| 01-gRPC commands | 83.26 KB |
destination-group (subscription view)
destination-group (telemetry view)
sensor-group (subscription view)
gRPC commands
gRPC dial-in mode commands
display grpc
Use display grpc to display gRPC dial-in mode information.
display grpc
# Display gRPC dial-in mode information.
<Sysname> display grpc
gRPC status : enabled.
gRPC port : 50051
gRPC idle-timeout : 3 minutes
Session count: 1.
Session ID: 1
User name: test
Login time:2018-01-05 06:46:43 Idle time : 2 mins 56 s
Client IP address : 169.254.100.170:40810
Received RPCs : 0 Received error RPCs : 0
Received subscription: 0 Output notifications: 0
gRPC status |
Status of the gRPC service: · enabled—The gRPC service is enabled. · disabled—The gRPC service is disabled. |
gRPC idle-timeout |
Setting for the gRPC session idle timeout timer. |
Session count |
Number of gRPC sessions. |
Idle time |
Duration in which the session idle timeout timer will expire. If the value of this field is 0, gRPC sessions will never be timed out. |
Received error RPCs |
Number of received erroneous gRPC requests. |
Received subscription |
Number of received gRPC subscription requests. |
grpc enable
Use grpc enable to enable the gRPC service.
Use undo grpc enable to disable the gRPC service.
grpc enable
undo grpc enable
If this command fails, use the display tcp or display ipv6 tcp command to verify whether the gRPC service port number has been used by another feature. If yes, specify a free port as the gRPC service port number and try to enable the gRPC service again.
# Enable the gRPC service.
<Sysname> system
[Sysname] grpc enable
display ipv6 tcp (Layer 3—IP Services Command Reference)
display tcp (Layer 3—IP Services Command Reference)
grpc port
grpc idle-timeout
Use grpc idle-timeout to set the gRPC session idle timeout timer.
Use undo grpc idle-timeout to restore the default.
grpc idle-timeout minutes
The gRPC session idle timeout timer is 5 minutes.
minutes: Specifies the gRPC session idle timeout timer in minutes, in the range of 0 to 30. To disable gRPC sessions from being timed out, set it to 0.
If no gRPC packet exchanges occur on the session between a gRPC and the server before the idle timeout timer expires, the device closes the session.
# Set the gRPC session idle timeout timer to 6 minutes.
<Sysname> system
[Sysname] grpc idle-timeout 6
grpc port
Use grpc port to specify the gRPC service port number.
Use undo grpc port to restore the default.
grpc port port-number
undo grpc port
The gRPC service port number is 50051.
port-number: Specifies the gRPC service port number, in the range of 1 to 65535.
You can configure this command only when the gRPC service is disabled.
# Set the gRPC service port number to 50052.
<Sysname> system
[Sysname] grpc port 50052
grpc enable
gRPC dial-out mode commands
Use destination-group to specify a destination group for a subscription.
Use undo destination-group to remove a destination group from a subscription.
destination-group group-name
undo destination-group group-name
A subscription does not have a destination group.
Subscription view
group-name: Specifies a destination group by its name, a case-sensitive string of 1 to 31 characters.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
The specified destination group must have been created by using the destination-group command in telemetry view.
You can specify a maximum of five destination groups for a subscription.
# Specify destination group collector1 for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscription A
[Sysname-telemetry-subscription-A] destination-group collector1
Use destination-group to create a destination group and enter its view, or enter the view of an existing destination group.
Use undo destination-group to delete a destination group.
No destination groups exist.
Telemetry view
group-name: Specifies the destination group name, a case-sensitive string of 1 to 31 characters.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
# Create a destination group named collector1.
[Sysname] telemetry
[Sysname-telemetry] destination-group collector1
[Sysname-telemetry-destination-group-collector1]
ipv4-address
Use ipv4-address to add an IPv4 collector to a destination group.
Use undo ipv4-address to remove an IPv4 collector from a destination group.
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv4 collectors.
Destination group view
ipv4-address: Specifies the IPv4 address of the collector.
port port-number: Specifies the listening port of the collector, in the range of 1 to 65535. The default is 50051.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the collector belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the collector belongs to the public network, do not specify this option.
To add multiple collectors to a destination group, execute this command multiple times.
One collector must have a different address, port, or VPN instance than the other collectors.
You can specify a maximum of five collectors for a destination group.
# Add a collector that uses IPv4 address 192.168.21.21 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv4-address 192.168.21.21
ipv6-address
Use ipv6-address to add an IPv6 collector to a destination group.
Use undo ipv6-address to remove an IPv6 collector from a destination group.
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv6 collectors.
ipv6-address: Specifies the IPv6 address of the collector.
# Add a collector that uses IPv6 address 1: : 1 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv6-address 1: : 1
sensor path
Use sensor path to configure a sensor path.
Use undo sensor path to delete a sensor path.
sensor path path
undo sensor path path
No sensor paths exist.
Sensor group view
path: Specifies a data path. For information about the available paths, enter a question mark (?) in the position of this argument.
To configure multiple sensor paths, execute this command multiple times.
The device supports a maximum of 128 sensor paths.
If the device does not support the specified sensor path, the command displays an error message.
# Configure sensor path ifmgr/devicecapabilities/ for sensor group test.
[Sysname] telemetry
[Sysname-telemetry] sensor-group test
[Sysname-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities/
sensor-group (telemetry view)
Use sensor-group to specify a sensor group for a subscription.
Use undo sensor-group to remove a sensor group from a subscription.
sensor-group group-name [ sample-interval interval ]
undo sensor-group group-name
A subscription does not have a sensor group.
Subscription view
group-name: Specifies a sensor group by its name, a case-sensitive string of 1 to 31 characters.
sample-interval interval: Specifies the data sampling interval in seconds. The value range is 1 to 86400.
Specify the sample-interval interval option for periodic sensor paths and only for periodic sensor paths.
· If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
· If you do not specify the option for periodic sensor paths, the device does not sample or push data.
The specified sensor group must have been created by using the sensor-group command in telemetry view.
# Specify sensor group test for subscription A. Set the data sampling interval to 10 seconds.
[Sysname] telemetry
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
sensor path
Use sensor-group to create a sensor group and enter its view, or enter the view of an existing sensor group.
Use undo sensor-group to delete a sensor group.
No sensor groups exist.
Telemetry view
group-name: Specifies the sensor group name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 32 sensor groups.
# Create a sensor group named test.
[Sysname] telemetry
source-address
Use source-address to specify the source IP address for packets sent to collectors.
Use undo source-address to restore the default.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo source-address
The device uses the primary IPv4 address of the output interface for the route to the collectors as the source address.
Subscription view
ipv4-address: Specifies an IPv4 address.
interface interface-type interface-number: Specifies an interface by its type and number. In the current software version, you must specify a loopback interface. The device will use the interface's primary IPv4 address as the source address. If the interface does not have a primary IPv4 address, the device uses the primary IPv4 address of the output interface for the route to the collectors.
ipv6 ipv6-address: Specifies an IPv6 address.
Changing the source IP address for packets sent to collectors causes the device to re-establish the connection to the gRPC server.
# Specify the source IPv4 address of 169.254.1.1 for packets sent to collectors.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] source-address 169.254.1.1
subscription
Use subscription to create a subscription and enter its view, or enter the view of an existing subscription.
Use undo sensor-group to delete a subscription.
subscription subscription-name
undo subscription subscription-name
No subscription groups exist.
Telemetry view
subscription-name: Specifies the subscription name, a case-sensitive string of 1 to 31 characters.
The device supports a maximum of 10 subscriptions.
# Configure a subscription named A.
[Sysname] telemetry
telemetry
Use telemetry to enter telemetry view.
telemetry
In telemetry view, you can configure telemetry parameters.
# Enter telemetry view.
[Sysname] telemetry
[Sysname-telemetry]
