- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-QinQ commands
- 06-Loop detection commands
- 07-Spanning tree commands
- 08-LLDP commands
- 09-Layer 2 forwarding commands
- 10-VLAN termination commands
| 09-Layer 2 forwarding commands | 71.09 KB |
Normal Layer 2 forwarding commands
display mac-forwarding statistics
reset mac-forwarding statistics
Fast Layer 2 forwarding commands
display mac-forwarding cache ip
display mac-forwarding cache ip fragment
display mac-forwarding cache ipv6
This feature is supported only on Layer 2 Ethernet ports on Ethernet switching modules.
On Layer 2 Ethernet switching modules of MSR devices that are operating in IRF mode, Layer 2 forwarding across member devices is not supported. On SIC Layer 2 Ethernet switching modules, Layer 2 forwarding across member devices and slots is not supported.
Layer 2 forwarding across slots that reside on the same device is supported if multiple HMIM-24GSW, HMIM-24GSWP, HMIM-8GSW, or HMIM-8GSWF Layer 2 Ethernet switching modules are installed on the following devices:
· MSR5660.
· MSR5680.
Layer 2 forwarding across slots that reside on the same device is not supported on MSR5620 devices that are installed with multiple HMIM-8GSW or HMIM-8GSWF Layer 2 Ethernet switching modules.
On MSR56 devices:
· Layer 2 forwarding across slots is supported if multiple HMIM Layer 2 Ethernet switching modules are installed on the same SPE-S1 module.
· Layer 2 forwarding across slots is not supported if multiple HMIM Layer 2 Ethernet switching modules are installed on the same SPE-S3 module.
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays Layer 2 forwarding statistics on all interfaces.
# Display Layer 2 forwarding statistics on all interfaces.
<Sysname> display mac-forwarding statistics
Input:
Sum: 888 Unknown Unicast: 0
Broadcast: 0 Multicast: 0
Filtered: 0 STP discarded: 0
Service dropped: 0 Source dropped: 0
Unknown dropped: 0 Learning dropped: 0
Blackhole dropped: 0 Suppress dropped: 0
Source MAC dropped:0
Deliver:
Sum: 111 L2 protocol: 11
Local MAC address: 100
Output:
Sum: 666 Filtered: 0
Blackhole dropped: 0 STP discarded: 0
Service dropped: 0 Dest MAC dropped: 0
# Display Layer 2 forwarding statistics on GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Input frames: 100 Output frames:100
Filtered: 0
Input |
Inbound Ethernet frame statistics. · Sum—Total number of received Ethernet frames. · Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN inbound filtering rules. · STP discarded—Number of inbound Ethernet frames dropped on the ports blocked by STP. · Service dropped—Number of Ethernet frames dropped by inbound service features. · Source dropped—Number of Ethernet frames dropped because their source MAC addresses are all-zeros, multicast, or broadcast MAC addresses. · Unknown dropped—Number of Ethernet frames dropped because the device is disabled from forwarding frames with unknown source MAC addresses. · Learning dropped—Number of Ethernet frames dropped because the device is disabled from forwarding unknown frames after the number of learned MAC addresses reaches the upper limit. · Suppress dropped—Number of Ethernet frames dropped by storm suppression. · Broadcast—Number of received broadcast Ethernet frames. · Multicast—Number of received multicast Ethernet frames. · Unknown unicast—Number of received unknown unicast Ethernet frames. · Blackhole dropped—Number of Ethernet frames dropped because they are sourced from blackhole MAC addresses. · Source MAC dropped—Number of Ethernet frames dropped by features based on the source MAC addresses. |
Deliver |
Statistics of Ethernet frames delivered to the CPU. · Sum—Total number of Ethernet frames delivered to the CPU. · L2 protocol—Number of Layer 2 protocol Ethernet frames delivered to the CPU. · Local MAC address—Number of Ethernet frames that use the MAC addresses of local Layer 3 VLAN interfaces as the destination MAC addresses. |
Output |
Outbound Ethernet frame statistics. · Sum—Total number of sent Ethernet frames. · Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN outbound filtering rules. · Blackhole dropped—Number of Ethernet frames dropped because they are destined for blackhole MAC addresses. · STP discarded—Number of outbound Ethernet frames dropped on the ports blocked by STP. · Service dropped—Number of Ethernet frames dropped by outbound service features. · Dest MAC dropped—Number of Ethernet frames dropped by features based on the destination MAC addresses. |
GigabitEthernet1/0/1 |
Layer 2 forwarding statistics on GigabitEthernet 1/0/1: · Input frames—Number of Ethernet frames received on the interface. · Output frames—Number of Ethernet frames sent out of the interface. · Filtered—Number of Ethernet frames filtered out because they are from other VLANs. |
Use reset mac-forwarding statistics to clear Layer 2 forwarding statistics.
# Clear Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
Use display mac-forwarding cache ip to display IPv4 fast forwarding entries.
In standalone mode:
display mac-forwarding cache ip [ ip-address ] [ slot slot-number ]
In IRF mode:
display mac-forwarding cache ip [ ip-address ] [ chassis chassis-number slot slot-number ]
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast forwarding entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4 fast forwarding entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4 fast forwarding entries for all cards. (In IRF mode.)
# Display all IPv4 fast forwarding entries.
<Sysname> display mac-forwarding cache ip
Total number of mac-forwarding entries: 2
SIP SPort DIP DPort Pro Input_If Output_If VLAN
1.1.1.2 99 1.1.1.1 2048 1 GE1/0/1 GE1/0/2 2
1.1.1.1 98 1.1.1.2 2012 1 GE1/0/2 GE1/0/1 2
Total number of mac-forwarding entries |
Total number of IPv4 fast forwarding entries. |
SIP |
Source IPv4 address. |
SPort |
Source port number. |
DIP |
Destination IPv4 address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no input interface is involved in fast forwarding, this field displays N/A. If no input interface is available, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no output interface is involved in fast forwarding, this field displays N/A. If no output interface is available, this field displays a hyphen (-). |
VLAN |
VLAN ID. |
Use display mac-forwarding cache ip fragment to display IPv4 fast forwarding entries for fragments.
In standalone mode:
display mac-forwarding cache ip fragment [ ip-address ] [ slot slot-number ]
In IRF mode:
display mac-forwarding cache ip fragment [ ip-address ] [ chassis chassis-number slot slot-number ]
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast forwarding entries for all fragments.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4 fast forwarding entries for fragments on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4 fast forwarding entries for fragments on all cards. (In IRF mode.)
# Display IPv4 fast forwarding entries for all fragments.
<Sysname> display mac-forwarding cache ip fragment
Total number of fragment mac-forwarding entries: 2
SIP SPort DIP DPort Pro Input_If ID VLAN
1.1.1.1 117 1.1.1.2 0 1 GE1/0/1 2828 1
1.1.1.2 110 1.1.1.1 67 17 GE1/0/2 2322 1
Total number of fragment mac-forwarding entries |
Total number of IPv4 fast forwarding entries for fragments. |
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
VLAN |
VLAN ID. |
Use display mac-forwarding cache ipv6 to display IPv6 fast forwarding entries.
In standalone mode:
display mac-forwarding cache ipv6 [ ipv6-address ] [ slot slot-number ]
In IRF mode:
display mac-forwarding cache ipv6 [ ipv6-address ] [ chassis chassis-number slot slot-number ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 fast forwarding entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 fast forwarding entries for all cards. (In IRF mode.)
# Display all IPv6 fast forwarding entries.
<Sysname> display mac-forwarding cache ipv6
Total number of IPv6 mac-forwarding items: 1
Src IP: 2002::1 Src port: 129
Dst IP: 2001::1 Dst port: 65535
VLAN ID: 2
Protocol: 2
Input interface: GE1/0/2
Output interface: GE1/0/1
Total number of IPv6 mac-forwarding items |
Total number of IPv6 fast forwarding entries. |
Src IP |
Source IPv6 address. |
Src port |
Dst IP |
Destination IPv6 address. |
Dst Port |
Protocol |
Protocol number. |
Input interface |
Output interface |
