- 17-Network Management and Monitoring Command Reference
- 01-Information center commands
- 02-Flow log commands
- 03-Fast log output commands
- 04-NetStream commands
- 05-Mirroring commands
- 06-Packet capture commands
- 07-System maintenance and debugging commands
- 08-NQA commands
- 09-NTP commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-NETCONF commands
- 13-SNMP commands
- 14-RMON commands
- 15-Event MIB commands
- 16-CWMP commands
| 00-Preface | 100.54 KB |
Preface
· This command reference describes configuration commands for network management and monitoring features. It includes the following feature modules:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, configuration files, and licenses.
· FTP and TFTP.
· Tcl and Python.
· ISSU and common software upgrade.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
