| 03-Loopback, null, and inloopback interface configuration | 65.23 KB |
Configuring loopback, null, and inloopback interfaces
About loopback, null, and inloopback interfaces
Configuring a loopback interface
Restoring the default settings for an interface
Display and maintenance commands for loopback, null, and inloopback interfaces
This chapter describes how to configure a loopback interface, a null interface, and an inloopback interface.
About loopback interfaces
A loopback interface is a virtual interface. The physical layer state of a loopback interface is always up unless the loopback interface is manually shut down. Because of this benefit, loopback interfaces are widely used in the following scenarios:
· Configuring a loopback interface address as the source address of the IP packets that the device generates—Because loopback interface addresses are stable unicast addresses, they are usually used as device identifications.
When you configure a rule on an authentication or security server, you can configure it to permit or deny packets carrying the loopback interface address of a device. This simplifies your configuration and achieves the effect of permitting or denying packets that the device generates. To use a loopback interface address as the source address of IP packets, make sure the loopback interface is reachable from the peer by performing routing configuration. All data packets sent to the loopback interface are considered packets sent to the device itself, so the device does not forward these packets.
· Using a loopback interface in dynamic routing protocols—With no router ID configured for a dynamic routing protocol, the system selects the highest loopback interface IP address as the router ID. In BGP, to avoid interruption of BGP sessions due to physical port failure, you can use a loopback interface as the source interface of BGP packets.
About null interfaces
A null interface is a virtual interface and is always up, but you cannot use it to forward data packets or configure it with an IP address or link layer protocol. The null interface provides a simpler way to filter packets than ACL. You can filter undesired traffic by transmitting it to a null interface instead of applying an ACL. For example, if you specify a null interface as the next hop of a static route to a network segment, any packets routed to the network segment are dropped.
About inloopback interfaces
An inloopback interface is a virtual interface created by the system, which cannot be configured or deleted. The physical layer and link layer protocol states of an inloopback interface are always up. All IP packets sent to an inloopback interface are considered packets sent to the device itself and are not forwarded.
1. Enter system view.
2. Create a loopback interface and enter loopback interface view.
interface loopback interface-number
3. Configure the interface description.
The default setting is interface name Interface (for example, LoopBack1 Interface).
4. Configure the expected bandwidth of the loopback interface.
bandwidth bandwidth-value
By default, the expected bandwidth of a loopback interface is 0 kbps.
5. Bring up the loopback interface.
By default, a loopback interface is up.
Configuring a null interface
2. Enter null interface view.
interface null 0
Interface Null 0 is the default null interface on the device and cannot be manually created or removed.
Only one null interface, Null 0, is supported on the device. The null interface number is always 0.
The default setting is NULL0 Interface.
CAUTION: This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network. |
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2. Enter loopback interface view or null interface view.
¡ interface loopback interface-number
¡ interface null 0
3. Restore the default settings for the interface.
default
Task |
Command |
Display information about the inloopback interface. |
display interface [ inloopback [ 0 ] ] [ brief [ description | down ] ] |
Display information about the specified or all loopback interfaces. |
display interface [ loopback [ interface-number ] ] [ brief [ description | down ] ] |
Display information about the null interface. |
display interface [ null [ 0 ] ] [ brief [ description | down ] ] |
Clear the statistics on the specified or all loopback interfaces. |
reset counters interface [ loopback [ interface-number ] ] |
Clear the statistics on the null interface. |
reset counters interface [ null [ 0 ] ] |
