03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command References(V7)-6W40003-Security Command Reference
25-IP reputation commands
25-IP reputation commands 73.50 KB
The following compatibility matrixes show the support of hardware platforms for IP reputation:
Hardware
IP reputation compatibility
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3
Yes
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3
Yes
F1000-E-VG, F1000-S-VG
Yes
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2
Yes
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2
Yes
F1000-C-EI, F100-A-EI, F100-A-SI, F100-C-EI, F100-E-EI
Yes
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet
Yes
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110
Yes
F100-C-A6, F100-C-A5, F100-C-A3
Yes
F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W
No
F1000-C-HI, F100-A-HI, F100-C-HI, F100-S-HI
Yes
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI
Yes
LSPM6FWD8, LSQM2FWDSC8
Yes
display ip-reputation attack-category
Use display ip-reputation attack-category to display information about attack categories for IP reputation.
context-admin
context-operator
The command displays attack category information after IP reputation is enabled.
If you do not specify actions for an attack category, the pre-defined actions are displayed.
# Display information about attack categories for IP reputation.
<Sysname> display ip-reputation attack-category
ID      Attack name      Action      Logging
1       ddos              permit      enabled
2       web               deny         disabled
Figure 1 Command output
ID
Attack category ID.
Attack name
Attack category name.
Action
Action that the device takes on packets matching the attack category.
·     permit—Forwards the packets.
·     deny—Discards the packets.
Logging
Logging status, enabled or disabled.
attack-category
display ip-reputation exception
Use display ip-reputation exception to display exception IP addresses.
context-admin
context-operator
The command displays exception IP addresses, if any, when the IP reputation is enabled.
# Display exception IP addresses.
<Sysname> display ip-reputation exception
IP address
10.1.1.1
10.10.1.1
Figure 2 Command output
IP address
Exception IP address.
display ip-reputation top-hit-statistics
Use display ip-reputation top-hit-statistics to display statistics for IP addresses with the highest hits on the IP reputation list.
display ip-reputation top-hit-statistics [ top-number ] [ slot slot-number ]
context-admin
context-operator
top-number: Specifies the number of top ranking IP addresses. The value range is 10 to 100, and the default is 10.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics for IP addresses with the highest hits on the IP reputation list for all member devices.
This command displays statistics for IP addresses with the highest hits on the IP reputation list when the top hit ranking feature is enabled.
This command does not display IP addresses with no hits. Therefore, the number of IP addresses in the command output might be less than the value of the top-number argument.
# Display statistics for 10 IP addresses with the highest hits on the IP reputation list.
<Sysname> display ip-reputation top-hit-statistics 10 slot 1
Slot 1:
IP address      Hit count
10.1.1.1        1000
10.1.1.2        999
10.1.1.3        996
10.1.1.4        994
10.1.1.5        994
10.1.1.6        994
Figure 3 Command output
IP address
IP address on the IP reputation list.
Hit count
Number of times that the IP address is hit.
Use display ip-reputation to display IP reputation information about an IP address.
display ip-reputation ipv4 ipv4-address
context-admin
context-operator
ipv4 ipv4-address: Specifies an IPv4 address.
The IP reputation list contains the following attribute information for an IP address: attack category, match field, actions on matching packets, and the hit count.
If an IP address belongs to multiple attack categories, the command displays information about the IP address based on the attack category ID.
# Display IP reputation information about IP address 192.168.1.1.
<Sysname> display ip-reputation ipv4 192.168.1.1
IP address    Attack ID    Attack name    Direction    Action    Logging    Hit count
192.168.1.1   1             ddos             src           deny      enabled    1000
                2             web              dst           permit    disabled
Figure 4 Command output
IP address
Attack ID
ID of the attack category to which the IP address belongs.
Attack name
Name of the attack category to which the IP address belongs.
Direction
Match field attribute of the IP address:
·     src—Used as the source IP address match criterion.
·     dst—Used as the destination IP address match criterion.
·     src/dst—Used as the source or destination IP address match criterion.
Action
Action on matching packets:
·     permit—Allows the packets to pass through.
·     deny—Drops the packets.
Logging
Hit count
Number of times that the IP address is matched.
ip-reputation
Use ip-reputation to enter IP reputation view.
Use undo ip-reputation to delete all configuration in IP reputation view.
ip-reputation
undo ip-reputation
context-admin
# Enter IP reputation view.
[Sysname] ip-reputation
[Sysname-ip-reputation]
attack-category
Use attack-category to configure actions for an attack category.
Use undo attack-category to restore the default.
attack-category attack-id { action { deny | permit } | logging { disable | enable } } *
undo attack-category attack-id
No actions are configured for an attack category. Each attack category has its own pre-defined actions.
IP reputation view
context-admin
attack-id: Specifies an attack category ID. The value range depends on the IP reputation file and the device model.
action: Specifies an action.
deny: Drops matching packets.
permit: Allows matching packets to pass through.
logging: Sets the logging status for the attack category. When a packet matches the attack category with logging enabled, the device generates logs for the matching events.
disable: Disables logging for the matching events.
enable: Enables logging for the matching events.
The command configuration takes effect after you enable IP reputation.
On the IP reputation list, an IP address can belong to multiple attack categories. Each attack category has its own actions.
If an IP address belongs to only one attack category, the device takes the actions in this attack category. If an IP address belongs to multiple attack categories, the device takes an action that has higher priority among all actions in those attack categories. The drop action has higher priority than the permit action.
If logging is enabled for any one of attack categories to which an IP address belongs, the device generates a log when the IP address is matched.
The device supports fast output of IP reputation logs. For more information about fast log output, see fast log output commands in Network Management and Monitoring Command Reference.
# Set the action to deny for attack category 1 and enable logging for the attack category.
[Sysname-ip-reputation] attack-category 1 action deny logging enable
global enable
exception
Use exception to specify an exception IP address.
Use undo exception to remove an exception IP address.
exception ipv4 ipv4-address
undo exception ipv4 ipv4-address
No exception IP address is specified.
IP reputation view
context-admin
ipv4 ipv4-address: Specifies an exception IPv4 address.
The command takes effect after you enable IP reputation.
The device forwards a packet if the source or destination IP address of the packet is an exception IP address.
Repeat this command to add multiple exception IP addresses.
# Specify 192.168.1.1 as an exception IP address.
[Sysname-ip-reputation] exception ipv4 192.168.1.1
global enable
global enable
Use global enable to enable IP reputation globally.
Use undo global enable to disable IP reputation globally.
global enable
undo global enable
IP reputation is disabled globally.
IP reputation view
context-admin
# Enable IP reputation globally.
[Sysname-ip-reputation] global enable
top-hit-statistics enable
Use top-hit-statistics enable to enable the top hit ranking feature for IP addresses.
Use undo top-hit-statistics enable to disable the top hit ranking feature.
The top hit ranking feature is disabled for IP addresses on the IP reputation list.
IP reputation view
context-admin
This feature takes effect after you enable IP reputation.
This feature enables the device to collect hit statistics for IP addresses on the IP reputation list and rank them. After you disable this feature, the device clears hit statistics for IP reputation.
# Enable the top hit ranking feature for IP addresses on the IP reputation list.
[Sysname-ip-reputation] top-hit-statistics enable
