from the CLI. You can use this method to upgrade any master node.
For the SNA Installer platform to operate correctly, do not power off or reboot the server that hosts the platform during the upgrade process.
The SNA Installer platform supports In-Service Software Upgrade (ISSU) to ensure service continuity during the upgrade. To perform an ISSU in an SNA Installer cluster, upgrade secondary master nodes first and then the primary master node. Make sure you upgrade these nodes one by one.
Obtain the ISO image file for the SNA Installer platform, and decompress the package to obtain the matrix-version.rpm image file. version represents the version number.
1. Log in to the SNA Installer platform. Click Deploy on the top navigation bar and then select Cluster from the navigation pane.
2. Click the set icon
for
the target node, and then select Upgrade.
3. In the dialog box than opens, select Upload image for upgrade.
Figure 42 Selecting an upgrade method
4. Select the matrix-version.rpm image file, and then click Upload. After the upload is complete, click Apply to start the upgrade.
Figure 43 Uploading the image file
The node icon turns to blue when the upgrade succeeds.
Figure 44 Upgrade completed
5. Click the icon at the upper right
corner of the page and then select About SNA Installer to verify that
the SNA Installer platform has been upgraded successfully.
Disabling a node to be upgraded
2. Click the set icon for the target
node, and then select Disable.
Figure 45 Disabling a node
Upgrading a disabled node
1. Access the CLI of the node that hosts the SNA Installer.
2. Uninstall the SNA Installer platform.
[root@sna001 ~]# rpm -e matrix
3. Copy or use a file transfer protocol (for example, FTP) to upload the matrix-version.rpm image file to the target directory on the node. The directory is /root in this example.
4. Access the storage directory of the image file and execute the rpm -ivh matrix-version.rpm command. The version number is V500R001B04D001.x86_64 in this example.
[root@sna001 ~]# rpm -ivh matrix-V500R001B04D001.x86_64.rpm
Preparing... ################################# [100%]
Updating / installing...
1:matrix-V500R001B04D001-1 ################################# [100%]
Complete!
5. Execute the systemctl status matrix command to view the installation result. The installation succeeds if the active state is active (running).
● matrix.service - Matrix Server
Active: active (running) since Sat 2019-06-29 01:15:21 CST; 2min 23s ago
Main PID: 29028 (karaf)
Enabling an upgraded node
2. Click Deploy on the top navigation bar and then select Cluster from the navigation pane.
3. Click the set icon for the target
node, and then select Upgrade. In the dialog box
that opens, select Upgrade in background
Figure 46 Upgrading a node
4. Click the set icon for the node, and
then select Enable. The
upgrade succeeds.
Figure 47 Upgrade completed
corner of the page and select About
SNA Installer to verify that the SNA Installer
1. Log in to the SNA Installer. Click Deploy on the
Click the set icon for the target node, and then select Disable to
disable the node.
2. Obtain the ISO image file and reinstall the H3Linux OS and the SNA Installer platform. For more information, see "Installing the H3Linux operating system and the SNA Installer platform."
3. From the SNA Installer GUI, click Deploy on the
Click the set icon for the target node, and then select Upgrade to upgrade the node.
4. After the upgrade finishes, click the set
icon for the node, and then select Enable to enable the node.
Table 13 SNA Center software dependencies
Software name |
Software version |
java openjdk |
1.8.0 |
zip |
3.0 |
unzip |
6.0 |
tar |
1.26-34.el7.x86_64 |
chrony |
3.2-2 |
ntpdate |
4.2.6p5 |
docker-client |
1.13.1 |
docker-common |
1.13.1 |
docker |
1.13.1 |
