07-Layer 3—IP Services Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R0809-6W40007-Layer 3—IP Services Command Reference
21-WAAS commands
21-WAAS commands 181.35 KB
WAAS commands
class
Use class to specify a Wide Area Application Services (WAAS) class for a WAAS policy and enter WAAS policy class view.
Use undo class to remove a WAAS class from a WAAS policy.
class class-name [ insert-before existing-class ]
undo class class-name
No WAAS class exists in a WAAS policy.
WAAS policy view
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. The specified class must already exist.
insert-before existing-class: Inserts the new class before an existing class in the WAAS policy. If you do not specify this option, the new class is placed at the end of the WAAS policy.
A WAAS policy can use system-defined WAAS classes (see Table 7).
As a best practice, configure a WAAS class by modifying a system-defined WAAS class.
You can also use this command to arrange existing WAAS classes in a WAAS policy.
A packet is checked against WAAS classes in the specified order. When a packet matches a class, the action for the class is performed on the packet, and the match process ends.
If you do not configure an action for a WAAS class, the device ignores the WAAS class.
# Specify the system-defined WAAS class AFS for the WAAS policy waas_global, and enter the view of the WAAS class AFS.
[Sysname] waas policy waas_global
[Sysname-waaspolicy-waas_global] class AFS
[Sysname-waaspolicy-waas_global-AFS]
# Specify the system-defined WAAS class AOL for the WAAS policy waas_global, insert it before AFS, and enter the view of the WAAS class AOL.
[Sysname-waaspolicy-waas_global] class AOL insert-before AFS
[Sysname-waaspolicy-waas_global-AOL]
# Change the position of the WAAS class AOL in the WAAS policy waas_global by inserting it before AFS, and enter the view of the WAAS class AOL.
display waas policy
waas class
waas policy
display waas class
Use display waas class to display WAAS classes.
display waas class [ class-name ]
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS class, this command displays all WAAS classes.
# Display the WAAS class class1.
<Sysname> display waas class class1
WAAS class: class1
  match 1 tcp source 1.1.1.0 24 port 50000 60000
  match 6 tcp destination 2.2.2.2 port 1 1024
  match 11 tcp source 1001:: 96 port 50000 60000
  match 16 tcp destination 2002::2222 port 1 1024
match
Match criterion of the WAAS class.
match tcp
waas class
display waas policy
Use display waas policy to display WAAS policies.
display waas policy [ policy-name ]
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS policy, this command displays all WAAS policies.
# Display the WAAS policy po1.
<Sysname> display waas policy po1
WAAS policy: po1
  class cl1
    optimize TFO DRE LZ
  class cl2
    optimize TFO DRE
  class cl3
    passthrough
  class cl4
    optimize TFO LZ
  class cl5
class
WAAS class in the WAAS policy.
optimize
Optimization actions:
·     TFO (works with only TCP).
·     DRE.
·     LZ compression.
passthrough
Action that does not perform any optimization.
class
optimize
passthrough
waas policy
display waas session
Use display waas session to display WAAS session information.
In standalone mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ slot slot-number ]
In IRF mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 sessions.
ipv6: Specifies IPv6 sessions.
client-ip client-ip: Displays the WAAS session information for the client specified by its IP address.
client-port client-port: Displays the WAAS session information for the clients specified by port number in the range of 1 to 65535.
server-ip server-ip: Displays the WAAS session information for the server specified by its IP address.
server-port server-port: Displays the WAAS session information for the servers specified by port number in the range of 1 to 65535.
peer-id peer-id: Displays the WAAS session information for the peer specified by its bridge MAC address in the format of H-H-H.
verbose: Displays detailed information about WAAS sessions. If you do not specify this keyword, the command displays brief information about WAAS sessions.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays WAAS session information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays WAAS session information for all cards. (In IRF mode.)
If you specify only the ipv4 or ipv6 keyword, this command displays information about all IPv4 or IPv6 WAAS sessions.
# Display brief information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4
Peer ID: 0021-90ad-0012
Start Time: Fri Mar 21 10:43:05 2014
Source IP/Port: 1.1.1.1/34572
Destination IP/Port: 2.2.2.2/80
Peer ID: 0011-10ad-0012
Start Time: Fri Mar 21 10:45:05 2014
Source IP/Port: 2.2.1.1/34572
Destination IP/Port: 3.2.2.3/80
Total 2 sessions found.
# Display detailed information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4 verbose
Peer ID: 0021-90ad0-01221
Start Time: Fri Mar 21 11:43:05 2014
LAN interface: GigabitEthernet2/0/1
WAN interface: GigabitEthernet2/0/2
Configured Policy: TFO DRE LZ
Negotiated Policy: TFO DRE LZ
LAN->WAN bytes: Original   104884      Optimized  88594
WAN->LAN bytes: Original   744588      Optimized  3355445
LZ section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 400
    Space saved: 0%
    Average Latency: 0 usec
  Decode status:
    Bytes in: 329
    Bytes out: 393
    Bypass bytes: 63
    Space saved: 16%
    Average Latency: 2 usec
DRE section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 314
    Space saved: 0%
    Average latency: 0 usec
  Decode status:
    Bytes in: 399
    Bytes out: 332
    Bypass bytes: 0
    Space saved: 0%
    Chunk miss: 0
    Collision: 0
    Average latency: 23 usec
LZ section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 400
    Space saved: 0%
  Decode status:
    Bytes in: 329
    Bytes out: 393
    Bypass bytes: 63
    Space saved: 16%
DRE section:
  Encode status:
    Bytes in: 0
    Bytes out: 0
    Bypass bytes: 314
    Space saved: 0%
  Decode status:
    Bytes in: 399
    Bytes out: 332
    Bypass bytes: 0
    Space saved: 0%
    Chunk miss: 0
    Collision: 0
    Average latency 23 usec
Peer ID
Bridge MAC address of the peer device. A bridge MAC address uniquely identifies a peer device.
Start time
Time when the WAAS session was established.
Source IP/Port
IP address and port number of the client.
Destination IP/Port
IP address and port number of the server.
Configured Policy
Optimization actions configured on the local device, which can be one or any combination of the following actions:
·     DRE.
·     LZ compression.
Negotiated Policy
Optimization actions negotiated with the peer device, which can be one or any combination of the following actions:
·     DRE.
·     LZ compression.
The negotiated optimization actions are the union of the optimization actions configured on the local device and those configured on the peer device.
LAN->WAN bytes
Statistics for LAN-to-WAN data:
·     Original—Number of bytes before optimization.
·     Optimized—Number of bytes after optimization.
WAN->LAN bytes
Statistics for WAN-to-LAN data:
LZ section
LZ compression statistics.
DRE section
DRE statistics.
Encode status
Compression statistics.
Decode status
Decompression statistics.
Bytes in
Number of input bytes.
Bytes out
Number of output bytes.
Bypass bytes
Number of bytes that bypass DRE.
Space saved
·     Compression ratio: (1–Bytes out/Bytes in) x 100.
·     Decompression ratio: (1–Bytes in/Bytes out) x 100.
Average Latency
Average latency in milliseconds for the most recent compression or decompression. When multiple CPUs are available on a card, the average latency is the latency time divided by the number of CPUs.
Chunk miss
Cumulative number of times that DRE failed to find a dictionary entry according to a dictionary index.
Collision
Cumulative number of times that data checks failed.
display waas statistics dre
Use display waas statistics dre to display DRE statistics.
In standalone mode:
display waas statistics dre [ peer peer-id ] [ slot slot-number ]
In IRF mode:
display waas statistics dre [ peer peer-id ] [ chassis chassis-number slot slot-number ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, the command displays DRE statistics for all peer devices.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DRE statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays DRE statistics for all cards. (In IRF mode.)
# Display DRE statistics for all peer devices.
<Sysname> display waas statistics dre
Peer-ID: 0016-9d38-ca1d
Peer version: 1.0
Cache in storage: 19426304 bytes
Index number: 75884
Age: 00 weeks, 00 days, 00 hours, 00 minutes, 33 seconds
Total connections: 1
Active connections: 0
Encode Statistics
  Dre msgs: 2
  Bytes in: 392 bytes
  Bytes out: 424 bytes
  Bypass bytes: 0 bytes
  Bytes Matched: 0 bytes
  Space saved: -8%
Decode Statistics
  Dre msgs: 196407
  Bytes in: 29132703 bytes
  Bytes out: 42413368 bytes
  Space saved: 31%
Peer-ID: 0d38-9d38-ca1d
Peer version: 1.0
Cache in storage: 33554944 bytes
Index number: 131074
Age: 00 weeks, 00 days, 00 hours, 21 minutes, 31 seconds
Total connections: 2
Encode Statistics
  Dre msgs: 514872
  Bytes in: 111390296 bytes
  Bytes out: 60085884 bytes
  Bytes Matched: 56336640 bytes
  Space saved: 46%
Decode Statistics
  Dre msgs: 4
  Bytes in: 849 bytes
  Bytes out: 785 bytes
  Space saved: -8%
# Display DRE statistics for a specific peer device.
<Sysname> display waas statistics dre peer 0016-9d38-ca1d
Peer version: 1.0
Encode Statistics
  Dre msgs: 514872
  Space saved: 46%
Decode Statistics
  Dre msgs: 4
  Bytes in: 849 bytes
  Space saved: -8%
Peer ID
Peer version
WAAS version of the peer device.
Cache in storage
Disk space used by metadata. Metadata are original data that have indexes in the dictionary.
Index number
Number of dictionary indexes.
Age
Amount of time that has elapsed since the local device initially established an optimized TCP connection with the peer.
Total connections
Total number of DRE connections.
Active connections
Number of active DRE connections.
Encode Statistics
Decode Statistics
Dre msgs
Number of data blocks.
Bytes in
Bytes out
Bypass bytes
Bytes Matched
Number of bytes matched by DRE.
Space saved
Average Latency
reset waas statistics dre
display waas statistics udp compress
Use display waas statistics udp compress to display UDP log message compression statistics.
# Display UDP log message compression statistics.
<Sysname> display waas udp compress statistics
  Bytes in                      : 42413368 bytes
  Bytes out                     : 29132703 bytes
  Saved bandwidth ratio         : 31%
  Compressed packet ratio       : 100%
reset waas statistics udp compress
display waas status
Use display waas status to display the global WAAS status.
display waas status
# Display the global WAAS status.
<Sysname> display waas status
WAAS Version: 1.0
Local ID: 02e0-011a-0000
DRE Status: Disabled
LZ Status: Disabled
BlackList Status: Disabled
Total Active connections: 7889
Total data storage size: 1468006400 bytes
Total index number: 11513600
Blacklist Hold-time: 5 minutes
Interfaces             Applied policy
GE2/0/1                waas_global
GE2/0/2                waas_default
GE2/0/3                waas_global
Total policy interfaces: 3
Table 5 Command output
Local ID
Bridge MAC address of the local device. A bridge MAC address uniquely identifies a local device.
Total number of active WAAS connections.
Disk space used by all metadata. Metadata are original data that have indexes in the dictionary.
Total index number
Total number of dictionary indexes.
Blacklist Hold-time
Aging time for blacklist entries.
Interfaces
List of interfaces with WAAS policies applied.
Number of interfaces with WAAS policies applied.
display waas tfo auto-discovery blacklist
Use display waas tfo auto-discovery blacklist to display autodiscovered blacklist information.
In standalone mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ slot slot-number ]
In IRF mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 blacklist information.
ipv6: Specifies IPv6 blacklist information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays autodiscovered blacklist information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays autodiscovered blacklist information for all cards. (In IRF mode.)
# Display all IPv4 blacklist information.
<Sysname> display waas tfo auto-discovery blacklist ipv4
Server IP address/Port           Insert Time
1.1.1.1/8080                     Fri Mar 21 10:43:05 2014
1.1.1.2/8080                     Fri Mar 21 10:43:06 2014
2.2.2.2/443                      Fri Mar 21 10:20:37 2014
Total 3 entries found.
Table 6 Command output
Insert Time
Time when a blacklist entry was generated.
reset waas tfo auto-discovery blacklist
waas tfo auto-discovery blacklist enable
waas tfo auto-discovery blacklist hold-time
match tcp
Use match tcp to configure a match criterion.
Use undo match tcp to delete a match criterion.
match [ match-id ] tcp { any | destination | source } [ ip-address ipv4-address [ mask-length | mask ] | ipv6-address ipv6-address [ prefix-length ] ] [ port port-list ]
undo match match-id
No match criterion exists.
WAAS class view
match-id: Specifies the ID of the match criterion, in the range of 1 to 65535. If you specify an unused ID, you can create a new match criterion. If you specify a used ID, you can modify the existing match criterion. If you do not specify an ID, the system automatically assigns the lowest available ID.
tcp: Matches TCP packets.
any: Matches any TCP packets.
destination: Specifies destination elements for matching TCP packets.
source: Specifies source elements for matching TCP packets.
ip-address ipv4-address: Specifies an IPv4 address for matching TCP packets.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
ipv6-address ipv6-address: Specifies an IPv6 address for matching TCP packets.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
port port-list: Specifies a space-separated list of up to 10 port items for matching TCP packets. Each item specifies a port number or a range of port numbers in the form of port-number1 to port-number2. The value for port-number2 must be greater than or equal to the value for port-number1. The value range for the port-number argument is 1 to 65535. If you do not specify a port list, all port numbers are matched.
If you specify the destination or source keyword, you must specify the ip-address (or ipv6-address) option, the port option, or both.
If you specify the any keyword, the ip-address (or ipv6-address) option, and the port option, the ip-address (or ipv6-address) and port options match either source or destination fields of packets.
You cannot configure the same match criteria with different match IDs.
A WAAS class can have a maximum of 65535 match criteria. A packet is checked against match criteria in their order of appearance. The packet belongs to the WAAS class if it matches any one of the match criteria.
A WAAS class without any match criteria is not used to match packets.
# Create a WAAS class named http_class, and configure the class to match packets with source IP address 192.168.0.1/16 and port number 80 or port number in the range of 8000 to 8080.
[Sysname] waas class http_class
[Sysname-waasclass-http_class] match tcp source ip-address 192.168.0.1 16 port 80 8000 to 8080
# Create a WAAS class named http_class, and configure the class to match any TCP packets.
[Sysname-waasclass-http_class] match tcp any
display waas policy
waas class
optimize
Use optimize to configure optimization actions for a WAAS class.
Use undo optimize to restore the default.
optimize tfo [ dre | lz ] *
undo optimize
No optimization actions are configured for a WAAS class.
tfo: Specifies TFO.
dre: Specifies DRE.
lz: Specifies LZ compression.
An optimization action takes effect only when the corresponding feature is enabled.
An optimization action does not optimize the traffic that matches a blacklist entry.
If you configure both this command and the passthrough command, the most recent configuration takes effect.
# Configure optimization actions TFO, DRE, and LZ for the WAAS class AFS.
[Sysname-waaspolicy-waas_global-AFS] optimize tfo dre lz
class
display waas policy
passthrough
waas policy
waas tfo optimize dre
waas tfo optimize lz
passthrough
Use passthrough to configure the pass-through action for a WAAS class.
Use undo passthrough to restore the default.
passthrough
undo passthrough
The pass-through action is not configured.
The pass-through action allows packets to pass through unoptimized.
If you configure both this command and the optimize command, the most recent configuration takes effect.
# Configure the pass-through action for the WAAS class AFS.
class
display waas policy
optimize
waas policy
reset waas cache dre
Use reset waas cache dre to clear DRE data dictionaries.
reset waas cache dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE data dictionaries for all peer devices.
# Clear the DRE data dictionary for the peer device with the bridge MAC address 0789-445d-effa.
<Sysname> reset waas cache dre peer 0789-445d-effa
Use reset waas statistics dre to clear DRE statistics.
reset waas statistics dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE statistics for all peer devices.
# Clear DRE statistics for all peer devices.
<Sysname> reset waas statistics dre
Use reset waas statistics udp compress to clear UDP log message compression statistics.
# Clear UDP log message compression statistics.
<Sysname> reset waas statistics udp compress
Use reset waas tfo auto-discovery blacklist to clear all autodiscovered blacklist entries.
# Clear all autodiscovered blacklist entries.
<Sysname> reset waas tfo auto-discovery blacklist
waas apply policy
Use waas apply policy to apply a WAAS policy to an interface.
Use undo waas apply policy to restore the default.
waas apply policy [ policy-name ]
No WAAS policy is applied to an interface.
Interface view
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. The specified policy must already exist. If you do not specify a WAAS policy, this command applies the system-defined WAAS policy waas_default.
Apply a WAAS policy to an interface that connects to the WAN (not an interface that connects to the LAN). The device optimizes or passes through the traffic entering and leaving the WAN according to the configured policy. If the incoming and outgoing interfaces of the traffic are both connected to the WAN, the traffic is not optimized.
A global logical interface (such as a Layer 3 aggregate interface or VLAN interface) that spans multiple cards or IRF member devices can be used to connect to the WAN. To ensure the traffic optimization effect for such an interface, use the service command to specify one of these cards or IRF member devices to forward traffic for the interface.
# Apply the WAAS policy global_policy to the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] waas apply policy global_policy
display waas policy
display waas status
waas policy
waas asymmetric
Use waas asymmetric to configure WAAS to operate in asymmetric mode.
Use undo waas asymmetric to restore the default.
waas asymmetric
WAAS operates in symmetric mode.
Configure this command if the device sends and receives packets on different interfaces.
If the device sends and receives packets on the same interface, the device should operate in symmetric mode.
# Configure WAAS to operate in asymmetric mode.
[Sysname] waas asymmetric
waas class
Use waas class to create a WAAS class and enter its view, or enter the view of an existing WAAS class.
Use undo waas class to delete a WAAS class.
waas class class-name
undo waas class class-name
Only system-defined WAAS classes exist.
class-name: Specifies a name for the WAAS class, a case-insensitive string of 1 to 63 characters.
As a best practice, configure a WAAS class by modifying a system-defined WAAS class (see Table 7).
# Create a WAAS class named waas_global and enter WAAS class view.
[Sysname] waas class waas_global
[Sysname-waasclass-waas_global]
class
display waas class
waas config remove-all
Use waas config remove-all to delete all WAAS settings.
This command deletes all configuration data and running data for WAAS and exits the WAAS process.
# Delete all WAAS settings.
[Sysname] waas config remove-all
The command will clear all the WAAS configuration. Continue? [Y/N]:y
waas config restore-default
Use waas config restore-default to restore system-defined WAAS settings.
This command restores the system-defined WAAS policy and WAAS classes to their settings at the time when the WAAS process starts for the first time.
To successfully restore system-defined WAAS settings, make sure none of the interfaces has a WAAS policy applied.
# Restore system-defined WAAS settings.
[Sysname] waas config restore-default
The command will restore all the WAAS configuration to default. Continue? [Y/N]:y
waas dre cache aging
Use waas dre cache aging to set the aging time for entries in the data dictionary.
Use undo waas dre cache aging to restore the default.
waas dre cache aging minutes
Entries in the data dictionary are not aged out, and the newly created entry overwrites the oldest entry if the number of data dictionary entries reaches the limit.
minutes: Specifies the aging time for entries in the data dictionary, in the range of 10 to 60 minutes.
The device polls all data dictionary entries and deletes the entries that are not hit within the aging time. If the number of data dictionary entries reaches the limit, the device no longer creates new entries.
The amount of time used by the device to poll all data dictionary entries depends on the number of data dictionary entries on the device.
You must set the same aging time on the local and peer devices.
# Set the aging time to 10 minutes for entries in the data dictionary.
[Sysname] waas dre cache aging 10
waas dre offset-step
Use waas dre offset-step to set the DRE match offset step.
Use undo waas dre offset-step to restore the default.
waas dre offset-step { general | fast | fastest | normal }
The DRE match offset step is normal.
general: Specifies the DRE match offset step as general.
fast: Specifies the DRE match offset step as fast.
fastest: Specifies the DRE match offset step as fastest.
normal: Specifies the DRE match offset step as normal.
The following DRE match offset step levels are listed from high to low:
·     fastest.
·     fast.
·     general.
·     normal.
The higher the step level, the lower the match precision. As a best practice, use a higher-level offset step on high-speed links to improve match efficiency. Use a lower-level offset step on low-speed links to ensure match precision.
# Set the DRE match offset step to fast.
[Sysname] waas dre offset-step fast
waas policy
Use waas policy to create a WAAS policy and enter its view, or enter the view of an existing WAAS policy.
Use undo waas policy to delete a WAAS policy.
waas policy policy-name
undo waas policy policy-name
Only the system-defined WAAS policy waas_default exists.
policy-name: Specifies a name for the WAAS policy, a case-insensitive string of 1 to 63 characters.
To delete a WAAS policy applied to an interface, first remove the WAAS policy from the interface.
As a best practice, configure a WAAS policy by entering the system-defined WAAS policy view and modifying the system-defined WAAS policy. The system-defined WAAS policy is created by the system when the WAAS process starts for the first time. The system-defined WAAS policy uses all system-defined WAAS classes. Only system-defined WAAS classes FTP-Data and FTPS-Data use source ports as match options. All other system-defined WAAS classes use destination ports as match options.
Table 7 System-defined WAAS policy
System-defined WAAS class
WAAS actions
Source ports
Destination ports
AFS
LZ+TFO+DRE
N/A
7000–7009
Altiris-CarbonCopy
Passthrough
N/A
1680
Amanda
TFO
N/A
10080
AOL
Passthrough
N/A
5190–5193
Apple-AFP
LZ+TFO+DRE
N/A
548
Apple-iChat
Passthrough
N/A
5297, 5298
Apple-NetAssistant
Passthrough
N/A
3283
AppSocket
LZ+TFO+DRE
N/A
9100
BackupExpress
TFO
N/A
6123
Basic-TCP-services
Passthrough
N/A
1–19
BFTP
LZ+TFO+DRE
N/A
152
BGP
LZ+TFO+DRE
N/A
179
BitTorrent
Passthrough
N/A
6881–6889, 6969
BMC-Patrol
Passthrough
N/A
6161, 6162, 6767, 6768, 8160, 8161, 10128
Borland-Interbase
LZ+TFO+DRE
N/A
3050
CIFS
LZ+TFO+DRE
N/A
139, 445
CIFS-non-wafs
LZ+TFO+DRE
N/A
139, 445
Cisco-CallManager
Passthrough
N/A
2443, 2748
Cisco-NetFlow
Passthrough
N/A
7544, 7545
Citrix-ICA
LZ+TFO+DRE
N/A
1494, 2598
Clearcase
LZ+TFO+DRE
N/A
371
CommVault
TFO
N/A
8400–8403
Connected-DataProtector
TFO
N/A
16384
ControlIT
TFO
N/A
799
CU-SeeMe
Passthrough
N/A
7640, 7642, 7648, 7649
CVS
LZ+TFO+DRE
N/A
2401
Danware-NetOp
TFO
N/A
6502
DNS
Passthrough
N/A
53
Documentum
LZ+TFO+DRE
N/A
1489
Double-Take
LZ+TFO+DRE
N/A
1100, 1105
eDonkey
Passthrough
N/A
4661, 4662
EMC-Celerra-Replicator
LZ+TFO+DRE
N/A
8888
EMC-SRDFA-IP
LZ+TFO+DRE
N/A
1748
ezMeeting
Passthrough
N/A
10101–10103, 26260–26261
FCIP
LZ+TFO+DRE
N/A
3225
Filenet
LZ+TFO+DRE
N/A
32768–32774
FTP
Passthrough
N/A
21
FTP-Data
LZ+TFO+DRE
20
N/A
FTPS
TFO
N/A
990
FTPS-Data
Passthrough
989
N/A
GnomeMeeting
Passthrough
N/A
30000–30010
Gnutella
Passthrough
N/A
6346–6349, 6355, 5634
Grouper
Passthrough
N/A
8038
HotLine
Passthrough
N/A
5500–5503
HP-OpenMail
LZ+TFO+DRE
N/A
5729, 5755, 5757, 5766, 5767, 5768
HP-OpenView
Passthrough
N/A
7426–7431, 7501, 7510
HP-Radia
LZ+TFO+DRE
N/A
3460, 3461, 3464, 3466
HTTP
LZ+TFO+DRE
N/A
80, 3128, 8000, 8001, 8080
HTTPS
TFO
N/A
443
HTTPS
TFO
N/A
443
IBM-DB2
LZ+TFO+DRE
N/A
523
IBM-NetView
Passthrough
N/A
729–731
IBM-Tivoli
LZ+TFO+DRE
N/A
94, 627, 1580, 1581, 1965
IBM-TSM
TFO+LZ+DRE
N/A
1500–1502
iFCP
LZ+TFO+DRE
N/A
3420
Intel-Proshare
Passthrough
N/A
5713–5717
Internet-Mail
LZ+TFO+DRE
N/A
25, 110, 143, 220
Internet-Mail-secure
TFO
N/A
465, 993, 995
InterSystems-Cache
LZ+TFO+DRE
N/A
1972
IPP
LZ+TFO+DRE
N/A
631
IRC
Passthrough
N/A
531, 6660–6669
iSCSI
LZ+TFO+DRE
N/A
3260
iSNS
Passthrough
N/A
3205
Jabber
Passthrough
N/A
5222, 5269
Kazaa
Passthrough
N/A
1214
Kerberos
Passthrough
N/A
88, 464, 543, 544, 749, 754, 888, 2053
L2TP
TFO
N/A
1701
LANDesk
LZ+TFO+DRE
N/A
9535, 9593–9595
Laplink-Host
TFO
N/A
1547
Laplink-PCSync
TFO
N/A
8444
Laplink-PCSync-secure
TFO
N/A
8443
Laplink-ShareDirect
Passthrough
N/A
2705
LDAP
LZ+TFO+DRE
N/A
389, 8404
LDAP-Global-Catalog
LZ+TFO+DRE
N/A
3268
LDAP-Global-Catalog-Secure
Passthrough
N/A
3269
LDAP-secure
Passthrough
N/A
636
Legato-NetWorker
TFO
N/A
7937, 7938, 7939
Legato-RepliStor
TFO
N/A
7144, 7145
Liquid-Audio
LZ+TFO+DRE
N/A
18888
Lotus-Notes
LZ+TFO+DRE
N/A
1352
Lotus-Sametime-Connect
Passthrough
N/A
1533
MDaemon
LZ+TFO+DRE
N/A
3000, 3001
MS-Chat
Passthrough
N/A
6665, 6667
MS-Content-Replication-Service
TFO
N/A
560, 507
MS-Message-Queuing
LZ+TFO+DRE
N/A
1801, 2101, 2103, 2105
MS-NetMeeting
Passthrough
N/A
522, 1503, 1731
MS-NetShow
LZ+TFO+DRE
N/A
1755
MSN-Messenger
Passthrough
N/A
1863, 6891–6900
MS-SQL
LZ+TFO+DRE
N/A
1433
MS-Terminal-Services
TFO
N/A
3389
MySQL
LZ+TFO+DRE
N/A
3306
Napster
Passthrough
N/A
6666, 6677, 6700, 6688, 7777, 8875
Netapp-SnapMirror
LZ+TFO+DRE
N/A
10565–10569
NetIQ
Passthrough
N/A
2220, 2735, 10113–10116
Netopia-netOctopus
Passthrough
N/A
1917, 1921
Netopia-Timbuktu
TFO
N/A
407, 1417–1420
NFS
LZ+TFO+DRE
N/A
2049
NNTP
LZ+TFO+DRE
N/A
119
NNTP-secure
TFO
N/A
563
Novell-Groupwise
LZ+TFO+DRE
N/A
1099, 1677, 2800, 3800, 7100, 7101, 7180, 7181, 7205, 9850
Novell-NetWare
LZ+TFO+DRE
N/A
524
Novell-ZenWorks
LZ+TFO+DRE
N/A
517, 1761–1763, 2037, 2544, 8039
NTP
Passthrough
N/A
123
OpenVPN
TFO
N/A
1194
Oracle
LZ+TFO+DRE
N/A
66, 1521, 1525
Other-Secure
Passthrough
N/A
261, 44, 684, 695, 994, 2252, 2478, 2479, 2482, 2484, 2679, 2762, 2998, 3077, 3078, 3183, 3191, 3220, 3410, 3424, 3471, 3496,3509, 3529, 3539, 3660, 3661, 3747, 3864, 3885, 3896, 3897, 3995, 4031, 5007, 5989, 5990, 7674, 9802, 12109
PCAnywhere
TFO
N/A
73, 5631, 5632, 65301
PCMail-Server
LZ+TFO+DRE
N/A
158
PDMWorks
LZ+TFO+DRE
N/A
30000, 40000
Pervasive-SQL
LZ+TFO+DRE
N/A
1583
PostgreSQL
LZ+TFO+DRE
N/A
5432
PPTP
TFO
N/A
1723
ProjectWise-FileTransfer
LZ+TFO+DRE
N/A
5800
QMTP
LZ+TFO+DRE
N/A
209
Qnext
Passthrough
N/A
44, 5555
RAdmin
TFO
N/A
4899
Remote-Anything
TFO
N/A
3999, 4000
Remote-Replication-Agent
TFO
N/A
5678
Rsync
TFO
N/A
873
RTSP
LZ+TFO+DRE
N/A
554, 8554
SAP
LZ+TFO+DRE
N/A
3200–3219, 3221–3224, 3226–3267, 3270–3282, 3284–3305, 3307–3388, 3390–3399, 3600–3659, 3662–3699
SASL
Passthrough
N/A
3659
Scalable-SQL
LZ+TFO+DRE
N/A
3352
Service-Location
Passthrough
N/A
427
Siebel
LZ+TFO+DRE
N/A
2320, 2321, 8448
Simple-FTP
LZ+TFO+DRE
N/A
115
SIP-secure
Passthrough
N/A
5061
SOAP
LZ+TFO+DRE
N/A
7627
SoulSeek
Passthrough
N/A
2234, 5534
SQL-Service
LZ+TFO+DRE
N/A
156
SSH
TFO
N/A
22
SSL-Shell
Passthrough
N/A
614
Sun-RPC
Passthrough
N/A
111
SUN-Xprint
LZ+TFO+DRE
N/A
8100
Sybase-SQL
LZ+TFO+DRE
N/A
1498, 2439, 2638, 3968
Symantec-AntiVirus
LZ+TFO+DRE
N/A
2847, 2848, 2967, 2968, 38037, 38292
TACACS
Passthrough
N/A
49
Telnet
Passthrough
N/A
23, 107, 513
Telnets
Passthrough
N/A
992
TFTPS
TFO
N/A
3713
UniSQL
LZ+TFO+DRE
N/A
1978, 1979
Unix-Printing
LZ+TFO+DRE
N/A
170, 515
Unix-Remote-Execution
Passthrough
N/A
512, 514
VDOLive
LZ+TFO+DRE
N/A
7000
Veritas-BackupExec
TFO
N/A
1125, 3527, 6101, 6102, 6106
Veritas-NetBackup
TFO
N/A
13720, 13721, 13782, 13785
Vmware-VMConsole
TFO
N/A
902
VNC
TFO
N/A
5801–5809, 6900–6909
VocalTec
Passthrough
N/A
1490, 6670, 22555, 25793
VoIP-Control
Passthrough
N/A
1300, 1718–1720, 2000-2002, 2428, 5060, 11000–11999
WAAS-FlowMonitor
TFO
N/A
7878
WASTE
Passthrough
N/A
1337
WBEM
Passthrough
N/A
5987, 5988
WinMX
Passthrough
N/A
6699
WINS
Passthrough
N/A
42, 137, 1512
X400
LZ+TFO+DRE
N/A
102
XWindows
TFO
N/A
6000–6063
Yahoo-Messenger
Passthrough
N/A
5000, 5001, 5050, 5100
# Enter system-defined WAAS policy view.
[Sysname] waas policy waas_default
[Sysname-waaspolicy-waas_default]
display waas policy
Use waas tfo auto-discovery blacklist enable to enable the TFO blacklist autodiscovery feature.
Use undo waas tfo auto-discovery blacklist enable to disable the TFO blacklist autodiscovery feature.
The TFO blacklist autodiscovery feature is disabled.
This feature automatically discovers servers that cannot receive TCP packets with options and adds the server IP addresses and port numbers to a blacklist.
During the 3-way handshake, the local device considers the TCP connection attempt failed if either of the following situations occurs:
·     The peer device does not respond within the specified time period.
·     The peer device closes the TCP connection.
# Enable the TFO blacklist autodiscovery feature.
[Sysname] waas tfo auto-discovery blacklist enable
Use waas tfo auto-discovery blacklist hold-time to set the aging time for autodiscovered blacklist entries.
Use undo waas tfo auto-discovery blacklist hold-time to restore the default.
waas tfo auto-discovery blacklist hold-time minutes
The aging time for autodiscovery blacklist entries is 5 minutes.
minutes: Specifies the aging time for autodiscovered blacklist entries, in the range of 1 to 10080 minutes.
An aging timer is started when a blacklist entry is created. The system automatically deletes an autodiscovered blacklist entry to make room for a new blacklist entry when the aging timer expires.
# Set the aging time to 30 minutes for autodiscovered blacklist entries.
[Sysname] waas tfo auto-discovery blacklist hold-time 30
waas tfo base-congestion-window
Use waas tfo base-congestion-window to set the initial congestion window size for slow start.
Use undo waas tfo base-congestion-window to restore the default.
waas tfo base-congestion-window segments
The initial congestion window size is two TCP segments.
segments: Specifies the initial congestion window size in the range of 1 to 10 TCP segments.
The congestion window size changes with the congestion status and transmission speed. An appropriate initial congestion window size can quickly restore the network to its full transmission capacity after congestion occurs.
# Set the initial congestion window size to three segments.
[Sysname] waas tfo base-congestion-window 3
waas tfo congestion-method
Use waas tfo congestion-method to specify a TCP congestion control algorithm for the WAN side.
Use undo waas tfo congestion-method to restore the default.
waas tfo congestion-method { bic | reno }
WAAS uses BIC as the TCP congestion control algorithm on the WAN side.
bic: Specifies BIC as the TCP congestion control algorithm.
reno: Specifies Reno as the TCP congestion control algorithm.
# Specify Reno as the TCP congestion control algorithm for the WAN side.
[Sysname] waas tfo congestion-method reno
waas tfo connect-limit
Use waas tfo connect-limit to set the maximum number of concurrent connections.
Use undo waas tfo connect-limit to restore the default.
waas tfo connect-limit limit
The maximum number of concurrent connections is 10000.
limit: Specifies the maximum number of concurrent connections, in the range of 1000 to 4294967295.
After the maximum number of concurrent connections is reached, WAAS does not optimize traffic for newly established connections. Configure the maximum number of concurrent connections according to your available memory resources, because optimizing TCP flows consumes memory resources.
You must set the same maximum number of concurrent connections on the local and peer devices.
# Set the maximum number of concurrent connections to 20000.
[Sysname] waas tfo connect-limit 20000
waas tfo keepalive
Use waas tfo keepalive to enable TFO keepalives.
Use undo waas tfo keepalive to disable TFO keepalives.
waas tfo keepalive
TFO keepalives are enabled.
After you enable TFO keepalives, the system starts the 2-hour TCP keepalive timer. If the local device does not send or receive any data when the timer expires, it sends a keepalive to the peer to maintain the connection.
# Disable TFO keepalives.
[Sysname] undo waas tfo keepalive
Use waas tfo optimize dre to enable DRE.
Use undo waas tfo optimize dre to disable DRE.
DRE is enabled.
The DRE optimization action configured in a WAAS policy takes effect only when DRE is enabled.
# Disable DRE.
[Sysname] undo waas tfo optimize dre
display waas status
Use waas tfo optimize lz to enable LZ compression.
Use undo waas tfo optimize lz to disable LZ compression.
LZ compression is enabled.
The LZ optimization action configured in a WAAS policy takes effect only when LZ compression is enabled.
# Disable LZ compression.
[Sysname] undo waas tfo optimize lz
display waas status
waas tfo receive-buffer
Use waas tfo receive-buffer to set the TFO receiving buffer size.
Use undo waas tfo receive-buffer to restore the default.
waas tfo receive-buffer buffer-size
The TFO receiving buffer size is 64 KB.
buffer-size: Specifies the TFO receiving buffer size in the range of 32 to 16384 KB.
The TFO receiving buffer size affects network throughput.
# Set the TFO receiving buffer size to 1024 KB.
[Sysname] waas tfo receive-buffer 1024
waas udp
Use waas udp to enable UDP log message compression or decompression.
Use undo waas udp to disable UDP log message compression or decompression.
waas udp { compress [ max max-number ] | decompress }
undo waas udp
UDP log message compression and decompression is disabled.
compress: Enables UDP log message compression.
max max-number: Specifies the maximum number of UDP log messages to be compressed.
decompress: Enables UDP log message decompression.
This command takes effect only on UDP log messages with the destination IP address and destination port number specified in the waas udp ip command.
Enable UDP log message compression on the upstream device and enable UDP log message decompression on the downstream device. The upstream device compresses packets and forwards them to the downstream device. The downstream device decompresses the received packets and then forwards them.
You can enable UDP log message compression or decompression for the same destination IP address, but not both.
# Enables UDP log message compression and set the maximum number of UDP log messages to be compressed to 10.
[Sysname] waas udp compress max 10
waas udp ip
waas udp ip
Use waas udp ip to specify the destination IP address and destination port number of UDP log messages to be compressed or decompressed.
Use undo waas udp ip to remove the specified destination IP address and destination port number.
waas udp ip ip-address port port-number
undo waas udp ip ip-address port port-number
No destination IP address and destination port number are specified.
ip-address: Specifies the destination IP address of UDP log messages to be compressed or decompressed.
port port-number: Specifies the destination port number of UDP log messages, in the range of 1 to 65535.
UDP log message compression and decompression takes effect only on UDP log messages with the destination IP address and destination port number specified in the waas udp ip command.
You can configure this command multiple times to specify multiple IP address-port number pairs.
# Specify that UDP log messages with destination IP address 172.16.105.48 and destination port number 5000 are compressed.
[Sysname] waas udp ip 172.16.105.48 port 5000
waas udp
