04-DPI Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath Firewall Series Configuration Guides(V7)-6W40004-DPI Configuration Guide
10-WAF configuration
10-WAF configuration 228.96 KB
Configuring WAF
About WAF
The Web application firewall (WAF) feature monitors HTTP and HTTPS traffic to and from Web applications for malicious activity and to proactively take prevention actions.
WAF policies
WAF is implemented based on WAF policies. A WAF policy contains a set of WAF signatures for matching packets and the actions for the packets.
WAF signatures
The device compares packets with WAF signatures to detect, classify, and prevent network attacks.
Each WAF signature contains various attributes, including attack category, action, protected target, severity level, and direction. You can filter the WAF signatures that a WAF policy uses based on the WAF signature attributes.
The device supports only the predefined WAF signatures. They are automatically generated by the device based on the local signature library. You cannot modify or delete a predefined WAF signature.
WAF actions
When the device detects a matching packet for a WAF signature, it takes the actions specified for the signature on the packet.
The device supports the following signature actions:
·     Reset—Closes the TCP connections for matching packets by sending TCP reset messages.
·     Redirect—Redirects matching packets to a webpage.
·     Block-source—Drops matching packets and adds the packet sources to the IP blacklist. If the IP blacklist feature is enabled, the device blocks the packets from the blacklisted sources for a duration set by the block-period command. If the IP blacklist feature is not enabled, the device does not block the packets from the blacklisted sources.
To enable the IP blacklist feature, use the blacklist global enable command. For more information about the IP blacklist feature, see Security Configuration Guide.
For more information about the block-period command, see DPI Command Reference.
·     Drop—Drops matching packets.
·     Permit—Permits matching packets to pass.
·     Capture—Captures matching packets.
·     Logging—Logs matching packets.
WAF mechanism
WAF takes effect after you apply a WAF policy to a DPI application profile and use the DPI application profile in a security policy rule or object policy rule.
As shown in Figure 1, upon receiving a packet, the device performs the following operations:
1.     The device identifies the packet application layer protocol and extracts the packet signatures.
2.     The device determines the actions for the packet by comparing the extracted packet signatures with the WAF signatures in the WAF policy:
?     If the packet does not match any WAF signatures, the device permits the packet to pass.
?     If the packet matches only one WAF signature, the device takes the signature actions.
?     If the packet matches multiple WAF signatures, the device uses the following rules to select the actions:
-     If the matching WAF signatures have two or more actions, including redirect, drop, permit, and reset, the device takes the action of the highest priority. The actions in descending order of priority are reset, redirect, drop, and permit.
-     The device executes the block-source, capture, and logging actions if they are in the matching WAF signatures.
Figure 1 WAF mechanism
WAF signature library management
The device uses WAF signatures to inspect Web application layer traffic for malicious threats and attacks.
You can update the device WAF signature library to the latest version or roll back the library to the previous or the factory default version.
Updating the WAF signature library
The following methods are available for updating the WAF signature library on the device:
·     Automatic update.
The device automatically downloads the most up-to-date WAF signature file to update its local signature library periodically.
·     Triggered update.
The device downloads the most up-to-date WAF signature file to update its local signature library immediately after you trigger the operation.
·     Manual update.
Use this method when the device cannot obtain the WAF signature file automatically.
You must manually download the most up-to-date WAF signature file, and then use the file to update the signature library on the device.
Rolling back the WAF signature library
If filtering false alarms or filtering exceptions occur frequently, you can roll back the WAF signature library to the previous version or to the factory default version.
Restrictions: Hardware compatibility with WAF
Hardware
WAF compatibility
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3
Yes
F100-A-G3, F100-E-G3
Yes
F100-C-G3, F100-M-G3, F100-S-G3
No
F1000-E-VG
Yes
F1000-S-VG
No
F100-A-G2, F100-E-G2
Yes
F100-C-G2, F100-M-G2, F100-S-G2
No
F1000-C-EI, F100-A-EI, F100-A-SI, F100-E-EI
Yes
F100-C-EI
No
F100-A80-WiNet
Yes
F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet
No
F1000-C8180, F1000-C8170, F1000-C8160
Yes
F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110
No
F100-C-A6, F100-C-A5, F100-C-A3
No
F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W
No
F1000-C-HI, F100-A-HI
Yes
F100-C-HI, F100-S-HI
No
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI
Yes
LSPM6FWD8, LSQM2FWDSC8
Yes
Restrictions: Licensing requirements for WAF
The WAF module requires a license to run on the device. If the license expires, you can still use the WAF functions but you cannot upgrade the WAF signature library to the version released after the expiration time. For more information about licenses, see license management in Fundamentals Configuration Guide.
WAF tasks at a glance
To configure WAF, perform the following tasks:
1.     Creating a WAF policy
2.     Configuring WAF signature filtering criteria for a WAF policy
3.     Configuring WAF actions for a WAF policy
4.     Specifying a parameter profile for a WAF action
5.     Applying a WAF policy to a DPI application profile
6.     Activating WAF policy settings
7.     Using the DPI application profile in a security policy rule
8.     Using the DPI application profile in an object policy rule
9.     Managing the WAF signature library
By default, a newly created WAF policy uses all enabled WAF signatures and applies to the packet matching a signature the default signature action. You can filter the WAF signatures used by the WAF policy and change the signature actions.
2.     Create a WAF policy and enter its view.
waf policy policy-name
A default WAF policy named default exists. The default WAF policy uses all enabled WAF signatures on the device and cannot be modified or deleted.
By default, a WAF policy uses all enabled WAF signatures on the device. You can set criteria to filter WAF signatures that a WAF policy uses based on the signature attributes.
A WAF policy uses a WAF signature only if the signature matches all the configured criteria.
For certain attribute-based criterion (such as the action, direction, or severity level criterion), you can specify multiple attribute values. A WAF signature matches the criterion if it matches any of the specified attribute values.
2.     Enter WAF policy view.
3.     Configure the WAF signature filtering criteria.
?     Set a target criterion.
protected-target { target [ sub-target subtarget ]| all }
By default, the target attribute is not used for WAF signature filtering.
?     Set an attack category criterion.
attack-category { sub-category subcategory ] | all }
By default, the attack category attribute is not used for WAF signature filtering.
?     Set an action criterion.
action { block-source | drop | permit | reset } *
By default, the action attribute is not used for WAF signature filtering.
?     Set a direction criterion.
object-dir { client | server } *
By default, the direction attribute is not used for WAF signature filtering.
?     Set a severity level criterion.
severity-level { critical | high | low | medium } *
By default, the severity level attribute is not used for WAF signature filtering.
By default, the system applies the default actions of a WAF signature to packets matching the signature.
You can also configure global actions for a WAF policy or change the actions for individual WAF signatures in the policy.
The system selects the actions for packets matching a WAF signature in the following order:
1.     Actions configured for the WAF signature in the WAF policy.
2.     Actions configured for the WAF policy.
3.     Default actions of the WAF signature.
The logging keyword enables the WAF module to log packet matching events and send log messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output WAF logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view WAF logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
2.     Enter the view of a WAF policy.
3.     Specify the global packet processing actions for the WAF policy.
signature override all { { block-source | drop | permit | redirect | reset } | capture | logging } *
By default, no actions are specified for a WAF policy and the default actions of WAF signatures are applied to matching packets.
4.     (Optional.) Change the status or actions for a WAF signature.
signature override pre-defined signature-id { disable | enable } [ { block-source | drop | permit | redirect | reset } | capture | logging ] *
By default, the predefined WAF signatures use the actions and statuses defined by the system.
You can specify parameter profiles for WAF signature actions. A parameter profile is a set of parameters that determine how an action is executed. If you do not specify a parameter profile for an action, or if the specified profile does not exist, the default action parameter settings are used. For information about configuring parameter profiles, see "Configuring DPI engine."
2.     Specify a parameter profile for a WAF action.
waf { block-source | capture | logging | redirect } parameter-profile parameter-name
By default, no parameter profile is specified for a WAF action.
A WAF policy must be applied to a DPI application profile to take effect.
A DPI application profile can use only one WAF policy. If you apply different WAF policies to the same DPI application profile, only the most recent configuration takes effect.
2.     Enter DPI application profile view.
app-profile profile-name
For more information about this command, see DPI engine commands in DPI Command Reference.
3.     Apply a WAF policy to the DPI application profile.
waf apply policy policy-name mode { protect | alert }
By default, no WAF policy is applied to the DPI application profile.
After you edit the WAF policy settings, perform this task to activate the settings.
This task can cause temporary outage for all DPI services. As a best practice, perform the task after all DPI service policy and rule settings are complete.
For more information about activating DPI service module configuration, see "Configuring DPI engine."
2.     Activate WAF policy settings.
inspect activate
By default, WAF policy settings do not take effect.
2.     Enter security policy view.
security-policy { ip | ipv6 }
3.     Enter security policy rule view.
rule { rule-id | name name } *
4.     Set the rule action to pass.
action pass
The default rule action is drop.
5.     Use a DPI application profile in the rule.
profile app-profile-name
By default, no DPI application profile is used in a security policy rule.
2.     Enter object policy view.
object-policy { ip | ipv6 } object-policy-name
3.     Use a DPI application profile in an object policy rule.
rule [ rule-id ] inspect app-profile-name
By default, no DPI application profile is used in an object policy rule.
4.     Return to system view.
5.     Create a zone pair and enter zone pair view.
zone-pair security source source-zone-name destination destination-zone-name
For more information about zone pairs, see security zone configuration in Security Configuration Guide.
6.     Apply the object policy to the zone pair.
object-policy apply { ip | ipv6 } object-policy-name
By default, no object policy is applied to a zone pair.
You can update or roll back the version of the WAF signature library on the device.
·     Do not delete the /dpi/ folder in the root directory of the storage medium.
·     Do not perform WAF signature update or rollback when the device's free memory is below the normal state threshold. For more information about device memory thresholds, see device management in Fundamentals Configuration Guide.
·     For successful automatic and immediate signature update, make sure the device can resolve the domain name of the official website into an IP address through DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
·     Update only one signature library at a time. Do not perform signature library update until the existing signature library update is completed.
Scheduling automatic WAF signature library update
You can schedule automatic WAF signature library update if the device can access the signature database services on the official website. The device periodically obtains the latest signature file from the official website to update its local signature library according to the update schedule.
2.     Enable automatic WAF signature library update and enter automatic WAF signature library update configuration view.
waf signature auto-update
By default, automatic WAF signature library update is disabled.
3.     Schedule the update time.
By default, the device updates the WAF signature library at a random time between 01:00:00 and 03:00:00 every day.
4.     (Optional.) Configure the device to overwrite the current WAF signature library without backing up the library during an automatic signature library update.
override-current
By default, the device backs up the current WAF signature library as the previous version before performing an automatic WAF signature library update.
Triggering an immediate WAF signature update
Anytime you find a release of new signature version on the official website, you can trigger the device to immediately update the local signature library.
2.     Trigger an immediate WAF signature library update.
waf signature auto-update-now
Performing a WAF signature manual update
If the device cannot access the signature database services on the official website, use one of the following methods to manually update the WAF signature library on the device:
·     Local update—Updates the WAF signature library by using a locally stored update WAF signature file.
Store the update file on the master device for successful signature library update.
·     FTP/TFTP update—Updates the WAF signature library by using the file stored on the FTP or TFTP server.
2.     Manually update the WAF signature library on the device.
waf signature update [ override-current ] file-path
If a WAF signature library update causes exceptions or a high false alarm rate, you can roll back the WAF signature library.
Before rolling back the WAF signature library, the device backs up the current signature library as the previous version. For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
2.     Roll back the WAF signature library to the previous version or to the factory default version.
waf signature rollback { factory | last }
Display and maintenance commands for WAF
Display WAF policy information.
display waf policy policy-name
Display WAF signature library information.
display waf signature library
Display WAF signature information.
display waf signature [ pre-defined ] [ direction { any | to-client | to-server } ] [ category category-name | fidelity { high | low | medium } | severity { critical | high | low | medium } ] *
Display detailed information about a predefined WAF signature.
display waf signature pre-defined signature-id
WAF configuration examples
Example: Using the default WAF policy in a security policy
As shown in Figure 2, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
Configure the device to use the default WAF policy for attack detection and prevention.
Figure 2 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 2. (Details not shown.)
2.     Configure the security zones:
# Assign GigabitEthernet 1/0/1 to security zone Trust.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
# Assign GigabitEthernet 1/0/2 to security zone Untrust.
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
3.     Create an IP address object group named waffilter and configure an IP address object with subnet 192.168.1.0/24.
[Device] object-group ip address waffilter
[Device-obj-grp-ip-waffilter] network subnet 192.168.1.0 24
[Device-obj-grp-ip-waffilter] quit
4.     Apply the default WAF policy to a DPI application profile:
# Create a DPI application profile named sec and enter its view.
[Device] app-profile sec
# Apply the default WAF policy to the DPI application profile and set the policy mode to protect.
[Device-app-profile-sec] waf apply policy default mode protect
[Device-app-profile-sec] quit
5.     Activate the WAF policy settings.
[Device] inspect activate
6.     Configure a security policy:
# Create a security policy named ip and enter its view.
[Device] security-policy ip
# Create a security policy rule named waffilter. Configure the rule to apply DPI application profile sec to packets from security zone Trust to security zone Untrust with source IP addresses contained in IP address object group waffilter.
[Device-security-policy-ip] rule name waffilter
[Device-security-policy-ip-10-waffilter] source-zone trust
[Device-security-policy-ip-10-waffilter] source-ip waffilter
[Device-security-policy-ip-10-waffilter] destination-zone untrust
[Device-security-policy-ip-10-waffilter] action pass
[Device-security-policy-ip-10-waffilter] profile sec
[Device-security-policy-ip-10-waffilter] quit
# Activate rule matching acceleration.
[Device-security-policy-ip] accelerate enhance enable
[Device-security-policy-ip] quit
# Verify that the device can use the default WAF policy to detect and prevent known network attacks. (Details not shown.)
For example, if an incoming attack packet matches predefined WAF signature GNU_Bash_Remote_Code_Execution_Vulnerability(CVE-2014-6271), the device automatically applies the signature actions (reset and logging) to the packet.
Example: Using a user-defined WAF policy in a security policy
As shown in Figure 3, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
Perform the following tasks:
1.     Configure the device to use a WAF policy for attack detection and prevention.
2.     Enable predefined WAF signature 2 and specify actions drop and logging for the signature.
Figure 3 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 3. (Details not shown.)
4.     Configure a WAF policy:
# Create a WAF policy named waf1 and enter its view.
[Device] waf policy waf1
# Configure the server to client direction as signature filtering criterion in the WAF policy.
[Device-waf-policy-waf1] object-dir client
# Enable predefined WAF signature 2 and specify actions drop and logging for the signature.
[Device-waf-policy-waf1] signature override pre-defined 2 enable drop logging
[Device-waf-policy-waf1] quit
5.     Apply WAF policy waf1 to a DPI application profile:
# Create a DPI application profile named sec.
# Apply WAF policy waf1 to the DPI application profile and set the policy mode to protect.
[Device-app-profile-sec] waf apply policy waf1 mode protect
6.     Activate the WAF policy settings.
7.     Configure a security policy:
[Device-security-policy-ip] accelerate enhanced enable
# Verify that when a packet matches predefined WAF signature 2, the device executes the drop and logging actions.
Example: Manually updating the WAF signature library
As shown in Figure 4, LAN users in security zone Trust can access the following resources:
·     Internet resources in security zone Untrust.
·     The FTP server at 192.168.2.4/24 in security zone DMZ. The FTP login username and password are waf and 123, respectively.
Manually update the WAF signature library by using the latest WAF signature file stored on the FTP server.
Figure 4 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 4. (Details not shown.)
2.     Configure a security policy to enable the device to communicate with the FTP server in security zone DMZ:
# Assign GigabitEthernet 1/0/3 to zone DMZ.
[Device] security-zone name dmz
[Device-security-zone-DMZ] import interface gigabitethernet 1/0/3
[Device-security-zone-DMZ] quit
# Create a security policy rule named update. Configure the rule to permit bidirectional traffic between security zones Local and DMZ.
[Device-security-policy-ip] rule name update
[Device-security-policy-ip-11-update] source-zone local
[Device-security-policy-ip-11-update] source-zone dmz
[Device-security-policy-ip-11-update] destination-zone dmz
[Device-security-policy-ip-11-update] destination-zone local
[Device-security-policy-ip-11-update] action pass
[Device-security-policy-ip-11-update] quit
3.     Update the WAF signature library on the device by using WAF signature file waf-1.0.8-encrypt.dat on the FTP server.
[Device] waf signature update ftp://waf:[email protected]/waf-1.0.8-encrypt.dat
# Verify that the device WAF signature library is updated.
<Device> display waf signature library
Example: Configuring automatic WAF signature library update
As shown in Figure 5, LAN users in security zone Trust can access Internet resources in security zone Untrust.
Configure the device to automatically update the local WAF signature library at a random time between 08:30 a.m. and 09:30 a.m. every Saturday.
Figure 5 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 5. (Details not shown.)
2.     Configure DNS for the device to resolve the domain name of the official website into the IP address. (Details not shown.)
3.     Configure a security policy to allow LAN users in security zone Trust to access Internet resources in security zone Untrust. (Details not shown.)
4.     Configure automatic WAF signature library update:
# Enable automatic WAF signature library update.
[Device] waf signature auto-update
[Device-waf-autoupdate]
# Configure the device to perform automatic update at a random time between 08:30 a.m. and 09:30 a.m. every Saturday.
[Device-waf-autoupdate] update schedule weekly sat start-time 9:00:00 tingle 60
[Device-waf-autoupdate] quit
# Verify that the device WAF signature library is updated as scheduled.
Example: Using the default WAF policy in an object policy
As shown in Figure 6, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
Figure 6 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 6. (Details not shown.)
6.     Configure an object policy:
# Create an IPv4 object policy named waffilter and enter its view.
[Device] object-policy ip waffilter
# Configure an object policy rule to apply DPI application profile sec to packets with source IP addresses contained in IP address object group waffilter.
[Device-object-policy-ip-waffilter] rule inspect sec source-ip waffilter destination-ip any
[Device-object-policy-ip-waffilter] quit
7.     Create a zone pair between source security zone Trust and destination security zone Untrust, and apply object policy waffilter to the zone pair.
[Device] zone-pair security source trust destination untrust
[Device-zone-pair-security-Trust-Untrust] object-policy apply ip waffilter
[Device-zone-pair-security-Trust-Untrust] quit
Example: Using a user-defined WAF policy in an object policy
As shown in Figure 7, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
1.     ?Configure the device to use a WAF policy for attack detection and prevention.
3.     Apply WAF policy waf1 to zone pair between source security zone Trust and destination security zone Untrust.
Figure 7 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 7. (Details not shown.)
# Configure the server to client direction as signature filtering criteria in the WAF policy.
7.     Configure an object policy:
8.     Create a zone pair between source security zone Trust and destination security zone Untrust, and apply object policy waffilter to the zone pair.
As shown in Figure 8, LAN users in security zone Trust can access the following resources:
·     The FTP server at 192.168.2.1/24 in security zone DMZ. The FTP login username and password are waf and 123, respectively.
·     Manually update the WAF signature library by using the latest WAF signature file stored on the FTP server.
·     Configure the device to use the default WAF policy to detect and prevent known attacks on the network.
Figure 8 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 8. (Details not shown.)
2.     Enable the device to communicate with the FTP server:
# Configure ACL 2001 to permit all traffic.
[Device] acl basic 2001
[Device-acl-ipv4-basic-2001] rule permit
[Device-acl-ipv4-basic-2001] quit
# Create a zone pair between source security zone Local and destination security zone DMZ, and then apply ACL 2001 to the zone pair.
[Device] zone-pair security source local destination dmz
[Device-zone-pair-security-Local-DMZ] packet-filter 2001
[Device-zone-pair-security-Local-DMZ] quit
# Create a zone pair between source security zone DMZ and destination security zone Local, and the apply ACL 2001 to the zone pair.
[Device] zone-pair security source dmz destination local
[Device-zone-pair-security-DMZ-Local] packet-filter 2001
[Device-zone-pair-security-DMZ-Local] quit
3.     Update the device WAF signature library by using WAF signature file waf-1.0.8-encrypt.dat on the FTP server.
As shown in Figure 9, LAN users in security zone Trust can access Internet resources in security zone Untrust.
Figure 9 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 9. (Details not shown.)
3.     Configure an object policy to allow LAN users in security zone Trust to access Internet resources in security zone Untrust. (Details not shown.)
