- 07-MPLS Configuration Examples
- 01-H3C_MCE_Configuration_Examples
- 02-H3C_MPLS_L2VPN_Configuration_Examples
- 03-H3C_MPLS_L3VPN_Configuration_Examples
- 04-H3C_MPLS_TE_Configuration_Examples
- 05-H3C_MPLS_TE_Forwarding_Adjacency_Configuration_Examples
- 06-H3C_Basic_MPLS_Configuration_Examples
- 07-H3C_VPLS_Configuration_Examples
- 08-H3C_GRE_Tunnel_Access_to_MPLS_L3VPN_Configuration_Examples
| 05-H3C_MPLS_TE_Forwarding_Adjacency_Configuration_Examples | 78.43 KB |
H3C MPLS TE Forwarding Adjacency Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides MPLS TE forwarding adjacency configuration examples.
This document assumes that you have basic knowledge of MPLS TE forwarding adjacency.
Example: Configuring MPLS TE forwarding adjacency
As shown in Figure 1, Device A, Device B, Device C, and Device D run OSPF.
Establish an MPLS TE tunnel from Device B to Device D that uses the path Device B—Device C—Device D, and configure MPLS TE forwarding adjacency for the tunnel.
Before the tunnel is established, traffic from Device A to Device D is forwarded through the direct link Device A—Device D. After the tunnel is established, the traffic is forwarded through the MPLS TE tunnel.
Analysis
· To make forwarding adjacency take effect, you must establish two MPLS TE tunnels in opposite directions between Device B and Device D, and enable forwarding adjacency on both devices.
· For the MPLS TE tunnel to use the path Device B—Device C—Device D, configure the path as the explicit path for the tunnel.
· For traffic from Device A to Device D to be forwarded through the MPLS TE tunnel, make sure the tunnel's metric is less than 15 (metric 25 minus 10). This example uses 12.
Procedures
1. Configure IP addresses for interfaces, configure basic OSPF, and set OSPF costs. (Details not shown.) For the configuration, see "Configuration files."
2. Enable MPLS TE on each node and interface that the MPLS TE tunnel traverses:
# On Device B, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
[DeviceB] mpls lsr-id 2.2.2.2
[DeviceB] mpls te
[DeviceB-te] quit
[DeviceB] rsvp
[DeviceB-rsvp] quit
[DeviceB] interface vlan-interface 23
[DeviceB-Vlan-interface23] mpls enable
[DeviceB-Vlan-interface23] mpls te enable
[DeviceB-Vlan-interface23] rsvp enable
[DeviceB-Vlan-interface23] quit
# On Device C, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
[DeviceC] mpls lsr-id 3.3.3.3
[DeviceC] mpls te
[DeviceC-te] quit
[DeviceC] rsvp
[DeviceC-rsvp] quit
[DeviceC] interface vlan-interface 23
[DeviceC-Vlan-interface23] mpls enable
[DeviceC-Vlan-interface23] mpls te enable
[DeviceC-Vlan-interface23] rsvp enable
[DeviceC-Vlan-interface23] ospf cost 10
[DeviceC-Vlan-interface23] quit
[DeviceC] interface vlan-interface 34
[DeviceC-Vlan-interface34] mpls enable
[DeviceC-Vlan-interface34] mpls te enable
[DeviceC-Vlan-interface34] rsvp enable
[DeviceC-Vlan-interface34] ospf cost 10
[DeviceC-Vlan-interface34] quit
# On Device D, configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE.
[DeviceD] mpls lsr-id 4.4.4.4
[DeviceD] mpls te
[DeviceD-te] quit
[DeviceD] rsvp
[DeviceD-rsvp] quit
[DeviceD] interface vlan-interface 34
[DeviceD-Vlan-interface34] mpls enable
[DeviceD-Vlan-interface34] mpls te enable
[DeviceD-Vlan-interface34] rsvp enable
[DeviceD-Vlan-interface34] quit
3. Configure OSPF TE to advertise link TE attributes:
# On Device B, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceB] ospf
[DeviceB-ospf-1] opaque-capability enable
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] mpls te enable
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# On Device C, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceC] ospf
[DeviceC-ospf-1] opaque-capability enable
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] mpls te enable
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
# On Device D, enable opaque LSA advertisement and reception, and enable MPLS TE for OSPF area 0. By default, opaque LSA advertisement and reception are enabled.
[DeviceD] ospf
[DeviceD-ospf-1] opaque-capability enable
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] mpls te enable
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
4. Configure MPLS TE tunnels:
# On Device B, configure MPLS TE tunnel interface Tunnel 1, and specify the tunnel destination address as the LSR ID of Device D.
[DeviceB] interface tunnel 1 mode mpls-te
[DeviceB-Tunnel1] ip address 9.2.2.2 255.255.255.0
[DeviceB-Tunnel1] destination 4.4.4.4
# Configure MPLS TE to use RSVP-TE to establish the tunnel.
[DeviceB-Tunnel1] mpls te signaling rsvp-te
[DeviceB-Tunnel1] quit
# Configure an explicit path named tun1.
[DeviceB] explicit-path tun1
[DeviceB-explicit-path-tun1] nexthop 23.23.23.3
[DeviceB-explicit-path-tun1] nexthop 34.34.34.4
[DeviceB-explicit-path-tun1]quit
# Specify the explicit path to be used as tun1.
[DeviceB–Tunnel1] mpls te path preference 1 explicit-path tun1
# Enable forwarding adjacency for the tunnel.
[DeviceA-Tunnel1] mpls te igp advertise
# Enable OSPF on tunnel interface Tunnel 1 and set the OSPF cost to 12 on the interface.
[DeviceA-Tunnel1] ospf 1 area 0
[DeviceA-Tunnel1] ospf cost 12
[DeviceA-Tunnel1] quit
# On Device D, configure MPLS TE tunnel interface Tunnel 1, and specify the tunnel destination address as the LSR ID of Device B.
[DeviceD] interface tunnel 1 mode mpls-te
[DeviceD-Tunnel1] ip address 9.2.2.4 255.255.255.0
[DeviceD-Tunnel1] destination 2.2.2.2
[DeviceD-Tunnel1] mpls te signaling rsvp-te
[DeviceD-Tunnel1] quit
[DeviceD] explicit-path tun1
[DeviceD-explicit-path-tun1] nexthop 34.34.34.3
[DeviceD-explicit-path-tun1] nexthop 23.23.23.2
[DeviceD-explicit-path-tun1]quit
[DeviceD–Tunnel1] mpls te path preference 1 explicit-path tun1
[DeviceD-Tunnel1] mpls te igp advertise
[DeviceD-Tunnel1] ospf 1 area 0
[DeviceD-Tunnel1] ospf cost 12
# Verify that the tunnel interfaces on Device B and Device D are up. This example uses Device B.
[DeviceB] display interface tunnel brief
Protocol: (s) - spoofing
Tun1 UP UP 9.2.2.2
# Display routing table information on Device A. The output shows that the next hop of the route to Device D is Device B, and the cost is 22. The MPLS TE tunnel has been used during IGP route calculation.
[Device A] display ip routing-table
Destinations : 24 Routes : 24
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.2/32 O_INTRA 10 10 12.12.12.2 Vlan12
3.3.3.3/32 O_INTRA 10 20 12.12.12.2 Vlan12
4.4.4.4/32 O_INTRA 10 22 12.12.12.2 Vlan12
9.2.2.0/24 O_INTRA 10 22 12.12.12.2 Vlan12
10.1.0.3/32 Direct 0 0 127.0.0.1 InLoop0
12.12.12.0/24 Direct 0 0 12.12.12.1 Vlan12
12.12.12.0/32 Direct 0 0 12.12.12.1 Vlan12
12.12.12.1/32 Direct 0 0 127.0.0.1 InLoop0
12.12.12.255/32 Direct 0 0 12.12.12.1 Vlan12
14.14.14.0/24 Direct 0 0 14.14.14.1 Vlan14
14.14.14.0/32 Direct 0 0 14.14.14.1 Vlan14
14.14.14.1/32 Direct 0 0 127.0.0.1 InLoop0
14.14.14.255/32 Direct 0 0 14.14.14.1 Vlan14
23.23.23.0/24 O_INTRA 10 20 12.12.12.2 Vlan12
34.34.34.0/24 O_INTRA 10 30 12.12.12.2 Vlan12
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
Configuration files
· Device A:
ospf 1
area 0.0.0.0
network 1.1.1.1 0.0.0.0
network 12.12.12.0 0.0.0.255
network 14.14.14.0 0.0.0.255
vlan 12
vlan 14
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface12
ip address 12.12.12.1 255.255.255.0
ospf cost 10
interface Vlan-interface14
ip address 14.14.14.1 255.255.255.0
ospf cost 25
· Device B:
ospf 1
area 0.0.0.0
network 2.2.2.2 0.0.0.0
network 23.23.23.0 0.0.0.255
mpls te enable
mpls lsr-id 2.2.2.2
mpls te
explicit-path tun1
nexthop index 1 23.23.23.3 include strict
nexthop index 101 34.34.34.4 include strict
rsvp
vlan 12
vlan 23
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
ip address 12.12.12.2 255.255.255.0
ospf cost 10
interface Vlan-interface23
ip address 23.23.23.2 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
interface Tunnel1 mode mpls-te
ospf cost 12
ospf 1 area 0.0.0.0
destination 4.4.4.4
· Device C:
ospf 1
area 0.0.0.0
network 3.3.3.3 0.0.0.0
network 34.34.34.0 0.0.0.255
mpls te enable
mpls lsr-id 3.3.3.3
mpls te
rsvp
vlan 23
vlan 34
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
ip address 23.23.23.3 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
interface Vlan-interface34
ip address 34.34.34.3 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
· Device D:
ospf 1
area 0.0.0.0
network 4.4.4.4 0.0.0.0
mpls te enable
mpls lsr-id 4.4.4.4
mpls te
explicit-path tun1
nexthop index 1 34.34.34.3 include strict
nexthop index 101 23.23.23.2 include strict
rsvp
vlan 14
vlan 34
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 14.14.14.4 255.255.255.0
ospf cost 25
ip address 34.34.34.4 255.255.255.0
ospf cost 10
mpls enable
mpls te enable
rsvp enable
ospf cost 12
ospf 1 area 0.0.0.0
destination 2.2.2.2
Related documentation
· H3C S10500X Switch Series MPLS Configuration Guide-R758X
· H3C S10500X Switch Series MPLS Command Reference-R758X
