| 03-VM configuration | 235.70 KB |
Restrictions: Hardware compatibility with VMs
VM configuration tasks at a glance
Removing a disk or CD-ROM from a VM
Specifying a boot order number for a disk or CD-ROM
Removing an SR-IOV NIC from a VM
Specifying a VLAN for a vTap NIC
Allocating CPU cores to the VM plane
Binding vCPUs to physical CPUs
Configuring VNC parameters for remote VM login
Display and maintenance commands for VMs
Configuring virtual machines
About virtual machine hosting
A virtual machine (VM) is a complete computer system running in an isolated environment with full hardware system functions simulated by software. A VM can provide the same services as a physical computer. When creating a VM, you need to assign part of the CPU, memory, and hard disk resources on the physical device that hosts the VM to the VM. Each VM can install an operating system like a physical computer for service processing.
The device can act as an ICT converged gateway that integrates IT and CT. It supports VM deployment through x86 virtualization technology to complete interaction of service data for enterprise users.
Architecture
An SR6600 RPE-X5E MPU can host one or multiple VMs. The maximum number of hosted VMs on the MPU depends on the device's CPU and memory usage. The device can use Layer 2 broadcast and Layer 3 routing to communicate with a VM, as shown in Figure 1.
IMPORTANT: The dotted lines in the figure represent links virtualized by software. The virtual links only indicate the connection relationship. The solid lines represent physical links that actually exist inside the device. |
Figure 1 SR6600 router architecture with the RPE-X5E MPU
As shown in Figure 1, the router architecture contains the following components:
· VMs—Deployed as needed on the MPU to offer new applications or services. The operating system of a VM is called the guest OS.
· SR-IOV NIC—NIC built with single route input/output virtualization (SR-IOV) technology to support hardware-based virtualization. VMs use SR-IOV physical functions (PF) to access the I/O modules through physical SR-IOV NICs at high performance as if through physical interfaces.
· vTap NIC—Software-based virtual NIC that connects VMs to the vSwitch. A vTap NIC has lower performance than a PF interface. The device reserves eight MAC addresses for vTap NICs to use.
· VM-Ethernet—Virtual Layer 2 Ethernet interfaces on the virtual software switching system (vSwitch). The device supports eight VM-Ethernet interfaces. By default, the interfaces belong to VLAN 1. The device randomly associates a VM-Ethernet interface with a vTap NIC.
· vSwitch—Distributed virtual software switching system, which contains vSwitches deployed on MPUs. A vSwitch provides Layer 2 VM-Ethernet ports for VM vTap NICs.
· Router—The routing system.
· MGE—Management Ethernet ports used to upload software image files or Telnet to the device.
· Switch (BKE)—The carrier of the RPE-X5E MPU. The carrier is integrated with switching chips used to connect MPUs and connect an MPU to service modules.
· FIP/SAP—Service modules, which provide Layer 2 or Layer 3 Ethernet ports and fiber ports.
· WAN—Layer 3 Ethernet ports.
· LAN—Layer 2 Ethernet ports. By default, the ports belong to VLAN 1.
· SFP+—Physical 10 GigbitEthernet fiber ports. The SPF+ ports on the RPE-X5E MPU are used to connect SR-IOV NICs.
Supported vNICs
The VMs on the MPU can use vTap and SR-IOV NICs for network connectivity.
vTap NIC
A vTap NIC provides software-based forwarding. It is slower than an SR-IOV NIC. However, you do not need to install any driver for the vTap NICs. In addition, the vTap NICs can run on a low version operating system.
Use vTap NICs in scenarios where VMs do not process much service data.
SR-IOV NIC
An SR-IOV NIC provides hardware-based forwarding. It forwards traffic at higher speeds than vTap NICs. The RPE-X5E MPU provides two SR-IOV NICs. An SR-IOV NIC is allocated to a VM exclusively.
The PF interface connects a VM to an SR-IOV NIC, which allows the VM to have direct access to the I/O module at high performance as if through a physical interface.
NOTE: To use SR-IOV PFs for VM connectivity, you must install an SR-IOV NIC driver in the guest OS of VMs. If the guest OS is not compatible with the driver, you can only use the vTap NIC for VM connectivity. |
Communication mechanisms
Communication scenarios
Table 1 Communication scenarios and used NICs
Scenario |
Ports or interfaces |
VM-VM traffic forwarding |
· Between vTap interfaces · Between a vTap interface and a PF interface · Between PF interfaces |
VM-WAN traffic forwarding |
· Between a vTap interface and a WAN port · Between a PF interface and a WAN port |
VM-LAN traffic forwarding |
· Between a vTap interface and a LAN port · Between a PF interface and a LAN port |
Figure 2 illustrates the forwarding path for the traffic between the vTap interfaces of two VMs on different MPUs. The vSwitch is used to forward the traffic.
Figure 2 vTap-vTap traffic forwarding
Figure 3 illustrates the forwarding path for the traffic from a vTap interface on one VM to a PF interface on another VM.
1. The source vTap NIC forwards the traffic to the vSwitch.
2. The vSwitch forwards the traffic to the FIP/SAP module.
3. The FIP/SAP module forwards the traffic to the destination PF interface through the SPF+ ports.
The path of PF-to-vTap traffic forwarding is the reverse of the vTap-to-PF traffic forwarding path.
Figure 3 vTap-PF traffic forwarding
Figure 4 illustrates the forwarding path for the traffic between the PF interfaces of two VMs on different MPUs. The SR-IOV NICs forward the traffic through SPF+ ports.
Figure 4 PF-PF traffic forwarding
Figure 5 illustrates the forwarding path for the traffic from a vTap interface on a VM to a WAN port on the FIP/SAP module.
1. The vTap interface forwards the traffic to the vSwitch.
3. The FIP/SAP module forwards the traffic to the WAN port.
The path of WAN-to-vTap traffic forwarding is the reverse of the vTap-to-WAN traffic forwarding path.
Figure 5 vTap-WAN traffic forwarding
Figure 6 illustrates the forwarding path for the traffic from a PF interface on a VM to a WAN port on the device.
1. The SR-IOV NIC forwards the traffic to the FIP/SAP module through an SFP+ port.
2. The FIP/SAP module forwards the traffic to the WAN port.
The path of WAN-to-PF traffic forwarding is the reverse of the PF-to-WAN traffic forwarding path.
Figure 6 PF-WAN traffic forwarding
Figure 7 illustrates the forwarding path for the traffic from a vTap interface on a VM to a LAN port on the device.
3. The FIP/SAP module forwards the traffic to the LAN port.
The path of LAN-to-vTap traffic forwarding is the reverse of the vTap-to-LAN traffic forwarding path.
Figure 7 vTap-LAN traffic forwarding
Figure 8 illustrates the forwarding path for the traffic from a PF interface on a VM to a LAN port on the device. The SR-IOV NIC forwards the traffic to the FIP/SAP module. Then, the FIP/SAP module forwards the traffic to the LAN port.
The path of LAN-to-PF traffic forwarding is the reverse of the PF-to-LAN traffic forwarding path.
Figure 8 PF-LAN traffic forwarding
Only the SR6600 RPE-X5E MPU supports VMs.
To configure and manage VMs, perform the following tasks:
¡ Removing a disk or CD-ROM from a VM
¡ Specifying a boot order number for a disk
¡ Adding an SR-IOV NIC to a VM
¡ Removing an SR-IOV NIC from a VM
¡ Specifying a VLAN for a vTap NIC
¡ Removing a vTap NIC from a VM
¡ Allocating CPU cores to the VM plane
¡ Binding vCPUs to physical CPUs
¡ Configuring VNC parameters for remote VM login
¡ Uninstalling a VM_Ref518998393
Installing a VM
The following VM installation methods are available:
· Install a VM by using a .pkg file—You can bulk-install VMs by using a .pkg VM file. A .pkg file contains all files that make up a VM. All VMs created from a .pkg file have the same parameter settings as the source VM, including their guest OS, CPU, and memory settings. After a VM is installed, you can tune its settings as needed.
· Install a VM by manually specifying its parameters—You can install VMs by specifying VM parameters at the CLI of the device. Each VM has its own parameter settings, including the guest OS, CPU, and memory settings.
If you are using the VM to provide H3C vFW services, use the following guidelines when you specify memory for the VM:
· If the vFW requires only one CPU core, allocate 2 GB of memory to the VM.
· If the vFW requires two CPU cores, allocate 4 GB of memory to the VM.
· If the vFW requires four CPU cores, allocate 8 GB of memory to the VM.
Allocate CPU cores to the VM plane. For more information, see "Allocating CPU cores to the VM plane."
If you are installing a VM by manually specifying its parameters, use the create-disk command to create a disk for the VM as described in "Adding a disk to a VM."
If you are using a .pkg file to install a VM, export an existing .pkg file as described in "Exporting a VM." If a USB flash drive is used to store the .pkg file, make sure the file system format of the USB flash drive is EXT4.
1. Enter system view.
2. Enter VMM view.
vmm
3. Install a VM. Choose one of the following methods:
¡ Install a VM by using a .pkg file.
In standalone mode:
install slot slot-number vm-pkg pkg-path
In IRF mode:
install chassis chassis-number slot slot-number vm-pkg pkg-path
¡ Install a VM based on the specified parameters.
In standalone mode:
install slot slot-number vm-name vm-name vcpu vcpu-count memory size vncport vncport disk disk-file format { raw | qcow2 } disk-bus { ide | virtio } [ cdrom cdrom-file ] [ vnic { vtap [ mac mac-address ] [ vlan vlan-id ] | sriov pf pfid } ]
In IRF mode:
install chassis chassis-number slot slot-number vm-name vm-name vcpu vcpu-count memory size vncport vncport disk disk-file format { raw | qcow2 } disk-bus { ide | virtio } [ cdrom cdrom-file ] [ vnic { vtap [ mac mac-address ] [ vlan vlan-id ] | sriov pf pfid } ]
Starting a VM
For a VM can start successfully, you must make sure the system has sufficient memory. In addition to the memory for VMs, you must also make sure sufficient memory is available for the VM plane to run.
If system memory becomes insufficient while it is running, the system automatically stops the VM that uses the most memory.
Make sure the VM you want to start has been created on the device and the system has sufficient memory to start the VM.
2. Enter VMM view.
vmm
3. Start a VM.
In standalone mode:
start vm slot slot-number vm-name
In IRF mode:
start vm chassis chassis-number slot slot-number vm-name
Resizing a VM
After you install a VM, you can resize the VM as needed by adding or removing its resources such as disks and memory.
Disks for VMs are in the form of disk files. You add a disk to a VM by associating the disk file with the VM.
A VM supports the following bus types of disks:
· IDE—IDE disks and CD-ROMs share disk drive names hda, hdb, hdc, and hdd. The VM randomly assigns a drive name to an IDE disk or CD-ROM.
· Virtio—The drive names of virtio disks are vda, vdb, vdc, and vdd. The VM randomly assigns a drive name to a virtio disk.
A VM supports a maximum of four disks for each bus type.
If you perform this task on a running VM, you must restart the VM for the configuration to take effect. If you perform this task on a stopped VM, the configuration takes effect after you start the VM.
After you add a disk to a VM, you must partition and format that disk on the VM before you can use it.
You can mount only one disk to a vFW VM.
When a VM is deployed, the VM automatically assigns a boot order number of 1 to its boot disk. To change the boot disk, you can perform the following operations:
1. (Optional.) Add a new disk to the VM.
2. Modify the boot order number of the original boot disk.
3. Assign the new boot disk a boot order number that has higher priority than that of the original boot disk.
For more information, see "Specifying a boot order number for a disk." To view the disk boot order, use the display vmdisklist command.
2. Enter VMM view.
vmm
3. Create a VM disk.
create-disk disk-file size size format { raw | qcow2 }
4. Add the disk to a VM.
In standalone mode:
add disk vm slot slot-number vm-name format { raw | qcow2 } disk-file path-file disk-bus { ide | virtio }
In IRF mode:
add disk vm chassis chassis-number slot slot-number vm-name format { raw | qcow2 } disk-file path-file disk-bus { ide | virtio }
Removing a disk or CD-ROM from a VM does not delete the disk or delete the image files uploaded by the CD-ROM. To release storage space, you must use the delete command to manually delete the disk or the image files. For more information, see file system management in Fundamentals Configuration Guide.
2. Enter VMM view.
vmm
3. Remove a disk or CD-ROM from a VM.
In standalone mode:
delete disk vm slot slot-number vm-name target target
delete disk vm chassis chassis-number slot slot-number vm-name target target
Adding a CD-ROM
The CD-ROMs and IDE disks share drive names hda, hdb, hdc, and hdd. When you add a CD-ROM or IDE disk to a VM, the VM randomly assigns a drive name to the CD-ROM or IDE disk.
Before using a newly added CD-ROM, specify a boot order number for it. CD-ROMs that contain operating system image files always have higher boot priority that those containing hardware driver image files. The same type of CD-ROMs boot according to the priority of their boot order numbers.
If you do not change the boot disk or uninstall the images of a CD-ROM after the CD-ROM is installed, the CD-ROM will no longer be used for booting.
When a VM is deployed, the VM automatically assigns a boot order number of 8 to the CD-ROM that contains the operating system image file. To replace the operating system images, perform the following operations:
1. Add a new CD-ROM that contains the new operating system image file.
2. Set the boot order of the new CD-ROM to take precedence over that of the original CD-ROM.
3. (Optional.) Add a new hard disk as the boot disk of the VM.
Alternatively, you can remove the CD-ROM that contains the current operating system image file and add the CD-ROM that contains the new operating system image file to the VM.
For more information about boot order configuration, see "Specifying a boot order number for a disk." To view the disk boot order, use the display vmdisklist command.
2. Enter VMM view.
vmm
3. Add a CD-ROM.
In standalone mode:
add cdrom vm slot slot-number vm-name cdrom-file cdrom-file
In IRF mode:
add cdrom vm chassis chassis-number slot slot-number vm-name cdrom-file cdrom-file
Perform this task to specify a boot order number for a disk or CD-ROM. The lower the number, the higher the boot priority.
To ensure that a VM can start, make sure no disk or CD-ROM has the same boot order number as the disk or CD-ROM used to boot the VM.
2. Enter VMM view.
vmm
3. Specify a boot order number for a disk or CD-ROM.
In standalone mode:
set bootorder vm slot slot-number vm-name target target order-number
In IRF mode:
set bootorder vm chassis chassis-number slot slot-number vm-name target target order-number
Each RPE-X5E MPU provides two SR-IOV NICs for VMs. A VM can use the PF interface of a NIC exclusively for communication.
Perform this task to allocate an SR-IOV NIC to a VM by specifying the MAC address of a PF.
For an SR-IOV NIC to operate on a VM, you must install an SR-IOV NIC driver on the VM.
2. Enter VMM view.
vmm
3. Add an SR-IOV NIC to a VM.
In standalone mode:
add sriov vm slot slot-number vm-name pf pfid
In IRF mode:
add sriov vm chassis chassis-number slot slot-number vm-name pf pfid
Remove a PF from a VM to remove the SR-IOV NIC from that VM.
2. Enter VMM view.
vmm
3. Remove an SR-IOV NIC from a VM.
In standalone mode:
delete sriov vm slot slot-number vm-name pf pfid
In IRF mode:
delete sriov vm chassis chassis-number slot slot-number vm-name pf pfid
Adding a vTap NIC to a VM
The Comware system has reserved eight MAC addresses for vTap NICs. When you add a vTap NIC to a VM, select a MAC address to uniquely identify it.
You can add a vTap NIC only to one VM. To display the MAC addresses of NICs that have been added to a VM, use the display vminterface command.
2. Enter VMM view.
vmm
3. Add a vTap NIC to a VM.
In standalone mode:
add vtap vm slot slot-number vm-name mac mac-address [ vlan vlan-id ]
In IRF mode:
add vtap vm chassis chassis-number slot slot-number vm-name mac mac-address [ vlan vlan-id ]
Use the display vminterface command to obtain the MAC address of the vTap NIC.
2. Enter VMM view.
vmm
3. Specify a VLAN for the vTap NIC of a VM.
In standalone mode:
set vtap vm slot slot-number vm-name mac mac-address vlan vlan-id
In IRF mode:
set vtap vm chassis chassis-number slot slot-number vm-name mac mac-address vlan vlan-id
2. Enter VMM view.
vmm
3. Remove a vTap NIC from a VM.
In standalone mode:
delete vtap vm slot slot-number vm-name mac mac-address
In IRF mode:
delete vtap vm chassis chassis-number slot slot-number vm-name mac mac-address
Functionalities of the system are categorized into the control, data, and VM planes. The virtualization functions run on the VM plane.
By default, the control plane is allocated one physical CPU core, the data plane is allocated the remaining physical CPU cores, and the VM plane is not allocated a physical CPU core.
To change the number of physical CPU cores assigned to the VM plane, perform this task.
For the configuration in this task to take effect, you must save the configuration and reboot the device.
After you modify the number of CPU cores allocated to the VM plane, you must reallocate vCPUs to VMs and bind vCPUs to physical CPUs. For the reallocation and binding to take effect on a VM, you must restart the VM.
2. Allocate physical CPU cores to the VM plane.
In standalone mode:
set vcpu-pool slot slot-number vcpu-number
In IRF mode:
set vcpu-pool chassis chassis-number slot slot-number vcpu-number
Allocating vCPUs to a VM
If you set the number of vCPUs allocated to a VM to 0, the VM will be inaccessible at the next startup. To access the VM, you must reallocate vCPUs to the VM.
2. Enter VMM view.
vmm
3. Allocate vCPUs to a VM.
In standalone mode:
set vcpu vm slot slot-number vm-name vcpu-count vcpu-count
In IRF mode:
set vcpu vm chassis chassis-number slot slot-number vm-name vcpu-count vcpu-count
Perform this task to bind the vCPUs of a VM to physical CPUs on the device.
If you bind multiple vCPUs of a VM to only one physical CPU, the VM might fail to start up because of CPU resource conflict. As a best practice to ensure correct VM startup, bind the vCPUs to different physical CPUs.
2. Enter VMM view.
vmm
3. Bind a vCPU on a VM to a physical CPU.
In standalone mode:
set vcpupin vm slot slot-number vmname vcpuindex vcpuindex cpuindex cpuindex
In IRF mode:
set vcpupin vm chassis chassis-number slot slot-number vmname vcpuindex vcpuindex cpuindex cpuindex
Allocating memory to a VM
To ensure that a VM can operate, make sure the VM is allocated a minimum of 512 MB of memory.
2. Enter VMM view.
vmm
3. Allocate memory to a VM.
In standalone mode:
set memory vm slot slot-number vm-name size size
In IRF mode:
set memory vm chassis chassis-number slot slot-number vm-name size size
Maintaining a VM
To remotely access the desktop of a VM from a VNC viewer (or client), perform this task.
When the VM is running, you can access the VM desktop from a VNC viewer (or client) by using the VNC server IP address and VNC port number. The VNC server IP address is the IP address of a Layer 3 interface or a VLAN interface on the device.
2. Enter VMM view.
vmm
3. Set the VNC port number of the VM.
In standalone mode:
set vnc vm slot slot-number vm-name vncport vncport
In IRF mode:
set vnc vm chassis chassis-number slot slot-number vm-name vncport vncport
4. Set the VNC login password of the VM.
In standalone mode:
set vnc vm slot slot-number vm-name setpasswd password
In IRF mode:
set vnc vm chassis chassis-number slot slot-number vm-name setpasswd password
5. Set the IP address for accessing the VM.
In standalone mode:
set vnc vm slot slot-number vm-name listen ip-address
In IRF mode:
set vnc vm chassis chassis-number slot slot-number vm-name listen ip-address
6. (Optional.) Delete the VNC login password on the VM.
In standalone mode:
set vnc vm slot slot-number vm-name delpasswd
In IRF mode:
set vnc vm chassis chassis-number slot slot-number vm-name delpasswd
Enabling VM auto-start
About VM auto-start
Perform this task to enable a VM to start up automatically when the MPU starts.
2. Enter VMM view.
vmm
3. Enable VM auto-start.
In standalone mode:
autostart vm slot slot-number vm-name
In IRF mode:
autostart vm chassis chassis-number slot slot-number vm-name
By default, VM auto-start is disabled.
Suspending a VM
Perform this task to suspend a VM. The VM will then be placed in Paused state.
2. Enter VMM view.
vmm
3. Suspend a VM.
In standalone mode:
suspend vm slot slot-number vm-name
In IRF mode:
suspend vm chassis chassis-number slot slot-number vm-name
Resuming a suspended VM
2. Enter VMM view.
vmm
3. Resume a suspended VM.
In standalone mode:
resume vm slot slot-number vm-name
In IRF mode:
resume vm chassis chassis-number slot slot-number vm-name
Stopping a VM
When the MPU reboots, the system automatically attempts to stop all VMs on the MPU securely within 6 minutes. If VMs are operating incorrectly, it will take 6 minutes to stop each VM. If the system fails to stop a VM within 6 minutes, it will force that VM down.
Perform this task to manually stop a VM.
CAUTION: A force stop might cause data loss. Do not force a VM down unless necessary. |
If a VM fails to stop because of an abnormal process, access the VM, manually close the process, and retry the stop operation. If the stop operation still fails, force the VM down.
If the VM does not have an operating system, you must specify the force keyword to force it down.
2. Enter VMM view.
vmm
3. Stop a VM.
In standalone mode:
stop vm slot slot-number vm-name [ force ]
In IRF mode:
stop vm chassis chassis-number slot slot-number vm-name [ force ]
Backing up a VM
Perform this task to back up a VM to a .vmb file in the specified path.
Make sure the file path is correct and the target storage medium has sufficient storage space.
If a USB flash drive is used to store the backup file, make sure the file system format of the USB flash drive is EXT4.
You must stop a VM by using the stop vm command before you can back up it.
2. Enter VMM view.
vmm
3. Back up a VM.
In standalone mode:
backup vm slot slot-number vm-name backup-path
In IRF mode:
backup vm chassis chassis-number slot slot-number vm-name backup-path
Restoring a VM
Perform this task to restore a VM by using a .vmb backup file.
2. Enter VMM view.
vmm
3. Restore a VM by using a .vmb backup file.
In standalone mode:
restore slot slot-number pakagepath backup-image-path
In IRF mode:
restore chassis chassis-number slot slot-number pakagepath backup-image-path
Exporting a VM
Perform this task to export a VM to a .pkg file in the specified path.
Make sure you have access permissions to the target path and the target path has sufficient storage space.
If the .pkg file is saved on a USB flash drive, make sure the file system format of the USB flash drive is EXT4.
You must stop a VM by using the stop vm command before you can export it.
2. Enter VMM view.
vmm
3. Export a VM.
In standalone mode:
export vm slot slot-number vm-name pkg-path
In IRF mode:
export vm chassis chassis-number slot slot-number vm-name pkg-path
Uninstalling a VM
After you uninstall a VM, the hard disks allocated to the VM still retain the VM operating system image files and running data files. To release storage space, you must use the delete command to manually delete the hard disks. For more information about deleting hard disks, see file system management in Fundamentals Configuration Guide.
You must stop a VM by using the stop vm command before you can uninstall it.
2. Enter VMM view.
vmm
3. Uninstall a VM.
In standalone mode:
uninstall vm slot slot-number vm-name
In IRF mode:
uninstall vm chassis chassis-number slot slot-number vm-name
Task |
Command |
Display passthrough NIC information. |
display passthrough |
Display the number of CPUs allocated to VMs. |
display vcpu-pool |
Display the VNC port number of a VM. |
display vncport vm vm-name |
Display detailed information about a VM. |
display vm vm-name [ static-configuration ] |
Display the CPU usage of a VM. |
display vmcpu-usage vm vm-name |
Display the bindings between vCPUs and physical CPUs for a VM. |
display vmcpupin vm vm-name |
Display disk usage information about a VM. |
display vmdisk-usage vm vm-name |
Display disk or CD-ROM information. |
display vmdisklist vm vm-name |
Display network interface information about a VM. |
display vminterface vm vm-name |
Display the VM list. |
display vmlist |
Display the memory usage of a VM. |
display vmmem-usage vm vm-name |
