17-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath Firewall Series Configuration Guides(V7)-6W40017-Network Management and Monitoring Configuration Guide
15-Mirroring configuration
15-Mirroring configuration 74.97 KB
Configuring port mirroring
About port mirroring
Port mirroring copies the packets passing through a port to a port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports (called source ports).
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination connects to a data monitoring device and is the destination port (also known as the monitor port) of mirrored packets. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port A when the following conditions exist:
·     Port A is monitoring bidirectional traffic of Port B and Port C on the same device.
·     The packet travels from Port B to Port C.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
·     Inbound—Copies packets received.
·     Outbound—Copies packets sent.
·     Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through local mirroring groups. The mirroring sources and destination reside on the same device, which is directly connected to a data monitoring device. Packets received on the mirroring sources are sent through the mirroring destination to the data monitoring device.
Local port mirroring
Figure 1 Local port mirroring implementation
As shown in Figure 1, the source port (Port A) and the monitor port (Port B) reside on the same device. Packets received on Port A are copied to Port B. Port B then forwards the packets to the data monitoring device for analysis.
Restrictions: Hardware compatibility with port mirroring
Hardware
Port mirroring compatibility
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3
Yes on the following interfaces:
·     GE 1/0/0 through GE 1/0/13.
·     XGE 1/0/18 and XGE 1/0/19.
·     GE 1/0/22 through GE 1/0/29.
·     Interfaces on the four interface cards.
F100-A-G3, F100-E-G3
Yes
F100-C-G3, F100-M-G3, F100-S-G3
No
F1000-E-VG
Yes
F1000-S-VG
No
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2
Yes
F100-A-G2, F100-E-G2
Yes
F100-C-G2, F100-M-G2, F100-S-G2
No
F1000-C-EI, F100-A-EI, F100-A-SI, F100-E-EI
Yes
F100-C-EI
No
F100-A80-WiNet
Yes
F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet
No
F1000-C8180, F1000-C8170, F1000-C8160
Yes
F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110
No
F100-C-A6, F100-C-A5, F100-C-A3
No
F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W
No
F1000-C-HI, F100-A-HI
Yes
F100-C-HI, F100-S-HI
No
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI
Yes
LSPM6FWD8, LSQM2FWDSC8
No
Restrictions and guidelines: Port mirroring configuration
You cannot assign a fixed interface and an interface on an interface module to the same mirroring group.
Port mirroring across member devices in an IRF fabric is not supported, which means that the mirroring sources and destination must reside on the same member device.
Port mirroring is not supported on virtual interfaces.
If you configure an interface shared by multiple contexts as a source port, traffic of the source port will be sent to the monitor port without distinction of contexts.
When configuring a mirroring group, first configure the monitor port and then configure the source ports.
When one port mirroring group is configured to monitor the outbound or bidirectional traffic of source ports, the other mirroring group must be configured to monitor the incoming traffic of source ports.
A mirroring group can be configured with one monitor port and multiple source ports. A monitor port or source port of a mirroring group cannot be configured as the source port or monitor port of another mirroring group.
Configuring local port mirroring
Restrictions and guidelines for local port mirroring configuration
A local mirroring group takes effect only after it is configured with the monitor port and mirroring sources.
Local port mirroring tasks at a glance
To configure local port mirroring, perform the following tasks:
1.     Creating a local mirroring group
2.     Configuring mirroring sources
3.     Configuring the monitor port
2.     Create a local mirroring group.
mirroring-group group-id local
Restrictions and guidelines for mirroring source configuration
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
·     A mirroring group can contain multiple source ports.
·     A port can act as a source port for multiple mirroring groups.
·     A source port cannot be configured as a monitor port.
Configuring source ports
·     Configure source ports in system view.
a.     Enter system view.
b.     Configure source ports for a local mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
By default, no source port is configured for a local mirroring group.
·     Configure source ports in interface view.
b.     Enter interface view.
c.     Configure the port as a source port for a local mirroring group.
mirroring-group group-id mirroring-port { both | inbound | outbound }
By default, a port does not act as a source port for any local mirroring groups.
Do not enable the spanning tree feature on the monitor port.
Only one monitor port can be specified for a local mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
·     Configure the monitor port in system view.
b.     Configure the monitor port for a local mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
By default, no monitor port is configured for a local mirroring group.
·     Configure the monitor port in interface view.
c.     Configure the port as the monitor port for a mirroring group.
By default, a port does not act as the monitor port for any local mirroring groups.
Display and maintenance commands for port mirroring
Display mirroring group information.
display mirroring-group { group-id | all | local }
