06-VPN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command References(V7)-6W40006-VPN Command Reference
02-SSL VPN commands
02-SSL VPN commands 453.37 KB
SSL VPN commands· 1
aaa domain· 1
authentication use· 1
bandwidth· 2
certificate-authentication enable· 3
content-type· 4
default 4
default-policy-group· 5
description (shortcut view) 6
description (SSL VPN AC interface view) 6
display interface sslvpn-ac· 7
display sslvpn context 10
display sslvpn gateway· 13
display sslvpn ip-tunnel statistics· 15
display sslvpn policy-group· 19
display sslvpn port-forward connection· 20
display sslvpn session· 21
display sslvpn webpage-customize template· 23
dynamic-password enable· 24
emo-server 25
exclude· 26
execution (port forwarding item view) 26
execution (shortcut view) 27
file-policy· 28
filter ip-tunnel acl 29
filter ip-tunnel uri-acl 30
filter tcp-access acl 31
filter tcp-access uri-acl 32
filter web-access acl 33
filter web-access uri-acl 34
force-logout 35
force-logout max-onlines enable· 36
gateway· 36
heading· 37
http-redirect 38
idle-cut traffic-threshold· 39
include· 40
interface sslvpn-ac· 40
ip address· 41
ip-route-list 42
ip-tunnel access-route· 43
ip-tunnel address-pool (SSL VPN context view) 44
ip-tunnel address-pool (SSL VPN policy group view) 45
ip-tunnel bind address· 46
ip-tunnel dns-server 47
ip-tunnel interface· 48
ip-tunnel keepalive· 48
ip-tunnel log· 49
ip-tunnel rate-limit 50
ip-tunnel web-resource auto-push· 51
ip-tunnel wins-server 51
ipv6 address· 52
local-port 53
log resource-access enable· 54
log user-login enable· 55
login-message· 56
logo· 56
max-onlines· 57
max-users· 58
message-server 58
mtu· 59
new-content 60
old-content 60
password-authentication enable· 61
password-box hide· 62
policy-group· 62
port-forward· 63
port-forward-item·· 64
reset counters interface sslvpn-ac· 65
reset sslvpn ip-tunnel statistics· 66
resources port-forward· 66
resources port-forward-item·· 67
resources shortcut 68
resources shortcut-list 69
resources uri-acl 69
resources url-item·· 70
resources url-list 71
rewrite-rule· 72
rule· 72
service enable (SSL VPN context view) 74
service enable (SSL VPN gateway view) 74
session-connections· 75
shortcut 76
shortcut-list 76
shutdown· 77
sms-imc address· 77
sms-imc enable· 78
ssl client-policy· 79
ssl server-policy· 80
sslvpn context 80
sslvpn gateway· 81
sslvpn ip address-pool 82
sslvpn log enable· 83
sslvpn rbm-port 84
sslvpn webpage-customize· 84
timeout idle· 85
title· 86
uri-acl 87
url (file policy view) 87
url (URL item view) 88
url-item·· 89
url-list 90
url-mapping· 91
user 92
verify-code· 93
vpn-instance (SSL VPN context view) 93
vpn-instance (SSL VPN gateway view) 94
web-access ip-client auto-activate· 95
webpage-customize· 95
SSL VPN commands
aaa domain
Use aaa domain to specify an ISP domain for authentication, authorization, and accounting of SSL VPN users in an SSL VPN context.
Use undo aaa domain to restore the default.
aaa domain domain-name
undo aaa domain
The default ISP domain is used for authentication, authorization, and accounting of SSL VPN users in an SSL VPN context.
context-admin
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name must meet the following requirements:
·     The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
·     The name cannot be d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
An SSL VPN username cannot carry ISP domain information. After this command is executed, an SSL VPN gateway uses the specified ISP domain for authentication, authorization, and accounting of SSL VPN users in the context.
# Specify ISP domain myserver for authentication, authorization, and accounting of SSL VPN users in SSL VPN context ctx1.
[Sysname] sslvpn context ctx1
[Sysname-sslvpn-context-ctx1] aaa domain myserver
authentication use
Use authentication use to specify the authentication methods required for user login.
Use undo authentication use to restore the default.
authentication use { all | any-one }
To log in to an SSL VPN context, a user must pass all the authentication methods enabled for the context.
context-admin
all: Uses all enabled authentication methods.
any-one: Uses any enabled authentication method.
You can enable username/password authentication, certificate authentication, or both for an SSL VPN context. The authentication methods required for logging in to the SSL VPN context depend on the configuration of this command:
·     If the authentication use all command is configured, a user must pass all the enabled authentication methods for login.
·     If the authentication use any-one command is configured, a user can log in after passing any enabled authentication method.
# Configure SSL VPN context ctx to allow users to log in after passing any enabled authentication method.
[Sysname-sslvpn-context-ctx] authentication use any-one
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is 64 kbps for an interface.
context-admin
The expected bandwidth for an interface affects CBQ bandwidth and link costs in OSPF, OSPFv3, and IS-IS. For more information about CBQ bandwidth, see QoS configuration in ACL and QoS Configuration Guide. For more information about link costs, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 10000 kbps for SSL VPN AC 1000.
[Sysname] interface sslvpn-ac 1000
[Sysname-SSLVPN-AC1000] bandwidth 10000
Use certificate-authentication enable to enable certificate authentication.
Use undo certificate-authentication enable to disable certificate authentication.
Certificate authentication is disabled.
context-admin
After you enable certificate authentication, you must also execute the client-verify command in SSL server policy view. The SSL VPN gateway uses the digital certificate sent by an SSL VPN client to authenticate the client's identity. If the client's username and the username in the digital certificate are not the same, the client cannot log in to the SSL VPN gateway.
# Enable certificate authentication.
[Sysname-sslvpn-context-ctx] certificate-authentication enable
client-verify enable
client-verify optional
content-type
Use content-type to configure a file policy to rewrite a file in an HTTP response to a specific type of file.
Use undo content-type to restore the default.
content-type { css | html | javascript | other }
undo content-type
A file policy rewrites a file carried in an HTTP response to a file of the type indicated by the content-type field in the HTTP response.
File policy view
context-admin
css: Changes the file type to CSS.
html: Changes the file type to HTML.
javascript: Changes the file type to JavaScript.
other: Does not change the file type.
A file policy rewrites a file carried in an HTTP response to a file of the type specified by this command. If the specified file type is different from that indicated by the content-type field in the HTTP response, users might not be able to read the file correctly.
# Configure file policy fp to rewrite files to HTML files.
[Sysname-sslvpn-context-ctx] file-policy fp
[Sysname-sslvpn-context-ctx-file-policy-fp] content-type html
default
Use default to restore the default settings for an SSL VPN AC interface.
default
context-admin
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of sslvpn-ac 1000.
[Sysname-SSLVPN-AC1000] default
This command will restore the default settings. Continue? [Y/N]:y
Use default-policy-group to specify a policy group as the default policy group.
Use undo default-policy-group to restore the default.
default-policy-group group-name
No policy group is specified as the default policy group.
context-admin
group-name: Specifies a policy group by its name, a case-insensitive string of 1 to 31 characters. The specified policy group must have been created.
You can configure multiple policy groups for an SSL VPN context. When a remote user accesses the SSL VPN context, the AAA server issues the authorized policy group to the associated SSL VPN gateway. The user can access only the resources allowed by the authorized policy group. If the AAA server does not issue an authorized policy group to the user, the user can access only the resources allowed by the default policy group.
# Specify policy group pg1 as the default policy group.
[Sysname-sslvpn-context-ctx1] policy-group pg1
[Sysname-sslvpn-context-ctx1-policy-group-pg1] quit
[Sysname-sslvpn-context-ctx1] default-policy-group pg1
policy-group
Use description to configure a description for a shortcut.
No description is configured for a shortcut.
Shortcut view
context-admin
text: Specifies a description, a case-sensitive string of 1 to 63 characters.
# Configure a description for shortcut shortcut1.
[Sysname-sslvpn-context-ctx1] shortcut shortcut1
[Sysname-sslvpn-context-ctx1-shortcut-shortcut1] description shortcut1
The description of an interface is interface name Interface, for example, SSLVPN-AC1000 Interface.
context-admin
Configure descriptions for interfaces for identification and management purposes.
You can use the display interface command to display the configured interface descriptions.
# Configure a description of SSL VPN A for SSL VPN AC 1000.
[Sysname-SSLVPN-AC1000] description SSL VPN A
Use display interface sslvpn-ac to display SSL VPN AC interface information.
display interface [ sslvpn-ac [ interface-number ] ] [ brief [ description | down ] ]
context-admin
context-operator
sslvpn-ac [ interface-number ]: Specifies an SSL VPN AC interface by its number in the range of 0 to 4095. If you do not specify the sslvpn-ac keyword, this command displays information about all interfaces except virtual access (VA) interfaces. If you specify the sslvpn-ac keyword without the interface-number argument, this command displays information about all SSL VPN AC interfaces. For more information about VA interfaces, see PPP configuration in Layer 2—WAN Access Configuration Guide.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about SSL VPN AC 1000.
<Sysname> display interface sslvpn-ac 1000
SSLVPN-AC1000
Current state: UP
Line protocol state: DOWN
Description: SSLVPN-AC1000 Interface
Bandwidth: 64kbps
Link layer protocol is SSLVPN
SSLVPN-AC1000
Information about interface SSL VPN AC 1000.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
Most recent time the counters were cleared by using the reset counters interface command.
If the reset counters interface command has never been executed since the device starts up, this field displays Never.
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
# Display brief information about all SSL VPN AC interfaces.
<Sysname> display interface sslvpn-ac brief
Brief information of interfaces in route mode:
Protocol: (s) - spoofing
SSLVPN-AC1000        UP   DOWN     --
# Display brief information about SSL VPN AC 1000, including the complete interface description.
<Sysname> display interface sslvpn-ac 1000 brief description
SSLVPN-AC1000        UP    UP      1.1.1.1            SSLVPN-AC1000 Interface
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface sslvpn-ac brief down
SSLVPN-AC1000        ADM
SSLVPN-AC1001        ADM
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
·     DOWN—The data link layer protocol of the interface is down.
Primary IP
Primary IP address of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
Use display sslvpn context to display SSL VPN context information.
display sslvpn context [ brief | name context-name ]
context-admin
context-operator
brief: Displays brief SSL VPN context information. If you do not specify this keyword, the command displays detailed SSL VPN context information.
name context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command displays information about all SSL VPN contexts.
# Display detailed information about all SSL VPN contexts.
<Sysname> display sslvpn context
Context name: ctx1
  Operation state: Up
  AAA domain: domain1
  Certificate authentication: Enabled
  Password authentication: Enabled
  Authentication use: All
  Dynamic password: Enabled
  Code verification: Disabled
  Default policy group: Not configured
  Associated SSL VPN gateway: gw1
    Domain name: 1
  Associated SSL VPN gateway: gw2
    Virtual host: abc.com
  Associated SSL VPN gateway: gw3
  SSL client policy configured: ssl1
  SSL client policy in use: ssl
  Maximum users allowed: 200
  VPN instance:vpn1
  Idle timeout: 30 min
  Idle-cut traffic threshold: 100 Kilobytes
Context name: ctx2
  Operation state: Down
  Down reason: Administratively down
  AAA domain not specified
  Password authentication: Disabled
  Authentication use: Any-one
  Dynamic password: Disabled
  Default group policy: gp
  Associated SSL VPN gateway: -
  VPN instance not configured
  Idle timeout: 50 min
  Address pool: Conflicted with an IP address on the device
Context name
Name of the SSL VPN context.
Operation state
Operation state of the SSL VPN context:
·     Up—The context is running.
·     Down—The context is not running.
Down reason
Causes for the Down operations status:
·     Administratively down—The context is disabled. To enable the context, use the service enable command.
·     No gateway associated—The context is not associated with an SSL VPN gateway.
AAA domain
ISP domain for the SSL VPN context.
Whether certificate authentication is enabled for the SSL VPN context.
Whether username/password authentication is enabled for the SSL VPN context.
Authentication use
Authentication methods required for user login:
·     All—A user must pass all the enabled authentication methods to log in to the SSL VPN context.
·     Any-one—A user can log in to the SSL VPN context after passing any enabled authentication method.
Code verification
Whether code verification is enabled for the SSL VPN context.
Default policy group used by the SSL VPN context.
SSL VPN gateway associated with the SSL VPN context.
Domain name
Domain name specified for the SSL VPN context.
Virtual host
Virtual host name specified for the SSL VPN context.
SSL client policy configured for the SSL VPN context.
A newly configured SSL client policy takes effect only after the SSL VPN context is restarted.
SSL client policy being used by the SSL VPN context.
Maximum number of sessions allowed in the SSL VPN context.
VPN instance
VPN instance associated with the SSL VPN context.
Idle timeout
Maximum idle time of an SSL VPN session, in minutes.
SSL VPN idle session disconnection traffic threshold.
An IP address conflict was detected in the SSL VPN context.
# Display brief information about all SSL VPN contexts.
<Sysname> display sslvpn context brief
Context name   Admin   Operation   VPN instance   Gateway   Domain/VHost
ctx1           Up      Up          -              gw1       -/1
                                                  gw2       abc.com/-
                                                  gw3       -/-
ctx2           Down   Down         -              -         -/-
Context name
Admin
Administrative status of the SSL VPN context:
·     Up—The context has been enabled by using the service enable command.
·     Down—The context is disabled.
Operation
VPN instance
Gateway
Domain/VHost
Domain name or virtual host name specified for the SSL VPN context.
Use display sslvpn gateway to display SSL VPN gateway information.
display sslvpn gateway [ brief | name gateway-name ]
context-admin
context-operator
brief: Displays brief SSL VPN gateway information. If you do not specify this keyword, the command displays detailed SSL VPN gateway information.
name gateway-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command displays information about all SSL VPN gateways.
# Display detailed information about all SSL VPN gateways.
<Sysname> display sslvpn gateway
Gateway name: gw1
  Operation state: Up
  IP: 192.168.10.75  Port: 443
  HTTP redirect port: 80
  SSL server policy configured: ssl1
  SSL server policy in use: ssl
  Front VPN instance: vpn1
Gateway name: gw2
  IP: 0.0.0.0  Port: 443
  Front VPN instance: Not configured
Gateway name: gw3
  Operation state: Up
  IPv6: 3000::2  Port: 443
Table 5 Command output
Gateway name
Name of the SSL VPN gateway.
Operation state
Operation state of the SSL VPN gateway:
·     Up—The gateway is running.
·     Down—The gateway is not running.
Down reason
Causes for the Down operation status:
·     Administratively down—The SSL VPN gateway is disabled. To enable the gateway, use the service enable command.
·     VPN instance not exist—The VPN instance to which the SSL VPN gateway belongs does not exist.
·     Applying SSL server-policy failed—Failed to apply the SSL server policy to the SSL VPN gateway.
IP
IPv4 address of the SSL VPN gateway.
IPv6
IPv6 address of the SSL VPN gateway.
Port
Port number of the SSL VPN gateway.
HTTP redirect port
HTTP redirection port number of the SSL VPN gateway.
SSL server policy configured for the SSL VPN gateway.
A newly configured SSL server policy takes effect only after the SSL VPN gateway is restarted.
SSL server policy being used by the SSL VPN gateway.
Front VPN instance
Front VPN instance to which the SSL VPN gateway belongs.
# Display brief information about all SSL VPN gateways.
<Sysname> display sslvpn gateway brief
Gateway name                    Admin  Operation
gw1                             Up     Up
gw2                             Down   Down (Administratively down)
gw3                             Up     Up
Table 6 Command output
Gateway name
Admin
Administrative status of the SSL VPN gateway:
·     Up—The gateway has been enabled by using the service enable command.
·     Down—The gateway is disabled.
Operation
·     Down (Administratively down)—The gateway is disabled. To enable the gateway, use the service enable command.
·     Down (VPN instance not exist)—The gateway is down because the VPN instance to which the gateway belongs does not exist.
·     Down (Applying SSL server-policy failed)—The gateway is down because the SSL server policy failed to be applied to the gateway.
Use display sslvpn ip-tunnel statistics to display packet statistics for IP access users.
display sslvpn ip-tunnel statistics [ context context-name ] [ user user-name ]
context-admin
context-operator
context context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_).
user user-name: Specifies an IP access user by username, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command displays IP access packets statistics for all SSL VPN contexts.
If you only specify an SSL VPN context, this command displays IP access packet statistics for the specified context and for each SSL VPN user in the context.
If you only specify an SSL VPN user, this command displays IP access packet statistics for the specified user in all SSL VPN contexts.
If you specify both an SSL VPN context and user, this command displays IP access packet statistics for the specified user in the specified context.
# Display IP access packet statistics for all SSL VPN contexts.
<Sysname> display sslvpn ip-tunnel statistics
IP-tunnel statistics in SSL VPN context ctx1:
  Client:
    In bytes  : 125574               Out bytes  : 1717349
  Server:
    In bytes  : 1717349              Out bytes  : 116186
IP-tunnel statistics in SSL VPN context ctx2:
  Client:
    In bytes  : 521                  Out bytes  : 1011
  Server:
    In bytes  : 1011                 Out bytes  : 498
# Display IP access packet statistics for SSL VPN context ctx1 and for each user in the context.
<Sysname> display sslvpn ip-tunnel statistics context ctx1
  Client:
  Server:
SSL VPN session IP-tunnel statistics:
Context                       : ctx1
User                          : user1
Session ID                    : 1
User IPv4 address             : 192.168.56.1
Received requests             : 81
Sent requests                 : 0
Dropped requests              : 81
Received replies              : 0
Sent replies                  : 0
Dropped replies               : 0
Received keepalives           : 1
Sent keepalive replies        : 1
Received configuration updates: 0
Sent configuration updates    : 0
Context                       : ctx1
User                          : user2
Session ID                    : 2
User IPv6 address             : 1234::5001
Sent requests                 : 0
Sent replies                  : 0
Dropped replies               : 0
# Display IP access packet statistics for user user1 in all SSL VPN contexts.
<Sysname> display sslvpn ip-tunnel statistics user user1
Context                       : ctx1
User                          : user1
Session ID                    : 1
Sent requests                 : 0
Sent replies                  : 0
Dropped replies               : 0
Context                       : ctx2
User                          : user1
Session ID                    : 2
Sent requests                 : 0
Sent replies                  : 0
Dropped replies               : 0
Sent keepalives replies       : 1
# Display IP access packet statistics for user user1 in SSL VPN context ctx1.
<Sysname> display sslvpn ip-tunnel statistics context ctx1 user user1
Context                       : ctx1
User                          : user1
Session ID                    : 1
Sent requests                 : 0
Sent replies                  : 0
Dropped replies               : 0
Context                       : ctx1
User                          : user1
Session ID                    : 2
Sent requests                 : 0
Sent replies                  : 0
Dropped replies               : 0
Table 7 Command output
Context
SSL VPN context to which the SSL VPN user belongs.
User
Login username used by the SSL VPN user.
User IPv4 address
IPv4 address of the SSL VPN user.
User IPv6 address
IPv6 address of the SSL VPN user.
Received requests
Number of IP access requests received by the SSL VPN gateway from the user.
Sent requests
Number of IP access requests forwarded by the SSL VPN gateway to internal servers.
Dropped requests
Number of IP access requests dropped by the SSL VPN gateway.
Received replies
Number of IP access replies received by the SSL VPN gateway from internal servers.
Sent replies
Number of IP access replies forwarded by the SSL VPN gateway to the user.
Dropped replies
Number of IP access replies dropped by the SSL VPN gateway.
Received keepalives
Number of keepalive messages received by the SSL VPN gateway from the user.
Number of keepalive replies sent by the SSL VPN gateway to the user.
Number of configuration update messages received by the SSL VPN gateway from the user.
Number of configuration update messages sent by the SSL VPN gateway to the user.
Client
Statistics of the traffic transmitted between the SSL VPN gateway and the IP access client:
·     In bytes—Number of bytes received by the SSL VPN gateway from the client.
·     Out bytes—Number of bytes sent by the SSL VPN gateway to the client.
Server
Statistics of the traffic transmitted between the SSL VPN gateway and the server:
·     In bytes—Number of bytes received by the SSL VPN gateway from the server.
Use display sslvpn policy-group to display SSL VPN policy group information.
display sslvpn policy-group group-name [ context context-name ]
context-admin
context-operator
context context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command displays information about policy groups with the specified group name in all SSL VPN contexts.
# Display information about policy groups named pg1 in all SSL VPN contexts.
<Sysname> display sslvpn policy-group pg1
Group policy: pg1
  Context: context1
   Idle timeout: 35 min
  Context: context2
   Idle timeout: 40 min
Table 8 Command output
Idle timeout
Use display sslvpn port-forward connection to display TCP port forwarding connection information.
display sslvpn port-forward connection [ context context-name ] [ slot slot-number ]
context-admin
context-operator
context context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command displays TCP port forwarding connection information for all SSL VPN contexts.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays TCP port forwarding connection information for all member devices.
# Display TCP port forwarding connection information for all SSL VPN contexts.
<Sysname> display sslvpn port-forward connection
SSL VPN context  : ctx1
  Client address : 192.0.2.1
  Client port    : 1025
  Server address : 192.168.0.39
  Server port    : 80
  Slot           : 1
  Status         : Connected
SSL VPN context  : ctx2
  Client address : 3000::983F:7A36:BD06:342D
  Client port    : 56190
  Server address : 300::1
  Server port    : 23
  Slot           : 1
  Status         : Connecting
Table 9 Command output
Client address
IP address of the SSL VPN client.
Client port
Port number of the SSL VPN client.
Server address
IP address of the internal server.
Server port
Port number of the internal server.
Slot
IRF member ID of the device.
Status
Connection status, Connected or Connecting.
Use display sslvpn session to display SSL VPN session information.
display sslvpn session [ context context-name ] [ user user-name | verbose ]
context-admin
context-operator
context context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command displays SSL VPN session information for all SSL VPN contexts.
user user-name: Specifies an SSL VPN user by the username, a case-insensitive string of 1 to 63 characters. If you specify a user, this command displays detailed SSL VPN session information for the user. If you do not specify a user, this command displays brief SSL VPN session information for all users.
verbose: Displays detailed SSL VPN session information for all SSL VPN users. If you do not specify this keyword, the command displays brief SSL VPN session information for the specified or all SSL users.
# Display brief SSL VPN session information for all users in all SSL VPN contexts.
<Sysname> display sslvpn session
Total users: 4
SSL VPN context: ctx1
Users: 2
Username        Connections  Idle time   Created       User IP
user1           5            0/00:00:23  0/04:47:16    192.0.2.1
user2           5            0/00:00:46  0/04:48:36    192.0.2.2
SSL VPN context: ctx2
Users: 2
user3           5            0/00:00:30  0/04:50:06    192.168.2.1
user4           5            0/00:00:50  0/04:51:16    192.168.2.2
Table 10 Command output
Total users
Total number of users in all SSL VPN contexts.
SSL VPN context
Users
Number of users in the SSL VPN context.
Username
Login name for the SSL VPN session.
Connections
Number of connections in the SSL VPN session.
Idle time
Duration that the SSL VPN session has been idle, in the format of days/hh:mm:ss.
Created
Time elapsed since the SSL VPN session was created, in the format of days/hh:mm:ss.
User IP
IP address used by the SSL VPN session.
# Display SSL VPN session information for SSL VPN user user1.
<Sysname> display sslvpn session user user1
User              : user1
Context           : context1
Policy group      : pgroup
Idle timeout      : 30 min
Created at        : 13:49:27 UTC Wed 05/14/2014
Lastest           : 17:50:58 UTC Wed 05/14/2014
User IPv4 address : 192.0.2.1
Session ID        : 1
Web browser/OS    : Internet Explorer
User              : user1
Context           : context2
Policy group      : Default
Idle timeout      : 2100 sec
Created at        : 14:15:12 UTC Wed 05/14/2014
Lastest           : 18:56:58 UTC Wed 05/14/2014
User IPv6 address : 0:30::983F:7A36:BD06:342D
Session ID        : 5
# Display detailed SSL VPN session information for all users in all SSL VPN contexts.
<Sysname> display sslvpn session verbose
User              : user1
Context           : context1
Session ID        : 1
User              : user1
Context           : context2
Session ID        : 5
Table 11 Command output
User
SSL VPN username.
Context
Context to which the user belongs.
Policy group
Policy group used by the user.
Idle timeout
Idle timeout time of the SSL VPN session, in seconds.
Created at
Time at which the SSL VPN session was created.
Lastest
Most recent time when the SSL VPN user accessed resources through the SSL VPN session.
Allocated IP
IP address allocated to the iNode client of the SSL VPN user.
This field is displayed only for iNode users.
User IPv4 address
IPv4 address used by the SSL VPN session.
User IPv6 address
IPv6 address used by the SSL VPN session.
Web browser/OS
Web browser or operating system used by the SSL VPN user.
Use display sslvpn webpage-customize template to display SSL VPN webpage template information.
context-admin
context-operator
# Display information about all webpage templates.
<Sysname> display sslvpn webpage-customize template
Template name            Type              Status
default                  Pre-defined       Normal
system                   Pre-defined       Normal
User1                    User-defined      File login.html missing
User2                    User-defined      File home.html missing
Table 12 Command output
Template name
Name of the SSL VPN webpage template.
Type of the SSL VPN webpage template:
·     Pre-defined.
·     User-defined.
Status
State of the SSL VPN webpage template:
·     Normal—The template is complete and can be used.
·     File login.html missing—The login.html file is missing in the template.
·     File home.html missing—The home.html file is missing in the template.
webpage-customize
Use dynamic-password enable to enable dynamic password verification.
Use undo dynamic-password enable to disable dynamic password verification.
Dynamic password verification is disabled.
context-admin
After dynamic password verification is enabled, a user must enter a correct dynamic password to log in to the SSL VPN webpage.
# Enable dynamic password verification.
[Sysname-sslvpn-context-ctx] dynamic-password enable
emo-server
Use emo-server to specify an Endpoint Mobile Office (EMO) server for mobile clients.
Use undo emo-server to restore the default.
emo-server address { host-name | ipv4-address } port port-number
undo emo-server
No EMO server is specified for mobile clients.
context-admin
address: Specifies the host name or IPv4 address of the EMO server.
host-name: Specifies the host name of the EMO server, a case-insensitive string of 1 to 127 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.).
ipv4-address: Specifies the IPv4 address of the EMO server, in dotted decimal notation. The IP address cannot be a multicast, broadcast, or loopback address.
port port-number: Specifies the port number of the EMO server, in the range of 1025 to 65535.
An EMO server provides services for mobile clients. The SSL VPN gateway issues the EMO server information to the clients, and the clients can access available service resources through the EMO server.
# Specify the IP address of the EMO server as 10.10.1.1 and the port number as 9058 for context ctx1.
[Sysname-sslvpn-context-ctx1] emo-server address 10.10.1.1 port 9058
exclude
Use exclude to add an excluded route to a route list.
Use undo exclude to delete an excluded route from a route list.
exclude ip-address { mask | mask-length }
undo exclude ip-address { mask | mask-length }
No excluded routes exist in a route list.
Route list view
context-admin
ip-address: Specifies the destination IP address of the route. It cannot be a multicast, broadcast, or loopback address.
mask: Specifies the subnet mask of the destination IP address.
mask-length: Specifies the mask length of the destination IP address, an integer in the range of 0 to 32.
To deny user access to specific network nodes or segments behind an SSL VPN gateway, configure excluded routes for those nodes or segments.
When a client accesses the SSL VPN gateway in IP access mode, the SSL VPN gateway issues excluded routes to the client. The client adds the excluded routes to the local routing table. Traffic that matches the excluded routes are not sent to the SSL VPN gateway.
You can add multiple excluded routes to a route list.
If you execute the include and exclude commands to add the same route to a route list, the most recent configuration takes effect.
# Add excluded route 192.168.0.0/16 to route list rtlist.
[Sysname-sslvpn-context-ctx1] ip-route-list rtlist
[Sysname-sslvpn-context-ctx1-route-list-rtlist] exclude 192.168.0.0 16
include
Use execution to configure a resource link for a port forwarding item.
Use undo execution to restore the default.
execution script
undo execution
No resource link is configured for a port forwarding item.
Port forwarding item view
context-admin
script: Specifies the script for the resource link, a string of 1 to 255 characters.
You can configure a resource link in either of the following methods:
·     Enter the script for a resource in the format of url(‘url-value’). The url-value argument specifies the corresponding resource. The complete format for url-value is protocol://hostname or address:port number/resource path.
·     Enter an any-format JavaScript executable for a resource to provide access to the resource.
After you configure a resource link for a port forwarding item, you can click the port forwarding name on the SSL VPN Web page to access the resource.
If you execute this command for a port forwarding item multiple times, the most recent configuration takes effect.
# Configure the url(‘http://127.0.0.1’) resource for port forwarding item pfitem1.
[Sysname-sslvpn-context-ctx1] port-forward-item pfitem1
[Sysname-sslvpn-context-ctx1-forward-item-pfitem1] execution url(‘http://127.0.0.1’)
Use execution to configure a resource link for a shortcut.
execution script
undo execution
No resource link is configured for a shortcut.
Shortcut view
context-admin
script: Specifies the script for the resource, a string of 1 to 255 characters.
After you configure a resource link for a shortcut, you can click the shortcut name on the SSL VPN Web page to access the resource.
If you execute this command for a shortcut multiple times, the most recent configuration takes effect.
# Configure the url(‘http://10.0.0.1’) resource for shortcut shortcut1.
[Sysname-sslvpn-context-ctx1-shortcut-shortcut1] execution url(‘http://10.0.0.1’)
file-policy
Use file-policy to create a file policy and enter its view, or enter the view of an existing file policy.
Use undo file-policy to delete a file policy.
file-policy policy-name
undo file-policy policy-name
No file policies exist.
context-admin
policy-name: Specifies a file policy name, a case-insensitive string of 1 to 31 characters.
The SSL VPN gateway uses a file policy to rewrite the content of Web page files before forwarding them to requesting Web access users.
You can configure multiple file policies in an SSL VPN context.
# Create a file policy named fp and enter its view.
sslvpn context
Use filter ip-tunnel acl to specify an advanced ACL for IP access filtering.
Use undo filter ip-tunnel acl to remove the advanced ACL configuration for IP access filtering.
filter ip-tunnel [ ipv6 ] acl advanced-acl-number
undo filter ip-tunnel [ ipv6 ] acl
All IP accesses are denied.
context-admin
ipv6: Specifies an IPv6 ACL. Do not configure this keyword if you want to specify an IPv4 ACL.
acl advanced-acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999. If a rule in the specified ACL contains VPN settings, the rule does not take effect.
You can specify both an advanced ACL and a URI ACL for IP access filtering.
The SSL VPN gateway uses the following procedure to determine whether to forward an IP access request:
1.     Matches the request against rules in the URI ACL:
¡     If the request matches a permit rule, the gateway forwards the request.
¡     If the request matches a deny rule, the gateway drops the request.
¡     If the request does not match any rules in the URI ACL or if no URI ACL is available, the gateway proceeds to step 2.
2.     Matches the request against rules in the advanced ACL:
¡     If the request does not match any rules in the advanced ACL or if no advanced ACL is available, the gateway drops the request.
You can specify an IPv4 ACL, IPv6 ACL, or both by using this command, but you cannot specify multiple IPv4 ACLs or IPv6 ACLs. If you specify IPv4 or IPv6 ACLs multiple times, the most recent IPv4 or IPv6 ACL configuration takes effect.
# Configure policy group pg1 to use IPv4 ACL 3000 and IPv6 ACL 3500 for IP access filtering.
[Sysname-sslvpn-context-ctx1-policy-group-pg1] filter ip-tunnel acl 3000
[Sysname-sslvpn-context-ctx1-policy-group-pg1] filter ip-tunnel ipv6 acl 3500
Use filter ip-tunnel uri-acl to specify a URI ACL for IP access filtering.
Use undo filter ip-tunnel uri-acl to remove the URI ACL configuration for IP access filtering.
filter ip-tunnel uri-acl uri-acl-name
context-admin
uri-acl-name: Specifies a URI ACL by its name, a case-insensitive string of 1 to 31 characters. The specified URI ACL must already exist.
If a rule in the URI ACL specified for IP access filtering contains HTTP or HTTPS settings, the rule does not take effect.
# Configure policy group abcpg to use URI ACL abcuriacl for IP access filtering.
[Sysname] sslvpn context abc
[Sysname-sslvpn-context-abc] policy-group abcpg
[Sysname-sslvpn-context-abc-policy-group-abcpg] filter ip-tunnel uri-acl abcuriacl
Use filter tcp-access acl to specify an advanced ACL for TCP access filtering.
Use undo filter tcp-access acl to remove the advanced ACL configuration for TCP access filtering.
filter tcp-access [ ipv6 ]  acl advanced-acl-number
undo filter tcp-access [ ipv6 ]  acl
A user can access only the TCP resources in the TCP port forwarding list authorized to the user.
context-admin
You can specify both an advanced ACL and a URI ACL for TCP access filtering.
For mobile client users, the SSL VPN gateway uses the following procedure to determine whether to forward a TCP access request:
1.     Matches the request against the authorized port forwarding list.
¡     If the request matches a port forwarding item in the list, the gateway forwards the request.
¡     If the request does not match any port forwarding items in the list, the gateway proceeds to step 2.
2.     Matches the request against the rules in the URI ACL:
¡     If the request does not match any rules in the URI ACL or if no URI ACL is available, the gateway proceeds to step 3.
3.     Matches the request against the rules in the advanced ACL:
For PC users, the ACLs configured for TCP access filtering do not take effect. They can access only the TCP resources authorized to them through the TCP port forwarding list.
# Configure policy group pg1 to use IPv4 ACL 3000 and IPv6 ACL 3500 for TCP access filtering.
[Sysname]sslvpn context ctx1
[Sysname-sslvpn-context-ctx1-policy-group pg1] filter tcp-access acl 3000
[Sysname-sslvpn-context-ctx1-policy-group pg1] filter tcp-access ipv6 acl 3500
Use filter tcp-access uri-acl to specify a URI ACL for TCP access filtering.
Use undo filter tcp-access uri-acl to remove the URI ACL configuration for TCP access filtering.
filter tcp-access uri-acl uri-acl-name
context-admin
¡     If the request matches a port forwarding items in the list, the gateway forwards the request.
# Configure policy group abcpg to use URI ACL abcuriacl2 for TCP access filtering.
[Sysname-sslvpn-context-abc-policy-group-abcpg] filter tcp-access uri-acl abcuriacl2
Use filter web-access acl to specify an advanced ACL for Web access filtering.
Use undo filter web-access acl to remove the advanced ACL configuration for Web access filtering.
filter web-access [ ipv6 ]  acl advanced-acl-number
undo filter web-access [ ipv6 ]  acl
A user can access only the Web resources in the URL list authorized to the user.
context-admin
You can specify both an advanced ACL and a URI ACL for Web access filtering.
The SSL VPN gateway uses the following procedure to determine whether to forward a Web access request:
1.     Matches the request against the authorized URL list.
¡     If the request matches a URL item in the list, the gateway forwards the request.
¡     If the request does not match any URL entries in the list, the gateway proceeds to step 2.
2.     Matches the request against rules in the URI ACL:
3.     Matches the request against rules in the advanced ACL:
# Configure policy group pg1 to use IPv4 ACL 3000 and IPv6 ACL 3500 for Web access filtering.
[Sysname-sslvpn-context-ctx1-policy-group pg1] filter web-access acl 3000
[Sysname-sslvpn-context-ctx1-policy-group pg1] filter web-access ipv6 acl 3500
Use filter web-access uri-acl to specify a URI ACL for Web access filtering.
Use undo filter web-access uri-acl to remove the URI ACL configuration for Web access filtering.
filter web-access uri-acl uri-acl-name
Users can access only the Web resources authorized to them through the URL list.
context-admin
# Configure policy group abcpg to use URI ACL abcuriacl1 for Web access filtering.
[Sysname-sslvpn-context-abc-policy-group-abcpg] filter web-access uri-acl abcuriacl1
force-logout
Use force-logout to force online users to log out.
force-logout [ all | session session-id | user user-name ]
context-admin
all: Logs out all users.
session session-id: Logs out all users in a session. The session-id argument specifies the session ID in the range of 1 to 4294967295.
user user-name: Logs out a user. The user-name argument specifies the username, a case-sensitive string of 1 to 63 characters.
# Log out all users in session 1.
[Sysname-sslvpn-context-ctx1] force-logout session 1
force-logout max-onlines enable to enable the force logout feature.
undo force-logout max-onlines enable to disable the force logout feature.
The force logout feature is disabled.
context-admin
By default, a user cannot log in if the number of logins using the account reaches the limit.
When a login is attempted but logins using the account reach the maximum, this feature logs out the user with the longest idle time to allow the new login.
# Enable the force logout feature.
[Sysname-sslvpn-context-ctx1] force-logout max-onlines enable
gateway
Use gateway to associate an SSL VPN context with an SSL VPN gateway.
Use undo gateway to remove associated SSL VPN gateways.
gateway gateway-name [ domain domain-name | virtual-host virtual-host-name ]
undo gateway [ gateway-name ]
An SSL VPN context is not associated with an SSL VPN gateway.
context-admin
gateway-name: Specifies an SSL VPN gateway by its name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, and underscores (_).
domain domain-name: Specifies a domain name for the SSL VPN context, a case-insensitive string of 1 to 127 characters.
virtual-host virtual-host-name: Specifies a virtual host name for the SSL VPN context, a case-insensitive string of 1 to 127 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.).
When you associate an SSL VPN context with an SSL VPN gateway, follow these guidelines:
·     Make sure the context has a domain name or virtual host name different than any existing contexts associated with the SSL VPN gateway.
The SSL VPN gateway uses the domain name or virtual host name that a remote user entered to determine the SSL VPN context to which the user belongs.
·     If you do not specify a domain name or virtual host name for the context, you cannot associate other SSL VPN contexts with the SSL VPN gateway.
You can associate an SSL VPN context with a maximum of 10 SSL VPN gateways.
# Associate SSL VPN context ctx1 with SSL VPN gateway gw1, and specify the domain name as domain1 for the context.
[Sysname-sslvpn-context-ctx1] gateway gw1 domain domain1
heading
Use heading to configure a heading for a URL list.
Use undo heading to restore the default.
heading string
undo heading
The heading of a URL list is Web.
URL list view
context-admin
string: Specifies a URL list heading, a case-sensitive string of 1 to 31 characters.
# Specify urlhead as the heading of URL list url.
[Sysname-sslvpn-context-ctx1] url-list url
[Sysname-sslvpn-context-ctx1-url-list-url] heading urlhead
sslvpn context
url-list
http-redirect
Use http-redirect to enable HTTP redirection.
Use undo http-redirect to disable HTTP redirection.
http-redirect [ port port-number ]
undo http-redirect
HTTP redirection is disabled. An SSL VPN gateway does not process HTTP traffic.
context-admin
port-number: Specifies the HTTP port number to listen to, a value of 80 (the default) or in the range of 1025 to 65535.
This command enables an SSL VPN gateway to perform the following operations:
1.     Listen to an HTTP port.
2.     Redirect HTTP requests with the port number to the port used by HTTPS.
3.     Send redirection packets to clients.
# Enable HTTP redirection for HTTP port 1025.
[Sysname] sslvpn gateway gateway1
[Sysname-sslvpn-gateway-gateway1] http-redirect port 1025
Use idle-cut traffic-threshold to set the SSL VPN session idle-cut traffic threshold.
Use undo idle-cut traffic-threshold to restore the default.
idle-cut traffic-threshold kilobytes
The SSL VPN session idle-cut traffic threshold is 0 Kilobytes. An SSL VPN session will be disconnected if no traffic is transmitted within the session idle timeout.
context-admin
kilobytes: Specifies the session idle-cut traffic threshold in Kilobytes. The value range is 1 to 4294967295.
The SSL VPN session idle-cut traffic threshold refers to the minimum traffic required in the session idle timeout interval for a session not to be disconnected as an idle session.
After the idle-cut traffic threshold is set, the system counts the traffic transmitted in each SSL VPN session at intervals specified by the timeout idle command. If the traffic is less than the idle-cut traffic threshold, the system determines the session to be idle and disconnects the session.
If you change the setting of the idle-cut traffic-threshold or timeout idle command in an SSL VPN context, all session idle-cut traffic counters in the SSL VPN context will be cleared.
# Set the SSL VPN session idle-cut traffic threshold to 1000 Kilobytes in SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] idle-cut traffic-threshold 1000
timeout idle
include
Use include to add an included route to a route list.
Use undo include to delete an included route from a route list.
include ip-address { mask | mask-length }
undo include ip-address { mask | mask-length }
No included routes exist.
Route list view
context-admin
ip-address: Specifies the destination IP address of the route. It cannot be a multicast, broadcast, or loopback address. The specified IP address must be the address of the network segment where the internal servers reside.
mask: Specifies the subnet mask.
mask-length: Specifies the mask length of the route, an integer in the range of 0 to 32.
To permit user access to specific network nodes or segments behind an SSL VPN gateway, configure included routes for those nodes or segments.
When a client accesses an SSL VPN gateway in IP access mode, the SSL VPN gateway issues the included routes to the client. The client adds the included routes to the local routing table, using the VNIC as the output interface. Traffic that matches the included routes are sent to the SSL VPN gateway through the VNIC.
You can add multiple included routes to a route list.
# Add included route 10.0.0.0/8 to route list rtlist.
[Sysname-sslvpn-context-ctx1-route-list-rtlist] include 10.0.0.0 8
exclude
interface sslvpn-ac
Use interface sslvpn-ac to create an SSL VPN AC interface and enter its view, or enter the view of an existing SSL VPN AC interface.
Use undo interface sslvpn-ac to delete an SSL VPN AC interface.
interface sslvpn-ac interface-number
undo interface sslvpn-ac interface-number
No SSL VPN AC interfaces exist.
context-admin
interface-number: Specifies an SSL VPN AC interface number in the range of 0 to 4095.
# Create SSL VPN AC 1000 and enter its view.
<Sysname>system-view
[Sysname]interface SSLVPN-AC 1000
ip address
Use ip address to configure an IPv4 address and a port number for an SSL VPN gateway.
Use undo ip address to restore the default.
ip address ip-address [ port port-number ]
undo ip address
An SSL VPN gateway uses IPv4 address 0.0.0.0 and port number 443.
context-admin
ip-address: Specifies an IP address for the SSL VPN gateway, in dotted decimal notation.
port port-number: Specifies a port number for the SSL VPN gateway. The port number is 443 (the default value) or in the range of 1025 to 65535.
A remote user uses the IPv4 address and port number configured by this command to access an SSL VPN gateway.
The specified IPv4 address must be the IP address of an interface on the gateway device and is reachable from clients and internal servers.
If the gateway uses the default address (0.0.0.0), make sure its port number is different from the port number of the HTTPS server on the device.
# Configure the IPv4 address of SSL VPN gateway gw1 as 10.10.1.1 and the port number as 8000.
[Sysname] sslvpn gateway gw1
[Sysname-sslvpn-gateway-gw1] ip address 10.10.1.1 port 8000
ip-route-list
Use ip-route-list to create a route list for an SSL VPN context and enter its view, or enter the view of an existing route list.
Use undo ip-route-list to delete a route list.
ip-route-list list-name
undo ip-route-list list-name
No route lists exist.
context-admin
list-name: Specifies a name for the route list, a case-insensitive string of 1 to 31 characters.
You can add routes to a route list. The routes can be issued to IP access clients for them to access internal servers behind the SSL VPN gateway.
You cannot delete a route list that is used by a policy group. To delete the route list, execute the undo ip-tunnel access-route command to remove the configuration and then execute the undo ip-route-list command.
# In SSL VPN context ctx1, create a route list named rtlist and enter its view.
Use ip-tunnel access-route to specify the routes to be issued to clients.
Use undo ip-tunnel access-route to restore the default.
ip-tunnel access-route { ip-address { mask-length | mask } | force-all | ip-route-list list-name }
No routes to be issued to clients are specified.
context-admin
ip-address { mask-length | mask }: Configures a route to be issued to a client. The ip-address argument specifies the destination address of the route. It cannot be a multicast, broadcast, or loopback address. The mask-length argument specifies the mask length of the route, in the range of 0 to 32.
force-all: Forces all traffic to be sent to the SSL VPN gateway.
ip-route-list list-name: Issues routes in the specified route list to clients. The list-name argument specifies the route list name, a case-insensitive string of 1 to 31 characters. The specified route list must have been created by using the ip-route-list command.
When a client accesses an SSL VPN gateway in IP access mode, the SSL VPN gateway issues the configured route or the specified routes to the client. The client adds the routes, using the VNIC as the output interface. Packets from the client to the internal servers match the routes, and therefore are sent to the SSL VPN gateway through the VNIC.
To issue multiple routes to a client, execute the ip-tunnel access-route ip-route-list list-name command. To issue a route to a client, execute the ip-tunnel access-route ip-address { mask-length | mask } command.
After you execute the ip-tunnel access-route force-all command, the SSL VPN gateway issues a default route to the SSL VPN client. The default route uses the VNIC as the output interface and has the highest priority among all default routes on the client. Packets for destinations not in the routing table are sent to the SSL VPN gateway through the VNIC. The SSL VPN gateway monitors the SSL VPN client in real time. It does not allow the client to delete the default route or add a default route with a higher priority.
# In the view of policy group pg1, configure the SSL VPN gateway to issue routes in route list rtlist to a client.
[Sysname-sslvpn-context-ctx1-route-list-rtlist] include 20.0.0.0 8
[Sysname-sslvpn-context-ctx1-route-list-rtlist] quit
[Sysname-sslvpn-context-ctx1-policy-group-pg1] ip-tunnel access-route ip-route-list rtlist
ip-route-list
Use ip-tunnel address-pool to specify an address pool for IP access in an SSL VPN context.
Use undo ip-tunnel address-pool to restore the default.
ip-tunnel address-pool pool-name mask { mask-length | mask }
No address pool is specified for IP access in an SSL VPN context.
context-admin
pool-name: Specifies an address pool by its name, a case-insensitive string of 1 to 31 characters.
mask { mask-length | mask }: Specifies the mask length or mask of the address pool. The value range for the mask length is 1 to 30.
When a client accesses an SSL VPN gateway in IP access mode, the SSL VPN gateway allocates an IP address to the client from either of the following address pools:
·     Address pool specified for the policy group authorized to the client.
·     Address pool specified for the SSL VPN context. This address pool is used only if no address pool is specified for the policy group authorized to the client.
If no free address is available in the address pool or the address pool does not exist, address allocation to the client will fail and the client's IP access request will be rejected.
If you specify a nonexistent address pool, the pool is effective for address allocation after it is created.
You can specify only one address pool for an SSL VPN context. If you execute this command multiple times, the most recent configuration takes effect.
For IP access users to access the SSL VPN gateway correctly, make sure the IP addresses in the address pool do not conflict with the IP addresses used on the device.
# Specify address pool pool1 for IP access.
[Sysname-sslvpn-context-ctx] ip-tunnel address-pool pool1 mask 24
Use ip-tunnel address-pool to specify an address pool for IP access in an SSL VPN policy group.
No address pool is specified for IP access in an SSL VPN policy group.
context-admin
You can specify only one address pool for an SSL VPN policy group. If you execute this command for an SSL VPN policy group multiple times, the most recent configuration takes effect.
# Specify address pool pool1 for IP access in SSL VPN policy group pg1.
[Sysname-sslvpn-context-ctx1-policy-group-pg1] ip-tunnel address-pool pool1 mask 24
ip-tunnel bind address
Use ip-tunnel bind address to bind IP addresses to an SSL VPN user.
Use undo ip-tunnel bind address to restore the default.
ip-tunnel bind address { ip-address-list | auto-allocate number }
An SSL VPN user is not bound to IP addresses.
SSL VPN user view
context-admin
ip-address-list: Specifies an IP address list, a string of 1 to 255 characters and can contain digits, dots (.), commas (,), and hyphens (-). The IP address list specifies comma-separated IP address items. Each item specifies an IP address or specifies a range of IP addresses in the form of start IP address-end IP address. For example, 10.1.1.5,10.1.1.10-10.1.1.20. The IP address list can contain a maximum of 10000 addresses excluding multicast addresses, broadcast addresses, and loopback addresses.
auto-allocate number: Enables the SSL VPN gateway to automatically bind the specified number of free IP addresses to the user. The value range for the number argument is 1 to 10.
When an SSL VPN user accesses the SSL VPN gateway in IP access mode, the SSL VPN gateway must assign an IP address to the user. This command allows you to specify the IP addresses that can be assigned to a user.
You can bind IP addresses to an SSL VPN user as follows:
·     Use the ip-address-list argument to bind a list of IP addresses to the user.
When the user accesses the SSL VPN gateway in IP access mode, the SSL VPN gateway assigns a bound IP address to the user.
If an IP address has been assigned to another user, the SSL VPN gateway terminates the connection for that user and releases the IP address.
·     Use the auto-allocate number option to enable the SSL VPN gateway to automatically bind the specified number of free addresses in the IP access address pool to the user.
The IP addresses to be bound to an SSL VPN user must meet the following requirements:
·     If an IP access address pool is specified for the SSL VPN policy group authorized to the user, the IP addresses must exist in the address pool.
·     If no address pool is specified for the SSL VPN policy group, the IP addresses must exist in the address pool specified for the SSL VPN context of the user.
You can bind the same IP address to different SSL VPN users only when the SSL VPN contexts of the users are associated with different VPN instances.
If you configure this command multiple times, the most recent configuration takes effect.
# Bind IP addresses 10.1.1.5, 10.1.1.10 through 10.1.1.20, and 10.1.1.30 to SSL VPN user user1.
[Sysname] sslvpn context ctx
[Sysname-sslvpn-context-ctx] user user1
[Sysname-sslvpn-context-ctx-user-user1] ip-tunnel bind address 10.1.1.5,10.1.1.10-10.1.1.20,10.1.1.30
user
ip-tunnel dns-server
Use ip-tunnel dns-server to specify a DNS server for IP access.
Use undo ip-tunnel dns-server to restore the default.
ip-tunnel dns-server { primary | secondary } ip-address
undo ip-tunnel dns-server { primary | secondary }
No DNS servers are specified for IP access.
SSL VPN context view
context-admin
primary: Specifies the primary DNS server.
secondary: Specifies the secondary DNS server.
ip-address: Specifies the IP address of the DNS server. It cannot be a multicast, broadcast, or loopback address.
# Specify the primary DNS server 1.1.1.1 for IP access.
[Sysname-sslvpn-context-ctx] ip-tunnel dns-server primary 1.1.1.1
ip-tunnel interface
Use ip-tunnel interface to specify an SSL VPN AC interface for IP access in an SSL VPN context.
Use undo ip-tunnel interface to restore the default.
ip-tunnel interface sslvpn-ac interface-number
No SSL VPN AC interface is specified for IP access in an SSL VPN context.
context-admin
sslvpn-ac interface-number: Specifies the number of an SSL VPN AC interface. The interface must have been created.
The SSL VPN gateway uses the specified SSL VPN AC interface to communicate with SSL VPN users in IP access mode. It uses the SSL VPN AC interface to forward packets sent by the user to remote servers and to forward the servers' replies back to the user.
# Specify SSL VPN AC 100 for IP access.
[Sysname-sslvpn-context-ctx] ip-tunnel interface sslvpn-ac 100
interface sslvpn-ac
ip-tunnel keepalive
Use ip-tunnel keepalive to set the keepalive interval for IP access.
Use undo ip-tunnel keepalive to restore the default.
ip-tunnel keepalive seconds
The keepalive interval is 30 seconds for IP access.
context-admin
seconds: Specifies the keepalive interval in the range of 0 to 600 seconds. If the interval is set to 0 seconds, a client does not send keepalive messages to the SSL VPN gateway.
A client sends keepalive messages to the SSL VPN gateway to maintain sessions between them.
If an SSL VPN gateway does not receive any data or keepalive messages from a client during the session idle timeout time, it terminates the session with the client.
Set the keepalive interval to be shorter than the session idle timeout timer configured by the timeout idle command.
# Set the keepalive interval to 50 seconds for SSL VPN context ctx.
[Sysname-sslvpn-context-ctx] ip-tunnel keepalive 50
ip-tunnel log
Use ip-tunnel log to enable logging for IP access connection close events or IP access packet drop events.
Use undo ip-tunnel log to disable logging for IP access connection close events or IP access packet drop events.
ip-tunnel log { connection-close | packet-drop }
undo ip-tunnel log { connection-close | packet-drop }
Logging is disabled for IP access connection close events or IP access packet drop events.
context-admin
connection-close: Enables logging for IP access connection close events.
packet-drop: Enables logging for IP access packet drop events.
If logging for IP access connection close events is enabled, the SSL VPN gateway generates logs when the connections established for SSL VPN IP access users are closed.
If logging for IP access packet drop events is enabled, the SSL VPN gateway generates logs when packets for SSL VPN IP access users are dropped.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable logging for IP access connection close events.
[Sysname] sslvpn context ctx1
[Sysname-sslvpn-context-ctx1] ip-tunnel log connection-close
sslvpn context
ip-tunnel rate-limit
Use ip-tunnel rate-limit to set a rate limit for IP access upstream or downstream traffic.
Use undo ip-tunnel rate-limit to remove the rate limit set for IP access upstream or downstream traffic.
ip-tunnel rate-limit { downstream | upstream } { kbps | pps } value
undo ip-tunnel rate-limit { downstream | upstream }
No rate limit is set for IP access upstream or downstream traffic.
context-admin
downstream: Specifies the IP access downstream traffic, which is sent by internal servers to IP access users.
upstream: Specifies the IP access upstream traffic, which is sent by IP access users to internal servers.
kbps: Sets the unit of measurement for the rate limit to kilobits per second.
pps: Sets the unit of measurement for the rate limit to packets per second.
value: Sets the rate limit value, in the range of 1000 to 100000000.
You can set a rate limit for IP access upstream and downstream traffic, respectively. If you set the rate limit for the same traffic direction multiple times, the most recent configuration take effect.
If the IP access upstream or downstream traffic exceeds the rate limit, subsequent upstream or downstream traffic will be discarded.
# In SSL VPN context ctx1, set the rate limit to 10000 pps for IP access upstream traffic.
[Sysname-sslvpn-context-ctx1] ip-tunnel rate-limit upstream pps 10000
ip-tunnel web-resource auto-push
Use ip-tunnel web-resource auto-push to enable automatic pushing of accessible resources to IP access users through the Web page.
Use undo ip-tunnel web-resource auto-push to disable automatic pushing of accessible resources to IP access users through the Web page.
Automatic pushing of accessible resources to IP access users through the Web page is disabled.
context-admin
This feature enables automatic pushing of accessible resources to a user through the Web page after the user logs in to the SSL VPN gateway through the IP access client.
# Enable automatic pushing of accessible resources to IP access users through the Web page in SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] ip-tunnel web-resource auto-push
ip-tunnel wins-server
Use ip-tunnel wins-server to specify a WINS server for IP access.
Use undo ip-tunnel wins-server to restore the default.
ip-tunnel wins-server { primary | secondary } ip-address
undo ip-tunnel wins-server { primary | secondary }
No WINS servers are specified for IP access.
context-admin
primary: Specifies the primary WINS server.
secondary: Specifies the secondary WINS server.
ip-address: Specifies the IPv4 address of the WINS server. It cannot be a multicast, broadcast, or loopback address.
# Specify the primary WINS server 1.1.1.1 for IP access.
[Sysname-sslvpn-context-ctx] ip-tunnel wins-server primary 1.1.1.1
ipv6 address
Use ipv6 address to configure an IPv6 address and a port number for an SSL VPN gateway.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address [ port port-number ]
undo ipv6 address
No IPv6 address is configured for an SSL VPN gateway.
SSL VPN gateway view
context-admin
ipv6-address: Specifies an IPv6 address for the SSL VPN gateway, a 16-byte hexadecimal string separated by colons.
A remote user uses the IPv6 address and port number configured by this command to access an SSL VPN gateway.
The specified IPv6 address must be the address of an interface on the gateway device and is reachable from clients and internal servers.
Do not use the management address of the device as the IPv6 address of the SSL VPN gateway.
# Configure the IPv6 address of SSL VPN gateway gw1 as 200::1 and the port number as 8000.
[Sysname-sslvpn-gateway-gw1] ipv6 address 200::1 port 8000
local-port
Use local-port to configure a port forwarding instance for a port forwarding item.
Use undo local-port to remove the configuration.
local-port local-port-number local-name local-name remote-server remote-server remote-port remote-port-number [ description text ]
undo local-port
A port forwarding item does not contain a port forwarding instance.
context-admin
local-port-number: Specifies a local port number in the range of 1 to 65535. The specified port number must be different from the port numbers of any existing services on the SSL VPN client.
local-name local-name: Specifies a local address or a local host name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.). To specify an IPv4 address, use an address in the network segment 127.0.0.0/8. To specify an IPv6 address, enclose the IPv6 address in brackets. For example, local-name [1234::5678].
remote-server remote-server: Specifies the IP address or domain name of a TCP service on an internal server. The remote-server argument is a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.). To specify an IPv6 address, enclose the IPv6 address in brackets. For example, remote-server [1234::5678].
remote-port remote-port-number: Specifies the port number of the TCP service on the internal server, in the range of 1 to 65535.
description text: Specifies a description, a case-sensitive string of 1 to 63 characters.
A port forwarding instance maps a TCP service on an internal server to a local address and port number on an SSL VPN client.
For example, for an SSL VPN client to use local address 127.0.0.1 and port 80 to access the internal HTTP server 192.168.0.213, perform the following tasks:
1.     Create a port forwarding item (tcp1 in this example).
2.     Configure a port forwarding instance for the port forwarding item.
local-port 80 local-name 127.0.0.1 remote-server 192.168.0.213 remote-port 80
The port forwarding instance will be displayed together with the port forwarding item name on the SSL VPN Web page. In this example, tcp1 (127.0.0.1:80 -> 192.168.0.213) will be displayed.
If you map a TCP service to a local host name, the TCP access client software will add the IP address corresponding to the host name to the host file hosts. When the client logs out, the software restores the original host file. The host file hosts is in the directory C:\Windows\System32\drivers\etc of the client host.
You can configure only one port forwarding instance for a port forwarding item. If you execute this command for a port forwarding item multiple times, the most recent configuration takes effect.
# Configure a port forwarding instance for port forwarding item pfitem1. The port forwarding instance maps IP address 192.168.0.213 and port 80 of the internal HTTP server to local address 127.0.0.1 and port 80.
[Sysname-sslvpn-context-ctx1-port-forward-item-pfitem1] local-port 80 local-name 127.0.0.1 remote-server 192.168.0.213 remote-port 80 description http
port-forward-item
log resource-access enable
Use log resource-access enable to enable resource access logging.
Use undo log resource-access enable to disable resource access logging.
log resource-access enable [ brief | filtering ] *
Resource access logging is disabled.
context-admin
brief: Records brief resource access information. If you specify this keyword, only the address and port number of the accessed resource will be recorded. If you do not specify this keyword, a large amount of information including webpage formatting information will be recorded.
filtering: Enables resource access log filtering. With this keyword specified, the device generates only one log for accesses of the same user to the same resource in a minute. If this keyword is not specified, the device generates a log for each resource access.
This feature logs resource accesses of SSL VPN users. The logs are sent to the information center of the device.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output SSL VPN resource access logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view SSL VPN resource access logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
If you execute the log resource-access enable command multiple times, the most recent configuration takes effect.
# Enable resource access logging.
[Sysname-sslvpn-context-ctx1] log resource-access enable
log user-login enable
Use log user-login enable to enable logging for user login and logoff events.
Use undo log user-login enable to disable logging for user login and logoff events.
Logging for user login and logoff events is disabled.
context-admin
This feature logs user login and logoff events. The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable logging for user logins and logouts.
[Sysname-sslvpn-context-ctx1] log user-login enable
login-message
Use login-message to configure the welcome message to be displayed on the SSL VPN login page.
Use undo log login-message to restore the default.
login-message { chinese chinese-message | english english-message }
undo login-message { chinese | english }
The login welcome message is Welcome to SSL VPN.
context-admin
chinese chinese-message: Configures a login welcome message in Chinese, a case-sensitive string of 1 to 255 characters.
english english-message: Configures a login welcome message in English, a case-sensitive string of 1 to 255 characters.
# Configure the login welcome message as hello.
[Sysname-sslvpn-context-ctx1] login-message english hello
logo
Use logo to specify a logo to be displayed on SSL VPN webpages.
Use undo logo to restore the default.
logo { file file-name | none }
undo logo
The logo displayed on SSL VPN webpages is H3C.
context-admin
file file-name: Specifies a logo file by its name, a case-insensitive string of 1 to 255 characters. The file must be a .gif, .jpg, or .png file, and its size cannot exceed 100 KB. As a best practice, use a file whose image resolution is 110*30 pixels.
none: Specifies that no logo is displayed.
The specified logo file must exist on the local device.
After you specify a logo file, the logo is displayed on SSL VPN webpages even if the file is deleted.
# Specify the logo in file flash:/mylogo.gif as the logo displayed on SSL VPN webpages.
[Sysname-sslvpn-context-ctx1] logo file flash:/mylogo.gif
max-onlines
Use max-onlines to set the maximum number of concurrent logins for each account.
Use undo max-onlines to restore the default.
max-onlines number
undo max-onlines
The maximum number of concurrent logins for each account is 32.
context-admin
number: Specifies the maximum number, in the range of 0 to 1048575. Value 0 indicates that the number of concurrent logins for each account is not limited.
# Set the maximum number of concurrent logins for each account to 50.
[Sysname-sslvpn-context-ctx1] max-onlines 50
max-users
Use max-users to set the maximum number of sessions for an SSL VPN context.
Use undo max-users to restore the default.
max-users max-number
undo max-users
An SSL VPN context supports a maximum of 1048575 sessions.
context-admin
max-number: Specifies the maximum number of sessions, in the range of 1 to 1048575
If the limit is reached, new users cannot access the SSL VPN gateway.
# Set the maximum number of sessions to 500 for SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] max-users 500
display sslvpn context
message-server
Use message-server to specify a message server for mobile clients.
Use undo message-server to restore the default.
message-server address { host-name | ipv4-address } port port-number
undo message-server
No message server is specified for mobile clients.
context-admin
address: Specifies the host name or IPv4 address of the message server.
host-name: Specifies the host name of the message server, a case-insensitive string of 1 to 127 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.).
ipv4-address: Specifies the IPv4 address of the message server, in dotted decimal notation. The IP address cannot be a multicast, broadcast, or loopback address.
port port-number: Specifies the port number of the message server, in the range of 1025 to 65535.
A message server provides services for mobile clients. The SSL VPN gateway issues the message server information to the clients, and the clients can access the message server.
# Specify the IP address of the message server as 10.10.1.1 and the port number as 8000 for context ctx1.
[Sysname-sslvpn-context-ctx] message-server address 10.10.1.1 port 8000
sslvpn context
mtu
Use mtu to set the MTU of an SSL VPN AC interface.
mtu size
undo mtu
The default MTU is 1500 bytes.
SSL VPN AC interface view
context-admin
size: Specifies an MTU value in the range of 100 to 64000 bytes.
# Set the MTU of interface SSL VPN AC 1000 to 1430 bytes.
[Sysname] interface sslvpn-ac 1000
[Sysname-SSLVPN-AC1000] mtu 1430
new-content
Use new-content to specify the new content used to replace the old content.
Use undo new-content to restore the default.
new-content string
undo new-content
The new content used to replace the old content is not specified.
Rewrite rule view
context-admin
string: Specifies the new content, a case-sensitive string of 1 to 256 characters.
During file content rewriting, the new content will replace the old content specified by using the old-content command.
If the new content contains spaces, enclose the content in double quotation marks.
# Specify the new content in rewrite rule rule1 of file policy fp.
[Sysname-sslvpn-context-ctx] file-policy fp
[Sysname-sslvpn-context-ctx-file-policy-fp] rewrite-rule rule1
[Sysname-sslvpn-context-ctx-file-policy-fp-rewrite-rule-rule1] new-content sslvpn_rewrite_htmlcode(d)
old-content
old-content
Use old-content to specify the old file content to be rewritten.
Use undo old-content to restore the default.
old-content string
undo old-content
The old file content to be rewritten is not specified.
Rewrite rule view
context-admin
string: Specifies the old content, a case-sensitive string of 1 to 256 characters.
During file content rewriting, the old file content will be replaced by the new content specified by using the new-content command.
If the old content contains spaces, enclose the content in double quotation marks.
In the same file policy, the old content specified in different rewrite rules must be unique.
# Specify the content to be rewritten in rewrite rule rule1 of file policy fp.
[Sysname-sslvpn-context-ctx-file-policy-fp] rewrite rule rule1
[Sysname-sslvpn-context-ctx-file-policy-fp-rewrite-rule-rule1] old-content "a.b.c.innerHTML = d;"
new-content
password-authentication enable
Use password-authentication enable to enable username/password authentication.
Use undo password-authentication enable to disable username/password authentication.
Username/password authentication is enabled for an SSL VPN context.
SSL VPN context
context-admin
# Disable username/password authentication for SSL VPN context ctx.
[Sysname-sslvpn-context-ctx] undo password-authentication enable
certificate-authentication enable
password-box hide
Use password-box hide to hide the password input box on the SSL VPN Web login page.
Use undo password-box hide to display the password input box on the SSL VPN Web login page.
password-box hide
The password input box is displayed on the SSL VPN Web login page.
context-admin
If you want users to log in to the SSL VPN webpage by using authentication methods other than the username/password method, hide the password input box and configure the intended authentication methods.
After the password input box is hidden on the SSL VPN Web login page, only SSL VPN users with empty passwords can log in through the username/password authentication method.
# Hide the password input box on the SSL VPN Web login page.
[Sysname-sslvpn-context-ctx1] password-box hide
policy-group
Use policy-group to create an SSL VPN policy group and enter its view, or enter the view of an existing SSL VPN policy group.
Use undo policy-group to delete a policy group.
undo policy-group group-name
No SSL VPN policy groups exist.
context-admin
group-name: Specifies a name for the policy group, a case-insensitive string of 1 to 31 characters.
An SSL VPN policy group contains a set of rules for resource access authorization.
You can configure multiple SSL VPN policy groups for an SSL VPN context. When a remote user accesses the SSL VPN context, the AAA server issues the authorized policy group to the associated SSL VPN gateway. The user can access only the resources allowed by the authorized policy group. If the AAA server does not authorize the user to use a policy group, the user can access only the resources allowed by the default policy group.
# Create a policy group named pg1 and enter its view.
[Sysname-sslvpn-context-ctx1] policy-group pg1
default-policy-group
port-forward
Use port-forward to create a port forwarding list for an SSL VPN context and enter its view, or enter the view of an existing port forwarding list.
Use undo port-forward to delete a port forwarding list.
port-forward port-forward-name
undo port-forward port-forward-name
No port forwarding lists exist.
context-admin
port-forward-name: Specifies a name for the port forwarding list, a case-insensitive string of 1 to 31 characters.
Port forwarding lists provide TCP access services for SSL VPN users.
In port forwarding list view, you can use the port-forward-item command to create port forwarding items. Each port forwarding item defines an accessible TCP service provided on an internal server.
You can assign a port forwarding list to a policy group by using the resources port-forward command. After the AAA server authorizes a user to use a policy group, the SSL VPN Web page provides the user the port forwarding list assigned to the group. The user can access the TCP services provided by the port forwarding list.
# Create port forwarding list pflist1 and enter its view.
[Sysname-sslvpn-context-ctx1] port-forward pflist1
[Sysname-sslvpn-context-ctx1-port-forward-pflist1]
local-port
port-forward-item
Use port-forward-item to create a port forwarding item and enter its view, or enter the view of an existing port forwarding item.
Use undo port-forward-item to delete a port forwarding item.
port-forward-item item-name
undo port-forward-item item-name
No port forwarding items exist.
context-admin
item-name: Specifies a name for the port forwarding item, a case-insensitive string of 1 to 31 characters.
A port forwarding item defines an accessible TCP service provided on an internal server. It contains the following settings:
·     A port forwarding instance.
A port forwarding instance is configured by using the local-port command. It makes an internal TCP service accessible through a local address and port number on the SSL VPN client.
·     (Optional.) A resource link.
A resource link is configured by using the execution command.
After you configure a resource link for a port forwarding item, the port forwarding item name will be displayed on the SSL VPN Web page as a link. You can click the link to access the resource directly.
Make sure the resource link matches the TCP service specified by the port forwarding instance.
After you create a port forwarding item, you can assign it to a port forwarding list by using the resources port-forward-item command.
# Create a port forwarding item named pfitem1 and enter its view.
execution
local-port
reset counters interface sslvpn-ac
Use reset counters interface sslvpn-ac to clear SSL VPN AC interface statistics.
reset counters interface [ sslvpn-ac [ interface-number ] ]
context-admin
sslvpn-ac [ interface-number ]: Specifies an SSL VPN AC interface by its number in the range of 0 to 4095. If you do not specify this option, the command clears statistics for all interfaces. If you specify the sslvpn-ac keyword without the interface-number argument, this command clears statistics for all existing SSL VPN AC interfaces.
Use this command to clear old statistics so you can observe new traffic statistics on an SSL VPN AC interface.
# Clear statistics for SSL VPN AC 1000.
<Sysname> reset counters interface sslvpn-ac 1000
display interface sslvpn-ac
reset sslvpn ip-tunnel statistics
Use reset sslvpn ip-tunnel statistics to clear packet statistics for IP access users.
reset sslvpn ip-tunnel statistics [ context context-name [ session session-id ] ]
context-admin
context context-name: Specifies an SSL VPN context by its name. An SSL VPN context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN context, this command clear packet statistics for IP access users in all SSL VPN contexts.
session session-id: Specifies a session by its ID in the range of 1 to 4294967295. If you do not specify a session, this command clears packet statistics for all IP access users in the specified SSL VPN context.
To view the SSL VPN sessions in different SSL VPN contexts, execute the display sslvpn session command.
If you do not specify any parameters, this command clear packets statistics for all IP access users in all SSL VPN contexts.
# Clear the IP access packet statistics in all SSL VPN contexts.
<Sysname> reset sslvpn ip-tunnel statistics
# Clear the IP access packet statistics in SSL VPN context ctx1.
<Sysname> reset sslvpn ip-tunnel statistics context ctx1
# Clear the IP access packet statistics of session 1 in SSL VPN context ctx.
<Sysname> reset sslvpn ip-tunnel statistics context ctx1 session 1
display sslvpn ip-tunnel statistics
Use resources port-forward to assign a port forwarding list to an SSL VPN policy group.
Use undo resources port-forward to remove the configuration.
resources port-forward port-forward-name
An SSL VPN policy group does not contain a port forwarding list.
SSL VPN policy group view
context-admin
port-forward-name: Specifies the name of an existing port forwarding list. A port forwarding list name is a case-insensitive string of 1 to 31 characters.
# Assign port forwarding list pflist1 to SSL VPN policy group pg1.
[Sysname-sslvpn-context-ctx1-policy-group-pg1] resources port-forward pflist1
local-port
port-forward
Use resources port-forward-item to assign a port forwarding item to a port forwarding list.
Use undo resources port-forward-item to remove a port forwarding item from a port forwarding list.
resources port-forward-item item-name
undo resources port-forward-item item-name
A port forwarding list does not contain any port forwarding items.
Port forwarding list view
context-admin
item-name: Specifies a port forwarding item by its name, a case-insensitive string of 1 to 31 characters.
Before you assign a port forwarding item to a port forwarding list, make sure the port forwarding item has been created by using the port-forward-item command.
You can assign multiple port forwarding items to a port forwarding list.
# Create a port forwarding item named pfitem1, and then assign it to port forwarding list pflist1.
[Sysname-sslvpn-context-ctx1-port-forward-pflist1-port-forward-item-pfitem1] quit
[Sysname-sslvpn-context-ctx1-port-forward-pflist1] resources port-forward-item pfitem1
port-forward-item
resources shortcut
Use resources shortcut to assign a shortcut to a shortcut list.
Use undo resources shortcut to remove a shortcut from a shortcut list.
resources shortcut shortcut-name
undo resources shortcut shortcut-name
A shortcut list does not contain any shortcuts.
Shortcut list view
context-admin
shortcut-name: Specifies a shortcut by its name, a case-insensitive string of 1 to 31 characters.
You can assign multiple shortcuts to a shortcut list.
# Assign shortcut list1 to shortcut list shortcut1.
[Sysname-sslvpn-context-ctx1] shortcut shortcut1
[Sysname-sslvpn-context-ctx1-shortcut-shortcut1] quit
[Sysname-sslvpn-context-ctx1] shortcut-list list1
[Sysname-sslvpn-context-ctx1-shortcut-list-list1] resources shortcut shortcut1
resources shortcut-list
Use resources shortcut-list to assign a shortcut list to an SSL VPN policy group.
Use undo resources shortcut-list to restore the default.
resources shortcut-list list-name
An SSL VPN policy group does not contain a shortcut list.
context-admin
list-name: Specifies a shortcut list by its name, a case-insensitive string of 1 to 31 characters.
You can assign only one shortcut list to an SSL VPN policy group. After the AAA server authorizes a user to use a policy group, the SSL VPN Web page provides the user the shortcut list assigned to the group. The user can click a shortcut to access the associated resource.
# Assign shortcut list list1 to SSL VPN policy group pg1.
[Sysname-sslvpn-context-ctx1-shortcut-list-list1] quit
[Sysname-sslvpn-context-ctx1-policy-group-pg1] resources shortcut-list list1
resources uri-acl
Use resources uri-acl to specify a URI ACL for URL resource filtering in a URL item.
Use undo resources uri-acl to remove the URI ACL configuration from a URL item.
resources uri-acl uri-acl-name
No URI ACL is specified for URL resource filtering in a URL item.
URL item view
context-admin
The specified URI ACL will be used to filter the accessible resources under the URL specified in the URL item.
# Specify URI ACL abc in URL item serverA.
[Sysname-sslvpn-context-ctx1] url-item serverA
[Sysname-sslvpn-context-ctx1-url-item-serverA] resources uri-acl abc
uri-acl
resources url-item
Use resources url-item to assign a URL item to a URL list.
Use undo resources url-item to remove a URL item from a URL list.
resources url-item url-item-name
undo resources url-item url-item-name
A URL list does not contain any URL items.
URL list view
context-admin
url-item-name: Specifies a URL item by its name, a case-insensitive string of 1 to 31 characters. The specified URL item must already exist.
You can assign multiple URL items to a URL list.
# Assign URL item serverA to URL list list1.
[Sysname-sslvpn-context-ctx1] url-list list1
[Sysname-sslvpn-context-ctx1-url-list-list1] resources url-item serverA
url-item
resources url-list
Use resources url-list to assign a URL list to an SSL VPN policy group.
Use undo resources url-list to remove the configuration.
resources url-list url-list-name
undo resources url-list url-list-name
An SSL VPN policy group does not contain a URL list.
context-admin
url-list-name: Specifies an existing URL list by its name, a case-insensitive string of 1 to 31 characters.
In Web access mode, a remote user can use a Web browser to access URL resources in the URL list assigned to the authorized SSL VPN policy group.
# Assign URL list url1 to SSL VPN policy group pg1.
[Sysname-sslvpn-context-ctx1-policy-group-pg1] resources url-list url1
policy-group
sslvpn context
url-list
rewrite-rule
Use rewrite-rule to create a rewrite rule and enter its view, or enter the view of an existing rewrite rule.
Use undo rewrite-rule to delete a rewrite rule.
rewrite-rule rule-name
undo rewrite-rule rule-name
No rewrite rules exist.
File policy view
context-admin
rule-name: Specifies a rule name, a case-insensitive string of 1 to 31 characters.
You can configure multiple rewrite rules in a file policy.
# Create a rewrite rule named rule1 and enter its view.
rule
Use rule to create a rule for a URI ACL.
Use undo rule to remove a rule from a URI ACL.
rule [ rule-id ] { deny | permit } uri uri-pattern-string
undo rule rule-id
No URL ACL rules exist in a URI ACL
URI ACL view
context-admin
deny: Denies matching packets to pass.
permit: Allows matching packets to pass.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. The numbering step is 5 for automatic numbering of rule IDs. An automatically assigned rule ID takes the nearest multiple of 5 higher than the current highest rule ID. For example, if the current highest rule ID is 28, the rule is numbered 30.
uri uri-pattern-string: Specifies a URI pattern. The URI pattern can contain a maximum of 256 characters in the format of protocol://host:port/path, where protocol and host are required. See Table 13 for descriptions of the fields in a URI pattern.
Table 13 URI field descriptions
protocol
Protocol name. Options are:
·     http.
·     https.
·     tcp.
·     udp.
·     icmp.
·     ip.
host
Domain name or address of a host.
·     Valid host address formats:
¡     IPv4 or IPv6 address. For example, 192.168.1.1.
¡     IPv4 or IPv6 address range in the format of start address-end address. For example, 3.3.3.1-3.3.3.200.
¡     IPv4 address with a mask length or IPv6 address with a prefix length. For example 2.2.2.2/24.
¡     A combination of the preceding host address formats separated by comma (,). For example, 192.168.1.1,3.3.3.1-3.3.3.200,2.2.2.2/24.
·     Valid domain name formats:
¡     Fully qualified domain name. For example, www.domain.com
¡     Domain name with the following wildcard characters:
Asterisk (*)—Matches zero or more characters. For example, *.com.
Question mark (?)—Matches one character. For example, www.do?main.com.
Percent sign (%)—Matches one or more characters in a field of the domain name. For example, www.%.com.
port
Port number. If no port number is specified, the default port number of the protocol is used.
Valid formats for this field:
·     Single port number. For example, 1002.
·     Port number range in the format of start port-end port. For example, 8080-8088.
·     A combination of the preceding formats separate by comma (,). For example, 1002,90,8080-8088.
path
String that identifies a directory or file on the host. The path is a sequence of fields separated by forward or backward slashes.
The following wildcard characters are supported:
·     Asterisk (*)—Matches zero or more characters. For example, /path1/*.
·     Question mark (?)—Matches one character. For example, /path?/.
·     Percent sign (%)—Matches one or more characters in a field of the path. For example, /path1/%/.
You can add multiple rules to a URI ACL. The device matches a packet against the rules in ascending order of rule ID. The match process stops once a matching rule is found.
# Add a rule to URI ACL uriacla.
[Sysname-sslvpn-context-abc] uri-acl uriacla
[Sysname-sslvpn-context-abc-uri-acl-uriacla] rule 1 permit uri
service enable (SSL VPN context view)
Use service enable to enable an SSL VPN context.
Use undo service enable to disable an SSL VPN context.
service enable
undo service enable
An SSL VPN context is disabled.
context-admin
# Enable SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] service enable
service enable (SSL VPN gateway view)
Use service enable to enable an SSL VPN gateway.
Use undo service enable to disable an SSL VPN gateway.
service enable
undo service enable
An SSL VPN gateway is disabled.
context-admin
# Enable SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] service enable
display sslvpn gateway
session-connections
Use session-connections to set the maximum number of connections allowed per session.
Use undo session-connections to restore the default.
session-connections number
A maximum of 64 connections are allowed per session.
context-admin
number: Set the maximum number of connections allowed per session. The value can be 0 or in the range of 10 to 1000. Value 0 indicates that the number of connections per session is not limited.
If the number of connections in a session has reached the maximum, new connection requests for the session will be rejected with a 503 Service Unavailable message.
# Set the maximum number of connections allowed per session to 10.
[Sysname-sslvpn-context-ctx1] session-connections 10
shortcut
Use shortcut to create a shortcut and enter its view, or enter the view of an existing shortcut.
Use undo shortcut to delete a shortcut.
undo shortcut shortcut-name
No shortcuts exist.
context-admin
shortcut-name: Specifies a shortcut name, a case-insensitive string of 1 to 31 characters.
After you create a shortcut, use the execution command to configure a resource link for it. Users can then click the shortcut name on the SSL VPN Web page to access the associated resource.
# Create a shortcut named shortcut1 and enter its view.
shortcut-list
Use shortcut-list to create a shortcut list and enter its view, or enter the view of an existing shortcut list.
Use undo shortcut-list to delete a shortcut list.
undo shortcut-list list-name
No shortcut lists exist.
context-admin
list-name: Specifies a name for the shortcut list, a case-insensitive string of 1 to 31 characters.
# Create a shortcut list named list1 and enter its view.
shutdown
Use shutdown to shut down an SSL VPN AC interface.
Use undo shutdown to bring up an SSL VPN AC interface.
shutdown
An SSL VPN AC interface is up.
context-admin
# Shut down SSL VPN AC 1000.
[Sysname-SSLVPN-AC1000] shutdown
sms-imc address
Use sms-imc address to specify an IMC server for SMS message verification.
Use undo sms-imc address to restore the default.
sms-imc address ip-address port port-number [ vpn-instance vpn-instance-name ]
No IMC server is specified for SMS message verification.
context-admin
ip-address: Specifies the IP address of the IMC server, in dotted decimal notation.
port port-number: Specifies the port number of the IMC server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IMC server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. Do not specify this option if the IMC server is on the public network.
# Specify an IMC server (with IP address 192.168.10.1 and port 2000) in VPN instance vpn1 for SMS message verification of users in SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] sms-imc address 192.168.10.1 port 2000 vpn-instance vpn1
sms-imc enable
sms-imc enable
Use sms-imc enable to enable IMC SMS message verification.
Use undo sms-imc enable to disable IMC SMS message verification.
sms-imc enable
undo sms-imc enable
IMC SMS message verification is disabled.
context-admin
Before you execute this command, make sure SMS message verification has been configured on the IMC server.
In Web or IP access mode, the authentication process for an SSL VPN user is as follows:
1.     The SSL VPN gateway obtains the verification code request from the user's login request and sends the verification code request to the IMC server.
2.     The IMC server sends a verification code to the user through an SMS message.
3.     The user enters the username, password, and the received verification code on the login page to pass authentication through the IMC server.
# Enable IMC SMS message verification.
[Sysname-sslvpn-context-ctx1] sms-imc enable
sms-imc address
ssl client-policy
Use ssl client-policy to apply an SSL client policy to an SSL VPN context.
Use undo ssl client-policy to restore the default.
ssl client-policy policy-name
The default SSL client policy for SSL VPN is used. This policy supports the dhe_rsa_aes_128_cbc_sha, dhe_rsa_aes_256_cbc_sha, rsa_3des_ede_cbc_sha, rsa_aes_128_cbc_sha, and rsa_aes_256_cbc_sha cipher suites.
context-admin
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
You can apply only one SSL client policy to an SSL VPN context. For the applied SSL client policy to take effect, you must enable the SSL VPN context by using the service enable command. The SSL VPN gateway will use the parameters defined by the policy to establish SSL connections to HTTPS servers.
If you execute this command multiple times, the new configuration overwrites the previous configuration, but does not take effect. For the new configuration to take effect, disable the SSL VPN context and then re-enable it.
For information about configuring SSL client policies, see Security Configuration Guide.
# Apply SSL client policy abc to SSL VPN context ctx1.
[Sysname-sslvpn-context-ctx1] ssl client-policy abc
ssl server-policy
Use ssl server-policy to apply an SSL server policy to an SSL VPN gateway.
Use undo ssl server-policy to remove the application.
ssl server-policy policy-name
An SSL VPN gateway uses the SSL server policy of its self-signed certificate.
context-admin
policy-name: Specifies the name of an SSL server policy, a case-insensitive string of 1 to 31 characters.
You can apply only one SSL server policy to an SSL VPN gateway. For the applied SSL server policy to take effect, you must enable the SSL VPN gateway by using the service enable command. The SSL VPN gateway will use the parameters defined by the policy to establish SSL connections to remote users.
If you execute this command multiple times, the new configuration overwrites the previous configuration but does not take effect. For the new configuration to take effect, disable the SSL VPN gateway and then enable the SSL VPN gateway. To disable and enable an SSL VPN gateway, use the undo service enable and service enable commands.
After you modify the content of the SSL server policy applied to an SSL VPN gateway, you must disable and then re-enable the gateway to validate the policy. To disable and enable an SSL VPN gateway, use the undo service enable and service enable commands.
# Apply SSL server policy CA_CERT to SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ssl server-policy CA_CERT
sslvpn context
Use sslvpn context to create an SSL VPN context and enter its view, or enter the view of an existing SSL VPN context.
Use undo sslvpn context to delete an SSL VPN context.
sslvpn context context-name
undo sslvpn context context-name
No SSL VPN contexts exist.
context-admin
context-name: Specifies an SSL VPN context name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, and underscores (_).
SSL VPN contexts contain different user sessions, accessible resources, and user authentication methods.
An SSL VPN gateway can be associated with multiple SSL VPN contexts. After a remote user logs in to an SSL VPN gateway, the user can access only the resources in the SSL VPN context to which the user belongs.
# Create an SSL VPN context named ctx1 and enter its view.
sslvpn gateway
Use sslvpn gateway to create an SSL VPN gateway and enter its view, or enter the view of an existing SSL VPN gateway.
Use undo sslvpn gateway to delete an SSL VPN gateway.
sslvpn gateway gateway-name
undo sslvpn gateway gateway-name
No SSL VPN gateways exist.
context-admin
gateway-name: Specifies an SSL VPN gateway name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, and underscores (_).
An SSL VPN gateway resides between remote users and the enterprise network to ensure secure access of remote users to the enterprise internal network. The SSL VPN gateway establishes an SSL connection to a remote user, and then authenticates the user before allowing the user to access an internal server.
You must perform the following tasks in the view of an SSL VPN gateway:
·     Execute the ip address command to configure an IP address and a port number for the SSL VPN gateway.
·     Execute the ssl server-policy command to apply an SSL server policy to the SSL VPN gateway.
·     Execute the service enable command to enable the SSL VPN gateway.
You cannot delete an SSL VPN gateway that has been associated with an SSL VPN context. To delete the SSL VPN gateway, execute the undo gateway command to remove the association and then execute the undo sslvpn gateway command.
# Create an SSL VPN context named gw1 and enter its view.
sslvpn ip address-pool
Use sslvpn ip address-pool to create an address pool.
Use undo sslvpn ip address-pool to delete an address pool.
sslvpn ip address-pool pool-name start-ip-address end-ip-address
undo sslvpn ip address-pool pool-name
No address pools exist.
context-admin
pool-name: Specifies a name for the address pool, a case-insensitive string of 1 to 31 characters.
start-ip-address end-ip-address: Specifies the start IP address and end IP address for the pool. The end IP address must be greater than the start IP address. The start IP address and end IP address cannot be a multicast, broadcast, or loopback address.
The created address pools are used for address allocation to SSL VPN IP access clients. You can specify an address pool for an SSL VPN context or an SSL VPN policy group. An SSL VPN gateway uses the specified address pools to assign IP addresses to IP access clients.
# Create an address pool named pool1 and specify the address range as 10.1.1.1 to 10.1.1.254.
[Sysname] sslvpn ip address-pool pool1 10.1.1.1 10.1.1.254
ip-tunnel address-pool (SSL VPN context view)
ip-tunnel address-pool (SSL VPN policy group view)
sslvpn log enable
Use sslvpn log enable to enable the SSL VPN global logging feature.
Use undo sslvpn log enable to disable the SSL VPN global logging feature.
sslvpn log enable
The SSL VPN global logging feature is disabled.
context-admin
This feature logs the following global events:
·     SSL VPN access failures because of not associating SSL VPN contexts with gateways.
·     SSL VPN access failures because of not enabling SSL VPN contexts.
# Enable the SSL VPN global logging feature.
[Sysname] sslvpn log enable
sslvpn rbm-port
Use sslvpn rbm-port to specify the TCP port number used for RBM backup of SSL VPN user data.
Use undo sslvpn rbm-port to restore the default.
sslvpn rbm-port port-number
The TCP port number used for RBM backup of SSL VPN user data is 60065.
context-admin
port-number: Specifies the TCP port number used for RBM backup of SSL VPN user data, in the range of 1024 to 65535.
In the RBM network, the SSL VPN does not use the RBM control channel, but establishes its own backup channel for user data backup.
The sslvpn rbm-port and remote-ip commands configure the port number and the remote end IP address in a VRRP group, respectively, for the SSL VPN to establish the backup channel. The master in the VRRP group will synchronize user data to the backup. For more information about RBM, see High Availability Configuration Guide.
You need to use the sslvpn rbm-port command only on the master, and the backup will automatically synchronize the configuration.
# Specify the TCP port number as 60000 for RBM backup of SSL VPN user data.
[Sysname] sslvpn rbm-port 60000
remote-ip (High Availability Command Reference)
sslvpn webpage-customize
Use sslvpn webpage-customize to specify a global webpage template for SSL VPN webpage customization.
Use undo sslvpn webpage-customize to restore the default.
sslvpn webpage-customize template-name
SSL VPN uses the system default webpages.
context-admin
template-name: Specifies a webpage template by its name, a string of 1 to 31 characters. The name cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), quotation mark ("), question mark (?), left angle bracket (<), and right angle bracket (>).
This command allows you to set the global SSL VPN webpage template. Both predefined and user-defined webpage templates are available.
You can upload and download webpage templates through the SSL VPN Web interface. You can create a user-defined template by editing a downloaded predefined template.
To view all webpage templates in the system, use the display sslvpn webpage-customize template command.
In an SSL VPN context, the webpage template specified for the SSL VPN context takes precedence over the global SSL VPN webpage template. To specify a webpage template for an SSL VPN context, use the webpage-customize command in SSL VPN context view.
# Use webpage template template1 to customize SSL VPN webpages.
[Sysname] sslvpn webpage-customize template1
webpage-customize
timeout idle
Use timeout idle to set the idle timeout timer for SSL VPN sessions.
Use undo timeout idle to restore the default.
timeout idle minutes
undo timeout idle
The idle timeout timer is 30 minutes for SSL VPN sessions.
context-admin
seconds: Specifies the idle timeout timer in the range of 1 to 1440 minutes.
If the idle time of an SSL VPN session exceeds the specified idle timeout time, the session is terminated.
# Set the idle timeout timer to 50 minutes for SSL VPN sessions.
[Sysname-sslvpn-context-ctx1] timeout idle 50
display sslvpn policy-group
title
Use title to configure a title to be displayed on SSL VPN webpages.
Use undo title to restore the default.
title { chinese chinese-title | english english-title }
undo title { chinese | english }
The title is SSL VPN.
context-admin
chinese chinese-title: Configures a title in Chinese, a case-sensitive string of 1 to 255 characters.
english english-title: Configures a title in English, a case-sensitive string of 1 to 255 characters.
# Configure the title as SSL VPN service for company A.
[Sysname-sslvpn-context-ctx1] title english SSL VPN service for company A
uri-acl
Use uri-acl to create a URI ACL and enter its view, or enter the view of an existing URI ACL.
Use undo uri-acl to delete a URI ACL.
undo uri-acl uri-acl-name
No URI ACLs exist.
context-admin
uri-acl-name: Specifies a name for the URI ACL, a case-insensitive string of 1 to 31 characters.
A URI ACL is a set of rules that permit or deny access to resources. You can use URI ACLs for IP, TCP, and Web access filtering of SSL VPN users.
You can create multiple URI ACLs in an SSL VPN context.
# Create a URI ACL named uriacla and enter its view.
[Sysname] sslvpn context abc
url (file policy view)
Use url to specify the URL of the Web page file to be rewritten in a file policy.
Use undo url to restore the default.
url url
undo url
No file URL is specified in a file policy.
File policy view
context-admin
url: Specifies the complete file path, a case-insensitive string of 1 to 256 characters.
A file policy can be used to modify only the Web page file whose URL is the same as the URL configured in the policy.
A file URL is in the format of scheme://user:password@host:port/path. Table 14 describes the fields in the file URL.
Table 14 URL field descriptions
scheme
Protocol type. Options include http and https.
user:password
Username and password used to access the file.
host
Host name or IP address of the server where the file resides.
To specify an IPv6 address, enclose the IPv6 address in brackets. For example, http://[1234::5678]:8080/a.html.
port
Port number on which the server listens for resource access requests.
If you do not specify a port number, the default port number of the protocol is used, which is 80 for HTTP and 443 for HTTPS.
path
Local path of the file on the server.
You can specify only one file URL in a file policy. In the same SSL VPN context, the URL specified for each file policy must be unique.
# Specify a file URL for file policy fp.
[Sysname-sslvpn-context-ctx-file-policy-fp] url http://192.168.1.1:8080/js/test.js
url (URL item view)
Use url to specify a URL in a URL item.
Use undo url to remove the URL from a URL item.
url url
undo url
No URL is specified in a URL item.
URL item view
context-admin
url: Specifies a URL, a case-insensitive string of 1 to 253 characters in the format of protocol://host:port/path.
Table 15 describes the fields in a URL.
Table 15 URL field descriptions
protocol
·     http.
·     https.
If you do not specify a protocol name, the default protocol (HTTP) is used.
host
Domain name or IP address of a host.
To specify an IPv6 address, enclose the IPv6 address in brackets. For example. http://[1234::5678]:8080.
port
Port number.
path
Path to the resource on the host.
You can specify only one URL in a URL item. If you execute this command multiple times, the most recent configuration takes effect.
# Specify www.abc.com as the URL in URL item serverA.
[Sysname-sslvpn-context-ctx1-url-item-serverA] url www.abc.com
url-item
Use url-item to create a URL item and enter its view, or enter the view of an existing URL item.
Use undo url-item to delete a URL item.
undo url-item url-item-name
No URL items exist in an SSL VPN context.
context-admin
url-item-name: Specifies a name for the URL item, a case-insensitive string of 1 to 31 characters.
You can create multiple URL items in an SSL VPN context. Each URL item contains an accessible resource URL and can be assigned to a URL list in the SSL VPN context.
A URL item that has been assigned to a URL list cannot be deleted.
# Create a URL item named serverA and enter URL item view.
url-list
Use url-list to create a URL list and enter its view, or enter the view of an existing URL list.
Use undo url-list to delete a URL list.
url-list name
undo url-list name
No URL lists exist.
context-admin
name: Specifies a name for the URL list, a case-insensitive string of 1 to 31 characters.
# Create a URL list named url1 and enter URL list view.
[Sysname-sslvpn-context-ctx1] url-list url1
[Sysname-sslvpn-context-ctx1-url-list-url1]
sslvpn context
url-mapping
Use url-mapping to configure URL mapping in a URL item.
Use undo url-mapping to restore the default.
url-mapping { domain-mapping domain-name | port-mapping gateway gateway-name [ virtual-host virtual-host-name ] } [ rewrite-enable ]
undo url-mapping
The normal rewriting method is used.
URL item view
context-admin
domain-mapping domain-name: Specifies the domain name mapping method. This method maps the URL to a domain name, a case-insensitive string of 1 to 127 characters which can contain letters, digits, underscores (_), hyphens (-), and dots (.). The specified domain cannot be the same as the domain name of the SSL VPN gateway.
port-mapping gateway gateway-name: Specifies the port mapping method. This method maps the URL to a gateway name and an optional virtual host name. The gateway-name argument specifies the gateway name, a case-insensitive string of 1 to 31 characters which can contain letters, digits, and underscores (_). The specified SSL VPN gateway name must be the name of an existing SSL VPN gateway.
virtual-host virtual-host-name: Specifies the virtual host name, a case-insensitive string of 1 to 127 characters which can contain letters, digits, underscores (_), hyphens (-), and dots (.). Do not specify a virtual host name if you want to use the SSL VPN gateway exclusively for the URL item.
rewrite-enable: Enables the SSL VPN gateway to rewrite the absolute URLs in the resource access response returned from the internal server. These absolute URLs are generally the URLs linked to other servers from the internal server. If you do not specify this keyword, these absolute URLs are not accessible. Enable this rewriting feature as a best practice to improve user experience.
The SSL VPN gateway rewrites the resource URLs in resource access responses that contain HTML, XML, CSS, or JavaScript files before sending the URLs to the requesting users. By default, the normal rewriting method is used. You can also configure the SSL VPN gateway to use the domain mapping or port mapping method.
Normal rewriting might cause problems such as missed URL rewriting and rewriting errors, resulting in SSL VPN clients not being able to access the internal resources. Use domain mapping or port mapping as a best practice. For more information about these mapping methods, see SSL VPN configuration in Security Configuration Guide.
When configuring the domain mapping method, make sure the SSL VPN client can resolve the mapped domain name (through DNS or the Hosts file) into the IP address of the SSL VPN gateway.
When configuring the port mapping method, you can specify an SSL VPN gateway exclusively for a URL item by specifying the gateway name without a virtual host name. To share an SSL VPN gateway with other URL items or SSL VPN contexts, specify the SSL VPN gateway name together with a virtual host name.
If you execute this command for a URL item multiple times, the most recent configuration takes effect.
# Create URL item serverA and specify www.server.com as the resource URL. Map the resource URL to domain name www.domain.com and enable URL rewriting.
[Sysname-sslvpn-context-ctx1-url-item-serverA] url www.server.com
[Sysname-sslvpn-context-ctx1-url-item-serverA] url-mapping domain-mapping www.domain.com rewrite-enable
# Create URL item serverB and specify www.server.com as the resource URL. Map the resource URL to gateway gw1 with virtual host name host1 and enable URL rewriting.
[Sysname-sslvpn-context-ctx1] url-item serverB
[Sysname-sslvpn-context-ctx1-url-item-serverB] url www.server.com
[Sysname-sslvpn-context-ctx1-url-item-serverB] url-mapping port-mapping gateway gw1 virtual-host host1 rewrite-enable
url-item
url
user
Use user to create an SSL VPN user and enter SSL VPN user view, or enter the view of an existing SSL VPN user.
Use undo user to delete an SSL VPN user.
user username
undo user username
No SSL VPN users exist.
context-admin
username: Specifies the SSL VPN username, a case-sensitive string of 1 to 63 characters. The username cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), and at sign (@).
You can create multiple SSL VPN users in an SSL VPN context.
# Create SSL VPN user user1 and enter SSL VPN user view.
[Sysname-sslvpn-context-ctx] user user1
[Sysname-sslvpn-context-ctx-user-user1]
verify-code
Use verify-code enable to enable code verification.
Use undo verify-code enable to disable code verification.
verify-code enable
Code verification is disabled.
context-admin
After code verification is enabled, a user must enter a correct verification code to log in to the SSL VPN webpage.
# Enable code verification.
[Sysname-sslvpn-context-ctx] verify-code enable
vpn-instance (SSL VPN context view)
Use vpn-instance to associate an SSL VPN context with a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
An SSL VPN context is associated with the public network.
context-admin
vpn-instance-name: Specifies the name of a VPN instance, a case-sensitive string of 1 to 31 characters.
After you associate an SSL VPN context with a VPN instance, the resources managed by the context belong to the VPN instance.
An SSL VPN context can be associated with only one VPN instance.
You can associate an SSL VPN context with a nonexistent VPN instance. The context does not take effect until the associated VPN instance is created.
If you change the VPN instance associated with an SSL VPN context, all user-to-IP address bindings configured for SSL VPN users in the SSL VPN context will be removed.
# Associate SSL VPN context context1 with VPN instance vpn1.
<Sysname> System-view
[Sysname] sslvpn context context1
[Sysname-sslvpn-context-context1] vpn-instance vpn1
vpn-instance (SSL VPN gateway view)
Use vpn-instance to specify a VPN instance for an SSL VPN gateway.
undo vpn-instance
An SSL VPN gateway belongs to the public network.
context-admin
The VPN instance specified for an SSL VPN gateway is called a front VPN instance.
You can specify only one VPN instance for an SSL VPN gateway.
You can specify a nonexistent VPN instance for an SSL VPN gateway. The SSL VPN gateway does not take effect until the VPN instance is created.
# Specify VPN instance vpn1 for SSL VPN gateway gateway1.
[Sysname] sslvpn gateway gateway1
[Sysname-sslvpn-gateway-gateway1] vpn-instance vpn1
web-access ip-client auto-activate
Use web-access ip-client auto-activate to enable automatic startup of the IP access client after Web login.
Use undo web-access ip-client auto-activate to disable automatic startup of the IP access client after Web login.
Automatic startup of the IP access client after Web login is disabled.
context-admin
With this feature enabled, after a user logs in to the SSL VPN gateway through a Web browser, the IP access client on the user host will automatically connect to the gateway. If the IP access client software is not installed, the user will be prompted to install the software first.
For the IP access client to connect to the SSL VPN gateway correctly, make sure the IP access service and resources are configured on the SSL VPN gateway.
If an SSL VPN user has already logged in through an IP access client when this feature is enabled, the user cannot access the SSL VPN gateway directly through the Web browser. To access the SSL VPN gateway through the Web browser, the user must click Open Resource List in the IP access client.
# Enable automatic startup of the IP access client after Web login in SSL VPN context ctx1.
[Sysname] sslvpn context ctx1
[Sysname-sslvpn-context-ctx1] web-access ip-client auto-activate
webpage-customize
Use webpage-customize to specify a webpage template for SSL VPN webpage customization.
Use undo webpage-customize to restore the default.
The global SSL VPN webpage template is used.
context-admin
This command allows you to set the webpage template for an SSL VPN context. Both predefined and user-defined webpage templates are available.
In an SSL VPN context, the webpage template specified for the SSL VPN context takes precedence over the global SSL VPN webpage template. To set the global SSL VPN webpage template, use the sslvpn webpage-customize command in system view.
If a user-defined webpage template is specified in an SSL VPN context, all other webpage customization settings are invalid for the SSL VPN context.
# Use webpage template template1 to customize SSL VPN webpages in SSL VPN context ctx.
[Sysname-sslvpn-context-ctx] webpage-customize template1
