07-MPLS Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-64H Switch Command References-Release 655x-6W10107-MPLS Command Reference
13-MPLS SR commands
13-MPLS SR commands 69.92 KB
MPLS SR commands
display mpls static-sr-mpls
Use display mpls static-sr-mpls to display static SRLSP and adjacency segment information.
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] }
lsp: Displays static SRLSP information.
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this argument, the command displays information about all static SRLSPs.
adjacency: Displays static adjacency segment information.
adjacency-path-name: Specifies a static adjacency segment by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this argument, the command displays information about all static adjacency segments.
# Display information about all static SRLSPs.
<Sysname> display mpls static-sr-mpls lsp lsp1
Type           : LSP
In-Label       : -
Out-Label      : 60,70,80
Out-Interface  : -
Nexthop        : -
State          : Up
Name
Name of the static SRLSP or adjacency segment.
Information type:
·     LSP—Static SRLSP information.
·     Adjacency—Adjacency segment information.
In-Label
Incoming label.
Out-Label
Outgoing label.
Out-Interface
Output interface.
Nexthop
Next hop address.
Status of the static SRLSP or adjacency segment:
·     Down—The static SRLSP or adjacency segment is not available.
·     Up—The static SRLSP or adjacency segment is available.
static-sr-mpls adjacency
static-sr-mpls lsp
display mpls static-sr-mpls prefix
Use display mpls static-sr-mpls prefix to display static prefix segment information.
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ]
path lsp-name: Displays static prefix segment information for the specified static SRLSP. The lsp-name argument specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters.
destination ip-address: Displays static prefix segment information for the specified destination address. The ip-address argument specifies a destination address.
mask: Specifies the destination address mask.
mask-length: Specifies the mask length, in the range of 0 to 32.
If you do not specify any parameters, this command displays information about all static prefix segments.
# Display information about all static prefix segments.
<Sysname> display mpls static-sr-mpls prefix
Prefix Name    : prefixname
Destination    : 2.2.2.2/32
In-Label       : 1024
Active         : Yes(1)
Out-Interface  : Vlan2
Nexthop        : 10.0.0.2
Out-Label      : 600000
Status         : up
Out-Interface  : Vlan3
Nexthop        : 11.0.0.2
Out-Label      : 600002
Status         : down(No Route)
Out-Interface  : Vlan4
Nexthop        : 12.0.0.2
Out-Label      : 600001
Status         : down(No Mpls)
Prefix Name
Name of the prefix segment.
Destination
Destination IP address of the prefix segment.
In-Label
Incoming label of the prefix segment.
Active
Status of the prefix segment:
·     Yes(count)—The prefix segment is active. The value of count represents the number of egresses in up status.
·     No—The prefix segment is inactive.
Out-Interface
Outgoing interface of the prefix segment.
Nexthop
Next hop of the prefix segment.
Out-Label
Outgoing label of the prefix segment.
Status
Status of the egress:
·     down—The egress is inactive. The cause is displayed in brackets, which can be No Route or No Mpls. No Route means that the device has no route to reach the destination IP address over the outgoing interface. No Mpls means that MPLS is disabled on the output interface.
·     up—The egress is active.
·     duplicate—An egress conflict has occurred because the output interface is already used by another prefix segment.
mpls te static-sr-mpls
Use mpls te static-sr-mpls to bind a static SRLSP to an MPLS TE tunnel interface.
Use undo mpls te static-sr-mpls to unbind a static SRLSP from an MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
undo mpls te static-sr-mpls lsp-name
An MPLS TE tunnel interface does not use any static SRLSPs.
Tunnel interface view
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters. The specified static SRLSP must be already created by using the static-sr-mpls lsp command.
backup: Specifies the backup static SRLSP. If you do not specify this keyword, this command specifies the main static SRLSP.
Execute this command only on the ingress node of a static SRLSP.
This command takes effect only if you have configured the mpls te signaling static command in tunnel interface view.
You can specify the backup keyword to bind a backup static SRLSP only if both the main and backup SRLSPs are established by using the adjacency segment method.
If you execute both the mpls te static-sr-mpls and mpls te static-cr-lsp commands on the device, only the mpls te static-cr-lsp command takes effect. For the mpls te static-sr-mpls command to take effect, execute the undo mpls te static-cr-lsp command.
# Bind static SRLSP static-sr-3 to MPLS TE tunnel interface 0.
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te static-sr-mpls static-sr-3
display mpls te tunnel-interface (MPLS Command Reference)
mpls te signaling (MPLS Command Reference)
mpls te static-cr-lsp (MPLS Command Reference)
static-sr-mpls lsp
Use static-sr-mpls adjacency to configure an adjacency segment for static MPLS SR.
Use undo static-sr-mpls adjacency to delete an adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
undo static-sr-mpls adjacency adjacency-path-name
No adjacency segments exist.
adjacency-path-name: Specifies the adjacency segment name, a case-sensitive string of 1 to 15 characters.
in-label label-value: Specifies the incoming label, in the range of 16 to 15999.
nexthop ip-address: Specifies the next hop address.
outgoing-interface interface-type interface-number: Specifies an output interface by its type and number. The output interface must be a P2P interface.
Execute this command on all nodes of a static SRLSP.
If you specify the next hop address, make sure the following requirements are met:
·     The device has a route to reach the next hop address.
·     MPLS is enabled on the output interface of the route.
If you specify an output interface, make sure the following requirements are met:
·     The interface is up.
·     The interface can receive direct routes.
·     MPLS is enabled on the interface.
The incoming label specified by this command must be different than existing static LSPs, static PWs, and static CRLSPs. If not, the configured adjacency segment is unavailable. The adjacency segment cannot become available even if you change the incoming label of the static LSP, static PW, or static CRLSP. To resolve this problem, you must delete the existing adjacency segment and configure a new one with a different incoming label.
# Configure an adjacency segment named adj1. Set the incoming label to 100 and the next hop address to 12.2.1.2.
[Sysname] static-sr-mpls adjacency adj1 in-label 100 nexthop 12.2.1.2
display static-sr-mpls
static-sr-mpls lsp
static-sr-mpls lsp
Use static-sr-mpls lsp to configure a static SRLSP.
Use undo static-sr-mpls lsp to delete a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-n>
undo static-sr-mpls lsp lsp-name
No static SRLSPs exist.
lsp-name: Specifies the static SRLSP name, a case-sensitive string of 1 to 15 characters.
out-label out-label-value&<1-8>: Specifies a space-separated list of up to 8 outgoing labels, corresponding to the labels from top to bottom in the label stack. The value range for the out-label-value argument is 0, 3, and 16 to 1048575.
The outgoing labels represent an ordered list of labels allocated for the adjacencies or nodes that a static SRLSP traverses. The top label is the label that the ingress node allocates for the adjacency or destination prefix.
# Configure a static SRLSP named lsp1. Specify outgoing labels 100 and 200 for the SRLSP.
[Sysname] static-sr-mpls lsp lsp1 out-label 100 200
Use static-sr-mpls prefix to configure a prefix segment for static MPLS SR.
Use undo static-sr-mpls prefix to delete a prefix segment.
static-sr-mpls prefix prefix-path-name destination ip-address { mask | mask-length } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls prefix prefix-path-name [ destination ip-address { mask | mask-length } in-label in-label-value [ nexthop ip-address | output-interface interface-type interface-number ] ]
No prefix segments exist.
prefix-path-name: Specifies the prefix segment name, a case-sensitive string of 1 to 15 characters.
destination ip-address: Specifies the destination IP address.
mask: Specifies the mask.
in-label label-value: Specifies the incoming label, in the range of 16000 to 24000.
out-label out-label-value: Specifies the outgoing label, in the range of 0, 3, and 16 to 1048575.
A prefix segment must use the next hop or output interface of the optimal route to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hops or output interfaces. To avoid configuration failure, make sure all prefix segments use the same prefix segment name, and incoming label.
If you specify only the prefix-path-name argument, the undo static-sr-mpls prefix command deletes all prefix segments with the specified name. If you specify all parameters, only the prefix segment that matches the specified name, destination IP address, and next hop or output interface is deleted.
# Configure a prefix segment named prefix1. Set the destination IP address, incoming label, outgoing label, and next hop to 2.2.2.2, 16000, 16001, and 10.0.0.2, respectively.
[Sysname] static-sr-mpls prefix prefix1 destination 2.2.2.2 32 in-label 16000 nexthop 10.0.0.2 out-label 16001
