H3C Servers Purley Platform Text-Mode BIOS User Guide-2.00.XX-6W101
HomeSupportH3C Servers Purley Platform Text-Mode BIOS User Guide-2.00.XX-6W101
01-Text
01-Text 18.55 MB
About the BIOS·· 1
Introduction· 1
Applicable products· 1
Using this document 1
Common BIOS tasks· 2
Entering the BIOS setup utility· 2
Setting the BIOS setup mode (for all servers except for the B5700, B5800, and B7800) 5
Displaying processor information· 6
Displaying memory information· 6
Displaying onboard drive information (for all servers except for the R8900) 7
Displaying HDM network information· 8
Setting HDM network information (for all servers except for the B5700, B5800, and B7800) 9
Configuring BIOS passwords· 11
About this task· 11
Restrictions and guidelines for configuring BIOS passwords· 12
Setting the administrator password· 13
Setting the user password· 15
Deleting BIOS passwords· 17
Setting the system date and time· 19
Setting the BIOS boot mode· 20
Setting the server boot order 21
Configuring RAID·· 23
Restoring BIOS default settings· 23
Configuring an iSCSI virtual driver (for the R5300, B5700, B5800, and B7800 servers) 24
BIOS menus· 31
Main menu· 31
Advanced menu· 32
Trusted Computing submenu· 34
ACPI Settings submenu· 39
Serial Port Console Redirection submenu· 40
PCI Subsystem Settings submenu· 45
USB Configuration submenu· 46
CSM Configuration submenu· 48
NVMe Configuration submenu· 50
iMS Configuration submenu· 54
Network PXE Control submenu· 56
Network Stack Configuration submenu· 58
iSCSI Configuration submenu (for the R5300, B5700, B5800, and B7800 servers) 60
Intel(R) VROC sSATA Controller submenu (for all servers except for the R8900) 65
Intel(R) Virtual RAID on CPU submenu· 74
Slot x:Port x submenu· 84
Intel(R) Optane(TM) DC Persistent Memory Configuration submenu· 86
Driver Health submenu· 117
Platform Configuration menu· 118
PCH Configuration submenu· 118
Miscellaneous Configuration submenu· 148
Server ME Configuration submenu· 150
Runtime Error Logging submenu· 152
Socket Configuration menu· 167
Processor Configuration submenu· 169
Common RefCode Configuration submenu· 174
UPI Configuration submenu· 176
Memory Configuration submenu· 179
IIO Configuration menu· 185
Advanced Power Management Configuration submenu· 198
Server Management menu· 210
Security menu· 222
Boot menu· 227
Save & Exit menu· 233
Acronyms and abbreviations· 235
About the BIOS
Introduction
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the following products:
·     H3C UniServer E3200 G3 server
·     H3C UniServer R2700 G3 server
·     H3C UniServer R2900 G3 server
·     H3C UniServer R4300 G3 server
·     H3C UniServer R4400 G3 server
·     H3C UniServer R4700 G3 server
·     H3C UniServer R4900 G3 server
·     H3C UniServer R5300 G3 server
·     H3C UniServer R6700 G3 server
·     H3C UniServer R6900 G3 server
·     H3C UniServer R8900 G3 server
·     H3C UniServer B5700 G3 blade server
·     H3C UniServer B5800 G3 blade server
·     H3C UniServer B7800 G3 blade server
Using this document
The information in this document is subject to change over time. You can access the H3C website to obtain the most recent version of the BIOS.
The information in this document might differ from your product if it contains custom configuration options or features.
The figures used in this document are for illustration only and might differ from your product.
Common BIOS tasks
This section provides procedures for the following common BIOS tasks:
·     Entering the BIOS setup utility
·     Setting the BIOS setup mode (for all servers except for the B5700, B5800, and B7800)
·     Displaying processor information
·     Displaying memory information
·     Displaying onboard drive information (for all servers except for the R8900)
·     Displaying HDM network information
·     Setting HDM network information (for all servers except for the B5700, B5800, and B7800)
·     Configuring BIOS passwords
·     Setting the system date and time
·     Setting the BIOS boot mode
·     Setting the server boot order
·     Configuring RAID
·     Restoring BIOS default settings
·     Configuring an iSCSI virtual driver (for the R5300, B5700, B5800, and B7800 servers)
1.     Connect a keyboard, mouse, and monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see HDM online help.
2.     Start or restart the server.
3.     Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2.
The HDM Dedicated IPv4 item is unavailable for the B5700, B5800, and B7800 servers.
Figure 2 BIOS startup screen
4.     Enter the BIOS password if required during boot-up, as shown in Figure 3.
By default, no BIOS passwords are set. For information about BIOS password setup, see "Configuring BIOS passwords."
If only the administrator password is set, enter the administrator password to obtain the administrator privileges or press Enter to obtain the user privileges.
If you enter an incorrect password for three consecutive times, the server will restart automatically.
If you forget the password, use the system maintenance switch in the server to clear BIOS password settings. For more information about the system maintenance switch, see the user guide for the server.
IMPORTANT
IMPORTANT:
If you use the system maintenance switch to clear BIOS passwords, restore the switch to the default position after you set new password settings. If you fail to do so, the new settings will be cleared.
Figure 3 Entering the BIOS password
5.     On the BIOS setup utility screen that opens, follow the instructions at the lower-right side of the screen to configure BIOS settings, as shown in Figure 4.
Table 1 shows detailed information about the operation keys.
Figure 4 BIOS setup utility screen
Table 1 Operation keys
Key
Select a screen.
Select an item or a submenu.
Enter
Select an item to edit its value or access a submenu.
Change the field value of the selected item.
ESC
Exit the BIOS setup utility or return to the previous screen.
F1
Display the general help window.
F2
Load previous values in the BIOS.
F3
Load default values in the BIOS.
F4
Save the current configuration and exit the BIOS.
<K>
Scroll up the help area at the upper-right side of the screen.
<M>
Scroll down the help area at the upper-right side of the screen.
1.     Enter the BIOS setup utility. For more information, see "Entering the BIOS setup utility."
2.     Select Main > Setup Mode, and press Enter.
3.     In the Setup Mode window that opens, select a BIOS setup mode (Text or Graphic), and press Enter.
Figure 5 Setting the BIOS setup mode
4.     Press F4 and then press Enter to save the configuration.
The server will restart automatically.
2.     Select Socket Configuration > Processor Configuration, and press Enter.
The Processor Configuration submenu that opens displays detailed information about processors, as shown in Figure 6.
For more information about the Processor Configuration submenu, see "Processor Configuration submenu."
Figure 6 Processor Configuration screen
2.     Select Socket Configuration > Memory Configuration, and press Enter.
The Memory Configuration submenu that opens displays memory capacity and frequency information, as shown in Figure 7.
For more information about the Memory Configuration submenu, see "Memory Configuration submenu."
Figure 7 Memory Configuration submenu
3.     To view detailed information about each DIMM, select Memory Topology, and press Enter.
The screen that opens displays detailed information about each DIMM.
Both the PCH SATA Configuration and PCH sSATA Configuration submenus display onboard drive information. This example uses the PCH SATA Configuration submenu. For more information about the submenus, see "PCH SATA Configuration submenu screen."
2.     Select Platform Configuration > PCH Configuration > PCH SATA Configuration, and press Enter.
The PCH SATA Configuration submenu that opens displays drive information, as shown in Figure 8.
Figure 8 PCH SATA Configuration submenu
2.     Select Server Management > HDM Network Configuration, and press Enter.
The HDM Network Configuration submenu that opens displays HDM network configuration information, as shown in Figure 9.
Figure 9 HDM Network Configuration screen
Perform this task to configure the IP address, subnet mask, and router IP address of HDM network ports and the method of obtaining the network information.
The submenus are the same for both HDM dedicated and shared network ports. This example uses the HDM shared network port.
To avoid network storms, make sure the IP address of the HDM shared network port is on a network segment different than the HDM dedicated network port.
The HDM Network Configuration submenu that opens displays HDM network configuration information, as shown in Figure 10.
Figure 10 HDM Network Configuration submenu
3.     Select Configuration Address source for the HDM shared network port, and press Enter.
4.     In the dialog box that opens, select the method for obtaining HDM network information. Options are:
¡     UnspecifiedRetains current configuration.
¡     StaticUses manually specified configuration.
¡     DynamicHdmDhcpUses network information obtained through DHCP.
Figure 11 Configuration Address Source dialog box
5.     Press Enter. If you select Static as the method for obtaining HDM network information, edit the following items and press Enter every time you finish editing:
¡     Station IP address—Enter a static IP address. This item is required.
¡     Subnet mask—Enter a subnet mask for the static IP address. This item is required.
¡     Router IP address—Enter a gateway IP address.
6.     Press F4 and then press Enter to save the configuration.
BIOS passwords include an administrator password and a user password. By default, no passwords are set.
If only the administrator password is set, you can enter this password to obtain administrator privileges or press Enter to obtain user privileges. The system prompts for the password when you use shortcut keys to enter the BIOS setup utility, iFIST, boot menu, or PXE boot interface.
If only the user password is set, you must enter this password as the power-on password at the startup of the server. To enter the BIOS setup utility, this password is also required and you can obtain administrator privileges.
If both the administrator password and the user password are set, the following rules apply:
·     If the two passwords are different, you can enter the administrator password to obtain administrator privileges or enter the user password to obtain user privileges. If the two passwords are the same, you can enter the password to obtain the administrator privileges.
·     The system prompts for the user password at BIOS access and prompts for the administrator password when you use shortcut keys to enter the iFIST, boot menu, or PXE boot interface.
Table 2 shows menu items that are accessible in the BIOS when you enter BIOS setup by using the user password.
Table 2 BIOS menu items accessible with the user password
Level-1 menu
Submenu items
Security
User Password
Save & Exit
Save Changes and Exit
Discard Changes and Exit
Save Changes and Reset
Discard Changes and Reset
Save Changes
Discard Changes
To prevent unauthorized access and changes to the BIOS settings, set different BIOS user and BIOS administrator passwords for the server as a best practice.
When you change a BIOS password, make sure the new password is different from the most recent three passwords.
The BIOS passwords must meet the following requirements:
·     A case-sensitive string of 8 to 20 characters. Valid characters are letters, digits, spaces, and special characters in Table 3.
·     Contain a minimum of two character types from uppercase letters, lowercase letters, and digits.
·     Contain a minimum of one space or special character.
Table 3 Special characters
Character name
Symbol
Character name
Symbol
Back quote
Tilde
Exclamation point
At sign
Pound sign
Dollar sign
Percent sign
Caret
Ampersand sign
Asterisk
Left parenthesis
Right parenthesis
Underscore
_
Plus sign
Minus sign
Equal sign
Left bracket
Right bracket
Back slash
Left brace
Right brace
Vertical bar
Semi-colon
Apostrophe
Colon
Quotation marks
Comma
Dot
Forward slash
Left angle bracket
Right angle bracket
Question mark
2.     Select Security > Administrator Password, and press Enter.
Figure 12 Setting the administrator password
3.     In the Create New Password dialog box that opens, enter an administrator password, and press Enter.
Figure 13 Creating an administrator password
4.     In the Confirm New Password dialog box that opens, enter the password again, and press Enter.
Figure 14 Confirming the administrator password
5.     Press F4 and then press Enter to save the configuration.
2.     Select Security > User Password, and press Enter.
Figure 15 Setting the user password
3.     In the Create New Password dialog box that opens, enter a user password, and press Enter.
Figure 16 Creating a user password
Figure 17 Confirming the user password
The procedure is the same for deleting the administrator password and the user password. This section uses the administrator password as an example.
Figure 18 Selecting the administrator password
3.     In the Enter Current Password dialog box that opens, enter the current administrator password, and press Enter.
Figure 19 Entering the current administrator password
3.     Press Enter when the Create New Password dialog box opens as shown in Figure 20.
Figure 20 Deleting the administrator password
4.     In the WARNING dialog box that opens, select Yes, and press Enter.
Figure 21 Confirming the deletion
2.     Select the Main menu.
Figure 22 Main menu
3.     Set the system date:
a.     Select System Date.
The system date is in the format of mm/dd/yyyy.
a.     Press Enter or Tab to switch between the month, day, and year fields and then use the following methods to modify the value:
-     Press + to increase the value by 1.
-     Press to decrease the value by 1.
-     Press numeric keys to enter a new value.
4.     Set the system time:
a.     Select System Time.
The system time uses the 24-hour time system and is in the format of hh:mm:ss.
a.     Press Enter or Tab to switch between the hour, minute, and second fields and then use the following methods to modify the value:
The server supports two BIOS boot modes: legacy mode and UEFI mode.
By default, the boot mode is UEFI. For operating systems that support only the legacy mode, change the boot mode to legacy.
1.     Enter the BIOS setup screen. For more information, see "Entering the BIOS setup utility."
2.     Select Boot > Boot mode select, and press Enter.
3.     In the Boot mode select dialog box that opens, select LEGACY or UEFI, and press Enter.
Figure 23 Setting the BIOS boot mode
Perform this task to change the server boot order.
The default boot order is hard disk > network > CD/DVD > other device as shown in the Fixed Boot Order Priorities list in Figure 24.
If the server has more than one boot devices of the same type, the Fixed Boot Order Priorities list displays only the first boot device. To change the first boot device, enter the corresponding priorities submenu of the boot device, and then set the first boot option. For example, to change the first boot option for hard disks, enter the UEFI Hard Disk Drive BBS Priorities submenu as shown in Figure 187, and then set the first boot option.
2.     Select the Boot menu.
Figure 24 Boot menu
Table 4 Server boot options
Item
Example
Hard Disk
Disk and USB.
Network
Network.
CD/DVD
CD-ROM and DVD-ROM (including virtual ones).
Other Device
This item is available only in UEFI boot mode.
Options:
·     Embedded UEFI shell. This option is displayed only when EFI Shell Boot is set to Enabled.
·     USB devices with the capacity less than 32 GB.
·     Virtual drives.
Disabled
The boot option is disabled.
3.     Select the option to be modified from the Fixed Boot Order Priorities area, and press Enter.
4.     In the dialog box that opens, select a new boot device type, and press Enter.
Figure 25 Changing a boot option
Configuring RAID
For information about to configure RAID through the BIOS, see the storage controller user guide for the server.
2.     Press F3 in the BIOS, or select Save & Exit > Restore Defaults and press Enter as shown in Figure 26.
Figure 26 Restoring the default from the Save & Exit menu
iSCSI provides access to shared storage resources by carrying SCSI commands over TCP/IP networks.
If iSCSI is enabled on a network port, PXE is disabled for the port.
Make sure the UEFI boot mode is used for the server. For more information about setting the BIOS boot mode, see "Setting the BIOS boot mode."
·     You have the knowledge of iSCSI and the iSCSI server setup process.
·     You have the access to an external iSCSI server running on a supported OS.
·     You must prepare iSCSI target parameters. Table 5 shows the required parameters and parameter examples.
Table 5 iSCSI target parameters
Item
Example
iSCSI target name
iqn.1994-05.com.redhat:cb2b5bd41b30
iSCSI initiator name
iqn.1994-05.com.redhat:sq1s1sq11s11
Logical unit number
LUN 0
IP address of the iSCSI server
192.168.14.200 (IPv4)
Port number
3260
2.     (Optional.) Set the UEFI boot mode of ports on the iSCISI module to a mode other than iSCSI.
For some iSCISI modules, if the UEFI boot mode is iSCSI, the configuration item for the module is unavailable in the iSCSI Configuration menu.
This section uses port Slot 5 Mezz1: Port 1 as an example.
a.     Select Advanced > Slot 5 Mezz1: Port 1- Qlogic 577xx/578xx 10 Gb Ethernet BCM57840 – 38:97:D6:E2:5D:BA.
Figure 27 Network port configuration option
b.     Select Device Hardware Configuration Menu, and press Enter.
Figure 28 Device Hardware Configuration Menu
c.     Set the UEFI boot mode to UNDI.
Figure 29 Setting the UEFI boot mode of the iSCSI module
d.     Save the changes and reboot the server for the configuration changes to take effect.
3.     Select Advanced > iSCSI Configuration, and press Enter.
Figure 30 Advanced menu
4.     Select iSCSI Initiator Name, and enter the iSCSI initiator name.
The iSCSI initiator name must be in the iSCSI Qualified Name (IQN) format, iqn.2003-02.emu.com:test123, for example.
Figure 31 Entering the iSCSI initiator name
5.     Select Add an Attempt, and press Enter.
6.     Select the MAC address of the network port interconnected to the iSCSI server, and press Enter.
Figure 32 Selecting the MAC address of the network port interconnected to the iSCSI server
7.     Configure an iSCSI virtual driver (iSCSI attempt):
¡     Set the iSCSI mode to Enabled.
¡     Set the internet protocol.
¡     Set the connection retry count and the connection establishing timeout.
¡     Enable or disable DHCP as needed.
If DHCP is disabled, you need to specify the following parameters: Initiator IP address, Initiator Subnet Mask, and Gateway.
¡     Set the target name. The target name must be in the IQN format, for example, iqn.1994-05.com.redhat:cb2b5bd41b30.
¡     Set the target address. The target address is the IP address of the iSCSI server, which is in dotted-decimal notion, for example, 192.168.14.200.
¡     Set the target port. The target port is the port number of the iSCSI server, for example, 3260.
¡     Set the boot LUN. In the Boot LUN dialog box that opens, enter the logical unit number, for example, 0.
Figure 33 Configuring an iSCSI attempt
8.     Select Save Changes, and press Enter.
Figure 34 Saving the iSCSI attempt configuration
9.     Select Back to Previous Page, and press Enter.
The iSCSI Configuration menu that opens displays the newly created iSCSI virtual driver Attempt 1.
Figure 35 Displaying Attempts
BIOS menus
Main menu
As shown in Figure 36, the Main menu contains information about the BIOS, memory, system language, and system time and date. For more information about the menu items, see Table 6.
Figure 36 Main menu screen
Table 6 Items on the Main menu screen
Item
BIOS Information
Project Name
Displays the project name.
N/A
Product Name
Displays the server model.
N/A
BIOS Version
Displays the BIOS version.
N/A
System Uuid
Displays the universally unique identifier (UUID) of the system.
N/A
Serial Number
Displays the serial number of the server, a string of 2 to 20 characters. Only uppercase letters and digits are allowed.
N/A
Asset Tag
Specify the asset tag of the server, a case-sensitive string of 2 to 32 characters.
N/A
Build Date and Time
Displays the date and time of the BIOS build.
N/A
Platform Information
Processor
Displays the CPU ID and stepping.
N/A
PCH
Displays the platform controller hub (PCH) model.
N/A
RC Revision
Displays the RC version.
N/A
Memory Information
Total Memory
Displays the total memory capacity of the system in GB.
N/A
Usable Memory
Displays the available memory capacity of the system in GB.
N/A
Current Memory Frequency
Displays the current memory frequency.
For information about setting the memory frequency, see "Memory Configuration submenu."
N/A
Other items
System Language
Displays the language used in the system.
The BIOS supports English and simplified Chinese.
To switch between the languages, press Enter.
English
Setup Mode
Set the BIOS setup mode.
Options:
·     Text.
·     Graphic.
This item is not available for the B5700, B5800, and B7800.
Text
System Date
Displays the system date. You can change the system date as needed.
The system date is in the format of mm/dd/yyyy. To move between the month, day, and year fields, press Enter or Tab. To change the value for the selected field, use the following method:
·     Press + to increase the value by 1.
·     Press - to decrease the value by 1.
·     Press a numeric key to set the value.
N/A
System Time
Displays the system time. You can change the system time as needed.
The system time is in the format of hh:mm:ss in 24-hour format. To move between the hour, minute, and second fields, press Enter or Tab. To change the value for the selected field, use the following method:
N/A
Advanced menu
As shown in Figure 37, the Advanced menu contains advanced system features and functionalities, which are described in Table 7.
Figure 37 Advanced menu screen (for the E3200, R2700, R2900, R4300, R4400, R4700, R4900, R5300, R6700, R6900, and R8900)
Figure 38 Advanced menu screen (for the B5700, B5800, and B7800)
Table 7 Items on the Advanced menu screen
Item
Trusted Computing
Submenu for configuring trusted computing.
ACPI Settings
Submenu for configuring advanced configuration and power interface (ACPI) settings.
Submenu for configuring serial console port redirection.
Submenu for configuring the PCI subsystem.
USB Configuration
Submenu for configuring USB.
CSM Configuration
Submenu for configuring the compatibility support module (CSM).
NVMe Configuration
Submenu for configuring NVMe.
iMS Configuration
Submenu for configuring IMS.
This submenu is available only for the B5700, B5800, and B7800 servers.
Network PXE Control
Submenu for configuring network PXE control.
This submenu is unavailable for the B5700, B5800, B7800, and R8900 servers.
Submenu for configuring network stacks.
iSCSI Configuration
Submenu for configuring iSCSI.
This submenu is available only for the R5300, B5700, B5800, and B7800.
Submenu for configuring Intel(R) VROC sSATA controller.
This submenu is available only when the RAID mode is used in the PCH settings.
Intel(R) VROC SATA Controller
Submenu for configuring Intel(R) VROC SATA controller.
Slot x:Port x
Submenu for configuring an Ethernet interface, storage controller, or NVMe drive that has an Option ROM.
Submenu for configuring Intel(R) Virtual RAID on CPU (Intel VROC). This submenu is available only when VMD is enabled.
Submenu for configuring Optane(TM) DC Persistent Memory. This submenu is available only when Intel DCPMMs are installed in the server.
Driver Health
Submenu for viewing the health state of drivers or controllers.
This submenu is available only in UEFI boot mode.
The server might contain a trusted platform module (TPM) or a trusted cryptography module (TCM).
Trusted Computing submenu screen (no security device installed)
Figure 39 shows a Trusted Computing submenu screen when no security device is installed. The submenu items are described in Table 8.
Figure 39 Trusted Computing submenu screen (no security device installed)
Table 8 Items on the Trusted Computing submenu screen when no security device is installed
Item
Security Device Support
Select Enabled or Disabled to enable or disable BIOS support for security devices.
·     R4400: Disabled
·     Other servers: Enabled
Trusted Computing submenu screen (TPM module installed)
Figure 40 shows a Trusted Computing submenu screen when a TPM module is installed. The submenu items are described in Table 9.
Figure 40 Trusted Computing submenu screen (TPM module installed)
Table 9 Items on the Trusted Computing submenu screen when a TPM module is installed
Item
Firmware Version
Displays the firmware version.
N/A
Vendor
Displays the name of the vendor.
N/A
Enabled
Active PCR banks
Displays the active platform configuration register (PCR) banks.
N/A
Available PCR Banks
Displays the available PCR banks.
N/A
SHA-1 PCR Bank
Select Enabled or Disabled to enable or disable the SHA-1 PCR bank.
Enabled
SHA256 PCR Bank
Select Enabled or Disabled to enable or disable the SHA256 PCR bank.
Enabled
SM3_256PCR Bank
Select Enabled or Disabled to enable or disable the SM3_256 PCR bank.
Enabled
TPM State
Select Enabled or Disabled to enable or disable TPM.
Enabled
Pending Operation
Select the TPM operation to be performed during the next boot process.
Options are None and TPM Clear. The TPM Clear operation clears the values of measurements in the TPM.
None
Platform Hierarchy
This item is inaccessible.
Select Enabled or Disabled to enable or disable platform hierarchy.
Enabled
Storage Hierarchy
Select Enabled or Disabled to enable or disable storage hierarchy.
Enabled
Endorsement Hierarchy
Select Enabled or Disabled to enable or disable endorsement hierarchy.
Enabled
TPM 2.0 UEFI Spec Version
Select the supported Trusted Computing Group (TCG) specification version.
Options:
·     TCG_1_2—Supports Windows 8 and Windows 10.
·     TCG_2—Supports TCG 2 protocols, TCG 2 event formats, and Windows 10 or higher.
TCG_2
Physical Presence Spec Version
Select the Physical Presence Interface (PPI) specification version to be reported to the OS.
Options:
·     1.2.
·     1.3. This option is not supported on all HCK tests.
1.3
TPM 2.0 InterfaceType
N/A
PH Randomization
Select Enabled or Disabled to enable or disable platform hierarchy randomization.
This feature is used only for tests in the development phase.
Disabled
Device Select
Select the supported security device version.
Options:
·     TCM 1.0—Select this option only if a TCM 1.0 module is installed.
·     TPM 2.0—Select this option only if a TPM 2.0 module is installed.
·     Auto—Select this option to have the system automatically select TCM 1.0 or TPM 2.0. The default is TPM 2.0. If TPM 2.0 is not present, TCM 1.0 is selected.
Auto
Trusted Computing submenu screen (TCM 1.0 module installed)
Figure 41 shows a Trusted Computing submenu screen when a TCM 1.0 module is installed. The submenu items are described in Table 10.
Figure 41 Trusted Computing submenu screen (TCM 1.0 module installed)
Table 10 Items on the Trusted Computing submenu screen when a TCM 1.0 module is installed
Item
Configuration
Enabled
TCM State
Select Enabled or Disabled to enable or disable TCM.
Enabled
Pending Operation
Select the TCM operation to be performed during the next boot process.
Options are None and TCM Clear. The TCM Clear operation clears the values of measurements in the TCM.
None
Device Select
Options:
Auto
Current Status Information
TCM Enabled Status
Displays whether TCM is enabled or disabled.
N/A
TCM Active Status
Displays whether TCM is activated or deactivated.
N/A
TCM Owner Status
Displays the TCM ownership state. Options are Owned and Unowned.
N/A
The ACPI Settings submenu contains the ACPI options for you to configure OS-directed configuration and power management of the server. The submenu items are described in Table 11.
Figure 42 ACPI Settings submenu screen
Table 11 Items on the ACPI Settings submenu screen
Item
Enable ACPI Auto Configuration
Select Enabled or Disabled to enable or disable ACPI auto configuration.
ACPI auto configuration allows the operating system to control and allocate power to the server hardware.
Disabled
Enable Hibernation
Select Enabled or Disabled to enable or disable system hibernation.
This option takes effect only on some OSs.
Enabled
Lock Legacy Resources
Select Enabled or Disabled to enable or disable lock of legacy resources.
Disabled
Serial port console redirection enables you to send all text-based output to one of the onboard serial ports by using a physical or virtual serial port.
Figure 43 shows the Serial Port Console Redirection submenu screen, on which you can configure console redirection settings as described in Table 12.
Figure 43 Serial Port Console Redirection submenu screen
redirection
Table 12 Items on the Serial Port Console Redirection submenu screen
Item
COM0
Serial port COM0.
N/A
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on COM0.
Enabled
Console Redirection Settings
Open the Console Redirection Settings submenu for COM0, as shown in Figure 44.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled on COM0.
N/A
Serial Port for Out-of-Band Management/Windows Emergency Management Services (EMS)
Serial port for out-of-band management or Windows Emergency Management Services (EMS).
N/A
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on the EMS port.
Disabled
Open the Console Redirection Settings submenu for the EMS port, as shown in Figure 45.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled for the EMS port.
N/A
Console Redirection Settings submenu screen (COM0)
Figure 44 shows a Console Redirection Settings submenu screen for serial port COM0. The submenu items are described in Table 13.
Figure 44 Console Redirection Settings submenu screen (COM0)
Table 13 Items on the Console Redirection Settings submenu screen (COM0)
Item
Terminal Type
Select the type of the terminal used for console redirection.
Options:
·     VT100—Uses a supported VT100 video terminal with the ASCII character set.
·     VT100+—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
·     VT-UTF8Uses a video terminal with the UTF-8 character set.
·     ANSIUses the ANSI character set, which is an extended ASCII character set.
VT100+
Bits Per Second
Set the baud rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     38400.
·     57600.
·     115200.
This baud rate setting must match the setting on the remote terminal.
As a best practice, set a low speed on a long or noisy serial line.
115200
Data Bits
Set the number of bits used to represent one character of data.
Options:
·     7.
·     8.
8
Parity
Set the parity bit to be sent with the data bits for transmission error detection.
Options:
·     NoneNo parity bit is sent.
·     Even—Sets the parity bit so that the number of ones in the data set is an even number.
·     Odd—Sets the parity bit so that the number of ones in the data set is an odd number.
·     Mark—Always sets the parity bit to 1. This setting cannot be used for error detection.
·     Space—Always sets the parity bit to 0. This setting cannot be used for error detection.
None
Stop Bits
Set the number of stop bits used to indicate the end of a serial data packet.
Options:
·     1.
·     2.
Two stop bits might be required for communications with a slow device.
1
Flow Control
Select a flow control method to prevent data loss from buffer overflow.
Options:
·     NoneNo flow control is used.
·     Hardware RTS/CTSFlow control that uses the ready to send/clear to send (RTS/CTS) signal. When you select this option, make sure it is supported on the serial port.
If you enable hardware RTS/CTS on a serial port that does not support hardware flow control (such as a port that uses a USB-to-serial cable), or on a serial port with no cable connected, the following issues might occur:
·     Failure to load the option ROM of embedded and external PCIe modules.
·     Screen blackout.
·     Cursor flickering.
None
VT-UTF8 Combo Key Support
Select Enabled or Disabled to enable or disable VT-UTF8 combination key support for ANSI/VT100 terminals.
Enabled
Recorder Mode
Select Enabled or Disabled to enable or disable the recorder mode, which is used to capture terminal text data.
Disabled
Resolution 100×31
Select Enabled or Disabled to enable or disable enhanced terminal resolution (100 × 31).
Enabled
Putty KeyPad
Select a mode to change the action of the function keys and keypad in PuTTY.
Options:
·     VT100.
·     LINUX.
·     XTERMR6.
·     SCO.
·     ESCN.
·     VT400.
VT100
Console Redirection Settings submenu screen (EMS port)
Figure 45 shows a Console Redirection Settings submenu screen for the EMS port. The submenu items are described in Table 14.
Figure 45 Console Redirection Settings submenu screen (EMS port)
Table 14 Items on the Console Redirection Settings submenu screen (EMS port)
Item
Out-of-Band Management Port
Indicate the EMS port.
This port allows Microsoft Windows EMS to remotely access the Window OS to collect fault information.
N/A
Terminal Type
Options:
VT100+
Bits Per Second
Set the data transfer rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     57600.
·     115200.
This data transfer rate setting must match the setting on the remote terminal.
115200
Flow Control
Options:
·     Software Xon/Xoff—Flow control that uses the XON (transmit ON) and XOFF (transmit OFF) control characters. When the data transfer rate exceeds 1200 bits per second, the receiver sends an XOFF to have the sender stop transmission. The sender will resume the transmission only when it receives an XON from the receiver.
None
Data Bits
Options:
·     7.
·     8.
8
Parity
Options:
None
Stop Bits
Options:
·     1.
·     2.
1
Figure 46 shows the PCI Subsystem Settings submenu screen, on which you can configure PCI subsystem settings as described Table 15.
Figure 46 PCI Subsystem Settings submenu screen
Table 15 Items on the PCI Subsystem Settings submenu screen
Item
PCI Bus Driver Version
Displays the PCI bus driver version.
N/A
PCI Devices Common Settings
Above 4G Decoding
Select Enabled or Disabled to enable or disable decoding of 64-bit PCIe modules in a 4 GB or greater address space.
As a best practice, enable this option if the PCIe module has a 4 GB or higher-capacity VRAM. For example, disabling this option can cause an M60 or K80 GPU to get stuck in the EarlyPOST 100% phase, preventing you from accessing the BIOS setup menu or the OS.
Enabled
SR-IOV Support
Select Enabled or Disabled to enable or disable the support for PCIe single-root I/O virtualization (SR-IOV). SR-IOV virtualizes one physical PCIe module into multiple virtual PCIe modules, each of which can be bound to a virtual machine, thus allowing multiple accesses to the physical PCIe module.
With SR-IOV support enabled, the BIOS allocates I/O resources if a PCIe module supports SR-IOV. With SR-IOV support disabled, the OS allocates I/O resources if a PCIe module supports SR-IOV.
Enabled
BME DMA Mitigation
Select Enabled or Disabled to enable or disable DMA attack prevention.
With DMA attack prevention disabled, when PCI enumeration detects a PCI to PCI bridge, DMA will not be blocked, and you can still use the nvidia-smi command.
Disabled
Figure 47 shows the USB Configuration submenu screen, on which you can view connected USB devices and configure USB settings as described in Table 16.
Figure 47 USB Configuration submenu screen
Table 16 Items on the USB Configuration submenu screen
Item
USB Controllers
Displays the detected USB controllers.
The system supports eXtensible Host Controller (XHCI) controllers that support USB 3.0.
N/A
USB Devices
Displays the numbers of connected USB devices, including drives, keyboards, mice, and hubs.
The server has one embedded USB hub in addition to the connected USB hubs.
N/A
Legacy USB Support
Select whether to enable the support for legacy USB devices.
Options:
·     Enabled—Legacy USB support is always enabled.
·     Disabled—USB devices are available only for EFI applications.
·     Auto—The system automatically disables legacy USB support if no USB devices are connected.
Enabled
XHCI Hand-off
Select whether to enable the XHCI hand-off feature. This feature specifies the owner of the control over USB 3.0 ports.
Options:
·     Enabled—Hands off the control over USB 3.0 ports to the OS after the OS loads.
·     Disabled—BIOS controls USB 3.0 ports.
Enabled
USB Mass Storage Driver Support
Select Enabled or Disabled to enable or disable the support for USB mass storage drivers.
Enabled
Mass Storage Devices
Displays the installed mass storage devices.
N/A
Dual SD Card RAID LUN
This option is available only if a dual SD card expander module is installed with a minimum of one SD card.
When you manage SD cards, follow these guidelines:
·     The dual SD card expander module is not hot swappable. However, the SD cards are hot swappable.
·     For redundancy and storage use efficiency, install two SD cards of the same capacity on the SD card expander module.
·     If an SD card fails while the server is operating, replace that SD card directly, and then power cycle the server. This replacement procedure ensures that the server can restore the data on the new SD card. Data loss might occur if you replace the failed SD card after powering off the server.
N/A
ASUS SDR-08B1-U A A301
Indicates that an ASUS SDR-08B1-U A A301 USB drive is present.
N/A
Hp v220w 1100
Indicates that an HP v220w 1100 USB drive is present.
N/A
AMI Virtual HDisk0 1.00
Indicates that an AMI Virtual HDisk0 1.00 hard disk is present.
N/A
AMI Virtual CDROM0 1.00
Indicates that an AMI Virtual CDROM0 1.00 drive is present.
N/A
The configuration support module (CSM) provides UEFI compatibility with OSs that do not support UEFI boot mode.
Figure 48 shows the CSM Configuration submenu screen, on which you can configure CMS settings as described in Table 17.
Figure 48 CSM Configuration submenu screen
Table 17 Items on the CSM Configuration submenu screen
Item
CSM Support
Select Enabled or Disabled to enable or disable support for UEFI-incapable operating systems.
In legacy boot mode, the setting is always Enabled and cannot be changed.
Enabled
CSM16 Module Version
Displays the version of the CSM 16 module.
N/A
Option ROM Policy
Select the option ROM policy.
Options:
·     Auto—Enables the UEFI boot mode for UEFI option ROMs and legacy boot mode for legacy option ROMs.
·     Custom—Customizes a policy matching with the BIOS boot mode. As a best practice, uses the auto mode to prevent some option ROMs from failing to execute due to incorrect settings.
Auto
Network
Select the option ROM load method for Ethernet adapters.
This option is available when the option ROM policy is in custom mode.
Options:
·     UEFI—Loads the option ROM for Ethernet adapters in UEFI boot mode.
·     Legacy—Loads the option ROM for Ethernet adapters in legacy boot mode.
In UEFI boot mode: UEFI.
In legacy boot mode: Legacy.
Storage
Select the option ROM load method for storage devices.
Options:
·     UEFI—Loads the option ROM for storage devices in UEFI boot mode.
·     Legacy—Loads the option ROM for storage devices in legacy boot mode.
Video
Select the option ROM load method for video devices.
Options:
·     UEFI—Loads the option ROM for video cards in UEFI boot mode.
·     Legacy—Loads the option ROM for video cards in legacy boot mode.
Other PCI devices
Select the option ROM load method for other PCI devices such as input devices.
Options:
·     UEFI—Loads the option ROM for other PCI devices in UEFI boot mode.
·     Legacy—Loads the option ROM for other PCI devices in legacy boot mode.
Figure 49 shows the NVMe Configuration submenu screen, on which all installed NVMe devices without option ROM are displayed. You can select an NVMe device to view its information as shown in Table 18.
Figure 49 NVMe Configuration submenu screen
Table 18 Items on the NVMe Configuration submenu screen
Item
SwitchSlot 2 NvmeSlot 105: INTEL SSDPE7KX020T7
Open the submenu for the selected NVMe device.
The logical slot number of NVMe devices varies by server model. For more information, see Table 20.
Figure 50 NVMe Device Information submenu screen
Table 19 Items on the NVMe Device Information submenu screen
Item
Seg:Bus:Dev:Func
Displays the Seg:Bus:Dev:Func of the NVMe device.
Model Number
Displays the model number of the NVMe device.
Total Size
Displays the total size of the NVMe device.
Vendor ID
Displays the vendor ID of the NVMe device.
Device ID
Displays the device ID of the NVMe device.
Namespace
Displays the namespace of the NVMe device.
Table 20 Description about NVMe logical slot number
Server model
NVMe device type
Logical slot number
B5700
N/A
Slot 101 or Slot 102.
NVMe SSDs 0 and 1 are installed in slot 101 and slot 102, respectively.
B5800
N/A
Slot 106 to Slot 114.
The NVMe slot number in the BIOS is consistent with the number of NVMe connector in the server.
B7800
N/A
Slot 101 to Slot 104
E3200
N/A
Slot 1XY.
·     X—Number of the PCIe riser connector or PCIe slot. The value range is 1 to 5.
¡     1—PCIe riser connector 1 (for processors 1 and 2).
¡     2—PCIe riser connector 2 (for processors 1 and 2).
¡     3Reserved for future use.
¡     4—PCIe slot 4 (for processor 1).
¡     5—PCIe slot 5 (for processor 1).
·     YNumber of the NVMe connector. The value range is 1 to 8.
For example, Slot 151.
R2700
R2900
R4700
R4900
4-port NVMe SSD expander module
Slot 1XY.
·     X—Number of the PCIe slot that holds the NVMe SSD.
·     YNumber of the NVMe connector. The value range is 0 to 3.
For example, Slot 123.
8-port NVMe SSD expander module
SwitchSlot X NvmeSlot 10Y.
·     YNumber of the NVMe connector. The value range is 0 to 7.
For example, SwitchSlot 2 NvmeSlot 105.
R4300
N/A
Slot 10X.
X represents the number of NVMe connector. The value range is 0 to 5.
For example, Slot 100.
R5300
N/A
Slot 20X.
·     For the 12LFF server, the value range is 0 to 3.
·     For the 24LFF server that supports eight NVMe SSDs, the value range is 0 to 7.
·     For the 24LFF server that supports four NVMe SSDs, the value range is 4 to 7.
For example, Slot 203.
R6700
N/A
Slot 2XY.
·     X—Number of the PCIe riser connector that is used to access the system.
¡     0—PCIe riser connector 1.
¡     1—PCIe riser connector 2.
R6900
Slot 1XY.
·     X—Number of the compute module where the SSD resides.
¡     6Compute module 1.
¡     7Compute module 2.
For example, Slot 163.
SwitchSlot X NvmeSlot 15Y.
¡     111Compute module 1.
¡     121Compute module 2.
For example, SwitchSlot 111 NvmeSlot 153.
R8900
NVMe SSD
Slot 2XY.
·     X—Number of the node used to access the system. The value range is 1 to 4.
·     YNumber of NVMe connector. The value range is 0 to 7.
For example, Slot 247.
PCIe M.2 SSD
Slot XY.
·     X—Number of the PCIe slot.
¡     2—PCIe slot 2.
¡     5—PCIe slot 5.
·     Y—Number of the M.2 transfer module.
¡     8—M.2 transfer module 1.
¡     9—M.2 transfer module 2.
For example, Slot 28.
Intelligent Memory Surveillance (IMS) provides a set of memory management functions, including memory error detection, memory diagnosis, and memory failure isolation and failure. It reduces memory waste, helps memory troubleshooting, and avoids server failure caused by memory failure.
Figure 51 shows the iMS Configuration submenu screen, on which you can configure IMS. The submenu items are described in Table 21.
Figure 51 iMS Configuration submenu screen
Table 21 Items on the iMS Configuration submenu screen
Item
VERSION FOR TESTING
iMS Module Version
Displays the version of the IMS module.
N/A
iMS Module Build Date
Displays the build date of the IMS module.
N/A
iMS Support
Select Enabled or Disabled to enable or disable support for IMS.
IMS detects and prevents memory failures in real time after the system starts.
Enabled
Run iMS Memory Diagnostic
Run an IMS memory diagnostic test.
If the Intel DCPMMs are in 2LM mode, you do not need to run a diagnostic test.
N/A
iMS Log Information
Defect Entries
Displays the number of log entries about detefected DIMMs, in pages.
N/A
Protected Memory
Protected memory capacity, in MB.
N/A
No. Defect Dimms
Displays the defected DIMMs.
N/A
Figure 52 shows the IMS Memory Diagnostic submenu screen, on which you can run a diagnostic test. Once the test finishes, press any key to reboot the server.
Figure 52 IMS Memory Diagnostic submenu screen
Table 22 Items on the IMS Memory Diagnostic submenu screen
Item
Test mode
Select a test mode or press ESC to exit the screen.
Options:
·     QuickEnter 1 to run a quick memory diagnostic test.
·     StandardEnter 2 to run a standard memory diagnostic test.
·     ExtensiveEnter 3 to run an extensive memory diagnostic test.
Network PXE control is not supported on the B5700, B5800, B7800, or R8900 server.
Figure 53 shows the Network PXE Control submenu screen, on which all Ethernet adapters are displayed. Each Ethernet adapter is identified by its PCIe slot number and type.
Figure 53 PCIe slot selection screen
Figure 54 shows the submenu for configuring PXE on an Ethernet adapter. The submenu items are described in Table 23.
Figure 54 Network PXE Control submenu screen
ipv2
Table 23 Items on the PXE Control submenu screen
Item
Network Function
Select Enabled or Disabled to enable or disable the Ethernet adapter.
If Disabled is selected, the Ethernet adapter cannot be used in the OS and the PXE function is not available.
Enabled
Port X
Displays the port number of the Ethernet adapter, which starts from 0.
This option is available when the network function is enabled.
N/A
IPv4 PXE
Select Enabled or Disabled to enable or disable the IPv4 PXE control of the Ethernet adapter.
Enabled
IPv6 PXE
Select Enabled or Disabled to enable or disable the IPv6 PXE control of the Ethernet adapter.
Enabled
Figure 55 shows the Network Stack Configuration submenu screen, on which you can configure PXE boot settings as described in Table 24.
Figure 55 Network Stack Configuration submenu screen
Table 24 Items on the Network Stack Configuration submenu screen
Item
IPv4 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv4 network.
If Disabled is selected, the IPv4 PXE boot option will not be created.
Enabled
IPv6 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv6 network.
If Disabled is selected, the IPv6 PXE boot option will not be created.
Disabled
PXE boot wait time
Set the wait time to press ESC key to abort the PXE boot:
Value range: 0 to 5, in seconds.
0
Media detect count
Set the maximum number of media presence detections.
Value range: 1 to 50.
1
PXE Retry Count
Set the maximum number of PXE retries.
Value range: 0 to 50.
A value of 0 indicates that the number of PXE retries is not limited.
1
CLP Command Feature Support
Select Enabled or Disabled to enable or disable the support for CLP commands. You can use CLP commands to modify the Ethernet adapter configuration in an out-of-band way to implement Ethernet adapter virtualization.
This option is available only in H3C UniServer B5700, B5800, and B7800 G3 blade servers.
Enabled
Figure 56 shows the iSCSI Configuration submenu screen, on which you can configure iSCSI settings as described in Table 25.
Figure 56 iSCSI Configuration submenu screen
Table 25 Items on the iSCSI Configuration submenu screen
Item
Set the name of the iSCSI initiator. The name is a string of 4 to 223 characters.
The name must be in the IQN format of iqn.YYYY-MM.Domain name:Device name.
·     YYYY—Year.
·     MM—Month.
·     Domain name—Domain name in the reversed order.
·     Device name.
For example, iqn.2003-02.emu.com:test123.
Add an Attempt
Add an iSCSI attempt.
Delete Attempts
Delete an iSCSI attempt.
Change Attempt Order
Change the order of the attempts.
Add an Attempt submenu screen
Figure 57 shows the Add an Attempt submenu screen, on which all existing attempts are displayed. Each attempt is identified by the MAC address of an iSCSI Ethernet adapter port. The submenu items for each port are the same.
Figure 57 Add an Attempt submenu screen
Figure 58 shows the submenu for configuring an attempt. The submenu items are described in Table 26.
Figure 58 Attempt Configuration submenu screen
Table 26 Items on the Attempt Configuration submenu screen
Item
iSCSI Attempt Name
Set the name of the iSCSI attempt. The name is a case-sensitive string of 1 to 12 characters.
N/A
iSCSI Mode
Set the iSCSI mode.
Options:
·     Disabled—Disables iSCSI.
·     Enabled—Enables iSCSI.
·     Enabled for MPIO—Enables MPIO iSCSI.
Disabled
Internet Protocol
Select the Internet protocol.
Options:
·     IP4—Enables IPv4.
·     IP6—Enables IPv6.
·     Autoconfigure—Configures the Internet protocol automatically. IPv4 takes precedence over IPv6.
IP4
Connection Retry Count
Set the maximum number of connection retries.
Value range: 0 to 16.
A value of 0 indicates no connection retries.
N/A
Connection Establishing Timeout
Set the connection timeout time, in milliseconds.
1000
OUT-format ISID
Displays the ID of the iSCSI initiator.
N/A
Configure ISID
Configure the ID of the iSCSI initiator.
The last six digits of the MAC address of the Ethernet adapter port.
Enable DHCP
Select Enabled or Disabled to enable or disable DHCP.
Disabled
Initiator IP Address
Set the IP address of the iSCSI initiator.
N/A
Set the subnet mask of the iSCSI initiator.
N/A
Gateway
Set the gateway IP address.
N/A
Target Name
Set the name of the iSCSI target.
N/A
Target Address
N/A
Target Port
Set the port number of the iSCSI target.
3260
Boot LUN
Set the LUN of the iSCSI target, in hexadecimal notation.
N/A
Authentication Type
Select the authentication type.
Options:
·     None.
·     CHAP.
None
CHAP Type
Select the CHAP authentication type.
Options:
·     Mutual—The iSCSI target and iSCSI initiator authenticate each other.
·     One way—Only the iSCSI target authenticates the iSCSI initiator.
Mutual
CHAP Name
Set the name for CHAP authentication.
N/A
CHAP Secret
Set the password for CHAP authentication.
N/A
CHAP Status
Displays the status of CHAP authentication.
N/A
Reverse CHAP Name
Set the name for reverse CHAP authentication.
N/A
Reverse CHAP Secret
Set the password for reverse CHAP authentication.
N/A
Reverse CHAP Status
Displays the status of reverse CHAP authentication.
N/A
Save Changes
Save the changes.
N/A
Return to the previous submenu.
N/A
Delete Attempts submenu screen
Figure 59 shows the Delete Attempts submenu screen. The items are described in Table 27.
Figure 59 Delete Attempts submenu screen
Table 27 Items on the Delete Attempts submenu screen
Item
Attempt x
Select the target attempts to delete.
Commit Changes and Exit
Commit the changes and return to the iSCSI Configuration submenu.
Discard the changes and return to the iSCSI Configuration submenu.
Change Attempt Order submenu screen
Figure 60 shows the Change Attempt Order submenu screen. The items are described in Table 28.
Figure 60 Change Attempt Order submenu screen
Table 28 Items on the Change Attempt Order submenu screen
Item
Change the order of existing attempts.
Select an attempt and press + or key to change its order.
The submenus of Intel(R) VROC sSATA controller and Intel(R) VROC SATA controller are available only when the RAID mode is used in the PCH settings.
The submenu screens of Intel(R) VROC sSATA controller and Intel(R) VROC SATA controller are the same. The following uses the submenu screen of Intel(R) VROC sSATA controller for example.
Figure 61 shows the Intel(R) VROC sSATA Controller submenu screen. The submenu items are described in Table 29.
Figure 61 Submenu screen of Intel(R) VROC sSATA controller
Table 29 Items on the submenu screen of Intel(R) VROC sSATA controller
Item
Create RAID Volume
Open the submenu for creating a RAID volume.
This option is available only when more than two SATA or sSATA drives are connected to the port that is managed by the SATA or sSATA controller.
RAID Volumes
Displays the list of the created RAID volumes.
Volume0,RAID0(Stripe),424.77GB,Normal
Displays summary information about managed RAID volumes, including their volume name, RAID level, capacity, and state, for example, Volume0, RAID0 (Stripe), 424.77GB, Normal.
Non-RAID Physical Disks
Displays the list of the physical drives that have not been used to build RAID volumes.
Port 0,INTEL SSDSC2BB480G7 SN:PHDV702001YJ480BGN,447.14GB
Displays the information about the non-RAID physical drives, including port number, physical drive name, serial number, and size.
Create RAID Volume submenu screen
Figure 62 shows the Create RAID Volume submenu screen. The submenu items are described in Table 30.
Figure 62 Create RAID Volume submenu screen
Table 30 Items on the Create RAID Volume submenu screen
Item
Create RAID volume
Name
Enter the name of the RAID volume.
Make sure the name does not contain backslashes (\) or spaces.
N/A
RAID Level
Select a RAID level.
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity)This option is available only when a minimum of three drives are present.
·     RAID10(RAID0+1)This option is available only when a minimum of four drives are present.
RAID0(Stripe)
Select Disks
All available drives, for example:
Select drives over which you want to create the RAID volume.
The selected drive is represented by the symbol X.
No drives are selected to configure RAID.
Stripe Size
Set the stripe size of the RAID volume, in KB.
Options:
·     4KB.
·     8KB.
·     16KB.
·     32KB.
·     64KB.
·     128KB.
128KB
Capacity(GB)
Displays the total capacity of the RAID volume, in GB.
N/A
Create Volume
Create a RAID volume.
To view information about the configured RAID volumes, select All Intel VMD Controllers.
N/A
RAID VOLUME INFO submenu screen
Figure 63 shows the RAID VOLUME INFO submenu screen. The submenu items are described in Table 31.
Figure 63 RAID VOLUME INFO submenu screen
Table 31 Items on the RAID VOLUME INFO submenu screen
Item
Volume Actions
Delete
CAUTION CAUTION:
All data in the member drives of the volume are permanently deleted when the volume is deleted. As a best practice to avoid data loss, back up the data before you delete a volume.
To delete the RAID volume, select this item, and then select Yes to confirm the deletion, as shown in Figure 64.
Name
Displays the name of the RAID volume.
RAID Level
Displays the RAID level.
Strip Size
Displays the stripe size of the RAID volume.
Size
Displays the capacity of the RAID volume.
Status
Displays the state of the RAID volume.
Bootable
Displays whether the RAID volume is bootable.
Block Size
Displays the block size of the RAID volume, in bytes.
RAID Member Disks
Member drives of the RAID, for example, Port 1,INTEL SSDSC2BB012T7 SN:PHDV641300NT1P2DGN,1117.81GB
To manage a member drive or view its detailed information, select that drive and the RAID member drive management submenu opens.
Delete Confirm submenu screen
Figure 64 shows the Delete Confirm submenu screen.
Figure 64 Delete Confirm submenu screen
PHYSICAL DISK INFO submenu screen
Figure 65 shows the PHYSICAL DISK INFO submenu screen. The submenu items are described in Table 32.
Figure 65 PHYSICAL DISK INFO submenu screen
Table 32 Items on the PHYSICAL DISK INFO submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
This action deletes all data on the drive. As a best practice to avoid data loss, back up the data before you perform this action.
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 66.
Turn Locate LED On/Off
Turn on or turn off the locate LED.
Controller
Displays the drive controller information, which is sSATA in this example.
Model Number
Displays the model number of the drive.
Serial Number
Displays the serial number of the drive.
Size
Displays the capacity of the drive.
Status
Displays whether the drive is a RAID member.
Block Size
Displays the block size of the drive, in bytes.
Reset to non-RAID submenu screen
Figure 66 shows the Reset to non-RAID submenu screen.
Figure 66 Reset to non-RAID submenu screen
Non-RAID Physical Disk submenu screen
Figure 67 shows the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. On the screen, you can view information about the drive and set the drive as a spare or journaling drive, as described in Table 33.
Figure 67 Non-RAID Physical Disk submenu screen
Table 33 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
Setting a drive as a spare drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action, as shown in Figure 68.
A spare drive cannot be used to build a RAID volume.
Mark as Journaling Drive
CAUTION CAUTION:
Setting a drive as a journaling drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a journaling drive, select this item, and then select Yes to confirm the action, as shown in Figure 69.
A journaling drive cannot be used to build a RAID volume.
Port
Displays the port number of the drive.
Controller
Displays drive controller information, which is sSATA in this example.
Model Number
Serial Number
Size
Status
Block Size
Mark as Spare submenu screen
Figure 68 shows the Mark as Spare submenu screen.
Figure 68 Mark as Spare submenu screen
Mark as Journaling Drive submenu screen
Figure 69 shows the Mark as Journaling Drive submenu screen.
Figure 69 Mark as Journaling Drive submenu screen
Intel® Virtual RAID on CPU (Intel VROC) is a RAID solution specifically designed for NVMe-based SSDs.
If the VMD is disabled, the information about the NVMe SSDs with or without option ROM loaded will be displayed in Slot x:Port x submenu or NVMe Configuration submenu, respectively.
Prerequisites for using Intel VROC
Before using Intel VROC for RAID volume management on a CPU that has NVMe SSDs attached, use the following procedure to enable Intel Volume Management Device (VMD) for that CPU:
1.     Install an Intel NVMe VROC module. The system supports the following NVMe VROC modules:
¡     Intel® VROC StandardSupports RAID levels 0, 1, and 10.
¡     Intel® VROC PremiumSupports RAID levels 0, 1, 5, and 10.
¡     Intel® VROC Intel® SSD OnlySupports RAID levels 0, 1, 5, and 10 and only Intel NVMe SSDs.
2.     Enable Intel Volume Management Device (VMD) for that CPU:
a.     Select Socket Configuration > IIO Configuration > Intel® VMD technology, and then enable VMD settings. For more information, see IIO Configuration menu.
b.     After setting VMD successfully, select Advanced > Intel(R) virtual RAID on CPU, and then press Enter. Table 34 shows the Intel(R) virtual RAID on CPU submenu screen. The submenu items are described in Table 35.
Table 34 Intel(R) virtual RAID on CPU submenu screen
Table 35 Items on the Intel(R) Virtual RAID on CPU submenu screen
Item
Intel VROC Managed Volumes
Displays summary information about managed RAID volumes, including their volume name, RAID level, capacity, and state, for example, Volume0, RAID0 (Stripe), 1769.86GB, Normal.
To view detailed information about a volume or manage its member drives, select that volume. The RAID volume management submenu opens, as shown in Figure 70. For more information about the submenu items, see Table 36.
Intel VROC Managed Controllers
To view information about Intel VROC managed VMD controllers and use a controller to create and configure a RAID volume, select All Intel VMD Controllers. The all Intel VMD controllers submenu opens, as shown in Figure 74. For more information about the submenu items, see Table 38.
Submenu for configuring RAID.
RAID Volume Management submenu screen
Figure 70 shows the RAID Volume Management submenu screen. The submenu items are described in Table 36.
Figure 70 RAID Volume Management submenu screen
Table 36 Items on the RAID Volume Management submenu screen
Item
Volume Actions
Delete
CAUTION CAUTION:
To delete the RAID volume, select this item, and then select Yes to confirm the deletion, as shown in Figure 71.
Name
RAID Level
Strip Size
Size
Status
Bootable
Block Size
RAID Member Disks
Member drives of the RAID, for example:
·     INTEL SSDPE2KX010T7 SN:PHLF721402JH1P0LGN 931.51GB Port 1:0,Slot 104,CPU0,VMD0,BDF 07:00.0
·     INTEL SSDPE7KX020T7 SN:PHLF7330003S2P0LGN 1863.02GB Port 1:0,Slot 105,CPU0,VMD0,BDF 08:00.0
To manage a member drive or view its detailed information, select that drive. The RAID member drive management submenu opens, as shown in Figure 72. For more information about the submenu items, see Table 37.
The port ID depends on the installed NVMe SSD expander module and its installation location. For more information, see Table 20.
Delete Confirm screen
Figure 71 shows the Delete Confirm screen.
Figure 71 Delete Confirm screen
RAID Member Drive Management submenu screen
Figure 72 shows the RAID Member Drive Management submenu screen. The submenu items are described in Table 37.
Figure 72 RAID Member Drive Management submenu screen
Table 37 Items on the RAID Member Drive Management submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 73.
Controller
Displays the controller information, which is Volume Management Device Controller in this example.
Model Number
Serial Number
Size
Status
Block Size
Root Port Number
Displays the root port number of the drive.
Root Port Offset
Displays the root port offset of the drive.
Slot Number
Displays the slot number of the drive.
Socket Number
Displays the slot number of the processor for the drive.
VMD Controller Number
Displays controller information.
PCI Bus:Device.Function
Displays the Bus:Dev.Func of the drive.
Reset to non-RAID screen
Figure 73 shows the Reset to non-RAID screen.
Figure 73 Reset to non-RAID screen
All Intel VMD Controllers submenu screen
Figure 74 shows the All Intel VMD Controllers submenu screen. The submenu items are described in Table 38.
Figure 74 All Intel VMD Controllers submenu screen
Table 38 Items on the All Intel VMD Controllers submenu screen
Item
Create RAID Volume
To create a RAID volume, select this item to access the Create RAID Volume screen shown in Figure 75, and then create the RAID volume as described in Table 39.
Drives that are not in a RAID volume, for example:
Displays physical drives that are available for creating a RAID volume.
To view information about a non-RAID physical drive or set that drive as a spare or journal drive, select that drive to access the non-RAID physical drive submenu shown in Figure 76. For more information about the submenu items, see Table 40.
Figure 75 shows the Create RAID Volume submenu screen. The submenu items are described in Table 39.
Figure 75 Create RAID Volume submenu screen
Table 39 Items on the Create RAID Volume submenu screen
Item
Name
Make sure the name does not contain special characters.
N/A
RAID Level
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity).
·     RAID10(RAID0+1).
RAID0(Stripe)
Enable RAID spanned over VMD Controllers
To build a RAID volume over physical drives controlled by different VMD controllers, select this item.
N/A
Select Disks
If a drive is selected, symbol X is displayed.
Stripe Size
Set the stripe size of the RAID volume.
N/A
Capacity (GB)
Displays the total capacity of the RAID volume.
N/A
Create Volume
Select Create Volume and press Enter to create the RAID volume.
To verify that the volume is correctly created, examine the RAID Volumes section on the all Intel VMD controllers submenu screen, as shown in Figure 74.
N/A
Figure 76 shows the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. On the screen, you can view information about the drive and set the drive as a spare or journaling drive, as described in Table 40.
Figure 76 Non-RAID Physical Disk submenu screen
Table 40 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action, as shown in Figure 77.
Controller
Model Number
Serial Number
Size
Status
Block Size
Displays the block size of the drive.
Root Port Number
Root Port Offset
Slot Number
Socket Number
Mark as Spare screen
Figure 77 shows the Mark as Spare screen.
Figure 77 Mark as Spare screen
Ethernet interfaces, storage controllers, and NVMe drives that have an Option ROM are displayed on the Advanced screen as Slot x:Port x entries, as shown in Figure 78. For Ethernet interfaces, Slot x represent the slot number of the Ethernet adapter that contains the interface and Port x represents the port index of the interface on the Ethernet adapter.
The Slot x:Port x submenu screen is generated by the option ROM of a PCIe module and the items on the screen vary by vendor. This section uses the Slot 3-mLOM:Port 1 entry for the mLOM Ethernet adapter as an example. Figure 79 shows the Ethernet Adapter Configuration submenu screen of the Slot 3-mLOM:Port 1 entry. The submenu items are described in Table 41.
Figure 78 Slot x:Port x submenu screen
Figure 79 Slot x:Port x entry submenu screen
Table 41 Items on the Ethernet Adapter Configuration submenu screen
Item
NIC Configuration
Open the Ethernet adapter port configuration submenu, as shown in Figure 80.
N/A
Blink LEDs
Set the number of seconds for which the port connection status LED keeps blinking.
Value range: 0 to 15.
0
UEFI Driver
Displays the UEFI driver name.
N/A
Adapter PBA
Displays the network adapter PBA number.
N/A
Device Name
Displays the name of the embedded Ethernet adapter.
N/A
Chip Type
Displays the chip type of the Ethernet adapter.
N/A
PCI Device ID
Displays the ID of the PCI device.
N/A
PCI Address
Displays the address of the PCI device.
N/A
Link Status
Displays the link status.
Options:
·     Disconnected.
·     Connected.
N/A
MAC Address
Displays the MAC address of the embedded Ethernet adapter.
N/A
Virtual MAC Address
Displays the virtual MAC address of the embedded Ethernet adapter.
N/A
Figure 80 shows the Ethernet Adapter Port Configuration screen, on which you can configure the link speed and Wake On LAN for the Ethernet interface as described in Table 42.
Figure 80 Ethernet Adapter Port Configuration screen (Slot 3-mLom : Port 1)
Table 42 Items on the Ethernet Adapter Port Configuration submenu screen
Item
Link Speed
Set the link speed.
The setting is fixed at Auto Negotiated, which is not user configurable.
N/A
Wake On LAN
Select Enabled or Disabled to enable or disable waking up the system from a low power mode remotely. If this option is enabled, the server is woke up when it receives an out-of-band magic packet.
Enabled
Intel(R) Optane(TM) DC Persistent Memory Configuration submenu
Figure 81 shows the Intel(R) Optane(TM) DC Persistent Memory Configuration submenu screen, on which you can view and configure Intel DCPMMs installed in the server. For more information about the submenu items, see Table 43. If no Intel DCPMMs are installed, this submenu is unavailable.
Figure 81 Intel(R) Optane(TM) DC Persistent Memory Configuration submenu screen
Table 43 Items on the Intel(R) Optane(TM) DC Persistent Memory Configuration submenu screen
Item
Detected DIMMs
Displays the number of Intel DCPMMs.
DIMMs
Submenu for configuring Intel DCPMMs.
Regions
Submenu for configuring regions.
Namespaces
Submenu for configuring namespaces.
Total capacity
Submenu for displaying the total capacity.
Diagnostics
Submenu for configuring diagnostic tests.
Preferences
Submenu for configuring preferences.
DIMMs submenu screen
Figure 82 shows the DIMMs submenu screen on which you can view and configure the installed Intel DCPMMs. The submenu items are described in Table 44.
Figure 82 DIMMs submenu screen
Table 44 Items on the DIMMs submenu screen
Item
DIMM ID
Submenu for configuring an Intel DCPMM identified by its DCPMM ID.
Monitor health
Submenu for configuring sensors.
Update firmware
Submenu for updating the firmware.
Configure security
Submenu for configuring security settings.
Configure data policy
Submenu for configuring the data policy.
Back to main menu
Return to the Intel(R) Optane(TM) DC Persistent Memory Configuration submenu.
Figure 83, Figure 84, Figure 85, Figure 86, and Figure 87 show the DIMM Configuration submenu screen, on which you can view and configure an Intel DCPMM. The submenu items are described in Table 45.
Figure 83 DIMM Configuration submenu screen (1)
Figure 84 DIMM Configuration submenu screen (2)
Figure 85 DIMM Configuration submenu screen (3)
Figure 86 DIMM Configuration submenu screen (4)
Figure 87 DIMM Configuration submenu screen (5)
Table 45 Items on the DIMM Configuration submenu screen
Item
DIMM UID
Displays the unique ID of the Intel DCPMM.
Typically, the ID is in the VVVV-ML-MDMD-SNSNSNSN format. If the manufacturing information is unavailable, it is in the VVVV-SNSNSNSN format.
·     VVVV—Vendor ID.
·     ML—Manufacturing location.
·     MDMD—Manufacturing date.
·     SNSNSNSN—Serial number.
N/A
DIMM handle
Displays the Intel DCPMM handle, which is defined by ACPI.
N/A
DIMM physical ID
Displays the Intel DCPMM physical ID, in hexadecimal notation.
N/A
Manageability state
Displays the Intel DCPMM state.
Options:
·     Manageable—The Intel DCPMM can be managed by the BIOS.
·     Unmanageable—The Intel DCPMM cannot be managed by the BIOS of the current version.
N/A
Health state
Displays the Intel DCPMM health status.
Options:
·     Healthy.
·     Minor failure.
·     Critical failure.
·     Non-recoverable error.
·     Unknown.
·     Unmanageable.
N/A
Health state reason
Displays the reason why the Intel DCPMM is not healthy.
This option displays None if the Intel DCPMM is healthy.
N/A
Capacity
Displays the Intel DCPMM capacity.
N/A
Firmware version
Displays the firmware version, in the format of PN.RN.SV.bbbb:
·     PN—2-digit product number.
·     RN—2-digit revision number.
·     SV—2-digit security revision number.
·     bbbb—4-digit build version.
N/A
Firmware API version
Displays the firmware API version.
N/A
Lock state
Displays the current security state of the persistent memory on the Intel DCPMM.
Options:
·     UnknownThe security state cannot be obtained. For example, the Intel DCPMM cannot be managed by the BIOS.
·     Disabled—Security is disabled.
·     Unlocked—Security is enabled and unlocked.
·     Locked—Security is enabled and locked.
·     FrozenSecurity can be enabled and unlocked, or disabled. A reboot is required for the state change to take effect.
·     ExceededThe password limit has been reached. A power cycle is required to change the state.
·     Not supported—Security is not supported.
N/A
Staged firmware version
Displays the firmware version of each stage.
N/A
Firmware update status
Displays the state of the most recent firmware update operation.
N/A
Manufacturer
Displays the manufacturer of the Intel DCPMM.
N/A
Show more details+
Select Enabled or Disabled to display or hide detailed Intel DCPMM information.
N/A
Monitor health
This option is inaccessible if the manageability state is Unmanageable.
N/A
Update firmware
N/A
Configure security
Submenu for configuring the security settings.
N/A
N/A
Back to main menu
N/A
Intel DCPMM detailed information
(The following items are available only when the Show more details + option is set to Enabled.)
Serial number
Displays the serial number, in hexadecimal notation.
N/A
Part number
Displays the part number assigned by the vendor.
N/A
Socket
Displays the socket number of the processor to which the Intel DCPMM belongs. The socket number is in hexadecimal notation.
N/A
Memory controller ID
Displays the memory controller ID, in hexadecimal notation.
N/A
Vendor ID
Displays the vendor ID, in hexadecimal notation.
N/A
Device ID
Displays the device ID, in hexadecimal notation.
N/A
Subsystem vendor ID
Displays the vendor ID of the non-volatile memory subsystem controller, in hexadecimal notation.
N/A
Subsystem device ID
Displays the device ID of the non-volatile memory subsystem controller, in hexadecimal notation.
N/A
Device locator
Displays the device location, in the format of processor_number-channel_number-DIMM_slot_number.
N/A
Subsystem revision ID
Displays the revision ID of the non-volatile memory subsystem controller, in hexadecimal notation.
N/A
Interface format code
Displays the code for the DCMPP type, in hexadecimal notation.
N/A
Manufacturing info valid
Identifies the validity of the manufacturing location and date.
Options:
·     0—Invalid.
·     1—Valid.
N/A
Manufacturing date
Displays the manufacturing date, in hexadecimal notation.
This option displays N/A if the value of Manufacturing info valid is 0.
N/A
Displays the manufacturing location, in hexadecimal notation.
N/A
Memory type
Displays the type of the memory, which is Logical Non-Volatile Device in this example.
N/A
Memory bank label
Displays the physically labeled bank where the memory device resides.
N/A
Data width label
Displays the width used to store user data, in bits.
N/A
Total width
Displays the total width used for data and error correction and data redundancy, in bits.
N/A
Speed
Displays the maximum frequency of the Intel DCPMM.
N/A
Channel ID
Displays the channel ID.
N/A
Channel position
Displays the channel position.
N/A
Revision ID
Displays the revision ID.
N/A
Form factor
Displays the form factor.
Options:
·     DIMM.
·     SODIMM.
·     Unknown.
N/A
Manufacturer ID
Displays the manufacturer ID.
N/A
Controller revision ID
Displays the controller revision ID.
N/A
Is new
Displays whether the Intel DCPMM is configured to incorporate with the other Intel DCPMMs in the system.
Options:
·     0Yes.
·     1No.
N/A
Memory capacity
Displays the Intel DCPMM capacity configured for use in memory mode.
N/A
App Direct capacity
Displays the Intel DCPMM capacity configured for use in App Direct mode.
N/A
Unconfigured capacity
Displays the capacity of Intel DCPMMs that cannot be accessed because the capacity is not mapped into the system physical address space.
N/A
Inaccessible capacity
Displays the capacity of Intel DCPMMs that cannot be accessed because of a licensing issue.
N/A
Reserved capacity
Displays the Intel DCPMM capacity reserved for proper alignment of the memory mode capacity.
N/A
Peak power budget [mW]
Displays the instantaneous power budget when the Intel DCPMM firmware power management policy is enabled.
Value range: 10000 to 20000, in mW.
10000
Avg power budget [mW]
Displays the average power budget when the Intel DCPMM firmware power management policy is enabled.
Value range: 10000 to 18000, in mW.
10000
Max average power budget [mW]
Displays the maximum average power budget.
N/A
Package sparing capable
Select 0 or 1 to disable or enable support for the package sparing policy.
N/A
Package sparing enabled
Select 0 or 1 to disable or enable package sparing policy.
N/A
Package spares available
Displays the number of spare devices available for package sparing.
N/A
Configuration status
Displays the configuration state of the Intel DCPMM.
Options:
·     Valid—The configuration is valid.
·     Not configured—The Intel DCPMM has not been configured.
·     Failed - bad configuration—The configuration is corrupted.
·     Failed- broken interleave—The Intel DCPMM is part of an interleave set that is not complete.
·     Failed – reverted—The configuration failed and was restored to the most recent known correct configuration.
·     Failed – unsupported—The configuration is incompatible with the installed BIOS.
N/A
SKU violation
Displays whether the Intel DCPMM configuration is supported in case of a licensing issue.
Options:
·     0—Not supported.
·     1—Supported.
N/A
ARS status
Displays the Address Range Scrub (ARS) operation state.
Options:
·     Unknown—The ARS operation state cannot be determined.
·     Not startedNo ARS operation was run at the most recent boot.
·     In progress—An ARS operation is in progress.
·     CompletedThe ARS operation finished at the most recent boot.
·     AbortedThe ARS operation was aborted at the most recent boot.
N/A
Overwrite DIMM status
Displays the Intel DCPMM overwrite operation state.
Options:
·     Unknown—The overwrite operation state cannot be determined.
·     Not startedNo overwrite operation was run at the most recent boot.
·     In progress—An overwrite operation is in progress.
·     CompletedThe overwrite operation finished and a reboot is required to use the Intel DCPMM.
N/A
Last shutdown time
Displays the time for the most recent system shutdown.
N/A
First fast refresh
Select 0 or 1 to disable or enable the acceleration of the first refresh cycle for the Intel DCPMM.
Before starting the benchmark test, you must wait for a pre-determined time (5 to 6 minutes).
N/A
Viral policy enable
Select 0 or 1 to disable or enable the viral policy.
If the host operating system software detects an uncorrectable error situation and indicates the viral state, the persistent memory enters into the read-only mode to prevent the spread of the damage.
N/A
Viral state
Displays whether the memory is currently viral.
Options:
·     0—Not viral.
·     1—Viral.
N/A
Latched Last shutdown status
Displays the most recent latched shutdown state of the Intel DCPMM.
Options:
·     Unknown—The most recent shutdown state cannot be determined.
·     FW Flush Complete—Firmware flush finished.
·     PM ADR Command—Power management ADR command received.
·     PM S3—Power management S3 command received.
·     PM S5—Power management S5 command received.
·     DDRT Power Fail Command—DDR power fail command received.
·     PMIC 12V/DDRT 1.2V Power Loss (PLI)—PMIC power loss.
·     PM Warm Reset—Power management warm reset received.
·     Thermal Shutdown—Thermal shutdown triggered.
·     Controller’s FW Statue Flush Complete—Flush finished.
·     Viral Interrupt—Viral interrupt received.
·     Surprise Clock Stop—Surprise clock stop received.
·     Write Data Flush Complete—Write data flush finished.
·     PM S4—Power management S4 command received.
·     PM Idle—Power management idle received.
·     DDRT Surprise Reset—Surprise reset received.
N/A
Unlatched last shutdown status
Displays the most recent unlatched shutdown state of the Intel DCPMM.
Options:
·     PMIC 12V/DDRT 1.2V Power Loss (PLI)—PMIC power lost.
N/A
Security capabilities
Displays the security features supported by the Intel DCPMM.
Options:
·     None—The Intel DCPMM does not support any security features.
·     Encryption—The Intel DCPMM supports persistent memory encryption through password setting.
·     Erase—The Intel DCPMM is erasable.
N/A
Modes supported
Displays a list of modes supported by the Intel DCPMM.
Options:
·     Memory Mode—Intel DCPMMs act as system memory under the control of the OS and all DDR in the platform act as a cache working in conjunction with the Intel DCPMMs.
·     App DirectIntel DCPMMs and DDR act as independent memory resources under direct load/store control of the application.
N/A
Boot status
Displays the initialization state of the Intel DCPMM reported by the firmware in the boot status register.
Options:
·     Unknown—The boot status register cannot be read.
·     Success—No errors were reported during initialization.
The following states indicate that the media is unavailable and therefore access to user data and operations that require use of the media will fail:
·     Media not ready—The firmware failed to complete media training.
·     Media error—The firmware detected an error during media training.
·     Media disabled—The firmware disabled the media due to a critical issue.
The following states indicate that the firmware cannot be reached:
·     DDRT not ready—The DDRT interface was not initialized properly.
·     FW Assert—The firmware reported an assert during initialization.
·     Mailbox not ready—The firmware was unable to initialize a communication interface.
N/A
AIT DRAM enabled
Selelct 0 or 1 to disable or enable the Intel DCPMM AIT DRAM.
Disabling AIT DRAM will degrade memory performance.
N/A
Error injection enabled
Selelct 0 or 1 to disable or enable error injection.
Disabled
Media temperature injection enabled
Selelct 0 or 1 to disable or enable media temperature injection.
Disabled
Software trigger enabled
Select 0 or 1 to disable or enable software trigger.
Disabled
Poison error injections counter
Display the count of poison error injections.
This counter is incremented each time the set poison error command is successfully executed.
N/A
Poison error clear counter
Display the count of poison error clearances.
This counter is incremented each time the clear poison error command is successfully executed.
N/A
Media temperature injections counter
Display the count of media temperature injections.
This counter is incremented each time the media temperature is injected.
N/A
Software triggers counter
Displays the count of software triggers.
The counter is incremented each time a software trigger is enabled.
N/A
Master Passphrase Enabled
Indicates that the master password is enabled.
N/A
Figure 88, Figure 89, and Figure 90 show the Monitor Health submenu screen, on which you can view and configure sensors on all Intel DCPMMs. For more information about the submenu items, see Table 46.
Figure 88 Monitor Health submenu screen (1)
Figure 89 Monitor Health submenu screen (2)
Figure 90 Monitor Health submenu screen (3)
Table 46 Items on the Monitor Health submenu screen
Item
Sensor Type
Displays the sensor type.
Options:
·     Health.
·     Controller temperature.
·     Media temperature.
·     Percentage remaining.
·     Latched dirty shutdown count.
·     Power on time.
·     Up time.
·     Power cycles.
·     FW error count.
·     Unlatched dirty shutdown count.
Value
Displays the value of the current sensor.
Non-critical threshold
Displays the non-critical alarm threshold for the temperature sensor.
Critical lower threshold
Displays the lower critical alarm threshold for the temperature sensor.
Critical upper threshold
Displays the upper critical alarm threshold for the temperature sensor.
Fatal threshold
Displays the fatal alarm threshold for the temperature sensor.
Displays the sensor state.
Options:
·     Unknown.
·     Normal.
·     Noncritical.
·     Critical.
·     Fatal.
This option is displayed only for the controller temperature, media temperature, and percentage remaining sensors.
Alarm enabled state
Select 0 or 1 to disable or enable alarming.
With alarming enabled, the system generates an alarm when the temperature sensor reading exceeds the non-critical alarm threshold.
Modify non-critical thresholds
Set the threshold of the controller temperature sensor.
Value range: 20°C to 105°C (68°F to 221°F).
Media temperature
Set the threshold of the media temperature sensor.
Value range: 20°C to 85°C (68°F to 185°F).
Set the threshold of the percentage remaining sensor.
Value range: 1% to 99%.
Apply changes
Apply the changes.
After editing the non-critical threshold of the sensor, apply the changes for the editing to take effect immediately.
Back to main menu
Figure 91 shows the Update Firmware submenu screen, on which you can view and update the firmware of an Intel DCPMM. For more information about the submenu items, see Table 47.
Figure 91 Update Firmware submenu screen
Table 47 Items on the Update Firmware submenu screen
Item
Current firmware version
Displays the current firmware version.
Selected firmware version
Displays the selected firmware version.
Options:
·     None—No file path has been entered in the File option.
·     Incorrect FW—The entered file path is incorrect.
·     (version)The version of the firmware in the specified firmware image file is displayed.
File
Enter the path for saving the firmware file.
The path must be a relative path of the root directory, for example, \firmware\newFirmware.bin.
Displays the current staged firmware version.
Options:
·     MixedDifferent versions of firmware are staged on the Intel DCPMMs.
·     N/A—No firmware is staged on the Intel DCPMMs.
Update
Update the firmware.
After the update, a reboot is required for the new firmware to take effect.
Back to main menu
Figure 92 shows the Configure Security submenu screen, on which you can configure the security features of an Intel DCPMM. For more information about the submenu items, see Table 48.
Figure 92 Configure Security submenu screen
Table 48 Items on the Configure Security submenu screen
Item
Displays the current security state for all Intel DCPMMs in the system.
Options:
Enable security
Select this option to enable security.
After the enabling, a reboot is required for the change to take effect.
Secure erase
Clear the persistent memory on the Intel DCPMM.
This item is available only when the security state of the Intel DCPMM is unlocked or disabled.
·     If the security state of the Intel DCPMM is unlocked, you must enter the current password.
·     If the security state of the Intel DCPMM is disabled, you must confirm the operation in the confirm window that opens.
Freeze lock
Freeze the lock state of the Intel DCPMM till the next reboot.
No password is required to change the security state to frozen.
Back to main menu
Figure 93 shows the Configure Data Policy submenu screen, on which you can configure the data policy of an Intel DCPMM. For more information about the submenu items, see Table 49.
Figure 93 Configure Data Policy submenu screen
Table 49 Items on the Configure Data Policy submenu screen
Item
First fast refresh state
Displays the state of the first fast refresh on all Intel DCPMMs.
This item is available only if you access the submenu from the Configure data policy item on the DIMM Configuration submenu described in Table 44.
Options:
·     Enabled—First fast refresh is enabled on all Intel DCPMMs.
·     Disabled—First fast refresh is disabled on all Intel DCPMMs.
·     MixedFirst fast refresh is enabled on some Intel DCPMMs and disabled on the other Intel DCPMMs.
Enable first fast refresh
Enables the acceleration of the first fast refresh cycle on the Intel DCPMM.
This option is available only when first fast refresh is disabled.
Disable first fast refresh
Disables the acceleration of the first fast refresh cycle on the Intel DCPMM.
This option is available only when first fast refresh is enabled.
Back to main menu
Regions submenu screen
Memory configuration changes require a reboot to take effect and stays in pending state before the reboot. You can delete the pending configuration (goal configuration) before the reboot for the system to start up with the current configuration.
The system manages persistent memory configurations in the form of regions. Figure 94 shows the Regions submenu screen, on which you can view or configure the current and goal configurations. For more information about the submenu items, see Table 50.
Figure 94 Regions submenu screen
Table 50 Items on the Regions submenu screen
Item
Current configuration
Region ID
Submenu for displaying detailed information about the region.
Persistent memory type
Displays the current memory type.
Options:
·     App Direct.
·     App Direct Not Interleaved.
Capacity
Displays the total capacity of the region, in GB.
Free capacity
Displays the available capacity of the region, in GB.
Memory allocation goal configuration
DIMM ID
This item is available only when a pending memory allocation goal exists.
Submenu for configuring an Intel DCPMM.
MemorySize
Displays the memory size for an Intel DCPMM.
AppDirect1Size
Displays the size of App Direct 1.
AppDirect2Size
Displays the size of App Direct 2.
Create goal config
Creates goal configuration.
Delete goal config
Deletes goal configuration.
This item is available only if pending goal configurations exist.
Back to main menu
Figure 95 shows the Region Detailed Information submenu screen, on which you can view the detailed information about the persistent memory configuration. For more information about the submenu items, see Table 51.
Figure 95 Region Detailed Information submenu screen
Table 51 Items on the Region Detailed Information submenu screen
Item
Region ID
Displays the region ID, in hexadecimal notation.
N/A
DIMM ID
Displays the IDs of the Intel DCPMMs contained in the region.
N/A
ISet ID
Displays the ISet ID.
N/A
Displays the type of persistent memory capacity.
Options:
·     App DirectThe App Direct capacity is interleaved across two or more Intel DCPMMs.
·     App Direct Not InterleavedThe App Direct capacity is wholly contained on a single Intel DCPMM.
App Direct
Capacity
Displays the total usable capacity, the sum of allocated capacity and unallocated capacity.
N/A
Free capacity
Displays the remaining usable capacity.
N/A
Health
Displays the health state of the Intel DCPMM capacity.
Options:
·     Health—All underlying Intel DCPMM persistent memory is available.
·     Pending—A new memory allocation goal has been created but not been applied.
·     Error—The interleave set has failed.
·     Locked—One or more of the underlying Intel DCPMMs are locked.
·     Unknown—The region health cannot be determined.
N/A
Socket ID
Displays the socket ID to which the region belongs.
N/A
Back to Regions menu
Return to the Regions submenu.
N/A
Back to main menu
N/A
Figure 96 shows the View Goal Config submenu screen, on which you can view the detailed information about a configuration goal. For more information about the submenu items, see Table 52.
Figure 96 View Goal Config submenu screen
Table 52 Items on the View Goal Config submenu screen
Item
Socket ID
Displays the ID of the socket to which the Intel DCPMM belongs.
DIMM ID
Displays the Intel DCPMM ID.
Memory Mode size
Displays the capacity of the Intel DCPMM that will be configured in memory mode.
App Direct #1 size
Displays the capacity of the Intel DCPMM that will be configured as the first App Direct interleave set.
App Direct #1 index
Displays the unique ID of the first App Direct interleave set.
This item displays N/A when the size of the App Direct #1 is 0.
App Direct #1 setting
Displays the format of the App Direct 1: x (DIMM ID) – (IMC size) IMC x (Channel size) Channel.
App Direct #2 size
Displays the capacity of the Intel DCPMM that will be configured as the second App Direct interleave set.
App Direct #2 index
Displays the unique ID of the second App Direct interleave set.
This item displays N/A when the size of the App Direct #2 is 0.
App Direct #2 setting
Displays the format of the App Direct 2: x (DIMM ID) – (IMC size) IMC x (Channel size) Channel.
Back to main menu
Figure 97 shows the Create Goal Config submenu screen, on which you can create a configuration goal. For more information about the submenu items, see Table 53.
Figure 97 Create Goal config submenu screen
Table 53 Items on the Create Goal Config submenu screen
Item
Create goal config for
Select a target to create a goal configuration.
Options:
·     Platform—Creates a memory allocation goal on all the sockets in the platform.
·     Socket—Creates a memory allocation goal of the Intel DCPMMs on the specified sockets.
·     Partially-configured sockets—Creates a memory allocation goal on the specified sockets which are partially configured because of the addition of new Intel DCPMMs. A partially-configured socket refers to a socket that has a minimum of one configured Intel DCPMM and a minimum of one unconfigured Intel DCPMM. This option is not displayed if no partially-configured sockets exist.
Platform
Reserved
Set the percentage of the reserved capacity, which will not be mapped into the system physical address space.
Value range: 0% to 100%.
N/A
Memory Mode
Set the percentage of the total capacity to use in memory mode.
Because of platform memory alignment requirements, this value will be aligned automatically.
N/A
Select the type of persistent memory capacity to create.
Options:
·     App DirectThe capacity is interleaved across the Intel DCPMMs.
·     App Direct Not InterleavedThe capacity is not hardware interleaved.
This item is inaccessible when the Memory Mode item is set to 100%.
N/A
Namespace Label version
Displays the version of the namespace label.
Options:
·     1.2.
·     1.1.
N/A
Create goal config
Create a configuration goal on the selected target.
N/A
N/A
Back to main menu
N/A
Figure 98 shows the Delete Goal Config submenu screen, on which you can delete the goal configuration. For more information about the submenu items, see Table 54.
Figure 98 Delete Goal Config submenu screen
Table 54 Items on the Delete Goal Config submenu screen
Item
Delete goal config for
Select the target to delete goal configuration.
Options:
·     Platform.
·     Socket.
Delete goal config
Delete goal configuration from the selected target.
Back to main menu
Namespaces submenu screen
Figure 99 shows the Namespaces submenu screen, on which you can view and configure namespaces. For more information about the submenu items, see Table 55.
Figure 99 Namespaces submenu screen
Table 55 Items on the Namespaces submenu screen
Item
Namespace ID
Displays the namespace ID, in hexadecimal notation.
This item is available only when a namespace exists in the system.
Name
Displays the name of namespace.
Health Status
Displays the health state.
Options:
·     Healthy.
·     Warning.
·     Critical.
·     Locked.
·     Unknown.
Create namespace
Submenu for creating a namespace
Back to main menu
Figure 100 shows the Create Namespace submenu screen, on which you can create a namespace. For more information about the submenu items, see Table 56.
Figure 100 Create Namespace submenu screen
Table 56 Items on the Create Namespace submenu screen
Item
Name
Enter the name of the namespace to be created.
The name can contain a maximum of 63 characters.
N/A
Region ID
Set the region ID of the namespace.
N/A
Mode
Set the namespace mode.
Options:
·     NoneAllows only raw access.
·     Sector—Guarantees powerfail write atomicity by using a block translation table (BTT).
None
Capacity input
Select to use the maximum available capacity or enter the capacity manually.
Options:
·     RemainingSelect this option to use the maximum available capacity of the specified persistent memory type on the specified region for the new namespace.
·     Manual—Select this option to enter the capacity for the new namespace manually.
Remaining
Units
Set the capacity unit.
Options:
·     GiB.
·     GB.
·     B.
·     MB.
·     MiB.
·     TB.
·     TiB.
GiB
Capacity
Displays the namespace capacity.
This item is inaccessible if the Capacity input item is set to Remaining.
N/A
Create namespace
N/A
Back to Namespaces
Return to the Namespaces submenu.
N/A
Back to main menu
N/A
Figure 101 shows the Modify Namespace submenu screen, on which you can modify or delete a namespace. For the new configuration to take effect, you must select Save and then press Enter. For more information about the submenu items, see Table 57.
Figure 101 Modify Namespace submenu screen
Table 57 Items on the Modify Namespace submenu screen
Item
UUID
Displays the universal unique identifier (UUID) of the namespace.
ID
Displays the ID of the namespace, in hexadecimal notation.
Name
Displays the name of the namespace.
Region
Displays the region ID of the namespace, in decimal notation.
Health
Displays the health state of the underlying Intel DCPMMs.
Options:
·     Healthy.
·     Warning.
·     Critical.
·     Locked.
·     Unknown.
·     Unsupported—The namespace type is not supported.
Mode
Displays the namespace mode.
Options:
·     Fsdax—Supports filesystem-dax.
Block size
Displays the logical block size.
Units
Displays the capacity unit.
Options:
·     GiB.
·     GB.
·     B.
·     MB.
·     MiB.
·     TB.
·     TiB.
Capacity
Displays the usable namespace capacity.
Label Version
Displays the version of the LSA.
Options:
·     1.1.
·     1.2.
The label version for all namespaces is the same.
Save
Save the change.
For the configuration changes to take effect, you must save the change.
Delete
Delete the namespace.
Back to Namespaces
Back to main menu
Total Capacity submenu
Figure 102 shows the Total Capacity submenu screen, on which you can view the total Intel DCPMM memory resource allocation across the server. For more information about the submenu items, see Table 58.
Figure 102 Total Capacity submenu screen
Table 58 Items on the Total Capacity submenu screen
Item
Raw capacity
Displays the total Intel DCPMM capacity.
App Direct capacity
Displays the total Intel DCPMM capacity configured to use as APP Direct.
Memory capacity
Displays the total Intel DCPMM capacity configured to use in memory mode.
Displays the capacity of unconfigured Intel DCPMMs that are not mapped into the system physical address space.
Displays the capacity of Intel DCPMMs inaccessible because of licensing issues.
Reserved capacity
Displays the total system Intel DCPMM capacity reserved for proper alignment of the memory mode capacity.
Back to main menu
Diagnostics submenu
Figure 103 shows the Diagnostics submenu screen, on which you can run a combination of different diagnostic tests. For more information about the submenu items, see Table 59.
Figure 103 Diagnostics submenu screen
Table 59 Items on the Diagnostics submenu screen
Item
Quick diagnostics
Select Enabled or Disabled to enable or disable quick diagnostic test.
Enabled
DIMM ID
Select Enabled or Disabled to enable or disable diagnosis on an Intel DCPMM.
Enabled
Config diagnostics
Select Enabled or Disabled to enable or disable platform configuration diagnostic test.
Enabled
FW diagnostics
Select Enabled or Disabled to enable or disable firmware diagnostic test.
Enabled
Security diagnostics
Select Enabled or Disabled to enable or disable security diagnostic test.
Enabled
Execute tests
Execute the selected diagnostic tests.
This item is inaccessible when one of the following conditions exists:
·     No test items are enabled.
·     Quick diagnostic test is enabled but no Intel DCPMMs are selected.
N/A
Back to main menu
N/A
Preferences submenu
Figure 104 shows the Preferences submenu screen, on which you can view or modify user preferences. For more information about the submenu items, see Table 60.
Figure 104 Preferences submenu screen
Table 60 Items on the Preferences submenu screen
Item
Default DIMM ID
Set the default display of the Intel DCPMM ID.
Options:
·     Handle—Uses the SMBIOS Type 17 handle.
·     UID—Uses the Intel DCPMM UID set in Table 45.
Handle
Capacity units
Options:
·     Auto.
·     Auto_10.
·     B.
·     MB.
·     MiB.
·     GB.
·     GiB.
·     TB.
·     TiB.
Auto
App Direct settings
Configure the interleave settings for creating an App Direct capacity.
You can use only the BIOS recommended interleave settings, in the format of (IMC size)_(Channel size).
This option is inaccessible if an App Direct capacity already exists on the system.
BIOS recommended interleaving settings
App Direct granularity
Set the minimum App Direct granularity per Intel DCPMM.
Options:
·     Recommended—Uses the recommended App Direct granularity of 32 GiB.
·     1Uses the granularity of 1 GiB.
Recommended
Back to main menu
N/A
Driver Health submenu
Figure 105 shows the Driver Health submenu screen, on which you can view the health state of a driver or controller. This section uses a controller of a 4-port mLOM Ethernet adapter as an example. The submenu items are described in Table 61.
Figure 105 Driver Health submenu screen
Table 61 Items on the Driver Health submenu screen
Item
Intel(R) DCPM 1.0.0.3286 Driver
Displays the health state of a driver or a controller.
Options:
·     Healthy—Normal.
·     Failed—Abnormal.
If the state is Failed, press Enter and follow the instructions to repair the driver or controller. The repair method varies by driver or controller.
Platform Configuration menu
As shown in Figure 106, the Platform Configuration menu contains the submenus described in Table 62.
Figure 106 Platform Configuration menu screen
Table 62 Items on the Platform Configuration menu screen
Item
PCH Configuration
Submenu for configuring the platform controller hub (PCH).
Miscellaneous Configuration
Submenu for configuring miscellaneous settings, including video display device and debug mode settings.
Server ME Configuration
Submenu for configuring the server management engine (ME).
Runtime Error Logging
Submenu for configuring runtime error logging.
PCH Configuration submenu
Figure 107 shows the PCH Configuration submenu screen, on which you can configure PCH settings as described in Table 63.
Figure 107 PCH Configuration submenu screen
Table 63 Items on the PCH Configuration submenu screen
Item
PCH SATA Configuration
Submenu for configuring PCH SATA settings, as shown in Figure 108.
The submenu menu items are described in Figure 109.
This submenu is not available for the R8900.
PCH sSATA Configuration
Submenu for configuring PCH sSATA settings, as shown in Figure 111.
The submenu menu items are described in Figure 112.
USB Configuration
Submenu for configuring USB, as shown in Figure 113 through Figure 126.
The submenu menu items are described in Table 69 through Table 82.
The submenu items vary by server model.
ADR Configuration
Submenu for configuring asynchronous dram refresh (ADR), as shown in Figure 127.
The submenu menu items are described in Table 83.
PCH SATA Configuration submenu screen
Figure 108 and Figure 109 show the PCH SATA Configuration submenu screen. The submenu items are described in Figure 110.
Figure 108 PCH SATA Configuration submenu screen (for all servers except for the B5700, B5800, B7800, R5300, and R8900)
Figure 109 PCH SATA Configuration submenu screen (for the R5300)
Figure 110 PCH SATA Configuration submenu screen (for the B5700, B5800, and B7800)
Table 64 Items on the PCH SATA Configuration submenu screen
Item
SATA Controller
Select Enabled or Disabled to enable or disable the SATA controller.
Enabled
Configure SATA As
Select the operating mode of the SATA controller.
Options:
·     AHCI—Uses the AHCI mode, which allows the drives attached to the SATA ports to be used as SATA disks. This mode supports hot swapping of drives. To use this mode, a SATA driver must be installed.
·     RAID—Uses the RAID mode, which allows creation of a logical drive from multiple independent physical drives. To configure the embedded RSTe RAID controller, select this option.
AHCI
SATA Test Mode
Select Enabled or Disabled to enable or disable SATA test mode.
Disabled
SATA Port N
Displays the name and slot number of the drive connected to logic PCH SATA port N. If no drive is connected, Not Installed is displayed.
For the R4300, only SATA Port 0 and SATA Port 1 are available.
For the R4400, only SATA Port 0, SATA Port 1, SATA Port 2, and SATA Port 3 are available.
For the R5300, the slot number indicates the drive slot for the SATA port.
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to SATA port N.
For the B5700, B5800, and B7800, this field also displays the name of the component connected to the port, as shown in Figure 110. For information about the connected component for each SATA port, see Table 65.
Enabled
Table 65 Connected component information for each SATA port (for the B5700 and B7800)
SATA port
H3C UniServer B5700 G3
SATA Port 0
Riser Card M.2 Port 0
SATA Port 1
Riser Card M.2 Port 1
H3C UniServer B7800 G3
SATA Port 0
HDD Slot 0
SATA Port 1
HDD Slot 1
SATA Port 2
HDD Slot 2
SATA Port 3
HDD Slot 3
SATA Port 4
HDD Slot 4(M.2 Adapter Box Port 0)
SATA Port 5
M.2 Adapter Box Port 1
SATA Port 6
Motherboard M.2 Slot 0
SATA Port 7
Motherboard M.2 Slot 1
PCH sSATA Configuration submenu screen
Figure 111 shows the PCH sSATA Configuration submenu screen. The submenu items are described in Figure 112.
Figure 111 PCH sSATA Configuration submenu screen (for all servers except for the B5700, B5800, B7800, R5300, and R8900)
Figure 112 PCH sSATA Configuration submenu screen (for the R5300)
Table 66 Items on the PCH sSATA Configuration submenu screen
Item
sSATA Controller
Select Enabled or Disabled to enable or disable the sSATA controller.
Enabled
Configure sSATA As
Select the operating mode of the drive controller.
Options:
AHCI
sSATA Test Mode
Select Enabled or Disabled to enable or disable sSATA test mode.
Disabled
sSATA Port N
Displays the name and the slot number of the drive connected to logic PCH sSATA port N. If no drive is connected, Not Installed is displayed.
For the R5300, the slot number indicates the drive slot for the sSATA port.
The number of sSATA ports varies by server model. For more information, see Table 68.
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to sSATA port N.
For the B5700, B5800, and B7800, this field also displays the name of the component connected to the port, as shown in Figure 110. For information about the connected component for each sSATA port, see Table 67.
Enabled
Table 67 Connected component information for each sSATA port (for the B5700, B5800, and B7800)
sSATA port
B5700
sSATA Port 0
HDD Slot 0
sSATA Port 1
HDD Slot 1
sSATA Port 2
HDD Slot 2(M.2 Adapter Box Port 0)
sSATA Port 3
B5800
sSATA Port 2
M.2 slot0
sSATA Port 3
M.2 slot1
B7800
sSATA Port 2
sSATA Port 3
Table 68 sSATA ports available for each server model
Server model
sSATA ports
B5700
See Table 67
B5800
See Table 67
B7800
See Table 67
E3200
Ports 0 through 5
R2700
Ports 0 through 5
R2900
Ports 0 through 5
R4300
Ports 0 through 5
R4400
N/A
R4700
Port 5
R4900
Port 5
R5300
Ports 0 through 5
R6700
Ports 0 through 5
R6900
Ports 0 through 5
R8900
N/A
USB Configuration submenu screen (for the R2700)
Figure 113 shows the USB Configuration submenu screen. The submenu items are described in Table 69.
Figure 113 USB Configuration submenu screen (for the R2700)
Table 69 Items on the USB Configuration submenu screen
Parameter
USB Per-Connector Disable
Enable or disable independent control of individual USB connectors on the system board.
Options:
·     Enabled—You can disable the USB connectors on a per-connector basis.
·     Disabled—You cannot disable the USB connectors on a per-connector basis.
If a USB connector is disabled, the BIOS or OS does not display the USB device plugged into that connector.
All subsequent menu items for setting USB port capability are available only if you set USB Per-Connector Disable to Enabled.
Disabled
Rear Left USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the left USB 2.0 connector on the server's rear panel.
Enabled
Rear Right USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the right USB 2.0 connector on the server's rear panel.
Enabled
Internal Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the upper internal USB 2.0 connector.
Enabled
Internal Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the lower internal USB 2.0 connector.
Enabled
Front Left Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the upper USB 2.0 connector on the left chassis ear at the server front.
Enabled
Front Left Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 2.0 connector on the left chassis ear at the server front.
Enabled
SD Card Slot USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of the SD card slot.
Enabled
SD Card Slot USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 capability of the SD card slot.
Enabled
Rear Left USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the left USB 3.0 connector on the server's rear panel.
Enabled
Rear Right USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the right USB 3.0 connector on the server's rear panel.
Enabled
Internal Top USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the upper internal USB 3.0 connector.
Enabled
Internal Bottom USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the lower internal USB 3.0 connector.
Enabled
USB Configuration submenu screen (for the R2900)
Figure 114 shows the USB Configuration submenu screen. The submenu items are described in Table 70.
Figure 114 USB Configuration submenu screen (for the R2900)
Table 70 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Front Left USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector on the left chassis ear at the server front.
Enabled
Front Right USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector on the right chassis ear at the server front.
Enabled
Enabled
Front Right USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector on the right chassis ear at the server front.
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
USB Configuration submenu screen (for the R4300)
Figure 115 shows the USB Configuration submenu screen. The submenu items are described in Table 71.
Figure 115 USB Configuration submenu screen (for the R4300)
Table 71 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Rear Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 2.0 connector on the server's rear panel.
Enabled
Rear Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the upper USB 2.0 connector on the server's rear panel.
Enabled
Select Enabled or Disabled to enable or disable the right USB 2.0 connector on the right chassis ear at the server front.
Enabled
Enabled
Select Enabled or Disabled to enable or disable the right USB 3.0 connector on the right chassis ear at the server front.
Enabled
Enabled
Rear Bottom USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 3.0 connector on the server's rear panel.
Enabled
Rear Top USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the upper USB 3.0 connector on the server's rear panel.
Enabled
USB Configuration submenu screen (for the R4400)
Figure 116 shows the USB Configuration submenu screen. The submenu items are described in Table 72.
Figure 116 USB Configuration submenu screen (for the R4400)
Table 72 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Rear USB Port1 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector 1 on the server's rear panel.
Enabled
Rear USB Port2 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector 2 on the server's rear panel.
Enabled
Front VGA&USB Port1 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of the front VGA and USB 2.0 connector 1 on the server's front panel.
Enabled
Front VGA&USB Port2 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of the front VGA and USB 2.0 connector 2 on the server's front panel.
Enabled
Front PANEL Right 2.0 Capability
Enabled
Front PANEL Right 3.0 Capability
Enabled
Rear USB Port1 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector 1 on the server's rear panel.
Enabled
Rear USB Port2 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector 2 on the server's rear panel.
Enabled
USB Configuration submenu screen (for the R4700)
Figure 117 shows the USB Configuration submenu screen. The submenu items are described in Table 73.
Figure 117 USB Configuration submenu screen (for the R4700)
Table 73 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
USB Configuration submenu screen (for the R4900)
Figure 118 shows the USB Configuration submenu screen. The submenu items are described in Table 74.
Figure 118 USB Configuration submenu screen (for the R4900)
Table 74 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
USB Configuration submenu screen (for the R5300)
Figure 119 shows the USB Configuration submenu screen. The submenu items are described in Table 75.
Figure 119 USB Configuration submenu screen (for the R5300)
Table 75 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
USB Configuration submenu screen (for the R6700)
Figure 120 shows the USB Configuration submenu screen. The submenu items are described in Table 76.
Figure 120 USB Configuration submenu screen (for the R6700)
Table 76 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Internal BMC USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable USB 2.0 capability of the internal BMC.
Enabled
Enabled
Enabled
Internal Left USB Port 2.0 Capability(J16)
Select Enabled or Disabled to enable or disable the left internal USB 2.0 connector.
Enabled
Internal Right USB Port 2.0 Capability(J15)
Select Enabled or Disabled to enable or disable the right internal USB 2.0 connector.
Enabled
Enabled
Enabled
Select Enabled or Disabled to enable or disable USB 2.0 capability of the SD card slot.
Enabled
Select Enabled or Disabled to enable or disable the USB 3.0 connector on the server's front panel.
Enabled
Select Enabled or Disabled to enable or disable USB 3.0 capability of the SD card slot.
Enabled
Enabled
Enabled
Internal Left USB Port 3.0 Capability(J16)
Select Enabled or Disabled to enable or disable the left internal USB 3.0 connector.
Enabled
Internal Right USB Port 3.0 Capability(J15)
Select Enabled or Disabled to enable or disable the right internal USB 3.0 connector.
Enabled
USB Configuration submenu screen (for the R6900)
Figure 121 shows the USB Configuration submenu screen. The submenu items are described in Table 77.
Figure 121 USB Configuration submenu screen (for the R6900)
Table 77 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
USB HS Physical Connector #2 Disable
Enabled
USB HS Physical Connector #3 Disable
Enabled
USB HS Physical Connector #5 Disable
Select Enabled or Disabled to enable or disable the internal USB 2.0 connector.
Enabled
USB HS Physical Connector #6 Disable
Enabled
USB HS Physical Connector #7 Disable
Enabled
USB HS Physical Connector #10 Disable
Enabled
USB SS Physical Connector #0 Disable
Enabled
USB SS Physical Connector #1 Disable
Select Enabled or Disabled to enable or disable the USB 3.0 capability of the dual SD card extended module.
Enabled
USB SS Physical Connector #2 Disable
Enabled
USB SS Physical Connector #3 Disable
Enabled
USB SS Physical Connector #5 Disable
Select Enabled or Disabled to enable or disable the internal USB 3.0 connector.
Enabled
USB Configuration submenu screen (for the R8900)
Figure 122 shows the USB Configuration submenu screen. The submenu items are described in Table 78.
Figure 122 USB Configuration submenu screen (for the R8900)
Table 78 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Internal USB Port 2.0 Capability
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Internal USB Port 3.0 Capability
Enabled
USB Configuration submenu screen (for the E3200)
Figure 123 shows the USB Configuration submenu screen. The submenu items are described in Table 79.
Figure 123 USB Configuration submenu screen (for the E3200)
Table 79 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Front Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 2.0 connector on the server's front panel.
Enabled
Front Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the upper USB 2.0 connector on the server's front panel.
Enabled
Enabled
Enabled
Enabled
Enabled
Front Left USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector on the left chassis ear at the server front.
Enabled
Front Bottom USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 3.0 connector on the server's front panel.
Enabled
Front Top USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the upper USB 3.0 connector on the server's front panel.
Enabled
Enabled
USB Configuration submenu screen (for the B5700)
Figure 124 shows the USB Configuration submenu screen. The submenu items are described in Table 80.
Figure 124 USB Configuration submenu screen (for the B5700)
Table 80 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Internal Front USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the internal front USB 2.0 connector.
Enabled
Enabled
Front SUV #1 USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of SUV port #1 on the server's front panel.
Enabled
Front SUV #2 USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of SUV port #2 on the server's front panel.
Enabled
Internal BMC #A USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of the internal BMC port #A.
Enabled
Internal BMC #B USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 capability of the internal BMC port #B.
Enabled
Enabled
Internal Front USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the internal front USB 3.0 connector.
Enabled
Front Left Bottom USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the lower USB 3.0 connector on the left chassis ear at the server front.
Enabled
USB Configuration submenu screen (for the B5800)
Figure 125 shows the USB Configuration submenu screen. The submenu items are described in Table 81.
Figure 125 USB Configuration submenu screen (for the B5800)
Table 81 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
USB Configuration submenu screen (for the B7800)
Figure 126 shows the USB Configuration submenu screen. The submenu items are described in Table 82.
Figure 126 USB Configuration submenu screen (for the B7800)
Table 82 Items on the USB Configuration submenu screen
Parameter
Options:
Disabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
ADR Configuration submenu screen
Figure 127 shows the ADR Configuration submenu screen. The submenu items are described in Table 83.
Figure 127 ADR Configuration submenu screen
Table 83 Items on the ADR Configuration submenu screen
Item
Enable/Disable ADR
Select whether to enable ADR mode.
Options:
·     Platform-PORAutomatically uses the recommended configuration.
·     EnabledEnables ADR mode, which can protect memory from data loss in case of abnormal power supply.
·     DisabledDisables ADR mode.
Platform-POR
Host Partition Reset ADR Enable
Select whether to enable ADR on host paritition reset.
Options:
·     EnabledEnables ADR on host paritition reset.
·     DisabledDisables ADR on host paritition reset.
Platform-POR
Enable/Disable ADR Timer
Select whether to enable ADR timer.
Options:
·     EnabledEnables ADR timer.
·     Held-offDisables ADR timer.
Platform-POR
ADR timer expire time
Set the expiration time of the ADR timer.
Options:
·     Platform-PORAutomatically uses the recommended expiration time.
·     25us.
·     50us.
·     100us.
·     0us.
Platform-POR
ADR timer multiplier
Set the ADR timer multiplier.
Options:
·     Platform-PORAutomatically uses the recommended value.
·     ×1.
·     ×8.
·     ×24.
·     ×40.
·     ×56.
·     ×64.
·     ×72.
·     ×80.
·     ×88.
·     ×96.
Platform-POR
Miscellaneous Configuration submenu
Figure 128 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 84.
Figure 128 Miscellaneous Configuration submenu screen
Table 84 Items on the Miscellaneous Configuration submenu screen
Item
Active Video
This item is unavailable for the B5700, B5800, and B7800.
Select a monitor to display videos.
Options:
·     Auto—Enables the server to automatically select a monitor to display videos.
·     Onboard Device—Uses the monitor connected to the onboard VGA connector to display videos.
·     PCIe Device—Uses the monitor connected to the GPU module in the PCIe slot to display videos.
In legacy boot mode, the server cannot display the BIOS menus on the monitor connected to the GPU module or VGA connector if the Onboard Device or PCIe Device option is selected, respectively.
Onboard Device
Debug Mode
Select Enabled or Disabled to enable or disable outputting the debug log from a BIOS serial port.
If debug mode is enabled, you can obtain the debug log by connecting to a BIOS serial port.
Disabled
MLOM LLDP Control
This item is available only for the R2700, R2900, R4700, R4900, and R6900.
Select Enabled or Disabled to enable or disable LLDP for the mLOM Ethernet adapter.
LLDP enables devices of different vendors on a network to discover and exchange the system and configuration information.
If LLDP is enabled, the mLOM Ethernet adapter neither send nor receive LLDP packets.
Enabled
Server ME Configuration submenu
Figure 129 and Figure 130 show the Server ME Configuration submenu screen, on which you can view the server management engine information described in Table 85.
Figure 129 Server ME Configuration submenu screen (1)
Figure 130 Server ME Configuration submenu screen (2)
Table 85 Items on the Server ME Configuration submenu screen
Item
Oper. Firmware Version
Displays the active firmware version.
N/A
Backup Firmware Version
Displays the backup firmware version.
N/A
Recovery Firmware Version
Displays the recovery firmware version.
N/A
ME Firmware Status #1
Displays ME firmware status #1.
N/A
ME Firmware Status #2
Displays ME firmware status #2.
N/A
Current State
Displays the current ME state.
N/A
Error Code
Displays the error code.
N/A
Recovery Cause
Displays the reason for recovery.
N/A
PTT Support
Display support for the Platform Trusted Technology (PTT).
N/A
Altitude
Set the altitude at which the server is located, a hexadecimal value in meters. The default is 8000 meters (or 26246.72 ft).
8000
Enable MCTP Proxy
Select Enabled or Disabled to enable or disable MCTP proxy.
Disabled
MCTP Bus Owner
Displays the Management Component Transport Protocol (MCTP) bus owner location on PCIe. The field value is a four-bit hexadecimal number and can indicate the bus, device, and function if converted to binary format.
In binary format, the high-order 9th to 16th bits indicate the bus number, 4th to 8th bits indicate the device number, and 1st to 3rd bits indicate the function.
If the item is set to 0, the MCTP bus owner feature is disabled.
0
ME Firmware Features
Displays the ME firmware features.
N/A
Runtime Error Logging submenu
Figure 131 shows the Runtime Error Logging submenu screen, on which you can configure the runtime error logging as described in Table 86.
Figure 131 Runtime Error Logging submenu screen
Table 86 Items on the Runtime Error Logging submenu screen
Item
System Errors
This item controls system error logging, which enables the server to correct system errors automatically and report uncorrectable errors to HDM and the operating system.
Select Enabled or Disabled to enable or disable system error logging.
Enabled
S/W Error Injection Support
This item is available only when System Errors is set to Enabled.
Software error injection tests system performance by injecting software errors.
To test system performance, select Enabled.
Disabled
System Memory Poison
Select Enabled or Disabled to enable or disable system memory poison.
To report event logs to HDM when uncorrectable memory errors are injected, you must set both System Memory Poison and Viral Status to Disabled.
Enabled
Viral Status
This item is inaccessible if the process does not support advanced RSA.
Options:
·     AutoEnables the system to determine whether to enable detection of memory-resident viruses based on CPU and memory conditions.
·     Enabled—Enables detection of memory-resident viruses.
·     Disabled—Disables detection of memory-resident viruses.
Auto
Clear Viral Status
This item is unavailable when Viral Status or System Errors is set to Disabled.
Select Enabled or Disabled to enable or disable the clear viral status feature.
Disabled
System Cloaking
System cloaking enables the operating system and software to block corrected errors and uncorrected no action required (UCNA) errors.
Select Enabled or Disabled to enable or disable system cloaking.
Enabled
UboxToPcuMca Enabling
Select Enabled or Disabled to enable or disable the server to report Ubox errors to Machine Check Architecture (MCA).
Enabled
FatalErrDebugHalt
This item is available only when System Errors is set to Enabled, and this feature is applicable only to McBank fatal error debugging.
Select Enabled or Disabled to enable or disable halting fatal error debugging. Enable this feature only in conjunction with Intel® Technology Provider (ITP) because a thread will halt in fatal error flow.
Disabled
UNC Error Source Check for Variable Services
Select Enabled or Disabled to enable or disable uncorrectable error source check for variable services. Enabling this feature will decrease the SMI latency for variable services.
Enabled
eMCA Settings
Access the submenu for configuring the Enhanced Machine Check Architecture (eMCA), as shown in Figure 132.
The submenu items are described in Table 87.
N/A
Whea Settings
Access the submenu for configuring the Windows Hardware Error Architecture (WHEA), as shown in Figure 133.
The submenu items are described in Table 88.
N/A
Error Injection Settings
Access the submenu for configuring error injection settings, as shown in Figure 134.
The submenu items are described in Table 89.
N/A
UPI Error Enabling
This item is configurable only when the processors support the Advanced RAS feature.
Access the submenu for configuring UltraPath Interconnect (UPI) error reporting, as shown in Figure 135.
The submenu items are described in Table 90.
N/A
Memory Error Enabling
Access the submenu for configuring memory error reporting, as shown in Figure 136.
The submenu items are described in Table 91.
N/A
IIO Error Enabling
Access the submenu for configuring Integrated I/O module (IIO) error reporting, as shown in Figure 137 and Figure 138.
The submenu items are described in Table 92.
N/A
PCIe Error Enabling
Access the submenu for configuring PCIe error reporting, as shown in Figure 139.
The submenu items are described in Table 93.
N/A
Enhanced Diagnosis Enabling
Access the submenu for configuring enhanced diagnosis reporting, as shown in Figure 140.
The submenu items are described in Table 94.
N/A
eMCA Settings submenu screen
Figure 132 shows the eMCA Settings submenu screen. The submenu items are described in Table 87.
Figure 132 eMCA Settings submenu screen
Table 87 Items on the EMCA Settings submenu screen
Item
EMCA Logging Support
Select Enabled or Disabled to enable or disable EMCA logging.
EMCA logging provides MAC error reports for the server.
Enabled
LMCE Support
Local machine check exceptions (LMCE) support enables the system to log detected hardware errors in firmware registers.
Select Enabled or Disabled to enable or disable LMCE support.
Enabled
Ignore OS EMCA Opt-in
Select Enabled or Disabled to enable or disable the ignore OS EMCA opt-in feature.
Disabled
EMCA CMCI-SMI Morphing
This item is available only when EMCA Logging Support is set to Enabled.
When EMCA CMCI-SMI morphing is enabled:
·     The SMI is triggered each time a correctable error occurs.
·     If the number of correctable errors on the MCBank exceeds the upper limit, the SMI is triggered but the Corrected Machine Check Interrupt (CMCI) is not.
Options:
·     EMCA gen 1 Lite—Enables EMCA CMCI-SMI morphing in EMCA gen 1 lite mode.
·     EMCA gen 2 CSMI—Enables EMCA CMCI-SMI morphing in EMCA gen 2 CSMI mode.
·     Disabled—Disables EMCA CMCI-SMI morphing.
EMCA gen 2 CSMI
EMCA MCE-SMI Enable
Options:
·     EMCA gen 1 Dual Mode—Enables EMCA MCE-SMI in EMCA gen1 dual mode.
·     EMCA gen 2 – MSMI—Enables EMCA MCE-SMI in EMCA gen 2 MSMI mode.
·     Disabled—Disables EMCA MCE-SMI.
EMCA gen 2 – MSMI
Corrected Error eLog
Select Enabled or Disabled to enable or disable eMCA correctable error logging.
Enabled
Memory Error eLog
Select Enabled or Disabled to enable or disable eMCA memory error logging.
Enabled
Processor Error eLog
Select Enabled or Disabled to enable or disable eMCA processor error logging.
Enabled
Whea Settings submenu screen
Figure 133 shows the Whea Settings submenu screen. The submenu items are described in Table 88.
Figure 133 Whea Settings submenu screen
Table 88 Items on the Whea Settings submenu screen
Item
WHEA Support
Select Enabled or Disabled to enable or disable WHEA.
WHEA provides hardware error reports for the server.
Enabled
Whea Log Memory Error
Select Enabled or Disabled to enable or disable WHEA memory error logging.
Enabled
Whea Log Processor Error
Select Enabled or Disabled to enable or disable WHEA processor error logging.
Enabled
Whea Log PCI Error
Select Enabled or Disabled to enable or disable WHEA PCI error logging.
Enabled
Error Injection Settings submenu screen
Figure 134 shows the Error Injection Settings submenu screen. The submenu items are described in Table 89.
Figure 134 Error Injection Settings submenu screen
Table 89 Items on the Error Injection Settings submenu screen
Item
Mca Bank Error Injection Support
Select Enabled or Disabled to enable or disable MCA bank error injection.
If MCA bank error injection is enabled, the write function of the register into which errors are injected is enabled.
Disabled
AEP Error Injection
Select Enabled or Disabled to enable or disable Apache Pass (AEP) error injection.
Disabled
WHEA Error Injection Support
Select Enabled or Disabled to enable or disable WHEA error injection.
Disabled
WHEA Error Injection 5.0 Support Extension
This item is available only when WHEA Error Injection Support is set to Enabled.
Select Enabled or Disabled to enable or disable support for WHEA error injection 5.0 extension.
If support for WHEA error injection 5.0 extension is enabled, the error type can carry address and vendor extensions.
Enabled
Whea PCIE Error Injection Support
Select Enabled or Disabled to enable or disable WHEA PCIe error injection.
Disabled
Whea PCIe Error Injection Action Table
Select Enabled or Disabled to enable or disable WHEA PCIe error injection action table.
Enabled
Enable HA Parity Check
Select Enabled or Disabled to enable or disable HA parity check.
Disabled
Mca Bank Warm Boot Clear Errors
Select Enabled or Disabled to enable or disable MCA bank error clearing upon a warm reset.
Disabled
UPI Error Enabling submenu screen
Figure 135 shows the UPI Error Enabling submenu screen. The submenu items are described in Table 90.
Figure 135 UPI Error Enabling submenu screen
Table 90 Items on the UPI Error Enabling submenu screen
Item
SMI UPI Lane Failover
Select Enabled or Disabled to enable or disable triggering an SMI upon a UPI lane failover.
Disabled
UPI Corrected Error
Select Enabled or Disabled to enable or disable reporting UPI correctable errors to HDM.
Disabled
Memory Error Enabling submenu screen
Figure 136 shows the Memory Error Enabling submenu screen. The submenu items are described in Table 91.
Figure 136 Memory Error Enabling submenu screen
Table 91 Items on the Memory Error Enabling submenu screen
Item
Memory Error
Select Enabled or Disabled to enable or disable memory error reporting.
Enabled
Memory Corrected Error
This item is available only when Memory Corrected Error is set to Enabled.
Select Enabled or Disabled to enable or disable correctable memory error reporting.
Enabled
Memory Leaky Bucket Value
Set the memory leaky bucket value in hexadecimal notation.
Value range: 0x0000 to 0xffff.
0
Spare Interrupt
Select the type of the spare interrupt to generate upon detection of a memory error.
Options:
·     Disabled—Disables spare interrupt generation.
·     SMI—Generates an SMI interrupt.
·     Error Pin—Generates an error pin interrupt.
·     CMCI—Generates a CMCI interrupt.
SMI
NVMCTLR Errors
Select Enabled or Disabled to enable or disable NVMCTLR error logging and reporting.
Enabled
NVMCTLR Low Priority Error Signaling
Set NVMCTLR low priority error signaling.
Options:
·     Disabled—Disables reporting of NVMCTLR low priority errors.
·     SMI—Uses SMI interrupts to send NVMCTLR low priority error signals.
·     ERRO# Pin—Uses ERRO# Pin to send NVMCTLR low priority error signals.
SMI
NVMCTLR High Priority Error Signaling
Set NVMCTLR high priority error signaling configuration.
Options:
·     Disabled—Disables reporting of NVMCTLR high priority errors.
·     SMI—Uses SMI interrupts to send NVMCTLR high priority error signals.
·     ERRO# Pin—Uses ERRO# Pin to send NVMCTLR high priority error signals.
SMI
Mailbox for DDRT Alert Handling
Select the method for the mailbox to handle DDRT alerts.
Options:
·     DDRT—Uses DDRT to handle alerts.
·     SMBUS—Uses System Management Bus (SMBus) to handle alerts. This option is only available for verification.
DDRT
Set NGN Address Range Scrub
Select Enabled or Disabled to enable or disable NGN DIMM physical address range scrubbing.
Disabled
Set NGN Host Alert Policy for AIT Error
Set the signal type for the received address indirection table (AIT) errors. Options are Poison and Viral.
Poison
Set NGN Host Alert Policy for DPA Error
Set the signal type for the received DIMM physical address (DPA) errors. Options are Poison and Viral.
Poison
Set NGN Host Alert Policy for Patrol Scrub
This item is configurable only when the processors support the Advanced RAS feature. This item is available only when Memory Corrected Error is set to Enabled.
Select Enabled or Disabled to enable or disable the patrol scrubbing error alert policy. With the policy enabled, the system triggers DDRT interrupts based on uncorrectable errors detected by NGN patrol scrubbing.
Enabled
Enable Reporting SPA to OS
Select Enabled or Disabled to enable or disable system physical address (SPA) reporting to the operating system.
If the reporting is enabled, the MCE recovery threshold is disabled.
Enabled
DCPMM UNC Poison
Select whether to enable the poison mode for Intel DCPMMs.
Options:
·     EnabledWhen an uncorrectable error is detected in an Intel DCPMM, the DCPMM marks the abnormal data as poison and then continues to transmit the data.
·     DisabledWhen an uncorrectable error is detected in an Intel DCPMM, the DCPMM directly reports the error.
Enabled
IIO Error Enabling submenu screen
Figure 137 and Figure 138 show the IIO Error Enabling submenu screen. The submenu items are described in Table 92.
Figure 137 IIO Error Enabling submenu screen (1)
Figure 138 IIO Error Enabling submenu screen (2)
Table 92 Items on the IIO Error Enabling submenu screen
Item
IIO/PCH Global Error Support
Select Enabled or Disabled to enable or disable IIO/PCH global error reporting.
Enabled
IIO MCA Support
Select Enabled or Disabled to enable or disable IIO MCA support.
Enabled
IIO Error Pin Programming
This item is available only when IIO LER Support is set to Enabled.
Select Enabled or Disabled to enable or disable IIO error register.
Enabled
IIO Error Registers Clear
Select Enabled or Disabled to enable or disable clearing IIO error registers.
Enabled
IIO LER Support
Select Enabled or Disabled to enable or disable IIO LER support.
Disabled
LER MA Error Logging
Select Enabled or Disabled to disable or enable PCIe MCA error logging.
IIO Coherent Interface Error
Select Enabled or Disabled to enable or disable IIO coherent interface error detection.
Enabled
IIO IRP0 protocol parity error
This item is configurable only when IIO Coherent Interface Error is set to Enabled.
Select Enabled or Disabled to enable or disable IIO IRP0 protocol parity error detection.
Enabled
IIO IRP0 protocol qt overflow underflow error
Select Enabled or Disabled to enable or disable the IIO coherent interface protocol layer queue table overflow or underflow error reporting.
Enabled
IIO IRP0 protocol rcvd unexprsp
Select Enabled or Disabled to enable or disable IIO coherent interface protocol layer received unexpected response or completion error reporting.
Enabled
IIO IRP0 csr acc 32b unaligned
Select Enabled or Disabled to enable or disable IIO coherent interface CSR access crossing 32-bit boundary error reporting.
Enabled
IIO IRP0 wrcache uncecccs0 error
Select Enabled or Disabled to enable or disable reporting of IIO coherent interface write cache uncorrectable ECC errors.
Enabled
IIO IRP0 wrcache uncecccs1 error
Enabled
IIO IRP0 protocol rcvd poison error
Select Enabled or Disabled to enable or disable reporting of IIO coherent interface protocol layer received poisoned packet errors.
Enabled
IIO IRP0 wrcache correcccs0 error
Select Enabled or Disabled to enable or disable reporting of IIO coherent interface write cache correctable ECC errors.
Enabled
IIO IRP0 wrcache correcccs1 error
Enabled
IIO Misc. Error
Select Enabled or Disabled to enable or disable miscellaneous IIO error detection.
Enabled
IIO Vtd Error
Select Enabled or Disabled to enable or disable IIO Vtd error detection.
Enabled
IIO Dma Error
Select Enabled or Disabled to enable or disable IIO DMA error detection.
Enabled
IIO Dmi Error
Select Enabled or Disabled to enable or disable IIO DMI error detection.
Disabled
PCIE Error
Select Enabled or Disabled to enable or disable PCIe error detection.
Enabled
IIO PCIE Additional Corrected error
Select Enabled or Disabled to enable or disable IIO PCIe additional correctable error detection.
Enabled
IIO PCIE Additional Uncorrected error
Select Enabled or Disabled to enable or disable IIO PCIe additional uncorrectable error detection.
Enabled
IIO PCIe AER Spec Compliant
Select Enabled or Disabled to enable or disable IIO PCIe Advanced Error Reporting (AER) specification compliance checking.
If this feature is enabled, poisoned errors are recorded as fatal errors. If this feature is disabled, poisoned errors are recorded as non-fatal errors.
Disabled
PCIe Error Enabling submenu screen
Figure 139 shows the PCIe Error Enabling submenu screen. The submenu items are described in Table 93.
Figure 139 PCIe Error Enabling submenu screen
Table 93 Items on the PCIe Error Enabling submenu screen
Items
Corrected Error
Select Enabled or Disabled to enable or disable PCIe correctable error reporting.
Enabled
Uncorrected Error
Select Enabled or Disabled to enable or disable PCIe uncorrectable error reporting.
Enabled
Fatal Error Enable
Select Enabled or Disabled to enable or disable PCIe fatal error reporting.
Enabled
PCIe Corrected Error Threshold Counter
Select Enabled or Disabled to enable or disable the PCIe correctable error threshold counter.
Enabled
PCIe Corrected Error Threshold Mask
This item is configurable only when PCIe Corrected Error Threshold Counter is set to Enabled.
Set the PCIe correctable error threshold mask.
0
PCIE Correctable Error Threshold
Set the PCIe correctable error threshold.
1
PCIE AER Corrected Errors
Select Enabled or Disabled to enable or disable PCIe AER correctable error detection.
Enabled
PCIE AER Advisory Nonfatal Error
Select Enabled or Disabled to enable or disable PCIe AER advisory non-fatal error detection.
Enabled
PCIE AER NonFatal Error
Select Enabled or Disabled to enable or disable PCIe AER non-fatal error detection.
Enabled
PCIE AER Fatal Error
Select Enabled or Disabled to enable or disable PCIe AER fatal error detection.
Enabled
PCIe CE Event Report
Select Enabled or Disabled to enable or disable reporting PCIe correctable errors to System Event Log (SEL).
Disabled
SERR Propagation
Select Enabled or Disabled to enable or disable SERR propagation.
Enabled
PERR Propagation
Select Enabled or Disabled to enable or disable PERR propagation.
Enabled
Signal to OS on SERR
Select Enabled or Disabled to enable or disable reporting SERR signals to the operating system.
Enabled
Signal to OS on PERR
Select Enabled or Disabled to enable or disable reporting PERR signals to the operating system.
Enabled
Enhanced Diagnosis Enabling submenu screen
Figure 140 shows the Enhanced Diagnosis Enabling submenu screen. The submenu items are described in Table 94.
Figure 140 Enhanced Diagnosis Enabling submenu screen
Table 94 Items on the Enhanced Diagnosis Enabling submenu screen
Items
Enhanced Diagnosis Module
Select Enabled or Disabled to enable or disable the enhanced diagnosis module.
Enabled
PCIe SEL Info Level
This item is configurable only when Enhanced Diagnosis Module is set to Enabled.
Set the SEL log reporting level of the PCIe module. Options:
·     Standard—Reports standard PCIe SEL logs.
·     Detailed—Reports detailed PCIe SEL logs. The detailed logs contain PCIe error types that are not recorded in standard logs.
Standard
Socket Configuration menu
Figure 141 shows the Socket Configuration menu screen, on which you can configure processors, command reference code, UPI, memory, IIO, and advanced power management settings as described in Table 95.
Figure 141 Socket Configuration menu screen
Table 95 Items on the Socket Configuration menu screen
Item
Processor Configuration
Submenu for configuring processors, as shown in Figure 142 and Figure 143.
The submenu items are described in Table 98.
Common RefCode Configuration
Submenu for configuring the common reference code, as shown in Figure 146.
The submenu items are described in Table 99.
UPI Configuration
Submenu for configuring Intel® UltraPath Interconnect (UPI) parameters, as shown in Figure 147.
The submenu items are described in Table 100.
Memory Configuration
Submenu for configuring memory parameters, as shown in Figure 150.
The submenu items are described in Table 102.
IIO Configuration
Submenu for configuring Integrated I/O module (IIO) parameters, as shown in Figure 154.
The submenu items are described in Table 106.
Advanced Power Management Configuration
Submenu for configuring advanced power management parameters, as shown in Figure 161.
The submenu items are described in Table 115.
Processor Configuration submenu
Figure 142 and Figure 143 show the Processor Configuration submenu screen, on which you can configure features such as hyper-threading and hardware prefetcher for processors.
The submenu items are described in Table 96.
Figure 142 Processor Configuration submenu screen (1)
Figure 143 Processor Configuration submenu screen (2)
Table 96 Items on the Processor Configuration submenu screen
Item
Per-Socket Configuration
Access the submenu for per-socket configuration, as shown in Figure 144.
The submenu items are described in Table 97.
N/A
Processor BSP Revision
Displays the processor revision.
N/A
Processor Socket
Displays the sequence number of the processor socket.
N/A
Processor ID
Displays the processor ID.
N/A
Processor Frequency
Displays the processor frequency.
N/A
Processor Max Frequency
Displays the maximum frequency allowed for each processor.
N/A
Processor Min Frequency
Displays the minimum frequency allowed for each processor.
N/A
Processor TDP
Displays the thermal design power (TDP) of the processor.
N/A
Microcode Revision
Displays the microcode revision.
N/A
L1 Cache RAM
Displays the capacity of the level-1 processor cache.
N/A
L2 Cache RAM
Displays the capacity of the level-2 processor cache.
N/A
L3 Cache RAM
Displays the capacity of the level-3 processor cache.
N/A
Processor 1 Version
Displays the version of processor 1.
N/A
Processor 2 Version
Displays the version of processor 2.
N/A
Hyper-Threading [ALL]
This item is unavailable if the processer does not support hyper-threading.
Select Enabled or Disabled to enable or disable hyper-threading for the processors.
Hyper-threading allows a single processor to handle thread-level parallelism by enabling each physical processor core to function as two logical processor cores. This improves processor operating efficiency by enabling the processors to be compatible with multi-threaded OSs and software and reducing processor idle time.
Enabled
Enable Intel(R) TXT
Select Enabled or Disabled to enable or disable Intel Trusted Execution Technology (TXT).
Intel TXT provides comprehensive data security protection in a virtualized computing environment.
CAUTION CAUTION:
Set Debug Mode to Disabled before enabling Intel TXT.
Disabled
VMX
This item is configurable only when Enable Intel(R) TXT is set to Disabled.
Select Enabled or Disabled to enable or disable CPU Virtual Machine Extensions (VMX).
CPU VMX improves server hardware resource usage by enabling the virtualization layer or OS that supports VMX to use Intel hardware virtualization capabilities.
For virtualization layers or OSs that do not support VMX, this feature does not take effect even if it is enabled.
Enabled
Enable SMX
This item is configurable only when Enable Intel(R) TXT is set to Disable.
Select Enabled or Disabled to enable or disable Intel Safer Mode Extensions (SMX).
Disabled
Hardware Prefetcher
Select Enabled or Disabled to enable or disable hardware prefetcher.
If hardware prefetcher is enabled, the processor prefetches instructions or data from memory to L2 cache before processing the instructions or data. This feature helps improve system performance by reducing memory access time and eliminating potential bottlenecks.
Enabled
Adjacent Cache Prefetch
Select Enabled or Disabled to enable or disable adjacent cache prefetcher. Adjacent cache prefetcher is also referred to as mid-level cache (MLC) prefetcher.
Enabled
DCU Streamer Prefetcher
Select Enabled or Disabled to enable or disable data cache unit (DCU) stream prefetcher.
If the DCU stream prefetcher is enabled, the processor improves data processing and system performance by prefetching the stream and sending it to the L1 cache.
Enabled
DCU IP Prefetcher
Select Enabled or Disabled to enable or disable DCU IP prefetcher.
If the DCU IP prefetcher is enabled, the processor prefetches IP addresses to improve network connectivity and system performance.
Enabled
LLC Prefetch
Select Enabled or Disabled to enable or disable the L3 or last level cache (LLC) prefetcher.
Disabled
DCU Mode
Select a DCU mode.
Options:
·     32KB 8Way without ECC.
·     16KB 4Way with ECC.
Extended APIC
Select Enabled or Disabled to enable or disable the extended APIC mode. If the total number of processor cores exceeds 256, enable this mode as a best practice for the operating system to better support the processor multi-core feature.
Disabled
Monitor/MWAIT
Select whether to enable MONITOR and MWAIT instructions.
Options:
·     Auto.
·     Enabled.
·     Disabled.
The MONITOR and MWAIT instructions allow the processors to optimize instruction execution.
For some OSs, to disable CPU C State Control, you must disable this feature.
Contact H3C Support if you have any further questions.
Enabled
Per-Socket Configuration submenu screen
Figure 144 shows the Per-Socket Configuration submenu screen. The submenu items are described in Table 97.
Figure 144 Per-Socket Configuration submenu screen
Table 97 Items on the Per-Socket Configuration submenu screen
Item
CPU Socket N Configuration
Submenu for configuring processor N, as shown in Figure 145. N represents the processor number. The screen displays only present processors.
CPU Socket Configuration submenu screen
Figure 145 shows the CPU Socket Configuration submenu screen. The submenu items are described in Table 98.
This section uses CPU socket 1 as an example.
Figure 145 CPU Socket 1 Configuration submenu screen
Table 98 Items on the CPU Socket 1 Configuration submenu screen
Item
Available Core Bitmap
Displays available core bitmaps.
N/A
Active Core Bitmap
Displays active core bitmaps.
N/A
Core Disable Bitmap(Hex)
Set the number of disabled core bitmaps for the processor in hexadecimal notation.
To enable all cores of the processor, set the value to 0.
Use the available core bitmaps as reference when you disable the cores of the processor.
Make sure a minimum of one core is enabled for a processor. If you disable all cores for a processor, the configuration does not take effect.
0
Common RefCode Configuration submenu
Figure 146 shows the Common RefCode Configuration submenu screen, on which you can configure memory mapped I/O (MMIO) above 4 GB and non-uniform memory access (NUMA) settings as described in Table 99.
Figure 146 Common RefCode Configuration submenu screen
Table 99 Items on the Common RefCode Configuration submenu screen
Item
MMIO High Base
Select the address space for MMIO.
Options:
·     56T.
·     40T.
·     24T.
·     16T.
·     4T.
·     1T.
·     R5300: 4T.
·     Other servers: 56T.
MMIO High Granularity Size
Select the address allocation size for MMIO.
Options:
·     1G.
·     4G.
·     16G.
·     64G.
·     256G.
·     1024G.
·     R5300: 1024G.
·     Other servers: 64G.
Isoc Mode
Select whether to enable the Isoc mode.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
NUMA
Select Enabled or Disabled to enable or disable NUMA.
Non-uniform memory access (NUMA) allows a processor to access its local memory faster than a non-local memory.
Enabled
UPI Configuration submenu
Figure 146 shows the UPI Configuration submenu screen, from which you can access the UPI General Configuration submenu to configure UPI parameters.
Figure 147 UPI Configuration submenu screen
UPI General Configuration submenu screen
Figure 148 shows the UPI General Configuration submenu screen, on which you can configure parameters such as the UPI link frequency as described in Table 100.
Figure 148 UPI General Configuration submenu screen
Table 100 Items on the UPI General Configuration submenu screen
Item
UPI Status
Access the submenu that displays UPI information, as shown in Figure 149.
The submenu items are described in Table 101.
N/A
Link Frequency Select
Select a link frequency.
Options:
·     9.6 GT/s.
·     10.4 GT/s.
·     Auto.
Auto
SNC
The SNC feature can shorten the LLC and memory latency.
Select whether to enable sub-NUMA clustering (SNC).
Options:
·     Enabled.
·     Disabled.
·     Auto.
Disabled
XPT Prefetch
Select whether to enable XPT prefetcher.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
KTI Prefetch
Select Enabled or Disabled to enable or disable KTI prefetcher.
Enabled
RdCur for XPT Prefetch
Select whether to enable RdCur for XPT prefetcher.
Options:
·     AutoEnables the system to set RdCur for XPT prefetcher based on Si compatibility.
·     Enabled—Sets the suppress_mem_rd_prefetch_rdcur.
·     DisabledResets the RdCur for XPT prefetcher.
Auto
UPI Status submenu screen
Figure 149 shows the UPI Status submenu screen. The submenu items are described in Table 101.
Figure 149 UPI Status submenu screen
Table 101 Items on the UPI Status submenu screen
Item
Number of CPU
Displays the number of processors.
Number of IIO
Displays the number of integrated I/O modules.
Current UPI Link Speed
Displays the current speed of the UPI link.
Current UPI Link Frequency
Displays the current frequency of the UPI link.
UPI Global MMIO Low Base / Limit
Displays the UPI global MMIO low base address and limit.
UPI Global MMIO High Base / Limit
Displays the UPI global MMIO high base address and limit.
UPI PCIe Configuration Base / Size
Displays the PCIe configuration base address and size.
Memory Configuration submenu
Figure 150 shows the Memory Configuration submenu screen, on which you can configure memory settings such as the memory speed and memory RAS features as described in Table 102.
Figure 150 Memory Configuration submenu screen
Table 102 Items on the Memory Configuration submenu screen
Item
Total Memory
Displays the total memory capacity.
N/A
Current Memory Frequency
Displays the current memory frequency.
N/A
Enforce POR
Select whether to enforce POR restrictions on DDR4 frequency selection to improve memory reliability.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Memory Frequency
Select the maximum memory frequency, in MHz.
Options:
·     Auto.
·     1600.
·     1866.
·     2133.
·     2400.
·     2666.
·     2933. This option is available only for Cascade Lake processors.
The value range is 1866 to 2666 when Intel DCPMMs are used.
Auto
Attempt Fast Boot
Select whether to enable fast boot attempt.
Options:
·     Auto—Enables fast boot by default.
·     Enabled—Enables fast boot. If skipping part of memory reference code (MRC) can speed up the warm boot process, the system skips this part of MRC.
·     Disabled—Disables fast boot.
·     R8900: Disabled.
·     Other servers: Auto.
Attempt Fast Cold Boot
Select whether to enable fast cold boot attempt.
Options:
·     Auto—Enables fast cold boot by default.
·     Enabled—Enables fast cold boot. If skipping part of MRC can speed up the cold boot process, the system skips this part of MRC.
·     Disabled—Disables fast cold boot.
·     R8900: Disabled.
Memory Topology
Access the submenu that displays memory information, as shown in Figure 151.
The submenu items are described in Table 103.
N/A
Memory Map
Access the submenu for configuring memory mapping and interleaving, as shown in Figure 152.
You can enable memory interleaving to improve memory read and write performance.
The submenu items are described in Table 104.
N/A
Memory RAS Configuration
Access the submenu for configuring memory reliability, availability, and serviceability (RAS) settings, as shown in Figure 153.
The submenu items are described in Table 105.
N/A
Memory Topology submenu screen
Figure 151 shows the Memory Topology submenu screen. The submenu items are described in Table 103.
Figure 151 Memory Topology submenu screen
Table 103 Items on the Memory Topology submenu screen
Item
Processor 1 Ch1 DIMM A1:DIMM is Present.DIMM Status:Enabled.DIMM Details:2666MT/s Micron DRx8 16GB RDIMM
Displays information about the memory module of a processor (for example, DIMM A1 in channel 1 of processor 1), including:
·     Presence of the DIMM.
·     Enabling status of the DIMM.
·     Memory specifications:
¡     Memory frequency.
¡     Vendor.
¡     Number of ranks and bit width.
¡     Memory capacity.
¡     Memory type.
Memory Map submenu screen
Figure 152 shows the Memory Map submenu screen. The submenu items are described in Table 104.
Figure 152 Memory Map submenu screen
Table 104 Items on the Memory Map submenu screen
Item
eADR Support
Select Enabled or Disabled to enable or disable support for eADR.
Disabled
1LM Memory Interleave Granularity
Select the granularity for 1LM memory interleaving.
Options:
·     Auto.
·     256B Target,256B Channel.
·     64B Target,64B Channel.
Auto
IMC Interleaving
This item is configurable only when NUMA is disabled. For more information about NUMA, see"Common RefCode Configuration submenu."
Select an interleaving mode for integrated memory controllers.
Options:
·     Auto.
·     1-way Interleave.
·     2-way Interleave.
Auto
Channel Interleaving
Select a memory channel interleaving mode.
Options:
·     Auto.
·     1-way Interleave.
·     2-way Interleave.
·     3-way Interleave.
High-level interleaving improves memory performance, but low-level interleaving reduces power consumption.
Auto
Rank Interleaving
Select a memory rank interleaving mode.
Rank interleaving enables interleaving of memory ranks on the same channel.
Options:
·     Auto.
·     1-way Interleave.
·     2-way Interleave.
·     4-way Interleave.
·     8-way Interleave.
Auto
Socket Interleave Below 4GB
Select Enabled or Disabled to enable or disable socket interleaving for memory below 4 GB.
Disabled
Memory RAS Configuration submenu screen
Figure 153 shows the Memory RAS Configuration submenu screen. The submenu items are described in Table 105.
Figure 153 Memory RAS Configuration submenu screen
Table 105 Items on the Memory RAS Configuration submenu screen
Item
Mirror Mode
Select a memory mirroring mode to optimize system reliability by using half the system memory capacity for backup.
Options:
·     Disabled.
·     Enable Mirror Mode 1LM.
After you enable memory mirroring, the Total Memory Size item on the Memory Configuration submenu screen displays the total available memory, which is half the installed physical memory. To identify the installed physical memory capacity, access the Smbios Type 17 structure from a shell (for example, the CLI) of the operating system.
If all the DIMM slots are installed with DIMMs and memory mirroring is enabled, the memory capacity displayed on the POST self-test screen and the BIOS setup utility is larger than half the total installed physical memory.
Disabled
Memory Rank Sparing
Select Enabled or Disabled to enable or disable memory sparing for memory ranks.
Memory rank sparing uses some ranks in the memory as spare ranks for the non-spare ranks on the same channel.
Memory rank sparing is mutually exclusive with memory mirroring.
When the independent RAS mode is set and memory rank sparing is enabled, both the independent RAS mode and memory rank sparing take effect.
Disabled
Multi Rank Sparing
Select the number of spare ranks per channel. This item is available only when Memory Rank Sparing is set to Enabled.
Options:
·     One Rank—Uses one spare rank on a channel. To use one spare rank, each channel must have a minimum of two ranks.
·     Two Rank—Uses two spare ranks on a channel. To use two spare ranks, each channel must have a minimum of four ranks.
Two Rank
Set the correctable error threshold in decimal notation.
Value range: 0 to 32767.
Value 0 indicates that no correctable error threshold is set.
·     R8900: 1000
·     Other servers: 4096
Leaky bucket low bit
This item is configurable only when Memory Rank Sparing is set to Enabled.
Set the leaky bucket low bit in the range of 0 to 3F in hexadecimal notation.
10
Leaky bucket high bit
Set the leaky bucket high bit in the range of 0 to 29 in hexadecimal notation.
11
ADDDC Sparing
Select Enabled or Disabled to enable or disable adaptive double device data correction sparing (ADDDC).
ADDDC sparing can correct two-bit memory errors.
·     R8900: Enabled
·     Other servers: Disabled
Enable ADDDC Error Injection
This item is available only when ADDDC Sparing is set to Enabled.
Select Enabled or Disabled to enable or disable ADDDC error injection.
Enabled
Patrol Scrub
Select Enabled or Disabled to enable or disable patrol scrubbing.
Patrol scrubbing allows a processor to automatically search for and correct correctable memory errors at regular intervals while the system is idle.
Enabled
Patrol Scrub Interval
Set the patrol scrub interval in hours. This item is available only when Patrol Scrub is set to Enabled.
24
IIO Configuration menu
Figure 154 and Figure 155 show the IIO Configuration submenu screens, on which you can configure the peripheral component interconnect express (PCIe) slots, including their link speed and maximum payload size, as described in Table 106.
Figure 154 IIO Configuration submenu screen (1)
Figure 155 IIO Configuration submenu screen (2)
Table 106 Items on the IIO Configuration submenu screen
Item
Processor n Configuration
This item is available only when a processor is in position.
Access the IIO configuration submenu for a processor, for example, processor 1 or processor 2.
The port items on the Processor 1 Configuration submenu vary by server model and PCIe module.
Figure 156 uses the Processor 1 Configuration submenu screen as an example.
The submenu items are described in Table 107.
Intel® VT for Directed I/O (VT-d)
Access the submenu for enabling or disabling Intel virtualization technology for directed I/O (VT-d), as shown in Figure 158.
The submenu items are described in Table 109.
Intel® VMD technology
Access the submenu for configuring Intel Volume Management Device (VMD) technology, as shown in Figure 159.
The submenu items are described in Table 110.
Figure 156 shows the Processor 1 Configuration submenu screen. The submenu items are described in Table 107.
Figure 156 Processor 1 Configuration submenu screen
Table 107 Items on the Processor n Configuration submenu screen
Item
PCIe port submenu items, for example:
Processor 1 PcieBr0D00F0 - Port 0/DMI
Processor 1 PcieBr1D00F0 - Port 1A
Processor 1 PcieBr2D02F0 - Port 2C
Processor 1 PcieBr3D00F0 - Port 3A
Submenus for configuring PCIe ports.
Figure 157 shows the submenu for configuring Processor 1 PcieBr1D00F0 - Port 1A, which slightly differs from the submenu for other PCIe ports.
The submenu items are described in Table 108.
Figure 157 Submenu screen for Processor 1 PcieBr1D00F0 - Port 1A
Table 108 Items on the Processor 1 PcieBr1D00F0 - Port 1A submenu screen
Item
PCI-E Port
This item is available only for non-DMI PCIe ports.
Select whether to enable the PCIe port.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Link Speed
Select a link speed for the PCIe port.
Options:
·     Auto.
·     Gen 1 (2.5 GT/s).
·     Gen 2 (5.0 GT/s).
·     Gen 3 (8.0 GT/s).
Auto
PCI-E Port Link Status
Displays the PCIe port link status.
N/A
PCI-E Port Link Max
Displays the maximum bandwidth of the PCIe port link.
N/A
PCI-E Port Link Speed
Displays the PCIe port link speed.
N/A
PCI-E Port Max Payload Size
Set the maximum payload size of the PCIe port.
Options:
·     Auto—Sets the maximum payload size to 256B by default.
·     128B—Sets the maximum payload size to 128B. The configuration might affect the performance of NVMe drives. You can set the maximum payload size of a PCIe port to 128B if NVMe drive hot swapping causes the system to reboot.
·     256B—Sets the maximum payload size to 256B.
256B
Intel® VT for Directed I/O (VT-d) submenu screen
Figure 158 shows the Intel® VT for Directed I/O (VT-d) submenu screen. The submenu items are described in Table 109.
Figure 158 Intel® VT for Directed I/O (VT-d) submenu screen
Table 109 Items on the Intel® VT for Directed I/O (VT-d) submenu screen
Item
Select Enabled or Disabled to enable or disable Intel virtualization technology for directed I/O (VT-d).
With this feature enabled, management programs and OSs that support this feature can provide directed I/O with hardware support offered by the Intel virtualization technology. You can enable this feature even if such management programs and OSs are not used.
Intel VT-d enhances system security and reliability, and improves the performance of I/O devices in a virtualized environment.
As a best practice, enable this feature for the R8900.
Enabled
Interrupt Remapping
Select Enabled or Disabled to enable or disable interrupt remapping.
Enabled
PassThrough DMA
Select Enabled or Disabled to enable or disable pass-through direct memory access (DMA).
Enabled
ATS
Select Enabled or Disabled to enable or disable non-Isoch VT-d engine address translation services (ATS).
Enabled
Posted Interrupt
Select Enabled or Disabled to enable or disable the posted interrupt feature.
Enabled
Coherency Support(Non-Isoch)
Select Enabled or Disabled to enable or disable support for non-Isoch coherency.
Enabled
Intel® VMD technology submenu screen
Figure 159 shows the Intel® VMD technology submenu screen. The submenu items are described in Table 110.
Figure 159 Intel® VMD technology submenu screen
VMD 4
Table 110 Items on the Intel® VMD technology submenu screen
Item
Intel® VMD for Volume Management Device on Processor n
VMD configuration submenu for the volume management device on a processor.
Figure 160 shows the submenu for the volume management device on Processor 1 as an example, which is the same with the submenu for other processors.
The submenu items are described in Table 111.
Figure 160 Intel® VMD for Volume Management Device on Processor 1 submenu screen
Table 111 Items on the Intel® VMD for Volume Management Device on Processor 1 submenu screen
Item
Intel® VMD for Volume Management Device for PStack0
This item is available only in UEFI boot mode.
Select whether to enable Intel® VMD for the volume management device in PStack0.
Options:
·     Disabled—Disables Intel® VMD for the volume management device for PStack0.
·     Enabled—Enables Intel® VMD the volume management device for PStack0. The screen displays items for further configuration if you set the item to Enabled.
·     Auto—Enables Intel® VMD automatically when a device is detected for the stack during POST.
Auto
VMD port 1A
This item is available only when Intel® VMD for Volume Management Device for the corresponding PStack is enabled.
Select Enabled or Disabled to enable or disable VMD port 1A.
Disabled
VMD port 1B
Select Enabled or Disabled to enable or disable VMD port 1B.
Disabled
VMD port 1C
Select Enabled or Disabled to enable or disable VMD port 1C.
Disabled
VMD port 1D
Select Enabled or Disabled to enable or disable VMD port 1D.
Disabled
Hot Plug Capable
Select Enabled or Disabled to enable or disable hot swapping on the PCIe root port.
Disabled
CfgBar Size
Set the base address register (BAR) size in bits.
Value range: 20 to 27.
25
CfgBar attribute
Set the BAR attribute.
64-bit prefetchable
MemBar1 size
Set the size of memory bar 1. The minimum size is 20 bits.
25 bits
MemBar1 attribute
Set the attribute of memory bar 1.
Options:
·     32-bit non-prefetchable.
·     64-bit non-prefetchable.
·     64-bit prefetchable.
MemBar2 size
Set the size of memory bar 2. The minimum size is 20 bits.
25 bits
MemBar2 attribute
Set the attribute of memory bar 2.
Options:
·     32-bit non-prefetchableThis option is available only for Intel® VMD for the volume management device for PStack0 on processor 1.
Intel® VMD for Volume Management Device for PStack1
Select whether to enable Intel® VMD for the volume management device for PStack1.
Options:
·     Disabled—Disables Intel® VMD for the volume management device for PStack1.
·     Enabled—Enables Intel® VMD the volume management device for PStack1. The screen displays items for further configuration if you set this item to Enabled.
Auto
Intel® VMD for Volume Management Device for PStack2
Select whether to enable Intel® VMD for the volume management device for PStack2.
Options:
·     Disabled—Disables Intel® VMD for the volume management device for PStack2.
·     Enabled—Enables Intel® VMD the volume management device for PStack2. The screen displays items for further configuration if you set this item to Enabled.
Auto
Mapping relations between VMD items and NVMe device slots
IMPORTANT
IMPORTANT:
VMD items unmentioned in the following tables of this section support standard PCIe rather than VMD. To avoid device identification failure on PCIe slots, do not change the configuration of these VMD items.
For the E3200, R4300, R5300, and R8900, you can determine the corresponding VMD items for the logic slot of each NVMe device, as shown in Table 112.
Table 112 Mapping relations between VMD items and logic slots of NVMe devices (for the R4300, R5300, and R8900)
Logic slot of NVMe device
VMD items
R4300
Slot 100
Intel® VMD for Volume Management Device on Processor 2
VMD port 1C
Slot 101
VMD port 1D
Slot 102
VMD port 3A
Slot 103
VMD port 3B
Slot 104
VMD port 3C
Slot 105
VMD port 3D
R5300 (12LFF)
Slot 200
VMD port 3A
Slot 201
VMD port 3B
Slot 202
VMD port 3C
Slot 203
VMD port 3D
R5300 (24LFF)
Slot 200
VMD port 3A
Slot 201
VMD port 3B
Slot 202
VMD port 3C
Slot 203
VMD port 3D
Slot 204
VMD port 3A
Slot 205
VMD port 3B
Slot 206
VMD port 3C
Slot 207
VMD port 3D
R8900
Slots 210 through 213
Intel® VMD for Volume Management Device for Pstack1
VMD ports 2A, 2B, 2C, and 2D
Slots 214 through 217
Slots 220 through 223
Intel® VMD for Volume Management Device on Processor 4
Slots 224 through 227
Intel® VMD for Volume Management Device on Processor 3
Slots 230 through 233
Intel® VMD for Volume Management Device on Processor 6
Slots 234 through 237
Intel® VMD for Volume Management Device on Processor 5
Slots 240 through 243
Intel® VMD for Volume Management Device on Processor 8
Slots 244 through 247
Intel® VMD for Volume Management Device on Processor 7
E3200
Slots 111 through 114
Slots 115 through 118
Intel® VMD for Volume Management Device for Pstack2
VMD ports 3A, 3B, 3C, and 3D
Slots 121 through 124
Slots 125 through 128
VMD ports 1A, 1B, 1C, and 1D
Slots 141 through 144
Slots 151 through 154
For the B5700, B5800, and B7800, you can determine the corresponding VMD items for the physical slot of each NVMe SSD, as shown in Table 113.
Table 113 Mapping relations slots between NVMe SSD slots and VMD items (for the B5700, B5800, and B7800)
NVMe SSD
VMD items
B5700
NVMe SSD 1
VMD port 2A
NVMe SSD 2
VMD port 1A
B5800
NVMe SSD 6
VMD port 1A
NVMe SSDs 7 through 10
NVMe SSDs 11 through 14
B7800
NVMe SSD 1
VMD port 1C
NVMe SSD 2
VMD port 1D
NVMe SSD 3
VMD port 2C
NVMe SSD 4
VMD port 2D
For the B5700, B7800, R2700, R2900, R4700, R4900, R6700, and R6900, you can determine the corresponding VMD items for each PCIe riser connector if NVMe devices are installed through riser cards, as shown in Table 114.
Table 114 Mapping relations between PCIe riser connectors and VMD items (for the B5700, B7800, R2700, R2900, R4700, R4900, R6700, and R6900)
VMD items
B5700
PCIe riser connector 1
B7800
PCIe riser connector 2
R2900 and R4900
VMD port 1A, 1B, 1C, 1D
VMD port 3A, 3B, 3C, 3D
VMD port 2A, 2B, 2C, 2D
R2700 and R4700
R6700
(Required if the riser card on the connector can hold eight NVMe drives)
R6900
Compute module 1 PCIe riser connector 0
Compute module 2 PCIe riser connector 0
Advanced Power Management Configuration submenu
Figure 161 shows the Advanced Power Management Configuration submenu screen, on which you can configure advanced power management parameters, including P state control and C state control for processors and power management policy.
Figure 161 Advanced Power Management Configuration submenu screen
Table 115 Items on the Advanced Power Management Configuration submenu screen
Item
CPU P State Control
Submenu for configuring CPU P-state control options, as shown in Figure 162.
On the submenu, you can select whether to enable Enhanced Intel SpeedStep Technology (EIST) and turbo mode as described in Table 116.
Hardware PM State Control
Submenu for configuring hardware P-state control options, as shown in Figure 163.
The submenu items are described in Table 117.
CPU C State Control
Submenu for configuring CPU C-state control options, as shown in Figure 164.
On the submenu, you can control the power consumption of CPUs in idle state as described in Table 118.
Package C State Control
Submenu for configuring package C state control options, as shown in Figure 165.
On the submenu, you can set the C2 to C3 state transition timer as described in Table 119.
CPU Thermal Management
Submenu for configuring CPU thermal management options, as shown in Figure 166.
The submenu items are described in Table 120.
CPU Advanced PM Tuning
Submenu for configuring CPU advanced power management tuning, as shown in Figure 168.
The submenu items are described in Table 122.
SOCKET RAPL Config
Submenu for configuring socket RAPL settings, as shown in Figure 170.
The submenu items are described in Table 124.
CPU P State Control submenu screen
Figure 162 shows the CPU P State Control submenu screen. The submenu items are described in Table 116.
Figure 162 CPU P State Control submenu screen
Table 116 Items on the CPU P State Control submenu screen
Item
Uncore Freq Scaling (UFS)
Select Enabled or Disabled to enable or disable uncore frequency scaling (UFS).
Enabled
EIST (P-States)
Select Enabled or Disabled to enable or disable Enhanced Intel SpeedStep Technology (EIST).
EIST allows the system to automatically adjust processor voltage and core frequency to reduce power consumption and heat dissipation.
Enabled
Config TDP
This item is available only when EIST (P-States) is set to Enabled.
Set the level of the thermal design power (TDP) that represents the maximum amount of power required for system cooling.
Options:
·     Nominal.
·     Level1.
·     Level2.
Nominal
P State Domain
Set the P-states domain.
Options:
·     ALL.
·     ONE.
ALL
EIST PSD Function
Set the method for EIST to automatically adjust processor voltage and core frequency to reduce power consumption and help heat dissipation.
Options:
·     HW_ALL—Specifies all the hardware.
·     SW_ALL—Specifies all the software.
·     SW_ANY—Specifies any software.
HW_ALL
SINGLE_PCTL
Select Enabled or Disabled to enable or disable the SINGLE_PCTL mode.
Disabled
Single Power Domain (SPD)
Select Enabled or Disabled to enable or disable single power domain (SPD) configuration.
Disable
Boot performance mode
Set the boot performance state for BIOS before the OS takes over.
Options:
·     Max Performance.
·     Max Efficient.
·     Set by Intel Node Manager.
Max Performance
Energy Efficient Turbo
Select Enabled or Disabled to enable or disable energy efficient Turbo mode.
Enabled
Turbo Mode
Select Enabled or Disabled to enable or disable the Turbo mode.
Enabled
CPU Flex Ratio Override
Select Enabled or Disabled to enable or disable setting processor flex ratio.
Disabled
CPU Core Flex Ratio
This item is configurable only when CPU Flex Ratio Override is set to Enabled.
Set the the processor core ratio multiplier. The value range is 0 to 100.
23
Hardware PM State Control submenu screen
Figure 163 shows the Hardware PM State Control submenu screen. The submenu items are described in Table 117.
Figure 163 Hardware PM State Control submenu screen
Table 117 Items on the Hardware PM State Control submenu screen
Item
Hardware P-States
Set the mode for selecting the hardware P-states.
Options:
·     DisabledEnables the hardware to select a P-state based on operating system request.
·     Native ModeAllows the hardware to select a P-state with the guidance of the operating system.
·     Out of Band ModeAllows the hardware to autonomously select a P-state without guidance of the operating system.
·     Native Mode with No Legacy SupportSelects the Native mode with no support for Legacy.
Native Mode
HardwarePM Interrupt
This item is configurable only when Hardware P-States is set to Native Mode.
Select Enabled or Disabled to enable or disable hardware PM interrupt.
Disabled
EPP Enable
This item is unconfigurable when Hardware P-States is set to Disabled.
Select Enabled or Disabled to enable or disable ENERGY_PERFORMANCE_PREFERENCE (EPP).
If this feature is disabled, the system uses ENEGY_PERF_BIAS (EPB).
Enabled
EPP profile
Set the EPP mode.
Options:
·     PerformanceProvides maximum system performance at the expense of energy efficiency.
·     Balanced PerformanceProvides optimum performance with good energy efficiency.
·     Balanced PowerProvides optimum power efficiency with good performance.
·     PowerProvides maximum power efficiency (maximum power saving) at the expense of system performance.
CPU C State Control submenu screen
Figure 164 shows the CPU C State Control submenu screen. The submenu items are described in Table 118.
Figure 164 CPU C State Control submenu screen
Table 118 Items on the CPU C State Control submenu screen
Item
Autonomous Core C-State
Select Enabled or Disabled to enable or disable the autonomous core C-state.
If this item is enabled, the hardware autonomously chooses to enter a C-state based on power consumption and clock speed.
Disabled
CPU C6 Report
Select whether to enable the BIOS to report the C6 state to the operating system.
Options:
·     Enabled—Enables the BIOS to report the C6 state to the operating system.
·     Disabled—Disables the BIOS from reporting the C6 state to the operating system.
·     Auto—Enables the BIOS to report the C6 state to the operating system by default.
Disabled
Enhanced Halt State (C1E)
Select Enabled or Disabled to enable or disable the C1E feature.
C1E feature reduces the power consumption of a CPU by reducing its clock cycle and voltage during a Halt-state.
The C1E configuration takes effect after the server restarts.
Disabled
OS ACPI Cx
Select the ACPI to which the system reports C3/C6.
Options:
·     ACPI C2.
·     ACPI C3.
ACPI C2
Package C State Control submenu screen
Figure 165 shows the Package C State Control submenu screen. The submenu items are described in Table 119.
Figure 165 Package C State Control submenu screen
Table 119 Items on the Package C State Control submenu screen
Item
Package C State
Select the package C state limit.
Options:
·     C0/C1 state.
·     C2 state.
·     C6 (non Retention)state.
·     C6 (Retention) state.
·     No Limit.
·     Auto.
C0/C1 state
PKG C-state Lat. Neg.
Select Enabled or Disabled to enable or disable the package C-state latency negotiation feature.
Disabled
CPU Thermal Management submenu screen
Figure 166 shows the CPU Thermal Management submenu screen. The submenu items are described in Table 120.
Figure 166 CPU Thermal Management submenu screen
Table 120 Items on the CPU Thermal Management submenu screen
Item
CPU T State Control
CPU T-state control submenu, as shown in Figure 167.
The submenu items are described in Table 121.
N/A
PROCHOT Modes
Set the PROCHOT mode.
Options:
·     Output-only.
·     Disabled.
·     Both Input and Output.
·     Input-only.
Thermal Monitor
Select Enabled or Disabled to enable or disable processor temperature monitoring.
Enabled
PROCHOT RATIO
Set the PROCHOT ratio.
0
TCC Activation Offset
Set the offset value from the default TCC activation temperature at which thermal control circuit (TCC) is activated.
0
CPU T State Control submenu screen
Figure 167 shows the CPU T State Control submenu screen. The submenu items are described in Table 121.
Figure 167 CPU T State Control submenu screen
Table 121 Items on the CPU T State Control submenu screen
Item
Software Controlled T-State
Select Enabled or Disabled to enable or disable software controlled T-state.
Disabled
T-State Throttle Level
This item is available only when Software Controlled T-State is set to Enabled.
Select the T-state throttle level.
Options:
·     DisabledDisables T-state throttling.
·     6.25%.
·     12.5%.
·     18.75%.
·     25.0%.
·     31.25%.
·     37.5%.
·     43.75%.
·     50.0%.
·     56.25%.
·     62.5%.
·     68.75%.
·     75.0%.
·     81.25%.
·     87.5%.
·     93.75%.
The 6.25% and 12.5% options are unavailable for the B5700, B5800, and B7800.
Disabled
CPU Advanced PM Tuning submenu screen
Figure 168 shows the CPU Advanced PM Tuning submenu screen. The submenu items are described in Table 122.
Figure 168 CPU Advanced PM Tuning submenu screen
Table 122 Items on the CPU Advanced PM Tuning submenu screen
Item
Energy Perf BIAS
Energy and performance bias configuration submenu, on which you can configure the energy and performance policy for the system, as shown in Figure 169.
The submenu items are described in Table 123.
Energy Perf BIAS submenu screen
Figure 169 shows the Energy Perf BIAS submenu screen. The submenu items are described in Table 123.
Figure 169 Energy Perf BIAS submenu screen
Table 123 Items on the Energy Perf BIAS submenu screen
Item
Power Performance Tuning
This item is inaccessible when Hardware P-States is set to Out of Band Mode.
Select the operating system or the BIOS to control energy and performance bias tuning.
Options:
·     OS Controls EPB.
·     BIOS Controls EPB.
BIOS Controls EPB
PECI PCS EPB
This item is unconfigurable when Hardware P-States is set to Out of Band Mode or Power Performance Tuning is set to BIOS Controls EPB.
Select whether to authorize PECI with the control over EPB.
Options:
·     OS controls EPB—Enables the operating system to control EPB.
·     PECI controls EPB using PCS—Enables PECI to control EPB by using packet config space (PCS).
OS controls EPB
ENERGY_PERF_BIAS_CFG Mode
This item is available only when Energy Performance Tuning is set to BIOS Controls EPB.
Select an energy and performance bias option. The setting for this option overrides the energy and performance bias configured by the operating system.
Options:
·     PerformanceProvides maximum system performance (maximum cooling) at the expense of energy efficiency.
Performance
SOCKET RAPL Config submenu screen
Figure 170 shows the SOCKET RAPL Config submenu screen. The submenu items are described in Table 124.
Figure 170 SOCKET RAPL Config submenu screen
Table 124 Items on the SOCKET RAPL Config submenu screen
Item
FAST_RAPL_NSTRIKE_PL2_DUTY_CYCLE
Set FAST_RAPL_NSTRIKE_PL2_DUTY_CYCLE value.
Value range: 0 to 255.
64
Package RAPL Limit MSR Lock
Select Enabled or Disabled to lock or unlock the PACKAGE_RAPL_LIMIT MSR register.
Disabled
Package RAPL Limit CSR Lock
Select Enabled or Disabled to lock or unlock the PACKAGE_RAPL_LIMIT CSR register.
Enabled
PL1 Limit
Select Enabled or Disabled to enable or disable power limit 1 (PL1), including PL1 power limit and PL1 time window.
If this feature is disabled, the BIOS sets both PL1 power limit and PL1 time window to the default values.
Enabled
PL1 Power Limit
Set the PL1 power limit in watts. If this item is set to 0, the fused value is programmed.
Value range: 0 to the fused value.
0
PL1 Time Window
Set the PL1 time window value in seconds, which indicates the time window over which the TDP value must be maintained. If the value is set to 0, the fused value is programmed.
Value range: 0 to 56.
1
PL2 Limit
Select Enabled or Disabled to enable or disable PL2 limit, including PL2 power limit and PL2 time window.
If this feature is disabled, the BIOS sets both PL2 power limit and PL2 time window to the default values.
Enabled
PL2 Power Limit
Set the PL2 power limit in watts. If this item is set to 0, the fused value is programmed.
0
PL2 Time Window
Set the PL2 time window value in seconds, which indicates the time window over which the TDP value must be maintained. If the value is set to 0, the fused value is programmed.
1
Server Management menu
Figure 171 and Figure 172 show the Server Management menu. From the menu, you can access the firmware information menu, and configure server management features such as the FRB-2 timer, OS watchdog timer, system event logging, HDM network configuration, and HDM user settings.
AC Restore Settings, Load HDM Default, HDM User Settings, and HDM Network Configuration items are unavailable for the B5700, B5800, and B7800 servers.
The menu items are described in Table 125.
Figure 171 Server Management menu screen (for all servers except for the B5700, B5800, and B7800)
Figure 172 Server Management menu screen (for the B5700, B5800, and B7800)
Table 125 Items on the Server Management menu screen
Item
FRB-2 Timer
Select Enabled or Disabled to enable or disable the FRB-2 timer.
Enabled
FRB-2 Timer timeout
Set the timeout time for the FRB-2 timer.
Options:
·     3 minutes.
·     4 minutes.
·     5 minutes.
·     6 minutes.
·     10 minutes.
·     15 minutes.
·     20 minutes.
15 Minutes
FRB-2 Timer Policy
Select the action to take when the FRB-2 timer expires.
Options:
·     Do NothingNo action is taken.
·     Reset—Reboots the system.
·     Power Down—Removes the main power from the system.
·     Power Cycle—Power cycles the system.
Power Cycle
OS Watchdog Timer
Select Enabled or Disabled to enable or disable the OS watchdog timer.
The OS watchdog timer starts when the OS begins to run.
Disabled
OS Wtd Timer Timeout
This item is configurable only when OS Watchdog Timer is set to Enabled.
Set the timeout time for the OS watchdog timer.
Options:
·     5 Minutes.
·     10 Minutes.
·     15 Minutes.
·     20 Minutes.
10 Minutes
OS Wtd Timer Policy
Select the action to take when the OS watchdog timer expires.
Options:
·     Do Nothing—No action is taken.
·     Reset—Reboot the system.
Reset
AC Restore Settings
This item is unavailable for the B5700, B5800, and B7800.
Select the state to which the system is restored when the system AC power is restored.
Options:
·     Always Power On—The system always returns to the power-on state.
·     Always Remain Off—The system always returns to the power-off state.
·     Restore Last Power State—The system returns to the power state when AC power was lost.
Load HDM Default
This item is unavailable for the B5700, B5800, and B7800 .
To restore the factory default settings for HDM, select this item, and then press Enter. It takes one minute to restore the factory default HDM settings. After the restoration finishes, the server restarts automatically.
CAUTION CAUTION:
Do not configure HDM-related items before the server restarts.
N/A
View FRU information
Access the submenu for viewing FRU information, as shown in Figure 173.
The submenu items are described in Table 126.
N/A
Access the network configuration submenu for HDM access, as shown in Figure 176.
The submenu items are described in Table 127.
N/A
HDM User Settings
Access the submenu for managing HDM user accounts, as shown in Figure 177.
The submenu items are described in Table 128.
N/A
Firmware Information
Access the submenu that displays the firmware information, as shown in Figure 180.
The submenu items are described in Table 132.
N/A
View FRU information submenu
Figure 173 shows the View FRU information menu screen, on which you can view the FRU information. The menu items are described in Table 126.
Figure 173 View FRU information menu screen
Table 126 Items on the View FRU information menu screen
Item
System Manufacturer
Displays the manufacturer of the system.
System Product Name
Displays the name of the system product.
System Version
Displays the version of the system.
System Serial Number
Displays the serial number of the system.
Board Manufacturer
Displays the manufacturer of the system board.
Board Product Name
Displays the product name of the system board.
Board Version
Displays the version of the system board.
Board Serial Number
Displays the serial number of the system board.
Chassis Manufacturer
Displays the manufacturer of the chassis.
Chassis Version
Displays the version of the chassis.
Chassis Serial Number
Displays the serial number of the system product.
System Uuid
Displays the UUID of the system.
HDM Network Configuration submenu
Figure 174 and Figure 175 show the HDM Network Configuration menu screens, on which you can configure the HDM shared network port and the HDM dedicated network port. The menu items are described in Table 127.
HDM network configuration is not supported on the B5700, B5800, or B7800.
The configuration items for the HDM shared network port and the HDM dedicated network port are the same. This section uses the HDM shared network port as an example.
IMPORTANT
IMPORTANT:
·     Make sure the IP addresses of the HDM shared network port and the HDM dedicated network port are not in the same network segment.
·     The HDM dedicated network port for the B5700, B5800, and B7800 servers are unavailable, so the configuration items for the port are not displayed.
Figure 174 HDM Network Configuration submenu screen (IPv4)
Figure 175 HDM Network Configuration submenu screen (IPv6)
Table 127 Items on the HDM Network Configuration submenu screen
Item
Configure IPv4 Support
Sharelink Network
Select whether to enable the HDM shared network port. Options:
·     Enabled.
·     Disabled.
·     Auto—The system automatically enables the HDM shared network port as needed.
Enabled
HDM Active/standby Mode
Displays the enabling status of the active/standby mode.
With the active/standby mode enabled, you can configure different VLAN settings for the HDM dedicated and shared network ports.
With this mode enabled, the BIOS displays information only about the active port and allows users to configure only the active port.
N/A
VLAN Setting
Select Enabled or Disabled to enable or disable VLAN.
Disabled
VLAN id
This item is available only when VLAN Setting is set to Enabled.
Set the VLAN ID.
Value range: 2 to 4094.
2
VLAN priority
Set the priority of the VLAN.
Value range: 0 to 7. The greater the value, the higher the priority.
When congestion occurs, the port preferentially forwards packets for the VLAN with a higher priority.
0
Configuration Address source
Select the IP address obtaining method for the port.
Options:
·     Unspecified—Uses the current IP address obtaining method and settings.
·     Static—Uses the manually configured static IP address.
·     DynamicHdmDhcp—Obtains an IP address from a DHCP server.
Unspecified
Current Configuration Address source
Displays the current IP address obtaining method.
N/A
Station IP Address
This item is available only when the Configuration Address source item is set to Static.
Set the IP address of the port.
This setting takes effect only when the subnet mask is also set.
N/A
Subnet Mask
This item is available only when Configuration Address source is set to Static.
Set the subnet mask.
This setting takes effect only when the station IP address is also set.
N/A
Station MAC Address
Set the MAC address of the port.
N/A
Router IP Address
Set the gateway IP address.
N/A
Router MAC Address
Set the gateway MAC address.
N/A
Configure IPv6 Support
Select the IPv6 address obtaining method for the port.
Options:
Unspecified
Displays the current IPv6 address obtaining method.
N/A
Station IPv6 address
Set the IPv6 address of the port.
This setting takes effect only when the prefix length is also set.
N/A
Prefix Length
Set the subnet prefix length.
Value range: 1 to 127. The value of 0 indicates that the prefix length is not set.
This setting takes effect only when the station IPv6 address is also set.
0
IPv6 Router IP Address
Set the gateway IPv6 address.
Make sure the IPv6 address of the port and the gateway IPv6 address are on the same network segment.
N/A
IPv6 address status
Displays the status of the IPv6 address.
N/A
IPv6 DHCP Algorithm
Displays the DHCPv6 algorithm.
N/A
HDM User Settings submenu
Figure 176 shows the HDM User Settings menu screen, on which you can configure HDM users. The menu items are described in Table 128.
Figure 176 HDM User Settings submenu screen
Table 128 Items on the HDM User Settings submenu screen
Item
Add User
Submenu for adding an HDM user account, as shown in Figure 177.
The submenu items are described in Table 129.
Delete User
Submenu for deleting an HDM user account, as shown in Figure 178.
The submenu items are described in Table 130.
Change User Settings
Submenu for changing the settings of an existing HDM user account, as shown in Figure 179.
The submenu items are described in Table 131.
Figure 177 Add User submenu screen
Table 129 Items on the Add User submenu screen
Item
User Name
Specify the username, a case-sensitive string of 1 to 16 characters. The user name can contain letters, digits, and underscores (_).
N/A
User Password
Specify an HDM user password.
If password complexity check is enabled on the HDM Web interface, the password must meet the following requirements:
·     8 to 20 characters in length.
·     Case sensitive. Valid characters are letters, digits, spaces, and the following special characters: ` ~ ! @ # $ % ^ & * ( ) _ + - = [ ] \ { } | ; ' : " , . / < > ?
·     Must contain characters from at least two of the following categories: uppercase letters, lowercase letters, and digits.
·     Must contain at least one space or special character.
·     Must not be identical to the username or the reverse of the username.
If password complexity check is disabled on the HDM Web interface, the password must meet the following requirements:
·     2 to 20 characters in length.
By default, password complexity check is enabled on the HDM Web interface. For more information about enabling or disabling password complexity check, see HDM online help.
N/A
User Privilege Limit
Select a user role, which represents a set of network and service access privileges.
Options:
·     None—Retains the current privileges of the user account.
·     User—Assigns the user the read-only permission to HDM.
·     Operator—Assigns the user the read permission to all HDM features and write permission to a limited set of HDM features.
·     AdministratorAssigns the user read and write permissions to all HDM features.
None
User Access
Select Enabled or Disabled to permit or deny the user's access to HDM Web interface.
Disabled
Figure 178 Delete User submenu screen
Table 130 Items on the Delete User submenu screen
Item
User Name
Enter the username of the HDM user account to be deleted.
User Password
Enter the password of the HDM user account to be deleted.
Figure 179 Change User Settings submenu screen
Table 131 Items on the Change User Settings submenu screen
Item
User Name
Enter the username of an existing HDM user account.
N/A
User Password
Enter the password of the HDM user account.
If the account logout threshold set in HDM (the default is 5 login failures) is reached, the user account is locked for the specified duration (the default is 5 minutes).
N/A
User Access
This item is available only after you enter the correct username and password for the user account.
Disabled
Change User Password
Specify a new password.
The password must meet the complexity requirements described in Table 129.
N/A
Assign role-based privileges to the user account.
This item is available only after you specify the correct user name and password of an HDM user account.
Options:
·     Administrator—Assigns the user read and write permissions to all HDM features.
None
Firmware Information submenu
Figure 180 shows the Firmware Information menu screen. The menu items are described in Table 132.
Figure 180 Firmware Information submenu screen
Table 132 Items on the Firmware Information submenu screen
Item
BIOS Information
BIOS Vendor
Displays the BIOS vendor.
Compliancy
Displays the standard with which the BIOS is compliant.
Project Name
Displays the project name.
BIOS Version
Displays the BIOS version.
Build Date and Time
Displays the date and time of the BIOS build.
HDM Information
HDM Self Test Status
Displays the HDM self test status.
HDM Device ID
Displays the HDM device ID.
HDM Device Revision
Displays the HDM device revision.
HDM Firmware Revision
Displays the HDM firmware revision.
IPMI Version
Displays the IPMI version.
Security menu
Figure 181 and Figure 182 show the Security menu, on which you can configure security features such as setting the BIOS administrator and user passwords.
The menu items are described in Table 133.
Figure 181 Security menu screen (part 1)
Figure 182 Security menu screen (part 2)
Table 133 Items on the Security menu screen
Item
Password Description
Displays the password description.
Administrator Password
Set the administrator password. For more information about restrictions for setting the administrator password, see "Setting the administrator password."
User Password
Set the user password. For more information about restrictions for setting the user password, see "Setting the user password."
HDD Security Configuration
Displays hard disk drives that support security configuration, for example, P2:TS256GMTS800.
To configure security settings for a hard disk drive, select the disk drive and press Enter. The screen that opens is as shown in Figure 183, and the submenu items are described in Table 134.
Secure Boot Menu
Access the submenu for configuring secure boot, as shown in Figure 184.
The submenu items are described in Table 135.
Figure 183 HDD Security Configuration submenu screen
Hidden (2)
Table 134 Items on the HDD Security Configuration submenu screen
Item
Security Supported
Displays whether the hard disk drive supports security configuration.
Security Enabled
Displays whether an HDD user password has been set.
If an HDD user password has been set, you must provide the password to unlock the hard disk drive before using it.
Security Locked
Displays whether the hard disk drive is locked.
If the hard disk drive is locked, enter the user password to unlock it.
Security Frozen
Displays the security frozen status.
Options:
·     Yes—The hard disk drive can be used but you cannot configure a user password for it. To change the security frozen status to No, you must power cycle the server.
·     No—The hard disk drive is not frozen. You can set the HDD user password.
HDD User Pwd Status
Displays whether an HDD user password is set (Installed) or not (Not Installed).
Set User Password
Set an HDD user password.
If the HDD user password is set or removed, the setting on the BIOS will not affect the HDD password.
If this item is inaccessible or hiden, you can power cycle the server for this item to become accessible.
Figure 184 Secure Boot Menu submenu screen
Table 135 Items on the Secure Boot menu screen
Item
System Mode
Displays the system mode.
N/A
Secure Boot
Select Enabled or Disabled to enable or display secure boot.
If Disabled is selected, Not Active is also displayed. If Enabled is selected, Active is also displayed.
Disabled
Secure Boot Mode
Select a secure boot mode.
Options:
·     Standard.
·     Custom.
In custom boot mode, you can change the image execution policy and manage secure boot keys.
Custom
Restore Factory Keys
Restore the factory default secure boot keys.
N/A
Reset To Setup Mode
Reset the system mode to setup mode.
N/A
Key Management
Access the submenu for key management, as shown in Figure 185.
The submenu items are described in Table 136.
N/A
Figure 185 Key Management submenu screen
Table 136 Items on the Key Management submenu screen
Item
Vendor Keys
Displays whether the vendor keys have been modified.
Options:
·     ValidThe vendor keys have not been modified and are valid.
·     ModifiedThe vendor keys have beed modified or deleted.
N/A
Factory Key Provision
Select Enabled or Disabled to enable or disable provisioning the factory default keys when the system is in setup mode.
Disabled
Access the submenu for restoring factory default keys.
This operation forces the system to enter user mode and installs factory default secure boot keys.
N/A
Reset To Setup Mode
Access the submenu for resetting the system mode to setup mode.
N/A
Export Secure Boot Variables
Access the submenu for exporting all secure boot variables.
N/A
Enroll Efi Image
Access the submenu for enrolling the EFI image.
This operation enables secure boot for the image and enrolls a SHA256 hash of the PE image in the Authorized Signature Database (DB).
N/A
Device Guard Ready
Indicates the server is ready for device guard.
N/A
Remove ‘UEFI CA’ from DB
Access the submenu for removing UEFI CA from DB.
N/A
Restore DB defaults
Access the submenu for restoring all DB variables to factory defaults.
N/A
Platform Key(PK)
Access the submenu for managing the platform key.
Option is Update.
N/A
Key Exchange Keys
Access the submenu for managing key exchange keys.
Options:
·     Update.
·     Append.
N/A
Authorized Signatures
Access the submenu for configuring authorized signatures.
Options:
·     Update.
·     Append.
N/A
Forbidden Signatures
Access the submenu for managing forbidden signatures.
Options:
·     Update.
·     Append.
N/A
Authorized TimeStamps
Access the submenu for managing authorized timestamps.
Options:
·     Update.
·     Append.
N/A
OsRecovery Signatures
Access the submenu for configuring operating system recovery signatures.
Options:
·     Update.
·     Append.
N/A
Boot menu
Figure 186 shows the Boot menu, on which you can configure boot settings such as the boot type and boot sequence.
The menu items are described in Table 137.
Figure 186 Boot menu screen
Table 137 Items on the Boot menu screen
Item
Bootup NumLock State
Select On or Off to turn on or turn off the NumLock key on the numeric keypad of the keyboard at system boot.
On
Hide Logo
Select Enabled or Disabled to display or hide the logo on the boot screen.
Disabled
iFIST Boot
Select Enabled or Disabled to enable or disable iFIST boot.
If iFIST boot is disabled, the iFist item is not displayed on the BIOS startup screen as shown in Figure 2, and pressing F10 cannot boot iFIST.
Enabled
Boot mode select
Select a boot mode.
Options:
·     LEGACY.
·     UEFI.
UEFI
EFI Shell Boot
Select Enabled or Disabled to enable or disable shell boot.
Disabled
Fixed Boot Order Priorities
Displays the prioritized list of bootable devices from which the system can boot.
In legacy mode, a drive is displayed in the list only if it has the highest boot priority (BBS priority) among all the drives of the same type. To display a drive in this list, enter the BBS priorities submenu for the drive type, and then set this drive as the first boot option.
N/A
Boot Option #1
Set the first boot option.
To disable the first boot option, select Disabled for this item.
N/A
Boot Option #2
Set the second boot option.
To disable the second boot option, select Disabled for this item.
N/A
Boot Option #3
Set the third boot option.
To disable the third boot option, select Disabled for this item.
N/A
Boot Option #4
Set the fourth boot option.
To disable the fourth boot option, select Disabled for this item.
N/A
UEFI Hard Disk Drive BBS Priorities
Access the submenu for configuring the boot priorities of hard disk drives, as shown in Figure 187.
The submenu items are described in Table 138.
N/A
This item is available only in legacy boot mode.
Access the submenu for configuring the boot priorities of hard disk drives.
N/A
UEFI CDROM/DVD Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives, as shown in Figure 188.
The submenu items are described in Table 139.
N/A
This item is available only in legacy boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives.
N/A
UEFI Network Drive BBS Priorities
Access the submenu for configuring the boot priorities of available network drives, as shown in Figure 189.
The submenu items are described in Table 140.
N/A
Access the submenu for configuring the boot priorities of available network drives.
N/A
UEFI Other Drive BBS Priorities
Set the boot device priority sequence from the available UEFI other drives.
Options:
·     Embedded UEFI shell. This option is available only when EFI Shell Boot is set to Enabled.
·     USB devices with the capacity less than 32 GB.
·     Virtual drives.
Access the submenu for configuring the boot priorities of other devices, as shown in Figure 190.
The submenu items are described in Table 141.
N/A
Figure 187 UEFI Hard Disk Drive BBS Priorities
Table 138 Items on the UEFI Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a hard disk as the first boot option. To disable this boot option, select Disabled.
The number of available options varies by server configuration.
Figure 188 UEFI CDROM/DVD Drive BBS Priorities screen menu
Table 139 Items on the UEFI CDROM/DVD Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a CD- or DVD-ROM drive as the first boot option. To disable this boot option, select Disabled.
Figure 189 UEFI Network Drive BBS Priorities submenu screen
Table 140 Items on the UEFI Network Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a PXE boot device as the first boot option. To disable this boot option, select Disabled.
Boot Option #2
Select a PXE boot device as the second boot option. To disable this boot option, select Disabled.
Boot Option #3
Select a PXE boot device as the third boot option. To disable this boot option, select Disabled.
Boot Option #4
Select a PXE boot device as the fourth boot option. To disable this boot option, select Disabled.
Figure 190 UEFI Other Drive BBS Priorities submenu screen
Table 141 Items on the UEFI Other Drive BBS Priorities submenu screen
Item
Boot Option #1
Select the other type of boot devices as the first boot option. To disable this boot option, select Disabled.
Save & Exit menu
Figure 191 shows the Save & Exit menu, on which you can save the BIOS parameter settings and exit BIOS.
The menu items are described in Table 142.
Figure 191 Save & Exit menu screen
Table 142 Items on the Save & Exit menu screen
Item
Save Options
Save Changes and Exit
Exit with changes saved.
Discard Changes and Exit
Exit without saving changes.
Save Changes and Reset
Restart the server with changes saved.
Discard Changes and Reset
Restart the server without saving changes.
Save Changes
Save changes without exiting the BIOS.
Discard Changes
Discard changes without exiting the BIOS.
Default Options
Restore Defaults
Restore the factory-default settings.
Boot Override
Select a boot device option and press Enter to boot from that device.
This setting is a one-time setting that takes effect only at the next boot. Subsequent boots will use the boot order configured on the Boot menu screen.
UEFI: PXE IPv4 Slot9 mLOM: Port x – Intel(R) Ethernet Connection X722 for 1GbE
Select this item as a boot option for one-time boot override.
IBA 40G Slot 3D00 v1066
Acronyms and abbreviations
Table 143 Acronyms and abbreviations
Term
Definition
A
ACPI
Advanced Configuration and Power Interface
ADR
Asynchronous Dram Refresh
AHCI
Advanced Host Controller Interface
B
BIOS
Basic Input Output System
C
COD
Cluster On Die
CFG
Configure
CSM
Compatibility Support Module
D
DCU
Drive Control Unit
DMA
Direct Memory Access
DRAM
Dynamic Random Access Memory
DCPMM
Intel® Optane™ DC PMEM module
E
ECC
Error Checking and Correcting
EFI
Extensible Firmware Interface
EIST
EMS
Emergency Management Services
EMCA
Enhanced Machine Check Architecture
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDM
H3C Device Management
I
IDE
Integrated Drive Electronics
IIO
Integrated I/O Module
IMC
Integrated Memory Controller
IRQ
Interrupt Request
iSCSI
Internet Small Computer System Interface
L
LLC
Last Level Cache
LLDP
Link Layer Discovery Protocol
LUN
Logical Unit Number
M
MAC
Media Access Control
MCTP
Management Component Transport Protocol
ME
Management Engine
MMIO
Memory mapping I/O
MRC
Memory Reference Code
N
NIC
Network Interface Controller
NMI
Non-Maskable Interrupt
NUMA
Non Uniform Memory Access
O
OS
Operating System
P
PCH
Platform Controller Hub
PCI
Peripheral Component Interface
PCIe
Peripheral Component Interconnect Express
PCU
Power Controller Unit
PECI
Platform Environment Control Interface
PK
Platform Key
POR
Plan Of Record
POST
Power On Self Test
PXE
Preboot Execute Environment
R
RAID
Redundant Arrays of Independent Disks
RAPL
Running Average Power Limit
RAS
Reliability, Availability, Serviceability
RFO
Request For Ownership
ROM
Read-Only Memory
RTS/CTS
Request To Send/Clear To Send
S
SAS
Serial Attached SCSI
SATA
Serial Advanced Technology Attachment
SCSI
SEL
System Event Log
SMI
System Management Interrupt
SR-IOV
Single-Root I/O Virtualization
SMBIOS
System Management BIOS
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
TXT
Trusted Execution Technologies
U
UEFI
Unified Extensible Firmware Interface
UID
Unit Identification
UPI
Ultra Path Interconnect
V
VT-d
Intel Virtualization Technology For Directed I/O
VGA
Video Graphics Array
X
XHCI
eXtensible Host Controller Interface
