- 04-DPI Configuration Guide
- 01-DPI overview
- 02-DPI engine configuration
- 03-IPS configuration
- 04-URL filtering configuration
- 05-Data filtering configuration
- 06-File filtering configuration
- 07-Anti-virus configuration
- 08-Data analysis center configuration
- 09-WAF configuration
- 10-Proxy policy configuration
| 00-Preface | 100.71 KB |
Preface
· This configuration guide describes the fundamentals and configuration procedures for DPI features, including DPI overview, DPI engine, IPS, URL filtering, data filtering, file filtering, and anti-virus.
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, configuration files, and licenses.
· FTP and TFTP.
· Tcl and Python.
· ISSU and common software upgrade.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
