WA5300-CMW710-E2433P10-ANCHOR(support for AP model WA538-WW、WA536-WW、WA530X-WW、WA5530X、WA5330、WA538-JP、WA5530i )
Release time:2020-07-06
HomeSupportWirelessWA5330 Access PointSoftware DownloadWA5330
WA5300-CMW710-E2433P10-ANCHOR Release Notes
This document describes the features, restrictions and guidelines, open problems, and workarounds of WA5300 anchor APs. Before you use this version in a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with the documents listed in “Related documentation”.
Version information
Version number
Comware Software, Version 7.1.064, ESS 2433P10
Note: This version number can be displayed by using the command display version in any view. Please see Note1.
Version history
Version History
Table 1 Version history
Version number
Last version
Release date
Release type
Remarks
First release
2020-06-24
Official version
Released for production
Hardware and software compatibility matrix
CAUTION
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Table 2 Hardware and software compatibility matrix
Item
Specifications
Product family
WA538-WW/WA536-WW/WA530X-WW/WA5530X/WA5330/WA538-JP/WA5530i
Memory
512M
Flash
128M
Boot ROM version
Basic 7.12
Extend 7.22
(Note: Perform the command display version command in any view to view the version information. Please see Note2.)
Host software
WA5300-CMW710-E2433P10-ANCHOR.ipe
MD5: 8bf391f00b673403bbef1a1f391098d5
To display the software and Boot ROM version of the WA5300, perform the following:
<Sysname> display version
H3C Comware Software, Version 7.1.064, ESS 2433P10                    --------Note1
Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.
H3C WA538-WW uptime is 0 weeks, 0 days, 0 hours, 0 minutes
Last reboot reason : User soft reboot
Boot image: flash:/wa5300anchor-boot.bin
Boot image version: 7.1.064, ESS 2433P10                              --------Note1
  Compiled Apr 02 2020 16:00:00
System image: flash:/wa5300anchor-system.bin
System image version: 7.1.064, ESS 2433P10                            --------Note1
with 1 ARM 710MHz Processor
512M bytes DDR3
4M bytes NorFlash Memory
128M bytes NandFlash Memory
Hardware Version is Ver.A
Basic Bootrom Version is 7.12                                           --------Note2
Extend Bootrom Version is 7.22                                          --------Note2
[Subslot 0] H3C WA538-WW Hardware Version is Ver.A
[SLOT 1]GE1/0/1     (Hardware)Ver.A, (Driver)1.0
[SLOT 1]GE1/0/2     (Hardware)Ver.A, (Driver)1.0
[SLOT 1]RADIO1/0/1  (Hardware)Ver.A, (Driver)1.0
[SLOT 1]RADIO1/0/2  (Hardware)Ver.A, (Driver)1.0
[SLOT 1]RADIO1/0/3  (Hardware)Ver.A, (Driver)1.0
Upgrading restrictions and guidelines
Make sure bootware is 7.22 or later, or upgrade first.
Hardware feature updates
None.
Software feature and command updates
None.
MIB updates
None.
Operation changes
None.
Restrictions and cautions
None.
Open problems and workarounds
None.
List of resolved problems
Resolved problems in WA5300-CMW710-E2433P10
First release.
None
Technical support
To obtain support services, contact H3C Support at [email protected]
Appendix A Feature list
Hardware features
Table 3 Hardware features
Item
WA538-WW/WA538-JP
WA536-WW
WA530X-WW
Dimensions (H × W × D)
(excluding feet and rack-mounting brackets)
40 × 183 × 183 mm (1.57 × 7.20 × 7.20 in)
47.5 × 215 × 215 mm (1.87 × 8.46 × 8.46 in)
35.5 × 170 × 170 mm (1.40 × 6.69 × 6.69 in)
Weight
700 g (1.54 lb)
728 g (1.60 lb)
1.8 kg (3.97 lb)
Port type and max transmission distance
Category 5e twisted-pair: 100 m (328.08 ft)
Voltage
PoE: 54 VDC
Local supply:
+54 VDC at 0.74 A
PoE: 54 VDC
Local supply:
+54 VDC at 0.74 A
PoE: 54 VDC
Max power consumption (excluding USB and PoE)
25 W
15 W
25 W
Operating temperature
0°C to 45°C (32°F to 113°F)
–30°C to 55°C (–22°F to 131°F)
Operating humidity
5% RH to 95% RH, non-condensing
0% RH to 100% RH, non-condensing
Item
WA5530X
WA5330
WA5530i
79.5 × 250 × 250 mm (3.13 × 9.84 × 9.84 in)
68 × 325 × 255  mm (2.68 × 12.80 × 10.04 in)
Weight
1.8 kg (3.97 lb)
728 g (1.60 lb)
2.18kg (4.81 lb)
Voltage
PoE: 54 VDC
PoE: 54 VDC
Local supply:+54 VDC at 0.74 A
PoE: 54 VDC
26.3 W
15 W
15 W
–30°C to +55°C (–22°F to 131°F)
0°C to +45°C (32°F to 113°F)
Operating humidity
Software features
Table 4 Software features
Category
Feature
802.11 MAC
802.11 protocols
802.11a/802.11b/802.11d/802.11e(WMM)/802.11g/802.11h/802.11i/802.11n/802.11w/802.11ac
AP management
AP discovery and previsioning
DHCP Option 43 discovery
MSM DHCP Option 43 discovery
Tunneling
CAPWAP
Security and access control
Wireless encryption
Shared-Key
TKIP
CCMP
Authentication
Open system
Shared-Key
PSK
Private PSK
802.1X
MAC authentication
EAP
EAP-TLS/EAP-TTLS/EAP-PEAP/EAP-MD5/EAP-GTC/EAP-FAST/EAP-SIM/EAP-AKA
AAA
RADIUS
Domain-based AAA server selection
SSID-based AAA server selection
AAA server redundancy
Time-based accounting
User and access control
User-based ACL
User-based bandwidth limit
User account-to-SSID binding
Binding of user account, VLAN, ACL, and user profile
Access control based on AP or AP group
Wireless radio resource management (WRRM)
RRM
20M/40M switchover for APs
Dynamic rate adjustment
Automatic channel selection
Automatic power adjustment
Blackhole detection and compensation
WIPS
Rogue AP
SSID-based rogue AP detection
Rogue AP countermeasure
Countermeasure
DoS attack avoidance
Attack detection
Flood attack detection
Spoofing Detection
Weak IV detection
Framework
Multi-radio support
Support for hybrid sensor
Device classification
802.11n/802.11ac device support
802.11w device support
Rogue device detection
Full-channel scanning
OUI
OUI database import
OUI information display
IP protocols
IPv4
TCP/UDPV4
ICMPv4
ACL
DHCP server
Management
HTTP/HTTPS
CLI/Telnet/SSH v2.0
Energy saving
Green AP
Scheduled radio interface shutdown
Scheduled SSID disabling
Client probing service
Client probing
Appendix B Upgrading software
You can upgrade an AP through the associated AC or from the BootWare menu.
Figure 1 Upgrading environment
Upgrading from the BootWare menu
1.        Enter the EXTENDED-BOOTWARE menu
# Reboot the AP.
Starting......
Press Ctrl+D to access BASIC BOOT MENU
*                   H3C WA538-WW BootWare, Version 7.22                    *
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd.
Compiled Date       : Dec 19 2017
CPU Type            : ARM
CPU L1 Cache        : 32KB
CPU L2 Cache        : 256KB
CPU Clock Speed     : 710MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 512MB
Memory Speed        : 667MHz
Flash Size          : 128MB
PCB Version         : Ver.A
Press Ctrl+B to access EXTENDED 4
The output in this section is for illustration only.
# Press Ctrl+B at the prompt to access the EXTENDED-BOOTWARE menu.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9):
Table 5 EXTENDED-BOOTWARE menu options
Item
<1> Boot System
Boot the system software image.
Access the Serial submenu for upgrading system software through the console port or changing the serial port settings.
Access the Ethernet submenu for upgrading system software through an Ethernet port or changing Ethernet settings.
<4> File Control
Access the File Control submenu to retrieve and manage the files stored on the device.
Delete the next-startup configuration files and load the factory-default configuration.
Start the device with the factory default configuration. This is a one-time operation and does not take effect at the next reboot. You use this option when you forget the console login password.
Access the BootWare Operation menu for backing up, restoring, or upgrading BootWare. When you upgrade the system software image, BootWare is automatically upgraded. H3C does not recommend upgrading BootWare separately. This document does not cover using the BootWare Operation menu.
Clear all the authentication schemes on the console port.
Access the Storage Device Operation menu to manage storage devices. Using this option is beyond this chapter.
<0> Reboot
Restart the device.
2.        Enter CTRL+Y to select AP mode
Please select the new mode
Current mode is FIT Mode
|NO.  Mode        |
|1    Fat Mode                                                             |
|2    Fit Mode                                                             |
|3    Anchor-AC   (Virtual AC Mode)                                        |
|4    Anchor-Fit                                                           |
|5    Oasis Mode                                                           |
|0    Exit        |
Enter your choice(0-5):4
Changed to anchor-fit mode successfully!
3.        In the EXTEND-BOOTWARE menu, enter 3 to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                         |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Table 6 Ethernet submenu options
Item
Download a system software image to the SDRAM and run the image.
Upgrade the main system software image.
Upgrade the backup system software image.
Download a system software image to the Flash or CF card.
Modify network settings.
Return to the EXTEND-BOOTWARE menu.
4.        Enter 5 to configure the network settings.
=========================<ETHERNET PARAMETER SET>=========================
|Note:       '.' = Clear field.                                           |
|            '-' = Go to previous field.                                  |
|          Ctrl+D = Quit.                                                 |
Protocol (FTP or TFTP) :ftp
Load File Name         :wa5300anchor.ipe
Target File Name       :wa5300anchor.ipe
Server IP Address      :192.168.1.1
Local IP Address       :192.168.1.100
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
FTP User Name          :user001
FTP User Password      :********
Table 7 Network parameter fields and shortcut keys
'.' = Clear field
Press a dot (.) and then Enter to clear the setting for a field.
Press a hyphen (-) and then Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl + D to exit the Ethernet Parameter Set menu.
Set the file transfer protocol to FTP or TFTP.
Load File Name
Set the name of the file to be downloaded.
Target File Name
Set a file name for saving the file on the device. By default, the target file name is the same as the source file name.
Server IP Address
Set the IP address of the FTP or TFTP server. If a mask must be set, use a colon (:) to separate the mask length from the IP address. For example, 100.1.1.13:24.
Local IP Address
Set the IP address of the device.
Subnet Mask
Subnet Mask of the local IP address.
Gateway IP Address
Set a gateway IP address if the device is on a different network than the server.
FTP User Name
Set the username for accessing the FTP server. This username must be the same as configured on the FTP server. This field is not available for TFTP.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as configured on the FTP server. This field is not available for TFTP.
5.        Select the option 2 or 3 in the Ethernet submenu to upgrade a system software image. For example, enter 2 to upgrade the main system software image.
Loading.....................................................................
...................................................Done.
13736960 bytes downloaded!
Image file wa5300anchor-boot.bin is self-decompressing...
Saving file flash:/wa5300anchor-boot.bin .........................................
Image file wa5600-system.bin is self-decompressing...
Saving file flash:/wa5300anchor-system.bin .......................................
..............Done.
6.        Enter 0 to return to the EXTEND-BOOTWARE menu
Enter your choice(0-5): 0
===========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                            |
|<4> File Control                                                           |
|<5> Modify BootWare Password                                               |
|<0> Reboot        |
7.        Enter 1 to boot the system.
Enter your choice(0-9): 1
Loading the main image files...
Loading file flash:/wa5300anchor-system.bin.................................
...Done.
Loading file flash:/wa5300anchor-boot.bin........Done.
Image file flash:/wa5300anchor-boot.bin is self-decompressing...............
......Done.
System image is starting...
Startup configuration file doesn't exist or is invalid.
Line con0 is available.
Press ENTER to get started.
8.        After the upgrade, verify that the AP's firmware has been upgraded to the most recent version.
<Sysname>display version
H3C WA538-WW uptime is 0 weeks, 0 days, 0 hours, 1 minute
  Compiled May 22 2020 16:00:00
512M bytes DDR3
[Subslot 0]H3C WA5530 Hardware Version is Ver.A
